path: root/net/bridge
2008-11-28Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6 Conflicts: net/netfilter/nf_conntrack_netlink.c
2008-11-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/hp-plus.c drivers/net/wireless/ath5k/base.c drivers/net/wireless/ath9k/recv.c net/wireless/reg.c
2008-11-24bridge: netfilter: fix update_pmtu crash with GREHerbert Xu
As GRE tries to call the update_pmtu function on skb->dst and bridge supplies an skb->dst that has a NULL ops field, all is not well. This patch fixes this by giving the bridge device an ops field with an update_pmtu function. For the moment I've left all other fields blank but we can fill them in later should the need arise. Based on report and patch by Philip Craig. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19bridge: convert to net_device_opsStephen Hemminger
Convert to net_device_ops function table. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-4Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-04netfilter: netns ebtables: br_nf_pre_routing_finish() fixupAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-04netfilter: netns ebtables: ebtable_nat in netnsAlexey Dobriyan
2008-11-04netfilter: netns ebtables: ebtable_filter in netnsAlexey Dobriyan
2008-11-04netfilter: netns ebtables: ebtable_broute in netnsAlexey Dobriyan
2008-11-04netfilter: netns ebtables: more cleanup during ebt_unregister_table()Alexey Dobriyan
Now that ebt_unregister_table() can be called during netns stop, and module pinning scheme can't prevent netns stop, do table cleanup by hand. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-04netfilter: netns ebtables: part 2Alexey Dobriyan
* return ebt_table from ebt_register_table(), module code will save it into per-netns data for unregistration * duplicate ebt_table at the very beginning of registration -- it's added into list, so one ebt_table wouldn't end up in many lists (and each netns has different one) * introduce underscored tables in individial modules, this is temporary to not break bisection. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-04netfilter: netns ebtables: part 1Alexey Dobriyan
* propagate netns from userspace, register table in passed netns * remporarily register every ebt_table in init_net P. S.: one needs to add ".netns_ok = 1" to igmp_protocol to test with ebtables(8) in netns. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
2008-10-28net: remove NIP6(), NIP6_FMT, NIP6_SEQFMT and final usersHarvey Harrison
Open code NIP6_FMT in the one call inside sscanf and one user of NIP6() that could use %p6 in the netfilter code. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-23net: Fix disjunct computation of netdev featuresHerbert Xu
My change commit e2a6b85247aacc52d6ba0d9b37a99b8d1a3e0d83 net: Enable TSO if supported by at least one device didn't do what was intended because the netdev_compute_features function was designed for conjunctions. So what happened was that it would simply take the TSO status of the last constituent device. This patch extends it to support both conjunctions and disjunctions under the new name of netdev_increment_features. It also adds a new function netdev_fix_features which does the sanity checking that usually occurs upon registration. This ensures that the computation doesn't result in an illegal combination since this checking is absent when the change is initiated via ethtool. The two users of netdev_compute_features have been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-20netfilter: replace old NF_ARP calls with NFPROTO_ARPJan Engelhardt
(Supplements: ee999d8b9573df1b547aacdc6d79f86eb79c25cd) NFPROTO_ARP actually has a different value from NF_ARP, so ensure all callers use the new value so that packets _do_ get delivered to the registered hooks. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)Johannes Berg
Some code here depends on CONFIG_KMOD to not try to load protocol modules or similar, replace by CONFIG_MODULES where more than just request_module depends on CONFIG_KMOD and and also use try_then_request_module in ebtables. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-14netfilter: fix ebtables dependenciesPatrick McHardy
Ingo Molnar reported a build error with ebtables: ERROR: "ebt_register_table" [net/bridge/netfilter/ebtable_filter.ko] undefined! ERROR: "ebt_do_table" [net/bridge/netfilter/ebtable_filter.ko] undefined! ERROR: "ebt_unregister_table" [net/bridge/netfilter/ebtable_filter.ko] undefined! ERROR: "ebt_register_table" [net/bridge/netfilter/ebtable_broute.ko] undefined! ERROR: "ebt_do_table" [net/bridge/netfilter/ebtable_broute.ko] undefined! ERROR: "ebt_unregister_table" [net/bridge/netfilter/ebtable_broute.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 This reason is a missing dependencies that got lost during Kconfig cleanups. Restore it. Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08netfilter: xtables: provide invoked family value to extensionsJan Engelhardt
By passing in the family through which extensions were invoked, a bit of data space can be reclaimed. The "family" member will be added to the parameter structures and the check functions be adjusted. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (6/6)Jan Engelhardt
This patch does this for target extensions' destroy functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (5/6)Jan Engelhardt
This patch does this for target extensions' checkentry functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (4/6)Jan Engelhardt
This patch does this for target extensions' target functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (3/6)Jan Engelhardt
This patch does this for match extensions' destroy functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (2/6)Jan Engelhardt
This patch does this for match extensions' checkentry functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (1/6)Jan Engelhardt
The function signatures for Xtables extensions have grown over time. It involves a lot of typing/replication, and also a bit of stack space even if they are not used. Realize an NFWS2008 idea and pack them into structs. The skb remains outside of the struct so gcc can continue to apply its optimizations. This patch does this for match extensions' match functions. A few ambiguities have also been addressed. The "offset" parameter for example has been renamed to "fragoff" (there are so many different offsets already) and "protoff" to "thoff" (there is more than just one protocol here, so clarify). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: ebtables: make BRIDGE_NF_EBTABLES a menuconfig optionJan Engelhardt
2008-10-08netfilter: xtables: do centralized checkentry call (1/2)Jan Engelhardt
It used to be that {ip,ip6,etc}_tables called extension->checkentry themselves, but this can be moved into the xtables core. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: ebtables: fix one wrong return valueJan Engelhardt
Usually -EINVAL is used when checkentry fails (see *_tables). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: remove redundant casts from EbtablesJan Engelhardt
2008-10-08netfilter: remove unused Ebtables functionsJan Engelhardt
2008-10-08netfilter: implement hotdrop for EbtablesJan Engelhardt
2008-10-08netfilter: ebtables: use generic table checkingJan Engelhardt
Ebtables ORs (1 << NF_BR_NUMHOOKS) into the hook mask to indicate that the extension was called from a base chain. So this also needs to be present in the extensions' ->hooks. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: move Ebtables to use XtablesJan Engelhardt
2008-10-08netfilter: change Ebtables function signatures to match Xtables'sJan Engelhardt
2008-10-08netfilter: ebt_among: obtain match size through different meansJan Engelhardt
The function signatures will be changed to match those of Xtables, and the datalen argument will be gone. ebt_among unfortunately relies on it, so we need to obtain it somehow. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: add dummy members to Ebtables code to ease transition to XtablesJan Engelhardt
2008-10-08netfilter: Change return types of targets/watchers for Ebtables extensionsJan Engelhardt
2008-10-08netfilter: change return types of match functions for ebtables extensionsJan Engelhardt
2008-10-08netfilter: change return types of check functions for Ebtables extensionsJan Engelhardt
2008-10-08netfilter: ebtables: do centralized size checkingJan Engelhardt
2008-10-08netfilter: x_tables: use NFPROTO_* in extensionsJan Engelhardt
2008-10-08netfilter: Use unsigned types for hooknum and pf varsJan Engelhardt
and (try to) consistently use u_int8_t for the L3 family. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-09-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: net/mac80211/mlme.c
2008-09-08netns bridge: cleanup bridges during netns stopAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Stephen Hemminger <shemming@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08netns bridge: allow bridges in netns!Alexey Dobriyan
Bridge as netdevice doesn't cross netns boundaries. Bridge ports and bridge itself live in same netns. Notifiers are fixed. netns propagated from userspace socket for setup and teardown. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Stephen Hemminger <shemming@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-08bridge: don't allow setting hello time to zeroStephen Hemminger
Dushan Tcholich reports that on his system ksoftirqd can consume between %6 to %10 of cpu time, and cause ~200 context switches per second. He then correlated this with a report by bdupree@techfinesse.com: http://marc.info/?l=linux-kernel&m=119613299024398&w=2 and the culprit cause seems to be starting the bridge interface. In particular, when starting the bridge interface, his scripts are specifying a hello timer interval of "0". The bridge hello time can't be safely set to values less than 1 second, otherwise it is possible to end up with a runaway timer. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-15bridge: show offload settingsStephen Hemminger
Add more ethtool generic operations to dump the bridge offload settings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
