path: root/net/core/link_watch.c
2015-04-02dev: introduce dev_get_iflink()Nicolas Dichtel
The goal of this patch is to prepare the removal of the iflink field. It introduces a new ndo function, which will be implemented by virtual interfaces. There is no functional change into this patch. All readers of iflink field now call dev_get_iflink(). Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18net/core: include linux/types.h instead of asm/types.hFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-18arch: Mass conversion of smp_mb__*()Peter Zijlstra
Mostly scripted conversion of the smp_mb__* barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-13net: make all team port device link events urgentFlavio Leitner
Since team functionality relies heavily on userspace daemon, we need to deliver event to userspace via Netlink as quick as possible. So make all team port device link events urgent. Signed-off-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
2012-08-24net: Set device operstate at registration timeBen Hutchings
The operstate of a device is initially IF_OPER_UNKNOWN and is updated asynchronously by linkwatch after each change of carrier state reported by the driver. The default carrier state of a net device is on, and this will never be changed on drivers that do not support carrier detection, thus the operstate remains IF_OPER_UNKNOWN. For devices that do support carrier detection, the driver must set the carrier state to off initially, then poll the hardware state when the device is opened. However, we must not activate linkwatch for a unregistered device, and commit b473001 ('net: Do not fire linkwatch events until the device is registered.') ensured that we don't. But this means that the operstate for many devices that support carrier detection remains IF_OPER_UNKNOWN when it should be IF_OPER_DOWN. The same issue exists with the dormant state. The proper initialisation sequence, avoiding a race with opening of the device, is: rtnl_lock(); rc = register_netdevice(dev); if (rc) goto out_unlock; netif_carrier_off(dev); /* or netif_dormant_on(dev) */ rtnl_unlock(); but it seems silly that this should have to be repeated in so many drivers. Further, the operstate seen immediately after opening the device may still be IF_OPER_UNKNOWN due to the asynchronous nature of linkwatch. Commit 22604c8 ('net: Fix for initial link state in 2.6.28') attempted to fix this by setting the operstate synchronously, but it was reverted as it could lead to deadlock. This initialises the operstate synchronously at registration time only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-21workqueue: use mod_delayed_work() instead of __cancel + queueTejun Heo
Now that mod_delayed_work() is safe to call from IRQ handlers, __cancel_delayed_work() followed by queue_delayed_work() can be replaced with mod_delayed_work(). Most conversions are straight-forward except for the following. * net/core/link_watch.c: linkwatch_schedule_work() was doing a quite elaborate dancing around its delayed_work. Collapse it such that linkwatch_work is queued for immediate execution if LW_URGENT and existing timer is kept otherwise. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
2011-09-15net: linkwatch: allow vlans to get carrier changes fasterEric Dumazet
There is a time-lag of IFF_RUNNING flag consistency between vlan and real devices when the real devices are in problem such as link or cable broken. This leads to a degradation of Availability such as a delay of failover in HA systems using vlan since the detection of the problem at real device is delayed. We can avoid the linkwatch delay (~1 sec) for devices linked to another ones, since delay is already done for the realdev. Based on a previous patch from Mitsuo Hayasaka Reported-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Patrick McHardy <kaber@trash.net> Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl> Cc: Tom Herbert <therbert@google.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jesse Gross <jesse@nicira.com> Tested-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-22net: allow netif_carrier to be called safely from IRQstephen hemminger
As reported by Ben Greer and Froncois Romieu. The code path in the netif_carrier code leads it to try and disable a late workqueue to reenable it immediately netif_carrier_on -> linkwatch_fire_event -> linkwatch_schedule_work -> cancel_delayed_work -> del_timer_sync If __cancel_delayed_work is used instead then there is no problem of waiting for running linkwatch_event. There is a race between linkwatch_event running re-scheduling but it is harmless to schedule an extra scan of the linkwatch queue. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/core: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-18linkwatch: linkwatch_forget_dev() to speedup device dismantleEric Dumazet
Herbert Xu a écrit : > On Tue, Nov 17, 2009 at 04:26:04AM -0800, David Miller wrote: >> Really, the link watch stuff is just due for a redesign. I don't >> think a simple hack is going to cut it this time, sorry Eric :-) > > I have no objections against any redesigns, but since the only > caller of linkwatch_forget_dev runs in process context with the > RTNL, it could also legally emit those events. Thanks guys, here an updated version then, before linkwatch surgery ? In this version, I force the event to be sent synchronously. [PATCH net-next-2.6] linkwatch: linkwatch_forget_dev() to speedup device dismantle time ip link del eth3.103 ; time ip link del eth3.104 ; time ip link del eth3.105 real 0m0.266s user 0m0.000s sys 0m0.001s real 0m0.770s user 0m0.000s sys 0m0.000s real 0m1.022s user 0m0.000s sys 0m0.000s One problem of current schem in vlan dismantle phase is the holding of device done by following chain : vlan_dev_stop() -> netif_carrier_off(dev) -> linkwatch_fire_event(dev) -> dev_hold() ... And __linkwatch_run_queue() runs up to one second later... A generic fix to this problem is to add a linkwatch_forget_dev() method to unlink the device from the list of watched devices. dev->link_watch_next becomes dev->link_watch_list (and use a bit more memory), to be able to unlink device in O(1). After patch : time ip link del eth3.103 ; time ip link del eth3.104 ; time ip link del eth3.105 real 0m0.024s user 0m0.000s sys 0m0.000s real 0m0.032s user 0m0.000s sys 0m0.001s real 0m0.033s user 0m0.000s sys 0m0.000s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08net: Clean up explicit ->tx_queue references in link watch.David S. Miller
First, we add a qdisc_tx_changing() helper which returns true if the qdisc attachment is in transition. Second, we remove an assertion warning which is of limited value and is hard to express precisely in a multiqueue environment. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move rest of qdisc state into struct netdev_queueDavid S. Miller
Now qdisc, qdisc_sleeping, and qdisc_list also live there. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[NET] link_watch: Always schedule urgent eventsHerbert Xu
Urgent events may be delayed if we already have a non-urgent event queued for that device. This patch changes this by making sure that an urgent event is always looked at immediately. I've replaced the LW_RUNNING flag by LW_URGENT since whether work is scheduled is already kept track by the work queue system. The only complication is that we have to provide some exclusion for the setting linkwatch_nextevent which is available in the actual work function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[NET] link_watch: Eliminate potential delay on wrap-aroundHerbert Xu
When the jiffies wrap around or when the system boots up for the first time, down events can be delayed indefinitely since we no longer update linkwatch_nextevent when only urgent events are processed. This patch fixes this by setting linkwatch_nextevent when a wrap-around occurs. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[NET]: Remove link_watch delay for up even when we're downHerbert Xu
Currently all link carrier events are delayed by up to a second before they're processed to prevent link storms. This causes unnecessary packet loss during that interval. In fact, we can achieve the same effect in preventing storms by only delaying down events and unnecssary up events. The latter is defined as up events when we're already up. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[NET] link_watch: Move link watch list into net_deviceHerbert Xu
These days the link watch mechanism is an integral part of the network subsystem as it manages the carrier status. So it now makes sense to allocate some memory for it in net_device rather than allocating it on demand. In fact, this is necessary because we can't tolerate a memory allocation failure since that means we'd have to potentially throw a link up event away. It also simplifies the code greatly. In doing so I discovered a subtle race condition in the use of singleevent. This race condition still exists (and is somewhat magnified) without singleevent but it's now plugged thanks to an smp_mb__before_clear_bit. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] CORE: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-22WorkStruct: Separate delayable and non-delayable events.David Howells
Separate delayable work items from non-delayable work items be splitting them into a separate structure (delayed_work), which incorporates a work_struct and the timer_list removed from work_struct. The work_struct struct is huge, and this limits it's usefulness. On a 64-bit architecture it's nearly 100 bytes in size. This reduces that by half for the non-delayable type of event. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-06-23[PATCH] list: use list_replace_init() instead of list_splice_init()Oleg Nesterov
list_splice_init(list, head) does unneeded job if it is known that list_empty(head) == 1. We can use list_replace_init() instead. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-09[NET] linkwatch: Handle jiffies wrap-aroundHerbert Xu
The test used in the linkwatch does not handle wrap-arounds correctly. Since the intention of the code is to eliminate bursts of messages we can afford to delay things up to a second. Using that fact we can easily handle wrap-arounds by making sure that we don't delay things by more than one second. This is based on diagnosis and a patch by Stefan Rompf. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Stefan Rompf <stefan@loplof.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: Convert RTNL to mutex.Stephen Hemminger
This patch turns the RTNL from a semaphore to a new 2.6.16 mutex and gets rid of some of the leftover legacy. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET] core: add RFC2863 operstateStefan Rompf
this patch adds a dormant flag to network devices, RFC2863 operstate derived from these flags and possibility for userspace interaction. It allows drivers to signal that a device is unusable for user traffic without disabling queueing (and therefore the possibility for protocol establishment traffic to flow) and a userspace supplicant (WPA, 802.1X) to mark a device unusable without changes to the driver. It is the result of our long discussion. However I must admit that it represents what Jamal and I agreed on with compromises towards Krzysztof, but Thomas and Krzysztof still disagree with some parts. Anyway I think it should be applied. Signed-off-by: Stefan Rompf <stefan@loplof.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[NET]: Disable queueing when carrier is lost.Tommy S. Christensen
Some network drivers call netif_stop_queue() when detecting loss of carrier. This leads to packets being queued up at the qdisc level for an unbound period of time. In order to prevent this effect, the core networking stack will now cease to queue packets for any device, that is operationally down (i.e. the queue is flushed and disabled). Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
