[ Upstream commit 2d6fbfe733f35c6b355c216644e08e149c61b271 ]
The current code does not fill the msg_name member in case it is set.
It also does not set the msg_namelen member to 0 and therefore makes
net/socket.c leak the local, uninitialized sockaddr_storage variable
to userland -- 128 bytes of kernel stack memory.
Fix that by simply setting msg_namelen to 0 as obviously nobody cared
about caif_seqpkt_recvmsg() not filling the msg_name in case it was
set.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Sjur Braendeland <sjur.brandeland@stericsson.com>
[ Upstream commit 96f80d123eff05c3cd4701463786b87952a6c3ac ]
unregister_netdevice_notifier() must be called before
unregister_pernet_subsys() to avoid accessing already freed
pernet memory. This fixes the following oops when doing rmmod:
Call Trace:
[<ffffffffa0f802bd>] caif_device_notify+0x4d/0x5a0 [caif]
[<ffffffff81552ba9>] unregister_netdevice_notifier+0xb9/0x100
[<ffffffffa0f86dcc>] caif_device_exit+0x1c/0x250 [caif]
[<ffffffff810e7734>] sys_delete_module+0x1a4/0x300
[<ffffffff810da82d>] ? trace_hardirqs_on_caller+0x15d/0x1e0
[<ffffffff813517de>] ? trace_hardirqs_on_thunk+0x3a/0x3
[<ffffffff81696bad>] system_call_fastpath+0x1a/0x1f
RIP
[<ffffffffa0f7f561>] caif_get+0x51/0xb0 [caif]
Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Added kfree_skb() calls in the chnk_net.c file on
the error paths.
Connection ID configured through RTNL must allow zero as
connection id. If connection-id is not given when creating the
interface, configure a loopback interface using ifindex as
connection-id.
Kill faulty checks on flow-off leading to connection drop at race conditions.
caif_socket checks for flow-on before transmitting and goes to sleep or
return -EAGAIN upon flow stop. Remove faulty subsequent checks on flow-off
leading to connection drop. Also fix memory leaks on some of the errors paths.
"priv" is initialized twice. I kept the second one, because it is next
to the check for NULL.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Count dropped packets in CAIF Netdevice.
Kill off the debug-fs exposed varaibles from caif_socket.
SKB is freed twice upon send error. The Network stack consumes SKB even
when it returns error code.
Always use cfmuxl_remove_uplayer when removing a up-layer.
cfmuxl_ctrlcmd() can be called independently and in parallel with
cfmuxl_remove_uplayer(). The race between them could cause list_del_rcu
to be called on a node which has been already taken out from the list.
That lead to a (rare) crash on accessing poisoned node->prev inside
list_del_rcu.
This fix ensures that deletion are done holding the same lock.
Reported-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
caif is a subsystem and as such it needs to register with
register_pernet_subsys instead of register_pernet_device.
Among other problems using register_pernet_device was resulting in
net_generic being called before the caif_net structure was allocated.
Which has been causing net_generic to fail with either BUG_ON's or by
return NULL pointers.
A more ugly problem that could be caused is packets in flight why the
subsystem is shutting down.
To remove confusion also remove the cruft cause by inappropriately
trying to fix this bug.
With the aid of the previous patch I have tested this patch and
confirmed that using register_pernet_subsys makes the failure go away as
it should.
Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Tested-by: Sasha Levin <levinsasha928@gmail.com>
Remove WARN_ON and bad handling of SKB without destructor callback
in caif_flow_cb. SKB without destructor cannot be handled as an
error case.
Fix typo for the Vendor/Product Id for ST-Ericsson CAIF modems.
Discovery is based on fixed USB vendor 0x04cc (ST-Ericsson),
product-id 0x230f (NCM).
For net part, remove duplicate included header.
Signed-off-by: Shan Wei <davidshan@tencent.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Remove irqsafe_cpu_xxx variants
Fix up conflict in arch/x86/include/asm/percpu.h due to clash with
cebef5beed3d ("x86: Fix and improve percpu_cmpxchg{8,16}b_double()")
which edited the (now removed) irqsafe_cpu_cmpxchg*_double code.
We simply say that regular this_cpu use must be safe regardless of
preemption and interrupt state. That has no material change for x86
and s390 implementations of this_cpu operations. However, arches that
do not provide their own implementation for this_cpu operations will
now get code generated that disables interrupts instead of preemption.
-tj: This is part of on-going percpu API cleanup. For detailed
discussion of the subject, please refer to the following thread.
http://thread.gmane.org/gmane.linux.kernel/1222078
Signed-off-by: Christoph Lameter <cl@linux.com>
LKML-Reference: <alpine.DEB.2.00.1112221154380.11787@router.home>
DaveM said:
Please, this kind of stuff rots forever and not using bool properly
drives me crazy.
Joe Perches <joe@perches.com> gave me the spatch script:
bool b;
-b = 0
+b = false
bool b;
-b = 1
+b = true
I merely installed coccinelle, read the documentation and took credit.
BUG_ON is too strict in a number of circumstances,
use WARN_ON instead. Protocol errors should not halt the system.
Fix bad assert on fragment size triggering false positive.
This patch adds functionality for avoiding orphaning SKB too early.
The original skb is stashed away and the original destructor is called
from the hi-jacked flow-on callback. If CAIF interface goes down and a
hi-jacked SKB exists, the original skb->destructor is restored.
Flow control is implemented by inspecting the qdisc queue length
in order to detect potential overflow on the TX queue. When a threshold
is reached flow-off is sent upwards in the CAIF stack. At the same time
the skb->destructor is hi-jacked by orphaning the SKB and the original
destructor is replaced with a "flow-on" callback. When the "hi-jacked"
SKB is consumed the queue should be empty, and the "flow-on" callback
is called and xon is sent upwards in the CAIF stack.
NCM 1.0 does not support anything but Ethernet framing, hence
CAIF payload will be put into Ethernet frames.
product-id 0x230f (NCM). In this variant only CAIF payload is sent over
the NCM interface.
The CAIF stack (cfusbl.c) will when USB interface register first check if
we got a CDC NCM USB interface with the right VID, PID.
It will then read the device's Ethernet address and create a 'template'
Ethernet TX header, using a broadcast address as the destination address,
and EthType 0x88b5 (802.1 Local Experimental - vendor specific).
A protocol handler for 0x88b5 is setup for reception of CAIF frames from
the CDC NCM USB interface.
Remove unused enum cfcnfg_phy_type and the parameter to cfserl_create.
Enrolling CAIF link layers are refactored.
Allow NULL pointer in cfpkt_extr_head in order to
skip past header data.
The "tmp" variable here is used to store the result of cpu_to_le16()
so it should be an __le16 instead of an int. We want the high bits
set and the current code works on little endian systems but not on
big endian systems.
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
With calls to modular infrastructure, these files really
needs the full module.h header. Call it out so some of the
cleanups of implicit and unrequired includes elsewhere can be
cleaned up.
The caif code will register its own pernet_operations, and then register
a netdevice_notifier. Each time the netdevice_notifier is triggered,
it'll do some stuff... including a lookup of its own pernet stuff with
net_generic().
If the net_generic() call ever returns NULL, the caif code will BUG().
That doesn't seem *so* unreasonable, I suppose — it does seem like it
should never happen.
However, it *does* happen. When we clone a network namespace,
setup_net() runs through all the pernet_operations one at a time. It
gets to loopback before it gets to caif. And loopback_net_init()
registers a netdevice... while caif hasn't been initialised. So the caif
netdevice notifier triggers, and immediately goes BUG().
We could imagine a complex and overengineered solution to this generic
class of problems, but this patch takes the simple approach. It just
makes caif_device_notify() *not* go looking for its pernet data
structures if the device it's being notified about isn't a caif device
in the first place.
Cc: stable@kernel.org
The allocation of "phyinfo" wasn't checked, and also the allocation
wasn't freed on error paths. Sjur Brændeland pointed out as well
that "phy_driver" should be freed on the error path too.
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
Commit bd30ce4bc0b7 (caif: Use RCU instead of spin-lock in caif_dev.c)
added a potential NULL dereference in case alloc_percpu() fails.
caif_device_alloc() can also use GFP_KERNEL instead of GFP_ATOMIC.
CC: Sjur Brændeland <sjur.brandeland@stericsson.com>
Remove per site OOM messages because they duplicate
the generic mm subsystem OOM message.
Use kzalloc instead of kmalloc/memset
when next to the OOM message removals.
Reduces object size (allyesconfig ~2%)
$ size -t drivers/net/caif/built-in.o.old net/caif/built-in.o.old
32297 700 8224 41221 a105 drivers/net/caif/built-in.o.old
72159 1317 20552 94028 16f4c net/caif/built-in.o.old
104456 2017 28776 135249 21051 (TOTALS)
$ size -t drivers/net/caif/built-in.o.new net/caif/built-in.o.new
31975 700 8184 40859 9f9b drivers/net/caif/built-in.o.new
70748 1317 20152 92217 16839 net/caif/built-in.o.new
102723 2017 28336 133076 207d4 (TOTALS)
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
It was suggested by "make versioncheck" that the follwing includes of
linux/version.h are redundant:
/home/jj/src/linux-2.6/net/caif/caif_dev.c: 14 linux/version.h not needed.
/home/jj/src/linux-2.6/net/caif/chnl_net.c: 10 linux/version.h not needed.
/home/jj/src/linux-2.6/net/ipv4/gre.c: 19 linux/version.h not needed.
/home/jj/src/linux-2.6/net/netfilter/ipset/ip_set_core.c: 20 linux/version.h not needed.
/home/jj/src/linux-2.6/net/netfilter/xt_set.c: 16 linux/version.h not needed.
and it seems that it is right.
Beyond manually inspecting the source files I also did a few build
tests with various configs to confirm that including the header in
those files is indeed not needed.
Here's a patch to remove the pointless includes.
Acked-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
XOFF was mixed up with DOWN indication, causing causing CAIF channel to be
removed from mux and all incoming traffic to be lost after receiving flow-off.
Fix this by replacing FLOW_OFF with DOWN notification.
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
Take the RTNL lock unconditionally when calling dev_close.
Taking the lock conditionally may cause race conditions.
In case of checksum error, the framing layer returns -EILSEQ, but
does not free the packet. Plug this hole by freeing the packet if
-EILSEQ is returned.
Fix spinlock bugs when running out of link-ids in loopback tests and
avoid allocating link-id when error is set in link-setup-response.
CAIF Socket layer - caif_socket.c:
- Plug mem-leak at reconnect.
- Always call disconnect to cleanup CAIF stack.
- Disconnect will always report success.
CAIF configuration layer - cfcnfg.c
- Disconnect must dismantle the caif stack correctly
- Protect against faulty removals (check on id zero)
CAIF mux layer - cfmuxl.c
- When inserting new service layer in the MUX remove
any old entries with the same ID.
- When removing CAIF Link layer, remove the associated
service layers before notifying service layers.
Add check on layer->dn != NULL before calling functions in
layer below.
Race condition caused debugfs_create_dir() to fail due to duplicate
name. Use atomic counter to create unique directory name.
net_ratelimit() is introduced to limit debug printouts.
Do proper handling of dev_queue_xmit errors in order to
avoid double free of skb and leaks in error conditions.
In cfctrl pending requests are removed when CAIF Link layer goes down.
Use struct net to reference CAIF configuration object instead of static variables.
Refactor functions caif_connect_client, caif_disconnect_client and squach
files cfcnfg.c and caif_config_utils.
CAIF Socket Layer and ip-interface registers reference counters
in CAIF service layer. The functions sock_hold, sock_put and
dev_hold, dev_put are used by CAIF Stack to protect from freeing
memory while packets are in-flight.
