This patch has ceph's lib code use the memalloc flags.
If the VM layer needs to write data out to free up memory to handle new
allocation requests, the block layer must be able to make forward progress.
To handle that requirement we use structs like mempools to reserve memory for
objects like bios and requests.
The problem is when we send/receive block layer requests over the network
layer, net skb allocations can fail and the system can lock up.
To solve this, the memalloc related flags were added. NBD, iSCSI
and NFS uses these flags to tell the network/vm layer that it should
use memory reserves to fullfill allcation requests for structs like
skbs.
I am running ceph in a bunch of VMs in my laptop, so this patch was
not tested very harshly.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Ilya Dryomov <idryomov@redhat.com>
Commit f363e45fd118 ("net/ceph: make ceph_msgr_wq non-reentrant")
effectively removed WQ_MEM_RECLAIM flag from ceph_msgr_wq. This is
wrong - libceph is very much a memory reclaim path, so restore it.
Cc: stable@vger.kernel.org # needs backporting for < 3.12
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
Tested-by: Micha Krause <micha@krausam.de>
Reviewed-by: Sage Weil <sage@redhat.com>
this allow pagelist to present data that may be sent multiple times.
Signed-off-by: Yan, Zheng <zyan@redhat.com>
Use the more common pr_warn.
Other miscellanea:
o Coalesce formats
o Realign arguments
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Determining ->last_piece based on the value of ->page_offset + length
is incorrect because length here is the length of the entire message.
->last_piece set to false even if page array data item length is <=
PAGE_SIZE, which results in invalid length passed to
ceph_tcp_{send,recv}page() and causes various asserts to fire.
# cat pages-cursor-init.sh
#!/bin/bash
rbd create --size 10 --image-format 2 foo
FOO_DEV=$(rbd map foo)
dd if=/dev/urandom of=$FOO_DEV bs=1M &>/dev/null
rbd snap create foo@snap
rbd snap protect foo@snap
rbd clone foo@snap bar
# rbd_resize calls librbd rbd_resize(), size is in bytes
./rbd_resize bar $(((4 << 20) + 512))
rbd resize --size 10 bar
BAR_DEV=$(rbd map bar)
# trigger a 512-byte copyup -- 512-byte page array data item
dd if=/dev/urandom of=$BAR_DEV bs=1M count=1 seek=5
The problem exists only in ceph_msg_data_pages_cursor_init(),
ceph_msg_data_pages_advance() does the right thing. The size_t cast is
unnecessary.
Cc: stable@vger.kernel.org # 3.10+
Reviewed-by: Alex Elder <elder@linaro.org>
queue_con() bumps osd ref count. We should do the reverse when
canceling con work.
Add dout()s to ceph_msg_{get,put}(). Also move them to .c and turn
kref release callback into a static function.
It has been reported that using ZFSonLinux on rbd will result in memory
corruption. The bug report can be found here:
https://github.com/zfsonlinux/spl/issues/241
http://tracker.ceph.com/issues/7790
The reason is that ZFS will send pages with page_count 0 into rbd, which in
turns send them to tcp_sendpage. However, tcp_sendpage cannot deal with
page_count 0, as it will do get_page and put_page, and erroneously free the
page.
This type of issue has been noted before, and handled in iscsi, drbd,
etc. So, rbd should also handle this. This fix address this issue by fall back
to slower sendmsg when page_count 0 detected.
Cc: Sage Weil <sage@inktank.com>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Signed-off-by: Chunwei Chen <tuxoko@gmail.com>
Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
When there is no more data, ceph_msg_data_{pages,pagelist}_advance()
should not move on to the next page.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
Commit f38a5181d9f3 ("ceph: Convert to immutable biovecs") introduced
a NULL pointer dereference, which broke rbd in -rc1. Fix it.
Cc: Kent Overstreet <kmo@daterainc.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Pull core block IO changes from Jens Axboe:
"The major piece in here is the immutable bio_ve series from Kent, the
rest is fairly minor. It was supposed to go in last round, but
various issues pushed it to this release instead. The pull request
contains:
- Various smaller blk-mq fixes from different folks. Nothing major
here, just minor fixes and cleanups.
- Fix for a memory leak in the error path in the block ioctl code
from Christian Engelmayer.
- Header export fix from CaiZhiyong.
- Finally the immutable biovec changes from Kent Overstreet. This
enables some nice future work on making arbitrarily sized bios
possible, and splitting more efficient. Related fixes to immutable
bio_vecs:
- dm-cache immutable fixup from Mike Snitzer.
- btrfs immutable fixup from Muthu Kumar.
- bio-integrity fix from Nic Bellinger, which is also going to stable"
* 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits)
xtensa: fixup simdisk driver to work with immutable bio_vecs
block/blk-mq-cpu.c: use hotcpu_notifier()
blk-mq: for_each_* macro correctness
block: Fix memory leak in rw_copy_check_uvector() handling
bio-integrity: Fix bio_integrity_verify segment start bug
block: remove unrelated header files and export symbol
blk-mq: uses page->list incorrectly
blk-mq: use __smp_call_function_single directly
btrfs: fix missing increment of bi_remaining
Revert "block: Warn and free bio if bi_end_io is not set"
blk-mq: fix initializing request's start time
block: blk-mq: don't export blk_mq_free_queue()
block: blk-mq: make blk_sync_queue support mq
block: blk-mq: support draining mq queue
dm cache: increment bi_remaining when bi_end_io is restored
block: fixup for generic bio chaining
block: Really silence spurious compiler warnings
block: Silence spurious compiler warnings
block: Kill bio_pair_split()
Encapsulate kmalloc vs vmalloc memory allocation and freeing logic into
two helpers, ceph_kvmalloc() and ceph_kvfree(), and switch to them.
ceph_kvmalloc() kmalloc()'s a maximum of 8 pages, anything bigger is
vmalloc()'ed with __GFP_HIGHMEM set. This changes the existing
behaviour:
- for buffers (ceph_buffer_new()), from trying to kmalloc() everything
and using vmalloc() just as a fallback
- for messages (ceph_msg_new()), from going to vmalloc() for anything
bigger than a page
- for messages (ceph_msg_new()), from disallowing vmalloc() to use high
memory
The check that makes sure that we have enough memory allocated to read
in the entire header of the message in question is currently busted.
It compares front_len of the incoming message with iov_len field of
ceph_msg::front structure, which is used primarily to indicate the
amount of data already read in, and not the size of the allocated
buffer. Under certain conditions (e.g. a short read from a socket
followed by that socket's shutdown and owning ceph_connection reset)
this results in a warning similar to
[85688.975866] libceph: get_reply front 198 > preallocated 122 (4#0)
and, through another bug, leads to forever hung tasks and forced
reboots. Fix this by comparing front_len with front_alloc_len field of
struct ceph_msg, which stores the actual size of the buffer.
Fixes: http://tracker.ceph.com/issues/5425
Rename front_max field of struct ceph_msg to front_alloc_len to make
its purpose more clear.
Similar to userspace, don't bail with "parse_ips bad ip ..." if the
specified port is port 0, instead use port CEPH_MON_PORT (6789, the
default monitor port).
This updates ceph_features.h so that it has all feature bits defined in
ceph.git. In the interim since the last update, ceph.git crossed the
"32 feature bits" point, and, the addition of the 33rd bit wasn't
handled correctly. The work-around is squashed into this commit and
reflects ceph.git commit 053659d05e0349053ef703b414f44965f368b9f0.
In preparation for ceph_features.h update, change all features fields
from unsigned int/u32 to u64. (ceph.git has ~40 feature bits at this
point.)
Now that we've got a mechanism for immutable biovecs -
bi_iter.bi_bvec_done - we need to convert drivers to use primitives that
respect it instead of using the bvec array directly.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: ceph-devel@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull ceph updates from Sage Weil:
"This includes both the first pile of Ceph patches (which I sent to
torvalds@vger, sigh) and a few new patches that add support for
fscache for Ceph. That includes a few fscache core fixes that David
Howells asked go through the Ceph tree. (Thanks go to Milosz Tanski
for putting this feature together)
This first batch of patches (included here) had (has) several
important RBD bug fixes, hole punch support, several different
cleanups in the page cache interactions, improvements in the truncate
code (new truncate mutex to avoid shenanigans with i_mutex), and a
series of fixes in the synchronous striping read/write code.
On top of that is a random collection of small fixes all across the
tree (error code checks and error path cleanup, obsolete wq flags,
etc)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (43 commits)
ceph: use d_invalidate() to invalidate aliases
ceph: remove ceph_lookup_inode()
ceph: trivial buildbot warnings fix
ceph: Do not do invalidate if the filesystem is mounted nofsc
ceph: page still marked private_2
ceph: ceph_readpage_to_fscache didn't check if marked
ceph: clean PgPrivate2 on returning from readpages
ceph: use fscache as a local presisent cache
fscache: Netfs function for cleanup post readpages
FS-Cache: Fix heading in documentation
CacheFiles: Implement interface to check cache consistency
FS-Cache: Add interface to check consistency of a cached object
rbd: fix null dereference in dout
rbd: fix buffer size for writes to images with snapshots
libceph: use pg_num_mask instead of pgp_num_mask for pg.seed calc
rbd: fix I/O error propagation for reads
ceph: use vfs __set_page_dirty_nobuffers interface instead of doing it inside filesystem
ceph: allow sync_read/write return partial successed size of read/write.
ceph: fix bugs about handling short-read for sync read mode.
ceph: remove useless variable revoked_rdcache
dbf2576e37 ("workqueue: make all workqueues non-reentrant") made
WQ_NON_REENTRANT no-op and the flag is going away. Remove its usages.
This patch doesn't introduce any behavior changes.
Several call sites use the hardcoded following condition :
sk_stream_wspace(sk) >= sk_stream_min_wspace(sk)
Lets use a helper because TCP_NOTSENT_LOWAT support will change this
condition for TCP sockets.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Create a slab cache to manage ceph_msg_data structure allocation.
This is part of:
http://tracker.ceph.com/issues/3926
Signed-off-by: Alex Elder <elder@inktank.com>
Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
Create a slab cache to manage ceph_msg structure allocation.
This is part of:
This patch makes four small changes in the ceph messenger.
While getting copyup functionality working I found two bugs in the
messenger. Existing paths through the code did not trigger these
problems, but they're fixed here:
- In ceph_msg_data_pagelist_cursor_init(), the cursor's
last_piece field was being checked against the length
supplied. This was OK until this commit: ccba6d98 libceph:
implement multiple data items in a message That commit changed
the cursor init routines to allow lengths to be supplied that
exceeded the size of the current data item. Because of this,
we have to use the assigned cursor resid field rather than the
provided length in determining whether the cursor points to
the last piece of a data item.
- In ceph_msg_data_add_pages(), a BUG_ON() was erroneously
catching attempts to add page data to a message if the message
already had data assigned to it. That was OK until that same
commit, at which point it was fine for messages to have
multiple data items. It slipped through because that BUG_ON()
call was present twice in that function. (You can never be too
careful.)
In addition two other minor things are changed:
- In ceph_msg_data_cursor_init(), the local variable "data" was
getting assigned twice.
- In ceph_msg_data_advance(), it was assumed that the
type-specific advance routine would set new_piece to true
after it advanced past the last piece. That may have been
fine, but since we check for that case we might as well set it
explicitly in ceph_msg_data_advance().
This resolves:
http://tracker.ceph.com/issues/4762
Change the names of the functions that put data on a pagelist to
reflect that we're adding to whatever's already there rather than
just setting it to the one thing. Currently only one data item is
ever added to a message, but that's about to change.
This resolves:
http://tracker.ceph.com/issues/2770
This patch adds support to the messenger for more than one data item
in its data list.
A message data cursor has two more fields to support this:
- a count of the number of bytes left to be consumed across
all data items in the list, "total_resid"
- a pointer to the head of the list (for validation only)
The cursor initialization routine has been split into two parts: the
outer one, which initializes the cursor for traversing the entire
list of data items; and the inner one, which initializes the cursor
to start processing a single data item.
When a message cursor is first initialized, the outer initialization
routine sets total_resid to the length provided. The data pointer
is initialized to the first data item on the list. From there, the
inner initialization routine finishes by setting up to process the
data item the cursor points to.
Advancing the cursor consumes bytes in total_resid. If the resid
field reaches zero, it means the current data item is fully
consumed. If total_resid indicates there is more data, the cursor
is advanced to point to the next data item, and then the inner
initialization routine prepares for using that. (A check is made at
this point to make sure we don't wrap around the front of the list.)
The type-specific init routines are modified so they can be given a
length that's larger than what the data item can support. The resid
field is initialized to the smaller of the provided length and the
length of the entire data item.
When total_resid reaches zero, we're done.
This resolves:
http://tracker.ceph.com/issues/3761
In place of the message data pointer, use a list head which links
through message data items. For now we only support a single entry
on that list.
Rather than having a ceph message data item point to the cursor it's
associated with, have the cursor point to a data item. This will
allow a message cursor to be used for more than one data item.
A message will only be processing a single data item at a time, so
there's no need for each data item to have its own cursor.
Move the cursor embedded in the message data structure into the
message itself. To minimize the impact, keep the data->cursor
field, but make it be a pointer to the cursor in the message.
Move the definition of ceph_msg_data above ceph_msg_data_cursor so
the cursor can point to the data without a forward definition rather
than vice-versa.
This and the upcoming patches are part of:
The bio is the only data item type that doesn't record its full
length. Fix that.
We know the length of our message buffers. If we get a message
that's too long, just dump it and ignore it. If skip was set
then con->in_msg won't be valid, so be careful not to dereference
a null pointer in the process.
This resolves:
http://tracker.ceph.com/issues/4664
This patch:
15a0d7b libceph: record message data length
did not enclose some bio-specific code inside CONFIG_BLOCK as
it should have. Fix that.
In prepare_message_data(), the length used to initialize the cursor
is taken from the header of the message provided. I'm working
toward not using the header data length field to determine length in
outbound messages, and this is a step in that direction. For
inbound messages this will be set to be the actual number of bytes
that are arriving (which may be less than the total size of the data
buffer available).
This resolves:
http://tracker.ceph.com/issues/4589
Keep track of the length of the data portion for a message in a
separate field in the ceph_msg structure. This information has
been maintained in wire byte order in the message header, but
that's going to change soon.
When a cursor for a page array data message is initialized it needs
to determine the initial value for cursor->last_piece. Currently it
just checks if length is less than a page, but that's not correct.
The data in the first page in the array will be offset by a page
offset based on the alignment recorded for the data. (All pages
thereafter will be aligned at the base of the page, so there's
no need to account for this except for the first page.)
Because this was wrong, there was a case where the length of a piece
would be calculated as all of the residual bytes in the message and
that plus the page offset could exceed the length of a page.
So fix this case. Make sure the sum won't wrap.
This resolves a third issue described in:
http://tracker.ceph.com/issues/4598
Currently ceph_msg_data_pages_advance() allows the page offset value
to be PAGE_SIZE, apparently assuming ceph_msg_data_pages_next() will
treat it as 0. But that doesn't happen, and the result led to a
helpful assertion failure.
Change ceph_msg_data_pages_advance() to truncate the offset to 0
before returning if it reaches PAGE_SIZE.
Make a few other minor adjustments in this area (comments and a
better assertion) while modifying it.
This resolves a second issue described in:
It's OK for the result of a read to come back with fewer bytes than
were requested. So don't trigger a BUG() in that case when
initializing the data cursor.
This resolves the first problem described in:
Begin the transition from a single message data item to a list of
them by replacing the "data" structure in a message with a pointer
to a ceph_msg_data structure.
A null pointer will indicate the message has no data; replace the
use of ceph_msg_has_data() with a simple check for a null pointer.
Create functions ceph_msg_data_create() and ceph_msg_data_destroy()
to dynamically allocate and free a data item structure of a given type.
When a message has its data item "set," allocate one of these to
hold the data description, and free it when the last reference to
the message is dropped.
This partially resolves:
http://tracker.ceph.com/issues/4429
The *_msg_pos_next() functions do little more than call
ceph_msg_data_advance(). Replace those wrapper functions with
a simple call to ceph_msg_data_advance().
This cleanup is related to:
http://tracker.ceph.com/issues/4428
In write_partial_message_data() we aggregate the crc for the data
portion of the message as each new piece of the data item is
encountered. Because it was computed *before* sending the data, if
an attempt to send a new piece resulted in 0 bytes being sent, the
crc crc across that piece would erroneously get computed again and
added to the aggregate result. This would occasionally happen in
the evnet of a connection failure.
The crc value isn't really needed until the complete value is known
after sending all data, so there's no need to compute it before
sending.
So don't calculate the crc for a piece until *after* we know at
least one byte of it has been sent. That will avoid this problem.
This resolves:
http://tracker.ceph.com/issues/4450
The only remaining field in the ceph_msg_pos structure is
did_page_crc. In the new cursor model of things that flag (or
something like it) belongs in the cursor.
Define a new field "need_crc" in the cursor (which applies to all
types of data) and initialize it to true whenever a cursor is
initialized.
In write_partial_message_data(), the data CRC still will be computed
as before, but it will check the cursor->need_crc field to determine
whether it's needed. Any time the cursor is advanced to a new piece
of a data item, need_crc will be set, and this will cause the crc
for that entire piece to be accumulated into the data crc.
In write_partial_message_data() the intermediate crc value is now
held in a local variable so it doesn't have to be byte-swapped so
many times. In read_partial_msg_data() we do something similar
(but mainly for consistency there).
With that, the ceph_msg_pos structure can go away, and it no longer
needs to be passed as an argument to prepare_message_data().
All but one of the fields in the ceph_msg_pos structure are now
never used (only assigned), so get rid of them. This allows
several small blocks of code to go away.
This is cleanup of old code related to:
Use the "resid" field of a cursor rather than finding when the
message data position has moved up to meet the data length to
determine when all data has been sent or received in
write_partial_message_data() and read_partial_msg_data().
It turns out that only one of the data item types is ever used at
any one time in a single message (currently).
- A page array is used by the osd client (on behalf of the file
system) and by rbd. Only one osd op (and therefore at most
one data item) is ever used at a time by rbd. And the only
time the file system sends two, the second op contains no
data.
- A bio is only used by the rbd client (and again, only one
data item per message)
- A page list is used by the file system and by rbd for outgoing
data, but only one op (and one data item) at a time.
We can therefore collapse all three of our data item fields into a
single field "data", and depend on the messenger code to properly
handle it based on its type.
This allows us to eliminate quite a bit of duplicated code.
This is related to:
Now that read_partial_message_pages() and read_partial_message_bio()
are literally identical functions we can factor them out. They're
pretty simple as well, so just move their relevant content into
This is and previous patches together resolve:
There is handling in write_partial_message_data() for the case where
only the length of--and no other information about--the data to be
sent has been specified. It uses the zero page as the source of
data to send in this case.
This case doesn't occur. All message senders set up a page array,
pagelist, or bio describing the data to be sent. So eliminate the
block of code that handles this (but check and issue a warning for
now, just in case it happens for some reason).
This resolves:
http://tracker.ceph.com/issues/4426
The cursor code for a page array selects the right page, page
offset, and length to use for a ceph_tcp_recvpage() call, so
we can use it to replace a block in read_partial_message_pages().
The bio_iter and bio_seg fields in a message are no longer used, we
use the cursor instead. So get rid of them and the functions that
operate on them them.
This is related to:
Replace the use of the information in con->in_msg_pos for incoming
bio data. The old in_msg_pos and the new cursor mechanism do
basically the same thing, just slightly differently.
The main functional difference is that in_msg_pos keeps track of the
length of the complete bio list, and assumed it was fully consumed
when that many bytes had been transferred. The cursor does not assume
a length, it simply consumes all bytes in the bio list. Because the
only user of bio data is the rbd client, and because the length of a
bio list provided by rbd client always matches the number of bytes
in the list, both ways of tracking length are equivalent.
In addition, for in_msg_pos the initial bio vector is selected as
the initial value of the bio->bi_idx, while the cursor assumes this
is zero. Again, the rbd client always passes 0 as the initial index
so the effect is the same.
Other than that, they basically match:
in_msg_pos cursor
bio_iter bio
bio_seg vec_index
page_pos page_offset
The in_msg_pos field is initialized by a call to init_bio_iter().
The bio cursor is initialized by ceph_msg_data_cursor_init().
Both now happen in the same spot, in prepare_message_data().
The in_msg_pos field is advanced by a call to in_msg_pos_next(),
which updates page_pos and calls iter_bio_next() to move to the next
bio vector, or to the next bio in the list. The cursor is advanced
by ceph_msg_data_advance(). That isn't currently happening so
add a call to that in in_msg_pos_next().
Finally, the next piece of data to use for a read is determined
by a bunch of lines in read_partial_message_bio(). Those can be
replaced by an equivalent ceph_msg_data_bio_next() call.
