[ Upstream commit ac5b70198adc25c73fba28de4f78adcee8f6be0b ]
netif_set_real_num_tx_queues() can be called when netdev is up.
That usually happens when user requests change of number of
channels/rings with ethtool -L. The procedure for changing
the number of queues involves resetting the qdiscs and setting
dev->num_tx_queues to the new value. When the new value is
lower than the old one, extra care has to be taken to ensure
ordering of accesses to the number of queues vs qdisc reset.
Currently the queues are reset before new dev->num_tx_queues
is assigned, leaving a window of time where packets can be
enqueued onto the queues going down, leading to a likely
crash in the drivers, since most drivers don't check if TX
skbs are assigned to an active queue.
Fixes: e6484930d7c7 ("net: allocate tx queues in register_netdevice")
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
commit 8d74e9f88d65af8bb2e095aff506aa6eac755ada upstream.
skb_warn_bad_offload warns when packets enter the GSO stack that
require skb_checksum_help or vice versa. Do not warn on arbitrary
bad packets. Packet sockets can craft many. Syzkaller was able to
demonstrate another one with eth_type games.
In particular, suppress the warning when segmentation returns an
error, which is for reasons other than checksum offload.
See also commit 36c92474498a ("net: WARN if skb_checksum_help() is
called on skb requiring segmentation") for context on this warning.
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 7c68d1a6b4db9012790af7ac0f0fdc0d2083422a ]
Without proper validation of DODGY packets, we might very well
feed qdisc_pkt_len_init() with invalid GSO packets.
tcp_hdrlen() might access out-of-bound data, so let's use
skb_header_pointer() and proper checks.
Whole story is described in commit d0c081b49137 ("flow_dissector:
properly cap thoff field")
We have the goal of validating DODGY packets earlier in the stack,
so we might very well revert this fix in the future.
Cc: Willem de Bruijn <willemb@google.com>
Cc: Jason Wang <jasowang@redhat.com>
Reported-by: syzbot+9da69ebac7dddd804552@syzkaller.appspotmail.com
Acked-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit 37c343b4f4e70e9dc328ab04903c0ec8d154c1a4 ]
When we notify peers of potential changes, it's also good to update
IGMP memberships. For example, during VM migration, updating IGMP
memberships will redirect existing multicast streams to the VM at the
new location.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 0ad646c81b2182f7fa67ec0c8c825e0ee165696d ]
register_netdevice() could fail early when we have an invalid
dev name, in which case ->ndo_uninit() is not called. For tun
device, this is a problem because a timer etc. are already
initialized and it expects ->ndo_uninit() to clean them up.
We could move these initializations into a ->ndo_init() so
that register_netdevice() knows better, however this is still
complicated due to the logic in tun_detach().
Therefore, I choose to just call dev_get_valid_name() before
register_netdevice(), which is quicker and much easier to audit.
And for this specific case, it is already enough.
Fixes: 96442e42429e ("tuntap: choose the txq based on rxq")
Reported-by: Dmitry Alexeev <avekceeb@gmail.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
[ Upstream commit 9899886d5e8ec5b343b1efe44f185a0e68dc6454 ]
Added NULL check to make __dev_kfree_skb_irq consistent with kfree
family of functions.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=195289
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
[ Upstream commit 25cc72a33835ed8a6f53180a822cadab855852ac ]
The mlxsw driver relies on NETDEV_CHANGEUPPER events to configure the
device in case a port is enslaved to a master netdev such as bridge or
bond.
Since the driver ignores events unrelated to its ports and their
uppers, it's possible to engineer situations in which the device's data
path differs from the kernel's.
One example to such a situation is when a port is enslaved to a bond
that is already enslaved to a bridge. When the bond was enslaved the
driver ignored the event - as the bond wasn't one of its uppers - and
therefore a bridge port instance isn't created in the device.
Until such configurations are supported forbid them by checking that the
upper device doesn't have uppers of its own.
Fixes: 0d65fc13042f ("mlxsw: spectrum: Implement LAG port join/leave")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Nogah Frankel <nogahf@mellanox.com>
Tested-by: Nogah Frankel <nogahf@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 8d63bee643f1fb53e472f0e135cae4eb99d62d19 ]
skb_warn_bad_offload triggers a warning when an skb enters the GSO
stack at __skb_gso_segment that does not have CHECKSUM_PARTIAL
checksum offload set.
Commit b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
observed that SKB_GSO_DODGY producers can trigger the check and
that passing those packets through the GSO handlers will fix it
up. But, the software UFO handler will set ip_summed to
CHECKSUM_NONE.
When __skb_gso_segment is called from the receive path, this
triggers the warning again.
Make UFO set CHECKSUM_UNNECESSARY instead of CHECKSUM_NONE. On
Tx these two are equivalent. On Rx, this better matches the
skb state (checksum computed), as CHECKSUM_NONE here means no
checksum computed.
See also this thread for context:
http://patchwork.ozlabs.org/patch/799015/
Fixes: b2504a5dbef3 ("net: reduce skb_warn_bad_offload() noise")
commit 6e7bc478c9a006c701c14476ec9d389a484b4864 upstream.
My recent change missed fact that UFO would perform a complete
UDP checksum before segmenting in frags.
In this case skb->ip_summed is set to CHECKSUM_NONE.
We need to add this valid case to skb_needs_check()
commit b2504a5dbef3305ef41988ad270b0e8ec289331c upstream.
Dmitry reported warnings occurring in __skb_gso_segment() [1]
All SKB_GSO_DODGY producers can allow user space to feed
packets that trigger the current check.
We could prevent them from doing so, rejecting packets, but
this might add regressions to existing programs.
It turns out our SKB_GSO_DODGY handlers properly set up checksum
information that is needed anyway when packets needs to be segmented.
By checking again skb_needs_check() after skb_mac_gso_segment(),
we should remove these pesky warnings, at a very minor cost.
With help from Willem de Bruijn
[1]
WARNING: CPU: 1 PID: 6768 at net/core/dev.c:2439 skb_warn_bad_offload+0x2af/0x390 net/core/dev.c:2434
lo: caps=(0x000000a2803b7c69, 0x0000000000000000) len=138 data_len=0 gso_size=15883 gso_type=4 ip_summed=0
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 6768 Comm: syz-executor1 Not tainted 4.9.0 #5
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
ffff8801c063ecd8 ffffffff82346bdf ffffffff00000001 1ffff100380c7d2e
ffffed00380c7d26 0000000041b58ab3 ffffffff84b37e38 ffffffff823468f1
ffffffff84820740 ffffffff84f289c0 dffffc0000000000 ffff8801c063ee20
Call Trace:
[<ffffffff82346bdf>] __dump_stack lib/dump_stack.c:15 [inline]
[<ffffffff82346bdf>] dump_stack+0x2ee/0x3ef lib/dump_stack.c:51
[<ffffffff81827e34>] panic+0x1fb/0x412 kernel/panic.c:179
[<ffffffff8141f704>] __warn+0x1c4/0x1e0 kernel/panic.c:542
[<ffffffff8141f7e5>] warn_slowpath_fmt+0xc5/0x100 kernel/panic.c:565
[<ffffffff8356cbaf>] skb_warn_bad_offload+0x2af/0x390 net/core/dev.c:2434
[<ffffffff83585cd2>] __skb_gso_segment+0x482/0x780 net/core/dev.c:2706
[<ffffffff83586f19>] skb_gso_segment include/linux/netdevice.h:3985 [inline]
[<ffffffff83586f19>] validate_xmit_skb+0x5c9/0xc20 net/core/dev.c:2969
[<ffffffff835892bb>] __dev_queue_xmit+0xe6b/0x1e70 net/core/dev.c:3383
[<ffffffff8358a2d7>] dev_queue_xmit+0x17/0x20 net/core/dev.c:3424
[<ffffffff83ad161d>] packet_snd net/packet/af_packet.c:2930 [inline]
[<ffffffff83ad161d>] packet_sendmsg+0x32ed/0x4d30 net/packet/af_packet.c:2955
[<ffffffff834f0aaa>] sock_sendmsg_nosec net/socket.c:621 [inline]
[<ffffffff834f0aaa>] sock_sendmsg+0xca/0x110 net/socket.c:631
[<ffffffff834f329a>] ___sys_sendmsg+0x8fa/0x9f0 net/socket.c:1954
[<ffffffff834f5e58>] __sys_sendmsg+0x138/0x300 net/socket.c:1988
[<ffffffff834f604d>] SYSC_sendmsg net/socket.c:1999 [inline]
[<ffffffff834f604d>] SyS_sendmsg+0x2d/0x50 net/socket.c:1995
[<ffffffff84371941>] entry_SYSCALL_64_fastpath+0x1f/0xc2
Cc: Mark Salyzyn <salyzyn@android.com>
commit 9af9959e142c274f4a30fefb71d97d2b028b337f upstream.
commit 9256645af098 ("net/core: relax BUILD_BUG_ON in
netdev_stats_to_stats64") made an attempt to read beyond
the size of the source a possibility.
Fix to only copy src size to dest. As dest might be bigger than src.
BUG: KASAN: slab-out-of-bounds in netdev_stats_to_stats64+0xe/0x30 at addr ffff8801be248b20
Read of size 192 by task VBoxNetAdpCtl/6734
CPU: 1 PID: 6734 Comm: VBoxNetAdpCtl Tainted: G O 4.11.4prahal+intel+ #118
Hardware name: LENOVO 20CDCTO1WW/20CDCTO1WW, BIOS GQET52WW (1.32 ) 05/04/2017
Call Trace:
dump_stack+0x63/0x86
kasan_object_err+0x1c/0x70
kasan_report+0x270/0x520
? netdev_stats_to_stats64+0xe/0x30
? sched_clock_cpu+0x1b/0x190
? __module_address+0x3e/0x3b0
? unwind_next_frame+0x1ea/0xb00
check_memory_region+0x13c/0x1a0
memcpy+0x23/0x50
dev_get_stats+0x1b9/0x230
rtnl_fill_stats+0x44/0xc00
? nla_put+0xc6/0x130
rtnl_fill_ifinfo+0xe9e/0x3700
? rtnl_fill_vfinfo+0xde0/0xde0
? sched_clock+0x9/0x10
? sched_clock_local+0x120/0x130
? VBoxNetAdpLinuxIOCtlUnlocked+0x14b/0x280 [vboxnetadp]
? depot_save_stack+0x1d8/0x4a0
? depot_save_stack+0x34f/0x4a0
? save_stack+0xb1/0xd0
? save_stack_trace+0x16/0x20
? save_stack+0x46/0xd0
? kasan_slab_alloc+0x12/0x20
? __kmalloc_node_track_caller+0x10d/0x350
? __kmalloc_reserve.isra.36+0x2c/0xc0
? __alloc_skb+0xd0/0x560
? rtmsg_ifinfo_build_skb+0x61/0x120
? rtmsg_ifinfo.part.25+0x16/0xb0
? rtmsg_ifinfo+0x47/0x70
? register_netdev+0x15/0x30
? vboxNetAdpOsCreate+0xc0/0x1c0 [vboxnetadp]
? vboxNetAdpCreate+0x210/0x400 [vboxnetadp]
? do_vfs_ioctl+0x17f/0xff0
? SyS_ioctl+0x74/0x80
? do_syscall_64+0x182/0x390
? init_object+0x64/0xa0
? ___slab_alloc+0x1ae/0x5c0
? kasan_unpoison_shadow+0x35/0x50
? kasan_kmalloc+0xad/0xe0
? __kmalloc_node_track_caller+0x246/0x350
? memset+0x31/0x40
? __alloc_skb+0x31f/0x560
? napi_consume_skb+0x320/0x320
? br_get_link_af_size_filtered+0xb7/0x120 [bridge]
? if_nlmsg_size+0x440/0x630
rtmsg_ifinfo_build_skb+0x83/0x120
register_netdevice+0xa2b/0xe50
? __kmalloc+0x171/0x2d0
? netdev_change_features+0x80/0x80
? vboxNetAdpComposeMACAddress+0x1d0/0x1d0 [vboxnetadp]
? kasan_check_write+0x14/0x20
? VBoxNetAdpLinuxOpen+0x20/0x20 [vboxnetadp]
? lock_acquire+0x11c/0x270
? __audit_syscall_entry+0x2fb/0x660
? ioctl_preallocate+0x1d0/0x1d0
? kmem_cache_free+0xb2/0x250
? syscall_trace_enter+0x537/0xd00
? exit_to_usermode_loop+0x100/0x100
SyS_ioctl+0x74/0x80
? do_sys_open+0x350/0x350
? do_vfs_ioctl+0xff0/0xff0
entry_SYSCALL64_slow_path+0x25/0x25
RIP: 0033:0x7f7e39a1ae07
RSP: 002b:00007ffc6f04c6d8 EFLAGS: 00000206 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00007ffc6f04c730 RCX: 00007f7e39a1ae07
RDX: 00007ffc6f04c730 RSI: 00000000c0207601 RDI: 0000000000000007
RBP: 00007ffc6f04c700 R08: 00007ffc6f04c780 R09: 0000000000000008
R10: 0000000000000541 R11: 0000000000000206 R12: 0000000000000007
R13: 00000000c0207601 R14: 00007ffc6f04c730 R15: 0000000000000012
Object at ffff8801be248008, in cache kmalloc-4096 size: 4096
Allocated:
PID = 6734
alloc_netdev_mqs+0x8a7/0xbe0
vboxNetAdpOsCreate+0x65/0x1c0 [vboxnetadp]
SyS_ioctl+0x74/0x80
return_from_SYSCALL_64+0x0/0x6a
Freed:
PID = 5600
kasan_slab_free+0x73/0xc0
kfree+0xe4/0x220
kvfree+0x25/0x30
single_release+0x74/0xb0
__fput+0x265/0x6b0
____fput+0x9/0x10
task_work_run+0xd5/0x150
exit_to_usermode_loop+0xe2/0x100
do_syscall_64+0x26c/0x390
Memory state around the buggy address:
ffff8801be248a80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8801be248b00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff8801be248b80: 00 00 00 00 00 00 00 00 00 00 00 07 fc fc fc fc
ffff8801be248c00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8801be248c80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
Signed-off-by: Alban Browaeys <alban.browaeys@gmail.com>
commit e44699d2c28067f69698ccb68dd3ddeacfebc434 upstream.
Recently I started seeing warnings about pages with refcount -1. The
problem was traced to packets being reused after their head was merged into
a GRO packet by skb_gro_receive(). While bisecting the issue pointed to
commit c21b48cc1bbf ("net: adjust skb->truesize in ___pskb_trim()") and
I have never seen it on a kernel with it reverted, I believe the real
problem appeared earlier when the option to merge head frag in GRO was
implemented.
Handling NAPI_GRO_FREE_STOLEN_HEAD state was only added to GRO_MERGED_FREE
branch of napi_skb_finish() so that if the driver uses napi_gro_frags()
and head is merged (which in my case happens after the skb_condense()
call added by the commit mentioned above), the skb is reused including the
head that has been merged. As a result, we release the page reference
twice and eventually end up with negative page refcount.
To fix the problem, handle NAPI_GRO_FREE_STOLEN_HEAD in napi_frags_finish()
the same way it's done in napi_skb_finish().
Fixes: d7e8883cfcf4 ("net: make GRO aware of skb->head_frag")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
commit 6f64ec74515925cced6df4571638b5a099a49aae upstream.
Similar to the fix provided by Dominik Heidler in commit
9b3dc0a17d73 ("l2tp: cast l2tp traffic counter to unsigned")
we need to take care of 32bit kernels in dev_get_stats().
When using atomic_long_read(), we add a 'long' to u64 and
might misinterpret high order bit, unless we cast to unsigned.
Fixes: caf586e5f23ce ("net: add a core netdev->rx_dropped counter")
Fixes: 015f0688f57ca ("net: net: add a core netdev->tx_dropped counter")
Fixes: 6e7333d315a76 ("net: add rx_nohandler stat counter")
Cc: Jarod Wilson <jarod@redhat.com>
[ Upstream commit c28294b941232931fbd714099798eb7aa7e865d7 ]
KMSAN reported a use of uninitialized memory in dev_set_alias(),
which was caused by calling strlcpy() (which in turn called strlen())
on the user-supplied non-terminated string.
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit 13baa00ad01bb3a9f893e3a08cbc2d072fc0c15d ]
It is now very clear that silly TCP listeners might play with
enabling/disabling timestamping while new children are added
to their accept queue.
Meaning net_enable_timestamp() can be called from BH context
while current state of the static key is not enabled.
Lets play safe and allow all contexts.
The work queue is scheduled only under the problematic cases,
which are the static key enable/disable transition, to not slow down
critical paths.
This extends and improves what we did in commit 5fa8bbda38c6 ("net: use
a work queue to defer net_disable_timestamp() work")
Fixes: b90e5794c5bd ("net: dont call jump_label_dec from irq context")
[ Upstream commit 5fa8bbda38c668e56b0c6cdecced2eac2fe36dec ]
Dmitry reported a warning [1] showing that we were calling
net_disable_timestamp() -> static_key_slow_dec() from a non
process context.
Grabbing a mutex while holding a spinlock or rcu_read_lock()
is not allowed.
As Cong suggested, we now use a work queue.
It is possible netstamp_clear() exits while netstamp_needed_deferred
is not zero, but it is probably not worth trying to do better than that.
netstamp_needed_deferred atomic tracks the exact number of deferred
decrements.
[1]
[ INFO: suspicious RCU usage. ]
4.10.0-rc5+ #192 Not tainted
./include/linux/rcupdate.h:561 Illegal context switch in RCU read-side
critical section!
rcu_scheduler_active = 2, debug_locks = 0
2 locks held by syz-executor14/23111:
#0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff83a35c35>] lock_sock
include/net/sock.h:1454 [inline]
rawv6_sendmsg+0x1e65/0x3ec0 net/ipv6/raw.c:919
#1: (rcu_read_lock){......}, at: [<ffffffff83ae2678>] nf_hook
include/linux/netfilter.h:201 [inline]
__ip6_local_out+0x258/0x840 net/ipv6/output_core.c:160
stack backtrace:
CPU: 2 PID: 23111 Comm: syz-executor14 Not tainted 4.10.0-rc5+ #192
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs
01/01/2011
Call Trace:
lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4452
rcu_preempt_sleep_check include/linux/rcupdate.h:560 [inline]
___might_sleep+0x560/0x650 kernel/sched/core.c:7748
__might_sleep+0x95/0x1a0 kernel/sched/core.c:7739
mutex_lock_nested+0x24f/0x1730 kernel/locking/mutex.c:752
atomic_dec_and_mutex_lock+0x119/0x160 kernel/locking/mutex.c:1060
__static_key_slow_dec+0x7a/0x1e0 kernel/jump_label.c:149
static_key_slow_dec+0x51/0x90 kernel/jump_label.c:174
net_disable_timestamp+0x3b/0x50 net/core/dev.c:1728
sock_disable_timestamp+0x98/0xc0 net/core/sock.c:403
__sk_destruct+0x27d/0x6b0 net/core/sock.c:1441
sk_destruct+0x47/0x80 net/core/sock.c:1460
__sk_free+0x57/0x230 net/core/sock.c:1468
sock_wfree+0xae/0x120 net/core/sock.c:1645
skb_release_head_state+0xfc/0x200 net/core/skbuff.c:655
skb_release_all+0x15/0x60 net/core/skbuff.c:668
__kfree_skb+0x15/0x20 net/core/skbuff.c:684
kfree_skb+0x16e/0x4c0 net/core/skbuff.c:705
inet_frag_destroy+0x121/0x290 net/ipv4/inet_fragment.c:304
inet_frag_put include/net/inet_frag.h:133 [inline]
nf_ct_frag6_gather+0x1106/0x3840
net/ipv6/netfilter/nf_conntrack_reasm.c:617
ipv6_defrag+0x1be/0x2b0 net/ipv6/netfilter/nf_defrag_ipv6_hooks.c:68
nf_hook_entry_hookfn include/linux/netfilter.h:102 [inline]
nf_hook_slow+0xc3/0x290 net/netfilter/core.c:310
nf_hook include/linux/netfilter.h:212 [inline]
__ip6_local_out+0x489/0x840 net/ipv6/output_core.c:160
ip6_local_out+0x2d/0x170 net/ipv6/output_core.c:170
ip6_send_skb+0xa1/0x340 net/ipv6/ip6_output.c:1722
ip6_push_pending_frames+0xb3/0xe0 net/ipv6/ip6_output.c:1742
rawv6_push_pending_frames net/ipv6/raw.c:613 [inline]
rawv6_sendmsg+0x2d1a/0x3ec0 net/ipv6/raw.c:927
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744
sock_sendmsg_nosec net/socket.c:635 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:645
sock_write_iter+0x326/0x600 net/socket.c:848
do_iter_readv_writev+0x2e3/0x5b0 fs/read_write.c:695
do_readv_writev+0x42c/0x9b0 fs/read_write.c:872
vfs_writev+0x87/0xc0 fs/read_write.c:911
do_writev+0x110/0x2c0 fs/read_write.c:944
SYSC_writev fs/read_write.c:1017 [inline]
SyS_writev+0x27/0x30 fs/read_write.c:1014
RIP: 0033:0x445559
RSP: 002b:00007f6f46fceb58 EFLAGS: 00000292 ORIG_RAX: 0000000000000014
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 0000000000445559
RDX: 0000000000000001 RSI: 0000000020f1eff0 RDI: 0000000000000005
RBP: 00000000006e19c0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000292 R12: 0000000000700000
R13: 0000000020f59000 R14: 0000000000000015 R15: 0000000000020400
BUG: sleeping function called from invalid context at
in_atomic(): 1, irqs_disabled(): 0, pid: 23111, name: syz-executor14
INFO: lockdep is turned off.
01/01/2011
Call Trace:
___might_sleep+0x47e/0x650 kernel/sched/core.c:7780
RIP: 0033:0x445559
Suggested-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 7be2c82cfd5d28d7adb66821a992604eb6dd112e ]
Ashizuka reported a highmem oddity and sent a patch for freescale
fec driver.
But the problem root cause is that core networking stack
must ensure no skb with highmem fragment is ever sent through
a device that does not assert NETIF_F_HIGHDMA in its features.
We need to call illegal_highdma() from harmonize_features()
regardless of CSUM checks.
Fixes: ec5f06156423 ("net: Kill link between CSUM and SG features.")
Cc: Pravin Shelar <pshelar@ovn.org>
Reported-by: "Ashizuka, Yuusuke" <ashiduka@jp.fujitsu.com>
[ Upstream commit 7cfd5fd5a9813f1430290d20c0fead9b4582a307 ]
On 32bit arches, (skb->end - skb->data) is not 'unsigned int',
so we shall use min_t() instead of min() to avoid a compiler error.
Fixes: 1272ce87fa01 ("gro: Enter slow-path if there is no tailroom")
Reported-by: kernel test robot <fengguang.wu@intel.com>
[ Upstream commit 1272ce87fa017ca4cf32920764d879656b7a005a ]
The GRO path has a fast-path where we avoid calling pskb_may_pull
and pskb_expand by directly accessing frag0. However, this should
only be done if we have enough tailroom in the skb as otherwise
we'll have to expand it later anyway.
This patch adds the check by capping frag0_len with the skb tailroom.
Fixes: cb18978cbf45 ("gro: Open-code final pskb_may_pull")
Reported-by: Slava Shwartsman <slavash@mellanox.com>
If the bpf program calls bpf_redirect(dev, 0) and dev is
an ipip/ip6tnl, it currently includes the mac header.
e.g. If dev is ipip, the end result is IP-EthHdr-IP instead
of IP-IP.
The fix is to pull the mac header. At ingress, skb_postpull_rcsum()
is not needed because the ethhdr should have been pulled once already
and then got pushed back just before calling the bpf_prog.
At egress, this patch calls skb_postpull_rcsum().
If bpf_redirect(dev, BPF_F_INGRESS) is called,
it also fails now because it calls dev_forward_skb() which
eventually calls eth_type_trans(skb, dev). The eth_type_trans()
will set skb->type = PACKET_OTHERHOST because the mac address
does not match the redirecting dev->dev_addr. The PACKET_OTHERHOST
will eventually cause the ip_rcv() errors out. To fix this,
____dev_forward_skb() is added.
Joint work with Daniel Borkmann.
Fixes: cfc7381b3002 ("ip_tunnel: add collect_md mode to IPIP tunnel")
Fixes: 8d79266bc48c ("ip6_tunnel: add collect_md mode to IPv6 tunnels")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@fb.com>
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Sending zero checksum is ok for TCP, but not for UDP.
UDPv6 receiver should by default drop a frame with a 0 checksum,
and UDPv4 would not verify the checksum and might accept a corrupted
packet.
Simply replace such checksum by 0xffff, regardless of transport.
This error was caught on SIT tunnels, but seems generic.
Cc: Maciej Żenczykowski <maze@google.com>
Acked-by: Maciej Żenczykowski <maze@google.com>
Pull networking fixes from David Miller:
"Lots of fixes, mostly drivers as is usually the case.
1) Don't treat zero DMA address as invalid in vmxnet3, from Alexey
Khoroshilov.
2) Fix element timeouts in netfilter's nft_dynset, from Anders K.
Pedersen.
3) Don't put aead_req crypto struct on the stack in mac80211, from
Ard Biesheuvel.
4) Several uninitialized variable warning fixes from Arnd Bergmann.
5) Fix memory leak in cxgb4, from Colin Ian King.
6) Fix bpf handling of VLAN header push/pop, from Daniel Borkmann.
7) Several VRF semantic fixes from David Ahern.
8) Set skb->protocol properly in ip6_tnl_xmit(), from Eli Cooper.
9) Socket needs to be locked in udp_disconnect(), from Eric Dumazet.
10) Div-by-zero on 32-bit fix in mlx4 driver, from Eugenia Emantayev.
11) Fix stale link state during failover in NCSCI driver, from Gavin
Shan.
12) Fix netdev lower adjacency list traversal, from Ido Schimmel.
13) Propvide proper handle when emitting notifications of filter
deletes, from Jamal Hadi Salim.
14) Memory leaks and big-endian issues in rtl8xxxu, from Jes Sorensen.
15) Fix DESYNC_FACTOR handling in ipv6, from Jiri Bohac.
16) Several routing offload fixes in mlxsw driver, from Jiri Pirko.
17) Fix broadcast sync problem in TIPC, from Jon Paul Maloy.
18) Validate chunk len before using it in SCTP, from Marcelo Ricardo
Leitner.
19) Revert a netns locking change that causes regressions, from Paul
Moore.
20) Add recursion limit to GRO handling, from Sabrina Dubroca.
21) GFP_KERNEL in irq context fix in ibmvnic, from Thomas Falcon.
22) Avoid accessing stale vxlan/geneve socket in data path, from
Pravin Shelar"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (189 commits)
geneve: avoid using stale geneve socket.
vxlan: avoid using stale vxlan socket.
qede: Fix out-of-bound fastpath memory access
net: phy: dp83848: add dp83822 PHY support
enic: fix rq disable
tipc: fix broadcast link synchronization problem
ibmvnic: Fix missing brackets in init_sub_crq_irqs
ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context
Revert "ibmvnic: Fix releasing of sub-CRQ IRQs in interrupt context"
arch/powerpc: Update parameters for csum_tcpudp_magic & csum_tcpudp_nofold
net/mlx4_en: Save slave ethtool stats command
net/mlx4_en: Fix potential deadlock in port statistics flow
net/mlx4: Fix firmware command timeout during interrupt test
net/mlx4_core: Do not access comm channel if it has not yet been initialized
net/mlx4_en: Fix panic during reboot
net/mlx4_en: Process all completions in RX rings after port goes up
net/mlx4_en: Resolve dividing by zero in 32-bit system
net/mlx4_core: Change the default value of enable_qos
net/mlx4_core: Avoid setting ports to auto when only one port type is supported
net/mlx4_core: Fix the resource-type enum in res tracker to conform to FW spec
When transmitting on a packet socket with PACKET_VNET_HDR and
PACKET_QDISC_BYPASS, validate device support for features requested
in vnet_hdr.
Drop TSO packets sent to devices that do not support TSO or have the
feature disabled. Note that the latter currently do process those
packets correctly, regardless of not advertising the feature.
Because of SKB_GSO_DODGY, it is not sufficient to test device features
with netif_needs_gso. Full validate_xmit_skb is needed.
Switch to software checksum for non-TSO packets that request checksum
offload if that device feature is unsupported or disabled. Note that
similar to the TSO case, device drivers may perform checksum offload
correctly even when not advertising it.
When switching to software checksum, packets hit skb_checksum_help,
which has two BUG_ON checksum not in linear segment. Packet sockets
always allocate at least up to csum_start + csum_off + 2 as linear.
Tested by running github.com/wdebruij/kerneltools/psock_txring_vnet.c
ethtool -K eth0 tso off tx on
psock_txring_vnet -d $dst -s $src -i eth0 -l 2000 -n 1 -q -v
psock_txring_vnet -d $dst -s $src -i eth0 -l 2000 -n 1 -q -v -N
ethtool -K eth0 tx off
psock_txring_vnet -d $dst -s $src -i eth0 -l 1000 -n 1 -q -v -G
psock_txring_vnet -d $dst -s $src -i eth0 -l 1000 -n 1 -q -v -G -N
v2:
- add EXPORT_SYMBOL_GPL(validate_xmit_skb_list)
Fixes: d346a3fae3ff ("packet: introduce PACKET_QDISC_BYPASS socket option")
Currently, GRO can do unlimited recursion through the gro_receive
handlers. This was fixed for tunneling protocols by limiting tunnel GRO
to one level with encap_mark, but both VLAN and TEB still have this
problem. Thus, the kernel is vulnerable to a stack overflow, if we
receive a packet composed entirely of VLAN headers.
This patch adds a recursion counter to the GRO layer to prevent stack
overflow. When a gro_receive function hits the recursion limit, GRO is
aborted for this skb and it is processed normally. This recursion
counter is put in the GRO CB, but could be turned into a percpu counter
if we run out of space in the CB.
Thanks to Vladimír Beneš <vbenes@redhat.com> for the initial bug report.
Fixes: CVE-2016-7039
Fixes: 9b174d88c257 ("net: Add Transparent Ethernet Bridging GRO support.")
Fixes: 66e5133f19e9 ("vlan: Add GRO support for non hardware accelerated vlan")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Tom Herbert <tom@herbertland.com>
Tamir reported the following trace when processing ARP requests received
via a vlan device on top of a VLAN-aware bridge:
NMI watchdog: BUG: soft lockup - CPU#1 stuck for 22s! [swapper/1:0]
CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 4.8.0-rc7 #1
Hardware name: Mellanox Technologies Ltd. "MSN2100-CB2F"/"SA001017", BIOS 5.6.5 06/07/2016
task: ffff88017edfea40 task.stack: ffff88017ee10000
RIP: 0010:[<ffffffff815dcc73>] [<ffffffff815dcc73>] netdev_all_lower_get_next_rcu+0x33/0x60
Call Trace:
<IRQ>
[<ffffffffa015de0a>] mlxsw_sp_port_lower_dev_hold+0x5a/0xa0 [mlxsw_spectrum]
[<ffffffffa016f1b0>] mlxsw_sp_router_netevent_event+0x80/0x150 [mlxsw_spectrum]
[<ffffffff810ad07a>] notifier_call_chain+0x4a/0x70
[<ffffffff810ad13a>] atomic_notifier_call_chain+0x1a/0x20
[<ffffffff815ee77b>] call_netevent_notifiers+0x1b/0x20
[<ffffffff815f2eb6>] neigh_update+0x306/0x740
[<ffffffff815f38ce>] neigh_event_ns+0x4e/0xb0
[<ffffffff8165ea3f>] arp_process+0x66f/0x700
[<ffffffff8170214c>] ? common_interrupt+0x8c/0x8c
[<ffffffff8165ec29>] arp_rcv+0x139/0x1d0
[<ffffffff816e505a>] ? vlan_do_receive+0xda/0x320
[<ffffffff815e3794>] __netif_receive_skb_core+0x524/0xab0
[<ffffffff815e6830>] ? dev_queue_xmit+0x10/0x20
[<ffffffffa06d612d>] ? br_forward_finish+0x3d/0xc0 [bridge]
[<ffffffffa06e5796>] ? br_handle_vlan+0xf6/0x1b0 [bridge]
[<ffffffff815e3d38>] __netif_receive_skb+0x18/0x60
[<ffffffff815e3dc0>] netif_receive_skb_internal+0x40/0xb0
[<ffffffff815e3e4c>] netif_receive_skb+0x1c/0x70
[<ffffffffa06d7856>] br_pass_frame_up+0xc6/0x160 [bridge]
[<ffffffffa06d63d7>] ? deliver_clone+0x37/0x50 [bridge]
[<ffffffffa06d656c>] ? br_flood+0xcc/0x160 [bridge]
[<ffffffffa06d7b14>] br_handle_frame_finish+0x224/0x4f0 [bridge]
[<ffffffffa06d7f94>] br_handle_frame+0x174/0x300 [bridge]
[<ffffffff815e3599>] __netif_receive_skb_core+0x329/0xab0
[<ffffffff81374815>] ? find_next_bit+0x15/0x20
[<ffffffff8135e802>] ? cpumask_next_and+0x32/0x50
[<ffffffff810c9968>] ? load_balance+0x178/0x9b0
[<ffffffffa01544a1>] mlxsw_sp_rx_listener_func+0x61/0xb0 [mlxsw_spectrum]
[<ffffffffa005c9f7>] mlxsw_core_skb_receive+0x187/0x200 [mlxsw_core]
[<ffffffffa007332a>] mlxsw_pci_cq_tasklet+0x63a/0x9b0 [mlxsw_pci]
[<ffffffff81091986>] tasklet_action+0xf6/0x110
[<ffffffff81704556>] __do_softirq+0xf6/0x280
[<ffffffff8109213f>] irq_exit+0xdf/0xf0
[<ffffffff817042b4>] do_IRQ+0x54/0xd0
[<ffffffff8170214c>] common_interrupt+0x8c/0x8c
The problem is that netdev_all_lower_get_next_rcu() never advances the
iterator, thereby causing the loop over the lower adjacency list to run
forever.
Fix this by advancing the iterator and avoid the infinite loop.
Fixes: 7ce856aaaf13 ("mlxsw: spectrum: Add couple of lower device helper functions")
Reported-by: Tamir Winetroub <tamirw@mellanox.com>
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc plugins update from Kees Cook:
"This adds a new gcc plugin named "latent_entropy". It is designed to
extract as much possible uncertainty from a running system at boot
time as possible, hoping to capitalize on any possible variation in
CPU operation (due to runtime data differences, hardware differences,
SMP ordering, thermal timing variation, cache behavior, etc).
At the very least, this plugin is a much more comprehensive example
for how to manipulate kernel code using the gcc plugin internals"
* tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
latent_entropy: Mark functions with __latent_entropy
gcc-plugins: Add latent_entropy plugin
The __latent_entropy gcc attribute can be used only on functions and
variables. If it is on a function then the plugin will instrument it for
gathering control-flow entropy. If the attribute is on a variable then
the plugin will initialize it with random contents. The variable must
be an integer, an integer array type or a structure with integer fields.
These specific functions have been selected because they are init
functions (to help gather boot-time entropy), are called at unpredictable
times, or they have variable loops, each of which provide some level of
latent entropy.
Signed-off-by: Emese Revfy <re.emese@gmail.com>
[kees: expanded commit message]
This is a respin of a patch to fix a relatively easily reproducible kernel
panic related to the all_adj_list handling for netdevs in recent kernels.
The following sequence of commands will reproduce the issue:
ip link add link eth0 name eth0.100 type vlan id 100
ip link add link eth0 name eth0.200 type vlan id 200
ip link add name testbr type bridge
ip link set eth0.100 master testbr
ip link set eth0.200 master testbr
ip link add link testbr mac0 type macvlan
ip link delete dev testbr
This creates an upper/lower tree of (excuse the poor ASCII art):
/---eth0.100-eth0
mac0-testbr-
\---eth0.200-eth0
When testbr is deleted, the all_adj_lists are walked, and eth0 is deleted twice from
the mac0 list. Unfortunately, during setup in __netdev_upper_dev_link, only one
reference to eth0 is added, so this results in a panic.
This change adds reference count propagation so things are handled properly.
Matthias Schiffer reported a similar crash in batman-adv:
https://github.com/freifunk-gluon/gluon/issues/680
https://www.open-mesh.org/issues/247
which this patch also seems to resolve.
Signed-off-by: Andrew Collins <acollins@cradlepoint.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next
net/netfilter/nf_tables_netdev.c
Resolve two conflicts before pull request for David's net-next tree:
1) Between c73c24849011 ("netfilter: nf_tables_netdev: remove redundant
ip_hdr assignment") from the net tree and commit ddc8b6027ad0
("netfilter: introduce nft_set_pktinfo_{ipv4, ipv6}_validate()").
2) Between e8bffe0cf964 ("net: Add _nf_(un)register_hooks symbols") and
Aaron Conole's patches to replace list_head with single linked list.
This commit ensures that the rcu read-side lock is held while the
ingress hook is called. This ensures that a call to nf_hook_slow (and
ultimately nf_ingress) will be read protected.
Signed-off-by: Aaron Conole <aconole@bytheb.org>
drivers/net/ethernet/mediatek/mtk_eth_soc.c
drivers/net/ethernet/qlogic/qed/qed_dcbx.c
drivers/net/phy/Kconfig
All conflicts were cases of overlapping commits.
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either
built-in or as a module, use that macro instead of open coding the same.
Using the macro makes the code more readable by helping abstract away some
of the Kconfig built-in and module enable details.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Following few steps will crash kernel -
(a) Create bonding master
> modprobe bonding miimon=50
(b) Create macvlan bridge on eth2
> ip link add link eth2 dev mvl0 address aa:0:0:0:0:01 \
type macvlan
(c) Now try adding eth2 into the bond
> echo +eth2 > /sys/class/net/bond0/bonding/slaves
<crash>
Bonding does lots of things before checking if the device enslaved is
busy or not.
In this case when the notifier call-chain sends notifications, the
bond_netdev_event() assumes that the rx_handler /rx_handler_data is
registered while the bond_enslave() hasn't progressed far enough to
register rx_handler for the new slave.
This patch adds a rx_handler check that can be performed right at the
beginning of the enslave code to avoid getting into this situation.
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
After commit 145dd5f9c88f ("net: flush the softnet backlog in process
context"), we can easily batch calls to flush_all_backlogs() for all
devices processed in rollback_registered_many()
Tested:
Before patch, on an idle host.
modprobe dummy numdummies=10000
perf stat -e context-switches -a rmmod dummy
Performance counter stats for 'system wide':
1,211,798 context-switches
1.302137465 seconds time elapsed
After patch:
225,523 context-switches
0.721623566 seconds time elapsed
switchdev_port_fwd_mark_set() is used to set the 'offload_fwd_mark' of
port netdevs so that packets being flooded by the device won't be
flooded twice.
It works by assigning a unique identifier (the ifindex of the first
bridge port) to bridge ports sharing the same parent ID. This prevents
packets from being flooded twice by the same switch, but will flood
packets through bridge ports belonging to a different switch.
This method is problematic when stacked devices are taken into account,
such as VLANs. In such cases, a physical port netdev can have upper
devices being members in two different bridges, thus requiring two
different 'offload_fwd_mark's to be configured on the port netdev, which
is impossible.
The main problem is that packet and netdev marking is performed at the
physical netdev level, whereas flooding occurs between bridge ports,
which are not necessarily port netdevs.
Instead, packet and netdev marking should really be done in the bridge
driver with the switch driver only telling it which packets it already
forwarded. The bridge driver will mark such packets using the mark
assigned to the ingress bridge port and will prevent the packet from
being forwarded through any bridge port sharing the same mark (i.e.
having the same parent ID).
Remove the current switchdev 'offload_fwd_mark' implementation and
instead implement the proposed method. In addition, make rocker - the
sole user of the mark - use the proposed method.
Currently in process_backlog(), the process_queue dequeuing is
performed with local IRQ disabled, to protect against
flush_backlog(), which runs in hard IRQ context.
This patch moves the flush operation to a work queue and runs the
callback with bottom half disabled to protect the process_queue
against dequeuing.
Since process_queue is now always manipulated in bottom half context,
the irq disable/enable pair around the dequeue operation are removed.
To keep the flush time as low as possible, the flush
works are scheduled on all online cpu simultaneously, using the
high priority work-queue and statically allocated, per cpu,
work structs.
Overall this change increases the time required to destroy a device
to improve slightly the packets reinjection performances.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Minor overlapping changes for both merge conflicts.
Resolution work done by Stephen Rothwell was used
as a reference.
The idea for type_check in dev_get_nest_level() was to count the number
of nested devices of the same type (currently, only macvlan or vlan
devices).
This prevented the false positive lockdep warning on configurations such
as:
eth0 <--- macvlan0 <--- vlan0 <--- macvlan1
However, this doesn't prevent a warning on a configuration such as:
eth1 <--- vlan1 <--- macvlan1
In this case, all the locks end up with a nesting subclass of 1, so
lockdep thinks that there is still a deadlock:
- in the first case we have (macvlan_netdev_addr_lock_key, 1) and then
take (vlan_netdev_xmit_lock_key, 1)
- in the second case, we have (vlan_netdev_xmit_lock_key, 1) and then
take (macvlan_netdev_addr_lock_key, 1)
By removing the linktype check in dev_get_nest_level() and always
incrementing the nesting depth, lockdep considers this configuration
valid.
Convert the per-device linked list into a hashtable. The primary
motivation for this change is that currently, we're not tracking all the
qdiscs in hierarchy (e.g. excluding default qdiscs), as the lookup
performed over the linked list by qdisc_match_from_root() is rather
expensive.
The ultimate goal is to get rid of hidden qdiscs completely, which will
bring much more determinism in user experience.
Reviewed-by: Cong Wang <xiyou.wangcong@gmail.com>
This changes the vfs dentry hashing to mix in the parent pointer at the
_beginning_ of the hash, rather than at the end.
That actually improves both the hash and the code generation, because we
can move more of the computation to the "static" part of the dcache
setup, and do less at lookup runtime.
It turns out that a lot of other hash users also really wanted to mix in
a base pointer as a 'salt' for the hash, and so the slightly extended
interface ends up working well for other cases too.
Users that want a string hash that is purely about the string pass in a
'salt' pointer of NULL.
* merge branch 'salted-string-hash':
fs/dcache.c: Save one 32-bit multiply in dcache lookup
vfs: make the string hashes salt the hash
Add one new netdev op for drivers implementing the BPF_PROG_TYPE_XDP
filter. The single op is used for both setup/query of the xdp program,
modelled after ndo_setup_tc.
Signed-off-by: Brenden Blanco <bblanco@plumgrid.com>
An important information for the napi_poll tracepoint is knowing
the work done (packets processed) by the napi_poll() call. Add
both the work done and budget, as they are related.
Handle trace_napi_poll() param change in dropwatch/drop_monitor
and in python perf script netdev-times.py in backward compat way,
as python fortunately supports optional parameter handling.
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
L2 upper device needs to propagate neigh_construct/destroy calls down to
lower devices. Do this by defining default ndo functions and use them in
team, bond, bridge and vlan.
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
Add functions that iterate over lower devices and find port device.
As a dependency add netdev_for_each_all_lower_dev and
netdev_for_each_all_lower_dev_rcu macro with
netdev_all_lower_get_next and netdev_all_lower_get_next_rcu shelpers.
Also, add functions to return mlxsw struct according to lower device
found and mlxsw_port struct with a reference to lower device.
Qdisc performance suffers when packets are dropped at enqueue()
time because drops (kfree_skb()) are done while qdisc lock is held,
delaying a dequeue() draining the queue.
Nominal throughput can be reduced by 50 % when this happens,
at a time we would like the dequeue() to proceed as fast as possible.
Even FQ is vulnerable to this problem, while one of FQ goals was
to provide some flow isolation.
This patch adds a 'struct sk_buff **to_free' parameter to all
qdisc->enqueue(), and in qdisc_drop() helper.
I measured a performance increase of up to 12 %, but this patch
is a prereq so that future batches in enqueue() can fly.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
The space is missing after ',', and this will introduce much more
noise when checking patch around.
Signed-off-by: Wei Tang <tangwei@cmss.chinamobile.com>
This patch fixes the checkpatch.pl error to dev.c:
ERROR: do not initialise statics to 0
We always mixed in the parent pointer into the dentry name hash, but we
did it late at lookup time. It turns out that we can simplify that
lookup-time action by salting the hash with the parent pointer early
instead of late.
A few other users of our string hashes also wanted to mix in their own
pointers into the hash, and those are updated to use the same mechanism.
Hash users that don't have any particular initial salt can just use the
NULL pointer as a no-salt.
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: George Spelvin <linux@sciencehorizons.net>
Respect the stack's xmit_recursion limit for calls into dev_queue_xmit().
Currently, they are not handeled by the limiter when attached to clsact's
egress parent, for example, and a buggy program redirecting it to the
same device again could run into stack overflow eventually. It would be
good if we could notify an admin to give him a chance to react. We reuse
xmit_recursion instead of having one private to eBPF, so that the stack's
current recursion depth will be taken into account as well. Follow-up to
commit 3896d655f4d4 ("bpf: introduce bpf_clone_redirect() helper") and
27b29f63058d ("bpf: add bpf_redirect() helper").
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
When in kdump kernel, reduce memory usage by only using a single Queue
Set for multiqueue devices. So make netif_get_num_default_rss_queues()
return one, when in kdump kernel.
Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com>
