When configuring DMVPN (GRE + openNHRP) and a GRE remote
address is configured a kernel Oops is observed. The
obserseved Oops is caused by a NULL header_ops pointer
(neigh->dev->header_ops) in neigh_update_hhs() when
void (*update)(struct hh_cache*, const struct net_device*, const unsigned char *)
= neigh->dev->header_ops->cache_update;
is executed. The dev associated with the NULL header_ops is
the GRE interface. This patch guards against the
possibility that header_ops is NULL.
This Oops was first observed in kernel version 2.6.26.8.
Signed-off-by: Doug Kehn <rdkehn@yahoo.com>
commit 7fee226ad23 (net: add a noref bit on skb dst) missed one spot
where an skb is enqueued, with a possibly not refcounted dst entry.
__neigh_event_send() inserts skb into arp_queue, so we must make sure
dst entry is refcounted, or dst entry can be freed by garbage collector
after caller exits from rcu protected section.
Reported-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Ingo Molnar <mingo@elte.hu>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Annotates neigh_invalidate() with __releases() and __acquires() for
sparse sake.
Stop computing the number of neighbour table settings we have by
counting the number of binary sysctls. This behaviour was silly
and meant that we could not add another neighbour table setting
without also adding another binary sysctl.
Don't pass the binary sysctl path for neighour table entries
into neigh_sysctl_register. These parameters are no longer
used and so are just dead code.
Simpily pass 'struct neigh_table' with seq_file private pointer,
and save one dereference. Proc entry itself isn't interesting.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits)
mac80211: fix reorder buffer release
iwmc3200wifi: Enable wimax core through module parameter
iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter
iwmc3200wifi: Coex table command does not expect a response
iwmc3200wifi: Update wiwi priority table
iwlwifi: driver version track kernel version
iwlwifi: indicate uCode type when fail dump error/event log
iwl3945: remove duplicated event logging code
b43: fix two warnings
ipw2100: fix rebooting hang with driver loaded
cfg80211: indent regulatory messages with spaces
iwmc3200wifi: fix NULL pointer dereference in pmkid update
mac80211: Fix TX status reporting for injected data frames
ath9k: enable 2GHz band only if the device supports it
airo: Fix integer overflow warning
rt2x00: Fix padding bug on L2PAD devices.
WE: Fix set events not propagated
b43legacy: avoid PPC fault during resume
b43: avoid PPC fault during resume
tcp: fix a timewait refcnt race
Fix up conflicts due to sysctl cleanups (dead sysctl_check code and
CTL_UNNUMBERED removed) in
kernel/sysctl_check.c
net/ipv4/sysctl_net_ipv4.c
net/ipv6/addrconf.c
net/sctp/sysctl.c
Generated with the following semantic patch
struct net *n1;
struct net *n2;
- n1 == n2
+ net_eq(n1, n2)
struct net *n1;
struct net *n2;
- n1 != n2
+ !net_eq(n1, n2)
applied over {include,net,drivers/net}.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
Current neigh_periodic_timer() function is fired by timer IRQ, and
scans one hash bucket each round (very litle work in fact)
As we are supposed to scan whole hash table in 15 seconds, this means
neigh_periodic_timer() can be fired very often. (depending on the number
of concurrent hash entries we stored in this table)
Converting this to a workqueue permits scanning whole table, minimizing
icache pollution, and firing this work every 15 seconds, independantly
of hash table size.
This 15 seconds delay is not a hard number, as work is a deferrable one.
Rename lookup_neigh_params to lookup_neigh_parms as the struct is named
neigh_parms and all other functions dealing with the struct carry
neigh_parms in their names.
Signed-off-by: Tobias Klauser <klto@zhaw.ch>
The current code errors out the INCOMPLETE neigh entry skb queue only from
the timer if maximum probes have been attempted and there has been no reply.
This also causes the transtion to FAILED state.
However, the neigh entry can be also updated via Netlink to inform that the
address is unavailable. Currently, neigh_update() just stops the timers and
leaves the pending skb's unreleased. This results that the clean up code in
the timer callback is never called, preventing also proper garbage collection.
This fixes neigh_update() to process the pending skb queue immediately if
INCOMPLETE -> FAILED state transtion occurs due to a Netlink request.
Signed-off-by: Timo Teras <timo.teras@iki.fi>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Currently it is possible to do just about everything with the arp table
from user space except treat an entry like you are using it. To that end
implement and a flag NTF_USE that when set in a netwlink update request
treats the neighbour table entry like the kernel does on the output path.
This allows user space applications to share the kernel's arp cache.
Signed-off-by: Eric Biederman <ebiederm@aristanetworks.com>
Remove some pointless conditionals before kfree_skb().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
This patch changes the return value of nlmsg_notify() as follows:
If NETLINK_BROADCAST_ERROR is set by any of the listeners and
an error in the delivery happened, return the broadcast error;
else if there are no listeners apart from the socket that
requested a change with the echo flag, return the result of the
unicast notification. Thus, with this patch, the unicast
notification is handled in the same way of a broadcast listener
that has set the NETLINK_BROADCAST_ERROR socket flag.
This patch is useful in case that the caller of nlmsg_notify()
wants to know the result of the delivery of a netlink notification
(including the broadcast delivery) and take any action in case
that the delivery failed. For example, ctnetlink can drop packets
if the event delivery failed to provide reliable logging and
state-synchronization at the cost of dropping packets.
This patch also modifies the rtnetlink code to ignore the return
value of rtnl_notify() in all callers. The function rtnl_notify()
(before this patch) returned the error of the unicast notification
which makes rtnl_set_sk_err() reports errors to all listeners. This
is not of any help since the origin of the change (the socket that
requested the echoing) notices the ENOBUFS error if the notification
fails and should resync itself.
Acked-by: Patrick McHardy <kaber@trash.net>
neightbl_dump_info and neigh_dump_table can skip entries if the
*fill*info functions return an error. This results in an incomplete
dump ((invoked by netlink requests for RTM_GETNEIGHTBL or
RTM_GETNEIGH)
nidx and idx should not be incremented if the current entry was not
placed in the output buffer
Signed-off-by: Gautam Kachroo <gk@aristanetworks.com>
In future all cpumask ops will only be valid (in general) for bit
numbers < nr_cpu_ids. So use that instead of NR_CPUS in iterators
and other comparisons.
This is always safe: no cpu number can be >= nr_cpu_ids, and
nr_cpu_ids is initialized to NR_CPUS at boot.
Signed-off-by: Mike Travis <travis@sgi.com>
This patch moves neigh_setup and hard_start_xmit into the network device ops
structure. For bisection, fix all the previously converted drivers as well.
Bonding driver took the biggest hit on this.
Added a prefetch of the hard_start_xmit in the fast path to try and reduce
any impact this would have.
Using read_pnet() and write_pnet() in neighbour code ease the reading
of code.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
->pde isn't actually needed, since name is stashed in ->id.
I want to compile out proc_* and sysctl_* handlers totally and
stub them to NULL depending on config options, however usage of &
will prevent this, since taking adress of NULL pointer will break
compilation.
So, drop & in front of every ->proc_handler and every ->strategy
handler, it was never needed in fact.
call_rcu() will unconditionally rewrite RCU head anyway.
Applies to
struct neigh_parms
struct neigh_table
struct net
struct cipso_v4_doi
struct in_ifaddr
struct in_device
rt->u.dst
When pneigh entries exist, but the user's read buffer isn't sufficient to
hold them all, one of the pneigh entries will be missing from the results.
In neigh_get_idx_any, the number of elements which neigh_get_idx
encountered is not correctly subtracted from the position number before
the call to pneigh_get_idx. neigh_get_idx reduces the position by 1 for
each call to neigh_get_next, but it does not reduce it by one for the
first element (neigh_get_first). The patch alters the neigh_get_idx and
pneigh_get_idx functions to subtract one from pos, for the first element,
when pos is non-zero.
Signed-off-by: Chris Larson <clarson@mvista.com>
neigh_get_idx.
neigh_seq_next won't be called both with *pos > 0 && v ==
SEQ_START_TOKEN, so there's no point calling neigh_get_idx when we're
on the start token, just call neigh_get_first directly.
in __neigh_event_send, if we have a neighbour entry which is in
NUD_INCOMPLETE state, we enqueue any outbound frames to that neighbour
to the neighbours arp_queue, which is default capped to a length of 3
skbs. If that queue exceeds its set length, it will drop an skb on
the queue to enqueue the newly arrived skb. This results in a drop
for which we have no statistics incremented. This patch adds an
unresolved_discards stat to /proc/net/stat/ndisc_cache to track these
lost frames.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and
nla_nest_cancel() void functions.
Return -EMSGSIZE instead of -1 if the provided message buffer is not
big enough.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
The neighbor table time of last use information is returned in the
incorrect unit. Kernel to user space ABI's need to use USER_HZ (or
milliseconds), otherwise the application has to try and discover the
real system HZ value which is problematic. Linux has standardized on
keeping USER_HZ consistent (100hz) even when kernel is running
internally at some other value.
This change is small, but it breaks the ABI for older version of
iproute2 utilities. But these utilities are already broken since they
are looking at the psched_hz values which are completely different. So
let's just go ahead and fix both kernel and user space. Older
utilities will just print wrong values.
Simply replace proc_create and further data assigned with proc_create_data.
Additionally, there is no need to assign NULL to PDE->data after creation,
/proc generic has already done this for us.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Extract hash function for pneigh entries from pneigh_lookup(),
__pneigh_lookup() and pneigh_delete() as pneigh_hash().
Extract core of pneigh_lookup() and __pneigh_lookup() as
__pneigh_lookup_1().
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
function/variable.
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/usb/rndis_host.c
drivers/net/wireless/b43/dma.c
net/ipv6/ndisc.c
Introduce an inline net_eq() to compare two namespaces.
Without CONFIG_NET_NS, since no namespace other than &init_net
exists, it is always 1.
We do not need to convert 1) inline vs inline and
2) inline vs &init_net comparisons.
Introduce neigh_parms/pneigh_entry inlines: neigh_parms_net(), pneigh_net().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Without CONFIG_NET_NS, no namespace other than &init_net exists,
no need to store net in seq_net_private.
Introduce per-sock inlines: sock_net(), sock_net_set()
and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set().
Introduce per-net_device inlines: dev_net(), dev_net_set().
Proxy neighbors do not have any reference counting, so any caller
of pneigh_lookup (unless it's a netlink triggered add/del routine)
should _not_ perform any actions on the found proxy entry.
There's one exception from this rule - the ipv6's ndisc_recv_ns()
uses found entry to check the flags for NTF_ROUTER.
This creates a race between the ndisc and pneigh_delete - after
the pneigh is returned to the caller, the nd_tbl.lock is dropped
and the deleting procedure may proceed.
One of the fixes would be to add a reference counting, but this
problem exists for ndisc only. Besides such a patch would be too
big for -rc4.
So I propose to introduce a __pneigh_lookup() which is supposed
to be called with the lock held and use it in ndisc code to check
the flags on alive pneigh entry.
Changes from v2:
As David noticed, Exported the __pneigh_lookup() to ipv6 module.
The checkpatch generates a warning on it, since the EXPORT_SYMBOL
does not follow the symbol itself, but in this file all the
exports come at the end, so I decided no to break this harmony.
Changes from v1:
Fixed comments from YOSHIFUJI - indentation of prototype in header
and the pndisc_check_router() name - and a compilation fix, pointed
by Daniel - the is_routed was (falsely) considered as uninitialized
by gcc.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
net/mac80211/rc80211_pid_algo.c
neigh_update sends skb from neigh->arp_queue while neigh_timer_handler
has increased skbs refcount and calls solicit with the
skb. neigh_timer_handler should not increase skbs refcount but make a
copy of the skb and do solicit with the copy.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Default ARP parameters should be findable regardless of the context.
Required to make inetdev_event working.
neigh_sysctl_register should register sysctl entries inside correct namespace
to avoid naming conflict. Typical example is a loopback. Entries for it
present in all namespaces.
Use proc_create() to make sure that ->proc_fops be setup before gluing
PDE to main tree.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
The neigh_hash_grow() may update the tbl->hash_rnd value, which
is used in all tbl->hash callbacks to calculate the hashval.
Two lookup routines may race with this, since they call the
->hash callback without the tbl->lock held. Since the hash_rnd
is changed with this lock write-locked moving the calls to ->hash
under this lock read-locked closes this gap.
release_net is missed on the error path in pneigh_lookup.
This reverts commit 69cc64d8d92bf852f933e90c888dfff083bd4fc9.
It causes recursive locking in IPV6 because unlike other
neighbour layer clients, it even needs neighbour cache
entries to send neighbour soliciation messages :-(
We'll have to find another way to fix this race.
Frank Blaschka provided the bug report and the initial suggested fix
for this bug. He also validated this version of this fix.
The problem is that the access to neigh->arp_queue is inconsistent, we
grab references when dropping the lock lock to call
neigh->ops->solicit() but this does not prevent other threads of
control from trying to send out that packet at the same time causing
corruptions because both code paths believe they have exclusive access
to the skb.
The best option seems to be to hold the write lock on neigh->lock
during the ->solicit() call. I looked at all of the ndisc_ops
implementations and this seems workable. The only case that needs
special care is the IPV4 ARP implementation of arp_solicit(). It
wants to take neigh->lock as a reader to protect the header entry in
neigh->ha during the emission of the soliciation. We can simply
remove the read lock calls to take care of that since holding the lock
as a writer at the caller providers a superset of the protection
afforded by the existing read locking.
The rest of the ->solicit() implementations don't care whether the
neigh is locked or not.
Make them static.
[ Moved the inline before, instead of after, call sites. -DaveM ]
No need for this. It is declared in the neighbour.h
