The rcu callback ha_rcu_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(ha_rcu_free).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
addr_type of 0 means that the type should be adopted from from_dev and
not from __hw_addr_del_multiple(). Unfortunately it isn't so and
addr_type will always be considered. Fix this by implementing the
considered and documented behavior.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Signed-off-by: Gilles Espinasse <g.esp@free.fr>
As pointed by Randy Dunlap, we must include linux/proc_fs.h in
net/core/dev_addr_lists.c, regardless of CONFIG_PROC_FS
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>,
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
+little renaming of unicast functions to be smooth with multicast ones
