path: root/net/core/request_sock.c
2008-01-28[NET] net/core/request_sock.c: Remove unused exports.Adrian Bunk
This patch removes the following unused EXPORT_SYMBOL's: - reqsk_queue_alloc - __reqsk_queue_destroy - reqsk_queue_destroy Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-15[INET]: Fix potential kfree on vmalloc-ed area of request_sock_queuePavel Emelyanov
The request_sock_queue's listen_opt is either vmalloc-ed or kmalloc-ed depending on the number of table entries. Thus it is expected to be handled properly on free, which is done in the reqsk_queue_destroy(). However the error path in inet_csk_listen_start() calls the lite version of reqsk_queue_destroy, called __reqsk_queue_destroy, which calls the kfree unconditionally. Fix this and move the __reqsk_queue_destroy into a .c file as it looks too big to be inline. As David also noticed, this is an error recovery path only, so no locking is required and the lopt is known to be not NULL. reqsk_queue_yank_listen_sk is also now only used in net/core/request_sock.c so we should move it there too. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Size listen hash tables using backlog hintEric Dumazet
We currently allocate a fixed size (TCP_SYNQ_HSIZE=512) slots hash table for each LISTEN socket, regardless of various parameters (listen backlog for example) On x86_64, this means order-1 allocations (might fail), even for 'small' sockets, expecting few connections. On the contrary, a huge server wanting a backlog of 50000 is slowed down a bit because of this fixed limit. This patch makes the sizing of listen hash table a dynamic parameter, depending of : - net.core.somaxconn tunable (default is 128) - net.ipv4.tcp_max_syn_backlog tunable (default : 256, 1024 or 128) - backlog value given by user application (2nd parameter of listen()) For large allocations (bigger than PAGE_SIZE), we use vmalloc() instead of kmalloc(). We still limit memory allocation with the two existing tunables (somaxconn & tcp_max_syn_backlog). So for standard setups, this patch actually reduce RAM usage. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[NET]: More kzalloc conversions.Andrew Morton
2006-03-26[NET]: drop duplicate assignment in request_sockNorbert Kiesel
Just noticed that request_sock.[ch] contain a useless assignment of rskq_accept_head to itself. I assume this is a typo and the 2nd one was supposed to be _tail. However, setting _tail to NULL is not needed, so the patch below just drops the 2nd assignment. Signed-off-By: Norbert Kiesel <nkiesel@tbdnetworks.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-27[REQSK]: Don't reset rskq_defer_accept in reqsk_queue_allocArnaldo Carvalho de Melo
In 295f7324ff8d9ea58b4d3ec93b1aaa1d80e048a9 I moved defer_accept from tcp_sock to request_queue and mistakingly reset it at reqsl_queue_alloc, causing calls to setsockopt(TCP_DEFER_ACCEPT ) to be lost after bind, the fix is to remove the zeroing of rskq_defer_accept from reqsl_queue_alloc. Thanks to Alexandra N. Kossovsky <Alexandra.Kossovsky@oktetlabs.ru> for reporting and testing the suggested fix. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Introduce reqsk_queue_prune from code in tcp_synack_timerArnaldo Carvalho de Melo
With this we're very close to getting all of the current TCP refactorings in my dccp-2.6 tree merged, next changeset will export some functions needed by the current DCCP code and then dccp-2.6.git will be born! Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4]: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - xfrm4_state.c: xfrm4_state_fini - remove the following unneeded EXPORT_SYMBOL's: - ip_output.c: ip_finish_output - ip_output.c: sysctl_ip_default_ttl - fib_frontend.c: ip_dev_find - inetpeer.c: inet_peer_idlock - ip_options.c: ip_options_compile - ip_options.c: ip_options_undo - net/core/request_sock.c: sysctl_max_syn_backlog Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[REQSK]: Move the syn_table destroy from tcp_listen_stop to reqsk_queue_destroyArnaldo Carvalho de Melo
2005-06-18[NET]: Move sysctl_max_syn_backlog into request_sock.cDavid S. Miller
This fixes the CONFIG_INET=n build failure noticed by Andrew Morton. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] rename struct tcp_listen_opt to struct listen_sockArnaldo Carvalho de Melo
2005-06-18[NET] Generalise tcp_listen_optArnaldo Carvalho de Melo
This chunks out the accept_queue and tcp_listen_opt code and moves them to net/core/request_sock.c and include/net/request_sock.h, to make it useful for other transport protocols, DCCP being the first one to use it. Next patches will rename tcp_listen_opt to accept_sock and remove the inline tcp functions that just call a reqsk_queue_ function. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
