[ Upstream commit a3b299da869d6e78cf42ae0b1b41797bcb8c5e4b ]
sk_net_capable - The common case, operations that are safe in a network namespace.
sk_capable - Operations that are not known to be safe in a network namespace
sk_ns_capable - The general case for special cases.
[ Upstream commit c3f9b01849ef3bc69024990092b9f42e20df7797 ]
Lars Persson reported following deadlock :
-000 |M:0x0:0x802B6AF8(asm) <-- arch_spin_lock
-001 |tcp_v4_rcv(skb = 0x8BD527A0) <-- sk = 0x8BE6B2A0
-002 |ip_local_deliver_finish(skb = 0x8BD527A0)
-003 |__netif_receive_skb_core(skb = 0x8BD527A0, ?)
-004 |netif_receive_skb(skb = 0x8BD527A0)
-005 |elk_poll(napi = 0x8C770500, budget = 64)
-006 |net_rx_action(?)
-007 |__do_softirq()
-008 |do_softirq()
-009 |local_bh_enable()
-010 |tcp_rcv_established(sk = 0x8BE6B2A0, skb = 0x87D3A9E0, th = 0x814EBE14, ?)
-011 |tcp_v4_do_rcv(sk = 0x8BE6B2A0, skb = 0x87D3A9E0)
-012 |tcp_delack_timer_handler(sk = 0x8BE6B2A0)
-013 |tcp_release_cb(sk = 0x8BE6B2A0)
-014 |release_sock(sk = 0x8BE6B2A0)
-015 |tcp_sendmsg(?, sk = 0x8BE6B2A0, ?, ?)
-016 |sock_sendmsg(sock = 0x8518C4C0, msg = 0x87D8DAA8, size = 4096)
-017 |kernel_sendmsg(?, ?, ?, ?, size = 4096)
-018 |smb_send_kvec()
-019 |smb_send_rqst(server = 0x87C4D400, rqst = 0x87D8DBA0)
-020 |cifs_call_async()
-021 |cifs_async_writev(wdata = 0x87FD6580)
-022 |cifs_writepages(mapping = 0x852096E4, wbc = 0x87D8DC88)
-023 |__writeback_single_inode(inode = 0x852095D0, wbc = 0x87D8DC88)
-024 |writeback_sb_inodes(sb = 0x87D6D800, wb = 0x87E4A9C0, work = 0x87D8DD88)
-025 |__writeback_inodes_wb(wb = 0x87E4A9C0, work = 0x87D8DD88)
-026 |wb_writeback(wb = 0x87E4A9C0, work = 0x87D8DD88)
-027 |wb_do_writeback(wb = 0x87E4A9C0, force_wait = 0)
-028 |bdi_writeback_workfn(work = 0x87E4A9CC)
-029 |process_one_work(worker = 0x8B045880, work = 0x87E4A9CC)
-030 |worker_thread(__worker = 0x8B045880)
-031 |kthread(_create = 0x87CADD90)
-032 |ret_from_kernel_thread(asm)
Bug occurs because __tcp_checksum_complete_user() enables BH, assuming
it is running from softirq context.
Lars trace involved a NIC without RX checksum support but other points
are problematic as well, like the prequeue stuff.
Problem is triggered by a timer, that found socket being owned by user.
tcp_release_cb() should call tcp_write_timer_handler() or
tcp_delack_timer_handler() in the appropriate context :
BH disabled and socket lock held, but 'owned' field cleared,
as if they were running from timer handlers.
Fixes: 6f458dfb4092 ("tcp: improve latencies of timer triggered events")
Reported-by: Lars Persson <lars.persson@axis.com>
Tested-by: Lars Persson <lars.persson@axis.com>
[ Upstream commit ed98df3361f059db42786c830ea96e2d18b8d4db ]
sock_alloc_send_pskb() & sk_page_frag_refill()
have a loop trying high order allocations to prepare
skb with low number of fragments as this increases performance.
Problem is that under memory pressure/fragmentation, this can
trigger OOM while the intent was only to try the high order
allocations, then fallback to order-0 allocations.
We had various reports from unexpected regressions.
According to David, setting __GFP_NORETRY should be fine,
as the asynchronous compaction is still enabled, and this
will prevent OOM from kicking as in :
CFSClientEventm invoked oom-killer: gfp_mask=0x42d0, order=3, oom_adj=0,
oom_score_adj=0, oom_score_badness=2 (enabled),memcg_scoring=disabled
CFSClientEventm
Call Trace:
[<ffffffff8043766c>] dump_header+0xe1/0x23e
[<ffffffff80437a02>] oom_kill_process+0x6a/0x323
[<ffffffff80438443>] out_of_memory+0x4b3/0x50d
[<ffffffff8043a4a6>] __alloc_pages_may_oom+0xa2/0xc7
[<ffffffff80236f42>] __alloc_pages_nodemask+0x1002/0x17f0
[<ffffffff8024bd23>] alloc_pages_current+0x103/0x2b0
[<ffffffff8028567f>] sk_page_frag_refill+0x8f/0x160
[<ffffffff80295fa0>] tcp_sendmsg+0x560/0xee0
[<ffffffff802a5037>] inet_sendmsg+0x67/0x100
[<ffffffff80283c9c>] __sock_sendmsg_nosec+0x6c/0x90
[<ffffffff80283e85>] sock_sendmsg+0xc5/0xf0
[<ffffffff802847b6>] __sys_sendmsg+0x136/0x430
[<ffffffff80284ec8>] sys_sendmsg+0x88/0x110
[<ffffffff80711472>] system_call_fastpath+0x16/0x1b
Out of Memory: Kill process 2856 (bash) score 9999 or sacrifice child
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
[ Upstream commit 12663bfc97c8b3fdb292428105dd92d563164050 ]
unix_dgram_recvmsg() will hold the readlock of the socket until recv
is complete.
In the same time, we may try to setsockopt(SO_PEEK_OFF) which will hang until
unix_dgram_recvmsg() will complete (which can take a while) without allowing
us to break out of it, triggering a hung task spew.
Instead, allow set_peek_off to fail, this way userspace will not hang.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
[ Upstream commits 6d36824e730f247b602c90e8715a792003e3c5a7,
02cf4ebd82ff0ac7254b88e466820a290ed8289a, and parts of
7eec4174ff29cd42f2acfae8112f51c228545d40 ]
After hearing many people over past years complaining against TSO being
bursty or even buggy, we are proud to present automatic sizing of TSO
packets.
One part of the problem is that tcp_tso_should_defer() uses an heuristic
relying on upcoming ACKS instead of a timer, but more generally, having
big TSO packets makes little sense for low rates, as it tends to create
micro bursts on the network, and general consensus is to reduce the
buffering amount.
This patch introduces a per socket sk_pacing_rate, that approximates
the current sending rate, and allows us to size the TSO packets so
that we try to send one packet every ms.
This field could be set by other transports.
Patch has no impact for high speed flows, where having large TSO packets
makes sense to reach line rate.
For other flows, this helps better packet scheduling and ACK clocking.
This patch increases performance of TCP flows in lossy environments.
A new sysctl (tcp_min_tso_segs) is added, to specify the
minimal size of a TSO packet (default being 2).
A follow-up patch will provide a new packet scheduler (FQ), using
sk_pacing_rate as an input to perform optional per flow pacing.
This explains why we chose to set sk_pacing_rate to twice the current
rate, allowing 'slow start' ramp up.
sk_pacing_rate = 2 * cwnd * mss / srtt
v2: Neal Cardwell reported a suspect deferring of last two segments on
initial write of 10 MSS, I had to change tcp_tso_should_defer() to take
into account tp->xmit_size_goal_segs
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Van Jacobson <vanj@google.com>
Cc: Tom Herbert <therbert@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
When the kernel (compiled with CONFIG_PREEMPT=n) is performing the
rename of a network interface, it can end up waiting for a workqueue
to complete. If userland is able to invoke a SIOCGIFNAME ioctl or a
SO_BINDTODEVICE getsockopt in between, the kernel will deadlock due to
the fact that read_secklock_begin() will spin forever waiting for the
writer process (the one doing the interface rename) to update the
devnet_rename_seq sequence.
This patch fixes the problem by adding a helper (netdev_get_name())
and using it in the code handling the SIOCGIFNAME ioctl and
SO_BINDTODEVICE setsockopt.
The netdev_get_name() helper uses raw_seqcount_begin() to avoid
spinning forever, waiting for devnet_rename_seq->sequence to become
even. cond_resched() is used in the contended case, before retrying
the access to give the writer process a chance to finish.
The use of raw_seqcount_begin() will incur some unneeded work in the
reader process in the contended case, but this is better than
deadlocking the system.
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
The three arrays of strings: af_family_key_strings,
af_family_slock_key_strings and af_family_clock_key_strings have not
VSOCK's string
Signed-off-by: Federico Vaga <federico.vaga@gmail.com>
We have seen multiple NULL dereferences in __inet6_lookup_established()
After analysis, I found that inet6_sk() could be NULL while the
check for sk_family == AF_INET6 was true.
Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP
and TCP stacks.
Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash
table, we no longer can clear pinet6 field.
This patch extends logic used in commit fcbdf09d9652c891
("net: fix nulls list corruptions in sk_prot_alloc")
TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method
to make sure we do not clear pinet6 field.
At socket clone phase, we do not really care, as cloning the parent (non
NULL) pinet6 is not adding a fatal race.
The callers always pass current to sock_update_netprio().
Signed-off-by: Li Zefan <lizefan@huawei.com>
The callers always pass current to sock_update_classid().
Currently, when a socket receives something on the error queue it only wakes up
the socket on select if it is in the "read" list, that is the socket has
something to read. It is useful also to wake the socket if it is in the error
list, which would enable software to wait on error queue packets without waking
up for regular data on the socket. The main use case is for receiving
timestamped transmit packets which return the timestamp to the socket via the
error queue. This enables an application to select on the socket for the error
queue only instead of for the regular traffic.
-v2-
* Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file
* Modified every socket poll function that checks error queue
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Matthew Vick <matthew.vick@intel.com>
The cgroup code has been surrounded by ifdef CONFIG_NET_CLS_CGROUP
and CONFIG_NETPRIO_CGROUP.
The mem cgroup socket limit is only used if the config option is
enabled. Found with sparse
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
As in del_timer() there has already placed a timer_pending() function
to check whether the timer to be deleted is pending or not, it's
unnecessary to check timer pending state again before del_timer() is
called.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Cc: Eric Dumazet <edumazet@google.com>
Definitions and macros for implementing soreusport.
Signed-off-by: Tom Herbert <therbert@google.com>
While a privileged program can open a raw socket, attach some
restrictive filter and drop its privileges (or send the socket to an
unprivileged program through some Unix socket), the filter can still
be removed or modified by the unprivileged program. This commit adds a
socket option to lock the filter (SO_LOCK_FILTER) preventing any
modification of a socket filter program.
This is similar to OpenBSD BIOCLOCK ioctl on bpf sockets, except even
root is not allowed change/drop the filter.
The state of the lock can be read with getsockopt(). No error is
triggered if the state is not changed. -EPERM is returned when a user
tries to remove the lock or to change/remove the filter while the lock
is active. The check is done directly in sk_attach_filter() and
sk_detach_filter() and does not affect only setsockopt() syscall.
Signed-off-by: Vincent Bernat <bernat@luffy.cx>
Using a seqlock for devnet_rename_seq is not a good idea,
as device_rename() can sleep.
As we hold RTNL, we dont need a protection for writers,
and only need a seqcount so that readers can catch a change done
by a writer.
Bug added in commit c91f6df2db4972d3 (sockopt: Change getsockopt() of
SO_BINDTODEVICE to return an interface name)
Reported-by: Dave Jones <davej@redhat.com>
Cc: Brian Haley <brian.haley@hp.com>
Instead of having the getsockopt() of SO_BINDTODEVICE return an index, which
will then require another call like if_indextoname() to get the actual interface
name, have it return the name directly.
This also matches the existing man page description on socket(7) which mentions
the argument being an interface name.
If the value has not been set, zero is returned and optlen will be set to zero
to indicate there is no interface name present.
Added a seqlock to protect this code path, and dev_ifname(), from someone
changing the device name via dev_change_name().
v2: Added seqlock protection while copying device name.
v3: Fixed word wrap in patch.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Settings that merely control a single network device are allowed.
Either the network device is a logical network device where
restrictions make no difference or the network device is hardware NIC
that has been explicity moved from the initial network namespace.
In general policy and network stack state changes are allowed
while resource control is left unchanged.
Allow ethtool ioctls.
Allow binding to network devices.
Allow setting the socket mark.
Allow setting the socket priority.
Allow setting the network device alias via sysfs.
Allow setting the mtu via sysfs.
Allow changing the network device flags via sysfs.
Allow setting the network device group via sysfs.
Allow the following network device ioctls.
SIOCGMIIPHY
SIOCGMIIREG
SIOCSIFNAME
SIOCSIFFLAGS
SIOCSIFMETRIC
SIOCSIFMTU
SIOCSIFHWADDR
SIOCSIFSLAVE
SIOCADDMULTI
SIOCDELMULTI
SIOCSIFHWBROADCAST
SIOCSMIIREG
SIOCBONDENSLAVE
SIOCBONDRELEASE
SIOCBONDSETHWADDR
SIOCBONDCHANGEACTIVE
SIOCBRADDIF
SIOCBRDELIF
SIOCSHWTSTAMP
The SO_ATTACH_FILTER option is set only. I propose to add the get
ability by using SO_ATTACH_FILTER in getsockopt. To be less
irritating to eyes the SO_GET_FILTER alias to it is declared. This
ability is required by checkpoint-restore project to be able to
save full state of a socket.
There are two issues with getting filter back.
First, kernel modifies the sock_filter->code on filter load, thus in
order to return the filter element back to user we have to decode it
into user-visible constants. Fortunately the modification in question
is interconvertible.
Second, the BPF_S_ALU_DIV_K code modifies the command argument k to
speed up the run-time division by doing kernel_k = reciprocal(user_k).
Bad news is that different user_k may result in same kernel_k, so we
can't get the original user_k back. Good news is that we don't have
to do it. What we need to is calculate a user2_k so, that
reciprocal(user2_k) == reciprocal(user_k) == kernel_k
i.e. if it's re-loaded back the compiled again value will be exactly
the same as it was. That said, the user2_k can be calculated like this
user2_k = reciprocal(kernel_k)
with an exception, that if kernel_k == 0, then user2_k == 1.
The optlen argument is treated like this -- when zero, kernel returns
the amount of sock_fprog elements in filter, otherwise it should be
large enough for the sock_fprog array.
changes since v1:
* Declared SO_GET_FILTER in all arch headers
* Added decode of vlan-tag codes
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
sock_update_classid() assumes that the update operation always are
applied on the current task. sock_update_classid() needs to know on
which tasks to work on in order to be able to migrate task between
cgroups using the struct cgroup_subsys attach() callback.
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Joe Perches <joe@perches.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: <netdev@vger.kernel.org>
Cc: <cgroups@vger.kernel.org>
As Eric pointed out:
"Hey task_cls_classid() has its own rcu protection since commit
3fb5a991916091a908d (cls_cgroup: Fix rcu lockdep warning)
So we can safely revert Paul commit (1144182a8757f2a1)
(We no longer need rcu_read_lock/unlock here)"
Cc: Li Zefan <lizefan@huawei.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: netdev@vger.kernel.org
Cc: cgroups@vger.kernel.org
The SO_BINDTODEVICE option is the only SOL_SOCKET one that can be set, but
cannot be get via sockopt API. The only way we can find the device id a
socket is bound to is via sock-diag interface. But the diag works only on
hashed sockets, while the opt in question can be set for yet unhashed one.
That said, in order to know what device a socket is bound to (we do want
to know this in checkpoint-restore project) I propose to make this option
getsockopt-able and report the respective device index.
Another solution to the problem might be to teach the sock-diag reporting
info on unhashed sockets. Should I go this way instead?
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- xattr support added. The implementation is shared with tmpfs. The
usage is restricted and intended to be used to manage per-cgroup
metadata by system software. tmpfs changes are routed through this
branch with Hugh's permission.
- cgroup subsystem ID handling simplified.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: Define CGROUP_SUBSYS_COUNT according the configuration
cgroup: Assign subsystem IDs during compile time
cgroup: Do not depend on a given order when populating the subsys array
cgroup: Wrap subsystem selection macro
cgroup: Remove CGROUP_BUILTIN_SUBSYS_COUNT
cgroup: net_prio: Do not define task_netpioidx() when not selected
cgroup: net_cls: Do not define task_cls_classid() when not selected
cgroup: net_cls: Move sock_update_classid() declaration to cls_cgroup.h
cgroup: trivial fixes for Documentation/cgroups/cgroups.txt
xattr: mark variable as uninitialized to make both gcc and smatch happy
fs: add missing documentation to simple_xattr functions
cgroup: add documentation on extended attributes usage
cgroup: rename subsys_bits to subsys_mask
cgroup: add xattr support
cgroup: revise how we re-populate root directory
xattr: extract simple_xattr code from tmpfs
drivers/net/team/team.c
drivers/net/usb/qmi_wwan.c
net/batman-adv/bat_iv_ogm.c
net/ipv4/fib_frontend.c
net/ipv4/route.c
net/l2tp/l2tp_netlink.c
The team, fib_frontend, route, and l2tp_netlink conflicts were simply
overlapping changes.
qmi_wwan and bat_iv_ogm were of the "use HEAD" variety.
With help from Antonio Quartulli.
It seems sk_init() has no value today and even does strange things :
# grep . /proc/sys/net/core/?mem_*
/proc/sys/net/core/rmem_default:212992
/proc/sys/net/core/rmem_max:131071
/proc/sys/net/core/wmem_default:212992
/proc/sys/net/core/wmem_max:131071
We can remove it completely.
Reviewed-by: Shan Wei <davidshan@tencent.com>
Its possible to use RAW sockets to get a crash in
tcp_set_keepalive() / sk_reset_timer()
Fix is to make sure socket is a SOCK_STREAM one.
We currently use a per socket order-0 page cache for tcp_sendmsg()
operations.
This page is used to build fragments for skbs.
Its done to increase probability of coalescing small write() into
single segments in skbs still in write queue (not yet sent)
But it wastes a lot of memory for applications handling many mostly
idle sockets, since each socket holds one page in sk->sk_sndmsg_page
Its also quite inefficient to build TSO 64KB packets, because we need
about 16 pages per skb on arches where PAGE_SIZE = 4096, so we hit
page allocator more than wanted.
This patch adds a per task frag allocator and uses bigger pages,
if available. An automatic fallback is done in case of memory pressure.
(up to 32768 bytes per frag, thats order-3 pages on x86)
This increases TCP stream performance by 20% on loopback device,
but also benefits on other network devices, since 8x less frags are
mapped on transmit and unmapped on tx completion. Alexander Duyck
mentioned a probable performance win on systems with IOMMU enabled.
Its possible some SG enabled hardware cant cope with bigger fragments,
but their ndo_start_xmit() should already handle this, splitting a
fragment in sub fragments, since some arches have PAGE_SIZE=65536
Successfully tested on various ethernet devices.
(ixgbe, igb, bnx2x, tg3, mellanox mlx4)
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Vijay Subramanian <subramanian.vijay@gmail.com>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Tested-by: Vijay Subramanian <subramanian.vijay@gmail.com>
net/netfilter/nfnetlink_log.c
net/netfilter/xt_LOG.c
Rather easy conflict resolution, the 'net' tree had bug fixes to make
sure we checked if a socket is a time-wait one or not and elide the
logging code if so.
Whereas on the 'net-next' side we are calculating the UID and GID from
the creds using different interfaces due to the user namespace changes
WARNING: With this change it is impossible to load external built
controllers anymore.
In case where CONFIG_NETPRIO_CGROUP=m and CONFIG_NET_CLS_CGROUP=m is
set, corresponding subsys_id should also be a constant. Up to now,
net_prio_subsys_id and net_cls_subsys_id would be of the type int and
the value would be assigned during runtime.
By switching the macro definition IS_SUBSYS_ENABLED from IS_BUILTIN
to IS_ENABLED, all *_subsys_id will have constant value. That means we
need to remove all the code which assumes a value can be assigned to
net_prio_subsys_id and net_cls_subsys_id.
A close look is necessary on the RCU part which was introduces by
following patch:
commit f845172531fb7410c7fb7780b1a6e51ee6df7d52
Author: Herbert Xu <herbert@gondor.apana.org.au> Mon May 24 09:12:34 2010
Committer: David S. Miller <davem@davemloft.net> Mon May 24 09:12:34 2010
cls_cgroup: Store classid in struct sock
Tis code was added to init_cgroup_cls()
/* We can't use rcu_assign_pointer because this is an int. */
smp_wmb();
net_cls_subsys_id = net_cls_subsys.subsys_id;
respectively to exit_cgroup_cls()
net_cls_subsys_id = -1;
synchronize_rcu();
and in module version of task_cls_classid()
rcu_read_lock();
id = rcu_dereference(net_cls_subsys_id);
if (id >= 0)
classid = container_of(task_subsys_state(p, id),
struct cgroup_cls_state, css)->classid;
rcu_read_unlock();
Without an explicit explaination why the RCU part is needed. (The
rcu_deference was fixed by exchanging it to rcu_derefence_index_check()
in a later commit, but that is a minor detail.)
So here is my pondering why it was introduced and why it safe to
remove it now. Note that this code was copied over to net_prio the
reasoning holds for that subsystem too.
The idea behind the RCU use for net_cls_subsys_id is to make sure we
get a valid pointer back from task_subsys_state(). task_subsys_state()
is just blindly accessing the subsys array and returning the
pointer. Obviously, passing in -1 as id into task_subsys_state()
returns an invalid value (out of lower bound).
So this code makes sure that only after module is loaded and the
subsystem registered, the id is assigned.
Before unregistering the module all old readers must have left the
critical section. This is done by assigning -1 to the id and issuing a
synchronized_rcu(). Any new readers wont call task_subsys_state()
anymore and therefore it is safe to unregister the subsystem.
The new code relies on the same trick, but it looks at the subsys
pointer return by task_subsys_state() (remember the id is constant
and therefore we allways have a valid index into the subsys
array).
No precautions need to be taken during module loading
module. Eventually, all CPUs will get a valid pointer back from
task_subsys_state() because rebind_subsystem() which is called after
the module init() function will assigned subsys[net_cls_subsys_id] the
newly loaded module subsystem pointer.
When the subsystem is about to be removed, rebind_subsystem() will
called before the module exit() function. In this case,
rebind_subsys() will assign subsys[net_cls_subsys_id] a NULL pointer
and then it calls synchronize_rcu(). All old readers have left by then
the critical section. Any new reader wont access the subsystem
anymore. At this point we are safe to unregister the subsystem. No
synchronize_rcu() call is needed.
Acked-by: Li Zefan <lizefan@huawei.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Gao feng <gaofeng@cn.fujitsu.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: John Fastabend <john.r.fastabend@intel.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
task_netprioidx() should not be defined in case the configuration is
CONFIG_NETPRIO_CGROUP=n. The reason is that in a following patch the
net_prio_subsys_id will only be defined if CONFIG_NETPRIO_CGROUP!=n.
When net_prio is not built at all any callee should only get an empty
task_netprioidx() without any references to net_prio_subsys_id.
task_cls_classid() should not be defined in case the configuration is
CONFIG_NET_CLS_CGROUP=n. The reason is that in a following patch the
net_cls_subsys_id will only be defined if CONFIG_NET_CLS_CGROUP!=n.
When net_cls is not built at all a callee should only get an empty
task_cls_classid() without any references to net_cls_subsys_id.
Fix net/core/sock.c build error when CONFIG_INET is not enabled:
net/built-in.o: In function `sock_edemux':
(.text+0xd396): undefined reference to `inet_twsk_put'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
sock_edemux() can handle either a regular socket or a timewait socket
This is an initial merge in of Eric Biederman's work to start adding
user namespace support to the networking.
The network classifier cgroup initalizes each cgroups instance classid value to
0. However, the sock_update_classid function only updates classid's in sockets
if the tasks cgroup classid is not zero, and if it differs from the current
classid. The later check is to prevent cache line dirtying, but the former is
detrimental, as it prevents resetting a classid for a cgroup to 0. While this
is not a common action, it has administrative usefulness (if the admin wants to
disable classification of a certain group temporarily for instance).
Easy fix, just remove the zero check. Tested successfully by myself
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: "David S. Miller" <davem@davemloft.net>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
With the existence of kuid_t and kgid_t we can take this further
and remove the usage of struct cred altogether, ensuring we
don't get cache line misses from reference counts. For now
however start simply and do a straight forward conversion
I can be certain is correct.
In cred_to_ucred use from_kuid_munged and from_kgid_munged
as these values are going directly to userspace and we want to use
the userspace safe values not -1 when reporting a value that does not
map. The earlier conversion that used from_kuid was buggy in that
respect. Oops.
Cache the device gso_max_segs in sock::sk_gso_max_segs and use it to
limit the size of TSO skbs. This avoids the need to fall back to
software GSO for local TCP senders.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
This patch series is based on top of "Swap-over-NBD without deadlocking
v15" as it depends on the same reservation of PF_MEMALLOC reserves logic.
When a user or administrator requires swap for their application, they
create a swap partition and file, format it with mkswap and activate it
with swapon. In diskless systems this is not an option so if swap if
required then swapping over the network is considered. The two likely
scenarios are when blade servers are used as part of a cluster where the
form factor or maintenance costs do not allow the use of disks and thin
clients.
The Linux Terminal Server Project recommends the use of the Network Block
Device (NBD) for swap but this is not always an option. There is no
guarantee that the network attached storage (NAS) device is running Linux
or supports NBD. However, it is likely that it supports NFS so there are
users that want support for swapping over NFS despite any performance
concern. Some distributions currently carry patches that support swapping
over NFS but it would be preferable to support it in the mainline kernel.
Patch 1 avoids a stream-specific deadlock that potentially affects TCP.
Patch 2 is a small modification to SELinux to avoid using PFMEMALLOC
reserves.
Patch 3 adds three helpers for filesystems to handle swap cache pages.
For example, page_file_mapping() returns page->mapping for
file-backed pages and the address_space of the underlying
swap file for swap cache pages.
Patch 4 adds two address_space_operations to allow a filesystem
to pin all metadata relevant to a swapfile in memory. Upon
successful activation, the swapfile is marked SWP_FILE and
the address space operation ->direct_IO is used for writing
and ->readpage for reading in swap pages.
Patch 5 notes that patch 3 is bolting
filesystem-specific-swapfile-support onto the side and that
the default handlers have different information to what
is available to the filesystem. This patch refactors the
code so that there are generic handlers for each of the new
address_space operations.
Patch 6 adds an API to allow a vector of kernel addresses to be
translated to struct pages and pinned for IO.
Patch 7 adds support for using highmem pages for swap by kmapping
the pages before calling the direct_IO handler.
Patch 8 updates NFS to use the helpers from patch 3 where necessary.
Patch 9 avoids setting PF_private on PG_swapcache pages within NFS.
Patch 10 implements the new swapfile-related address_space operations
for NFS and teaches the direct IO handler how to manage
kernel addresses.
Patch 11 prevents page allocator recursions in NFS by using GFP_NOIO
where appropriate.
Patch 12 fixes a NULL pointer dereference that occurs when using
swap-over-NFS.
With the patches applied, it is possible to mount a swapfile that is on an
NFS filesystem. Swap performance is not great with a swap stress test
taking roughly twice as long to complete than if the swap device was
backed by NBD.
This patch: netvm: prevent a stream-specific deadlock
It could happen that all !SOCK_MEMALLOC sockets have buffered so much data
that we're over the global rmem limit. This will prevent SOCK_MEMALLOC
buffers from receiving data, which will prevent userspace from running,
which is needed to reduce the buffered data.
Fix this by exempting the SOCK_MEMALLOC sockets from the rmem limit. Once
this change it applied, it is important that sockets that set
SOCK_MEMALLOC do not clear the flag until the socket is being torn down.
If this happens, a warning is generated and the tokens reclaimed to avoid
accounting errors until the bug is fixed.
[davem@davemloft.net: Warning about clearing SOCK_MEMALLOC]
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
In order to make sure pfmemalloc packets receive all memory needed to
proceed, ensure processing of pfmemalloc SKBs happens under PF_MEMALLOC.
This is limited to a subset of protocols that are expected to be used for
writing to swap. Taps are not allowed to use PF_MEMALLOC as these are
expected to communicate with userspace processes which could be paged out.
[a.p.zijlstra@chello.nl: Ideas taken from various patches]
[jslaby@suse.cz: Lock imbalance fix]
Cc: Christoph Lameter <cl@linux.com>
Change the skb allocation API to indicate RX usage and use this to fall
back to the PFMEMALLOC reserve when needed. SKBs allocated from the
reserve are tagged in skb->pfmemalloc. If an SKB is allocated from the
reserve and the socket is later found to be unrelated to page reclaim, the
packet is dropped so that the memory remains available for page reclaim.
Network protocols are expected to recover from this packet loss.
[davem@davemloft.net: Use static branches, coding style corrections]
[sebastian@breakpoint.cc: Avoid unnecessary cast, fix !CONFIG_NET build]
Allow specific sockets to be tagged SOCK_MEMALLOC and use __GFP_MEMALLOC
for their allocations. These sockets will be able to go below watermarks
and allocate from the emergency reserve. Such sockets are to be used to
service the VM (iow. to swap over). They must be handled kernel side,
exposing such a socket to user-space is a bug.
There is a risk that the reserves be depleted so for now, the
administrator is responsible for increasing min_free_kbytes as necessary
to prevent deadlock for their workloads.
[a.p.zijlstra@chello.nl: Original patches]
Sanity:
CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG
CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP
CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED
CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM
[mhocko@suse.cz: fix missed bits]
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Instead of updating the sk_cgrp_prioidx struct field on every send
this only updates the field when a task is moved via cgroup
infrastructure.
This allows sockets that may be used by a kernel worker thread
to be managed. For example in the iscsi case today a user can
put iscsid in a netprio cgroup and control traffic will be sent
with the correct sk_cgrp_prioidx value set but as soon as data
is sent the kernel worker thread isssues a send and sk_cgrp_prioidx
is updated with the kernel worker threads value which is the
default case.
It seems more correct to only update the field when the user
explicitly sets it via control group infrastructure. This allows
the users to manage sockets that may be used with other threads.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
This introduce TSQ (TCP Small Queues)
TSQ goal is to reduce number of TCP packets in xmit queues (qdisc &
device queues), to reduce RTT and cwnd bias, part of the bufferbloat
problem.
sk->sk_wmem_alloc not allowed to grow above a given limit,
allowing no more than ~128KB [1] per tcp socket in qdisc/dev layers at a
given time.
TSO packets are sized/capped to half the limit, so that we have two
TSO packets in flight, allowing better bandwidth use.
As a side effect, setting the limit to 40000 automatically reduces the
standard gso max limit (65536) to 40000/2 : It can help to reduce
latencies of high prio packets, having smaller TSO packets.
This means we divert sock_wfree() to a tcp_wfree() handler, to
queue/send following frames when skb_orphan() [2] is called for the
already queued skbs.
Results on my dev machines (tg3/ixgbe nics) are really impressive,
using standard pfifo_fast, and with or without TSO/GSO.
Without reduction of nominal bandwidth, we have reduction of buffering
per bulk sender :
< 1ms on Gbit (instead of 50ms with TSO)
< 8ms on 100Mbit (instead of 132 ms)
I no longer have 4 MBytes backlogged in qdisc by a single netperf
session, and both side socket autotuning no longer use 4 Mbytes.
As skb destructor cannot restart xmit itself ( as qdisc lock might be
taken at this point ), we delegate the work to a tasklet. We use one
tasklest per cpu for performance reasons.
If tasklet finds a socket owned by the user, it sets TSQ_OWNED flag.
This flag is tested in a new protocol method called from release_sock(),
to eventually send new segments.
[1] New /proc/sys/net/ipv4/tcp_limit_output_bytes tunable
[2] skb_orphan() is usually called at TX completion time,
but some drivers call it in their start_xmit() handler.
These drivers should at least use BQL, or else a single TCP
session can still fill the whole NIC TX ring, since TSQ will
have no effect.
Cc: Dave Taht <dave.taht@bufferbloat.net>
Cc: Matt Mathis <mattmathis@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
