path: root/net/core
2011-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits) xfrm: Restrict extended sequence numbers to esp xfrm: Check for esn buffer len in xfrm_new_ae xfrm: Assign esn pointers when cloning a state xfrm: Move the test on replay window size into the replay check functions netdev: bfin_mac: document TE setting in RMII modes drivers net: Fix declaration ordering in inline functions. cxgb3: Apply interrupt coalescing settings to all queues net: Always allocate at least 16 skb frags regardless of page size ipv4: Don't ip_rt_put() an error pointer in RAW sockets. net: fix ethtool->set_flags not intended -EINVAL return value mlx4_en: Fix loss of promiscuity tg3: Fix inline keyword usage tg3: use <linux/io.h> and <linux/uaccess.h> instead <asm/io.h> and <asm/uaccess.h> net: use CHECKSUM_NONE instead of magic number Net / jme: Do not use legacy PCI power management myri10ge: small rx_done refactoring bridge: notify applications if address of bridge device changes ipv4: Fix IP timestamp option (IPOPT_TS_PRESPEC) handling in ip_options_echo() can: c_can: Fix tx_bytes accounting can: c_can_platform: fix irq check in probe ...
2011-03-27net: fix ethtool->set_flags not intended -EINVAL return valueStanislaw Gruszka
After commit d5dbda23804156ae6f35025ade5307a49d1db6d7 "ethtool: Add support for vlan accleration.", drivers that have NETIF_F_HW_VLAN_TX, and/or NETIF_F_HW_VLAN_RX feature, but do not allow enable/disable vlan acceleration via ethtool set_flags, always return -EINVAL from that function. Fix by returning -EINVAL only if requested features do not match current settings and can not be changed by driver. Change any driver that define ethtool->set_flags to use ethtool_invalid_flags() to avoid similar problems in the future (also on drivers that do not have the problem). Tested with modified (to reproduce this bug) myri10ge driver. Cc: stable@kernel.org # 2.6.37+ Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27bridge: notify applications if address of bridge device changesstephen hemminger
The mac address of the bridge device may be changed when a new interface is added to the bridge. If this happens, then the bridge needs to call the network notifiers to tickle any other systems that care. Since bridge can be a module, this also means exporting the notifier function. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27net: remove useless comments in net/core/dev.cAmerigo Wang
The code itself can explain what it is doing, no need these comments. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) route: Take the right src and dst addresses in ip_route_newports ipv4: Fix nexthop caching wrt. scoping. ipv4: Invalidate nexthop cache nh_saddr more correctly. net: fix pch_gbe section mismatch warning ipv4: fix fib metrics mlx4_en: Removing HW info from ethtool -i report. net_sched: fix THROTTLED/RUNNING race drivers/net/a2065.c: Convert release_resource to release_region/release_mem_region drivers/net/ariadne.c: Convert release_resource to release_region/release_mem_region bonding: fix rx_handler locking myri10ge: fix rmmod crash mlx4_en: updated driver version to 1.5.4.1 mlx4_en: Using blue flame support mlx4_core: reserve UARs for userspace consumers mlx4_core: maintain available field in bitmap allocator mlx4: Add blue flame support for kernel consumers mlx4_en: Enabling new steering mlx4: Add support for promiscuous mode in the new steering model. mlx4: generalization of multicast steering. mlx4_en: Reporting HW revision in ethtool -i ...
2011-03-22kthread: use kthread_create_on_node()Eric Dumazet
ksoftirqd, kworker, migration, and pktgend kthreads can be created with kthread_create_on_node(), to get proper NUMA affinities for their stack and task_struct. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22net: implement dev_disable_lro() hw_features compatibilityMichał Mirosław
Implement compatibility with new hw_features for dev_disable_lro(). This is a transition path - dev_disable_lro() should be later integrated into netdev_fix_features() after all drivers are converted. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21net: fix incorrect spelling in drop monitor protocolNeil Horman
It was pointed out to me recently that my spelling could be better :) Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18ethtool: __ethtool_set_sg: check for function pointer before using itRoger Luethi
__ethtool_set_sg does not check if dev->ethtool_ops->set_sg is defined which can result in a NULL pointer dereference when ethtool is used to change SG settings for drivers without SG support. Signed-off-by: Roger Luethi <rl@hellgate.ch> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16net: introduce rx_handler results and logic around thatJiri Pirko
This patch allows rx_handlers to better signalize what to do next to it's caller. That makes skb->deliver_no_wcard no longer needed. kernel-doc for rx_handler_result is taken from Nicolas' patch. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (57 commits) tidy the trailing symlinks traversal up Turn resolution of trailing symlinks iterative everywhere simplify link_path_walk() tail Make trailing symlink resolution in path_lookupat() iterative update nd->inode in __do_follow_link() instead of after do_follow_link() pull handling of one pathname component into a helper fs: allow AT_EMPTY_PATH in linkat(), limit that to CAP_DAC_READ_SEARCH Allow passing O_PATH descriptors via SCM_RIGHTS datagrams readlinkat(), fchownat() and fstatat() with empty relative pathnames Allow O_PATH for symlinks New kind of open files - "location only". ext4: Copy fs UUID to superblock ext3: Copy fs UUID to superblock. vfs: Export file system uuid via /proc/<pid>/mountinfo unistd.h: Add new syscalls numbers to asm-generic x86: Add new syscalls for x86_64 x86: Add new syscalls for x86_32 fs: Remove i_nlink check from file system link callback fs: Don't allow to create hardlink for deleted file vfs: Add open by file handle support ...
2011-03-15Allow passing O_PATH descriptors via SCM_RIGHTS datagramsAl Viro
Just need to make sure that AF_UNIX garbage collector won't confuse O_PATHed socket on filesystem for real AF_UNIX opened socket. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14pktgen: bug fix in transmission headers with frags=0Daniel Turull
(bug introduced by commit 26ad787962ef84677a48c560 (pktgen: speedup fragmented skbs) The headers of pktgen were incorrectly added in a pktgen packet without frags (frags=0). There was an offset in the pktgen headers. The cause was in reusing the pgh variable as a return variable in skb_put when adding the payload to the skb. Signed-off-by: Daniel Turull <daniel.turull@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_cmn.c
2011-03-10Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2011-03-10net: don't allow CAP_NET_ADMIN to load non-netdev kernel modulesVasiliy Kulikov
Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't allow anybody load any module not related to networking. This patch restricts an ability of autoloading modules to netdev modules with explicit aliases. This fixes CVE-2011-1019. Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior of loading netdev modules by name (without any prefix) for processes with CAP_SYS_MODULE to maintain the compatibility with network scripts that use autoloading netdev modules by aliases like "eth0", "wlan0". Currently there are only three users of the feature in the upstream kernel: ipip, ip_gre and sit. root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) -- root@albatros:~# grep Cap /proc/$$/status CapInh: 0000000000000000 CapPrm: fffffff800001000 CapEff: fffffff800001000 CapBnd: fffffff800001000 root@albatros:~# modprobe xfs FATAL: Error inserting xfs (/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted root@albatros:~# lsmod | grep xfs root@albatros:~# ifconfig xfs xfs: error fetching interface information: Device not found root@albatros:~# lsmod | grep xfs root@albatros:~# lsmod | grep sit root@albatros:~# ifconfig sit sit: error fetching interface information: Device not found root@albatros:~# lsmod | grep sit root@albatros:~# ifconfig sit0 sit0 Link encap:IPv6-in-IPv4 NOARP MTU:1480 Metric:1 root@albatros:~# lsmod | grep sit sit 10457 0 tunnel4 2957 1 sit For CAP_SYS_MODULE module loading is still relaxed: root@albatros:~# grep Cap /proc/$$/status CapInh: 0000000000000000 CapPrm: ffffffffffffffff CapEff: ffffffffffffffff CapBnd: ffffffffffffffff root@albatros:~# ifconfig xfs xfs: error fetching interface information: Device not found root@albatros:~# lsmod | grep xfs xfs 745319 0 Reference: https://lkml.org/lkml/2011/2/24/203 Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-09pktgen: fix errata in show resultsDaniel Turull
The units in show_results in pktgen were not correct. The results are in usec but it was displayed nsec. Reported-by: Jong-won Lee <ljw@handong.edu> Signed-off-by: Daniel Turull <daniel.turull@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-07net: allow handlers to be processed for orig_devJiri Pirko
This was there before, I forgot about this. Allows deliveries to ptype_base handlers registered for orig_dev. I presume this is still desired. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-03-01inet: Remove unused sk_sndmsg_* from UFOHerbert Xu
UFO doesn't really use the sk_sndmsg_* parameters so touching them is pointless. It can't use them anyway since the whole point of UFO is to use the original pages without copying. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28net: Forgot to commit net/core/dev.c part of Jiri's ->rx_handler patch.David S. Miller
2011-02-27bond: service netpoll arp queue on master deviceAmerigo Wang
Neil pointed out that we can't send ARP reply on behalf of slaves, we need to move the arp queue to their bond device. Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-27netpoll: remove IFF_IN_NETPOLL flagAmerigo Wang
V4: rebase to net-next-2.6 This patch removes the flag IFF_IN_NETPOLL, we don't need it any more since we have netpoll_tx_running() now. Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25net: handle addr_type of 0 properlyHagen Paul Pfeifer
addr_type of 0 means that the type should be adopted from from_dev and not from __hw_addr_del_multiple(). Unfortunately it isn't so and addr_type will always be considered. Fix this by implementing the considered and documented behavior. Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23net: Implement SFEATURES compatibility for not updated driversMichał Mirosław
Use discrete setting ops for not updated drivers. This will not make them conform to full G/SFEATURES semantics, though. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23net: Fix ETHTOOL_GFEATURES compatibilityMichał Mirosław
Implement getting rx checksum state for not updated drivers. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23net: avoid initial "Features changed" messageMichał Mirosław
Avoid "Features changed" message and ndo_set_features call on device registration caused by automatic enabling of GSO and GRO. Driver should have enabled hardware offloads it set in features, so the ndo_set_features() is not needed at registration time. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23Fix "(unregistered net_device): Features changed" messageMichał Mirosław
Fix netdev_update_features() messages on register time by moving the call further in register_netdevice(). When netdev->reg_state != NETREG_REGISTERED, netdev_name() returns "(unregistered netdevice)" even if the dev's name is already filled. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-22net: Make flow cache paths use a const struct flowi.David S. Miller
2011-02-22Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bwh/sfc-next-2.6
2011-02-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/e1000e/netdev.c net/xfrm/xfrm_policy.c
2011-02-18net: deinit automatic LIST_HEADEric Dumazet
commit 9b5e383c11b08784 (net: Introduce unregister_netdevice_many()) left an active LIST_HEAD() in rollback_registered(), with possible memory corruption. Even if device is freed without touching its unreg_list (and therefore touching the previous memory location holding LISTE_HEAD(single), better close the bug for good, since its really subtle. (Same fix for default_device_exit_batch() for completeness) Reported-by: Michal Hocko <mhocko@suse.cz> Tested-by: Michal Hocko <mhocko@suse.cz> Reported-by: Eric W. Biderman <ebiderman@xmission.com> Tested-by: Eric W. Biderman <ebiderman@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Ingo Molnar <mingo@elte.hu> CC: Octavian Purdila <opurdila@ixiacom.com> CC: stable <stable@kernel.org> [.33+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-18net: dont leave active on stack LIST_HEADLinus Torvalds
Eric W. Biderman and Michal Hocko reported various memory corruptions that we suspected to be related to a LIST head located on stack, that was manipulated after thread left function frame (and eventually exited, so its stack was freed and reused). Eric Dumazet suggested the problem was probably coming from commit 443457242beb (net: factorize sync-rcu call in unregister_netdevice_many) This patch fixes __dev_close() and dev_close() to properly deinit their respective LIST_HEAD(single) before exiting. References: https://lkml.org/lkml/2011/2/16/304 References: https://lkml.org/lkml/2011/2/14/223 Reported-by: Michal Hocko <mhocko@suse.cz> Tested-by: Michal Hocko <mhocko@suse.cz> Reported-by: Eric W. Biderman <ebiderman@xmission.com> Tested-by: Eric W. Biderman <ebiderman@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Ingo Molnar <mingo@elte.hu> CC: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: Add initial_ref arg to dst_alloc().David S. Miller
This allows avoiding multiple writes to the initial __refcnt. The most simplest cases of wanting an initial reference of "1" in ipv4 and ipv6 have been converted, the rest have been left along and kept at the existing "0". Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: introduce NETIF_F_RXCSUMMichał Mirosław
Introduce NETIF_F_RXCSUM to replace device-private flags for RX checksum offload. Integrate it with ndo_fix_features. ethtool_op_get_rx_csum() is removed altogether as nothing in-tree uses it. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17net: use ndo_fix_features for ethtool_ops->set_flagsMichał Mirosław
2011-02-17net: ethtool: use ndo_fix_features for offload settingMichał Mirosław
2011-02-17net: Introduce new feature setting opsMichał Mirosław
This introduces a new framework to handle device features setting. It consists of: - new fields in struct net_device: + hw_features - features that hw/driver supports toggling + wanted_features - features that user wants enabled, when possible - new netdev_ops: + feat = ndo_fix_features(dev, feat) - API checking constraints for enabling features or their combinations + ndo_set_features(dev) - API updating hardware state to match changed dev->features - new ethtool commands: + ETHTOOL_GFEATURES/ETHTOOL_SFEATURES: get/set dev->wanted_features and trigger device reconfiguration if resulting dev->features changed + ETHTOOL_GSTRINGS(ETH_SS_FEATURES): get feature bits names (meaning) Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17ethtool: factorize get/set_one_featureMichał Mirosław
This allows to enable GRO even if RX csum is disabled. GRO will not be used for packets without hardware checksum anyway. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17ethtool: factorize ethtool_get_strings() and ethtool_get_sset_count()Michał Mirosław
This is needed for unified offloads patch. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17ethtool: enable GSO and GRO by defaultMichał Mirosław
2011-02-17ethtool: move EXPORT_SYMBOL(ethtool_op_set_tx_csum) to correct placeMichał Mirosław
2011-02-17kbuild, mtd, net: a few comment typo fixes and rewordingGilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-15net: RPS: Make hardware-accelerated RFS conditional on NETIF_F_NTUPLEBen Hutchings
For testing and debugging purposes it is useful to be able to disable hardware acceleration of RFS without disabling RFS altogether. Since this is a similar feature to 'n-tuple' flow steering through the ethtool API, test the same feature flag that controls that. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-15Merge branch 'for-davem' of ↵David S. Miller
2011-02-15net: Adjust TX queue kobjects if number of queues changes during unregisterBen Hutchings
If the root qdisc for a net device is mqprio, and the driver's ndo_setup_tc() operation dynamically adds and remvoes TX queues, netif_set_real_num_tx_queues() will be called during device unregistration to remove the extra TX queues when the qdisc is destroyed. Currently this causes the corresponding kobjects to be leaked, and the device's reference count never drops to 0. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2011-02-13rtnetlink: implement setting of master deviceJiri Pirko
This patch allows userspace to enslave/release slave devices via netlink interface using IFLA_MASTER. This introduces generic way to add/remove underling devices. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
