Convert the uses of memcpy to ether_addr_copy because
for some architectures it is smaller and faster.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Part of the transition of done by this semantic patch:
// <smpl>
@ rule1 @
struct xt_target ops;
identifier check;
ops.checkentry = check;
identifier rule1.check;
check(...) { <...
-return true;
+return 0;
check(...) { <...
-return false;
+return -EINVAL;
// </smpl>
Restore function signatures from bool to int so that we can report
memory allocation failures or similar using -ENOMEM rather than
always having to pass -EINVAL back.
// <smpl>
type bool;
identifier check, par;
-bool check
+int check
(struct xt_tgchk_param *par) { ... }
// </smpl>
Minus the change it does to xt_ct_find_proto.
This will cause trouble once CONFIG_COMPAT support is added to ebtables.
xt_compat_*_offset() calculate the kernel/userland structure size delta
using:
XT_ALIGN(size) - COMPAT_XT_ALIGN(size)
If the match/target sizes are aligned at registration time,
delta is always zero.
Should have zero effect for existing systems: xtables uses
XT_ALIGN() whenever it deals with match/target sizes.
Signed-off-by: Florian Westphal <fwestphal@astaro.com>
This patch does this for target extensions' checkentry functions.
This patch does this for target extensions' target functions.
Ebtables ORs (1 << NF_BR_NUMHOOKS) into the hook mask to indicate that
the extension was called from a base chain. So this also needs to be
present in the extensions' ->hooks.
The function ebt_do_table doesn't take NF_DROP as a verdict from the targets.
Signed-off-by: Joonwoo Park <joonwpark81@gmail.com>
http://bugzilla.kernel.org/show_bug.cgi?id=9920
The function skb_make_writable returns true or false.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Update the MODULES_DESCRIPTION() tags for all Ebtables modules.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
This patch replaces unnecessary uses of skb_copy, pskb_copy and
skb_realloc_headroom by functions such as skb_make_writable and
pskb_expand_head.
This allows us to remove the double pointers later.
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
infrastructure for it.
Let it rip!
