[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
commit 89cbb4da0abee2f39d75f67f9fd57f7410c8b65c upstream.
This patch fixes the connection encryption key size information when
the host is playing the peripheral role. We should set conn->enc_key_
size in hci_le_ltk_request_evt, otherwise it is left uninitialized.
Signed-off-by: Andre Guedes <andre.guedes@openbossa.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit f8776218e8546397be64ad2bc0ebf4748522d6e3 upstream.
While playing the peripheral role, the host gets a LE Long Term Key
Request Event from the controller when a connection is established
with a bonded device. The host then informs the LTK which should be
used for the connection. Once the link is encrypted, the host gets
an Encryption Change Event.
Therefore we should set conn->pending_sec_level instead of conn->
sec_level in hci_le_ltk_request_evt. This way, conn->sec_level is
properly updated in hci_encrypt_change_evt.
Moreover, since we have a LTK associated to the device, we have at
least BT_SECURITY_MEDIUM security level.
commit 300b962e5244a1ea010df7e88595faa0085b461d upstream.
If a too small MTU value is set with ioctl(HCISETACLMTU) or by a bogus
controller, memory corruption happens due to a memcpy() call with
negative length.
Fix this crash on either incoming or outgoing connections with a MTU
smaller than L2CAP_HDR_SIZE + L2CAP_CMD_HDR_SIZE:
[ 46.885433] BUG: unable to handle kernel paging request at f56ad000
[ 46.888037] IP: [<c03d94cd>] memcpy+0x1d/0x40
[ 46.888037] *pdpt = 0000000000ac3001 *pde = 00000000373f8067 *pte = 80000000356ad060
[ 46.888037] Oops: 0002 [#1] SMP DEBUG_PAGEALLOC
[ 46.888037] Modules linked in: hci_vhci bluetooth virtio_balloon i2c_piix4 uhci_hcd usbcore usb_common
[ 46.888037] CPU: 0 PID: 1044 Comm: kworker/u3:0 Not tainted 3.10.0-rc1+ #12
[ 46.888037] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
[ 46.888037] Workqueue: hci0 hci_rx_work [bluetooth]
[ 46.888037] task: f59b15b0 ti: f55c4000 task.ti: f55c4000
[ 46.888037] EIP: 0060:[<c03d94cd>] EFLAGS: 00010212 CPU: 0
[ 46.888037] EIP is at memcpy+0x1d/0x40
[ 46.888037] EAX: f56ac1c0 EBX: fffffff8 ECX: 3ffffc6e EDX: f55c5cf2
[ 46.888037] ESI: f55c6b32 EDI: f56ad000 EBP: f55c5c68 ESP: f55c5c5c
[ 46.888037] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 46.888037] CR0: 8005003b CR2: f56ad000 CR3: 3557d000 CR4: 000006f0
[ 46.888037] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[ 46.888037] DR6: ffff0ff0 DR7: 00000400
[ 46.888037] Stack:
[ 46.888037] fffffff8 00000010 00000003 f55c5cac f8c6a54c ffffffff f8c69eb2 00000000
[ 46.888037] f4783cdc f57f0070 f759c590 1001c580 00000003 0200000a 00000000 f5a88560
[ 46.888037] f5ba2600 f5a88560 00000041 00000000 f55c5d90 f8c6f4c7 00000008 f55c5cf2
[ 46.888037] Call Trace:
[ 46.888037] [<f8c6a54c>] l2cap_send_cmd+0x1cc/0x230 [bluetooth]
[ 46.888037] [<f8c69eb2>] ? l2cap_global_chan_by_psm+0x152/0x1a0 [bluetooth]
[ 46.888037] [<f8c6f4c7>] l2cap_connect+0x3f7/0x540 [bluetooth]
[ 46.888037] [<c019b37b>] ? trace_hardirqs_off+0xb/0x10
[ 46.888037] [<c01a0ff8>] ? mark_held_locks+0x68/0x110
[ 46.888037] [<c064ad20>] ? mutex_lock_nested+0x280/0x360
[ 46.888037] [<c064b9d9>] ? __mutex_unlock_slowpath+0xa9/0x150
[ 46.888037] [<c01a118c>] ? trace_hardirqs_on_caller+0xec/0x1b0
[ 46.888037] [<c064ad08>] ? mutex_lock_nested+0x268/0x360
[ 46.888037] [<c01a125b>] ? trace_hardirqs_on+0xb/0x10
[ 46.888037] [<f8c72f8d>] l2cap_recv_frame+0xb2d/0x1d30 [bluetooth]
[ 46.888037] [<f8c754f1>] l2cap_recv_acldata+0x2a1/0x320 [bluetooth]
[ 46.888037] [<f8c491d8>] hci_rx_work+0x518/0x810 [bluetooth]
[ 46.888037] [<f8c48df2>] ? hci_rx_work+0x132/0x810 [bluetooth]
[ 46.888037] [<c0158979>] process_one_work+0x1a9/0x600
[ 46.888037] [<c01588fb>] ? process_one_work+0x12b/0x600
[ 46.888037] [<c015922e>] ? worker_thread+0x19e/0x320
[ 46.888037] [<c0159187>] worker_thread+0xf7/0x320
[ 46.888037] [<c0159090>] ? rescuer_thread+0x290/0x290
[ 46.888037] [<c01602f8>] kthread+0xa8/0xb0
[ 46.888037] [<c0656777>] ret_from_kernel_thread+0x1b/0x28
[ 46.888037] [<c0160250>] ? flush_kthread_worker+0x120/0x120
[ 46.888037] Code: c3 90 8d 74 26 00 e8 63 fc ff ff eb e8 90 55 89 e5 83 ec 0c 89 5d f4 89 75 f8 89 7d fc 3e 8d 74 26 00 89 cb 89 c7 c1 e9 02 89 d6 <f3> a5 89 d9 83 e1 03 74 02 f3 a4 8b 5d f4 8b 75 f8 8b 7d fc 89
[ 46.888037] EIP: [<c03d94cd>] memcpy+0x1d/0x40 SS:ESP 0068:f55c5c5c
[ 46.888037] CR2: 00000000f56ad000
[ 46.888037] ---[ end trace 0217c1f4d78714a9 ]---
Signed-off-by: Anderson Lizardo <anderson.lizardo@openbossa.org>
commit 96570ffcca0b872dc8626e97569d2697f374d868 upstream.
If hci_dev_open fails we need to ensure that the corresponding
mgmt_set_powered command gets an appropriate response. This patch fixes
the missing response by adding a new mgmt_set_powered_failed function
that's used to indicate a power on failure to mgmt. Since a situation
with the device being rfkilled may require special handling in user
space the patch uses a new dedicated mgmt status code for this.
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
[ Upstream commit e11e0455c0d7d3d62276a0c55d9dfbc16779d691 ]
If RFCOMM_DEFER_SETUP is set in the flags, rfcomm_sock_recvmsg() returns
early with 0 without updating the possibly set msg_namelen member. This,
in turn, leads to a 128 byte kernel stack leak in net/socket.c.
Fix this by updating msg_namelen in this case. For all other cases it
will be handled in bt_sock_stream_recvmsg().
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
[ Upstream commit 4683f42fde3977bdb4e8a09622788cc8b5313778 ]
In case the socket is already shutting down, bt_sock_recvmsg() returns
with 0 without updating msg_namelen leading to net/socket.c leaking the
local, uninitialized sockaddr_storage variable to userland -- 128 bytes
of kernel stack memory.
Fix this by moving the msg_namelen assignment in front of the shutdown
test.
commit eb20ff9c91ddcb2d55c1849a87d3db85af5e88a9 upstream.
With deferred setup for SCO, it is possible that userspace closes the
socket when it is in the BT_CONNECT2 state, after the Connect Request is
received but before the Accept Synchonous Connection is sent.
If this happens the following crash was observed, when the connection is
terminated:
[ +0.000003] hci_sync_conn_complete_evt: hci0 status 0x10
[ +0.000005] sco_connect_cfm: hcon ffff88003d1bd800 bdaddr 40:98:4e:32:d7:39 status 16
[ +0.000003] sco_conn_del: hcon ffff88003d1bd800 conn ffff88003cc8e300, err 110
[ +0.000015] BUG: unable to handle kernel NULL pointer dereference at 0000000000000199
[ +0.000906] IP: [<ffffffff810620dd>] __lock_acquire+0xed/0xe82
[ +0.000000] PGD 3d21f067 PUD 3d291067 PMD 0
[ +0.000000] Oops: 0002 [#1] SMP
[ +0.000000] Modules linked in: rfcomm bnep btusb bluetooth
[ +0.000000] CPU 0
[ +0.000000] Pid: 1481, comm: kworker/u:2H Not tainted 3.9.0-rc1-25019-gad82cdd #1 Bochs Bochs
[ +0.000000] RIP: 0010:[<ffffffff810620dd>] [<ffffffff810620dd>] __lock_acquire+0xed/0xe82
[ +0.000000] RSP: 0018:ffff88003c3c19d8 EFLAGS: 00010002
[ +0.000000] RAX: 0000000000000001 RBX: 0000000000000246 RCX: 0000000000000000
[ +0.000000] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88003d1be868
[ +0.000000] RBP: ffff88003c3c1a98 R08: 0000000000000002 R09: 0000000000000000
[ +0.000000] R10: ffff88003d1be868 R11: ffff88003e20b000 R12: 0000000000000002
[ +0.000000] R13: ffff88003aaa8000 R14: 000000000000006e R15: ffff88003d1be850
[ +0.000000] FS: 0000000000000000(0000) GS:ffff88003e200000(0000) knlGS:0000000000000000
[ +0.000000] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ +0.000000] CR2: 0000000000000199 CR3: 000000003c1cb000 CR4: 00000000000006b0
[ +0.000000] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ +0.000000] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ +0.000000] Process kworker/u:2H (pid: 1481, threadinfo ffff88003c3c0000, task ffff88003aaa8000)
[ +0.000000] Stack:
[ +0.000000] ffffffff81b16342 0000000000000000 0000000000000000 ffff88003d1be868
[ +0.000000] ffffffff00000000 00018c0c7863e367 000000003c3c1a28 ffffffff8101efbd
[ +0.000000] 0000000000000000 ffff88003e3d2400 ffff88003c3c1a38 ffffffff81007c7a
[ +0.000000] Call Trace:
[ +0.000000] [<ffffffff8101efbd>] ? kvm_clock_read+0x34/0x3b
[ +0.000000] [<ffffffff81007c7a>] ? paravirt_sched_clock+0x9/0xd
[ +0.000000] [<ffffffff81007fd4>] ? sched_clock+0x9/0xb
[ +0.000000] [<ffffffff8104fd7a>] ? sched_clock_local+0x12/0x75
[ +0.000000] [<ffffffff810632d1>] lock_acquire+0x93/0xb1
[ +0.000000] [<ffffffffa0022339>] ? spin_lock+0x9/0xb [bluetooth]
[ +0.000000] [<ffffffff8105f3d8>] ? lock_release_holdtime.part.22+0x4e/0x55
[ +0.000000] [<ffffffff814f6038>] _raw_spin_lock+0x40/0x74
[ +0.000000] [<ffffffff814f6936>] ? _raw_spin_unlock+0x23/0x36
[ +0.000000] [<ffffffffa0022339>] spin_lock+0x9/0xb [bluetooth]
[ +0.000000] [<ffffffffa00230cc>] sco_conn_del+0x76/0xbb [bluetooth]
[ +0.000000] [<ffffffffa002391d>] sco_connect_cfm+0x2da/0x2e9 [bluetooth]
[ +0.000000] [<ffffffffa000862a>] hci_proto_connect_cfm+0x38/0x65 [bluetooth]
[ +0.000000] [<ffffffffa0008d30>] hci_sync_conn_complete_evt.isra.79+0x11a/0x13e [bluetooth]
[ +0.000000] [<ffffffffa000cd96>] hci_event_packet+0x153b/0x239d [bluetooth]
[ +0.000000] [<ffffffff814f68ff>] ? _raw_spin_unlock_irqrestore+0x48/0x5c
[ +0.000000] [<ffffffffa00025f6>] hci_rx_work+0xf3/0x2e3 [bluetooth]
[ +0.000000] [<ffffffff8103efed>] process_one_work+0x1dc/0x30b
[ +0.000000] [<ffffffff8103ef83>] ? process_one_work+0x172/0x30b
[ +0.000000] [<ffffffff8103e07f>] ? spin_lock_irq+0x9/0xb
[ +0.000000] [<ffffffff8103fc8d>] worker_thread+0x123/0x1d2
[ +0.000000] [<ffffffff8103fb6a>] ? manage_workers+0x240/0x240
[ +0.000000] [<ffffffff81044211>] kthread+0x9d/0xa5
[ +0.000000] [<ffffffff81044174>] ? __kthread_parkme+0x60/0x60
[ +0.000000] [<ffffffff814f75bc>] ret_from_fork+0x7c/0xb0
[ +0.000000] Code: d7 44 89 8d 50 ff ff ff 4c 89 95 58 ff ff ff e8 44 fc ff ff 44 8b 8d 50 ff ff ff 48 85 c0 4c 8b 95 58 ff ff ff 0f 84 7a 04 00 00 <f0> ff 80 98 01 00 00 83 3d 25 41 a7 00 00 45 8b b5 e8 05 00 00
[ +0.000000] RIP [<ffffffff810620dd>] __lock_acquire+0xed/0xe82
[ +0.000000] RSP <ffff88003c3c19d8>
[ +0.000000] ---[ end trace e73cd3b52352dd34 ]---
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Tested-by: Frederic Dalleau <frederic.dalleau@intel.com>
commit 8cf9fa1240229cbdd888236c0c43fcbad680cf00 upstream.
The conn->smp_chan pointer can be NULL if SMP PDUs arrive at unexpected
moments. To avoid NULL pointer dereferences the code should be checking
for this and disconnect if an unexpected SMP PDU arrives. This patch
fixes the issue by adding a check for conn->smp_chan for all other PDUs
except pairing request and security request (which are are the first
PDUs to come to initialize the SMP context).
commit 0a9ab9bdb3e891762553f667066190c1d22ad62b upstream.
The length parameter should be sizeof(req->name) - 1 because there is no
guarantee that string provided by userspace will contain the trailing
'\0'.
Can be easily reproduced by manually setting req->name to 128 non-zero
bytes prior to ioctl(HIDPCONNADD) and checking the device name setup on
input subsystem:
$ cat /sys/devices/pnp0/00\:04/tty/ttyS0/hci0/hci0\:1/input8/name
AAAAAA[...]AAAAAAAAf0:af:f0:af:f0:af
("f0:af:f0:af:f0:af" is the device bluetooth address, taken from "phys"
field in struct hid_device due to overflow.)
commit dbccd791a3fbbdac12c33834b73beff3984988e9 upstream.
After sending reset command wait for its command complete event before
sending next command. Some chips sends CC event for command received
before reset if reset was send before chip replied with CC.
This is also required by specification that host shall not send
additional HCI commands before receiving CC for reset.
< HCI Command: Reset (0x03|0x0003) plen 0 [hci0] 18.404612
> HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.405850
Write Extended Inquiry Response (0x03|0x0052) ncmd 1
Status: Success (0x00)
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.406079
> HCI Event: Command Complete (0x0e) plen 4 [hci0] 18.407864
Reset (0x03|0x0003) ncmd 1
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0 [hci0] 18.408062
> HCI Event: Command Complete (0x0e) plen 12 [hci0] 18.408835
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
Acked-by: Johan Hedberg <johan.hedberg@intel.com>
commit b9b5ef188e5a2222cfc16ef62a4703080750b451 upstream.
We need to cancel the hci_power_on work in order to avoid it run when we
try to free the hdev.
[ 1434.201149] ------------[ cut here ]------------
[ 1434.204998] WARNING: at lib/debugobjects.c:261 debug_print_object+0x8e/0xb0()
[ 1434.208324] ODEBUG: free active (active state 0) object type: work_struct hint: hci
_power_on+0x0/0x90
[ 1434.210386] Pid: 8564, comm: trinity-child25 Tainted: G W 3.7.0-rc5-next-
20121112-sasha-00018-g2f4ce0e #127
[ 1434.210760] Call Trace:
[ 1434.210760] [<ffffffff819f3d6e>] ? debug_print_object+0x8e/0xb0
[ 1434.210760] [<ffffffff8110b887>] warn_slowpath_common+0x87/0xb0
[ 1434.210760] [<ffffffff8110b911>] warn_slowpath_fmt+0x41/0x50
[ 1434.210760] [<ffffffff819f3d6e>] debug_print_object+0x8e/0xb0
[ 1434.210760] [<ffffffff8376b750>] ? hci_dev_open+0x310/0x310
[ 1434.210760] [<ffffffff83bf94e5>] ? _raw_spin_unlock_irqrestore+0x55/0xa0
[ 1434.210760] [<ffffffff819f3ee5>] __debug_check_no_obj_freed+0xa5/0x230
[ 1434.210760] [<ffffffff83785db0>] ? bt_host_release+0x10/0x20
[ 1434.210760] [<ffffffff819f4d15>] debug_check_no_obj_freed+0x15/0x20
[ 1434.210760] [<ffffffff8125eee7>] kfree+0x227/0x330
[ 1434.210760] [<ffffffff83785db0>] bt_host_release+0x10/0x20
[ 1434.210760] [<ffffffff81e539e5>] device_release+0x65/0xc0
[ 1434.210760] [<ffffffff819d3975>] kobject_cleanup+0x145/0x190
[ 1434.210760] [<ffffffff819d39cd>] kobject_release+0xd/0x10
[ 1434.210760] [<ffffffff819d33cc>] kobject_put+0x4c/0x60
[ 1434.210760] [<ffffffff81e548b2>] put_device+0x12/0x20
[ 1434.210760] [<ffffffff8376a334>] hci_free_dev+0x24/0x30
[ 1434.210760] [<ffffffff82fd8fe1>] vhci_release+0x31/0x60
[ 1434.210760] [<ffffffff8127be12>] __fput+0x122/0x250
[ 1434.210760] [<ffffffff811cab0d>] ? rcu_user_exit+0x9d/0xd0
[ 1434.210760] [<ffffffff8127bf49>] ____fput+0x9/0x10
[ 1434.210760] [<ffffffff81133402>] task_work_run+0xb2/0xf0
[ 1434.210760] [<ffffffff8106cfa7>] do_notify_resume+0x77/0xa0
[ 1434.210760] [<ffffffff83bfb0ea>] int_signal+0x12/0x17
[ 1434.210760] ---[ end trace a6d57fefbc8a8cc7 ]---
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit dc2a0e20fbc85a71c63aa4330b496fda33f6bf80 upstream.
This patch fixes the following report, it happens when accepting rfcomm
connections:
[ 228.165378] =============================================
[ 228.165378] [ INFO: possible recursive locking detected ]
[ 228.165378] 3.7.0-rc1-00536-gc1d5dc4 #120 Tainted: G W
[ 228.165378] ---------------------------------------------
[ 228.165378] bluetoothd/1341 is trying to acquire lock:
[ 228.165378] (sk_lock-AF_BLUETOOTH-BTPROTO_RFCOMM){+.+...}, at:
[<ffffffffa0000aa0>] bt_accept_dequeue+0xa0/0x180 [bluetooth]
[ 228.165378]
[ 228.165378] but task is already holding lock:
[<ffffffffa0205118>] rfcomm_sock_accept+0x58/0x2d0 [rfcomm]
[ 228.165378]
[ 228.165378] other info that might help us debug this:
[ 228.165378] Possible unsafe locking scenario:
[ 228.165378]
[ 228.165378] CPU0
[ 228.165378] ----
[ 228.165378] lock(sk_lock-AF_BLUETOOTH-BTPROTO_RFCOMM);
[ 228.165378]
[ 228.165378] *** DEADLOCK ***
[ 228.165378]
[ 228.165378] May be due to missing lock nesting notation
commit 8f321f853ea33330c7141977cd34804476e2e07e upstream.
If remote device sends bogus RFC option with invalid length,
undefined options values are used. Fix this by using defaults when
remote misbehaves.
This also fixes the following warning reported by gcc 4.7.0:
net/bluetooth/l2cap_core.c: In function 'l2cap_config_rsp':
net/bluetooth/l2cap_core.c:3302:13: warning: 'rfc.max_pdu_size' may be used uninitialized in this function [-Wmaybe-uninitialized]
net/bluetooth/l2cap_core.c:3266:24: note: 'rfc.max_pdu_size' was declared here
net/bluetooth/l2cap_core.c:3298:25: warning: 'rfc.monitor_timeout' may be used uninitialized in this function [-Wmaybe-uninitialized]
net/bluetooth/l2cap_core.c:3266:24: note: 'rfc.monitor_timeout' was declared here
net/bluetooth/l2cap_core.c:3297:25: warning: 'rfc.retrans_timeout' may be used uninitialized in this function [-Wmaybe-uninitialized]
net/bluetooth/l2cap_core.c:3266:24: note: 'rfc.retrans_timeout' was declared here
net/bluetooth/l2cap_core.c:3295:2: warning: 'rfc.mode' may be used uninitialized in this function [-Wmaybe-uninitialized]
net/bluetooth/l2cap_core.c:3266:24: note: 'rfc.mode' was declared here
commit 065a13e2cc665f6547dc7e8a9d6b6565badf940a upstream.
When sending a pairing request or response we should not just blindly
copy the value that the remote device sent. Instead we should at least
make sure to mask out any unknown bits. This is particularly critical
from the upcoming LE Secure Connections feature perspective as
incorrectly indicating support for it (by copying the remote value)
would cause a failure to pair with devices that support it.
commit d8343f125710fb596f7a88cd756679f14f4e77b9 upstream.
In the case that the link is already in the connected state and a
Pairing request arrives from the mgmt interface, hci_conn_security()
would be called but it was not considering LE links.
Reported-by: João Paulo Rechi Vita <jprvita@openbossa.org>
commit cc110922da7e902b62d18641a370fec01a9fa794 upstream.
To make it clear that it may be called from contexts that may not have
any knowledge of L2CAP, we change the connection parameter, to receive
a hci_conn.
This also makes it clear that it is checking the security of the link.
commit 61a0cfb008f57ecf7eb28ee762952fb42dc15d15 upstream.
If SMP fails, we should always cancel security_timer delayed work.
Otherwise, security_timer function may run after l2cap_conn object
has been freed.
This patch fixes the following warning reported by ODEBUG:
WARNING: at lib/debugobjects.c:261 debug_print_object+0x7c/0x8d()
ODEBUG: free active (active state 0) object type: timer_list hint: delayed_work_timer_fn+0x0/0x27
Modules linked in: btusb bluetooth
Pid: 440, comm: kworker/u:2 Not tainted 3.5.0-rc1+ #4
Call Trace:
[<ffffffff81174600>] ? free_obj_work+0x4a/0x7f
[<ffffffff81023eb8>] warn_slowpath_common+0x7e/0x97
[<ffffffff81023f65>] warn_slowpath_fmt+0x41/0x43
[<ffffffff811746b1>] debug_print_object+0x7c/0x8d
[<ffffffff810394f0>] ? __queue_work+0x241/0x241
[<ffffffff81174fdd>] debug_check_no_obj_freed+0x92/0x159
[<ffffffff810ac08e>] slab_free_hook+0x6f/0x77
[<ffffffffa0019145>] ? l2cap_conn_del+0x148/0x157 [bluetooth]
[<ffffffff810ae408>] kfree+0x59/0xac
[<ffffffffa0019145>] l2cap_conn_del+0x148/0x157 [bluetooth]
[<ffffffffa001b9a2>] l2cap_recv_frame+0xa77/0xfa4 [bluetooth]
[<ffffffff810592f9>] ? trace_hardirqs_on_caller+0x112/0x1ad
[<ffffffffa001c86c>] l2cap_recv_acldata+0xe2/0x264 [bluetooth]
[<ffffffffa0002b2f>] hci_rx_work+0x235/0x33c [bluetooth]
[<ffffffff81038dc3>] ? process_one_work+0x126/0x2fe
[<ffffffff81038e22>] process_one_work+0x185/0x2fe
[<ffffffff81059f2e>] ? lock_acquired+0x1b5/0x1cf
[<ffffffffa00028fa>] ? le_scan_work+0x11d/0x11d [bluetooth]
[<ffffffff81036fb6>] ? spin_lock_irq+0x9/0xb
[<ffffffff81039209>] worker_thread+0xcf/0x175
[<ffffffff8103913a>] ? rescuer_thread+0x175/0x175
[<ffffffff8103cfe0>] kthread+0x95/0x9d
[<ffffffff812c5054>] kernel_threadi_helper+0x4/0x10
[<ffffffff812c36b0>] ? retint_restore_args+0x13/0x13
[<ffffffff8103cf4b>] ? flush_kthread_worker+0xdb/0xdb
[<ffffffff812c5050>] ? gs_change+0x13/0x13
This bug can be reproduced using hctool lecc or l2test tools and
bluetoothd not running.
commit 562fcc246ebe31ade6e1be08585673b9b2785498 upstream.
When new BT USB adapter is plugged in it's configured while still being powered
off (HCI_AUTO_OFF flag is set), thus Set LE will only set dev_flags but won't
write changes to controller. As a result it's not possible to start device
discovery session on LE controller as it uses interleaved discovery which
requires LE Supported Host flag in extended features.
This patch ensures HCI Write LE Host Supported is sent when Set Powered is
called to power on controller and clear HCI_AUTO_OFF flag.
Signed-off-by: Andrzej Kaczmarek <andrzej.kaczmarek@tieto.com>
commit 78c04c0bf52360dc2f7185e99c8e9aa05d73ae5a upstream.
For example, when a usb reset is received (I could reproduce it
running something very similar to this[1] in a loop) it could be
that the device is unregistered while the power_off delayed work
is still scheduled to run.
Backtrace:
Hardware name: To Be Filled By O.E.M.
ODEBUG: free active (active state 0) object type: timer_list hint: delayed_work_timer_fn+0x0/0x26
Modules linked in: nouveau mxm_wmi btusb wmi bluetooth ttm coretemp drm_kms_helper
Pid: 2114, comm: usb-reset Not tainted 3.5.0bt-next #2
Call Trace:
[<ffffffff8124cc00>] ? free_obj_work+0x57/0x91
[<ffffffff81058f88>] warn_slowpath_common+0x7e/0x97
[<ffffffff81059035>] warn_slowpath_fmt+0x41/0x43
[<ffffffff8124ccb6>] debug_print_object+0x7c/0x8d
[<ffffffff8106e3ec>] ? __queue_work+0x259/0x259
[<ffffffff8124d63e>] ? debug_check_no_obj_freed+0x6f/0x1b5
[<ffffffff8124d667>] debug_check_no_obj_freed+0x98/0x1b5
[<ffffffffa00aa031>] ? bt_host_release+0x10/0x1e [bluetooth]
[<ffffffff810fc035>] kfree+0x90/0xe6
[<ffffffffa00aa031>] bt_host_release+0x10/0x1e [bluetooth]
[<ffffffff812ec2f9>] device_release+0x4a/0x7e
[<ffffffff8123ef57>] kobject_release+0x11d/0x154
[<ffffffff8123ed98>] kobject_put+0x4a/0x4f
[<ffffffff812ec0d9>] put_device+0x12/0x14
[<ffffffffa009472b>] hci_free_dev+0x22/0x26 [bluetooth]
[<ffffffffa0280dd0>] btusb_disconnect+0x96/0x9f [btusb]
[<ffffffff813581b4>] usb_unbind_interface+0x57/0x106
[<ffffffff812ef988>] __device_release_driver+0x83/0xd6
[<ffffffff812ef9fb>] device_release_driver+0x20/0x2d
[<ffffffff813582a7>] usb_driver_release_interface+0x44/0x7b
[<ffffffff81358795>] usb_forced_unbind_intf+0x45/0x4e
[<ffffffff8134f959>] usb_reset_device+0xa6/0x12e
[<ffffffff8135df86>] usbdev_do_ioctl+0x319/0xe20
[<ffffffff81203244>] ? avc_has_perm_flags+0xc9/0x12e
[<ffffffff812031a0>] ? avc_has_perm_flags+0x25/0x12e
[<ffffffff81050101>] ? do_page_fault+0x31e/0x3a1
[<ffffffff8135eaa6>] usbdev_ioctl+0x9/0xd
[<ffffffff811126b1>] vfs_ioctl+0x21/0x34
[<ffffffff81112f7b>] do_vfs_ioctl+0x408/0x44b
[<ffffffff81208d45>] ? file_has_perm+0x76/0x81
[<ffffffff8111300f>] sys_ioctl+0x51/0x76
[<ffffffff8158db22>] system_call_fastpath+0x16/0x1b
[1] http://cpansearch.perl.org/src/DPAVLIN/Biblio-RFID-0.03/examples/usbreset.c
commit 3d1cbdd6aefff711bcf389fdabc4af9bc22e8201 upstream.
off (HCI_AUTO_OFF flag is set), thus Set SSP will only set dev_flags but won't
write changes to controller. As a result remote devices won't use Secure Simple
Pairing with our device due to SSP Host Support flag disabled in extended
features and may also reject SSP attempt from our side (with possible fallback
to legacy pairing).
This patch ensures HCI Write Simple Pairing Mode is sent when Set Powered is
[ Upstream commit 792039c73cf176c8e39a6e8beef2c94ff46522ed ]
The L2CAP code fails to initialize the l2_bdaddr_type member of struct
sockaddr_l2 and the padding byte added for alignment. It that for leaks
two bytes kernel stack via the getsockname() syscall. Add an explicit
memset(0) before filling the structure to avoid the info leak.
[ Upstream commit 9344a972961d1a6d2c04d9008b13617bcb6ec2ef ]
The RFCOMM code fails to initialize the trailing padding byte of struct
sockaddr_rc added for alignment. It that for leaks one byte kernel stack
via the getsockname() syscall. Add an explicit memset(0) before filling
[ Upstream commit f9432c5ec8b1e9a09b9b0e5569e3c73db8de432a ]
The RFCOMM code fails to initialize the two padding bytes of struct
rfcomm_dev_list_req inserted for alignment before copying it to
userland. Additionally there are two padding bytes in each instance of
struct rfcomm_dev_info. The ioctl() that for disclosures two bytes plus
dev_num times two bytes uninitialized kernel heap memory.
Allocate the memory using kzalloc() to fix this issue.
[ Upstream commit 9ad2de43f1aee7e7274a4e0d41465489299e344b ]
The RFCOMM code fails to initialize the key_size member of struct
bt_security before copying it to userland -- that for leaking one
byte kernel stack. Initialize key_size with 0 to avoid the info
leak.
[ Upstream commit 3f68ba07b1da811bf383b4b701b129bfcb2e4988 ]
The HCI code fails to initialize the hci_channel member of struct
sockaddr_hci and that for leaks two bytes kernel stack via the
getsockname() syscall. Initialize hci_channel with 0 to avoid the
info leak.
[ Upstream commit e15ca9a0ef9a86f0477530b0f44a725d67f889ee ]
The HCI code fails to initialize the two padding bytes of struct
hci_ufilter before copying it to userland -- that for leaking two
bytes kernel stack. Add an explicit memset(0) before filling the
commit a9ea3ed9b71cc3271dd59e76f65748adcaa76422 upstream.
Some devices e.g. some Android based phones don't do SDP search before
pairing and cancel legacy pairing when ACL is disconnected.
PIN Code Request event which changes ACL timeout to HCI_PAIRING_TIMEOUT
is only received after remote user entered PIN.
In that case no L2CAP is connected so default HCI_DISCONN_TIMEOUT
(2 seconds) is being used to timeout ACL connection. This results in
problems with legacy pairing as remote user has only few seconds to
enter PIN before ACL is disconnected.
Increase disconnect timeout for incomming connection to
HCI_PAIRING_TIMEOUT if SSP is disabled and no linkey exists.
To avoid keeping ACL alive for too long after SDP search set ACL
timeout back to HCI_DISCONN_TIMEOUT when L2CAP is connected.
2012-07-19 13:24:43.413521 < HCI Command: Create Connection (0x01|0x0005) plen 13
bdaddr 00:02:72:D6:6A:3F ptype 0xcc18 rswitch 0x01 clkoffset 0x0000
Packet type: DM1 DM3 DM5 DH1 DH3 DH5
2012-07-19 13:24:43.425224 > HCI Event: Command Status (0x0f) plen 4
Create Connection (0x01|0x0005) status 0x00 ncmd 1
2012-07-19 13:24:43.885222 > HCI Event: Role Change (0x12) plen 8
status 0x00 bdaddr 00:02:72:D6:6A:3F role 0x01
Role: Slave
2012-07-19 13:24:44.054221 > HCI Event: Connect Complete (0x03) plen 11
status 0x00 handle 42 bdaddr 00:02:72:D6:6A:3F type ACL encrypt 0x00
2012-07-19 13:24:44.054313 < HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2
handle 42
2012-07-19 13:24:44.055176 > HCI Event: Page Scan Repetition Mode Change (0x20) plen 7
bdaddr 00:02:72:D6:6A:3F mode 0
2012-07-19 13:24:44.056217 > HCI Event: Max Slots Change (0x1b) plen 3
handle 42 slots 5
2012-07-19 13:24:44.059218 > HCI Event: Command Status (0x0f) plen 4
Read Remote Supported Features (0x01|0x001b) status 0x00 ncmd 0
2012-07-19 13:24:44.062192 > HCI Event: Command Status (0x0f) plen 4
Unknown (0x00|0x0000) status 0x00 ncmd 1
2012-07-19 13:24:44.067219 > HCI Event: Read Remote Supported Features (0x0b) plen 11
Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87
2012-07-19 13:24:44.067248 < HCI Command: Read Remote Extended Features (0x01|0x001c) plen 3
handle 42 page 1
2012-07-19 13:24:44.071217 > HCI Event: Command Status (0x0f) plen 4
Read Remote Extended Features (0x01|0x001c) status 0x00 ncmd 1
2012-07-19 13:24:44.076218 > HCI Event: Read Remote Extended Features (0x23) plen 13
status 0x00 handle 42 page 1 max 1
Features: 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2012-07-19 13:24:44.076249 < HCI Command: Remote Name Request (0x01|0x0019) plen 10
bdaddr 00:02:72:D6:6A:3F mode 2 clkoffset 0x0000
2012-07-19 13:24:44.081218 > HCI Event: Command Status (0x0f) plen 4
Remote Name Request (0x01|0x0019) status 0x00 ncmd 1
2012-07-19 13:24:44.105214 > HCI Event: Remote Name Req Complete (0x07) plen 255
status 0x00 bdaddr 00:02:72:D6:6A:3F name 'uw000951-0'
2012-07-19 13:24:44.105284 < HCI Command: Authentication Requested (0x01|0x0011) plen 2
handle 42
2012-07-19 13:24:44.111207 > HCI Event: Command Status (0x0f) plen 4
Authentication Requested (0x01|0x0011) status 0x00 ncmd 1
2012-07-19 13:24:44.112220 > HCI Event: Link Key Request (0x17) plen 6
2012-07-19 13:24:44.112249 < HCI Command: Link Key Request Negative Reply (0x01|0x000c) plen 6
2012-07-19 13:24:44.115215 > HCI Event: Command Complete (0x0e) plen 10
Link Key Request Negative Reply (0x01|0x000c) ncmd 1
2012-07-19 13:24:44.116215 > HCI Event: PIN Code Request (0x16) plen 6
2012-07-19 13:24:48.099184 > HCI Event: Auth Complete (0x06) plen 3
status 0x13 handle 42
Error: Remote User Terminated Connection
2012-07-19 13:24:48.179182 > HCI Event: Disconn Complete (0x05) plen 4
status 0x00 handle 42 reason 0x13
Reason: Remote User Terminated Connection
commit c3e7c0d90b14a3e7ac091d24cef09efb516d587b upstream.
When the name of the given entry is empty , the state needs to be
updated accordingly.
Signed-off-by: Ram Malovany <ramm@ti.com>
commit 7cc8380eb10347016d95bf6f9d842c2ae6d12932 upstream.
If the device was not found in a list of found devices names of which
are pending.This may happen in a case when HCI Remote Name Request
was sent as a part of incoming connection establishment procedure.
Hence there is no need to continue resolving a next name as it will
be done upon receiving another Remote Name Request Complete Event.
This will fix a kernel crash when trying to use this entry to resolve
the next name.
commit c810089c27e48b816181b454fcc493d19fdbc2ba upstream.
If entry wasn't found in the hci_inquiry_cache_lookup_resolve do not
resolve the name.This will fix a kernel crash when trying to use NULL
pointer.
The mgmt_ev_device_connected signal must be sent before any event
indications happen for sockets associated with the connection. Otherwise
e.g. device authorization for the sockets will fail with ENOTCONN as
user space things that there is no baseband link.
This patch fixes the issue by ensuring that the device_connected event
if sent (if it hasn't been so already) as soon as the first ACL data
packet arrives from the remote device.
It fixes L2CAP socket based security level elevation during a
connection. The HID profile needs this (for keyboards) and it is the only
way to achieve the security level elevation when using the management
interface to talk to the kernel (hence the management enabling patch
being the one that exposes this issue).
It enables the userspace a security level change when the socket is
already connected and create a way to notify the socket the result of the
request. At the moment of the request the socket is made non writable, if
the request fails the connections closes, otherwise the socket is made
writable again, POLL_OUT is emmited.
Signed-off-by: Gustavo Padovan <gustavo@padovan.org>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
Command complete event for HCI_OP_USER_PASSKEY_NEG_REPLY would result
in calling handler function also for HCI_OP_LE_SET_SCAN_PARAM. This
could result in undefined behaviour.
If a key is non persistent then it should not be used in future
connections but it should be kept for current connection. And it
should be removed when connecion is removed.
Signed-off-by: Vishal Agarwal <vishal.agarwal@stericsson.com>
This patch changes the return type of function hci_persistent_key
from int to bool because it makes more sense to return information
whether a key is persistent or not as a bool.
Pull x32 support for x86-64 from Ingo Molnar:
"This tree introduces the X32 binary format and execution mode for x86:
32-bit data space binaries using 64-bit instructions and 64-bit kernel
syscalls.
This allows applications whose working set fits into a 32 bits address
space to make use of 64-bit instructions while using a 32-bit address
space with shorter pointers, more compressed data structures, etc."
Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c}
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
x32: Fix alignment fail in struct compat_siginfo
x32: Fix stupid ia32/x32 inversion in the siginfo format
x32: Add ptrace for x32
x32: Switch to a 64-bit clock_t
x32: Provide separate is_ia32_task() and is_x32_task() predicates
x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls
x86/x32: Fix the binutils auto-detect
x32: Warn and disable rather than error if binutils too old
x32: Only clear TIF_X32 flag once
x32: Make sure TS_COMPAT is cleared for x32 tasks
fs: Remove missed ->fds_bits from cessation use of fd_set structs internally
fs: Fix close_on_exec pointer in alloc_fdtable
x32: Drop non-__vdso weak symbols from the x32 VDSO
x32: Fix coding style violations in the x32 VDSO code
x32: Add x32 VDSO support
x32: Allow x32 to be configured
x32: If configured, add x32 system calls to system call tables
x32: Handle process creation
x32: Signal-related system calls
x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h>
Add missing endian conversion for page scan interval and window.
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
Incorrect pointer passed to eir_append_data made mgmt_device_connected
event unparsable by mgmt user space entity.
Signed-off-by: Brian Gix <bgix@codeaurora.org>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
When we queue delayed work we hold(chan) and delayed work
shall put(chan) after execution.
Make sure hci_dev_open returns immediately if hci_dev_unregister has
been called.
This fixes a race between hci_dev_open and hci_dev_unregister which can
lead to a NULL-pointer dereference.
Bug is 100% reproducible using hciattach and a disconnected serial port:
0. # hciattach -n /dev/ttyO1 any noflow
1. hci_dev_open called from hci_power_on grabs req lock
2. hci_init_req executes but device fails to initialise (times out
eventually)
3. hci_dev_open is called from hci_sock_ioctl and sleeps on req lock
4. hci_uart_tty_close calls hci_dev_unregister and sleeps on req lock in
hci_dev_do_close
5. hci_dev_open (1) releases req lock
6. hci_dev_do_close grabs req lock and returns as device is not up
7. hci_dev_unregister sleeps in destroy_workqueue
8. hci_dev_open (3) grabs req lock, calls hci_init_req and eventually sleeps
9. hci_dev_unregister finishes, while hci_dev_open is still running...
[ 79.627136] INFO: trying to register non-static key.
[ 79.632354] the code is fine but needs lockdep annotation.
[ 79.638122] turning off the locking correctness validator.
[ 79.643920] [<c00188bc>] (unwind_backtrace+0x0/0xf8) from [<c00729c4>] (__lock_acquire+0x1590/0x1ab0)
[ 79.653594] [<c00729c4>] (__lock_acquire+0x1590/0x1ab0) from [<c00733f8>] (lock_acquire+0x9c/0x128)
[ 79.663085] [<c00733f8>] (lock_acquire+0x9c/0x128) from [<c0040a88>] (run_timer_softirq+0x150/0x3ac)
[ 79.672668] [<c0040a88>] (run_timer_softirq+0x150/0x3ac) from [<c003a3b8>] (__do_softirq+0xd4/0x22c)
[ 79.682281] [<c003a3b8>] (__do_softirq+0xd4/0x22c) from [<c003a924>] (irq_exit+0x8c/0x94)
[ 79.690856] [<c003a924>] (irq_exit+0x8c/0x94) from [<c0013a50>] (handle_IRQ+0x34/0x84)
[ 79.699157] [<c0013a50>] (handle_IRQ+0x34/0x84) from [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c)
[ 79.708648] [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) from [<c037499c>] (__irq_usr+0x3c/0x60)
[ 79.718048] Exception stack(0xcf281fb0 to 0xcf281ff8)
[ 79.723358] 1fa0: 0001e6a0 be8dab00 0001e698 00036698
[ 79.731933] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000
[ 79.740509] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff
[ 79.747497] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 79.756011] pgd = cf3b4000
[ 79.758850] [00000000] *pgd=8f0c7831, *pte=00000000, *ppte=00000000
[ 79.765502] Internal error: Oops: 80000007 [#1]
[ 79.770294] Modules linked in:
[ 79.773529] CPU: 0 Tainted: G W (3.3.0-rc6-00002-gb5d5c87 #421)
[ 79.781066] PC is at 0x0
[ 79.783721] LR is at run_timer_softirq+0x16c/0x3ac
[ 79.788787] pc : [<00000000>] lr : [<c0040aa4>] psr: 60000113
[ 79.788787] sp : cf281ee0 ip : 00000000 fp : cf280000
[ 79.800903] r10: 00000004 r9 : 00000100 r8 : b6f234d0
[ 79.806427] r7 : c0519c28 r6 : cf093488 r5 : c0561a00 r4 : 00000000
[ 79.813323] r3 : 00000000 r2 : c054eee0 r1 : 00000001 r0 : 00000000
[ 79.820190] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 79.827728] Control: 10c5387d Table: 8f3b4019 DAC: 00000015
[ 79.833801] Process gpsd (pid: 1265, stack limit = 0xcf2802e8)
[ 79.839965] Stack: (0xcf281ee0 to 0xcf282000)
[ 79.844573] 1ee0: 00000002 00000000 c0040a24 00000000 00000002 cf281f08 00200200 00000000
[ 79.853210] 1f00: 00000000 cf281f18 cf281f08 00000000 00000000 00000000 cf281f18 cf281f18
[ 79.861816] 1f20: 00000000 00000001 c056184c 00000000 00000001 b6f234d0 c0561848 00000004
[ 79.870452] 1f40: cf280000 c003a3b8 c051e79c 00000001 00000000 00000100 3fa9e7b8 0000000a
[ 79.879089] 1f60: 00000025 cf280000 00000025 00000000 00000000 b6f234d0 00000000 00000004
[ 79.887756] 1f80: 00000000 c003a924 c053ad38 c0013a50 fa200000 cf281fb0 ffffffff c0008530
[ 79.896362] 1fa0: 0001e6a0 0000aab8 80000010 c037499c 0001e6a0 be8dab00 0001e698 00036698
[ 79.904998] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000
[ 79.913665] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff 00fbf700 04ffff00
[ 79.922302] [<c0040aa4>] (run_timer_softirq+0x16c/0x3ac) from [<c003a3b8>] (__do_softirq+0xd4/0x22c)
[ 79.931945] [<c003a3b8>] (__do_softirq+0xd4/0x22c) from [<c003a924>] (irq_exit+0x8c/0x94)
[ 79.940582] [<c003a924>] (irq_exit+0x8c/0x94) from [<c0013a50>] (handle_IRQ+0x34/0x84)
[ 79.948913] [<c0013a50>] (handle_IRQ+0x34/0x84) from [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c)
[ 79.958404] [<c0008530>] (omap3_intc_handle_irq+0x48/0x4c) from [<c037499c>] (__irq_usr+0x3c/0x60)
[ 79.967773] Exception stack(0xcf281fb0 to 0xcf281ff8)
[ 79.973083] 1fa0: 0001e6a0 be8dab00 0001e698 00036698
[ 79.981658] 1fc0: 0002df98 0002df38 0000001f 00000000 b6f234d0 00000000 00000004 00000000
[ 79.990234] 1fe0: 0001e6f8 be8d6aa0 be8dac50 0000aab8 80000010 ffffffff
[ 79.997161] Code: bad PC value
[ 80.000396] ---[ end trace 6f6739840475f9ee ]---
[ 80.005279] Kernel panic - not syncing: Fatal exception in interrupt
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Fix network to host endian conversion for L2CAP chan id.
Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com>
Acked-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
Pull TTY/serial patches from Greg KH:
"tty and serial merge for 3.4-rc1
Here's the big serial and tty merge for the 3.4-rc1 tree.
There's loads of fixes and reworks in here from Jiri for the tty
layer, and a number of patches from Alan to help try to wrestle the vt
layer into a sane model.
Other than that, lots of driver updates and fixes, and other minor
stuff, all detailed in the shortlog."
* tag 'tty-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (132 commits)
serial: pxa: add clk_prepare/clk_unprepare calls
TTY: Wrong unicode value copied in con_set_unimap()
serial: PL011: clear pending interrupts
serial: bfin-uart: Don't access tty circular buffer in TX DMA interrupt after it is reset.
vt: NULL dereference in vt_do_kdsk_ioctl()
tty: serial: vt8500: fix annotations for probe/remove
serial: remove back and forth conversions in serial_out_sync
serial: use serial_port_in/out vs serial_in/out in 8250
serial: introduce generic port in/out helpers
serial: reduce number of indirections in 8250 code
serial: delete useless void casts in 8250.c
serial: make 8250's serial_in shareable to other drivers.
serial: delete last unused traces of pausing I/O in 8250
pch_uart: Add module parameter descriptions
pch_uart: Use existing default_baud in setup_console
pch_uart: Add user_uartclk parameter
pch_uart: Add Fish River Island II uart clock quirks
pch_uart: Use uartclk instead of base_baud
mpc5200b/uart: select more tolerant uart prescaler on low baudrates
tty: moxa: fix bit test in moxa_start()
All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
If a master would like to raise the security level, it will send a
pairing request. While the pending security level is set on an incoming
security request (from a slave), it is not set on a pairing request. As
a result, the security level would not be raised on the slave in such
case.
Fix this by setting the pending security when receiving pairing
requests according to the requested authorization.
Signed-off-by: Ido Yariv <ido@wizery.com>
Acked-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
The major index of the table is actually the remote I/O capabilities, not
the local ones. As a result, devices with different I/O capabilities
could have used wrong or even unsupported generation methods.
CC: Brian Gix <bgix@codeaurora.org>
