path: root/net/core/drop_monitor.c
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-05-21dropmon: add ability to detect when hardware dropsrxpacketsNeil Horman
Patch to add the ability to detect drops in hardware interfaces via dropwatch. Adds a tracepoint to net_rx_action to signal everytime a napi instance is polled. The dropmon code then periodically checks to see if the rx_frames counter has changed, and if so, adds a drop notification to the netlink protocol, using the reserved all-0's vector to indicate the drop location was in hardware, rather than somewhere in the code. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> include/linux/net_dropmon.h | 8 ++ include/trace/napi.h | 11 +++ net/core/dev.c | 5 + net/core/drop_monitor.c | 124 ++++++++++++++++++++++++++++++++++++++++++-- net/core/net-traces.c | 4 + net/core/netpoll.c | 2 6 files changed, 149 insertions(+), 5 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27drop_monitor: Update netlink protocol to include netlink attribute header in ↵Neil Horman
alert message When I initially implemented this protocol, I disregarded the use of netlink attribute headers, thinking for my purposes they weren't needed. I've come to find out that, as I'm starting to work with sending down messages with associated data (like config messages), the kernel code spits out warnings about trailing data in a netlink skb that doesn't have an associated header on it. As such, I'm going to start including attribute headers in my netlink transaction, and so for completeness, I should likely include them on messages bound from the kernel to user space. This patch adds that header to the kernel, and bumps the protocol version accordingly Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-03-13Network Drop Monitor: Adding drop monitor implementation & Netlink protocolNeil Horman
Signed-off-by: Neil Horman <nhorman@tuxdriver.com> include/linux/net_dropmon.h | 56 +++++++++ net/core/drop_monitor.c | 263 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 319 insertions(+) Signed-off-by: David S. Miller <davem@davemloft.net>
