[ Upstream commit 0b67c43ce36a9964f1d5e3f973ee19eefd3f9f8f ]
We also need to save/store in forward, else br_parse_ip_options call
will zero frag_max_size as well.
Fixes: 93fdd47e5 ('bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING')
[ Upstream commit 62749e2cb3c4a7da3eaa5c01a7e787aebeff8536 ]
Name fits better. Plus there's going to be introduced
__vlan_insert_tag later on.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
Fixes: c2d3babf ("bridge: implement multicast fast leave")
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Ebtables on the OUTPUT chain (NF_BR_LOCAL_OUT) would not work as expected
for both locally generated IGMP and MLD queries. The IP header specific
filter options are off by 14 Bytes for netfilter (actual output on
interfaces is fine).
NF_HOOK() expects the skb->data to point to the IP header, not the
ethernet one (while dev_queue_xmit() does not). Luckily there is an
br_dev_queue_push_xmit() helper function already - let's just use that.
Introduced by eb1d16414339a6e113d89e2cca2556005d7ce919
("bridge: Add core IGMP snooping support")
Ebtables example:
$ ebtables -I OUTPUT -p IPv6 -o eth1 --logical-out br0 \
--log --log-level 6 --log-ip6 --log-prefix="~EBT: " -j DROP
before (broken):
~EBT: IN= OUT=eth1 MAC source = 02:04:64:a4:39:c2 \
MAC dest = 33:33:00:00:00:01 proto = 0x86dd IPv6 \
SRC=64a4:39c2:86dd:6000:0000:0020:0001:fe80 IPv6 \
DST=0000:0000:0000:0004:64ff:fea4:39c2:ff02, \
IPv6 priority=0x3, Next Header=2
after (working):
SRC=fe80:0000:0000:0000:0004:64ff:fea4:39c2 IPv6 \
DST=ff02:0000:0000:0000:0000:0000:0000:0001, \
IPv6 priority=0x0, Next Header=0
Signed-off-by: Linus Lüssing <linus.luessing@web.de>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Fix:
net/bridge/netfilter/nft_reject_bridge.c:
In function 'nft_reject_br_send_v6_unreach':
net/bridge/netfilter/nft_reject_bridge.c:240:3:
error: implicit declaration of function 'csum_ipv6_magic'
csum_ipv6_magic(&nip6h->saddr, &nip6h->daddr,
make[3]: *** [net/bridge/netfilter/nft_reject_bridge.o] Error 1
Seen with powerpc:allmodconfig.
Fixes: 523b929d5446 ("netfilter: nft_reject_bridge: don't use IP stack to reject traffic")
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Restrict the reject expression to the prerouting and input bridge
hooks. If we allow this to be used from forward or any other later
bridge hook, if the frame is flooded to several ports, we'll end up
sending several reject packets, one per cloned packet.
If the packet is received via the bridge stack, this cannot reject
packets from the IP stack.
This adds functions to build the reject packet and send it from the
bridge stack. Comments and assumptions on this patch:
1) Validate the IPv4 and IPv6 headers before further processing,
given that the packet comes from the bridge stack, we cannot assume
they are clean. Truncated packets are dropped, we follow similar
approach in the existing iptables match/target extensions that need
to inspect layer 4 headers that is not available. This also includes
packets that are directed to multicast and broadcast ethernet
addresses.
2) br_deliver() is exported to inject the reject packet via
bridge localout -> postrouting. So the approach is similar to what
we already do in the iptables reject target. The reject packet is
sent to the bridge port from which we have received the original
packet.
3) The reject packet is forged based on the original packet. The TTL
is set based on sysctl_ip_default_ttl for IPv4 and per-net
ipv6.devconf_all hoplimit for IPv6.
Fixes: 36d2af5 ("netfilter: nf_tables: allow to filter from prerouting and postrouting")
Commit 462fb2af9788a82a534f8184abfde31574e1cfa0
bridge : Sanitize skb before it enters the IP stack
broke when IP options are actually used because it mangles the
skb as if it entered the IP stack which is wrong because the
bridge is supposed to operate below the IP stack.
Since nobody has actually requested for parsing of IP options
this patch fixes it by simply reverting to the previous approach
of ignoring all IP options, i.e., zeroing the IPCB.
If and when somebody who uses IP options and actually needs them
to be parsed by the bridge complains then we can revisit this.
Reported-by: David Newall <davidn@davidnewall.com>
Tested-by: Florian Westphal <fw@strlen.de>
As we may defragment the packet in IPv4 PRE_ROUTING and refragment
it after POST_ROUTING we should save the value of frag_max_size.
This is still very wrong as the bridge is supposed to leave the
packets intact, meaning that the right thing to do is to use the
original frag_list for fragmentation.
Unfortunately we don't currently guarantee that the frag_list is
left untouched throughout netfilter so until this changes this is
the best we can do.
There is also a spot in FORWARD where it appears that we can
forward a packet without going through fragmentation, mark it
so that we can fix it later.
Pablo Neira Ayuso says:
Netfilter/IPVS updates for net-next
The following patchset contains another batch with Netfilter/IPVS updates
for net-next, they are:
1) Add abstracted ICMP codes to the nf_tables reject expression. We
introduce four reasons to reject using ICMP that overlap in IPv4
and IPv6 from the semantic point of view. This should simplify the
maintainance of dual stack rule-sets through the inet table.
2) Move nf_send_reset() functions from header files to per-family
nf_reject modules, suggested by Patrick McHardy.
3) We have to use IS_ENABLED(CONFIG_BRIDGE_NETFILTER) everywhere in the
code now that br_netfilter can be modularized. Convert remaining spots
in the network stack code.
4) Use rcu_barrier() in the nf_tables module removal path to ensure that
we don't leave object that are still pending to be released via
call_rcu (that may likely result in a crash).
5) Remove incomplete arch 32/64 compat from nft_compat. The original (bad)
idea was to probe the word size based on the xtables match/target info
size, but this assumption is wrong when you have to dump the information
back to userspace.
6) Allow to filter from prerouting and postrouting in the nf_tables bridge.
In order to emulate the ebtables NAT chains (which are actually simple
filter chains with no special semantics), we have support filtering from
this hooks too.
7) Add explicit module dependency between xt_physdev and br_netfilter.
This provides a way to detect if the user needs br_netfilter from
the configuration path. This should reduce the breakage of the
br_netfilter modularization.
8) Cleanup coding style in ip_vs.h, from Simon Horman.
9) Fix crash in the recently added nf_tables masq expression. We have
to register/unregister the notifiers to clean up the conntrack table
entries from the module init/exit path, not from the rule addition /
deletion path. From Arturo Borrero.
Currently when vlan filtering is turned on on the bridge, the bridge
will drop all traffic untill the user configures the filter. This
isn't very nice for ports that don't care about vlans and just
want untagged traffic.
A concept of a default_pvid was recently introduced. This patch
adds filtering support for default_pvid. Now, ports that don't
care about vlans and don't define there own filter will belong
to the VLAN of the default_pvid and continue to receive untagged
traffic.
This filtering can be disabled by setting default_pvid to 0.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Currently, if the pvid is not set, we return an illegal vlan value
even though the pvid value is set to 0. Since pvid of 0 is currently
invalid, just return 0 instead. This makes the current and future
checks simpler.
This patch allows the user to set and retrieve default_pvid
value. A new value can only be stored when vlan filtering
is disabled.
You can use physdev to match the physical interface enslaved to the
bridge device. This information is stored in skb->nf_bridge and it is
set up by br_netfilter. So, this is only available when iptables is
used from the bridge netfilter path.
Since 34666d4 ("netfilter: bridge: move br_netfilter out of the core"),
the br_netfilter code is modular. To reduce the impact of this change,
we can autoload the br_netfilter if the physdev match is used since
we assume that the users need br_netfilter in place.
This allows us to emulate the NAT table in ebtables, which is actually
a plain filter chain that hooks at prerouting, output and postrouting.
This patch introduces the NFT_REJECT_ICMPX_UNREACH type which provides
an abstraction to the ICMP and ICMPv6 codes that you can use from the
inet and bridge tables, they are:
* NFT_REJECT_ICMPX_NO_ROUTE: no route to host - network unreachable
* NFT_REJECT_ICMPX_PORT_UNREACH: port unreachable
* NFT_REJECT_ICMPX_HOST_UNREACH: host unreachable
* NFT_REJECT_ICMPX_ADMIN_PROHIBITED: administratevely prohibited
You can still use the specific codes when restricting the rule to match
the corresponding layer 3 protocol.
I decided to not overload the existing NFT_REJECT_ICMP_UNREACH to have
different semantics depending on the table family and to allow the user
to specify ICMP family specific codes if they restrict it to the
corresponding family.
In preparation for being able to propagate port states to e.g: notifiers
or other kernel parts, do not manipulate the port state directly, but
instead use a helper function which will allow us to do a bit more than
just setting the state.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Eric reports build failure with
CONFIG_BRIDGE_NETFILTER=n
We insist to build br_nf_core.o unconditionally, but we must only do so
if br_netfilter was enabled, else it fails to build due to
functions being defined to empty stubs (and some structure members
being defined out).
Also, BRIDGE_NETFILTER=y|m makes no sense when BRIDGE=n.
Fixes: 34666d467 (netfilter: bridge: move br_netfilter out of the core)
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
pull request: netfilter/ipvs updates for net-next
The following patchset contains Netfilter/IPVS updates for net-next,
most relevantly they are:
1) Four patches to make the new nf_tables masquerading support
independent of the x_tables infrastructure. This also resolves a
compilation breakage if the masquerade target is disabled but the
nf_tables masq expression is enabled.
2) ipset updates via Jozsef Kadlecsik. This includes the addition of the
skbinfo extension that allows you to store packet metainformation in the
elements. This can be used to fetch and restore this to the packets through
the iptables SET target, patches from Anton Danilov.
3) Add the hash:mac set type to ipset, from Jozsef Kadlecsick.
4) Add simple weighted fail-over scheduler via Simon Horman. This provides
a fail-over IPVS scheduler (unlike existing load balancing schedulers).
Connections are directed to the appropriate server based solely on
highest weight value and server availability, patch from Kenny Mathis.
5) Support IPv6 real servers in IPv4 virtual-services and vice versa.
Simon Horman informs that the motivation for this is to allow more
flexibility in the choice of IP version offered by both virtual-servers
and real-servers as they no longer need to match: An IPv4 connection
from an end-user may be forwarded to a real-server using IPv6 and
vice versa. No ip_vs_sync support yet though. Patches from Alex Gartrell
and Julian Anastasov.
6) Add global generation ID to the nf_tables ruleset. When dumping from
several different object lists, we need a way to identify that an update
has ocurred so userspace knows that it needs to refresh its lists. This
also includes a new command to obtain the 32-bits generation ID. The
less significant 16-bits of this ID is also exposed through res_id field
in the nfnetlink header to quickly detect the interference and retry when
there is no risk of ID wraparound.
7) Move br_netfilter out of the bridge core. The br_netfilter code is
built in the bridge core by default. This causes problems of different
kind to people that don't want this: Jesper reported performance drop due
to the inconditional hook registration and I remember to have read complains
on netdev from people regarding the unexpected behaviour of our bridging
stack when br_netfilter is enabled (fragmentation handling, layer 3 and
upper inspection). People that still need this should easily undo the
damage by modprobing the new br_netfilter module.
8) Dump the set policy nf_tables that allows set parameterization. So
userspace can keep user-defined preferences when saving the ruleset.
9) Use __seq_open_private() helper function to reduce boiler plate code
in x_tables, From Rob Jones.
10) Safer default behaviour in case that you forget to load the protocol
tracker. Daniel Borkmann and Florian Westphal detected that if your
ruleset is stateful, you allow traffic to at least one single SCTP port
and the SCTP protocol tracker is not loaded, then any SCTP traffic may
be pass through unfiltered. After this patch, the connection tracking
classifies SCTP/DCCP/UDPlite/GRE packets as invalid if your kernel has
been compiled with support for these modules.
Trivially resolved conflict in include/linux/skbuff.h, Eric moved some
netfilter skbuff members around, and the netfilter tree adjusted the
ifdef guards for the bridging info pointer.
Jesper reported that br_netfilter always registers the hooks since
this is part of the bridge core. This harms performance for people that
don't need this.
This patch modularizes br_netfilter so it can be rmmod'ed, thus,
the hooks can be unregistered. I think the bridge netfilter should have
been a separated module since the beginning, Patrick agreed on that.
Note that this is breaking compatibility for users that expect that
bridge netfilter is going to be available after explicitly 'modprobe
bridge' or via automatic load through brctl.
However, the damage can be easily undone by modprobing br_netfilter.
The bridge core also spots a message to provide a clue to people that
didn't notice that this has been deprecated.
On top of that, the plan is that nftables will not rely on this software
layer, but integrate the connection tracking into the bridge layer to
enable stateful filtering and NAT, which is was bridge netfilter users
seem to require.
This patch still keeps the fake_dst_ops in the bridge core, since this
is required by when the bridge port is initialized. So we can safely
modprobe/rmmod br_netfilter anytime.
Acked-by: Florian Westphal <fw@strlen.de>
Move nf_bridge_copy_header() as static inline in netfilter_bridge.h
header file. This patch prepares the modularization of the br_netfilter
code.
arch/mips/net/bpf_jit.c
drivers/net/can/flexcan.c
Both the flexcan and MIPS bpf_jit conflicts were cases of simple
overlapping changes.
As Toshiaki Makita pointed out, the BRIDGE_INPUT_SKB_CB will
not be initialized in br_should_learn() as that function
is called only from br_handle_local_finish(). That is
an input handler for link-local ethernet traffic so it perfectly
correct to check br->vlan_enabled here.
Reported-by: Toshiaki Makita<toshiaki.makita1@gmail.com>
Fixes: 20adfa1 bridge: Check if vlan filtering is enabled only once.
Currently, it is possible to modify the vlan filter
configuration to add pvid or untagged support.
For example:
bridge vlan add vid 10 dev eth0
bridge vlan add vid 10 dev eth0 untagged pvid
The second statement will modify vlan 10 to
include untagged and pvid configuration.
However, it is currently impossible to go backwards
Here nothing happens. This patch correct this so
that any modifiers not supplied are removed from
the configuration.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
The bridge code checks if vlan filtering is enabled on both
ingress and egress. When the state flip happens, it
is possible for the bridge to currently be forwarding packets
and forwarding behavior becomes non-deterministic. Bridge
may drop packets on some interfaces, but not others.
This patch solves this by caching the filtered state of the
packet into skb_cb on ingress. The skb_cb is guaranteed to
not be over-written between the time packet entres bridge
forwarding path and the time it leaves it. On egress, we
can then check the cached state to see if we need to
apply filtering information.
nf-next pull request
The following patchset contains Netfilter/IPVS updates for your
net-next tree. Regarding nf_tables, most updates focus on consolidating
the NAT infrastructure and adding support for masquerading. More
specifically, they are:
1) use __u8 instead of u_int8_t in arptables header, from
Mike Frysinger.
2) Add support to match by skb->pkttype to the meta expression, from
Ana Rey.
3) Add support to match by cpu to the meta expression, also from
Ana Rey.
4) A smatch warning about IPSET_ATTR_MARKMASK validation, patch from
Vytas Dauksa.
5) Fix netnet and netportnet hash types the range support for IPv4,
from Sergey Popovich.
6) Fix missing-field-initializer warnings resolved, from Mark Rustad.
7) Dan Carperter reported possible integer overflows in ipset, from
Jozsef Kadlecsick.
8) Filter out accounting objects in nfacct by type, so you can
selectively reset quotas, from Alexey Perevalov.
9) Move specific NAT IPv4 functions to the core so x_tables and
nf_tables can share the same NAT IPv4 engine.
10) Use the new NAT IPv4 functions from nft_chain_nat_ipv4.
11) Move specific NAT IPv6 functions to the core so x_tables and
12) Use the new NAT IPv6 functions from nft_chain_nat_ipv6.
13) Refactor code to add nft_delrule(), which can be reused in the
enhancement of the NFT_MSG_DELTABLE to remove a table and its
content, from Arturo Borrero.
14) Add a helper function to unregister chain hooks, from
Arturo Borrero.
15) A cleanup to rename to nft_delrule_by_chain for consistency with
the new nft_*() functions, also from Arturo.
16) Add support to match devgroup to the meta expression, from Ana Rey.
17) Reduce stack usage for IPVS socket option, from Julian Anastasov.
18) Remove unnecessary textsearch state initialization in xt_string,
from Bojan Prtvar.
19) Add several helper functions to nf_tables, more work to prepare
the enhancement of NFT_MSG_DELTABLE, again from Arturo Borrero.
20) Enhance NFT_MSG_DELTABLE to delete a table and its content, from
Arturo Borrero.
21) Support NAT flags in the nat expression to indicate the flavour,
eg. random fully, from Arturo.
22) Add missing audit code to ebtables when replacing tables, from
Nicolas Dichtel.
23) Generalize the IPv4 masquerading code to allow its re-use from
nf_tables, from Arturo.
24) Generalize the IPv6 masquerading code, also from Arturo.
25) Add the new masq expression to support IPv4/IPv6 masquerading
from nf_tables, also from Arturo.
This patch removes an unncessary check in the br_afspec() method of
br_netlink.c.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
Allow rtnetlink users to set bridge master info via IFLA_INFO_DATA attr
This initial part implements forward_delay, hello_time, max_age options.
Allow rtnetlink users to get bridge master info in IFLA_INFO_DATA attr
Allow rtnetlink users to set port info via IFLA_INFO_SLAVE_DATA attr
rtnl_link_ops->fill_slave_info
Allow rtnetlink users to get port info in IFLA_INFO_SLAVE_DATA attr
The thing is that netdev_master_upper_dev_link calls
call_netdevice_notifiers(NETDEV_CHANGEUPPER, dev). That generates rtnl
link message and during that, rtnl_link_ops->fill_slave_info is called.
But with current ordering, rx_handler and IFF_BRIDGE_PORT are not set
yet so there would have to be check for that in fill_slave_info callback.
Resolve this by reordering to similar what bonding and team does to
avoid the check.
Also add removal of IFF_BRIDGE_PORT flag into error path.
This is already done for x_tables (family AF_INET and AF_INET6), let's
do it for AF_BRIDGE also.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
The use of "rcu_assign_pointer()" is NULLing out the pointer.
According to RCU_INIT_POINTER()'s block comment:
"1. This use of RCU_INIT_POINTER() is NULLing out the pointer"
it is better to use it instead of rcu_assign_pointer() because it has a
smaller overhead.
The following Coccinelle semantic patch was used:
- rcu_assign_pointer
+ RCU_INIT_POINTER
(..., NULL)
Signed-off-by: Andreea-Cristina Bernat <bernat.ada@gmail.com>
Currently the functionality to untag traffic on input resides
as part of the vlan module and is build only when VLAN support
is enabled in the kernel. When VLAN is disabled, the function
vlan_untag() turns into a stub and doesn't really untag the
packets. This seems to create an interesting interaction
between VMs supporting checksum offloading and some network drivers.
There are some drivers that do not allow the user to change
tx-vlan-offload feature of the driver. These drivers also seem
to assume that any VLAN-tagged traffic they transmit will
have the vlan information in the vlan_tci and not in the vlan
header already in the skb. When transmitting skbs that already
have tagged data with partial checksum set, the checksum doesn't
appear to be updated correctly by the card thus resulting in a
failure to establish TCP connections.
The following is a packet trace taken on the receiver where a
sender is a VM with a VLAN configued. The host VM is running on
doest not have VLAN support and the outging interface on the
host is tg3:
10:12:43.503055 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27243,
offset 0, flags [DF], proto TCP (6), length 60)
10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect
-> 0x48d9), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294837885 ecr 0,nop,wscale 7], length 0
10:12:44.505556 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27244,
-> 0x44ee), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294838888 ecr 0,nop,wscale 7], length 0
This connection finally times out.
I've only access to the TG3 hardware in this configuration thus have
only tested this with TG3 driver. There are a lot of other drivers
that do not permit user changes to vlan acceleration features, and
I don't know if they all suffere from a similar issue.
The patch attempt to fix this another way. It moves the vlan header
stipping code out of the vlan module and always builds it into the
kernel network core. This way, even if vlan is not supported on
a virtualizatoin host, the virtual machines running on top of such
host will still work with VLANs enabled.
CC: Patrick McHardy <kaber@trash.net>
CC: Nithin Nayak Sujir <nsujir@broadcom.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Jiri Pirko <jiri@resnulli.us>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Eric Dumazet reports that getsockopt() or setsockopt() sometimes
returns -EINTR instead of -ENOPROTOOPT, causing headaches to
application developers.
This patch replaces all the mutex_lock_interruptible() by mutex_lock()
in the netfilter tree, as there is no reason we should sleep for a
long time there.
Reported-by: Eric Dumazet <edumazet@google.com>
Suggested-by: Patrick McHardy <kaber@trash.net>
Acked-by: Julian Anastasov <ja@ssi.bg>
All other add functions for lists have the new item as first argument
and the position where it is added as second argument. This was changed
for no good reason in this function and makes using it unnecessary
confusing.
The name was changed to hlist_add_behind() to cause unconverted code to
generate a compile error instead of using the wrong parameter order.
Signed-off-by: Ken Helias <kenhelias@firemail.de>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> [intel driver bits]
drivers/net/Makefile
net/ipv6/sysctl_net_ipv6.c
Two ipv6_table_template[] additions overlap, so the index
of the ipv6_table[x] assignments needed to be adjusted.
In the drivers/net/Makefile case, we've gotten rid of the
garbage whereby we had to list every single USB networking
driver in the top-level Makefile, there is just one
"USB_NETWORKING" that guards everything.
Now bridge ports can be non-promiscuous, vlan_vid_add() is no longer an
unnecessary operation.
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
commit 6cbdceeb1cb12c7d620161925a8c3e81daadb2e4
bridge: Dump vlan information from a bridge port
introduced a comment in an attempt to explain the
code logic. The comment is unfinished so it confuses more
than it explains, remove it.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
An FDB entry with vlan_id 0 doesn't mean it is used in vlan 0, but used when
vlan_filtering is disabled.
There is inconsistency around NDA_VLAN whose payload is 0 - even if we add
an entry by RTM_NEWNEIGH without any NDA_VLAN, and even though adding an
entry with NDA_VLAN 0 is prohibited, we get an entry with NDA_VLAN 0 by
RTM_GETNEIGH.
Dumping an FDB entry with vlan_id 0 shouldn't include NDA_VLAN.
The ulog targets were recently killed. A few references to the Kconfig
macros CONFIG_IP_NF_TARGET_ULOG and CONFIG_BRIDGE_EBT_ULOG were left
untouched. Kill these too.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
So you can reject IPv4 and IPv6 packets from bridge tables. If the ether
proto is now known, default on dropping the packet instead.
Netfilter updates for net-next
The following patchset contains updates for your net-next tree,
they are:
1) Use kvfree() helper function from x_tables, from Eric Dumazet.
2) Remove extra timer from the conntrack ecache extension, use a
workqueue instead to redeliver lost events to userspace instead,
from Florian Westphal.
3) Removal of the ulog targets for ebtables and iptables. The nflog
infrastructure superseded this almost 9 years ago, time to get rid
of this code.
4) Replace the list of loggers by an array now that we can only have
two possible non-overlapping logger flavours, ie. kernel ring buffer
and netlink logging.
5) Move Eric Dumazet's log buffer code to nf_log to reuse it from
all of the supported per-family loggers.
6) Consolidate nf_log_packet() as an unified interface for packet logging.
After this patch, if the struct nf_loginfo is available, it explicitly
selects the logger that is used.
7) Move ip and ip6 logging code from xt_LOG to the corresponding
per-family loggers. Thus, x_tables and nf_tables share the same code
for packet logging.
8) Add generic ARP packet logger, which is used by nf_tables. The
format aims to be consistent with the output of xt_LOG.
9) Add generic bridge packet logger. Again, this is used by nf_tables
and it routes the packets to the real family loggers. As a result,
we get consistent logging format for the bridge family. The ebt_log
logging code has been intentionally left in place not to break
backward compatibility since the logging output differs from xt_LOG.
10) Update nft_log to explicitly request the required family logger when
needed.
11) Finish nft_log so it supports arp, ip, ip6, bridge and inet families.
Allowing selection between netlink and kernel buffer ring logging.
12) Several fixes coming after the netfilter core logging changes spotted
by robots.
13) Use IS_ENABLED() macros whenever possible in the netfilter tree,
from Duan Jiong.
14) Removal of a couple of unnecessary branch before kfree, from Fabian
Frederick.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Actually better than brctl showmacs because we can filter by bridge
port in the kernel.
The current bridge netlink interface doesnt scale when you have many
bridges each with large fdbs or even bridges with many bridge ports
And now for the science non-fiction novel you have all been
waiting for..
//lets see what bridge ports we have
root@moja-1:/configs/may30-iprt/bridge# ./bridge link show
8: eth1 state DOWN : <BROADCAST,MULTICAST> mtu 1500 master br0 state
disabled priority 32 cost 19
17: sw1-p1 state DOWN : <BROADCAST,NOARP> mtu 1500 master br0 state
disabled priority 32 cost 100
// show all..
root@moja-1:/configs/may30-iprt/bridge# ./bridge fdb show
33:33:00:00:00:01 dev bond0 self permanent
33:33:00:00:00:01 dev dummy0 self permanent
33:33:00:00:00:01 dev ifb0 self permanent
33:33:00:00:00:01 dev ifb1 self permanent
33:33:00:00:00:01 dev eth0 self permanent
01:00:5e:00:00:01 dev eth0 self permanent
33:33:ff:22:01:01 dev eth0 self permanent
02:00:00:12:01:02 dev eth1 vlan 0 master br0 permanent
00:17:42:8a:b4:05 dev eth1 vlan 0 master br0 permanent
00:17:42:8a:b4:07 dev eth1 self permanent
33:33:00:00:00:01 dev eth1 self permanent
33:33:00:00:00:01 dev gretap0 self permanent
da:ac:46:27:d9:53 dev sw1-p1 vlan 0 master br0 permanent
33:33:00:00:00:01 dev sw1-p1 self permanent
//filter by bridge
root@moja-1:/configs/may30-iprt/bridge# ./bridge fdb show br br0
// bridge sw1 has no ports attached..
root@moja-1:/configs/may30-iprt/bridge# ./bridge fdb show br sw1
//filter by port
root@moja-1:/configs/may30-iprt/bridge# ./bridge fdb show brport eth1
02:00:00:12:01:02 vlan 0 master br0 permanent
00:17:42:8a:b4:05 vlan 0 master br0 permanent
00:17:42:8a:b4:07 self permanent
33:33:00:00:00:01 self permanent
// filter by port + bridge
root@moja-1:/configs/may30-iprt/bridge# ./bridge fdb show br br0 brport
sw1-p1
da:ac:46:27:d9:53 vlan 0 master br0 permanent
// for shits and giggles (as they say in New Brunswick), lets
// change the mac that br0 uses
// Note: a magical fdb entry with no brport is added ...
root@moja-1:/configs/may30-iprt/bridge# ip link set dev br0 address
02:00:00:12:01:04
// lets see if we can see the unicorn ..
02:00:00:12:01:04 dev br0 vlan 0 master br0 permanent <=== there it is
//can we see it if we filter by bridge?
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
Dumping a bridge fdb dumps every fdb entry
held. With this change we are going to filter
on selected bridge port.
With this patch other modules are able to ask the bridge whether an
IGMP or MLD querier exists on the according, bridged link layer.
Multicast snooping can only be performed if a valid, selected querier
exists on a link.
Just like the bridge only enables its multicast snooping if a querier
exists, e.g. batman-adv too can only activate its multicast
snooping in bridged scenarios if a querier is present.
For instance this export avoids having to reimplement IGMP/MLD
querier message snooping and parsing in e.g. batman-adv, when
multicast optimizations for bridged scenarios are added in the
future.
