commit f9fc54d313fab2834f44f516459cdc8ac91d797f upstream.
The return type for get_regs_len in struct ethtool_ops is int,
the hns3 driver may return error when failing to get the regs
len by sending cmd to firmware.
Signed-off-by: Yunsheng Lin <linyunsheng@huawei.com>
Cc: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit 0ee4e76937d69128a6a66861ba393ebdc2ffc8a2 ]
ethtool_get_regs() allocates a buffer of size ops->get_regs_len(),
and pass it to the kernel driver via ops->get_regs() for filling.
There is no restriction about what the kernel drivers can or cannot do
with the open ethtool_regs structure. They usually set regs->version
and ignore regs->len or set it to the same size as ops->get_regs_len().
But if userspace allocates a smaller buffer for the registers dump,
we would cause a userspace buffer overflow in the final copy_to_user()
call, which uses the regs.len value potentially reset by the driver.
To fix this, make this case obvious and store regs.len before calling
ops->get_regs(), to only copy as much data as requested by userspace,
up to the value returned by ops->get_regs_len().
While at it, remove the redundant check for non-null regbuf.
Signed-off-by: Vivien Didelot <vivien.didelot@gmail.com>
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
[ Upstream commit 3d8830266ffc28c16032b859e38a0252e014b631 ]
NULL or ZERO_SIZE_PTR will be returned for zero sized memory
request, and derefencing them will lead to a segfault
so it is unnecessory to call vzalloc for zero sized memory
request and not call functions which maybe derefence the
NULL allocated memory
this also fixes a possible memory leak if phy_ethtool_get_stats
returns error, memory should be freed before exit
Signed-off-by: Li RongQing <lirongqing@baidu.com>
Reviewed-by: Wang Li <wangli39@baidu.com>
In dev_ethtool(), the eth command 'ethcmd' is firstly copied from the
use-space buffer 'useraddr' and checked to see whether it is
ETHTOOL_PERQUEUE. If yes, the sub-command 'sub_cmd' is further copied from
the user space. Otherwise, 'sub_cmd' is the same as 'ethcmd'. Next,
according to 'sub_cmd', a permission check is enforced through the function
ns_capable(). For example, the permission check is required if 'sub_cmd' is
ETHTOOL_SCOALESCE, but it is not necessary if 'sub_cmd' is
ETHTOOL_GCOALESCE, as suggested in the comment "Allow some commands to be
done by anyone". The following execution invokes different handlers
according to 'ethcmd'. Specifically, if 'ethcmd' is ETHTOOL_PERQUEUE,
ethtool_set_per_queue() is called. In ethtool_set_per_queue(), the kernel
object 'per_queue_opt' is copied again from the user-space buffer
'useraddr' and 'per_queue_opt.sub_command' is used to determine which
operation should be performed. Given that the buffer 'useraddr' is in the
user space, a malicious user can race to change the sub-command between the
two copies. In particular, the attacker can supply ETHTOOL_PERQUEUE and
ETHTOOL_GCOALESCE to bypass the permission check in dev_ethtool(). Then
before ethtool_set_per_queue() is called, the attacker changes
ETHTOOL_GCOALESCE to ETHTOOL_SCOALESCE. In this way, the attacker can
bypass the permission check and execute ETHTOOL_SCOALESCE.
This patch enforces a check in ethtool_set_per_queue() after the second
copy from 'useraddr'. If the sub-command is different from the one obtained
in the first copy in dev_ethtool(), an error code EINVAL will be returned.
Fixes: f38d138a7da6 ("net/ethtool: support set coalesce per queue")
Signed-off-by: Wenwen Wang <wang6495@umn.edu>
In ethtool_get_rxnfc(), the eth command 'cmd' is compared against
'ETHTOOL_GRXFH' to see whether it is necessary to adjust the variable
'info_size'. Then the whole structure of 'info' is copied from the
user-space buffer 'useraddr' with 'info_size' bytes. In the following
execution, 'info' may be copied again from the buffer 'useraddr' depending
on the 'cmd' and the 'info.flow_type'. However, after these two copies,
there is no check between 'cmd' and 'info.cmd'. In fact, 'cmd' is also
copied from the buffer 'useraddr' in dev_ethtool(), which is the caller
function of ethtool_get_rxnfc(). Given that 'useraddr' is in the user
space, a malicious user can race to change the eth command in the buffer
between these copies. By doing so, the attacker can supply inconsistent
data and cause undefined behavior because in the following execution 'info'
will be passed to ops->get_rxnfc().
This patch adds a necessary check on 'info.cmd' and 'cmd' to confirm that
they are still same after the two copies in ethtool_get_rxnfc(). Otherwise,
Add flag wol_enabled to struct net_device indicating whether
Wake-on-LAN is enabled. As first user phy_suspend() will use it to
decide whether PHY can be suspended or not.
Fixes: f1e911d5d0df ("r8169: add basic phylib support")
Fixes: e8cfd9d6c772 ("net: phy: call state machine synchronously in phy_stop")
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
So it should not fail with EPERM even though it is no longer implemented...
This is a fix for:
(userns)$ egrep ^Cap /proc/self/status
CapInh: 0000003fffffffff
CapPrm: 0000003fffffffff
CapEff: 0000003fffffffff
CapBnd: 0000003fffffffff
CapAmb: 0000003fffffffff
(userns)$ tcpdump -i usb_rndis0
tcpdump: WARNING: usb_rndis0: SIOCETHTOOL(ETHTOOL_GUFO) ioctl failed: Operation not permitted
Warning: Kernel filter failed: Bad file descriptor
tcpdump: can't remove kernel filter: Bad file descriptor
With this change it returns EOPNOTSUPP instead of EPERM.
See also https://github.com/the-tcpdump-group/libpcap/issues/689
Fixes: 08a00fea6de2 "net: Remove references to NETIF_F_UFO from ethtool."
Signed-off-by: Maciej Żenczykowski <maze@google.com>
This patch adds a netdev feature to configure TLS RX inline crypto offload.
Signed-off-by: Ilya Lesokhin <ilyal@mellanox.com>
Signed-off-by: Boris Pismenny <borisp@mellanox.com>
The vzalloc() function has no 2-factor argument form, so multiplication
factors need to be wrapped in array_size(). This patch replaces cases of:
vzalloc(a * b)
with:
vzalloc(array_size(a, b))
as well as handling cases of:
vzalloc(a * b * c)
with:
vzalloc(array3_size(a, b, c))
This does, however, attempt to ignore constant size factors like:
vzalloc(4 * 1024)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
vzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
vzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
vzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
vzalloc(
- sizeof(char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
vzalloc(
- sizeof(u8) * COUNT
+ COUNT
vzalloc(
- sizeof(__u8) * COUNT
+ COUNT
vzalloc(
- sizeof(char) * COUNT
+ COUNT
vzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
vzalloc(
- sizeof(TYPE) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_ID
vzalloc(
- sizeof(TYPE) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * COUNT_CONST
vzalloc(
- sizeof(THING) * (COUNT_ID)
+ array_size(COUNT_ID, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_ID
vzalloc(
- sizeof(THING) * (COUNT_CONST)
+ array_size(COUNT_CONST, sizeof(THING))
vzalloc(
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
vzalloc(
- SIZE * COUNT
+ array_size(COUNT, SIZE)
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
vzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
vzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
vzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
vzalloc(
- sizeof(TYPE) * COUNT * STRIDE
vzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
vzalloc(
- sizeof(THING) * (COUNT) * STRIDE
vzalloc(
- sizeof(THING) * COUNT * (STRIDE)
vzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
vzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
vzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
vzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
vzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
vzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
vzalloc(
- COUNT * (STRIDE) * SIZE
vzalloc(
- COUNT * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * SIZE
vzalloc(
- COUNT * (STRIDE) * (SIZE)
vzalloc(
- (COUNT) * STRIDE * (SIZE)
vzalloc(
- (COUNT) * (STRIDE) * (SIZE)
vzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
vzalloc(C1 * C2 * C3, ...)
vzalloc(
- E1 * E2 * E3
+ array3_size(E1, E2, E3)
// And then all remaining 2 factors products when they're not all constants.
expression E1, E2;
constant C1, C2;
vzalloc(C1 * C2, ...)
vzalloc(
- E1 * E2
+ array_size(E1, E2)
The kzalloc() function has a 2-factor argument form, kcalloc(). This
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
kzalloc(4 * 1024, gfp)
type TYPE;
kzalloc(
+ sizeof(TYPE) * E
kzalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
kzalloc(
+ COUNT
type TYPE;
expression THING;
- kzalloc
+ kcalloc
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
kzalloc(
// Any remaining multi-factor products, first at least 3-factor products,
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
kmalloc_array(array_size(a, b), c, gfp)
kmalloc(4 * 1024, gfp)
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
type TYPE;
kmalloc(
+ sizeof(TYPE) * E
kmalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
type TYPE;
expression THING;
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
kmalloc(
- (E1) * (E2) * E3
kmalloc(
kmalloc(
- E1 * E2 * E3
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
Overlapping changes in selftests Makefile.
In ethtool_get_rxnfc(), the object "info" is firstly copied from
user-space. If the FLOW_RSS flag is set in the member field flow_type of
"info" (and cmd is ETHTOOL_GRXFH), info needs to be copied again from
user-space because FLOW_RSS is newer and has new definition, as mentioned
in the comment. However, given that the user data resides in user-space, a
malicious user can race to change the data after the first copy. By doing
so, the user can inject inconsistent data. For example, in the second
copy, the FLOW_RSS flag could be cleared in the field flow_type of "info".
In the following execution, "info" will be used in the function
ops->get_rxnfc(). Such inconsistent data can potentially lead to unexpected
information leakage since ops->get_rxnfc() will prepare various types of
data according to flow_type, and the prepared data will be eventually
copied to user-space. This inconsistent data may also cause undefined
behaviors based on how ops->get_rxnfc() is implemented.
This patch simply re-verifies the flow_type field of "info" after the
second copy. If the value is not as expected, an error code will be
returned.
This patch adds a netdev feature to configure TLS TX offloads.
Signed-off-by: Aviad Yehezkel <aviadye@mellanox.com>
Add a new callback: get_ethtool_phy_stats() which allows network device
drivers not making use of the PHY library to return PHY statistics.
Update ethtool_get_phy_stats(), __ethtool_get_sset_count() and
__ethtool_get_strings() accordingly to interogate the network device
about ETH_SS_PHY_STATS.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
In order to make it possible for network device drivers that do not
necessarily have a phy_device attached, but still report PHY statistics,
have a preliminary refactoring consisting in creating helper functions
that encapsulate the PHY device driver knowledge within PHYLIB.
Virtual devices such as tunnels and bonding can handle large packets.
Only segment packets when reaching a physical or loopback device.
Signed-off-by: Willem de Bruijn <willemb@google.com>
Ethtool option enables TLS record offload on HW, user
configures the feature for netdev capable of Inline TLS.
This allows user to define custom sk_prot for Inline TLS sock
Signed-off-by: Atul Gupta <atul.gupta@chelsio.com>
Provide a pointer to the SFP bus in struct net_device, so that the
ethtool module EEPROM methods can access the SFP directly, rather
than needing every user to provide a hook for it.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
In the event where the device unexpectedly becomes unresponsive
for a long period of time, flow control mechanism may propagate
pause frames which will cause congestion spreading to the entire
network.
To prevent this scenario, when the device is stalled for a period
longer than a pre-configured timeout, flow control mechanisms are
automatically disabled.
This patch adds support for the ETHTOOL_PFC_STALL_PREVENTION
as a tunable.
This API provides support for configuring flow control storm prevention
timeout (msec).
Signed-off-by: Inbar Karmy <inbark@mellanox.com>
Cc: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
We use a two-step process to configure a filter with RSS spreading. First,
the RSS context is allocated and configured using ETHTOOL_SRSSH; this
returns an identifier (rss_context) which can then be passed to subsequent
invocations of ETHTOOL_SRXCLSRLINS to specify that the offset from the RSS
indirection table lookup should be added to the queue number (ring_cookie)
when delivering the packet. Drivers for devices which can only use the
indirection table entry directly (not add it to a base queue number)
should reject rule insertions combining RSS with a nonzero ring_cookie.
Signed-off-by: Edward Cree <ecree@solarflare.com>
If ethtool_ops->get_fecparam returns an error, pass that error on to the
user, rather than ignoring it.
Fixes: 1a5f3da20bd9 ("net: ethtool: add support for forward error correction modes")
with bitmap_{from,to}_arr32 over the kernel. Additionally to it:
* __check_eq_bitmap() now takes single nbits argument.
* __check_eq_u32_array is not used in new test but may be used in
future. So I don't remove it here, but annotate as __used.
Tested on arm64 and 32-bit BE mips.
[arnd@arndb.de: perf: arm_dsu_pmu: convert to bitmap_from_arr32]
Link: http://lkml.kernel.org/r/20180201172508.5739-2-ynorov@caviumnetworks.com
[ynorov@caviumnetworks.com: fix net/core/ethtool.c]
Link: http://lkml.kernel.org/r/20180205071747.4ekxtsbgxkj5b2fz@yury-thinkpad
Link: http://lkml.kernel.org/r/20171228150019.27953-2-ynorov@caviumnetworks.com
Signed-off-by: Yury Norov <ynorov@caviumnetworks.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: David Decotigny <decot@googlers.com>,
Cc: David S. Miller <davem@davemloft.net>,
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Heiner Kallweit <hkallweit1@gmail.com>
Add a sanity check to ensure that all requested ring parameters
are within bounds, which should reduce errors in driver implementation.
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.com>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
In kernel log ths message appears on every boot:
"warning: `NetworkChangeNo' uses legacy ethtool link settings API,
link modes are only partially reported"
When ethtool link settings API changed, it started complaining about
usages of old API. Ironically, the original patch was from google but
the application using the legacy API is chrome.
Linux ABI is fixed as much as possible. The kernel must not break it
and should not complain about applications using legacy API's.
This patch just removes the warning since using legacy API's
in Linux is perfectly acceptable.
Fixes: 3f1ac7a700d0 ("net: ethtool: add new ETHTOOL_xLINKSETTINGS API")
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: David Decotigny <decot@googlers.com>
Introduce NETIF_F_GRO_HW feature flag for NICs that support hardware
GRO. With this flag, we can now independently turn on or off hardware
GRO when GRO is on. Previously, drivers were using NETIF_F_GRO to
control hardware GRO and so it cannot be independently turned on or
off without affecting GRO.
Hardware GRO (just like GRO) guarantees that packets can be re-segmented
by TSO/GSO to reconstruct the original packet stream. Logically,
GRO_HW should depend on GRO since it a subset, but we will let
individual drivers enforce this dependency as they see fit.
Since NETIF_F_GRO is not propagated between upper and lower devices,
NETIF_F_GRO_HW should follow suit since it is a subset of GRO. In other
words, a lower device can independent have GRO/GRO_HW enabled or disabled
and no feature propagation is required. This will preserve the current
GRO behavior. This can be changed later if we decide to propagate GRO/
GRO_HW/RXCSUM from upper to lower devices.
Cc: Ariel Elior <Ariel.Elior@cavium.com>
Cc: everest-linux-l2@cavium.com
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
There were quite a few overlapping sets of changes here.
Daniel's bug fix for off-by-ones in the new BPF branch instructions,
along with the added allowances for "data_end > ptr + x" forms
collided with the metadata additions.
Along with those three changes came veritifer test cases, which in
their final form I tried to group together properly. If I had just
trimmed GIT's conflict tags as-is, this would have split up the
meta tests unnecessarily.
In the socketmap code, a set of preemption disabling changes
overlapped with the rename of bpf_compute_data_end() to
bpf_compute_data_pointers().
Changes were made to the mv88e6060.c driver set addr method
which got removed in net-next.
The hyperv transport socket layer had a locking change in 'net'
which overlapped with a change of socket state macro usage
in 'net-next'.
Commit 9cab88726929605 ("net: ethtool: Add back transceiver type")
restores the transceiver type to struct ethtool_link_settings and
convert_link_ksettings_to_legacy_settings() but forgets to remove the
error check for the same in convert_legacy_settings_to_link_ksettings().
This prevents older versions of ethtool to change link settings.
# ethtool --version
ethtool version 3.16
# ethtool -s eth0 autoneg on speed 100 duplex full
Cannot set new settings: Invalid argument
not setting speed
not setting duplex
not setting autoneg
While newer versions of ethtool works.
# ethtool --version
ethtool version 4.10
[ 57.703268] sh-eth ee700000.ethernet eth0: Link is Down
[ 59.618227] sh-eth ee700000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Fixes: 19cab88726929605 ("net: ethtool: Add back transceiver type")
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Reported-by: Renjith R V <renjith.rv@quest-global.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
This function provides a way to intersect two link masks together to
find the common ground between them. For example in i40e, the driver
first generates link masks for what is supported by the PHY type. The
driver then gets the link masks for what the NVM supports. The
resulting intersection between them yields what can truly be supported.
Signed-off-by: Alan Brady <alan.brady@intel.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
Commit 3f1ac7a700d0 ("net: ethtool: add new ETHTOOL_xLINKSETTINGS API")
deprecated the ethtool_cmd::transceiver field, which was fine in
premise, except that the PHY library was actually using it to report the
type of transceiver: internal or external.
Use the first word of the reserved field to put this __u8 transceiver
field back in. It is made read-only, and we don't expect the
ETHTOOL_xLINKSETTINGS API to be doing anything with this anyway, so this
is mostly for the legacy path where we do:
ethtool_get_settings()
-> dev->ethtool_ops->get_link_ksettings()
-> convert_link_ksettings_to_legacy_settings()
to have no information loss compared to the legacy get_settings API.
Forward Error Correction (FEC) modes i.e Base-R
and Reed-Solomon modes are introduced in 25G/40G/100G standards
for providing good BER at high speeds. Various networking devices
which support 25G/40G/100G provides ability to manage supported FEC
modes and the lack of FEC encoding control and reporting today is a
source for interoperability issues for many vendors.
FEC capability as well as specific FEC mode i.e. Base-R
or RS modes can be requested or advertised through bits D44:47 of
base link codeword.
This patch set intends to provide option under ethtool to manage
and report FEC encoding settings for networking devices as per
IEEE 802.3 bj, bm and by specs.
set-fec/show-fec option(s) are designed to provide control and
report the FEC encoding on the link.
SET FEC option:
root@tor: ethtool --set-fec swp1 encoding [off | RS | BaseR | auto]
Encoding: Types of encoding
Off : Turning off any encoding
RS : enforcing RS-FEC encoding on supported speeds
BaseR : enforcing Base R encoding on supported speeds
Auto : IEEE defaults for the speed/medium combination
Here are a few examples of what we would expect if encoding=auto:
- if autoneg is on, we are expecting FEC to be negotiated as on or off
as long as protocol supports it
- if the hardware is capable of detecting the FEC encoding on it's
receiver it will reconfigure its encoder to match
- in absence of the above, the configuration would be set to IEEE
defaults.
>From our understanding , this is essentially what most hardware/driver
combinations are doing today in the absence of a way for users to
control the behavior.
SHOW FEC option:
root@tor: ethtool --show-fec swp1
FEC parameters for swp1:
Active FEC encodings: RS
Configured FEC encodings: RS | BaseR
ETHTOOL DEVNAME output modification:
ethtool devname output:
root@tor:~# ethtool swp1
Settings for swp1:
root@hpe-7712-03:~# ethtool swp18
Settings for swp18:
Supported ports: [ FIBRE ]
Supported link modes: 40000baseCR4/Full
40000baseSR4/Full
40000baseLR4/Full
100000baseSR4/Full
100000baseCR4/Full
100000baseLR4_ER4/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: [RS | BaseR | None | Not reported]
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: [RS | BaseR | None | Not reported]
<<<< One or more FEC modes
Speed: 100000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 106
Transceiver: internal
Auto-negotiation: off
Link detected: yes
This patch includes following changes
a) New ETHTOOL_SFECPARAM/SFECPARAM API, handled by
the new get_fecparam/set_fecparam callbacks, provides support
for configuration of forward error correction modes.
b) Link mode bits for FEC modes i.e. None (No FEC mode), RS, BaseR/FC
are defined so that users can configure these fec modes for supported
and advertising fields as part of link autonegotiation.
Signed-off-by: Vidya Sagar Ravipati <vidya.chowdary@gmail.com>
Signed-off-by: Dustin Byford <dustin@cumulusnetworks.com>
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
This adds a new netdevice feature, so that the offloading of RX port for
UDP tunnels can be disabled by the administrator on some netdevices,
using the "rx-udp_tunnel-port-offload" feature in ethtool.
This feature is set for all devices that provide ndo_udp_tunnel_add.
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
It is going away.
This patch adds netdev features to configure IPsec offloads.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
CRC32 engines are usually easily available in hardware and generate
OK spread for RSS hash. Add CRC32 RSS hash function to ethtool API.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
The conflict was an interaction between a bug fix in the
netvsc driver in 'net' and an optimization of the RX path
in 'net-next'.
We added generic support for busy polling in NAPI layer in linux-4.5
No network driver uses ndo_busy_poll() anymore, we can get rid
of the pointer in struct net_device_ops, and its use in sk_busy_loop()
Saves NETIF_F_BUSY_POLL features bit.
If ->get_regs_len() callback return 0, we allocate 0 bytes of memory,
what print ugly warning in dmesg, which can be found further below.
This happen on mac80211 devices where ieee80211_get_regs_len() just
return 0 and driver only fills ethtool_regs structure and actually
do not provide any dump. However I assume this can happen on other
drivers i.e. when for some devices driver provide regs dump and for
others do not. Hence preventing to to print warning in ethtool code
seems to be reasonable.
ethtool: vmalloc: allocation failure: 0 bytes, mode:0x24080c2(GFP_KERNEL|__GFP_HIGHMEM|__GFP_ZERO)
<snip>
Call Trace:
[<ffffffff813bde47>] dump_stack+0x63/0x8c
[<ffffffff811b0a1f>] warn_alloc+0x13f/0x170
[<ffffffff811f0476>] __vmalloc_node_range+0x1e6/0x2c0
[<ffffffff811f0874>] vzalloc+0x54/0x60
[<ffffffff8169986c>] dev_ethtool+0xb4c/0x1b30
[<ffffffff816adbb1>] dev_ioctl+0x181/0x520
[<ffffffff816714d2>] sock_do_ioctl+0x42/0x50
<snip>
Mem-Info:
active_anon:435809 inactive_anon:173951 isolated_anon:0
active_file:835822 inactive_file:196932 isolated_file:0
unevictable:0 dirty:8 writeback:0 unstable:0
slab_reclaimable:157732 slab_unreclaimable:10022
mapped:83042 shmem:306356 pagetables:9507 bounce:0
free:130041 free_pcp:1080 free_cma:0
Node 0 active_anon:1743236kB inactive_anon:695804kB active_file:3343288kB inactive_file:787728kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:332168kB dirty:32kB writeback:0kB shmem:0kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1225424kB writeback_tmp:0kB unstable:0kB pages_scanned:0 all_unreclaimable? no
Node 0 DMA free:15900kB min:136kB low:168kB high:200kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15984kB managed:15900kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
lowmem_reserve[]: 0 3187 7643 7643
Node 0 DMA32 free:419732kB min:28124kB low:35152kB high:42180kB active_anon:541180kB inactive_anon:248988kB active_file:1466388kB inactive_file:389632kB unevictable:0kB writepending:0kB present:3370280kB managed:3290932kB mlocked:0kB slab_reclaimable:217184kB slab_unreclaimable:4180kB kernel_stack:160kB pagetables:984kB bounce:0kB free_pcp:2236kB local_pcp:660kB free_cma:0kB
lowmem_reserve[]: 0 0 4456 4456
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
under memory pressure 'ethtool -S' command may warn:
[ 2374.385195] ethtool: page allocation failure: order:4, mode:0x242c0c0
[ 2374.405573] CPU: 12 PID: 40211 Comm: ethtool Not tainted
[ 2374.423071] Call Trace:
[ 2374.423076] [<ffffffff8148cb29>] dump_stack+0x4d/0x64
[ 2374.423080] [<ffffffff811667cb>] warn_alloc_failed+0xeb/0x150
[ 2374.423082] [<ffffffff81169cd3>] ? __alloc_pages_direct_compact+0x43/0xf0
[ 2374.423084] [<ffffffff8116a25c>] __alloc_pages_nodemask+0x4dc/0xbf0
[ 2374.423091] [<ffffffffa0023dc2>] ? cmd_exec+0x722/0xcd0 [mlx5_core]
[ 2374.423095] [<ffffffff811b3dcc>] alloc_pages_current+0x8c/0x110
[ 2374.423097] [<ffffffff81168859>] alloc_kmem_pages+0x19/0x90
[ 2374.423099] [<ffffffff81186e5e>] kmalloc_order_trace+0x2e/0xe0
[ 2374.423101] [<ffffffff811c0084>] __kmalloc+0x204/0x220
[ 2374.423105] [<ffffffff816c269e>] dev_ethtool+0xe4e/0x1f80
[ 2374.423106] [<ffffffff816b967e>] ? dev_get_by_name_rcu+0x5e/0x80
[ 2374.423108] [<ffffffff816d6926>] dev_ioctl+0x156/0x560
[ 2374.423111] [<ffffffff811d4c68>] ? mem_cgroup_commit_charge+0x78/0x3c0
[ 2374.423117] [<ffffffff8169d542>] sock_do_ioctl+0x42/0x50
[ 2374.423119] [<ffffffff8169d9c3>] sock_ioctl+0x1b3/0x250
[ 2374.423121] [<ffffffff811f0f42>] do_vfs_ioctl+0x92/0x580
[ 2374.423123] [<ffffffff8100222b>] ? do_audit_syscall_entry+0x4b/0x70
[ 2374.423124] [<ffffffff8100287c>] ? syscall_trace_enter_phase1+0xfc/0x120
[ 2374.423126] [<ffffffff811f14a9>] SyS_ioctl+0x79/0x90
[ 2374.423127] [<ffffffff81002bb0>] do_syscall_64+0x50/0xa0
[ 2374.423129] [<ffffffff817e19bc>] entry_SYSCALL64_slow_path+0x25/0x25
~1160 mlx5 counters ~= order 4 allocation which is unlikely to succeed
under memory pressure. Convert them to vzalloc() as ethtool_get_regs() does.
Also take care of drivers without counters similar to
commit 67ae7cf1eeda ("ethtool: Allow zero-length register dumps again")
and reduce warn_on to warn_on_once.
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Ethtool channels respond struct was uninitialized when querying device
channel boundaries settings. As a result, unreported fields by the driver
hold garbage. This may cause sending unsupported params to driver.
Fixes: 8bf368620486 ('ethtool: ensure channel counts are within bounds ...')
Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com>
CC: John W. Linville <linville@tuxdriver.com>
udplite conflict is resolved by taking what 'net-next' did
which removed the backlog receive method assignment, since
it is no longer necessary.
Two entries were added to the non-priv ethtool operations
switch statement, one in 'net' and one in 'net-next, so
simple overlapping changes.
The ETHTOOL_GLINKSETTINGS command is deprecating the ETHTOOL_GSET
command and likewise it shouldn't require the CAP_NET_ADMIN capability.
Signed-off-by: Miroslav Lichvar <mlichvar@redhat.com>
PHY drivers should be able to rely on the caller of {get,set}_tunable to
have acquired the PHY device mutex, in order to both serialize against
concurrent calls of these functions, but also against PHY state machine
changes. All ethtool PHY-level functions do this, except
{get,set}_tunable, so we make them consistent here as well.
We need to update the Microsemi PHY driver in the same commit to avoid
introducing either deadlocks, or lack of proper locking.
Fixes: 968ad9da7e0e ("ethtool: Implements ETHTOOL_PHY_GTUNABLE/ETHTOOL_PHY_STUNABLE")
Fixes: 310d9ad57ae0 ("net: phy: Add downshift get/set support in Microsemi PHYs driver")
Reviewed-by: Allan W. Nielsen <allan.nielsen@microsemi.com>
Adding validation support for the ETHTOOL_PHY_DOWNSHIFT. Functional
implementation needs to be done in the individual PHY drivers.
Signed-off-by: Raju Lakkaraju <Raju.Lakkaraju@microsemi.com>
Signed-off-by: Allan W. Nielsen <allan.nielsen@microsemi.com>
Adding get_tunable/set_tunable function pointer to the phy_driver
structure, and uses these function pointers to implement the
ETHTOOL_PHY_GTUNABLE/ETHTOOL_PHY_STUNABLE ioctls.
SCTP has this pecualiarity that its packets cannot be just segmented to
(P)MTU. Its chunks must be contained in IP segments, padding respected.
So we can't just generate a big skb, set gso_size to the fragmentation
point and deliver it to IP layer.
This patch takes a different approach. SCTP will now build a skb as it
would be if it was received using GRO. That is, there will be a cover
skb with protocol headers and children ones containing the actual
segments, already segmented to a way that respects SCTP RFCs.
With that, we can tell skb_segment() to just split based on frag_list,
trusting its sizes are already in accordance.
This way SCTP can benefit from GSO and instead of passing several
packets through the stack, it can pass a single large packet.
v2:
- Added support for receiving GSO frames, as requested by Dave Miller.
- Clear skb->cb if packet is GSO (otherwise it's not used by SCTP)
- Added heuristics similar to what we have in TCP for not generating
single GSO packets that fills cwnd.
v3:
- consider sctphdr size in skb_gso_transport_seglen()
- rebased due to 5c7cdf339af5 ("gso: Remove arbitrary checks for
unsupported GSO")
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Tested-by: Xin Long <lucien.xin@gmail.com>
This patch defines two new GSO definitions SKB_GSO_IPXIP4 and
SKB_GSO_IPXIP6 along with corresponding NETIF_F_GSO_IPXIP4 and
NETIF_F_GSO_IPXIP6. These are used to described IP in IP
tunnel and what the outer protocol is. The inner protocol
can be deduced from other GSO types (e.g. SKB_GSO_TCPV4 and
SKB_GSO_TCPV6). The GSO types of SKB_GSO_IPIP and SKB_GSO_SIT
are removed (these are both instances of SKB_GSO_IPXIP4).
SKB_GSO_IPXIP6 will be used when support for GSO with IP
encapsulation over IPv6 is added.
Signed-off-by: Tom Herbert <tom@herbertland.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
