path: root/net/caif/cfmuxl.c
2011-06-16caif: Bugfix - XOFF removed channel from caif-muxsjur.brandeland@stericsson.com
XOFF was mixed up with DOWN indication, causing causing CAIF channel to be removed from mux and all incoming traffic to be lost after receiving flow-off. Fix this by replacing FLOW_OFF with DOWN notification. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-05-22caif: Fixes freeze on Link layer removal.sjur.brandeland@stericsson.com
CAIF Socket layer - caif_socket.c: - Plug mem-leak at reconnect. - Always call disconnect to cleanup CAIF stack. - Disconnect will always report success. CAIF configuration layer - cfcnfg.c - Disconnect must dismantle the caif stack correctly - Protect against faulty removals (check on id zero) CAIF mux layer - cfmuxl.c - When inserting new service layer in the MUX remove any old entries with the same ID. - When removing CAIF Link layer, remove the associated service layers before notifying service layers. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-15caif: Use rcu_read_lock in CAIF mux layer.sjur.brandeland@stericsson.com
Replace spin_lock with rcu_read_lock when accessing lists to layers and cache. While packets are in flight rcu_read_lock should not be held, instead ref-counters are used in combination with RCU. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: Add BUG_ON if dev_info is missing in packetSjur Brændeland
2011-04-11caif: Don't resend if dev_queue_xmit fails.Sjur Brændeland
If CAIF Link Layer returns an error, we no longer try to re-build the CAIF packet and resend it. Instead, we simply return any transmission errors to the socket client. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: code cleanupStephen Hemminger
Cleanup of new CAIF code. * make local functions static * remove code that is never used * expand get_caif_conf() since wrapper is no longer needed * make args to comparison functions const * rename connect_req_to_link_param to keep exported names consistent Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11caif: Bugfix use for_each_safe when removing list nodes.Sjur Brændeland
2010-09-06net/caif: Use pr_fmtJoe Perches
This patch standardizes caif message logging prefixes. Add #define pr_fmt(fmt) KBUILD_MODNAME ":%s(): " fmt, __func__ Add missing "\n"s to some logging messages Convert pr_warning to pr_warn This changes the logging message prefix from CAIF: to caif: for all uses but caif_socket.c and chnl_net.c. Those now use their filename without extension. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23caif: Bugfix - missing spin_unlockSjur Braendeland
Splint found missing spin_unlock. Corrected this an some other trivial split warnings. Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-28caif: Add reference counting to service layerSjur Braendeland
Changes: o Added functions cfsrvl_get and cfsrvl_put. o Added support release_client to use by socket and net device. o Increase reference counting for in-flight packets from cfmuxl Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net-caif: add CAIF core protocol stackSjur Braendeland
CAIF generic protocol implementation. This layer is somewhat generic in order to be able to use and test it outside the Linux Kernel. cfctrl.c - CAIF control protocol layer cfdbgl.c - CAIF debug protocol layer cfdgml.c - CAIF datagram protocol layer cffrml.c - CAIF framing protocol layer cfmuxl.c - CAIF mux protocol layer cfrfml.c - CAIF remote file manager protocol layer cfserl.c - CAIF serial (fragmentation) protocol layer cfsrvl.c - CAIF generic service layer functions cfutill.c - CAIF utility protocol layer cfveil.c - CAIF AT protocol layer cfvidl.c - CAIF video protocol layer Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
