__u16 sco_pkt_type is introduced to struct sockaddr_sco. It allows bitwise
selection of SCO/eSCO packet types. Currently those bits are:
0x0001 HV1 may be used.
0x0002 HV2 may be used.
0x0004 HV3 may be used.
0x0008 EV3 may be used.
0x0010 EV4 may be used.
0x0020 EV5 may be used.
0x0040 2-EV3 may be used.
0x0080 3-EV3 may be used.
0x0100 2-EV5 may be used.
0x0200 3-EV5 may be used.
This is similar to the Packet Type parameter in the HCI Setup Synchronous
Connection Command, except that we are not reversing the logic on the EDR bits.
This makes the use of sco_pkt_tpye forward portable for the use case of
white-listing packet types, which we expect will be the primary use case.
If sco_pkt_type is zero, or userspace uses the old struct sockaddr_sco,
then the default behavior is to allow all packet types.
Packet type selection is just a request made to the Bluetooth chipset, and
it is up to the link manager on the chipset to negiotiate and decide on the
actual packet types used. Furthermore, when a SCO/eSCO connection is eventually
made there is no way for the host stack to determine which packet type was used
(however it is possible to get the link type of SCO or eSCO).
sco_pkt_type is ignored for incoming SCO connections. It is possible
to add this in the future as a parameter to the Accept Synchronous Connection
Command, however its a little trickier because the kernel does not
currently preserve sockaddr_sco data between userspace calls to accept().
The most common use for sco_pkt_type will be to white-list only SCO packets,
which can be done with the hci.h constant SCO_ESCO_MASK.
This patch is motivated by broken Bluetooth carkits such as the Motorolo
HF850 (it claims to support eSCO, but will actually reject eSCO connections
after 5 seconds) and the 2007/2008 Infiniti G35/37 (fails to route audio
if a 2-EV5 packet type is negiotiated). With this patch userspace can maintain
a list of compatible packet types to workaround remote devices such as these.
Based on a patch by Marcel Holtmann.
Rebased to 2.6.39.
Change-Id: Ide1c89574fa4f6f1b9218282e1af17051eb86315
Signed-off-by: Nick Pelly <npelly@google.com>
The Bluetooth stack has internal connection handlers for all of the various
Bluetooth protocols, and unfortunately, they are currently lacking the LSM
hooks found in the core network stack's connection handlers. I say
unfortunately, because this can cause problems for users who have have an
LSM enabled and are using certain Bluetooth devices. See one problem
report below:
* http://bugzilla.redhat.com/show_bug.cgi?id=741703
In order to keep things simple at this point in time, this patch fixes the
problem by cloning the parent socket's LSM attributes to the newly created
child socket. If we decide we need a more elaborate LSM marking mechanism
for Bluetooth (I somewhat doubt this) we can always revisit this decision
in the future.
Reported-by: James M. Cape <jcape@ignore-your.tv>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
Fix race conditions which can cause lost wakeups (or missed signals)
while waiting to accept a sco socket connection.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Make it easier to use more normal logging styles later.
shutdown should wait for SCO link to be properly disconnected before
detroying the socket, otherwise an application using the socket may
assume link is properly disconnected before it really happens which
can be a problem when e.g synchronizing profile switch.
Signed-off-by: Luiz Augusto von Dentz <luiz.dentz-von@nokia.com>
This reverts commit f21ca5fff6e548833fa5ee8867239a8378623150.
Quoth Gustavo F. Padovan:
"Commit f21ca5fff6e548833fa5ee8867239a8378623150 can cause a NULL
dereference if we call shutdown in a bluetooth SCO socket and doesn't
wait the shutdown completion to call close(). Please revert it. I
may have a fix for it soon, but we don't have time anymore, so revert
is the way to go. ;)"
Requested-by: Gustavo F. Padovan <padovan@profusion.mobi>
Use ERR_PTR mechanism to return error from hci_connect.
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
Signed-off-by: Anderson Briglia <anderson.briglia@openbossa.org>
Actually doesn't make sense have these modules built separately.
The L2CAP layer is needed by almost all Bluetooth protocols and profiles.
There isn't any real use case without having L2CAP loaded.
SCO is only essential for Audio transfers, but it is so small that we can
have it loaded always in bluetooth.ko without problems.
If you really doesn't want it you can disable SCO in the kernel config.
struct sco_conninfo has one padding byte in the end. Local variable
cinfo of type sco_conninfo is copied to userspace with this uninizialized
one byte, leading to old stack contents leak.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Do not use assignments in IF condition, remove extra spaces
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
Return 0 in that situation could lead to errors in the caller.
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
Remove extra braces and labels, break over column 80 lines, etc
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
It also removes an unneeded check for the MTU. The check is done before
on sco_send_frame()
Reviewed-by: João Paulo Rechi Vita <jprvita@profusion.mobi>
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
check the length of the socket address passed to connect(2).
Check the length of the socket address passed to connect(2). If the
length is invalid, -EINVAL will be returned.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
net/bluetooth/l2cap.c | 3 ++-
net/bluetooth/rfcomm/sock.c | 3 ++-
net/bluetooth/sco.c | 3 ++-
net/can/bcm.c | 3 +++
net/ieee802154/af_ieee802154.c | 3 +++
net/ipv4/af_inet.c | 5 +++++
net/netlink/af_netlink.c | 3 +++
7 files changed, 20 insertions(+), 3 deletions(-)
Some of the debug files ended up wrongly in sysfs, because at that point
of time, debugfs didn't exist. Convert these files to use debugfs and
also seq_file. This patch converts all of these files at once and then
removes the exported symbol for the Bluetooth sysfs class.
When creating a high number of Bluetooth sockets (L2CAP, SCO
and RFCOMM) it is possible to scribble repeatedly on arbitrary
pages of memory. Ensure that the content of these sysfs files is
always less than one page. Even if this means truncating. The
files in question are scheduled to be moved over to debugfs in
the future anyway.
Based on initial patches from Neil Brown and Linus Torvalds
Reported-by: Neil Brown <neilb@suse.de>
Passing the attribute to the low level IO functions allows all kinds
of cleanups, by sharing low level IO code without requiring
an own function for every piece of data.
Also drivers can extend the attributes with own data fields
and use that in the low level function.
This makes the class attributes the same as sysdev_class attributes
and plain attributes.
This will allow further cleanups in drivers.
Full tree sweep converting all users.
The generic __sock_create function has a kern argument which allows the
security system to make decisions based on if a socket is being created by
the kernel or by userspace. This patch passes that flag to the
net_proto_family specific create function, so it can do the same thing.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
All usages of structure net_proto_ops should be declared const.
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
The SCO sockets for Bluetooth audio setup and streaming are missing the
shutdown implementation. This hasn't been a problem so far, but with a
more deeper integration with PulseAudio it is important to shutdown SCO
sockets properly.
Also the Headset profile 1.2 has more detailed qualification tests that
require that SCO and RFCOMM channels are terminated in the right order. A
proper shutdown function is necessary for this.
Based on a report by Johan Hedberg <johan.hedberg@nokia.com>
Tested-by: Johan Hedberg <johan.hedberg@nokia.com>
Some of the qualification tests demand that in case of failures in L2CAP
the HCI disconnect should indicate a reason why L2CAP fails. This is a
bluntly layer violation since multiple L2CAP connections could be using
the same ACL and thus forcing a disconnect reason is not a good idea.
To comply with the Bluetooth test specification, the disconnect reason
is now stored in the L2CAP connection structure and every time a new
L2CAP channel is added it will set back to its default. So only in the
case where the L2CAP channel with the disconnect reason is really the
last one, it will propagated to the HCI layer.
The HCI layer has been extended with a disconnect indication that allows
it to ask upper layers for a disconnect reason. The upper layer must not
support this callback and in that case it will nicely default to the
existing behavior. If an upper layer like L2CAP can provide a disconnect
reason that one will be used to disconnect the ACL or SCO link.
No modification to the ACL disconnect timeout have been made. So in case
of Linux to Linux connection the initiator will disconnect the ACL link
before the acceptor side can signal the specific disconnect reason. That
is perfectly fine since Linux doesn't make use of this value anyway. The
L2CAP layer has a perfect valid error code for rejecting connection due
to a security violation. It is unclear why the Bluetooth specification
insists on having specific HCI disconnect reason.
The current security model is based around the flags AUTH, ENCRYPT and
SECURE. Starting with support for the Bluetooth 2.1 specification this is
no longer sufficient. The different security levels are now defined as
SDP, LOW, MEDIUM and SECURE.
Previously it was possible to set each security independently, but this
actually doesn't make a lot of sense. For Bluetooth the encryption depends
on a previous successful authentication. Also you can only update your
existing link key if you successfully created at least one before. And of
course the update of link keys without having proper encryption in place
is a security issue.
The new security levels from the Bluetooth 2.1 specification are now
used internally. All old settings are mapped to the new values and this
way it ensures that old applications still work. The only limitation
is that it is no longer possible to set authentication without also
enabling encryption. No application should have done this anyway since
this is actually a security issue. Without encryption the integrity of
the authentication can't be guaranteed.
As default for a new L2CAP or RFCOMM connection, the LOW security level
is used. The only exception here are the service discovery sessions on
PSM 1 where SDP level is used. To have similar security strength as with
a Bluetooth 2.0 and before combination key, the MEDIUM level should be
used. This is according to the Bluetooth specification. The MEDIUM level
will not require any kind of man-in-the-middle (MITM) protection. Only
the HIGH security level will require this.
All SCO and eSCO connection are auto-accepted no matter if there is a
corresponding listening socket for them. This patch changes this and
connection requests for SCO and eSCO without any socket are rejected.
The socket option levels SOL_L2CAP, SOL_RFOMM and SOL_SCO are currently
in use by various Bluetooth applications. Going forward the common
option level SOL_BLUETOOTH should be used. This patch prepares the clean
split of the old and new option levels while keeping everything backward
compatibility.
With the introduction of CONFIG_DYNAMIC_PRINTK_DEBUG it is possible to
allow debugging without having to recompile the kernel. This patch turns
all BT_DBG() calls into pr_debug() to support dynamic debug messages.
As a side effect all CONFIG_BT_*_DEBUG statements are now removed and
some broken debug entries have been fixed.
With the introduction of Security Mode 4 and Simple Pairing from the
Bluetooth 2.1 specification it became mandatory that the initiator
requires authentication and encryption before any L2CAP channel can
be established. The only exception here is PSM 1 for the service
discovery protocol (SDP). It is meant to be used without any encryption
since it contains only public information. This is how Bluetooth 2.0
and before handle connections on PSM 1.
For Bluetooth 2.1 devices the pairing procedure differentiates between
no bonding, general bonding and dedicated bonding. The L2CAP layer
wrongly uses always general bonding when creating new connections, but it
should not do this for SDP connections. In this case the authentication
requirement should be no bonding and the just-works model should be used,
but in case of non-SDP connection it is required to use general bonding.
If the new connection requires man-in-the-middle (MITM) protection, it
also first wrongly creates an unauthenticated link key and then later on
requests an upgrade to an authenticated link key to provide full MITM
protection. With Simple Pairing the link key generation is an expensive
operation (compared to Bluetooth 2.0 and before) and doing this twice
during a connection setup causes a noticeable delay when establishing
a new connection. This should be avoided to not regress from the expected
Bluetooth 2.0 connection times. The authentication requirements are known
up-front and so enforce them.
To fulfill these requirements the hci_connect() function has been extended
with an authentication requirement parameter that will be stored inside
the connection information and can be retrieved by userspace at any
time. This allows the correct IO capabilities exchange and results in
the expected behavior.
The Bluetooth entries for the MAINTAINERS file are a little bit too
much. Consolidate them into two entries. One for Bluetooth drivers and
another one for the Bluetooth subsystem.
Also the MODULE_AUTHOR should indicate the current maintainer of the
module and actually not the original author. Fix all Bluetooth modules
to provide current maintainer information.
It has been reported that some eSCO capable headsets are not able to
connect properly. The real reason for this is unclear at the moment. So
for easier testing add a module parameter to disable eSCO connection
creation.
Enable the common timestamp functionality that the network subsystem
provides for L2CAP, RFCOMM and SCO sockets. It is possible to either
use SO_TIMESTAMP or the IOCTLs to retrieve the timestamp of the
current packet.
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/s2io.c
The older RW_LOCK_UNLOCKED macros defeat lockdep state tracing so
replace them with the newer __RW_LOCK_UNLOCKED macros.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Introduce per-sock inlines: sock_net(), sock_net_set()
and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Many-many code in the kernel initialized the timer->function
and timer->data together with calling init_timer(timer). There
is already a helper for this. Use it for networking code.
The patch is HUGE, but makes the code 130 lines shorter
(98 insertions(+), 228 deletions(-)).
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Finally, the zero_it argument can be completely removed from
the callers and from the function prototype.
Besides, fix the checkpatch.pl warnings about using the
assignments inside if-s.
This patch is rather big, and it is a part of the previous one.
I splitted it wishing to make the patches more readable. Hope
this particular split helped.
With the Bluetooth 1.2 specification the Extended SCO feature for
better audio connections was introduced. So far the Bluetooth core
wasn't able to handle any eSCO connections correctly. This patch
adds simple eSCO support while keeping backward compatibility with
older devices.
This patch passes in the namespace a new socket should be created in
and has the socket code do the appropriate reference counting. By
virtue of this all socket create methods are touched. In addition
the socket create methods are modified so that they will fail if
you attempt to create a socket in a non-default network namespace.
Failing if we attempt to create a socket outside of the default
network namespace ensures that as we incrementally make the network stack
network namespace aware we will not export functionality that someone
has not audited and made certain is network namespace safe.
Allowing us to partially enable network namespaces before all of the
exotic protocols are supported.
Any protocol layers I have missed will fail to compile because I now
pass an extra parameter into the socket creation code.
[ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ]
Spring cleaning time...
There seems to be a lot of places in the network code that have
extra bogus semicolons after conditionals. Most commonly is a
bogus semicolon after: switch() { }
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
The bt_proto array needs to be protected by some kind of locking to
prevent a race condition between bt_sock_create and bt_sock_register.
And in addition all calls to sk_alloc need to be made GFP_ATOMIC now.
Signed-off-by: Masatake YAMATO <jet@gyve.org>
Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com>
Some return values of the driver core register and create functions
are not handled and so might cause unexpected problems.
This patch makes the remaining transitions to use kzalloc().
This patch converts the Bluetooth class devices into real devices. The
Bluetooth class is kept and the driver core provides the appropriate
symlinks for backward compatibility.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
this fixes coverity bug id #1068.
hci_send_sco() frees skb if (skb->len > hdev->sco_mtu).
Since it returns a negative error value only in this case, we
can directly return here.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
I noticed that some of 'struct proto_ops' used in the kernel may share
a cache line used by locks or other heavily modified data. (default
linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at
least)
This patch makes sure a 'struct proto_ops' can be declared as const,
so that all cpus can share all parts of it without false sharing.
This is not mandatory : a driver can still use a read/write structure
if it needs to (and eventually a __read_mostly)
I made a global stubstitute to change all existing occurences to make
them const.
This should reduce the possibility of false sharing on SMP, and
speedup some socket system calls.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
It also looks like there were 2 places where the test on sk_err was
missing from the event wait logic (in sk_stream_wait_connect and
sk_stream_wait_memory), while the rest of the sock_error() users look
to be doing the right thing. This version of the patch fixes those,
and cleans up a few places that were testing ->sk_err directly.
Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com>
