path: root/net/core/datagram.c
2008-01-28[NET] CORE: Introducing new memory accounting interface.Hideo Aoki
This patch introduces new memory accounting functions for each network protocol. Most of them are renamed from memory accounting functions for stream protocols. At the same time, some stream memory accounting functions are removed since other functions do same thing. Renaming: sk_stream_free_skb() -> sk_wmem_free_skb() __sk_stream_mem_reclaim() -> __sk_mem_reclaim() sk_stream_mem_reclaim() -> sk_mem_reclaim() sk_stream_mem_schedule -> __sk_mem_schedule() sk_stream_pages() -> sk_mem_pages() sk_stream_rmem_schedule() -> sk_rmem_schedule() sk_stream_wmem_schedule() -> sk_wmem_schedule() sk_charge_skb() -> sk_mem_charge() Removeing sk_stream_rfree(): consolidates into sock_rfree() sk_stream_set_owner_r(): consolidates into skb_set_owner_r() sk_stream_mem_schedule() The following functions are added. sk_has_account(): check if the protocol supports accounting sk_mem_uncharge(): do the opposite of sk_mem_charge() In addition, to achieve consolidation, updating sk_wmem_queued is removed from sk_mem_charge(). Next, to consolidate memory accounting functions, this patch adds memory accounting calls to network core functions. Moreover, present memory accounting call is renamed to new accounting call. Finally we replace present memory accounting calls with new interface in TCP and SCTP. Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Hideo Aoki <haoki@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Only increment counter on first peek/recvHerbert Xu
The previous move of the the UDP inDatagrams counter caused each peek of the same packet to be counted separately. This may be undesirable. This patch fixes this by adding a bit to sk_buff to record whether this packet has already been seen through skb_recv_datagram. We then only increment the counter when the packet is seen for the first time. The only dodgy part is the fact that skb_recv_datagram doesn't have a good way of returning this new bit of information. So I've added a new function __skb_recv_datagram that does return this and made skb_recv_datagram a wrapper around it. The plan is to eventually replace all uses of skb_recv_datagram with this new function at which time it can be renamed its proper name. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Avoid repeated counting of checksum errors due to peekingHerbert Xu
Currently it is possible for two processes to peek on the same socket and end up incrementing the error counter twice for the same packet. This patch fixes it by making skb_kill_datagram return whether it succeeded in unlinking the packet and only incrementing the counter if it did. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-11[NET]: Do not dereference iov if length is zeroHerbert Xu
When msg_iovlen is zero we shouldn't try to dereference msg_iov. Right now the only thing that tries to do so is skb_copy_and_csum_datagram_iovec. Since the total length should also be zero if msg_iovlen is zero, it's sufficient to check the total length there and simply return if it's zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-27[NET]: Revert sk_buff walker cleanups.David S. Miller
This reverts eefa3906283a2b60a6d02a2cda593a7d7d7946c5 The simplification made in that change works with the assumption that the 'offset' parameter to these functions is always positive or zero, which is not true. It can be and often is negative in order to access SKB header values in front of skb->data. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: Clean up sk_buff walkers.Jean Delvare
I noticed recently that, in skb_checksum(), "offset" and "start" are essentially the same thing and have the same value throughout the function, despite being computed differently. Using a single variable allows some cleanups and makes the skb_checksum() function smaller, more readable, and presumably marginally faster. We appear to have many other "sk_buff walker" functions built on the exact same model, so the cleanup applies to them, too. Here is a list of the functions I found to be affected: net/appletalk/ddp.c:atalk_sum_skb() net/core/datagram.c:skb_copy_datagram_iovec() net/core/datagram.c:skb_copy_and_csum_datagram() net/core/skbuff.c:skb_copy_bits() net/core/skbuff.c:skb_store_bits() net/core/skbuff.c:skb_checksum() net/core/skbuff.c:skb_copy_and_csum_bit() net/core/user_dma.c:dma_skb_copy_datagram_iovec() net/xfrm/xfrm_algo.c:skb_icv_walk() net/xfrm/xfrm_algo.c:skb_to_sgvec() OTOH, I admit I'm a bit surprised, the cleanup is rather obvious so I'm really wondering if I am missing something. Can anyone please comment on this? Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[UDP]: Clean up UDP-Lite receive checksumHerbert Xu
This patch eliminates some duplicate code for the verification of receive checksums between UDP-Lite and UDP. It does this by introducing __skb_checksum_complete_head which is identical to __skb_checksum_complete_head apart from the fact that it takes a length parameter rather than computing the first skb->len bytes. As a result UDP-Lite will be able to use hardware checksum offload for packets which do not use partial coverage checksums. It also means that UDP-Lite loopback no longer does unnecessary checksum verification. If any NICs start support UDP-Lite this would also start working automatically. This patch removes the assumption that msg_flags has MSG_TRUNC clear upon entry in recvmsg. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] CORE: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate __skb_checksum_complete() and friends.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate callers of csum_partial_copy_...() and csum_and_copy...() in ↵Al Viro
net/* Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate callers of csum_fold() in net/*Al Viro
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-13[NET]: Revert skb_copy_datagram_iovec() recursion elimination.David S. Miller
Revert the following changeset: bc8dfcb93970ad7139c976356bfc99d7e251deaf Recursive SKB frag lists are really possible and disallowing them breaks things. Noticed by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP]: Simplify and consolidate MSG_PEEK error handlingHerbert Xu
When a packet is obtained from skb_recv_datagram with MSG_PEEK enabled it is left on the socket receive queue. This means that when we detect a checksum error we have to be careful when trying to free the packet as someone could have dequeued it in the time being. Currently this delicate logic is duplicated three times between UDPv4, UDPv6 and RAWv6. This patch moves them into a one place and simplifies the code somewhat. This is based on a suggestion by Eric Dumazet. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NET]: Detect hardware rx checksum faults correctlyHerbert Xu
Here is the patch that introduces the generic skb_checksum_complete which also checks for hardware RX checksum faults. If that happens, it'll call netdev_rx_csum_fault which currently prints out a stack trace with the device name. In future it can turn off RX checksum. I've converted every spot under net/ that does RX checksum checks to use skb_checksum_complete or __skb_checksum_complete with the exceptions of: * Those places where checksums are done bit by bit. These will call netdev_rx_csum_fault directly. * The following have not been completely checked/converted: ipmr ip_vs netfilter dccp This patch is based on patches and suggestions from Stephen Hemminger and David S. Miller. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-02[NET]: Fix zero-size datagram receptionHerbert Xu
The recent rewrite of skb_copy_datagram_iovec broke the reception of zero-size datagrams. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-27[NET]: Use non-recursive algorithm in skb_copy_datagram_iovec()Daniel Phillips
Use iteration instead of recursion. Fraglists within fraglists should never occur, so we BUG check this. Signed-off-by: Daniel Phillips <phillips@istop.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
