[ Upstream commit 0888d5f3c0f183ea6177355752ada433d370ac89 ]
The bridge is falsly dropping ipv6 mulitcast packets if there is:
1. No ipv6 address assigned on the brigde.
2. No external mld querier present.
3. The internal querier enabled.
When the bridge fails to build mld queries, because it has no
ipv6 address, it slilently returns, but keeps the local querier enabled.
This specific case causes confusing packet loss.
Ipv6 multicast snooping can only work if:
a) An external querier is present
OR
b) The bridge has an ipv6 address an is capable of sending own queries
Otherwise it has to forward/flood the ipv6 multicast traffic,
because snooping cannot work.
This patch fixes the issue by adding a flag to the bridge struct that
indicates that there is currently no ipv6 address assinged to the bridge
and returns a false state for the local querier in
__br_multicast_querier_exists().
Special thanks to Linus Lüssing.
Fixes: d1d81d4c3dd8 ("bridge: check return value of ipv6_dev_get_saddr()")
Signed-off-by: Daniel Danzberger <daniel@dd-wrt.com>
Acked-by: Linus Lüssing <linus.luessing@c0d3.blue>
[ Upstream commit 0b148def403153a4d1565f1640356cb78ce5109f ]
The missing br_vlan_should_use() test caused creation of an unneeded
local fdb entry on changing mac address of a bridge device when there is
a vlan which is configured on a bridge port but not on the bridge
device.
Fixes: 2594e9064a57 ("bridge: vlan: add per-vlan struct and move to rhashtables")
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 856ce5d083e14571d051301fe3c65b32b8cbe321 ]
With the newly introduced helper functions the skb pulling is hidden
in the checksumming function - and undone before returning to the
caller.
The IGMP and MLD query parsing functions in the bridge still
assumed that the skb is pointing to the beginning of the IGMP/MLD
message while it is now kept at the beginning of the IPv4/6 header.
If there is a querier somewhere else, then this either causes
the multicast snooping to stay disabled even though it could be
enabled. Or, if we have the querier enabled too, then this can
create unnecessary IGMP / MLD query messages on the link.
Fixing this by taking the offset between IP and IGMP/MLD header into
account, too.
Fixes: 9afd85c9e455 ("net: Export IGMP/MLD message validation code")
Reported-by: Simon Wunderlich <sw@simonwunderlich.de>
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
[ Upstream commit 31ca0458a61a502adb7ed192bf9716c6d05791a5 ]
get_bridge_ifindices() is used from the old "deviceless" bridge ioctl
calls which aren't called with rtnl held. The comment above says that it is
called with rtnl but that is not really the case.
Here's a sample output from a test ASSERT_RTNL() which I put in
get_bridge_ifindices and executed "brctl show":
[ 957.422726] RTNL: assertion failed at net/bridge//br_ioctl.c (30)
[ 957.422925] CPU: 0 PID: 1862 Comm: brctl Tainted: G W O
4.6.0-rc4+ #157
[ 957.423009] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996),
BIOS 1.8.1-20150318_183358- 04/01/2014
[ 957.423009] 0000000000000000 ffff880058adfdf0 ffffffff8138dec5
0000000000000400
[ 957.423009] ffffffff81ce8380 ffff880058adfe58 ffffffffa05ead32
0000000000000001
[ 957.423009] 00007ffec1a444b0 0000000000000400 ffff880053c19130
0000000000008940
[ 957.423009] Call Trace:
[ 957.423009] [<ffffffff8138dec5>] dump_stack+0x85/0xc0
[ 957.423009] [<ffffffffa05ead32>]
br_ioctl_deviceless_stub+0x212/0x2e0 [bridge]
[ 957.423009] [<ffffffff81515beb>] sock_ioctl+0x22b/0x290
[ 957.423009] [<ffffffff8126ba75>] do_vfs_ioctl+0x95/0x700
[ 957.423009] [<ffffffff8126c159>] SyS_ioctl+0x79/0x90
[ 957.423009] [<ffffffff8163a4c0>] entry_SYSCALL_64_fastpath+0x23/0xc1
Since it only reads bridge ifindices, we can use rcu to safely walk the net
device list. Also remove the wrong rtnl comment above.
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit 5e263f712691615fb802f06c98d7638c378f5d11 ]
When NET_SWITCHDEV=n, switchdev_port_attr_set will return -EOPNOTSUPP,
we should ignore this error code and continue to set the ageing time.
Fixes: c62987bbd8a1 ("bridge: push bridge setting ageing_time down to switchdev")
Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com>
Acked-by: Ido Schimmel <idosch@mellanox.com>
[ Upstream commit 4c656c13b254d598e83e586b7b4d36a2043dad85 ]
This fixes a regression in the bridge ageing time caused by:
commit c62987bbd8a1 ("bridge: push bridge setting ageing_time down to switchdev")
There are users of Linux bridge which use the feature that if ageing time
is set to 0 it causes entries to never expire. See:
https://www.linuxfoundation.org/collaborate/workgroups/networking/bridge
For a pure software bridge, it is unnecessary for the code to have
arbitrary restrictions on what values are allowable.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 4f2c6ae5c64c353fb1b0425e4747e5603feadba1 ]
When switchdev drivers process FDB notifications from the underlying
device they resolve the netdev to which the entry points to and notify
the bridge using the switchdev notifier.
However, since the RTNL mutex is not held there is nothing preventing
the netdev from disappearing in the middle, which will cause
br_switchdev_event() to dereference a non-existing netdev.
Make switchdev drivers hold the lock at the beginning of the
notification processing session and release it once it ends, after
notifying the bridge.
Also, remove switchdev_mutex and fdb_lock, as they are no longer needed
when RTNL mutex is held.
Fixes: 03bf0c281234 ("switchdev: introduce switchdev notifier")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit c6894dec8ea9ae05747124dce98b3b5c2e69b168 ]
After promisc mode management was introduced a bridge device could do
dev_set_promiscuity from its ndo_change_rx_flags() callback which in
turn can be called after the bridge's addr_list_lock has been taken
(e.g. by dev_uc_add). This causes a false positive lockdep splat because
the port interfaces' addr_list_lock is taken when br_manage_promisc()
runs after the bridge's addr list lock was already taken.
To remove the false positive introduce a custom bridge addr_list_lock
class and set it on bridge init.
A simple way to reproduce this is with the following:
$ brctl addbr br0
$ ip l add l br0 br0.100 type vlan id 100
$ ip l set br0 up
$ ip l set br0.100 up
$ echo 1 > /sys/class/net/br0/bridge/vlan_filtering
$ brctl addif br0 eth0
Splat:
[ 43.684325] =============================================
[ 43.684485] [ INFO: possible recursive locking detected ]
[ 43.684636] 4.4.0-rc8+ #54 Not tainted
[ 43.684755] ---------------------------------------------
[ 43.684906] brctl/1187 is trying to acquire lock:
[ 43.685047] (_xmit_ETHER){+.....}, at: [<ffffffff8150169e>] dev_set_rx_mode+0x1e/0x40
[ 43.685460] but task is already holding lock:
[ 43.685618] (_xmit_ETHER){+.....}, at: [<ffffffff815072a7>] dev_uc_add+0x27/0x80
[ 43.686015] other info that might help us debug this:
[ 43.686316] Possible unsafe locking scenario:
[ 43.686743] CPU0
[ 43.686967] ----
[ 43.687197] lock(_xmit_ETHER);
[ 43.687544] lock(_xmit_ETHER);
[ 43.687886] *** DEADLOCK ***
[ 43.688438] May be due to missing lock nesting notation
[ 43.688882] 2 locks held by brctl/1187:
[ 43.689134] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff81510317>] rtnl_lock+0x17/0x20
[ 43.689852] #1: (_xmit_ETHER){+.....}, at: [<ffffffff815072a7>] dev_uc_add+0x27/0x80
[ 43.690575] stack backtrace:
[ 43.690970] CPU: 0 PID: 1187 Comm: brctl Not tainted 4.4.0-rc8+ #54
[ 43.691270] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.8.1-20150318_183358- 04/01/2014
[ 43.691770] ffffffff826a25c0 ffff8800369fb8e0 ffffffff81360ceb ffffffff826a25c0
[ 43.692425] ffff8800369fb9b8 ffffffff810d0466 ffff8800369fb968 ffffffff81537139
[ 43.693071] ffff88003a08c880 0000000000000000 00000000ffffffff 0000000002080020
[ 43.693709] Call Trace:
[ 43.693931] [<ffffffff81360ceb>] dump_stack+0x4b/0x70
[ 43.694199] [<ffffffff810d0466>] __lock_acquire+0x1e46/0x1e90
[ 43.694483] [<ffffffff81537139>] ? netlink_broadcast_filtered+0x139/0x3e0
[ 43.694789] [<ffffffff8153b5da>] ? nlmsg_notify+0x5a/0xc0
[ 43.695064] [<ffffffff810d10f5>] lock_acquire+0xe5/0x1f0
[ 43.695340] [<ffffffff8150169e>] ? dev_set_rx_mode+0x1e/0x40
[ 43.695623] [<ffffffff815edea5>] _raw_spin_lock_bh+0x45/0x80
[ 43.695901] [<ffffffff8150169e>] ? dev_set_rx_mode+0x1e/0x40
[ 43.696180] [<ffffffff8150169e>] dev_set_rx_mode+0x1e/0x40
[ 43.696460] [<ffffffff8150189c>] dev_set_promiscuity+0x3c/0x50
[ 43.696750] [<ffffffffa0586845>] br_port_set_promisc+0x25/0x50 [bridge]
[ 43.697052] [<ffffffffa05869aa>] br_manage_promisc+0x8a/0xe0 [bridge]
[ 43.697348] [<ffffffffa05826ee>] br_dev_change_rx_flags+0x1e/0x20 [bridge]
[ 43.697655] [<ffffffff81501532>] __dev_set_promiscuity+0x132/0x1f0
[ 43.697943] [<ffffffff81501672>] __dev_set_rx_mode+0x82/0x90
[ 43.698223] [<ffffffff815072de>] dev_uc_add+0x5e/0x80
[ 43.698498] [<ffffffffa05b3c62>] vlan_device_event+0x542/0x650 [8021q]
[ 43.698798] [<ffffffff8109886d>] notifier_call_chain+0x5d/0x80
[ 43.699083] [<ffffffff810988b6>] raw_notifier_call_chain+0x16/0x20
[ 43.699374] [<ffffffff814f456e>] call_netdevice_notifiers_info+0x6e/0x80
[ 43.699678] [<ffffffff814f4596>] call_netdevice_notifiers+0x16/0x20
[ 43.699973] [<ffffffffa05872be>] br_add_if+0x47e/0x4c0 [bridge]
[ 43.700259] [<ffffffffa058801e>] add_del_if+0x6e/0x80 [bridge]
[ 43.700548] [<ffffffffa0588b5f>] br_dev_ioctl+0xaf/0xc0 [bridge]
[ 43.700836] [<ffffffff8151a7ac>] dev_ifsioc+0x30c/0x3c0
[ 43.701106] [<ffffffff8151aac9>] dev_ioctl+0xf9/0x6f0
[ 43.701379] [<ffffffff81254345>] ? mntput_no_expire+0x5/0x450
[ 43.701665] [<ffffffff812543ee>] ? mntput_no_expire+0xae/0x450
[ 43.701947] [<ffffffff814d7b02>] sock_do_ioctl+0x42/0x50
[ 43.702219] [<ffffffff814d8175>] sock_ioctl+0x1e5/0x290
[ 43.702500] [<ffffffff81242d0b>] do_vfs_ioctl+0x2cb/0x5c0
[ 43.702771] [<ffffffff81243079>] SyS_ioctl+0x79/0x90
[ 43.703033] [<ffffffff815eebb6>] entry_SYSCALL_64_fastpath+0x16/0x7a
CC: Vlad Yasevich <vyasevic@redhat.com>
CC: Stephen Hemminger <stephen@networkplumber.org>
CC: Bridge list <bridge@lists.linux-foundation.org>
CC: Andy Gospodarek <gospo@cumulusnetworks.com>
CC: Roopa Prabhu <roopa@cumulusnetworks.com>
Fixes: 2796d0c648c9 ("bridge: Automatically manage port promiscuous mode.")
Reported-by: Andy Gospodarek <gospo@cumulusnetworks.com>
[I stole this patch from Eric Biederman. He wrote:]
> There is no defined mechanism to pass network namespace information
> into /sbin/bridge-stp therefore don't even try to invoke it except
> for bridge devices in the initial network namespace.
> It is possible for unprivileged users to cause /sbin/bridge-stp to be
> invoked for any network device name which if /sbin/bridge-stp does not
> guard against unreasonable arguments or being invoked twice on the
> same network device could cause problems.
[Hannes: changed patch using netns_eq]
Cc: Eric W. Biederman <ebiederm@xmission.com>
The bridge's ageing time is offloaded to hardware when:
1) A port joins a bridge
2) The ageing time of the bridge is changed
In the first case the ageing time is offloaded as jiffies, but in the
second case it's offloaded as clock_t, which is what existing switchdev
drivers expect to receive.
Fixes: 6ac311ae8bfb ("Adding switchdev ageing notification on port bridged")
When NET_SWITCHDEV=n, switchdev_port_attr_set simply returns EOPNOTSUPP.
In this case we should not emit errors and warnings to the kernel log.
Reported-by: Sander Eikelenboom <linux@eikelenboom.it>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Fixes: 0bc05d585d38 ("switchdev: allow caller to explicitly request
attr_set as deferred")
bridged")
This reverts commit 34c2d9fb0498c066afbe610b15e18995fd8be792.
There are 2 reasons for this revert:
1) The commit in question doesn't do what it says it does. The
description reads: "Allow bridge forward delay to be configured
when Spanning Tree is enabled." This was already the case before
the commit was made. What the commit actually do was disallow
invalid values or 'forward_delay' when STP was turned off.
2) The above change was actually a change in the user observed
behavior and broke things like libvirt and other network configs
that set 'forward_delay' to 0 without enabling STP. The value
of 0 is actually used when STP is turned off to immediately mark
the bridge as forwarding.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
br_should_learn() is protected by RCU and not by RTNL, so use correct
flavor of nbp_vlan_group().
Fixes: 907b1e6e83ed ("bridge: vlan: use proper rcu for the vlgrp
member")
The flag used to indicate if a VLAN should be used for filtering - as
opposed to context only - on the bridge itself (e.g. br0) is called
'brentry' and not 'brvlan'.
When adding a port to a bridge we initialize VLAN filtering on it. We do
not bail out in case an error occurred in nbp_vlan_init, as it can be
used as a non VLAN filtering bridge.
However, if VLAN filtering is required and an error occurred in
nbp_vlan_init, we should set vlgrp to NULL, so that VLAN filtering
functions (e.g. br_vlan_find, br_get_pvid) will know the struct is
invalid and will not try to access it.
hashtable
Problem Description:
We can add fdbs pointing to the bridge with NULL ->dst but that has a
few race conditions because br_fdb_insert() is used which first creates
the fdb and then, after the fdb has been published/linked, sets
"is_local" to 1 and in that time frame if a packet arrives for that fdb
it may see it as non-local and either do a NULL ptr dereference in
br_forward() or attach the fdb to the port where it arrived, and later
br_fdb_insert() will make it local thus getting a wrong fdb entry.
Call chain br_handle_frame_finish() -> br_forward():
But in br_handle_frame_finish() in order to call br_forward() the dst
should not be local i.e. skb != NULL, whenever the dst is
found to be local skb is set to NULL so we can't forward it,
and here comes the problem since it's running only
with RCU when forwarding packets it can see the entry before "is_local"
is set to 1 and actually try to dereference NULL.
The main issue is that if someone sends a packet to the switch while
it's adding the entry which points to the bridge device, it may
dereference NULL ptr. This is needed now after we can add fdbs
pointing to the bridge. This poses a problem for
br_fdb_update() as well, while someone's adding a bridge fdb, but
before it has is_local == 1, it might get moved to a port if it comes
as a source mac and then it may get its "is_local" set to 1
This patch changes fdb_create to take is_local and is_static as
arguments to set these values in the fdb entry before it is added to the
hash. Also adds null check for port in br_forward.
Fixes: 3741873b4f73 ("bridge: allow adding of fdb entries pointing to the bridge device")
Reported-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
if_nlmsg_size() overestimates the minimum allocation size of netlink
dump request (when called from rtnl_calcit()) or the size of the
message (when called from rtnl_getlink()). This is because
ext_filter_mask is not supported by rtnl_link_get_af_size() and
rtnl_link_get_size().
The over-estimation is significant when at least one netdev has many
VLANs configured (8 bytes for each configured VLAN).
This patch-set "rightsizes" the protocol specific attribute size
calculation by propagating ext_filter_mask to rtnl_link_get_af_size()
and adding this a argument to get_link_af_size op in rtnl_af_ops.
Bridge module already used filtering aware sizing for notifications.
br_get_link_af_size_filtered() is consistent with the modified
get_link_af_size op so it replaces br_get_link_af_size() in br_af_ops.
br_get_link_af_size() becomes unused and thus removed.
Signed-off-by: Ronen Arad <ronen.arad@intel.com>
Acked-by: Sridhar Samudrala <sridhar.samudrala@intel.com>
Configure ageing time to the HW for newly bridged device
CC: Scott Feldman <sfeldma@gmail.com>
CC: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Elad Raz <eladr@mellanox.com>
Acked-by: Scott Feldman <sfeldma@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next
This merge resolves conflicts with 75aec9df3a78 ("bridge: Remove
br_nf_push_frag_xmit_sk") as part of Eric Biederman's effort to improve
netns support in the network stack that reached upstream via David's
net-next tree.
net/bridge/br_netfilter_hooks.c
since commit 8405a8fff3f8 ("netfilter: nf_qeueue: Drop queue entries on
nf_unregister_hook") all pending queued entries are discarded.
So we can simply remove all of the owner handling -- when module is
removed it also needs to unregister all its hooks.
Since spinlock is held here, defer the switchdev operation. Also, ensure
that defered switchdev ops are processed before port master device
is unlinked.
When object is used in deferred work, we cannot use pointers in
switchdev object structures because the memory they point at may be already
used by someone else. So rather do local copy of the value.
Reviewed-by: John Fastabend <john.r.fastabend@intel.com>
Caller should know if he can call attr_set directly (when holding RTNL)
or if he has to defer the att_set processing for later.
This also allows drivers to sleep inside attr_set and report operation
status back to switchdev core. Switchdev core then warns if status is
not ok, instead of silent errors happening in drivers.
Benefit from newly introduced switchdev deferred ops infrastructure.
Ido Schimmel reported a problem with switchdev devices because of the
order change of del_nbp operations, more specifically the move of
nbp_vlan_flush() which deletes all vlans and frees vlgrp after the
rx_handler has been unregistered. So in order to fix this move
vlan_flush back where it was and make it destroy the rhtable after
NULLing vlgrp and waiting a grace period to make sure noone can see it.
Reported-by: Ido Schimmel <idosch@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
As Ido Schimmel pointed out the vlan_vid_del() code in nbp_vlan_flush is
unnecessary (and is actually a remnant of the old vlan code) so we can
remove it.
br_fill_ifinfo is called by br_ifinfo_notify which can be called from
many contexts with different locks held, sometimes it relies upon
bridge's spinlock only which is a problem for the vlan code, so use
explicitly rcu for that to avoid problems.
The bridge and port's vlgrp member is already used in RCU way, currently
we rely on the fact that it cannot disappear while the port exists but
that is error-prone and we might miss places with improper locking
(either RCU or RTNL must be held to walk the vlan_list). So make it
official and use RCU for vlgrp to catch offenders. Introduce proper vlgrp
accessors and use them consistently throughout the code.
switchdev") introduced a timer race condition because the gc_timer can
get rearmed after it's supposedly stopped and flushed in br_dev_delete()
leading to a use of freed memory. So take rtnl to sync with bridge
destruction when setting ageing_timer.
Here's the trace reproduced with these two commands running in parallel:
while :; do echo 10000 > /sys/class/net/br0/bridge/ageing_timer; done;
while :; do brctl addbr br0; ip l set br0 up; ip l set br0 down;
brctl delbr br0; done;
[ 300.000029] BUG: unable to handle kernel paging request at
ffffffff811c59d3
[ 300.000263] IP: [<ffffffff810f168e>] __internal_add_timer+0x2e/0xd0
[ 300.000422] PGD 1a0f067 PUD 1a10063 PMD 10001e1
[ 300.000639] Oops: 0003 [#1] SMP
[ 300.000793] Modules linked in: bridge stp llc nfsd auth_rpcgss
oid_registry nfs_acl nfs lockd grace fscache sunrpc crct10dif_pclmul
crc32_pclmul crc32c_intel ghash_clmulni_intel ppdev aesni_intel
aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
snd_hda_codec_generic qxl drm_kms_helper psmouse pcspkr ttm
snd_hda_intel 9pnet_virtio evdev serio_raw joydev snd_hda_codec 9pnet
virtio_balloon drm snd_hwdep virtio_console snd_hda_core pvpanic snd_pcm
i2c_piix4 snd_timer acpi_cpufreq parport_pc snd parport soundcore button
processor i2c_core ipv6 autofs4 hid_generic usbhid hid ext4 crc16
mbcache jbd2 sg sr_mod cdrom ata_generic virtio_blk virtio_net e1000
ehci_pci uhci_hcd ehci_hcd usbcore usb_common floppy ata_piix libata
virtio_pci virtio_ring virtio scsi_mod
[ 300.004008] CPU: 1 PID: 1169 Comm: bash Not tainted 4.3.0-rc3+ #46
[ 300.004008] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 300.004008] task: ffff880035be2200 ti: ffff88003795c000 task.ti:
ffff88003795c000
[ 300.004008] RIP: 0010:[<ffffffff810f168e>] [<ffffffff810f168e>]
[ 300.004008] RSP: 0018:ffff88003fd03e78 EFLAGS: 00010046
[ 300.004008] RAX: ffff88003fd0ef60 RBX: 840fc78949c08548 RCX:
00000001ffffffff
[ 300.004008] RDX: 0000000000000000 RSI: ffffffff811c59d3 RDI:
ffff88003fd0df00
[ 300.004008] RBP: ffff88003fd03e78 R08: 00000000ffffffff R09:
0000000000000000
[ 300.004008] R10: 0000000000000000 R11: 0000000000000000 R12:
ffff88003fd0df00
[ 300.004008] R13: 0000000000000000 R14: 0000000000000001 R15:
ffffffff816032e0
[ 300.004008] FS: 00007fcbdd609700(0000) GS:ffff88003fd00000(0000)
knlGS:0000000000000000
[ 300.004008] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 300.004008] CR2: ffffffff811c59d3 CR3: 0000000037879000 CR4:
00000000000406e0
[ 300.004008] Stack:
[ 300.004008] ffff88003fd03ea8 ffffffff810f1775 ffff88003c8cb958
ffff88003fd0df00
[ 300.004008] 0000000000000000 0000000000000001 ffff88003fd03f18
ffffffff810f28c4
[ 300.004008] ffff88003fd0eb68 ffff88003fd0e968 ffff88003fd0e768
ffff88003fd0df68
[ 300.004008] Call Trace:
[ 300.004008] <IRQ>
[ 300.004008] [<ffffffff810f1775>] cascade+0x45/0x70
[ 300.004008] [<ffffffff810f28c4>] run_timer_softirq+0x2f4/0x340
[ 300.004008] [<ffffffff8107e380>] __do_softirq+0xd0/0x440
[ 300.004008] [<ffffffff8107e8a3>] irq_exit+0xb3/0xc0
[ 300.004008] [<ffffffff815c2032>] smp_apic_timer_interrupt+0x42/0x50
[ 300.004008] [<ffffffff815bfe37>] apic_timer_interrupt+0x87/0x90
[ 300.004008] <EOI>
[ 300.004008] [<ffffffff811fb80c>] ? create_object+0x13c/0x2e0
[ 300.004008] [<ffffffff8109b23e>] ? __kernel_text_address+0x4e/0x70
[ 300.004008] [<ffffffff8101e17f>] print_context_stack+0x7f/0xf0
[ 300.004008] [<ffffffff8101d55b>] dump_trace+0x11b/0x300
[ 300.004008] [<ffffffff8102970b>] save_stack_trace+0x2b/0x50
[ 300.004008] [<ffffffff811fb80c>] create_object+0x13c/0x2e0
[ 300.004008] [<ffffffff815b2e8e>] kmemleak_alloc+0x4e/0xb0
[ 300.004008] [<ffffffff811e475d>] kmem_cache_alloc_trace+0x18d/0x2f0
[ 300.004008] [<ffffffff8128b139>] kernfs_fop_open+0xc9/0x380
[ 300.004008] [<ffffffff8120214f>] do_dentry_open+0x1ff/0x2f0
[ 300.004008] [<ffffffff8128b070>] ? kernfs_fop_release+0x70/0x70
[ 300.004008] [<ffffffff812034f9>] vfs_open+0x59/0x60
[ 300.004008] [<ffffffff812130de>] path_openat+0x1ce/0x1260
[ 300.004008] [<ffffffff812154ae>] do_filp_open+0x7e/0xe0
[ 300.004008] [<ffffffff812251ff>] ? __alloc_fd+0xaf/0x180
[ 300.004008] [<ffffffff8120387b>] do_sys_open+0x12b/0x210
[ 300.004008] [<ffffffff8120397e>] SyS_open+0x1e/0x20
[ 300.004008] [<ffffffff815bf0b6>] entry_SYSCALL_64_fastpath+0x16/0x7a
[ 300.004008] Code: 66 90 48 8b 46 10 48 8b 4f 40 55 48 89 c2 48 89 e5
48 29 ca 48 81 fa ff 00 00 00 77 20 0f b6 c0 48 8d 44 c7 68 48 8b 10 48
85 d2 <48> 89 16 74 04 48 89 72 08 48 89 30 48 89 46 08 5d c3 48 81 fa
[ 300.004008] RIP [<ffffffff810f168e>] __internal_add_timer+0x2e/0xd0
[ 300.004008] RSP <ffff88003fd03e78>
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Currently it's possible for someone to send a vlan range to the kernel
with the pvid flag set which will result in the pvid bouncing from a
vlan to vlan and isn't correct, it also introduces problems for hardware
where it doesn't make sense having more than 1 pvid. iproute2 already
enforces this, so let's enforce it on kernel-side as well.
Reported-by: Elad Raz <eladr@mellanox.com>
Some drivers need to implement both switchdev vlan ops and
vid_add/kill ndos. For that to work in bridge code, we need to try
switchdev op first when adding/deleting vlan id.
With the ARM mini2440_defconfig, the bridge netfilter code gets
built with both CONFIG_NF_DEFRAG_IPV4 and CONFIG_NF_DEFRAG_IPV6
disabled, which leads to a harmless gcc warning:
net/bridge/br_netfilter_hooks.c: In function 'br_nf_dev_queue_xmit':
net/bridge/br_netfilter_hooks.c:792:2: warning: label 'drop' defined but not used [-Wunused-label]
This gets rid of the warning by cleaning up the code to avoid
the respective #ifdefs causing this problem, and replacing them
with if(IS_ENABLED()) checks. I have verified that the resulting
object code is unchanged, and an additional advantage is that
we now get compile coverage of the unused functions in more
configurations.
Fixes: dd302b59bde0 ("netfilter: bridge: don't leak skb in error paths")
Use SWITCHDEV_F_SKIP_EOPNOTSUPP to skip over ports in bridge that don't
support setting ageing_time (or setting bridge attrs in general).
If push fails, don't update ageing_time in bridge and return err to user.
If push succeeds, update ageing_time in bridge and run gc_timer now to
recalabrate when to run gc_timer next, based on new ageing_time.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
This patch enables adding of fdb entries pointing to the bridge device.
This can be used to propagate mac address of vlan interfaces
configured on top of the vlan filtering bridge.
Before:
$bridge fdb add 44:38:39:00:27:9f dev bridge
RTNETLINK answers: Invalid argument
After:
Add IFLA_BRPORT_MULTICAST_ROUTER to allow setting/getting port's
multicast_router via netlink.
Add IFLA_BRPORT_FLUSH to allow flushing port's fdb similar to sysfs's
flush.
Add the following attributes in order to export port's timer values:
IFLA_BRPORT_MESSAGE_AGE_TIMER, IFLA_BRPORT_FORWARD_DELAY_TIMER and
IFLA_BRPORT_HOLD_TIMER.
Add IFLA_BRPORT_TOPOLOGY_CHANGE_ACK and IFLA_BRPORT_CONFIG_PENDING to
allow getting port's topology_change_ack and config_pending respectively
via netlink.
Add IFLA_BRPORT_(ID|NO) to allow getting port's port_id and port_no
respectively via netlink.
Add IFLA_BRPORT_DESIGNATED_(COST|PORT) to allow getting the port's
designated cost and port respectively via netlink.
Add IFLA_BRPORT_BRIDGE_ID to allow getting the designated bridge id via
netlink.
Add IFLA_BRPORT_ROOT_ID to allow getting the designated root id via
netlink.
When KASAN is enabled the frame size grows > 2048 bytes and we get a
warning, so make it smaller.
net/bridge/br_netlink.c: In function 'br_fill_info':
>> net/bridge/br_netlink.c:1110:1: warning: the frame size of 2160 bytes
>> is larger than 2048 bytes [-Wframe-larger-than=]
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/net-next
Eric W. Biederman says:
net: Pass net through ip fragmention
This is the next installment of my work to pass struct net through the
output path so the code does not need to guess how to figure out which
network namespace it is in, and ultimately routes can have output
devices in another network namespace.
This round focuses on passing net through ip fragmentation which we seem
to call from about everywhere. That is the main ip output paths, the
bridge netfilter code, and openvswitch. This has to happend at once
accross the tree as function pointers are involved.
First some prep work is done, then ipv4 and ipv6 are converted and then
temporary helper functions are removed.
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Add IFLA_BR_VLAN_DEFAULT_PVID to allow setting/getting bridge's
default_pvid via netlink.
Add support to allow getting/setting netfilter tables settings.
Currently these are IFLA_BR_NF_CALL_IPTABLES, IFLA_BR_NF_CALL_IP6TABLES
and IFLA_BR_NF_CALL_ARPTABLES.
Add support to set/get all of the igmp's configurable intervals via
netlink. These currently are:
IFLA_BR_MCAST_LAST_MEMBER_INTVL
IFLA_BR_MCAST_MEMBERSHIP_INTVL
IFLA_BR_MCAST_QUERIER_INTVL
IFLA_BR_MCAST_QUERY_INTVL
IFLA_BR_MCAST_QUERY_RESPONSE_INTVL
IFLA_BR_MCAST_STARTUP_QUERY_INTVL
Add IFLA_BR_MCAST_STARTUP_QUERY_CNT to allow setting/getting
br->multicast_startup_query_count via netlink. Also align the ifla
comments.
Add IFLA_BR_MCAST_LAST_MEMBER_CNT to allow setting/getting
br->multicast_last_member_count via netlink.
Add IFLA_BR_MCAST_HASH_MAX to allow setting/getting br->hash_max via
netlink.
Add IFLA_BR_MCAST_HASH_ELASTICITY to allow setting/getting
br->hash_elasticity via netlink.
