[ Upstream commit 62b1a8ab9b3660bb820d8dfe23148ed6cda38574 ]
Orphaning skb in dev_hard_start_xmit() makes bonding behavior
unfriendly for applications sending big UDP bursts : Once packets
pass the bonding device and come to real device, they might hit a full
qdisc and be dropped. Without orphaning, the sender is automatically
throttled because sk->sk_wmemalloc reaches sk->sk_sndbuf (assuming
sk_sndbuf is not too big)
We could try to defer the orphaning adding another test in
dev_hard_start_xmit(), but all this seems of little gain,
now that BQL tends to make packets more likely to be parked
in Qdisc queues instead of NIC TX ring, in cases where performance
matters.
Reverts commits :
fc6055a5ba31 net: Introduce skb_orphan_try()
87fd308cfc6b net: skb_tx_hash() fix relative to skb_orphan_try()
and removes SKBTX_DRV_NEEDS_SK_REF flag
Reported-and-bisected-by: Jean-Michel Hautbois <jhautbois@gmail.com>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
The BerliOS project, which currently hosts our mailinglist, will
close with the end of the year. Now take the chance and remove all
occurrences of the mailinglist address from the source files.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
net/batman-adv/soft-interface.c
The commit aabdcb0b553b9c9547b1a506b34d55a764745870 ("can bcm: fix tx_setup
off-by-one errors") fixed only a part of the original problem reported by
Andre Naujoks. It turned out that the original code needed to be re-ordered
to reduce complexity and to finally fix the reported frame counting issues.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
This patch fixes two off-by-one errors that canceled each other out.
Checking for the same condition two times in bcm_tx_timeout_tsklet() reduced
the count of frames to be sent by one. This did not show up the first time
tx_setup is invoked as an additional frame is sent due to TX_ANNONCE.
Invoking a second tx_setup on the same item led to a reduced (by 1) number of
sent frames.
Reported-by: Andre Naujoks <nautsch@gmail.com>
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
This patch adds a CAN Gateway/Router to route (and modify) CAN frames.
It is based on the PF_CAN core infrastructure for msg filtering and msg
sending and can optionally modify routed CAN frames on the fly.
CAN frames can *only* be routed between CAN network interfaces (one hop).
They can be modified with AND/OR/XOR/SET operations as configured by the
netlink configuration interface known e.g. from iptables. From the netlink
view this can-gw implements RTM_{NEW|DEL|GET}ROUTE for PF_CAN.
The CAN specific userspace tool to manage CAN routing entries can be found in
the CAN utils http://svn.berlios.de/wsvn/socketcan/trunk/can-utils/cangw.c
at the SocketCAN SVN on BerliOS.
This is important for SMP platform to check if timer function is
executing on other CPU with deleting the timer.
Signed-off-by: Rajan Aggarwal <Rajan Aggarwal rajan.aggarwal85@gmail.com>
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
Since printk_ratelimit() shouldn't be used anymore (see comment in
include/linux/printk.h), replace it with printk_ratelimited().
Signed-off-by: Manuel Zerpies <manuel.f.zerpies@ww.stud.uni-erlangen.de>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
As these pointers have been printed without using %p they were missed in the
big network kptr_restrict conversion patch %p -> %pK from Dan Rosenberg.
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
can: rename can_try_module_get to can_get_proto
can_try_module_get does return a struct can_proto.
The name explains what is done in so much detail that a caller
may not notice that a struct can_proto is locked/unlocked.
Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
commit 53914b67993c724cec585863755c9ebc8446e83b had the
same message. That commit did put everything in place but
did not make can_proto const itself.
Resolved logic conflicts causing a build failure due to
drivers/net/r8169.c changes using a patch from Stephen Rothwell.
v2: added space after 'if' according code style.
We can get here with a NULL socket argument passed from userspace,
so we need to handle it accordingly.
Thanks to Dave Jones pointing at this issue in net/can/bcm.c
Signed-off-by: Dave Jones <davej@redhat.com>
drivers/net/smsc911x.c
This patch removes spin_locks at CAN socket creation time by using RCU.
Inspired by the discussion with Kurt van Dijck and Eric Dumazet the RCU code
was partly derived from af_phonet.c
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
can_ioctl is the only reason for struct proto to be non-const.
script/check-patch.pl suggests struct proto be const.
Setting the reference to the common can_ioctl() in all CAN protocols directly
removes the need to make the struct proto writable in af_can.c
This patch makes the CAN socket code conform to the manpage of sendmsg.
Since the socket address is just being used as a unique identifier, its
inode number is an alternative that does not leak potentially sensitive
information.
CC-ing stable because MITRE has assigned CVE-2010-4565 to the issue.
Changed Makefile to use <modules>-y instead of <modules>-objs
because -objs is deprecated and not mentioned in
Documentation/kbuild/makefiles.txt.
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
On 64-bit platforms the ASCII representation of a pointer may be up to 17
bytes long. This patch increases the length of the buffer accordingly.
http://marc.info/?l=linux-netdev&m=128872251418192&w=2
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
CC: Linus Torvalds <torvalds@linux-foundation.org>
CAN has no addressing scheme. It is currently impossible for userspace
to tell is a received CAN frame comes from another process on the local
host, or from a remote CAN device.
This patch add support for userspace applications to distinguish between
'own', 'local' and 'remote' CAN traffic. The distinction is made by returning
flags in msg->msg_flags in the call to recvmsg().
The added documentation explains the introduced flags.
This patch removes the abstraction introduced by the union skb_shared_tx in
the shared skb data.
The access of the different union elements at several places led to some
confusion about accessing the shared tx_flags e.g. in skb_orphan_try().
http://marc.info/?l=linux-netdev&m=128084897415886&w=2
This patch adds a limit for nframes as the number of frames in TX_SETUP and
RX_SETUP are derived from a single byte multiplex value by default.
Use-cases that would require to send/filter more than 256 CAN frames should
be implemented in userspace for complexity reasons anyway.
Additionally the assignments of unsigned values from userspace to signed
values in kernelspace and vice versa are fixed by using unsigned values in
kernelspace consistently.
Reported-by: Ben Hawkes <hawkes@google.com>
Acked-by: Urs Thuermann <urs.thuermann@volkswagen.de>
Commit fc6055a5ba31e2c14e36e8939f9bf2b6d586a7f5 (net: Introduce
skb_orphan_try()) allows an early orphan of the skb and takes care on
tx timestamping, which needs the sk-reference in the skb on driver level.
So does the can-raw socket, which has not been taken into account here.
The patch below adds a 'prevent_sk_orphan' bit in the skb tx shared info,
which fixes the problem discovered by Matthias Fuchs here:
http://marc.info/?t=128030411900003&r=1&w=2
Even if it's not a primary tx timestamp topic it fits well into some skb
shared tx context. Or should be find a different place for the information to
protect the sk reference until it reaches the driver level?
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
// </smpl>
This patch removes from net/ (but not any netfilter files)
all the unnecessary return; statements that precede the
last closing brace of void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
At this point optlen == sizeof(sfilter) but some compilers are dumb.
Reported-by: Németh Márton <nm127@freemail.h
Acked-by: Oliver Hartkopp <oliver@hartkopp.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits)
smc91c92_cs: fix the problem of "Unable to find hardware address"
r8169: clean up my printk uglyness
net: Hook up cxgb4 to Kconfig and Makefile
cxgb4: Add main driver file and driver Makefile
cxgb4: Add remaining driver headers and L2T management
cxgb4: Add packet queues and packet DMA code
cxgb4: Add HW and FW support code
cxgb4: Add register, message, and FW definitions
netlabel: Fix several rcu_dereference() calls used without RCU read locks
bonding: fix potential deadlock in bond_uninit()
net: check the length of the socket address passed to connect(2)
stmmac: add documentation for the driver.
stmmac: fix kconfig for crc32 build error
be2net: fix bug in vlan rx path for big endian architecture
be2net: fix flashing on big endian architectures
be2net: fix a bug in flashing the redboot section
bonding: bond_xmit_roundrobin() fix
drivers/net: Add missing unlock
net: gianfar - align BD ring size console messages
net: gianfar - initialize per-queue statistics
check the length of the socket address passed to connect(2).
Check the length of the socket address passed to connect(2). If the
length is invalid, -EINVAL will be returned.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
net/bluetooth/l2cap.c | 3 ++-
net/bluetooth/rfcomm/sock.c | 3 ++-
net/bluetooth/sco.c | 3 ++-
net/can/bcm.c | 3 +++
net/ieee802154/af_ieee802154.c | 3 +++
net/ipv4/af_inet.c | 5 +++++
net/netlink/af_netlink.c | 3 +++
7 files changed, 20 insertions(+), 3 deletions(-)
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
In commit 20dd3850bcf860561496827b711fa10fecf6e787 "can: Speed up CAN frame
receiption by using ml_priv" the formerly used hlist of receiver lists for
each CAN netdevice has been replaced.
The hlist content ensured only CAN netdevices to be accessed by the
can_rx_(un)register() functions which accidently dropped away together with
the hlist receiver implementation.
This patch re-introduces the check for CAN netdevices in can_rx_(un)register().
Signed-off-by: Oliver Hartkopp <oliver@hartkopp.net>
this patch removes the hlist that contains the CAN receiver filter lists.
It uses the 'midlayer private' pointer ml_priv and links the filters directly
to the CAN netdevice, which allows to omit the walk through the complete CAN
devices hlist for each received CAN frame.
This patch is tested and does not remove any locking.
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
Generated with the following semantic patch
struct net *n1;
struct net *n2;
- n1 == n2
+ net_eq(n1, n2)
struct net *n1;
struct net *n2;
- n1 != n2
+ !net_eq(n1, n2)
applied over {include,net,drivers/net}.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Use new function to avoid doing read_lock().
drivers/net/can/usb/ems_usb.c
bcm_proc_getifname() is called with RTNL and dev_base_lock
not held. It calls __dev_get_by_index() without locks, and
this is illegal (might crash)
Close the race by holding dev_base_lock and copying dev->name
in the protected section.
The generic __sock_create function has a kern argument which allows the
security system to make decisions based on if a socket is being created by
the kernel or by userspace. This patch passes that flag to the
net_proto_family specific create function, so it can do the same thing.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
struct can_proto had a capability field which wasn't ever used. It is
dropped entirely.
struct inet_protosw had a capability field which can be more clearly
expressed in the code by just checking if sock->type = SOCK_RAW.
optlen is unsigned so the `< 0' test is never true.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Create a new socket level option to report number of queue overflows
Recently I augmented the AF_PACKET protocol to report the number of frames lost
on the socket receive queue between any two enqueued frames. This value was
exported via a SOL_PACKET level cmsg. AFter I completed that work it was
requested that this feature be generalized so that any datagram oriented socket
could make use of this option. As such I've created this patch, It creates a
new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a
SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue
overflowed between any two given frames. It also augments the AF_PACKET
protocol to take advantage of this new feature (as it previously did not touch
sk->sk_drops, which this patch uses to record the overflow count). Tested
successfully by me.
Notes:
1) Unlike my previous patch, this patch simply records the sk_drops value, which
is not a number of drops between packets, but rather a total number of drops.
Deltas must be computed in user space.
2) While this patch currently works with datagram oriented protocols, it will
also be accepted by non-datagram oriented protocols. I'm not sure if thats
agreeable to everyone, but my argument in favor of doing so is that, for those
protocols which aren't applicable to this option, sk_drops will always be zero,
and reporting no drops on a receive queue that isn't used for those
non-participating protocols seems reasonable to me. This also saves us having
to code in a per-protocol opt in mechanism.
3) This applies cleanly to net-next assuming that commit
977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
All usages of structure net_proto_ops should be declared const.
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
