path: root/net/ceph/msgpool.c
2011-08-09libceph: fix msgpoolSage Weil
There were several problems here: 1- we weren't tagging allocations with the pool, so they were never returned to the pool. 2- msgpool_put didn't add back to the mempool, even it were called. 3- msgpool_release didn't clear the pool pointer, so it would have looped had #1 not been broken. These may or may not have been responsible for #1136 or #1381 (BUG due to non-empty mempool on umount). I can't seem to trigger the crash now using the method I was using before. Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
