[ Upstream commit: 9d410c796067686b1e032d54ce475b7055537138 ]
On UDP sockets, we must call skb_free_datagram() with socket locked,
or risk sk_forward_alloc corruption. This requirement is not respected
in SUNRPC.
Add a convenient helper, skb_free_datagram_locked() and use it in SUNRPC
Reported-by: Francis Moreau <francis.moro@gmail.com>
Adding memory barrier after the poll_wait function, paired with
receive callbacks. Adding fuctions sock_poll_wait and sk_has_sleeper
to wrap the memory barrier.
Without the memory barrier, following race can happen.
The race fires, when following code paths meet, and the tp->rcv_nxt
and __add_wait_queue updates stay in CPU caches.
CPU1 CPU2
sys_select receive packet
__add_wait_queue update tp->rcv_nxt
tp->rcv_nxt check sock_def_readable
schedule ...
if (sk->sk_sleep && waitqueue_active(sk->sk_sleep))
wake_up_interruptible(sk->sk_sleep)
If there was no cache the code would work ok, since the wait_queue and
rcv_nxt are opposit to each other.
Meaning that once tp->rcv_nxt is updated by CPU2, the CPU1 either already
passed the tp->rcv_nxt check and sleeps, or will get the new value for
tp->rcv_nxt and will return with new data mask.
In both cases the process (CPU1) is being added to the wait queue, so the
waitqueue_active (CPU2) call cannot miss and will wake up CPU1.
The bad case is when the __add_wait_queue changes done by CPU1 stay in its
cache, and so does the tp->rcv_nxt update on CPU2 side. The CPU1 will then
endup calling schedule and sleep forever if there are no more data on the
socket.
Calls to poll_wait in following modules were ommited:
net/bluetooth/af_bluetooth.c
net/irda/af_irda.c
net/irda/irnet/irnet_ppp.c
net/mac80211/rc80211_pid_debugfs.c
net/phonet/socket.c
net/rds/af_rds.c
net/rfkill/core.c
net/sunrpc/cache.c
net/sunrpc/rpc_pipe.c
net/tipc/socket.c
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
I am working on enabling UFO between KVM guests using virtio-net and i have
some patches that i got working with 2.6.30-rc8. When i wanted to try them
with net-next-2.6, i noticed that virtio-net is not working with that tree.
After some debugging, it turned out to be several bugs in the recent patches
to fix aio with tun driver, specifically the following 2 commits.
http://git.kernel.org/?p=linux/kernel/git/davem/net-next-2.6.git;a=commitdiff;h=0a1ec07a67bd8b0033dace237249654d015efa21
http://git.kernel.org/?p=linux/kernel/git/davem/net-next-2.6.git;a=commitdiff;h=6f26c9a7555e5bcca3560919db9b852015077dae
Fix the call to memcpy_from_iovecend() in skb_copy_datagram_from_iovec
to pass the right iovec offset.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Commit ead2ceb0ec9f85cff19c43b5cdb2f8a054484431 ("Network Drop Monitor:
Adding kfree_skb_clean for non-drops and modifying end-of-line points
for skbs") established new conventions for identifying dropped packets.
Align skb_kill_datagram() with these conventions so that packets that
get dropped just before the copy to userspace are properly tracked.
Signed-off-by: John Dykstra <john.dykstra1@gmail.com>
Documentation/isdn/00-INDEX
drivers/net/wireless/iwlwifi/iwl-scan.c
drivers/net/wireless/rndis_wlan.c
net/mac80211/main.c
In 2.6.25 we added UDP mem accounting.
This unfortunatly added a penalty when a frame is transmitted, since
we have at TX completion time to call sock_wfree() to perform necessary
memory accounting. This calls sock_def_write_space() and utimately
scheduler if any thread is waiting on the socket.
Thread(s) waiting for an incoming frame was scheduled, then had to sleep
again as event was meaningless.
(All threads waiting on a socket are using same sk_sleep anchor)
This adds lot of extra wakeups and increases latencies, as noted
by Christoph Lameter, and slows down softirq handler.
Reference : http://marc.info/?l=linux-netdev&m=124060437012283&w=2
Fortunatly, Davide Libenzi recently added concept of keyed wakeups
into kernel, and particularly for sockets (see commit
37e5540b3c9d838eb20f2ca8ea2eb8072271e403
epoll keyed wakeups: make sockets use keyed wakeups)
Davide goal was to optimize epoll, but this new wakeup infrastructure
can help non epoll users as well, if they care to setup an appropriate
handler.
This patch introduces new DEFINE_WAIT_FUNC() helper and uses it
in wait_for_packet(), so that only relevant event can wakeup a thread
blocked in this function.
Trace of function calls from bnx2 TX completion bnx2_poll_work() is :
__kfree_skb()
skb_release_head_state()
sock_wfree()
__wake_up_sync_key()
__wake_up_common()
receiver_wake_function() : Stops here since thread is waiting for an INPUT
Reported-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
aio_write gets const struct iovec * but tun_chr_aio_write casts this to struct
iovec * and modifies the iovec. As a result, attempts to use io_submit
to send packets to a tun device fail with weird errors such as EINVAL.
Since tun is the only user of skb_copy_datagram_from_iovec, we can
fix this simply by changing the later so that it does not
touch the iovec passed to it.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
There's an skb_copy_datagram_iovec() to copy out of a paged skb,
but it modifies the iovec, and does not support starting
at an offset in the destination. We want both in tun.c, so let's
add the function.
It's a carbon copy of skb_copy_datagram_iovec() with enough changes to
be annoying.
end-of-line points for skbs
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
include/linux/skbuff.h | 4 +++-
net/core/datagram.c | 2 +-
net/core/skbuff.c | 22 ++++++++++++++++++++++
net/ipv4/arp.c | 2 +-
net/ipv4/udp.c | 2 +-
net/packet/af_packet.c | 2 +-
6 files changed, 29 insertions(+), 5 deletions(-)
I noticed a contention on udp_memory_allocated on regular UDP applications.
While tcp_memory_allocated is seldom used, it appears each incoming UDP frame
is currently touching udp_memory_allocated when queued, and when received by
application.
One possible solution is to use sk_mem_reclaim_partial() instead of
sk_mem_reclaim(), so that we keep a small reserve (less than one page)
of memory for each UDP socket.
We did something very similar on TCP side in commit
9993e7d313e80bdc005d09c7def91903e0068f07
([TCP]: Do not purge sk_forward_alloc entirely in tcp_delack_timer())
A more complex solution would need to convert prot->memory_allocated to
use a percpu_counter with batches of 64 or 128 pages.
Clean up the various different email addresses of mine listed in the code
to a single current and valid address. As Dave says his network merges
for 2.6.28 are now done this seems a good point to send them in where
they won't risk disrupting real changes.
Signed-off-by: Alan Cox <alan@redhat.com>
There's an skb_copy_datagram_iovec() to copy out of a paged skb, but
nothing the other way around (because we don't do that).
We want to allocate big skbs in tun.c, so let's add the function.
be annoying.
Removes legacy reinvent-the-wheel type thing. The generic
machinery integrates much better to automated debugging aids
such as kerneloops.org (and others), and is unambiguous due to
better naming. Non-intuively BUG_TRAP() is actually equal to
WARN_ON() rather than BUG_ON() though some might actually be
promoted to BUG_ON() but I left that to future.
I could make at least one BUILD_BUG_ON conversion.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
This patch introduces new memory accounting functions for each network
protocol. Most of them are renamed from memory accounting functions
for stream protocols. At the same time, some stream memory accounting
functions are removed since other functions do same thing.
Renaming:
sk_stream_free_skb() -> sk_wmem_free_skb()
__sk_stream_mem_reclaim() -> __sk_mem_reclaim()
sk_stream_mem_reclaim() -> sk_mem_reclaim()
sk_stream_mem_schedule -> __sk_mem_schedule()
sk_stream_pages() -> sk_mem_pages()
sk_stream_rmem_schedule() -> sk_rmem_schedule()
sk_stream_wmem_schedule() -> sk_wmem_schedule()
sk_charge_skb() -> sk_mem_charge()
Removeing
sk_stream_rfree(): consolidates into sock_rfree()
sk_stream_set_owner_r(): consolidates into skb_set_owner_r()
sk_stream_mem_schedule()
The following functions are added.
sk_has_account(): check if the protocol supports accounting
sk_mem_uncharge(): do the opposite of sk_mem_charge()
In addition, to achieve consolidation, updating sk_wmem_queued is
removed from sk_mem_charge().
Next, to consolidate memory accounting functions, this patch adds
memory accounting calls to network core functions. Moreover, present
memory accounting call is renamed to new accounting call.
Finally we replace present memory accounting calls with new interface
in TCP and SCTP.
Signed-off-by: Takahiro Yasui <tyasui@redhat.com>
Signed-off-by: Hideo Aoki <haoki@redhat.com>
The previous move of the the UDP inDatagrams counter caused each
peek of the same packet to be counted separately. This may be
undesirable.
This patch fixes this by adding a bit to sk_buff to record whether
this packet has already been seen through skb_recv_datagram. We
then only increment the counter when the packet is seen for the
first time.
The only dodgy part is the fact that skb_recv_datagram doesn't have
a good way of returning this new bit of information. So I've added
a new function __skb_recv_datagram that does return this and made
skb_recv_datagram a wrapper around it.
The plan is to eventually replace all uses of skb_recv_datagram with
this new function at which time it can be renamed its proper name.
Currently it is possible for two processes to peek on the same socket
and end up incrementing the error counter twice for the same packet.
This patch fixes it by making skb_kill_datagram return whether it
succeeded in unlinking the packet and only incrementing the counter
if it did.
When msg_iovlen is zero we shouldn't try to dereference
msg_iov. Right now the only thing that tries to do so
is skb_copy_and_csum_datagram_iovec. Since the total
length should also be zero if msg_iovlen is zero, it's
sufficient to check the total length there and simply
return if it's zero.
This reverts eefa3906283a2b60a6d02a2cda593a7d7d7946c5
The simplification made in that change works with the assumption that
the 'offset' parameter to these functions is always positive or zero,
which is not true. It can be and often is negative in order to access
SKB header values in front of skb->data.
I noticed recently that, in skb_checksum(), "offset" and "start" are
essentially the same thing and have the same value throughout the
function, despite being computed differently. Using a single variable
allows some cleanups and makes the skb_checksum() function smaller,
more readable, and presumably marginally faster.
We appear to have many other "sk_buff walker" functions built on the
exact same model, so the cleanup applies to them, too. Here is a list
of the functions I found to be affected:
net/appletalk/ddp.c:atalk_sum_skb()
net/core/datagram.c:skb_copy_datagram_iovec()
net/core/datagram.c:skb_copy_and_csum_datagram()
net/core/skbuff.c:skb_copy_bits()
net/core/skbuff.c:skb_store_bits()
net/core/skbuff.c:skb_checksum()
net/core/skbuff.c:skb_copy_and_csum_bit()
net/core/user_dma.c:dma_skb_copy_datagram_iovec()
net/xfrm/xfrm_algo.c:skb_icv_walk()
net/xfrm/xfrm_algo.c:skb_to_sgvec()
OTOH, I admit I'm a bit surprised, the cleanup is rather obvious so I'm
really wondering if I am missing something. Can anyone please comment
on this?
Signed-off-by: Jean Delvare <jdelvare@suse.de>
This patch eliminates some duplicate code for the verification of
receive checksums between UDP-Lite and UDP. It does this by
introducing __skb_checksum_complete_head which is identical to
__skb_checksum_complete_head apart from the fact that it takes
a length parameter rather than computing the first skb->len bytes.
As a result UDP-Lite will be able to use hardware checksum offload
for packets which do not use partial coverage checksums. It also
means that UDP-Lite loopback no longer does unnecessary checksum
verification.
If any NICs start support UDP-Lite this would also start working
automatically.
This patch removes the assumption that msg_flags has MSG_TRUNC clear
upon entry in recvmsg.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
net/*
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose
checksum still needs to be completed) and CHECKSUM_COMPLETE (for
incoming packets, device supplied full checksum).
Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3.
Implement the half-closed devices notifiation, by adding a new POLLRDHUP
(and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the
existing POLLHUP handling, that does not report correctly half-closed
devices, was feared to be changed, this implementation leaves the current
POLLHUP reporting unchanged and simply add a new bit that is set in the few
places where it makes sense. The same thing was discussed and conceptually
agreed quite some time ago:
http://lkml.org/lkml/2003/7/12/116
Since this new event bit is added to the existing Linux poll infrastruture,
even the existing poll/select system calls will be able to use it. As far
as the existing POLLHUP handling, the patch leaves it as is. The
pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing
archs and sets the bit in the six relevant files. The other attached diff
is the simple change required to sys/epoll.h to add the EPOLLRDHUP
definition.
There is "a stupid program" to test POLLRDHUP delivery here:
http://www.xmailserver.org/pollrdhup-test.c
It tests poll(2), but since the delivery is same epoll(2) will work equally.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Revert the following changeset:
bc8dfcb93970ad7139c976356bfc99d7e251deaf
Recursive SKB frag lists are really possible and disallowing
them breaks things.
Noticed by: Jesse Brandeburg <jesse.brandeburg@intel.com>
When a packet is obtained from skb_recv_datagram with MSG_PEEK enabled
it is left on the socket receive queue. This means that when we detect
a checksum error we have to be careful when trying to free the packet
as someone could have dequeued it in the time being.
Currently this delicate logic is duplicated three times between UDPv4,
UDPv6 and RAWv6. This patch moves them into a one place and simplifies
the code somewhat.
This is based on a suggestion by Eric Dumazet.
Here is the patch that introduces the generic skb_checksum_complete
which also checks for hardware RX checksum faults. If that happens,
it'll call netdev_rx_csum_fault which currently prints out a stack
trace with the device name. In future it can turn off RX checksum.
I've converted every spot under net/ that does RX checksum checks to
use skb_checksum_complete or __skb_checksum_complete with the
exceptions of:
* Those places where checksums are done bit by bit. These will call
netdev_rx_csum_fault directly.
* The following have not been completely checked/converted:
ipmr
ip_vs
netfilter
dccp
This patch is based on patches and suggestions from Stephen Hemminger
and David S. Miller.
The recent rewrite of skb_copy_datagram_iovec broke the reception of
zero-size datagrams. This patch fixes it.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Use iteration instead of recursion. Fraglists within fraglists
should never occur, so we BUG check this.
Signed-off-by: Daniel Phillips <phillips@istop.com>
Lots of places just needs the states, not even linux/tcp.h, where this
enum was, needs it.
This speeds up development of the refactorings as less sources are
rebuilt when things get moved from net/tcp.h.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Some KernelDoc descriptions are updated to match the current code.
No code changes.
Signed-off-by: Martin Waitz <tali@admingilde.org>
I have recompiled Linux kernel 2.6.11.5 documentation for me and our
university students again. The documentation could be extended for more
sources which are equipped by structured comments for recent 2.6 kernels. I
have tried to proceed with that task. I have done that more times from 2.6.0
time and it gets boring to do same changes again and again. Linux kernel
compiles after changes for i386 and ARM targets. I have added references to
some more files into kernel-api book, I have added some section names as well.
So please, check that changes do not break something and that categories are
not too much skewed.
I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved
by kernel convention. Most of the other changes are modifications in the
comments to make kernel-doc happy, accept some parameters description and do
not bail out on errors. Changed <pid> to @pid in the description, moved some
#ifdef before comments to correct function to comments bindings, etc.
You can see result of the modified documentation build at
http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz
Some more sources are ready to be included into kernel-doc generated
documentation. Sources has been added into kernel-api for now. Some more
section names added and probably some more chaos introduced as result of quick
cleanup work.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
infrastructure for it.
Let it rip!
