path: root/net/bluetooth
2009-08-03bluetooth: rfcomm_init bug fixDave Young
rfcomm tty may be used before rfcomm_tty_driver initilized, The problem is that now socket layer init before tty layer, if userspace program do socket callback right here then oops will happen. reporting in: http://marc.info/?l=linux-bluetooth&m=124404919324542&w=2 make 3 changes: 1. remove #ifdef in rfcomm/core.c, make it blank function when rfcomm tty not selected in rfcomm.h 2. tune the rfcomm_init error patch to ensure tty driver initilized before rfcomm socket usage. 3. remove __exit for rfcomm_cleanup_sockets because above change need call it in a __init function. Reported-by: Oliver Hartkopp <oliver@hartkopp.net> Tested-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-14Bluetooth: Fix Kconfig issue with RFKILL integrationMarcel Holtmann
Since the re-write of the RFKILL subsystem it is no longer good to just select RFKILL, but it is important to add a proper depends on rule. Based on a report by Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-11Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-next-2.6
2009-06-08Bluetooth: Add native RFKILL soft-switch support for all devicesMarcel Holtmann
With the re-write of the RFKILL subsystem it is now possible to easily integrate RFKILL soft-switch support into the Bluetooth subsystem. All Bluetooth devices will now get automatically RFKILL support. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Remove pointless endian conversion helpersMarcel Holtmann
The Bluetooth source uses some endian conversion helpers, that in the end translate to kernel standard routines. So remove this obfuscation since it is fully pointless. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Add basic constants for L2CAP ERTM support and use themMarcel Holtmann
This adds the basic constants required to add support for L2CAP Enhanced Retransmission feature. Based on a patch from Nathan Holstein <nathan@lampreynetworks.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Fix errors and warnings in L2CAP reported by checkpatch.plGustavo F. Padovan
This patch fixes the errors without changing the l2cap.o binary: text data bss dec hex filename 18059 568 0 18627 48c3 l2cap.o.after 18059 568 0 18627 48c3 l2cap.o.before Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Remove unnecessary variable initializationMarcel Holtmann
The initial value of err is not used until it is set to -ENOMEM. So just remove the initialization completely. Based on a patch from Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Use macro for L2CAP hint mask on receiving config requestGustavo F. Padovan
Using the L2CAP_CONF_HINT macro is easier to understand than using a hardcoded 0x80 value. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Use macros for L2CAP channel identifiersGustavo F. Padovan
Use macros instead of hardcoded numbers to make the L2CAP source code more readable. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08isdn: rename capi_ctr_reseted() to capi_ctr_down()Tilman Schmidt
Change the name of the Kernel CAPI exported function capi_ctr_reseted() to something representing its purpose better. Impact: renaming, no functional change Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-27Bluetooth: Remove useless flush_work() causing lockdep warningsDave Young
The calls to flush_work() are pointless in a single thread workqueue and they are actually causing a lockdep warning. ============================================= [ INFO: possible recursive locking detected ] 2.6.30-rc6-02911-gbb803cf #16 --------------------------------------------- bluetooth/2518 is trying to acquire lock: (bluetooth){+.+.+.}, at: [<c0130c14>] flush_work+0x28/0xb0 but task is already holding lock: (bluetooth){+.+.+.}, at: [<c0130424>] worker_thread+0x149/0x25e other info that might help us debug this: 2 locks held by bluetooth/2518: #0: (bluetooth){+.+.+.}, at: [<c0130424>] worker_thread+0x149/0x25e #1: (&conn->work_del){+.+...}, at: [<c0130424>] worker_thread+0x149/0x25e stack backtrace: Pid: 2518, comm: bluetooth Not tainted 2.6.30-rc6-02911-gbb803cf #16 Call Trace: [<c03d64d9>] ? printk+0xf/0x11 [<c0140d96>] __lock_acquire+0x7ce/0xb1b [<c0141173>] lock_acquire+0x90/0xad [<c0130c14>] ? flush_work+0x28/0xb0 [<c0130c2e>] flush_work+0x42/0xb0 [<c0130c14>] ? flush_work+0x28/0xb0 [<f8b84966>] del_conn+0x1c/0x84 [bluetooth] [<c0130469>] worker_thread+0x18e/0x25e [<c0130424>] ? worker_thread+0x149/0x25e [<f8b8494a>] ? del_conn+0x0/0x84 [bluetooth] [<c0133843>] ? autoremove_wake_function+0x0/0x33 [<c01302db>] ? worker_thread+0x0/0x25e [<c013355a>] kthread+0x45/0x6b [<c0133515>] ? kthread+0x0/0x6b [<c01034a7>] kernel_thread_helper+0x7/0x10 Based on a report by Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Tested-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-05-09Bluetooth: Don't trigger disconnect timeout for security mode 3 pairingMarcel Holtmann
A remote device in security mode 3 that tries to connect will require the pairing during the connection setup phase. The disconnect timeout is now triggered within 10 milliseconds and causes the pairing to fail. If a connection is not fully established and a PIN code request is received, don't trigger the disconnect timeout. The either successful or failing connection complete event will make sure that the timeout is triggered at the right time. The biggest problem with security mode 3 is that many Bluetooth 2.0 device and before use a temporary security mode 3 for dedicated bonding. Based on a report by Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Tested-by: Johan Hedberg <johan.hedberg@nokia.com>
2009-05-09Bluetooth: Don't use hci_acl_connect_cancel() for incoming connectionsMarcel Holtmann
The connection setup phase takes around 2 seconds or longer and in that time it is possible that the need for an ACL connection is no longer present. If that happens then, the connection attempt will be canceled. This only applies to outgoing connections, but currently it can also be triggered by incoming connection. Don't call hci_acl_connect_cancel() on incoming connection since these have to be either accepted or rejected in this state. Once they are successfully connected they need to be fully disconnected anyway. Also remove the wrong hci_acl_disconn() call for SCO and eSCO links since at this stage they can't be disconnected either, because the connection handle is still unknown. Based on a report by Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Tested-by: Johan Hedberg <johan.hedberg@nokia.com>
2009-05-09Bluetooth: Fix wrong module refcount when connection setup failsMarcel Holtmann
The module refcount is increased by hci_dev_hold() call in hci_conn_add() and decreased by hci_dev_put() call in del_conn(). In case the connection setup fails, hci_dev_put() is never called. Procedure to reproduce the issue: # hciconfig hci0 up # lsmod | grep btusb -> "used by" refcount = 1 # hcitool cc <non-exisiting bdaddr> -> will get timeout # lsmod | grep btusb -> "used by" refcount = 2 # hciconfig hci0 down # lsmod | grep btusb -> "used by" refcount = 1 # rmmod btusb -> ERROR: Module btusb is in use The hci_dev_put() call got moved into del_conn() with the 2.6.25 kernel to fix an issue with hci_dev going away before hci_conn. However that change was wrong and introduced this problem. When calling hci_conn_del() it has to call hci_dev_put() after freeing the connection details. This handling should be fully symmetric. The execution of del_conn() is done in a work queue and needs it own calls to hci_dev_hold() and hci_dev_put() to ensure that the hci_dev stays until the connection cleanup has been finished. Based on a report by Bing Zhao <bzhao@marvell.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Tested-by: Bing Zhao <bzhao@marvell.com>
2009-05-05Bluetooth: Move dev_set_name() to a context that can sleepMarcel Holtmann
Setting the name of a sysfs device has to be done in a context that can actually sleep. It allocates its memory with GFP_KERNEL. Previously it was a static (size limited) string and that got changed to accommodate longer device names. So move the dev_set_name() just before calling device_add() which is executed in a work queue. This fixes the following error: [ 110.012125] BUG: sleeping function called from invalid context at mm/slub.c:1595 [ 110.012135] in_atomic(): 1, irqs_disabled(): 0, pid: 0, name: swapper [ 110.012141] 2 locks held by swapper/0: [ 110.012145] #0: (hci_task_lock){++.-.+}, at: [<ffffffffa01f822f>] hci_rx_task+0x2f/0x2d0 [bluetooth] [ 110.012173] #1: (&hdev->lock){+.-.+.}, at: [<ffffffffa01fb9e2>] hci_event_packet+0x72/0x25c0 [bluetooth] [ 110.012198] Pid: 0, comm: swapper Tainted: G W 2.6.30-rc4-g953cdaa #1 [ 110.012203] Call Trace: [ 110.012207] <IRQ> [<ffffffff8023eabd>] __might_sleep+0x14d/0x170 [ 110.012228] [<ffffffff802cfbe1>] __kmalloc+0x111/0x170 [ 110.012239] [<ffffffff803c2094>] kvasprintf+0x64/0xb0 [ 110.012248] [<ffffffff803b7a5b>] kobject_set_name_vargs+0x3b/0xa0 [ 110.012257] [<ffffffff80465326>] dev_set_name+0x76/0xa0 [ 110.012273] [<ffffffffa01fb9e2>] ? hci_event_packet+0x72/0x25c0 [bluetooth] [ 110.012289] [<ffffffffa01ffc1d>] hci_conn_add_sysfs+0x3d/0x70 [bluetooth] [ 110.012303] [<ffffffffa01fba2c>] hci_event_packet+0xbc/0x25c0 [bluetooth] [ 110.012312] [<ffffffff80516eb0>] ? sock_def_readable+0x80/0xa0 [ 110.012328] [<ffffffffa01fee0c>] ? hci_send_to_sock+0xfc/0x1c0 [bluetooth] [ 110.012343] [<ffffffff80516eb0>] ? sock_def_readable+0x80/0xa0 [ 110.012347] [<ffffffff805e88c5>] ? _read_unlock+0x75/0x80 [ 110.012354] [<ffffffffa01fee0c>] ? hci_send_to_sock+0xfc/0x1c0 [bluetooth] [ 110.012360] [<ffffffffa01f8403>] hci_rx_task+0x203/0x2d0 [bluetooth] [ 110.012365] [<ffffffff80250ab5>] tasklet_action+0xb5/0x160 [ 110.012369] [<ffffffff8025116c>] __do_softirq+0x9c/0x150 [ 110.012372] [<ffffffff805e850f>] ? _spin_unlock+0x3f/0x80 [ 110.012376] [<ffffffff8020cbbc>] call_softirq+0x1c/0x30 [ 110.012380] [<ffffffff8020f01d>] do_softirq+0x8d/0xe0 [ 110.012383] [<ffffffff80250df5>] irq_exit+0xc5/0xe0 [ 110.012386] [<ffffffff8020e71d>] do_IRQ+0x9d/0x120 [ 110.012389] [<ffffffff8020c3d3>] ret_from_intr+0x0/0xf [ 110.012391] <EOI> [<ffffffff80431832>] ? acpi_idle_enter_bm+0x264/0x2a6 [ 110.012399] [<ffffffff80431828>] ? acpi_idle_enter_bm+0x25a/0x2a6 [ 110.012403] [<ffffffff804f50d5>] ? cpuidle_idle_call+0xc5/0x130 [ 110.012407] [<ffffffff8020a4b4>] ? cpu_idle+0xc4/0x130 [ 110.012411] [<ffffffff805d2268>] ? rest_init+0x88/0xb0 [ 110.012416] [<ffffffff807e2fbd>] ? start_kernel+0x3b5/0x412 [ 110.012420] [<ffffffff807e2281>] ? x86_64_start_reservations+0x91/0xb5 [ 110.012424] [<ffffffff807e2394>] ? x86_64_start_kernel+0xef/0x11b Based on a report by Davide Pesavento <davidepesa@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Tested-by: Hugo Mildenberger <hugo.mildenberger@namir.de> Tested-by: Bing Zhao <bzhao@marvell.com>
2009-05-04Bluetooth: Fix issue with sysfs handling for connectionsMarcel Holtmann
Due to a semantic changes in flush_workqueue() the current approach of synchronizing the sysfs handling for connections doesn't work anymore. The whole approach is actually fully broken and based on assumptions that are no longer valid. With the introduction of Simple Pairing support, the creation of low-level ACL links got changed. This change invalidates the reason why in the past two independent work queues have been used for adding/removing sysfs devices. The adding of the actual sysfs device is now postponed until the host controller successfully assigns an unique handle to that link. So the real synchronization happens inside the controller and not the host. The only left-over problem is that some internals of the sysfs device handling are not initialized ahead of time. This leaves potential access to invalid data and can cause various NULL pointer dereferences. To fix this a new function makes sure that all sysfs details are initialized when an connection attempt is made. The actual sysfs device is only registered when the connection has been successfully established. To avoid a race condition with the registration, the check if a device is registered has been moved into the removal work. As an extra protection two flush_work() calls are left in place to make sure a previous add/del work has been completed first. Based on a report by Marc Pignat <marc.pignat@hevs.ch> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Tested-by: Justin P. Mattock <justinmattock@gmail.com> Tested-by: Roger Quadros <ext-roger.quadros@nokia.com> Tested-by: Marc Pignat <marc.pignat@hevs.ch>
2009-04-28Bluetooth: Fix connection establishment with low security requirementMarcel Holtmann
The Bluetooth 2.1 specification introduced four different security modes that can be mapped using Legacy Pairing and Simple Pairing. With the usage of Simple Pairing it is required that all connections (except the ones for SDP) are encrypted. So even the low security requirement mandates an encrypted connection when using Simple Pairing. When using Legacy Pairing (for Bluetooth 2.0 devices and older) this is not required since it causes interoperability issues. To support this properly the low security requirement translates into different host controller transactions depending if Simple Pairing is supported or not. However in case of Simple Pairing the command to switch on encryption after a successful authentication is not triggered for the low security mode. This patch fixes this and actually makes the logic to differentiate between Simple Pairing and Legacy Pairing a lot simpler. Based on a report by Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-04-28Bluetooth: Add different pairing timeout for Legacy PairingMarcel Holtmann
The Bluetooth stack uses a reference counting for all established ACL links and if no user (L2CAP connection) is present, the link will be terminated to save power. The problem part is the dedicated pairing when using Legacy Pairing (Bluetooth 2.0 and before). At that point no user is present and pairing attempts will be disconnected within 10 seconds or less. In previous kernel version this was not a problem since the disconnect timeout wasn't triggered on incoming connections for the first time. However this caused issues with broken host stacks that kept the connections around after dedicated pairing. When the support for Simple Pairing got added, the link establishment procedure needed to be changed and now causes issues when using Legacy Pairing When using Simple Pairing it is possible to do a proper reference counting of ACL link users. With Legacy Pairing this is not possible since the specification is unclear in some areas and too many broken Bluetooth devices have already been deployed. So instead of trying to deal with all the broken devices, a special pairing timeout will be introduced that increases the timeout to 60 seconds when pairing is triggered. If a broken devices now puts the stack into an unforeseen state, the worst that happens is the disconnect timeout triggers after 120 seconds instead of 4 seconds. This allows successful pairings with legacy and broken devices now. Based on a report by Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-04-28Bluetooth: Ensure that HCI sysfs add/del is preempt safeRoger Quadros
Use a different work_struct variables for add_conn() and del_conn() and use single work queue instead of two for adding and deleting connections. It eliminates the following error on a preemptible kernel: [ 204.358032] Unable to handle kernel NULL pointer dereference at virtual address 0000000c [ 204.370697] pgd = c0004000 [ 204.373443] [0000000c] *pgd=00000000 [ 204.378601] Internal error: Oops: 17 [#1] PREEMPT [ 204.383361] Modules linked in: vfat fat rfcomm sco l2cap sd_mod scsi_mod iphb pvr2d drm omaplfb ps [ 204.438537] CPU: 0 Not tainted (2.6.28-maemo2 #1) [ 204.443664] PC is at klist_put+0x2c/0xb4 [ 204.447601] LR is at klist_put+0x18/0xb4 [ 204.451568] pc : [<c0270f08>] lr : [<c0270ef4>] psr: a0000113 [ 204.451568] sp : cf1b3f10 ip : cf1b3f10 fp : cf1b3f2c [ 204.463104] r10: 00000000 r9 : 00000000 r8 : bf08029c [ 204.468353] r7 : c7869200 r6 : cfbe2690 r5 : c78692c8 r4 : 00000001 [ 204.474945] r3 : 00000001 r2 : cf1b2000 r1 : 00000001 r0 : 00000000 [ 204.481506] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 204.488861] Control: 10c5387d Table: 887fc018 DAC: 00000017 [ 204.494628] Process btdelconn (pid: 515, stack limit = 0xcf1b22e0) Signed-off-by: Roger Quadros <ext-roger.quadros@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-04-19Bluetooth: Add workaround for wrong HCI event in eSCO setupMarcel Holtmann
The Broadcom chips with 2.1 firmware handle the fallback case to a SCO link wrongly when setting up eSCO connections. < HCI Command: Setup Synchronous Connection (0x01|0x0028) plen 17 handle 11 voice setting 0x0060 > HCI Event: Command Status (0x0f) plen 4 Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1 > HCI Event: Connect Complete (0x03) plen 11 status 0x00 handle 1 bdaddr 00:1E:3A:xx:xx:xx type SCO encrypt 0x01 The Link Manager negotiates the fallback to SCO, but then sends out a Connect Complete event. This is wrong and the Link Manager should actually send a Synchronous Connection Complete event if the Setup Synchronous Connection has been used. Only the remote side is allowed to use Connect Complete to indicate the missing support for eSCO in the host stack. This patch adds a workaround for this which clearly should not be needed, but reality is that broken Broadcom devices are deployed. Based on a report by Ville Tervo <ville.tervo@nokia.com> Signed-off-by: Marcel Holtman <marcel@holtmann.org>
2009-04-19Bluetooth: Fallback from eSCO to SCO on unspecified errorMarcel Holtmann
Some Bluetooth chips (like the ones from Texas Instruments) don't do proper eSCO negotiations inside the Link Manager. They just return an error code and in case of the Kyocera ED-8800 headset it is just a random error. < HCI Command: Setup Synchronous Connection 0x01|0x0028) plen 17 handle 1 voice setting 0x0060 > HCI Event: Command Status (0x0f) plen 4 Setup Synchronous Connection (0x01|0x0028) status 0x00 ncmd 1 > HCI Event: Synchronous Connect Complete (0x2c) plen 17 status 0x1f handle 257 bdaddr 00:14:0A:xx:xx:xx type eSCO Error: Unspecified Error In these cases it is up to the host stack to fallback to a SCO setup and so retry with SCO parameters. Based on a report by Nick Pelly <npelly@google.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-04-19Bluetooth: Fix removing of RFCOMM DLC timer with DEFER_SETUPJohan Hedberg
There is a missing call to rfcomm_dlc_clear_timer in the case that DEFER_SETUP is used and so the connection gets disconnected after the timeout even if it was successfully accepted previously. This patch adds a call to rfcomm_dlc_clear_timer to rfcomm_dlc_accept which will get called when the user accepts the connection by calling read() on the socket. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-04-01proc tty: remove struct tty_operations::read_procAlexey Dobriyan
struct tty_operations::proc_fops took it's place and there is one less create_proc_read_entry() user now! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-24Driver core: Fix device_move() vs. dpm list ordering, v2Cornelia Huck
dpm_list currently relies on the fact that child devices will be registered after their parents to get a correct suspend order. Using device_move() however destroys this assumption, as an already registered device may be moved under a newly registered one. This patch adds a new argument to device_move(), allowing callers to specify how dpm_list should be adapted. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-27Bluetooth: Remove some pointless conditionals before kfree_skb()Wei Yongjun
Remove some pointless conditionals before kfree_skb(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Move hci_conn_del_sysfs() back to avoid device destruct too earlyDave Young
The following commit introduce a regression: commit 7d0db0a373195385a2e0b19d1f5e4b186fdcffac Author: Marcel Holtmann <marcel@holtmann.org> Date: Mon Jul 14 20:13:51 2008 +0200 [Bluetooth] Use a more unique bus name for connections I get panic as following (by netconsole): [ 2709.344034] usb 5-1: new full speed USB device using uhci_hcd and address 4 [ 2709.505776] usb 5-1: configuration #1 chosen from 1 choice [ 2709.569207] Bluetooth: Generic Bluetooth USB driver ver 0.4 [ 2709.570169] usbcore: registered new interface driver btusb [ 2845.742781] BUG: unable to handle kernel paging request at 6b6b6c2f [ 2845.742958] IP: [<c015515c>] __lock_acquire+0x6c/0xa80 [ 2845.743087] *pde = 00000000 [ 2845.743206] Oops: 0002 [#1] SMP [ 2845.743377] last sysfs file: /sys/class/bluetooth/hci0/hci0:6/type [ 2845.743742] Modules linked in: btusb netconsole snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss rfcomm l2cap bluetooth vfat fuse snd_hda_codec_idt snd_hda_intel snd_hda_codec snd_hwdep snd_pcm pl2303 snd_timer psmouse usbserial snd 3c59x e100 serio_raw soundcore i2c_i801 intel_agp mii agpgart snd_page_alloc rtc_cmos rtc_core thermal processor rtc_lib button thermal_sys sg evdev [ 2845.743742] [ 2845.743742] Pid: 0, comm: swapper Not tainted (2.6.29-rc5-smp #54) Dell DM051 [ 2845.743742] EIP: 0060:[<c015515c>] EFLAGS: 00010002 CPU: 0 [ 2845.743742] EIP is at __lock_acquire+0x6c/0xa80 [ 2845.743742] EAX: 00000046 EBX: 00000046 ECX: 6b6b6b6b EDX: 00000002 [ 2845.743742] ESI: 6b6b6b6b EDI: 00000000 EBP: c064fd14 ESP: c064fcc8 [ 2845.743742] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 [ 2845.743742] Process swapper (pid: 0, ti=c064e000 task=c05d1400 task.ti=c064e000) [ 2845.743742] Stack: [ 2845.743742] c05d1400 00000002 c05d1400 00000001 00000002 00000000 f65388dc c05d1400 [ 2845.743742] 6b6b6b6b 00000292 c064fd0c c0153732 00000000 00000000 00000001 f700fa50 [ 2845.743742] 00000046 00000000 00000000 c064fd40 c0155be6 00000000 00000002 00000001 [ 2845.743742] Call Trace: [ 2845.743742] [<c0153732>] ? trace_hardirqs_on_caller+0x72/0x1c0 [ 2845.743742] [<c0155be6>] ? lock_acquire+0x76/0xa0 [ 2845.743742] [<c03e1aad>] ? skb_dequeue+0x1d/0x70 [ 2845.743742] [<c046c885>] ? _spin_lock_irqsave+0x45/0x80 [ 2845.743742] [<c03e1aad>] ? skb_dequeue+0x1d/0x70 [ 2845.743742] [<c03e1aad>] ? skb_dequeue+0x1d/0x70 [ 2845.743742] [<c03e1f94>] ? skb_queue_purge+0x14/0x20 [ 2845.743742] [<f8171f5a>] ? hci_conn_del+0x10a/0x1c0 [bluetooth] [ 2845.743742] [<f81399c9>] ? l2cap_disconn_ind+0x59/0xb0 [l2cap] [ 2845.743742] [<f81795ce>] ? hci_conn_del_sysfs+0x8e/0xd0 [bluetooth] [ 2845.743742] [<f8175758>] ? hci_event_packet+0x5f8/0x31c0 [bluetooth] [ 2845.743742] [<c03dfe19>] ? sock_def_readable+0x59/0x80 [ 2845.743742] [<c046c14d>] ? _read_unlock+0x1d/0x20 [ 2845.743742] [<f8178aa9>] ? hci_send_to_sock+0xe9/0x1d0 [bluetooth] [ 2845.743742] [<c015388b>] ? trace_hardirqs_on+0xb/0x10 [ 2845.743742] [<f816fa6a>] ? hci_rx_task+0x2ba/0x490 [bluetooth] [ 2845.743742] [<c0133661>] ? tasklet_action+0x31/0xc0 [ 2845.743742] [<c013367c>] ? tasklet_action+0x4c/0xc0 [ 2845.743742] [<c0132eb7>] ? __do_softirq+0xa7/0x170 [ 2845.743742] [<c0116dec>] ? ack_apic_level+0x5c/0x1c0 [ 2845.743742] [<c0132fd7>] ? do_softirq+0x57/0x60 [ 2845.743742] [<c01333dc>] ? irq_exit+0x7c/0x90 [ 2845.743742] [<c01055bb>] ? do_IRQ+0x4b/0x90 [ 2845.743742] [<c01333d5>] ? irq_exit+0x75/0x90 [ 2845.743742] [<c010392c>] ? common_interrupt+0x2c/0x34 [ 2845.743742] [<c010a14f>] ? mwait_idle+0x4f/0x70 [ 2845.743742] [<c0101c05>] ? cpu_idle+0x65/0xb0 [ 2845.743742] [<c045731e>] ? rest_init+0x4e/0x60 [ 2845.743742] Code: 0f 84 69 02 00 00 83 ff 07 0f 87 1e 06 00 00 85 ff 0f 85 08 05 00 00 8b 4d cc 8b 49 04 85 c9 89 4d d4 0f 84 f7 04 00 00 8b 75 d4 <f0> ff 86 c4 00 00 00 89 f0 e8 56 a9 ff ff 85 c0 0f 85 6e 03 00 [ 2845.743742] EIP: [<c015515c>] __lock_acquire+0x6c/0xa80 SS:ESP 0068:c064fcc8 [ 2845.743742] ---[ end trace 4c985b38f022279f ]--- [ 2845.743742] Kernel panic - not syncing: Fatal exception in interrupt [ 2845.743742] ------------[ cut here ]------------ [ 2845.743742] WARNING: at kernel/smp.c:329 smp_call_function_many+0x151/0x200() [ 2845.743742] Hardware name: Dell DM051 [ 2845.743742] Modules linked in: btusb netconsole snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss rfcomm l2cap bluetooth vfat fuse snd_hda_codec_idt snd_hda_intel snd_hda_codec snd_hwdep snd_pcm pl2303 snd_timer psmouse usbserial snd 3c59x e100 serio_raw soundcore i2c_i801 intel_agp mii agpgart snd_page_alloc rtc_cmos rtc_core thermal processor rtc_lib button thermal_sys sg evdev [ 2845.743742] Pid: 0, comm: swapper Tainted: G D 2.6.29-rc5-smp #54 [ 2845.743742] Call Trace: [ 2845.743742] [<c012e076>] warn_slowpath+0x86/0xa0 [ 2845.743742] [<c015041b>] ? trace_hardirqs_off+0xb/0x10 [ 2845.743742] [<c0146384>] ? up+0x14/0x40 [ 2845.743742] [<c012e661>] ? release_console_sem+0x31/0x1e0 [ 2845.743742] [<c046c8ab>] ? _spin_lock_irqsave+0x6b/0x80 [ 2845.743742] [<c015041b>] ? trace_hardirqs_off+0xb/0x10 [ 2845.743742] [<c046c900>] ? _read_lock_irqsave+0x40/0x80 [ 2845.743742] [<c012e7f2>] ? release_console_sem+0x1c2/0x1e0 [ 2845.743742] [<c0146384>] ? up+0x14/0x40 [ 2845.743742] [<c015041b>] ? trace_hardirqs_off+0xb/0x10 [ 2845.743742] [<c046a3d7>] ? __mutex_unlock_slowpath+0x97/0x160 [ 2845.743742] [<c046a563>] ? mutex_trylock+0xb3/0x180 [ 2845.743742] [<c046a4a8>] ? mutex_unlock+0x8/0x10 [ 2845.743742] [<c015b991>] smp_call_function_many+0x151/0x200 [ 2845.743742] [<c010a1a0>] ? stop_this_cpu+0x0/0x40 [ 2845.743742] [<c015ba61>] smp_call_function+0x21/0x30 [ 2845.743742] [<c01137ae>] native_smp_send_stop+0x1e/0x50 [ 2845.743742] [<c012e0f5>] panic+0x55/0x110 [ 2845.743742] [<c01065a8>] oops_end+0xb8/0xc0 [ 2845.743742] [<c010668f>] die+0x4f/0x70 [ 2845.743742] [<c011a8c9>] do_page_fault+0x269/0x610 [ 2845.743742] [<c011a660>] ? do_page_fault+0x0/0x610 [ 2845.743742] [<c046cbaf>] error_code+0x77/0x7c [ 2845.743742] [<c015515c>] ? __lock_acquire+0x6c/0xa80 [ 2845.743742] [<c0153732>] ? trace_hardirqs_on_caller+0x72/0x1c0 [ 2845.743742] [<c0155be6>] lock_acquire+0x76/0xa0 [ 2845.743742] [<c03e1aad>] ? skb_dequeue+0x1d/0x70 [ 2845.743742] [<c046c885>] _spin_lock_irqsave+0x45/0x80 [ 2845.743742] [<c03e1aad>] ? skb_dequeue+0x1d/0x70 [ 2845.743742] [<c03e1aad>] skb_dequeue+0x1d/0x70 [ 2845.743742] [<c03e1f94>] skb_queue_purge+0x14/0x20 [ 2845.743742] [<f8171f5a>] hci_conn_del+0x10a/0x1c0 [bluetooth] [ 2845.743742] [<f81399c9>] ? l2cap_disconn_ind+0x59/0xb0 [l2cap] [ 2845.743742] [<f81795ce>] ? hci_conn_del_sysfs+0x8e/0xd0 [bluetooth] [ 2845.743742] [<f8175758>] hci_event_packet+0x5f8/0x31c0 [bluetooth] [ 2845.743742] [<c03dfe19>] ? sock_def_readable+0x59/0x80 [ 2845.743742] [<c046c14d>] ? _read_unlock+0x1d/0x20 [ 2845.743742] [<f8178aa9>] ? hci_send_to_sock+0xe9/0x1d0 [bluetooth] [ 2845.743742] [<c015388b>] ? trace_hardirqs_on+0xb/0x10 [ 2845.743742] [<f816fa6a>] hci_rx_task+0x2ba/0x490 [bluetooth] [ 2845.743742] [<c0133661>] ? tasklet_action+0x31/0xc0 [ 2845.743742] [<c013367c>] tasklet_action+0x4c/0xc0 [ 2845.743742] [<c0132eb7>] __do_softirq+0xa7/0x170 [ 2845.743742] [<c0116dec>] ? ack_apic_level+0x5c/0x1c0 [ 2845.743742] [<c0132fd7>] do_softirq+0x57/0x60 [ 2845.743742] [<c01333dc>] irq_exit+0x7c/0x90 [ 2845.743742] [<c01055bb>] do_IRQ+0x4b/0x90 [ 2845.743742] [<c01333d5>] ? irq_exit+0x75/0x90 [ 2845.743742] [<c010392c>] common_interrupt+0x2c/0x34 [ 2845.743742] [<c010a14f>] ? mwait_idle+0x4f/0x70 [ 2845.743742] [<c0101c05>] cpu_idle+0x65/0xb0 [ 2845.743742] [<c045731e>] rest_init+0x4e/0x60 [ 2845.743742] ---[ end trace 4c985b38f02227a0 ]--- [ 2845.743742] ------------[ cut here ]------------ [ 2845.743742] WARNING: at kernel/smp.c:226 smp_call_function_single+0x8e/0x110() [ 2845.743742] Hardware name: Dell DM051 [ 2845.743742] Modules linked in: btusb netconsole snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss rfcomm l2cap bluetooth vfat fuse snd_hda_codec_idt snd_hda_intel snd_hda_codec snd_hwdep snd_pcm pl2303 snd_timer psmouse usbserial snd 3c59x e100 serio_raw soundcore i2c_i801 intel_agp mii agpgart snd_page_alloc rtc_cmos rtc_core thermal processor rtc_lib button thermal_sys sg evdev [ 2845.743742] Pid: 0, comm: swapper Tainted: G D W 2.6.29-rc5-smp #54 [ 2845.743742] Call Trace: [ 2845.743742] [<c012e076>] warn_slowpath+0x86/0xa0 [ 2845.743742] [<c012e000>] ? warn_slowpath+0x10/0xa0 [ 2845.743742] [<c015041b>] ? trace_hardirqs_off+0xb/0x10 [ 2845.743742] [<c0146384>] ? up+0x14/0x40 [ 2845.743742] [<c012e661>] ? release_console_sem+0x31/0x1e0 [ 2845.743742] [<c046c8ab>] ? _spin_lock_irqsave+0x6b/0x80 [ 2845.743742] [<c015041b>] ? trace_hardirqs_off+0xb/0x10 [ 2845.743742] [<c046c900>] ? _read_lock_irqsave+0x40/0x80 [ 2845.743742] [<c012e7f2>] ? release_console_sem+0x1c2/0x1e0 [ 2845.743742] [<c0146384>] ? up+0x14/0x40 [ 2845.743742] [<c015b7be>] smp_call_function_single+0x8e/0x110 [ 2845.743742] [<c010a1a0>] ? stop_this_cpu+0x0/0x40 [ 2845.743742] [<c026d23f>] ? cpumask_next_and+0x1f/0x40 [ 2845.743742] [<c015b95a>] smp_call_function_many+0x11a/0x200 [ 2845.743742] [<c010a1a0>] ? stop_this_cpu+0x0/0x40 [ 2845.743742] [<c015ba61>] smp_call_function+0x21/0x30 [ 2845.743742] [<c01137ae>] native_smp_send_stop+0x1e/0x50 [ 2845.743742] [<c012e0f5>] panic+0x55/0x110 [ 2845.743742] [<c01065a8>] oops_end+0xb8/0xc0 [ 2845.743742] [<c010668f>] die+0x4f/0x70 [ 2845.743742] [<c011a8c9>] do_page_fault+0x269/0x610 [ 2845.743742] [<c011a660>] ? do_page_fault+0x0/0x610 [ 2845.743742] [<c046cbaf>] error_code+0x77/0x7c [ 2845.743742] [<c015515c>] ? __lock_acquire+0x6c/0xa80 [ 2845.743742] [<c0153732>] ? trace_hardirqs_on_caller+0x72/0x1c0 [ 2845.743742] [<c0155be6>] lock_acquire+0x76/0xa0 [ 2845.743742] [<c03e1aad>] ? skb_dequeue+0x1d/0x70 [ 2845.743742] [<c046c885>] _spin_lock_irqsave+0x45/0x80 [ 2845.743742] [<c03e1aad>] ? skb_dequeue+0x1d/0x70 [ 2845.743742] [<c03e1aad>] skb_dequeue+0x1d/0x70 [ 2845.743742] [<c03e1f94>] skb_queue_purge+0x14/0x20 [ 2845.743742] [<f8171f5a>] hci_conn_del+0x10a/0x1c0 [bluetooth] [ 2845.743742] [<f81399c9>] ? l2cap_disconn_ind+0x59/0xb0 [l2cap] [ 2845.743742] [<f81795ce>] ? hci_conn_del_sysfs+0x8e/0xd0 [bluetooth] [ 2845.743742] [<f8175758>] hci_event_packet+0x5f8/0x31c0 [bluetooth] [ 2845.743742] [<c03dfe19>] ? sock_def_readable+0x59/0x80 [ 2845.743742] [<c046c14d>] ? _read_unlock+0x1d/0x20 [ 2845.743742] [<f8178aa9>] ? hci_send_to_sock+0xe9/0x1d0 [bluetooth] [ 2845.743742] [<c015388b>] ? trace_hardirqs_on+0xb/0x10 [ 2845.743742] [<f816fa6a>] hci_rx_task+0x2ba/0x490 [bluetooth] [ 2845.743742] [<c0133661>] ? tasklet_action+0x31/0xc0 [ 2845.743742] [<c013367c>] tasklet_action+0x4c/0xc0 [ 2845.743742] [<c0132eb7>] __do_softirq+0xa7/0x170 [ 2845.743742] [<c0116dec>] ? ack_apic_level+0x5c/0x1c0 [ 2845.743742] [<c0132fd7>] do_softirq+0x57/0x60 [ 2845.743742] [<c01333dc>] irq_exit+0x7c/0x90 [ 2845.743742] [<c01055bb>] do_IRQ+0x4b/0x90 [ 2845.743742] [<c01333d5>] ? irq_exit+0x75/0x90 [ 2845.743742] [<c010392c>] common_interrupt+0x2c/0x34 [ 2845.743742] [<c010a14f>] ? mwait_idle+0x4f/0x70 [ 2845.743742] [<c0101c05>] cpu_idle+0x65/0xb0 [ 2845.743742] [<c045731e>] rest_init+0x4e/0x60 [ 2845.743742] ---[ end trace 4c985b38f02227a1 ]--- [ 2845.743742] Rebooting in 3 seconds.. My logitec bluetooth mouse trying connect to pc, but pc side reject the connection again and again. then panic happens. The reason is due to hci_conn_del_sysfs now called in hci_event_packet, the del work is done in a workqueue, so it's possible done before skb_queue_purge called. I move the hci_conn_del_sysfs after skb_queue_purge just as that before marcel's commit. Remove the hci_conn_del_sysfs in hci_conn_hash_flush as well due to hci_conn_del will deal with the work. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Permit BT_SECURITY also for L2CAP raw socketsMarcel Holtmann
Userspace pairing code can be simplified if it doesn't have to fall back to using L2CAP_LM in the case of L2CAP raw sockets. This patch allows the BT_SECURITY socket option to be used for these sockets. Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Fix RFCOMM usage of in-kernel L2CAP socketsMarcel Holtmann
The CID value of L2CAP sockets need to be set to zero. All userspace applications do this via memset() on the sockaddr_l2 structure. The RFCOMM implementation uses in-kernel L2CAP sockets and so it has to make sure that l2_cid is set to zero. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Disallow usage of L2CAP CID setting for nowMarcel Holtmann
In the future the L2CAP layer will have full support for fixed channels and right now it already can export the channel assignment, but for the functions bind() and connect() the usage of only CID 0 is allowed. This allows an easy detection if the kernel supports fixed channels or not, because otherwise it would impossible for application to tell. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Change RFCOMM to use BT_CONNECT2 for BT_DEFER_SETUPMarcel Holtmann
When BT_DEFER_SETUP is enabled on a RFCOMM socket, then switch its current state from BT_OPEN to BT_CONNECT2. This gives the Bluetooth core a unified way to handle L2CAP and RFCOMM sockets. The BT_CONNECT2 state is designated for incoming connections. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Fix poll() misbehavior when using BT_DEFER_SETUPMarcel Holtmann
When BT_DEFER_SETUP has been enabled on a Bluetooth socket it keeps signaling POLLIN all the time. This is a wrong behavior. The POLLIN should only be signaled if the client socket is in BT_CONNECT2 state and the parent has been BT_DEFER_SETUP enabled. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Set authentication requirement before requesting itMarcel Holtmann
The authentication requirement got only updated when the security level increased. This is a wrong behavior. The authentication requirement is read by the Bluetooth daemon to make proper decisions when handling the IO capabilities exchange. So set the value that is currently expected by the higher layers like L2CAP and RFCOMM. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Fix authentication requirements for L2CAP security checkMarcel Holtmann
The L2CAP layer can trigger the authentication via an ACL connection or later on to increase the security level. When increasing the security level it didn't use the same authentication requirements when triggering a new ACL connection. Make sure that exactly the same authentication requirements are used. The only exception here are the L2CAP raw sockets which are only used for dedicated bonding. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Ask upper layers for HCI disconnect reasonMarcel Holtmann
Some of the qualification tests demand that in case of failures in L2CAP the HCI disconnect should indicate a reason why L2CAP fails. This is a bluntly layer violation since multiple L2CAP connections could be using the same ACL and thus forcing a disconnect reason is not a good idea. To comply with the Bluetooth test specification, the disconnect reason is now stored in the L2CAP connection structure and every time a new L2CAP channel is added it will set back to its default. So only in the case where the L2CAP channel with the disconnect reason is really the last one, it will propagated to the HCI layer. The HCI layer has been extended with a disconnect indication that allows it to ask upper layers for a disconnect reason. The upper layer must not support this callback and in that case it will nicely default to the existing behavior. If an upper layer like L2CAP can provide a disconnect reason that one will be used to disconnect the ACL or SCO link. No modification to the ACL disconnect timeout have been made. So in case of Linux to Linux connection the initiator will disconnect the ACL link before the acceptor side can signal the specific disconnect reason. That is perfectly fine since Linux doesn't make use of this value anyway. The L2CAP layer has a perfect valid error code for rejecting connection due to a security violation. It is unclear why the Bluetooth specification insists on having specific HCI disconnect reason. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Add CID field to L2CAP socket address structureMarcel Holtmann
In preparation for L2CAP fixed channel support, the CID value of a L2CAP connection needs to be accessible via the socket interface. The CID is the connection identifier and exists as source and destination value. So extend the L2CAP socket address structure with this field and change getsockname() and getpeername() to fill it in. The bind() and connect() functions have been modified to handle L2CAP socket address structures of variable sizes. This makes them future proof if additional fields need to be added. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Request L2CAP fixed channel list if availableMarcel Holtmann
If the extended features mask indicates support for fixed channels, request the list of available fixed channels. This also enables the fixed channel features bit so remote implementations can request information about it. Currently only the signal channel will be listed. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Don't enforce authentication for L2CAP PSM 1 and 3Marcel Holtmann
The recommendation for the L2CAP PSM 1 (SDP) is to not use any kind of authentication or encryption. So don't trigger authentication for incoming and outgoing SDP connections. For L2CAP PSM 3 (RFCOMM) there is no clear requirement, but with Bluetooth 2.1 the initiator is required to enable authentication and encryption first and this gets enforced. So there is no need to trigger an additional authentication step. The RFCOMM service security will make sure that a secure enough link key is present. When the encryption gets enabled after the SDP connection setup, then switch the security level from SDP to low security. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Fix double L2CAP connection requestMarcel Holtmann
If the remote L2CAP server uses authentication pending stage and encryption is enabled it can happen that a L2CAP connection request is sent twice due to a race condition in the connection state machine. When the remote side indicates any kind of connection pending, then track this state and skip sending of L2CAP commands for this period. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Fix race condition with L2CAP information requestMarcel Holtmann
When two L2CAP connections are requested quickly after the ACL link has been established there exists a window for a race condition where a connection request is sent before the information response has been received. Any connection request should only be sent after an exchange of the extended features mask has been finished. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Set authentication requirements if not availableMarcel Holtmann
When no authentication requirements are selected, but an outgoing or incoming connection has requested any kind of security enforcement, then set these authentication requirements. This ensures that the userspace always gets informed about the authentication requirements (if available). Only when no security enforcement has happened, the kernel will signal invalid requirements. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Use general bonding whenever possibleMarcel Holtmann
When receiving incoming connection to specific services, always use general bonding. This ensures that the link key gets stored and can be used for further authentications. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Add SCO fallback for eSCO connection attemptsMarcel Holtmann
When attempting to setup eSCO connections it can happen that some link manager implementations fail to properly negotiate the eSCO parameters and thus fail the eSCO setup. Normally the link manager is responsible for the negotiation of the parameters and actually fallback to SCO if no agreement can be reached. In cases where the link manager is just too stupid, then at least try to establish a SCO link if eSCO fails. For the Bluetooth devices with EDR support this includes handling packet types of EDR basebands. This is particular tricky since for the EDR the logic of enabling/disabling one specific packet type is turned around. This fix contains an extra bitmask to disable eSCO EDR packet when trying to fallback to a SCO connection. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Don't check encryption for L2CAP raw socketsMarcel Holtmann
For L2CAP sockets with medium and high security requirement a missing encryption will enforce the closing of the link. For the L2CAP raw sockets this is not needed, so skip that check. This fixes a crash when pairing Bluetooth 2.0 (and earlier) devices since the L2CAP state machine got confused and then locked up the whole system. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: When encryption is dropped, do not send RFCOMM packetsJaikumar Ganesh
During a role change with pre-Bluetooth 2.1 devices, the remote side drops the encryption of the RFCOMM connection. We allow a grace period for the encryption to be re-established, before dropping the connection. During this grace period, the RFCOMM_SEC_PENDING flag is set. Check this flag before sending RFCOMM packets. Signed-off-by: Jaikumar Ganesh <jaikumar@google.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Remove CONFIG_DEBUG_LOCK_ALLOC ifdefsDave Young
Due to lockdep changes, the CONFIG_DEBUG_LOCK_ALLOC ifdef is not needed now. So just remove it here. The following commit fixed the !lockdep build warnings: commit e8f6fbf62de37cbc2e179176ac7010d5f4396b67 Author: Ingo Molnar <mingo@elte.hu> Date: Wed Nov 12 01:38:36 2008 +0000 lockdep: include/linux/lockdep.h - fix warning in net/bluetooth/af_bluetooth.c Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Update version numbersMarcel Holtmann
With the support for the enhanced security model and the support for deferring connection setup, it is a good idea to increase various version numbers. This is purely cosmetic and has no effect on the behavior, but can be really helpful when debugging problems in different kernel versions. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-02-27Bluetooth: Restrict application of socket optionsMarcel Holtmann
The new socket options should only be evaluated for SOL_BLUETOOTH level and not for every other level. Previously this causes some minor issues when detecting if a kernel with certain features is available. Also restrict BT_SECURITY to SOCK_SEQPACKET for L2CAP and SOCK_STREAM for the RFCOMM protocol. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
