commit 130f52f2b203aa0aec179341916ffb2e905f3afd upstream.
Avoid scribbling over memory if the received reply/challenge is larger
than the buffer supplied with the authorizer.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Sage Weil <sage@redhat.com>
commit f1d10e04637924f2b00a0fecdd2ca4565f5cfc3f upstream.
Allow for extending ceph_x_authorize_reply in the future.
commit cc255c76c70f7a87d97939621eae04b600d9f4a1 upstream.
Derive the signature from the entire buffer (both AES cipher blocks)
instead of using just the first half of the first block, leaving out
data_crc entirely.
This addresses CVE-2018-1129.
Link: http://tracker.ceph.com/issues/24837
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 6daca13d2e72bedaaacfc08f873114c9307d5aea upstream.
When a client authenticates with a service, an authorizer is sent with
a nonce to the service (ceph_x_authorize_[ab]) and the service responds
with a mutation of that nonce (ceph_x_authorize_reply). This lets the
client verify the service is who it says it is but it doesn't protect
against a replay: someone can trivially capture the exchange and reuse
the same authorizer to authenticate themselves.
Allow the service to reject an initial authorizer with a random
challenge (ceph_x_authorize_challenge). The client then has to respond
with an updated authorizer proving they are able to decrypt the
service's challenge and that the new authorizer was produced for this
specific connection instance.
The accepting side requires this challenge and response unconditionally
if the client side advertises they have CEPHX_V2 feature bit.
This addresses CVE-2018-1128.
Link: http://tracker.ceph.com/issues/24836
commit 149cac4a50b0b4081b38b2f38de6ef71c27eaa85 upstream.
Will be used for encrypting both the initial and updated authorizers.
commit c571fe24d243bfe7017f0e67fe800b3cc2a1d1f7 upstream.
Will be used for decrypting the server challenge which is only preceded
by ceph_x_encrypt_header.
Drop struct_v check to allow for extending ceph_x_encrypt_header in the
future.
commit c0f56b483aa09c99bfe97409a43ad786f33b8a5a upstream.
Will be used for sending ceph_msg_connect with an updated authorizer,
after the server challenges the initial authorizer.
commit 262614c4294d33b1f19e0d18c0091d9c329b544a upstream.
We already copy authorizer_reply_buf and authorizer_reply_buf_len into
ceph_connection. Factoring out __prepare_write_connect() requires two
more: authorizer_buf and authorizer_buf_len. Store the pointer to the
handshake in con->auth rather than piling on.
commit 7e241f647dc7087a0401418a187f3f5b527cc690 upstream.
skb_can_coalesce() allows coalescing neighboring slab objects into
a single frag:
return page == skb_frag_page(frag) &&
off == frag->page_offset + skb_frag_size(frag);
ceph_tcp_sendpage() can be handed slab pages. One example of this is
XFS: it passes down sector sized slab objects for its metadata I/O. If
the kernel client is co-located on the OSD node, the skb may go through
loopback and pop on the receive side with the exact same set of frags.
When tcp_recvmsg() attempts to copy out such a frag, hardened usercopy
complains because the size exceeds the object's allocated size:
usercopy: kernel memory exposure attempt detected from ffff9ba917f20a00 (kmalloc-512) (1024 bytes)
Although skb_can_coalesce() could be taught to return false if the
resulting frag would cross a slab object boundary, we already have
a fallback for non-refcounted pages. Utilize it for slab pages too.
Cc: stable@vger.kernel.org # 4.8+
[ Upstream commit 937441f3a3158d5510ca8cc78a82453f57a96365 ]
When parsing string option, in order to avoid memory leak we need to
carefully free it first in case of specifying same option several times.
Signed-off-by: Chengguang Xu <cgxu519@icloud.com>
Reviewed-by: Ilya Dryomov <idryomov@gmail.com>
commit 9c55ad1c214d9f8c4594ac2c3fa392c1c32431a7 upstream.
ceph_con_workfn() validates con->state before calling try_read() and
then try_write(). However, try_read() temporarily releases con->mutex,
notably in process_message() and ceph_con_in_msg_alloc(), opening the
window for ceph_con_close() to sneak in, close the connection and
release con->sock. When try_write() is called on the assumption that
con->state is still valid (i.e. not STANDBY or CLOSED), a NULL sock
gets passed to the networking stack:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: selinux_socket_sendmsg+0x5/0x20
Make sure con->state is valid at the top of try_write() and add an
explicit BUG_ON for this, similar to try_read().
Link: https://tracker.ceph.com/issues/23706
Reviewed-by: Jason Dillaman <dillaman@redhat.com>
commit 7b4c443d139f1d2b5570da475f7a9cbcef86740c upstream.
If we go without an established session for a while, backoff delay will
climb to 30 seconds. The keepalive timeout is also 30 seconds, so it's
pretty easily hit after a prolonged hunting for a monitor: we don't get
a chance to send out a keepalive in time, which means we never get back
a keepalive ack in time, cutting an established session and attempting
to connect to a different monitor every 30 seconds:
[Sun Apr 1 23:37:05 2018] libceph: mon0 10.80.20.99:6789 session established
[Sun Apr 1 23:37:36 2018] libceph: mon0 10.80.20.99:6789 session lost, hunting for new mon
[Sun Apr 1 23:37:36 2018] libceph: mon2 10.80.20.103:6789 session established
[Sun Apr 1 23:38:07 2018] libceph: mon2 10.80.20.103:6789 session lost, hunting for new mon
[Sun Apr 1 23:38:07 2018] libceph: mon1 10.80.20.100:6789 session established
[Sun Apr 1 23:38:37 2018] libceph: mon1 10.80.20.100:6789 session lost, hunting for new mon
[Sun Apr 1 23:38:37 2018] libceph: mon2 10.80.20.103:6789 session established
[Sun Apr 1 23:39:08 2018] libceph: mon2 10.80.20.103:6789 session lost, hunting for new mon
The regular keepalive interval is 10 seconds. After ->hunting is
cleared in finish_hunting(), call __schedule_delayed() to ensure we
send out a keepalive after 10 seconds.
Cc: stable@vger.kernel.org # 4.7+
Link: http://tracker.ceph.com/issues/23537
commit facb9f6eba3df4e8027301cc0e514dc582a1b366 upstream.
This means that if we do some backoff, then authenticate, and are
healthy for an extended period of time, a subsequent failure won't
leave us starting our hunting sequence with a large backoff.
Mirrors ceph.git commit d466bc6e66abba9b464b0b69687cf45c9dccf383.
commit b11270853fa3654f08d4a6a03b23ddb220512d8d upstream.
The WARN_ON(!key->len) in set_secret() in net/ceph/crypto.c is hit if a
user tries to add a key of type "ceph" with an invalid payload as
follows (assuming CONFIG_CEPH_LIB=y):
echo -e -n '\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' \
| keyctl padd ceph desc @s
This can be hit by fuzzers. As this is merely bad input and not a
kernel bug, replace the WARN_ON() with return -EINVAL.
Fixes: 7af3ea189a9a ("libceph: stop allocating a new cipher on every crypto request")
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This reverts most of commit f53b7665c8ce ("libceph: upmap semantic
changes").
We need to prevent duplicates in the final result. For example, we
can currently take
[1,2,3] and apply [(1,2)] and get [2,2,3]
or
[1,2,3] and apply [(3,2)] and get [1,2,2]
The rest of the system is not prepared to handle duplicates in the
result set like this.
The reverted piece was intended to allow
[1,2,3] and [(1,2),(2,1)] to get [2,1,3]
to reorder primaries. First, this bidirectional swap is hard to
implement in a way that also prevents dups. For example, [1,2,3] and
[(1,4),(2,3),(3,4)] would give [4,3,4] but would we just drop the last
step we'd have [4,3,3] which is also invalid, etc. Simpler to just not
handle bidirectional swaps. In practice, they are not needed: if you
just want to choose a different primary then use primary_affinity, or
pg_upmap (not pg_upmap_items).
Cc: stable@vger.kernel.org # 4.13
Link: http://tracker.ceph.com/issues/21410
Improve accuracy of statfs reporting for Ceph filesystems comprising
exactly one data pool. In this case, the Ceph monitor can now report
the space usage for the single data pool instead of the global data
for the entire Ceph cluster. Include support for this message in
mon_client and leverage it in ceph/super.
Signed-off-by: Douglas Fuller <dfuller@redhat.com>
Reviewed-by: Yan, Zheng <zyan@redhat.com>
startsync is a no-op, has been for years. Remove it.
Link: http://tracker.ceph.com/issues/20604
Signed-off-by: Yanhu Cao <gmayyyha@gmail.com>
Reviewed-by: "Yan, Zheng" <zyan@redhat.com>
This is needed so that the OSDs can regenerate the missing set at the
start of a new interval where support for recovery deletes changed.
- apply both pg_upmap and pg_upmap_items
- allow bidirectional swap of pg-upmap-items
Reflects ceph.git commit 5e8fa3e06b68fae1582c9230a3a8d1abc6146286.
There is now a fallback to a choose_arg index of -1 if there isn't
a pool-specific choose_arg set. If you create a per-pool weight-set,
that works for that pool. Otherwise we try the compat/default one. If
that doesn't exist either, then we use the normal CRUSH weights.
Reencoding an already reencoded message is a bad idea. This could
happen on Policy::stateful_server connections (!CEPH_MSG_CONNECT_LOSSY),
such as MDS sessions.
This didn't pop up in testing because currently only OSD requests are
reencoded and OSD sessions are always lossy.
Fixes: 98ad5ebd1505 ("libceph: ceph_connection_operations::reencode_message() method")
Messages allocated out of ceph_msgpool have a fixed front length
(pool->front_len). Asserting that the entire front has been filled
while encoding is thus wrong.
Fixes: 8cb441c0545d ("libceph: MOSDOp v8 encoding (actual spgid + full hash)")
Reported-by: "Yan, Zheng" <zyan@redhat.com>
If kmem_cache_zalloc() returns NULL then the INIT_LIST_HEAD(&data->links);
will Oops. The callers aren't really prepared for NULL returns so it
doesn't make a lot of difference in real life.
Fixes: 5240d9f95dfe ("libceph: replace message data pointer with list")
encode_request_finish() is for MOSDOp messages. Calling it on
MOSDBackoff ack-block messages corrupts them.
Fixes: a02a946dfe96 ("libceph: respect RADOS_BACKOFF backoffs")
... otherwise we die in insert_pg_mapping(), which wants pg->node to be
empty, i.e. initialized with RB_CLEAR_NODE.
Fixes: 6f428df47dae ("libceph: pg_upmap[_items] infrastructure")
No sooner than Dan had fixed this issue in commit 293dffaad8d5
("libceph: NULL deref on crush_decode() error path"), I brought it
back. Add a new label and set -EINVAL once, right before failing.
Fixes: 278b1d709c6a ("libceph: ceph_decode_skip_* helpers")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
There are hidden gotos in the ceph_decode_* macros. We need to set the
"err" variable on these error paths otherwise we end up returning
ERR_PTR(0) which is NULL. It causes NULL dereferences in the callers.
[idryomov@gmail.com: similar bug in osdmap_decode(), changelog tweak]
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull random updates from Ted Ts'o:
"Add wait_for_random_bytes() and get_random_*_wait() functions so that
callers can more safely get random bytes if they can block until the
CRNG is initialized.
Also print a warning if get_random_*() is called before the CRNG is
initialized. By default, only one single-line warning will be printed
per boot. If CONFIG_WARN_ALL_UNSEEDED_RANDOM is defined, then a
warning will be printed for each function which tries to get random
bytes before the CRNG is initialized. This can get spammy for certain
architecture types, so it is not enabled by default"
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
random: reorder READ_ONCE() in get_random_uXX
random: suppress spammy warnings about unseeded randomness
random: warn when kernel uses unseeded randomness
net/route: use get_random_int for random counter
net/neighbor: use get_random_u32 for 32-bit hash random
rhashtable: use get_random_u32 for hash_rnd
ceph: ensure RNG is seeded before using
iscsi: ensure RNG is seeded before use
cifs: use get_random_u32 for 32-bit lock random
random: add get_random_{bytes,u32,u64,int,long,once}_wait family
random: add wait_for_random_bytes() API
Reflects ceph.git commit dca1ae1e0a6b02029c3a7f9dec4114972be26d50.
It is not just a pointer to crush_work, it is the whole structure.
That is not a problem since it only contains a pointer. But it will
be a problem if new data members are added to crush_work.
Reflects ceph.git commit ee957dd431bfbeb6dadaf77764db8e0757417328.
If there is no crush_choose_arg_map for a given pool, a NULL pointer is
passed to preserve existing crush_do_rule() behavior.
Reflects ceph.git commits 55fb91d64071552ea1bc65ab4ea84d3c8b73ab4b,
dbe36e08be00c6519a8c89718dd47b0219c20516.
bucket_straw2_choose needs to use weights that may be different from
weight_items. For instance to compensate for an uneven distribution
caused by a low number of values. Or to fix the probability biais
introduced by conditional probabilities (see
http://tracker.ceph.com/issues/15653 for more information).
We introduce a weight_set for each straw2 bucket to set the desired
weight for a given item at a given position. The weight of a given item
when picking the first replica (first position) may be different from
the weight the second replica (second position). For instance the weight
matrix for a given bucket containing items 3, 7 and 13 could be as
follows:
position 0 position 1
item 3 0x10000 0x100000
item 7 0x40000 0x10000
item 13 0x40000 0x10000
When crush_do_rule picks the first of two replicas (position 0), item 7,
3 are four times more likely to be choosen by bucket_straw2_choose than
item 13. When choosing the second replica (position 1), item 3 is ten
times more likely to be choosen than item 7, 13.
By default the weight_set of each bucket exactly matches the content of
item_weights for each position to ensure backward compatibility.
bucket_straw2_choose compares items by using their id. The same ids are
also used to index buckets and they must be unique. For each item in a
bucket an array of ids can be provided for placement purposes and they
are used instead of the ids. If no replacement ids are provided, the
legacy behavior is preserved.
Reflects ceph.git commit 19537a450fd5c5a0bb8b7830947507a76db2ceca.
Previously, pg_to_raw_osds() didn't filter for existent OSDs because
raw_to_up_osds() would filter for "up" ("up" is predicated on "exists")
and raw_to_up_osds() was called directly after pg_to_raw_osds(). Now,
with apply_upmap() call in there, nonexistent OSDs in pg_to_raw_osds()
output can affect apply_upmap(). Introduce remove_nonexistent_osds()
to deal with that.
Move raw_pg_to_pg() call out of get_temp_osds() and into
ceph_pg_to_up_acting_osds(), for upcoming apply_upmap().
pg_temp and pg_upmap encodings are the same (PG -> array of osds),
except for the incremental remove: it's an empty mapping in new_pg_temp
for pg_temp and a separate old_pg_upmap set for pg_upmap. (This isn't
to allow for empty pg_upmap mappings -- apparently, pg_temp just wasn't
looked at as an example for pg_upmap encoding.)
Reuse __decode_pg_temp() for decoding pg_upmap and new_pg_upmap.
__decode_pg_temp() stores into pg_temp union member, but since pg_upmap
union member is identical, reading through pg_upmap later is OK.
Some of these won't be as efficient as they could be (e.g.
ceph_decode_skip_set(... 32 ...) could advance by len * sizeof(u32)
once instead of advancing by sizeof(u32) len times), but that's fine
and not worth a bunch of extra macro code.
Replace skip_name_map() with ceph_decode_skip_map as an example.
Switch to DEFINE_RB_FUNCS2-generated {insert,lookup,erase}_pg_mapping().
Make __{lookup,remove}_pg_mapping() look like their ceph_spg_mapping
counterparts: take const struct ceph_pg *.
For luminous and beyond we are encoding the actual spgid, which
requires operating with the correct pg_num, i.e. that of the target
pool.
need_check_tiering logic doesn't make a whole lot of sense. Drop it
and apply tiering unconditionally on every calc_target() call instead.
Otherwise we may miss events like PG splits, pool deletions, etc when
we get multiple incremental maps at once. Because check_pool_dne() can
now be fed an unlinked request, finish_request() needed to be taught to
handle unlinked requests.
When processing a map update consisting of multiple incrementals, we
may end up running check_linger_pool_dne() on a lingering request that
was previously added to need_resend_linger list. If it is concluded
that the target pool doesn't exist, the request is killed off while
still on need_resend_linger list, which leads to a crash on a NULL
lreq->osd in kick_requests():
libceph: linger_id 18446462598732840961 pool does not exist
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: ceph_osdc_handle_map+0x4ae/0x870
Note that ceph_osd_request_target fields are updated regardless of
RESEND_ON_SPLIT.
Replace it with more fine-grained bools to separate updating
ceph_osd_request_target fields and the decision to resend.
