path: root/net/ceph/auth_x.h
2014-12-17libceph: store session key in cephx authorizerYan, Zheng
Session key is required when calculating message signature. Save the session key in authorizer, this avoid lookup ticket handler for each message Signed-off-by: Yan, Zheng <zyan@redhat.com>
2013-10-19net: 8021q/bluetooth/bridge/can/ceph: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-01libceph: add update_authorizer auth methodSage Weil
Currently the messenger calls out to a get_authorizer con op, which will create a new authorizer if it doesn't yet have one. In the meantime, when we rotate our service keys, the authorizer doesn't get updated. Eventually it will be rejected by the server on a new connection attempt and get invalidated, and we will then rebuild a new authorizer, but this is not ideal. Instead, if we do have an authorizer, call a new update_authorizer op that will verify that the current authorizer is using the latest secret. If it is not, we will build a new one that does. This avoids the transient failure. This fixes one of the sorry sequence of events for bug http://tracker.ceph.com/issues/4282 Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@inktank.com>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
