[ Upstream commit 4db428a7c9ab07e08783e0fcdc4ca0f555da0567 ]
reuseport_add_sock() needs to deal with attaching a socket having
its own sk_reuseport_cb, after a prior
setsockopt(SO_ATTACH_REUSEPORT_?BPF)
Without this fix, not only a WARN_ONCE() was issued, but we were also
leaking memory.
Thanks to sysbot and Eric Biggers for providing us nice C repros.
socket already in reuseport group
WARNING: CPU: 0 PID: 3496 at net/core/sock_reuseport.c:119
reuseport_add_sock+0x742/0x9b0 net/core/sock_reuseport.c:117
Kernel panic - not syncing: panic_on_warn set ...
CPU: 0 PID: 3496 Comm: syzkaller869503 Not tainted 4.15.0-rc6+ #245
Hardware name: Google Google Compute Engine/Google Compute Engine,
BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
panic+0x1e4/0x41c kernel/panic.c:183
__warn+0x1dc/0x200 kernel/panic.c:547
report_bug+0x211/0x2d0 lib/bug.c:184
fixup_bug.part.11+0x37/0x80 arch/x86/kernel/traps.c:178
fixup_bug arch/x86/kernel/traps.c:247 [inline]
do_error_trap+0x2d7/0x3e0 arch/x86/kernel/traps.c:296
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:315
invalid_op+0x22/0x40 arch/x86/entry/entry_64.S:1079
Fixes: ef456144da8e ("soreuseport: define reuseport groups")
Reported-by: syzbot+c0ea2226f77a42936bf7@syzkaller.appspotmail.com
Acked-by: Craig Gallek <kraig@google.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Syzkaller stumbled upon a way to trigger
WARNING: CPU: 1 PID: 13881 at net/core/sock_reuseport.c:41
reuseport_alloc+0x306/0x3b0 net/core/sock_reuseport.c:39
There are two initialization paths for the sock_reuseport structure in a
socket: Through the udp/tcp bind paths of SO_REUSEPORT sockets or through
SO_ATTACH_REUSEPORT_[CE]BPF before bind. The existing implementation
assumedthat the socket lock protected both of these paths when it actually
only protects the SO_ATTACH_REUSEPORT path. Syzkaller triggered this
double allocation by running these paths concurrently.
This patch moves the check for double allocation into the reuseport_alloc
function which is protected by a global spin lock.
Fixes: e32ea7e74727 ("soreuseport: fast reuseport UDP socket selection")
Fixes: c125e80b8868 ("soreuseport: fast reuseport TCP socket selection")
Signed-off-by: Craig Gallek <kraig@google.com>
Number of sockets is limited by 16-bit, so 64-bit allocation will never
happen.
16-bit ops are the worst code density-wise on x86_64 because of
additional prefix (66).
Space savings:
add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-3 (-3)
function old new delta
reuseport_add_sock 539 536 -3
reuseport_add_sock() is not used from a module,
no need to export it.
Marc Dionne discovered a NULL pointer dereference when setting
SO_REUSEPORT on a socket after it is bound.
This patch removes the assumption that at least one socket in the
reuseport group is bound with the SO_REUSEPORT option before other
bind calls occur.
Reported-by: Marc Dionne <marc.c.dionne@gmail.com>
Tested-by: Marc Dionne <marc.dionne@auristor.com>
Fixes: 538950a1b752 ("soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPF")
Suggested-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Expose socket options for setting a classic or extended BPF program
for use when selecting sockets in an SO_REUSEPORT group. These options
can be used on the first socket to belong to a group before bind or
on any socket in the group after bind.
This change includes refactoring of the existing sk_filter code to
allow reuse of the existing BPF filter validation checks.
Acked-by: Alexei Starovoitov <ast@kernel.org>
struct sock_reuseport is an optional shared structure referenced by each
socket belonging to a reuseport group. When a socket is bound to an
address/port not yet in use and the reuseport flag has been set, the
structure will be allocated and attached to the newly bound socket.
When subsequent calls to bind are made for the same address/port, the
shared structure will be updated to include the new socket and the
newly bound socket will reference the group structure.
Usually, when an incoming packet was destined for a reuseport group,
all sockets in the same group needed to be considered before a
dispatching decision was made. With this structure, an appropriate
socket can be found after looking up just one socket in the group.
This shared structure will also allow for more complicated decisions to
be made when selecting a socket (eg a BPF filter).
This work is based off a similar implementation written by
Ying Cai <ycai@google.com> for implementing policy-based reuseport
selection.
