path: root/net/bridge/netfilter/ebt_ip.c
2008-10-08netfilter: xtables: move extension arguments into compound structure (2/6)Jan Engelhardt
This patch does this for match extensions' checkentry functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (1/6)Jan Engelhardt
The function signatures for Xtables extensions have grown over time. It involves a lot of typing/replication, and also a bit of stack space even if they are not used. Realize an NFWS2008 idea and pack them into structs. The skb remains outside of the struct so gcc can continue to apply its optimizations. This patch does this for match extensions' match functions. A few ambiguities have also been addressed. The "offset" parameter for example has been renamed to "fragoff" (there are so many different offsets already) and "protoff" to "thoff" (there is more than just one protocol here, so clarify). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: move Ebtables to use XtablesJan Engelhardt
2008-10-08netfilter: change Ebtables function signatures to match Xtables'sJan Engelhardt
2008-10-08netfilter: add dummy members to Ebtables code to ease transition to XtablesJan Engelhardt
2008-10-08netfilter: change return types of match functions for ebtables extensionsJan Engelhardt
2008-10-08netfilter: change return types of check functions for Ebtables extensionsJan Engelhardt
2008-10-08netfilter: ebtables: do centralized size checkingJan Engelhardt
2008-01-31[NETFILTER]: ebtables: mark matches, targets and watchers __read_mostlyJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: ebtables: Update modules' descriptionsJan Engelhardt
Update the MODULES_DESCRIPTION() tags for all Ebtables modules. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: ebtables: remove casts, use constsJan Engelhardt
2007-02-10[NET] BRIDGE: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NET]: Add UDPLITE support in a few missing spotsPatrick McHardy
2006-12-02[BRIDGE]: Annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[NETFILTER]: Rename init functions.Andrew Morton
Every netfilter module uses `init' for its module_init() function and `fini' or `cleanup' for its module_exit() function. Problem is, this creates uninformative initcall_debug output and makes ctags rather useless. So go through and rename them all to $(filename)_init and $(filename)_fini. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[EBTABLES]: Handle SCTP/DCCP in ebt_{ip,log}Patrick McHardy
2006-01-10[EBTABLES] Don't match tcp/udp source/destination port for IP fragmentsBart De Schuymer
Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: David S. Miller <davem@davemloft.net>
