Signed-off-by: Yan, Zheng <zyan@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
- return -ETIMEDOUT instead of -EIO in case of timeout
- wait_event_interruptible_timeout() returns time left until timeout
and since it can be almost LONG_MAX we had better assign it to long
Reviewed-by: Alex Elder <elder@linaro.org>
There are currently three libceph-level timeouts that the user can
specify on mount: mount_timeout, osd_idle_ttl and osdkeepalive. All of
these are in seconds and no checking is done on user input: negative
values are accepted, we multiply them all by HZ which may or may not
overflow, arbitrarily large jiffies then get added together, etc.
There is also a bug in the way mount_timeout=0 is handled. It's
supposed to mean "infinite timeout", but that's not how wait.h APIs
treat it and so __ceph_open_session() for example will busy loop
without much chance of being interrupted if none of ceph-mons are
there.
Fix all this by verifying user input, storing timeouts capped by
msecs_to_jiffies() in jiffies and using the new ceph_timeout_jiffies()
helper for all user-specified waits to handle infinite timeouts
correctly.
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
On Mon, Dec 22, 2014 at 5:35 PM, Sage Weil <sage@newdream.net> wrote:
> On Mon, 22 Dec 2014, Ilya Dryomov wrote:
>> Actually, pool op stuff has been unused for over two years - looks like
>> it was added for rbd create_snap and that got ripped out in 2012. It's
>> unlikely we'd ever need to manage pools or snaps from the kernel client
>> so I think it makes sense to nuke it. Sage?
> Yep!
The only real issue is the one in auth_x.c and it came with
3.19-rc1 merge.
Use the more common pr_warn.
Other miscellanea:
o Coalesce formats
o Realign arguments
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
We preallocate a few of the message types we get back from the mon. If we
get a larger message than we are expecting, fall back to trying to allocate
a new one instead of blindly using the one we have.
CC: stable@vger.kernel.org
Signed-off-by: Sage Weil <sage@redhat.com>
Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Add ceph_monc_wait_osdmap(), which will block until the osdmap with the
specified epoch is received or timeout occurs.
Export both of these as they are going to be needed by rbd.
Reviewed-by: Sage Weil <sage@inktank.com>
Add support for mon_get_version requests to libceph. This reuses much
of the ceph_mon_generic_request infrastructure, with one exception.
Older OSDs don't set mon_get_version reply hdr->tid even if the
original request had a non-zero tid, which makes it impossible to
lookup ceph_mon_generic_request contexts by tid in get_generic_reply()
for such replies. As a workaround, we allocate a reply message on the
reply path. This can probably interfere with revoke, but I don't see
a better way.
Rename front_max field of struct ceph_msg to front_alloc_len to make
its purpose more clear.
Use wrapper functions that check whether the auth op exists so that callers
do not need a bunch of conditional checks. Simplifies the external
interface.
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
Eliminate most of the problems in the libceph code that cause sparse
to issue warnings.
- Convert functions that are never referenced externally to have
static scope.
- Pass NULL rather than 0 for a pointer argument in one spot in
ceph_monc_delete_snapid()
This partially resolves:
http://tracker.ceph.com/issues/4184
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Alex Elder <elder@inktank.com>
Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
Make ceph_monc_do_poolop() static to remove the following sparse warning:
* net/ceph/mon_client.c:616:5: warning: symbol 'ceph_monc_do_poolop' was not
declared. Should it be static?
Also drops the 'ceph_monc_' prefix, now being a private function.
Signed-off-by: Iulius Curt <icurt@ixiacom.com>
This is unused; use monc->client->have_fsid.
The debugfs directory includes the cluster fsid and our unique global_id.
We need to delay the initialization of the debug entry until we have
learned both the fsid and our global_id from the monitor or else the
second client can't create its debugfs entry and will fail (and multiple
client instances aren't properly reflected in debugfs).
Reported by: Yan, Zheng <zheng.z.yan@intel.com>
Reviewed-by: Yehuda Sadeh <yehuda@inktank.com>
Revoke all mon_client messages when we shut down the old connection.
This is mostly moot since we are re-using the same ceph_connection,
but it is cleaner.
Do not re-initialize the con on every connection attempt. When we
ceph_con_close, there may still be work queued on the socket (e.g., to
close it), and re-initializing will clobber the work_struct state.
The peer name may change on each open attempt, even when the connection is
reused.
Linux 3.5-rc1
net/ceph/messenger.c
We need to flush the msgr workqueue during mon_client shutdown to
ensure that any work affecting our embedded ceph_connection is
finished so that we can be safely destroyed.
Previously, we were flushing the work queue after osd_client
shutdown and before mon_client shutdown to ensure that any osd
connection refs to authorizers are flushed. Remove the redundant
flush, and document in the comment that the mon_client flush is
needed to cover that case as well.
ceph_con_revoke() is passed both a message and a ceph connection.
Now that any message associated with a connection holds a pointer
to that connection, there's no need to provide the connection when
revoking a message.
This has the added benefit of precluding the possibility of the
providing the wrong connection pointer. If the message's connection
pointer is null, it is not being tracked by any connection, so
revoking it is a no-op. This is supported as a convenience for
upper layers, so they can revoke a message that is not actually
"in flight."
Rename the function ceph_msg_revoke() to reflect that it is really
an operation on a message, not a connection.
The function ceph_alloc_msg() is only used to allocate a message
that will be assigned to a connection's in_msg pointer. Rename the
function so this implied usage is more clear.
In addition, make that assignment inside the function (again, since
that's precisely what it's intended to be used for). This allows us
to return what is now provided via the passed-in address of a "skip"
variable. The return type is now Boolean to be explicit that there
are only two possible outcomes.
Make sure the result of an ->alloc_msg method call always sets the
value of *skip properly.
Move the initialization of a ceph connection's private pointer,
operations vector pointer, and peer name information into
ceph_con_init(). Rearrange the arguments so the connection pointer
is first. Hide the byte-swapping of the peer entity number inside
ceph_con_init()
Hold off initializing a monitor client's connection until just
before it gets opened for use.
All references to the embedded ceph_connection come from the msgr
workqueue, which is drained prior to mon_client destruction. That
means we can ignore con refcounting entirely.
Signed-off-by: Sage Weil <sage@newdream.net>
A monitor client has a pointer to a ceph connection structure in it.
This is the only one of the three ceph client types that do it this
way; the OSD and MDS clients embed the connection into their main
structures. There is always exactly one ceph connection for a
monitor client, so there is no need to allocate it separate from the
monitor client structure.
So switch the ceph_mon_client structure to embed its
ceph_connection structure.
A ceph client has a pointer to a ceph messenger structure in it.
There is always exactly one ceph messenger for a ceph client, so
there is no need to allocate it separate from the ceph client
structure.
Switch the ceph_client structure to embed its ceph_messenger
structure.
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Initializing debufs under monc->mutex introduces a lock dependency for
sb->s_type->i_mutex_key, which (combined with several other dependencies)
leads to an annoying lockdep warning. There's no particular reason to do
the debugfs setup under this lock, so move it out.
It used to be the case that our first monmap could come from the OSD; that
is no longer the case with recent servers, so we will reliably set up the
client entry during the initial authentication.
We don't have to worry about racing with debugfs teardown by
ceph_debugfs_client_cleanup() because ceph_destroy_client() calls
ceph_msgr_flush() first, which will wait for the message dispatch work
to complete (and the debugfs init to complete).
Fixes: #1940
failure clean up does not consider ceph_auth_init.
Signed-off-by: Noah Watkins <noahwatkins@gmail.com>
The pool allocation failures are masked by the pool; there is no need to
spam the console about them. (That's the whole point of having the pool
in the first place.)
Mark msg allocations whose failure is safely handled as such.
Allocate the mon connection on init. We already reuse it across
reconnects. Remove now unnecessary (and incomplete) NULL checks.
This makes the base64 logic be contained in mount option parsing,
and prepares us for replacing the homebew key management with the
kernel key retention service.
Signed-off-by: Tommi Virtanen <tommi.virtanen@dreamhost.com>
This factors out protocol and low-level storage parts of ceph into a
separate libceph module living in net/ceph and include/linux/ceph. This
is mostly a matter of moving files around. However, a few key pieces
of the interface change as well:
- ceph_client becomes ceph_fs_client and ceph_client, where the latter
captures the mon and osd clients, and the fs_client gets the mds client
and file system specific pieces.
- Mount option parsing and debugfs setup is correspondingly broken into
two pieces.
- The mon client gets a generic handler callback for otherwise unknown
messages (mds map, in this case).
- The basic supported/required feature bits can be expanded (and are by
ceph_fs_client).
No functional change, aside from some subtle error handling cases that got
cleaned up in the refactoring process.
