path: root/net/bridge/br_notify.c
2011-08-09Bridge: Always send NETDEV_CHANGEADDR up on br MAC change.Andrei Warkentin
This ensures the neighbor entries associated with the bridge dev are flushed, also invalidating the associated cached L2 headers. This means we br_add_if/br_del_if ports to implement hand-over and not wind up with bridge packets going out with stale MAC. This means we can also change MAC of port device and also not wind up with bridge packets going out with stale MAC. This builds on Stephen Hemminger's patch, also handling the br_del_if case and the port MAC change case. Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Andrei Warkentin <andreiw@motorola.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28bridge: convert br_features_recompute() to ndo_fix_featuresMichał Mirosław
Note: netdev_update_features() needs only rtnl_lock as br->port_list is only changed while holding it. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17bridge: fix accidental creation of sysfs directoryStephen Hemminger
Commit bb900b27a2f49b37bc38c08e656ea13048fee13b ("bridge: allow creating bridge devices with netlink") introduced a bug in net-next because of a typo in notifier. Every device would have the sysfs bridge directory (and files). Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-04bridge: allow creating bridge devices with netlinkstephen hemminger
Add netlink device ops to allow creating bridge device via netlink. This works in a manner similar to vlan, macvlan and bonding. Example: # ip link add link dev br0 type bridge # ip link del dev br0 The change required rearranging initializtion code to deal with being called by create link. Most of the initialization happens in br_dev_setup, but allocation of stats is done in ndo_init callback to deal with allocation failure. Sysfs setup has to wait until after the network device kobject is registered. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15bridge: add RCU annotations to bridge port lookupEric Dumazet
br_port_get() renamed to br_port_get_rtnl() to make clear RTNL is held. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15bridge: fix RCU races with bridge portstephen hemminger
The macro br_port_exists() is not enough protection when only RCU is being used. There is a tiny race where other CPU has cleared port handler hook, but is bridge port flag might still be set. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15bridge: use rx_handler_data pointer to store net_bridge_port pointerJiri Pirko
Register net_bridge_port pointer as rx_handler data pointer. As br_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a bridge port. Also rcuized pointers are now correctly dereferenced in br_fdb.c and in netfilter parts. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15bridge: update sysfs link names if port device names have changedSimon Arlott
Links for each port are created in sysfs using the device name, but this could be changed after being added to the bridge. As well as being unable to remove interfaces after this occurs (because userspace tools don't recognise the new name, and the kernel won't recognise the old name), adding another interface with the old name to the bridge will cause an error trying to create the sysfs link. This fixes the problem by listening for NETDEV_CHANGENAME notifications and renaming the link. https://bugzilla.kernel.org/show_bug.cgi?id=12743 Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18net: forbid underlaying devices to change its typeJiri Pirko
It's not desired for underlaying devices to change type. At the time, there is for example possible to have bond with changed type from Ethernet to Infiniband as a port of a bridge. This patch fixes this. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08netns bridge: allow bridges in netns!Alexey Dobriyan
Bridge as netdevice doesn't cross netns boundaries. Bridge ports and bridge itself live in same netns. Notifiers are fixed. netns propagated from userspace socket for setup and teardown. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Stephen Hemminger <shemming@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25bridge: change when netlink events go to STPStephen Hemminger
Need to tell STP daemon about more events, like any time a device is added even when it is down. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
2007-02-26[BRIDGE]: eliminate workqueue for carrier checkStephen Hemminger
Having a work queue for checking carrier leads to lots of race issues. Simpler to just get the cost when data structure is created and update on change. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-13[BRIDGE] br_if: Fix oops in port_carrier_checkJarek Poplawski
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Acked-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] BRIDGE: Fix whitespace errors.YOSHIFUJI Hideaki
2006-06-17[BRIDGE]: netlink interface for link managementStephen Hemminger
Add basic netlink support to the Ethernet bridge. Including: * dump interfaces in bridges * monitor link status changes * change state of bridge port For some demo programs see: http://developer.osdl.org/shemminger/prototypes/brnl.tar.gz These are to allow building a daemon that does alternative implementations of Spanning Tree Protocol. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: handle speed detection after carrier changesStephen Hemminger
Speed of a interface may not be available until carrier is detected in the case of autonegotiation. To get the correct value we need to recheck speed after carrier event. But the check needs to be done in a context that is similar to normal ethtool interface (can sleep). Also, delay check for 1ms to try avoid any carrier bounce transitions. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-29[BRIDGE]: set features based on enslaved devicesStephen Hemminger
Make features of the bridge pseudo-device be a subset of the underlying devices. Motivated by Xen and others who use bridging to do failover. Signed-off-by: Catalin BOIE <catab at umrella.ro> Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
