path: root/net/core/gro_cells.c
2019-01-09gro_cell: add napi_disable in gro_cells_destroyLorenzo Bianconi
[ Upstream commit 8e1da73acded4751a93d4166458a7e640f37d26c ] Add napi_disable routine in gro_cells_destroy since starting from commit c42858eaf492 ("gro_cells: remove spinlock protecting receive queues") gro_cell_poll and gro_cells_destroy can run concurrently on napi_skbs list producing a kernel Oops if the tunnel interface is removed while gro_cell_poll is running. The following Oops has been triggered removing a vxlan device while the interface is receiving traffic [ 5628.948853] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 [ 5628.949981] PGD 0 P4D 0 [ 5628.950308] Oops: 0002 [#1] SMP PTI [ 5628.950748] CPU: 0 PID: 9 Comm: ksoftirqd/0 Not tainted 4.20.0-rc6+ #41 [ 5628.952940] RIP: 0010:gro_cell_poll+0x49/0x80 [ 5628.955615] RSP: 0018:ffffc9000004fdd8 EFLAGS: 00010202 [ 5628.956250] RAX: 0000000000000000 RBX: ffffe8ffffc08150 RCX: 0000000000000000 [ 5628.957102] RDX: 0000000000000000 RSI: ffff88802356bf00 RDI: ffffe8ffffc08150 [ 5628.957940] RBP: 0000000000000026 R08: 0000000000000000 R09: 0000000000000000 [ 5628.958803] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000040 [ 5628.959661] R13: ffffe8ffffc08100 R14: 0000000000000000 R15: 0000000000000040 [ 5628.960682] FS: 0000000000000000(0000) GS:ffff88803ea00000(0000) knlGS:0000000000000000 [ 5628.961616] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 5628.962359] CR2: 0000000000000008 CR3: 000000000221c000 CR4: 00000000000006b0 [ 5628.963188] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 5628.964034] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 [ 5628.964871] Call Trace: [ 5628.965179] net_rx_action+0xf0/0x380 [ 5628.965637] __do_softirq+0xc7/0x431 [ 5628.966510] run_ksoftirqd+0x24/0x30 [ 5628.966957] smpboot_thread_fn+0xc5/0x160 [ 5628.967436] kthread+0x113/0x130 [ 5628.968283] ret_from_fork+0x3a/0x50 [ 5628.968721] Modules linked in: [ 5628.969099] CR2: 0000000000000008 [ 5628.969510] ---[ end trace 9d9dedc7181661fe ]--- [ 5628.970073] RIP: 0010:gro_cell_poll+0x49/0x80 [ 5628.972965] RSP: 0018:ffffc9000004fdd8 EFLAGS: 00010202 [ 5628.973611] RAX: 0000000000000000 RBX: ffffe8ffffc08150 RCX: 0000000000000000 [ 5628.974504] RDX: 0000000000000000 RSI: ffff88802356bf00 RDI: ffffe8ffffc08150 [ 5628.975462] RBP: 0000000000000026 R08: 0000000000000000 R09: 0000000000000000 [ 5628.976413] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000040 [ 5628.977375] R13: ffffe8ffffc08100 R14: 0000000000000000 R15: 0000000000000040 [ 5628.978296] FS: 0000000000000000(0000) GS:ffff88803ea00000(0000) knlGS:0000000000000000 [ 5628.979327] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 5628.980044] CR2: 0000000000000008 CR3: 000000000221c000 CR4: 00000000000006b0 [ 5628.980929] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 5628.981736] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 [ 5628.982409] Kernel panic - not syncing: Fatal exception in interrupt [ 5628.983307] Kernel Offset: disabled Fixes: c42858eaf492 ("gro_cells: remove spinlock protecting receive queues") Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-25net: Generic XDPDavid S. Miller
This provides a generic SKB based non-optimized XDP path which is used if either the driver lacks a specific XDP implementation, or the user requests it via a new IFLA_XDP_FLAGS value named XDP_FLAGS_SKB_MODE. It is arguable that perhaps I should have required something like this as part of the initial XDP feature merge. I believe this is critical for two reasons: 1) Accessibility. More people can play with XDP with less dependencies. Yes I know we have XDP support in virtio_net, but that just creates another depedency for learning how to use this facility. I wrote this to make life easier for the XDP newbies. 2) As a model for what the expected semantics are. If there is a pure generic core implementation, it serves as a semantic example for driver folks adding XDP support. One thing I have not tried to address here is the issue of XDP_PACKET_HEADROOM, thanks to Daniel for spotting that. It seems incredibly expensive to do a skb_cow(skb, XDP_PACKET_HEADROOM) or whatever even if the XDP program doesn't try to push headers at all. I think we really need the verifier to somehow propagate whether certain XDP helpers are used or not. v5: - Handle both negative and positive offset after running prog - Fix mac length in XDP_TX case (Alexei) - Use rcu_dereference_protected() in free_netdev (kbuild test robot) v4: - Fix MAC header adjustmnet before calling prog (David Ahern) - Disable LRO when generic XDP is installed (Michael Chan) - Bypass qdisc et al. on XDP_TX and record the event (Alexei) - Do not perform generic XDP on reinjected packets (DaveM) v3: - Make sure XDP program sees packet at MAC header, push back MAC header if we do XDP_TX. (Alexei) - Elide GRO when generic XDP is in use. (Alexei) - Add XDP_FLAG_SKB_MODE flag which the user can use to request generic XDP even if the driver has an XDP implementation. (Alexei) - Report whether SKB mode is in use in rtnl_xdp_fill() via XDP_FLAGS attribute. (Daniel) v2: - Add some "fall through" comments in switch statements based upon feedback from Andrew Lunn - Use RCU for generic xdp_prog, thanks to Johannes Berg. Tested-by: Andy Gospodarek <andy@greyhouse.net> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-02-08gro_cells: move to net/core/gro_cells.cEric Dumazet
We have many gro cells users, so lets move the code to avoid duplication. This creates a CONFIG_GRO_CELLS option. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
