[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
[ Upstream commit 0ae89beb283a0db5980d1d4781c7d7be2f2810d6 ]
Self generated skbuffs in net/can/bcm.c are setting a skb->sk reference but
no explicit destructor which is enforced since Linux 3.11 with commit
376c7311bdb6 (net: add a temporary sanity check in skb_orphan()).
This patch adds some helper functions to make sure that a destructor is
properly defined when a sock reference is assigned to a CAN related skb.
To create an unshared skb owned by the original sock a common helper function
has been introduced to replace open coded functions to create CAN echo skbs.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Tested-by: Andre Naujoks <nautsch2@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Usually the received CAN frames can be processed/routed as much as 'max_hops'
times (which is given at module load time of the can-gw module).
Introduce a new configuration option to reduce the number of possible hops
for a specific gateway rule to a value smaller then max_hops.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
Currently, sock_tx_timestamp() always returns 0. The comment that
describes the sock_tx_timestamp() function wrongly says that it
returns an error when an invalid argument is passed (from commit
20d4947353be, ``net: socket infrastructure for SO_TIMESTAMPING'').
Make the function void, so that we can also remove all the unneeded
if conditions that check for such a _non-existant_ error case in the
output path.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
Memory allocated by kmem_cache_alloc() should be freed using
kmem_cache_free(), not kfree().
Cc: linux-stable <stable@vger.kernel.org> # >= v3.2
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
With decnet converted, we can finally get rid of rta_buf and its
computations around it. It also gets rid of the minimal header
length verification since all message handlers do that explicitly
anyway.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
The rework of the kernel hlist implementation "hlist: drop the node parameter
from iterators" (b67bfe0d42cac56c512dd5da4b1b347a23f4b70a) created some
fallout in the form of non matching comments and obsolete code.
Additionally to the cleanup this patch adds a WARN() statement to catch the
caller of the wrong filter removal request.
Replace printk(KERN_ERR with pr_err
Add space before {
Removed OOM messages
Signed-off-by: Valentin Ilie <valentin.ilie@gmail.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Added accessor and skb_reserve helpers for struct can_skb_priv.
Removed pointless skb_headroom() check.
CC: Marc Kleine-Budde <mkl@pengutronix.de>
Add a statistic counter to detect deleted frames due to misconfiguration with
a new read-only CGW_DELETED netlink attribute for the CAN gateway.
To prevent a possible misconfiguration (e.g. circular CAN frame routings)
limit the number of routings of a single CAN frame to a small variable value.
The limit can be specified by the module parameter 'max_hops' (1..6).
The default value is 1 (one hop), according to the original can-gw behaviour.
Introduce new configuration flag CGW_FLAGS_CAN_IIF_TX_OK to configure if a
CAN sk_buff that has been routed with can-gw is allowed to be send back to
the originating CAN interface.
The struct can_skb_priv is used to transport additional information along
with the stored struct can(fd)_frame that can not be contained in existing
struct sk_buff elements.
can_skb_priv is located in the skb headroom, which does not touch the existing
CAN sk_buff usage with skb->data and skb->len, so that even out-of-tree
CAN drivers can be used without changes.
Btw. out-of-tree CAN drivers without can_skb_priv in the sk_buff headroom
would not support features based on can_skb_priv.
The can_skb_priv->ifindex contains the first interface where the CAN frame
appeared on the local host. Unfortunately skb->skb_iif can not be used as this
value is overwritten in every netif_receive_skb() call.
This patch enables all basic CAN protocol by default.
This patch adds an 'if CAN...endif' Block around all CAN symbols in
net/can/Kconfig. So the 'depends on CAN' dependencies can be removed.
Pull trivial branch from Jiri Kosina:
"Usual stuff -- comment/printk typo fixes, documentation updates, dead
code elimination."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
HOWTO: fix double words typo
x86 mtrr: fix comment typo in mtrr_bp_init
propagate name change to comments in kernel source
doc: Update the name of profiling based on sysfs
treewide: Fix typos in various drivers
treewide: Fix typos in various Kconfig
wireless: mwifiex: Fix typo in wireless/mwifiex driver
messages: i2o: Fix typo in messages/i2o
scripts/kernel-doc: check that non-void fcts describe their return value
Kernel-doc: Convention: Use a "Return" section to describe return values
radeon: Fix typo and copy/paste error in comments
doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c
various: Fix spelling of "asynchronous" in comments.
Fix misspellings of "whether" in comments.
eisa: Fix spelling of "asynchronous".
various: Fix spelling of "registered" in comments.
doc: fix quite a few typos within Documentation
target: iscsi: fix comment typos in target/iscsi drivers
treewide: fix typo of "suport" in various comments and Kconfig
treewide: fix typo of "suppport" in various comments
Set in the rx_ifindex to pass the correct interface index in the case of a
message timeout detection. Usually the rx_ifindex value is set at receive
time. But when no CAN frame has been received the RX_TIMEOUT notification
did not contain a valid value.
Reported-by: Andre Naujoks <nautsch2@googlemail.com>
"Whether" is misspelled in various comments across the tree; this
fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
- In rtnetlink_rcv_msg convert the capable(CAP_NET_ADMIN) check
to ns_capable(net->user-ns, CAP_NET_ADMIN). Allowing unprivileged
users to make netlink calls to modify their local network
namespace.
- In the rtnetlink doit methods add capable(CAP_NET_ADMIN) so
that calls that are not safe for unprivileged users are still
protected.
Later patches will remove the extra capable calls from methods
that are safe for unprivilged users.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Oliver Hartkopp <socketcan@hartkopp.net>
It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
No need to cast return value of nla_data()
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
- set message type to RTM_NEWROUTE
- relate to original request by inheriting the sequence and port number.
- set NLM_F_MULTI because it's a dump and more messages will follow
Also use nla_get_u32() instead of nla_memcpy() to access u32 attribtues.
nlmsg_end() will take care of this when we finalize the message.
Put can_rx_alldev_list into the af_can header to fix the following
sparse warning: net/can/af_can.c:80:22: warning: symbol
'can_rx_alldev_list' was not declared. Should it be static?
- introduce a new sockopt CAN_RAW_FD_FRAMES to allow CAN FD frames
- handle CAN frames and CAN FD frames simultaneously when enabled
- handle ETH_P_CAN and ETH_P_CANFD skbuffs
- update sanity checks for CAN and CAN FD
- make sure the CAN frame can pass the selected CAN netdevice on send
- bump core version and abi version to indicate the new CAN FD support
- add new struct canfd_frame
- check identical element offsets in struct can_frame and struct canfd_frame
- new ETH_P_CANFD definition to tag CAN FD skbs correctly
- add CAN_MTU and CANFD_MTU definitions for easy frame and mode detection
- add CAN[FD]_MAX_[DLC|DLEN] helper constants to remove hard coded values
- update existing struct can_frame with helper constants and comments
net/ipv6/route.c
This deals with a merge conflict between the net-next addition of the
inetpeer network namespace ops, and Thomas Graf's bug fix in
2a0c451ade8e1783c5d453948289e4a978d417c9 which makes sure we don't
register /proc/net/ipv6_route before it is actually safe to do so.
Orphaning skb in dev_hard_start_xmit() makes bonding behavior
unfriendly for applications sending big UDP bursts : Once packets
pass the bonding device and come to real device, they might hit a full
qdisc and be dropped. Without orphaning, the sender is automatically
throttled because sk->sk_wmemalloc reaches sk->sk_sndbuf (assuming
sk_sndbuf is not too big)
We could try to defer the orphaning adding another test in
dev_hard_start_xmit(), but all this seems of little gain,
now that BQL tends to make packets more likely to be parked
in Qdisc queues instead of NIC TX ring, in cases where performance
matters.
Reverts commits :
fc6055a5ba31 net: Introduce skb_orphan_try()
87fd308cfc6b net: skb_tx_hash() fix relative to skb_orphan_try()
and removes SKBTX_DRV_NEEDS_SK_REF flag
Reported-and-bisected-by: Jean-Michel Hautbois <jhautbois@gmail.com>
As Heinz-Juergen Oertel pointed out 'CAN error frames' are a already defined
term for the CAN protocol violation indication on the wire.
To avoid confusion with the error messages created by CAN drivers available
via CAN RAW sockets update the documentation and change the naming from
'error frames' to 'error messages' or 'error message frames'.
Make cgw_list static to remove the following sparse warning:
net/can/gw.c:69:1: warning: symbol 'cgw_list' was not declared.
Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com>
The BerliOS project, which currently hosts our mailinglist, will
close with the end of the year. Now take the chance and remove all
occurrences of the mailinglist address from the source files.
net/batman-adv/soft-interface.c
The commit aabdcb0b553b9c9547b1a506b34d55a764745870 ("can bcm: fix tx_setup
off-by-one errors") fixed only a part of the original problem reported by
Andre Naujoks. It turned out that the original code needed to be re-ordered
to reduce complexity and to finally fix the reported frame counting issues.
This patch fixes two off-by-one errors that canceled each other out.
Checking for the same condition two times in bcm_tx_timeout_tsklet() reduced
the count of frames to be sent by one. This did not show up the first time
tx_setup is invoked as an additional frame is sent due to TX_ANNONCE.
Invoking a second tx_setup on the same item led to a reduced (by 1) number of
sent frames.
Reported-by: Andre Naujoks <nautsch@gmail.com>
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
This patch adds a CAN Gateway/Router to route (and modify) CAN frames.
It is based on the PF_CAN core infrastructure for msg filtering and msg
sending and can optionally modify routed CAN frames on the fly.
CAN frames can *only* be routed between CAN network interfaces (one hop).
They can be modified with AND/OR/XOR/SET operations as configured by the
netlink configuration interface known e.g. from iptables. From the netlink
view this can-gw implements RTM_{NEW|DEL|GET}ROUTE for PF_CAN.
The CAN specific userspace tool to manage CAN routing entries can be found in
the CAN utils http://svn.berlios.de/wsvn/socketcan/trunk/can-utils/cangw.c
at the SocketCAN SVN on BerliOS.
This is important for SMP platform to check if timer function is
executing on other CPU with deleting the timer.
Signed-off-by: Rajan Aggarwal <Rajan Aggarwal rajan.aggarwal85@gmail.com>
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
Since printk_ratelimit() shouldn't be used anymore (see comment in
include/linux/printk.h), replace it with printk_ratelimited().
Signed-off-by: Manuel Zerpies <manuel.f.zerpies@ww.stud.uni-erlangen.de>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
