[ Upstream commit db833d40ad3263b2ee3b59a1ba168bb3cfed8137 ]
Network interface groups support added while ago, however
there is no IFLA_GROUP attribute description in policy
and netlink message size calculations until now.
Add IFLA_GROUP attribute to the policy.
Fixes: cbda10fa97d7 ("net_device: add support for network device groups")
Signed-off-by: Serhey Popovych <serhe.popovych@gmail.com>
[ Upstream commit f186ce61bb8235d80068c390dc2aad7ca427a4c2 ]
It looks like this:
Message from syslogd@flamingo at Apr 26 00:45:00 ...
kernel:unregister_netdevice: waiting for lo to become free. Usage count = 4
They seem to coincide with net namespace teardown.
The message is emitted by netdev_wait_allrefs().
Forced a kdump in netdev_run_todo, but found that the refcount on the lo
device was already 0 at the time we got to the panic.
Used bcc to check the blocking in netdev_run_todo. The only places
where we're off cpu there are in the rcu_barrier() and msleep() calls.
That behavior is expected. The msleep time coincides with the amount of
time we spend waiting for the refcount to reach zero; the rcu_barrier()
wait times are not excessive.
After looking through the list of callbacks that the netdevice notifiers
invoke in this path, it appears that the dst_dev_event is the most
interesting. The dst_ifdown path places a hold on the loopback_dev as
part of releasing the dev associated with the original dst cache entry.
Most of our notifier callbacks are straight-forward, but this one a)
looks complex, and b) places a hold on the network interface in
question.
I constructed a new bcc script that watches various events in the
liftime of a dst cache entry. Note that dst_ifdown will take a hold on
the loopback device until the invalidated dst entry gets freed.
[ __dst_free] on DST: ffff883ccabb7900 IF tap1008300eth0 invoked at 1282115677036183
__dst_free
rcu_nocb_kthread
kthread
ret_from_fork
[ Upstream commit 0eed9cf58446b28b233388b7f224cbca268b6986 ]
Some of the structure's fields are not initialized by the
rtnetlink. If driver doesn't set those in ndo_get_vf_config(),
they'd leak memory to user.
Signed-off-by: Yuval Mintz <Yuval.Mintz@cavium.com>
CC: Michal Schmidt <mschmidt@redhat.com>
Reviewed-by: Greg Rose <gvrose8192@gmail.com>
[ Upstream commit c28294b941232931fbd714099798eb7aa7e865d7 ]
KMSAN reported a use of uninitialized memory in dev_set_alias(),
which was caused by calling strlcpy() (which in turn called strlen())
on the user-supplied non-terminated string.
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit 3808d34838184fd29088d6b3a364ba2f1c018fb6 ]
If ->get_regs_len() callback return 0, we allocate 0 bytes of memory,
what print ugly warning in dmesg, which can be found further below.
This happen on mac80211 devices where ieee80211_get_regs_len() just
return 0 and driver only fills ethtool_regs structure and actually
do not provide any dump. However I assume this can happen on other
drivers i.e. when for some devices driver provide regs dump and for
others do not. Hence preventing to to print warning in ethtool code
seems to be reasonable.
ethtool: vmalloc: allocation failure: 0 bytes, mode:0x24080c2(GFP_KERNEL|__GFP_HIGHMEM|__GFP_ZERO)
<snip>
Call Trace:
[<ffffffff813bde47>] dump_stack+0x63/0x8c
[<ffffffff811b0a1f>] warn_alloc+0x13f/0x170
[<ffffffff811f0476>] __vmalloc_node_range+0x1e6/0x2c0
[<ffffffff811f0874>] vzalloc+0x54/0x60
[<ffffffff8169986c>] dev_ethtool+0xb4c/0x1b30
[<ffffffff816adbb1>] dev_ioctl+0x181/0x520
[<ffffffff816714d2>] sock_do_ioctl+0x42/0x50
<snip>
Mem-Info:
active_anon:435809 inactive_anon:173951 isolated_anon:0
active_file:835822 inactive_file:196932 isolated_file:0
unevictable:0 dirty:8 writeback:0 unstable:0
slab_reclaimable:157732 slab_unreclaimable:10022
mapped:83042 shmem:306356 pagetables:9507 bounce:0
free:130041 free_pcp:1080 free_cma:0
Node 0 active_anon:1743236kB inactive_anon:695804kB active_file:3343288kB inactive_file:787728kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:332168kB dirty:32kB writeback:0kB shmem:0kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1225424kB writeback_tmp:0kB unstable:0kB pages_scanned:0 all_unreclaimable? no
Node 0 DMA free:15900kB min:136kB low:168kB high:200kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15984kB managed:15900kB mlocked:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
lowmem_reserve[]: 0 3187 7643 7643
Node 0 DMA32 free:419732kB min:28124kB low:35152kB high:42180kB active_anon:541180kB inactive_anon:248988kB active_file:1466388kB inactive_file:389632kB unevictable:0kB writepending:0kB present:3370280kB managed:3290932kB mlocked:0kB slab_reclaimable:217184kB slab_unreclaimable:4180kB kernel_stack:160kB pagetables:984kB bounce:0kB free_pcp:2236kB local_pcp:660kB free_cma:0kB
lowmem_reserve[]: 0 0 4456 4456
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 52bd2d62ce6758d811edcbd2256eb9ea7f6a56cb upstream.
skb->sender_cpu and skb->napi_id share a common storage,
and we had various bugs about this.
We had to call skb_sender_cpu_clear() in some places to
not leave a prior skb->napi_id and fool netdev_pick_tx()
As suggested by Alexei, we could split the space so that
these errors can not happen.
0 value being reserved as the common (not initialized) value,
let's reserve [1 .. NR_CPUS] range for valid sender_cpu,
and [NR_CPUS+1 .. ~0U] for valid napi_id.
This will allow proper busy polling support over tunnels.
Suggested-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Paul Menzel <pmenzel@molgen.mpg.de>
commit f6ba8d33cfbb46df569972e64dbb5bb7e929bfd9 upstream.
I should have known that lowering skb->truesize was dangerous :/
In case packets are not leaving the host via a standard Ethernet device,
but looped back to local sockets, bad things can happen, as reported
by Michael Madsen ( https://bugzilla.kernel.org/show_bug.cgi?id=195713 )
So instead of tweaking skb->truesize, lets change skb->destructor
and keep a reference on the owner socket via its sk_refcnt.
Fixes: f2f872f9272a ("netem: Introduce skb_orphan_partial() helper")
Reported-by: Michael Madsen <mkm@nabto.com>
[ Upstream commit 3fb07daff8e99243366a081e5129560734de4ada ]
Andrey Konovalov reported crashes in ipv4_mtu()
I could reproduce the issue with KASAN kernels, between
10.246.7.151 and 10.246.7.152 :
1) 20 concurrent netperf -t TCP_RR -H 10.246.7.152 -l 1000 &
2) At the same time run following loop :
while :
do
ip ro add 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
ip ro del 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
done
Cong Wang attempted to add back rt->fi in commit
82486aa6f1b9 ("ipv4: restore rt->fi for reference counting")
but this proved to add some issues that were complex to solve.
Instead, I suggested to add a refcount to the metrics themselves,
being a standalone object (in particular, no reference to other objects)
I tried to make this patch as small as possible to ease its backport,
instead of being super clean. Note that we believe that only ipv4 dst
need to take care of the metric refcount. But if this is wrong,
this patch adds the basic infrastructure to extend this to other
families.
Many thanks to Julian Anastasov for reviewing this patch, and Cong Wang
for his efforts on this problem.
Fixes: 2860583fe840 ("ipv4: Kill rt->fi")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit f6c5775ff0bfa62b072face6bf1d40f659f194b2 ]
In general, rtnetlink dumps do not anticipate failure to dump a single
object (e.g., link or route) on a single pass. As both route and link
objects have grown via more attributes, that is no longer a given.
netlink dumps can handle a failure if the dump function returns an
error; specifically, netlink_dump adds the return code to the response
if it is <= 0 so userspace is notified of the failure. The missing
piece is the rtnetlink dump functions returning the error.
Fix route and link dump functions to return the errors if no object is
added to an skb (detected by skb->len != 0). IPv6 route dumps
(rt6_dump_route) already return the error; this patch updates IPv4 and
link dumps. Other dump functions may need to be ajusted as well.
Reported-by: Jan Moskyto Matejka <mq@ucw.cz>
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 77ef033b687c3e030017c94a29bf6ea3aaaef678 ]
IFLA_PHYS_PORT_NAME is a string attribute, so terminate it with \0.
Otherwise libnl3 fails to validate netlink messages with this attribute.
"ip -detail a" assumes too that the attribute is NUL-terminated when
printing it. It often was, due to padding.
I noticed this as libvirtd failing to start on a system with sfc driver
after upgrading it to Linux 4.11, i.e. when sfc added support for
phys_port_name.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
[ Upstream commit c70b17b775edb21280e9de7531acf6db3b365274 ]
Reducing real_num_tx_queues needs to be in sync with skb queue_mapping
otherwise skbs with queue_mapping greater than real_num_tx_queues
can be sent to the underlying driver and can result in kernel panic.
One such event is running netconsole and enabling VF on the same
device. Or running netconsole and changing number of tx queues via
ethtool on same device.
e.g.
Unable to handle kernel NULL pointer dereference
tsk->{mm,active_mm}->context = 0000000000001525
tsk->{mm,active_mm}->pgd = fff800130ff9a000
\|/ ____ \|/
/_| \__/ |_\
\__U_/
kworker/48:1(475): Oops [#1]
CPU: 48 PID: 475 Comm: kworker/48:1 Tainted: G OE
4.11.0-rc3-davem-net+ #7
Workqueue: events queue_process
task: fff80013113299c0 task.stack: fff800131132c000
TSTATE: 0000004480e01600 TPC: 00000000103f9e3c TNPC: 00000000103f9e40 Y:
00000000 Tainted: G OE
TPC: <ixgbe_xmit_frame_ring+0x7c/0x6c0 [ixgbe]>
g0: 0000000000000000 g1: 0000000000003fff g2: 0000000000000000 g3:
0000000000000001
g4: fff80013113299c0 g5: fff8001fa6808000 g6: fff800131132c000 g7:
00000000000000c0
o0: fff8001fa760c460 o1: fff8001311329a50 o2: fff8001fa7607504 o3:
0000000000000003
o4: fff8001f96e63a40 o5: fff8001311d77ec0 sp: fff800131132f0e1 ret_pc:
000000000049ed94
RPC: <set_next_entity+0x34/0xb80>
l0: 0000000000000000 l1: 0000000000000800 l2: 0000000000000000 l3:
0000000000000000
l4: 000b2aa30e34b10d l5: 0000000000000000 l6: 0000000000000000 l7:
fff8001fa7605028
i0: fff80013111a8a00 i1: fff80013155a0780 i2: 0000000000000000 i3:
0000000000000000
i4: 0000000000000000 i5: 0000000000100000 i6: fff800131132f1a1 i7:
00000000103fa4b0
I7: <ixgbe_xmit_frame+0x30/0xa0 [ixgbe]>
Call Trace:
[00000000103fa4b0] ixgbe_xmit_frame+0x30/0xa0 [ixgbe]
[0000000000998c74] netpoll_start_xmit+0xf4/0x200
[0000000000998e10] queue_process+0x90/0x160
[0000000000485fa8] process_one_work+0x188/0x480
[0000000000486410] worker_thread+0x170/0x4c0
[000000000048c6b8] kthread+0xd8/0x120
[0000000000406064] ret_from_fork+0x1c/0x2c
[0000000000000000] (null)
Disabling lock debugging due to kernel taint
Caller[00000000103fa4b0]: ixgbe_xmit_frame+0x30/0xa0 [ixgbe]
Caller[0000000000998c74]: netpoll_start_xmit+0xf4/0x200
Caller[0000000000998e10]: queue_process+0x90/0x160
Caller[0000000000485fa8]: process_one_work+0x188/0x480
Caller[0000000000486410]: worker_thread+0x170/0x4c0
Caller[000000000048c6b8]: kthread+0xd8/0x120
Caller[0000000000406064]: ret_from_fork+0x1c/0x2c
Caller[0000000000000000]: (null)
Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com>
[ Upstream commit 48481c8fa16410ffa45939b13b6c53c2ca609e5f ]
Dmitry posted a nice reproducer of a bug triggering in neigh_probe()
when dereferencing a NULL neigh->ops->solicit method.
This can happen for arp_direct_ops/ndisc_direct_ops and similar,
which can be used for NUD_NOARP neighbours (created when dev->header_ops
is NULL). Admin can then force changing nud_state to some other state
that would fire neigh timer.
[ Upstream commit a97e50cc4cb67e1e7bff56f6b41cda62ca832336 ]
In sk_clone_lock(), we create a new socket and inherit most of the
parent's members via sock_copy() which memcpy()'s various sections.
Now, in case the parent socket had a BPF socket filter attached,
then newsk->sk_filter points to the same instance as the original
sk->sk_filter.
sk_filter_charge() is then called on the newsk->sk_filter to take a
reference and should that fail due to hitting max optmem, we bail
out and release the newsk instance.
The issue is that commit 278571baca2a ("net: filter: simplify socket
charging") wrongly combined the dismantle path with the failure path
of xfrm_sk_clone_policy(). This means, even when charging failed, we
call sk_free_unlock_clone() on the newsk, which then still points to
the same sk_filter as the original sk.
Thus, sk_free_unlock_clone() calls into __sk_destruct() eventually
where it tests for present sk_filter and calls sk_filter_uncharge()
on it, which potentially lets sk_omem_alloc wrap around and releases
the eBPF prog and sk_filter structure from the (still intact) parent.
Fix it by making sure that when sk_filter_charge() failed, we reset
newsk->sk_filter back to NULL before passing to sk_free_unlock_clone(),
so that we don't mess with the parents sk_filter.
Only if xfrm_sk_clone_policy() fails, we did reach the point where
either the parent's filter was NULL and as a result newsk's as well
or where we previously had a successful sk_filter_charge(), thus for
that case, we do need sk_filter_uncharge() to release the prior taken
reference on sk_filter.
Fixes: 278571baca2a ("net: filter: simplify socket charging")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 22a0e18eac7a9e986fec76c60fa4a2926d1291e2 ]
I mistakenly added the code to release sk->sk_frag in
sk_common_release() instead of sk_destruct()
TCP sockets using sk->sk_allocation == GFP_ATOMIC do no call
sk_common_release() at close time, thus leaking one (order-3) page.
iSCSI is using such sockets.
Fixes: 5640f7685831 ("net: use a per task frag allocator")
[ Upstream commit 9ac25fc063751379cb77434fef9f3b088cd3e2f7 ]
TX skbs do not necessarily hold a reference on skb->sk->sk_refcnt
By the time TX completion happens, sk_refcnt might be already 0.
sock_hold()/sock_put() would then corrupt critical state, like
sk_wmem_alloc and lead to leaks or use after free.
Fixes: 62bccb8cdb69 ("net-timestamp: Make the clone operation stand-alone from phy timestamping")
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Soheil Hassas Yeganeh <soheil@google.com>
Cc: Willem de Bruijn <willemb@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit dd4f10722aeb10f4f582948839f066bebe44e5fb ]
sk_wmem_alloc.
Fixes: bf7fa551e0ce ("mac80211: Resolve sk_refcnt/sk_wmem_alloc issue in wifi ack path")
[ Upstream commit 13baa00ad01bb3a9f893e3a08cbc2d072fc0c15d ]
It is now very clear that silly TCP listeners might play with
enabling/disabling timestamping while new children are added
to their accept queue.
Meaning net_enable_timestamp() can be called from BH context
while current state of the static key is not enabled.
Lets play safe and allow all contexts.
The work queue is scheduled only under the problematic cases,
which are the static key enable/disable transition, to not slow down
critical paths.
This extends and improves what we did in commit 5fa8bbda38c6 ("net: use
a work queue to defer net_disable_timestamp() work")
Fixes: b90e5794c5bd ("net: dont call jump_label_dec from irq context")
[ Upstream commit 5fa8bbda38c668e56b0c6cdecced2eac2fe36dec ]
Dmitry reported a warning [1] showing that we were calling
net_disable_timestamp() -> static_key_slow_dec() from a non
process context.
Grabbing a mutex while holding a spinlock or rcu_read_lock()
is not allowed.
As Cong suggested, we now use a work queue.
It is possible netstamp_clear() exits while netstamp_needed_deferred
is not zero, but it is probably not worth trying to do better than that.
netstamp_needed_deferred atomic tracks the exact number of deferred
decrements.
[1]
[ INFO: suspicious RCU usage. ]
4.10.0-rc5+ #192 Not tainted
./include/linux/rcupdate.h:561 Illegal context switch in RCU read-side
critical section!
rcu_scheduler_active = 2, debug_locks = 0
2 locks held by syz-executor14/23111:
#0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff83a35c35>] lock_sock
include/net/sock.h:1454 [inline]
rawv6_sendmsg+0x1e65/0x3ec0 net/ipv6/raw.c:919
#1: (rcu_read_lock){......}, at: [<ffffffff83ae2678>] nf_hook
include/linux/netfilter.h:201 [inline]
__ip6_local_out+0x258/0x840 net/ipv6/output_core.c:160
stack backtrace:
CPU: 2 PID: 23111 Comm: syz-executor14 Not tainted 4.10.0-rc5+ #192
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs
01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:15 [inline]
dump_stack+0x2ee/0x3ef lib/dump_stack.c:51
lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4452
rcu_preempt_sleep_check include/linux/rcupdate.h:560 [inline]
___might_sleep+0x560/0x650 kernel/sched/core.c:7748
__might_sleep+0x95/0x1a0 kernel/sched/core.c:7739
mutex_lock_nested+0x24f/0x1730 kernel/locking/mutex.c:752
atomic_dec_and_mutex_lock+0x119/0x160 kernel/locking/mutex.c:1060
__static_key_slow_dec+0x7a/0x1e0 kernel/jump_label.c:149
static_key_slow_dec+0x51/0x90 kernel/jump_label.c:174
net_disable_timestamp+0x3b/0x50 net/core/dev.c:1728
sock_disable_timestamp+0x98/0xc0 net/core/sock.c:403
__sk_destruct+0x27d/0x6b0 net/core/sock.c:1441
sk_destruct+0x47/0x80 net/core/sock.c:1460
__sk_free+0x57/0x230 net/core/sock.c:1468
sock_wfree+0xae/0x120 net/core/sock.c:1645
skb_release_head_state+0xfc/0x200 net/core/skbuff.c:655
skb_release_all+0x15/0x60 net/core/skbuff.c:668
__kfree_skb+0x15/0x20 net/core/skbuff.c:684
kfree_skb+0x16e/0x4c0 net/core/skbuff.c:705
inet_frag_destroy+0x121/0x290 net/ipv4/inet_fragment.c:304
inet_frag_put include/net/inet_frag.h:133 [inline]
nf_ct_frag6_gather+0x1106/0x3840
net/ipv6/netfilter/nf_conntrack_reasm.c:617
ipv6_defrag+0x1be/0x2b0 net/ipv6/netfilter/nf_defrag_ipv6_hooks.c:68
nf_hook_entry_hookfn include/linux/netfilter.h:102 [inline]
nf_hook_slow+0xc3/0x290 net/netfilter/core.c:310
nf_hook include/linux/netfilter.h:212 [inline]
__ip6_local_out+0x489/0x840 net/ipv6/output_core.c:160
ip6_local_out+0x2d/0x170 net/ipv6/output_core.c:170
ip6_send_skb+0xa1/0x340 net/ipv6/ip6_output.c:1722
ip6_push_pending_frames+0xb3/0xe0 net/ipv6/ip6_output.c:1742
rawv6_push_pending_frames net/ipv6/raw.c:613 [inline]
rawv6_sendmsg+0x2d1a/0x3ec0 net/ipv6/raw.c:927
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744
sock_sendmsg_nosec net/socket.c:635 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:645
sock_write_iter+0x326/0x600 net/socket.c:848
do_iter_readv_writev+0x2e3/0x5b0 fs/read_write.c:695
do_readv_writev+0x42c/0x9b0 fs/read_write.c:872
vfs_writev+0x87/0xc0 fs/read_write.c:911
do_writev+0x110/0x2c0 fs/read_write.c:944
SYSC_writev fs/read_write.c:1017 [inline]
SyS_writev+0x27/0x30 fs/read_write.c:1014
entry_SYSCALL_64_fastpath+0x1f/0xc2
RIP: 0033:0x445559
RSP: 002b:00007f6f46fceb58 EFLAGS: 00000292 ORIG_RAX: 0000000000000014
RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 0000000000445559
RDX: 0000000000000001 RSI: 0000000020f1eff0 RDI: 0000000000000005
RBP: 00000000006e19c0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000292 R12: 0000000000700000
R13: 0000000020f59000 R14: 0000000000000015 R15: 0000000000020400
BUG: sleeping function called from invalid context at
in_atomic(): 1, irqs_disabled(): 0, pid: 23111, name: syz-executor14
INFO: lockdep is turned off.
01/01/2011
Call Trace:
___might_sleep+0x47e/0x650 kernel/sched/core.c:7780
RIP: 0033:0x445559
Suggested-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit 7be2c82cfd5d28d7adb66821a992604eb6dd112e ]
Ashizuka reported a highmem oddity and sent a patch for freescale
fec driver.
But the problem root cause is that core networking stack
must ensure no skb with highmem fragment is ever sent through
a device that does not assert NETIF_F_HIGHDMA in its features.
We need to call illegal_highdma() from harmonize_features()
regardless of CSUM checks.
Fixes: ec5f06156423 ("net: Kill link between CSUM and SG features.")
Cc: Pravin Shelar <pshelar@ovn.org>
Reported-by: "Ashizuka, Yuusuke" <ashiduka@jp.fujitsu.com>
[ Upstream commit 7cfd5fd5a9813f1430290d20c0fead9b4582a307 ]
On 32bit arches, (skb->end - skb->data) is not 'unsigned int',
so we shall use min_t() instead of min() to avoid a compiler error.
Fixes: 1272ce87fa01 ("gro: Enter slow-path if there is no tailroom")
Reported-by: kernel test robot <fengguang.wu@intel.com>
[ Upstream commit 1272ce87fa017ca4cf32920764d879656b7a005a ]
The GRO path has a fast-path where we avoid calling pskb_may_pull
and pskb_expand by directly accessing frag0. However, this should
only be done if we have enough tailroom in the skb as otherwise
we'll have to expand it later anyway.
This patch adds the check by capping frag0_len with the skb tailroom.
Fixes: cb18978cbf45 ("gro: Open-code final pskb_may_pull")
Reported-by: Slava Shwartsman <slavash@mellanox.com>
[ Upstream commit 3b48ab2248e61408910e792fe84d6ec466084c1a ]
Final nlmsg_len field update must reflect inserted net_dm_drop_point
data.
This patch depends on previous patch:
"drop_monitor: add missing call to genlmsg_end"
Signed-off-by: Reiter Wolfgang <wr0112358@gmail.com>
[ Upstream commit 4200462d88f47f3759bdf4705f87e207b0f5b2e4 ]
Update nlmsg_len field with genlmsg_end to enable userspace processing
using nlmsg_next helper. Also adds error handling.
[ Upstream commit b98b0bc8c431e3ceb4b26b0dfc8db509518fb290 ]
CAP_NET_ADMIN users should not be allowed to set negative
sk_sndbuf or sk_rcvbuf values, as it can lead to various memory
corruptions, crashes, OOM...
Note that before commit 82981930125a ("net: cleanups in
sock_setsockopt()"), the bug was even more serious, since SO_SNDBUF
and SO_RCVBUF were vulnerable.
This needs to be backported to all known linux kernels.
Again, many thanks to syzkaller team for discovering this gem.
[ Upstream commit f82ef3e10a870acc19fa04f80ef5877eaa26f41e ]
Add missing NDA_VLAN attribute's size.
Fixes: 1e53d5bb8878 ("net: Pass VLAN ID to rtnl_fdb_notify.")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
[ Upstream commit cfc44a4d147ea605d66ccb917cc24467d15ff867 ]
Andrei reports we still allocate netns ID from idr after we destroy
it in cleanup_net().
cleanup_net():
idr_destroy(&net->netns_ids);
list_for_each_entry_reverse(ops, &pernet_list, list)
ops_exit_list(ops, &net_exit_list);
-> rollback_registered_many()
-> rtmsg_ifinfo_build_skb()
-> rtnl_fill_ifinfo()
-> peernet2id_alloc()
After that point we should not even access net->netns_ids, we
should check the death of the current netns as early as we can in
peernet2id_alloc().
For net-next we can consider to avoid sending rtmsg totally,
it is a good optimization for netns teardown path.
Fixes: 0c7aecd4bde4 ("netns: add rtnl cmd to add and get peer netns ids")
Reported-by: Andrei Vagin <avagin@gmail.com>
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Andrei Vagin <avagin@openvz.org>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
commit c9b8af1330198ae241cd545e1f040019010d44d9 upstream.
Andre Noll reported panics after my recent fix (commit 34fad54c2537
"net: __skb_flow_dissect() must cap its return value")
After some more headaches, Alexander root caused the problem to
init_default_flow_dissectors() being called too late, in case
a network driver like IGB is not a module and receives DHCP message
very early.
Fix is to call init_default_flow_dissectors() much earlier,
as it is a core infrastructure and does not depend on another
kernel service.
Fixes: 06635a35d13d4 ("flow_dissect: use programable dissector in skb_flow_dissect and friends")
Reported-by: Andre Noll <maan@tuebingen.mpg.de>
Diagnosed-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit ac6e780070e30e4c35bd395acfe9191e6268bdd3 ]
With syzkaller help, Marco Grassi found a bug in TCP stack,
crashing in tcp_collapse()
Root cause is that sk_filter() can truncate the incoming skb,
but TCP stack was not really expecting this to happen.
It probably was expecting a simple DROP or ACCEPT behavior.
We first need to make sure no part of TCP header could be removed.
Then we need to adjust TCP_SKB_CB(skb)->end_seq
Many thanks to syzkaller team and Marco for giving us a reproducer.
Reported-by: Marco Grassi <marco.gra@gmail.com>
Reported-by: Vladis Dronov <vdronov@redhat.com>
[ Upstream commit 34fad54c2537f7c99d07375e50cb30aa3c23bd83 ]
After Tom patch, thoff field could point past the end of the buffer,
this could fool some callers.
If an skb was provided, skb->len should be the upper limit.
If not, hlen is supposed to be the upper limit.
Fixes: a6e544b0a88b ("flow_dissector: Jump to exit code in __skb_flow_dissect")
Reported-by: Yibin Yang <yibyang@cisco.com
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
Acked-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 4f2e4ad56a65f3b7d64c258e373cb71e8d2499f4 ]
Sending zero checksum is ok for TCP, but not for UDP.
UDPv6 receiver should by default drop a frame with a 0 checksum,
and UDPv4 would not verify the checksum and might accept a corrupted
packet.
Simply replace such checksum by 0xffff, regardless of transport.
This error was caught on SIT tunnels, but seems generic.
Cc: Maciej Żenczykowski <maze@google.com>
Acked-by: Maciej Żenczykowski <maze@google.com>
[ Upstream commit e551c32d57c88923f99f8f010e89ca7ed0735e83 ]
At accept() time, it is possible the parent has a non zero
sk_err_soft, leftover from a prior error.
Make sure we do not leave this value in the child, as it
makes future getsockopt(SO_ERROR) calls quite unreliable.
[ Upstream commit 104ba78c98808ae837d1f63aae58c183db5505df ]
When transmitting on a packet socket with PACKET_VNET_HDR and
PACKET_QDISC_BYPASS, validate device support for features requested
in vnet_hdr.
Drop TSO packets sent to devices that do not support TSO or have the
feature disabled. Note that the latter currently do process those
packets correctly, regardless of not advertising the feature.
Because of SKB_GSO_DODGY, it is not sufficient to test device features
with netif_needs_gso. Full validate_xmit_skb is needed.
Switch to software checksum for non-TSO packets that request checksum
offload if that device feature is unsupported or disabled. Note that
similar to the TSO case, device drivers may perform checksum offload
correctly even when not advertising it.
When switching to software checksum, packets hit skb_checksum_help,
which has two BUG_ON checksum not in linear segment. Packet sockets
always allocate at least up to csum_start + csum_off + 2 as linear.
Tested by running github.com/wdebruij/kerneltools/psock_txring_vnet.c
ethtool -K eth0 tso off tx on
psock_txring_vnet -d $dst -s $src -i eth0 -l 2000 -n 1 -q -v
psock_txring_vnet -d $dst -s $src -i eth0 -l 2000 -n 1 -q -v -N
ethtool -K eth0 tx off
psock_txring_vnet -d $dst -s $src -i eth0 -l 1000 -n 1 -q -v -G
psock_txring_vnet -d $dst -s $src -i eth0 -l 1000 -n 1 -q -v -G -N
v2:
- add EXPORT_SYMBOL_GPL(validate_xmit_skb_list)
Fixes: d346a3fae3ff ("packet: introduce PACKET_QDISC_BYPASS socket option")
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit fcd91dd449867c6bfe56a81cabba76b829fd05cd ]
Currently, GRO can do unlimited recursion through the gro_receive
handlers. This was fixed for tunneling protocols by limiting tunnel GRO
to one level with encap_mark, but both VLAN and TEB still have this
problem. Thus, the kernel is vulnerable to a stack overflow, if we
receive a packet composed entirely of VLAN headers.
This patch adds a recursion counter to the GRO layer to prevent stack
overflow. When a gro_receive function hits the recursion limit, GRO is
aborted for this skb and it is processed normally. This recursion
counter is put in the GRO CB, but could be turned into a percpu counter
if we run out of space in the CB.
Thanks to Vladimír Beneš <vbenes@redhat.com> for the initial bug report.
Fixes: CVE-2016-7039
Fixes: 9b174d88c257 ("net: Add Transparent Ethernet Bridging GRO support.")
Fixes: 66e5133f19e9 ("vlan: Add GRO support for non hardware accelerated vlan")
Reviewed-by: Jiri Benc <jbenc@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Tom Herbert <tom@herbertland.com>
[ Upstream commit 9a0b1e8ba4061778897b544afc898de2163382f7 ]
After Jesper commit back in linux-3.18, we trigger a lockdep
splat in proc_create_data() while allocating memory from
pktgen_change_name().
This patch converts t->if_lock to a mutex, since it is now only
used from control path, and adds proper locking to pktgen_change_name()
1) pktgen_thread_lock to protect the outer loop (iterating threads)
2) t->if_lock to protect the inner loop (iterating devices)
Note that before Jesper patch, pktgen_change_name() was lacking proper
protection, but lockdep was not able to detect the problem.
Fixes: 8788370a1d4b ("pktgen: RCU-ify "if_list" to remove lock in next_to_run()")
Reported-by: John Sperbeck <jsperbeck@google.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit 93409033ae653f1c9a949202fb537ab095b2092f ]
This is a respin of a patch to fix a relatively easily reproducible kernel
panic related to the all_adj_list handling for netdevs in recent kernels.
The following sequence of commands will reproduce the issue:
ip link add link eth0 name eth0.100 type vlan id 100
ip link add link eth0 name eth0.200 type vlan id 200
ip link add name testbr type bridge
ip link set eth0.100 master testbr
ip link set eth0.200 master testbr
ip link add link testbr mac0 type macvlan
ip link delete dev testbr
This creates an upper/lower tree of (excuse the poor ASCII art):
/---eth0.100-eth0
mac0-testbr-
\---eth0.200-eth0
When testbr is deleted, the all_adj_lists are walked, and eth0 is deleted twice from
the mac0 list. Unfortunately, during setup in __netdev_upper_dev_link, only one
reference to eth0 is added, so this results in a panic.
This change adds reference count propagation so things are handled properly.
Matthias Schiffer reported a similar crash in batman-adv:
https://github.com/freifunk-gluon/gluon/issues/680
https://www.open-mesh.org/issues/247
which this patch also seems to resolve.
Signed-off-by: Andrew Collins <acollins@cradlepoint.com>
[ Upstream commit 63d75463c91a5b5be7c0aca11ceb45ea5a0ae81d ]
The commit 879c7220e828 ("net: pktgen: Observe needed_headroom
of the device") increased the 'pkt_overhead' field value by
LL_RESERVED_SPACE.
As a side effect the generated packet size, computed as:
/* Eth + IPh + UDPh + mpls */
datalen = pkt_dev->cur_pkt_size - 14 - 20 - 8 -
pkt_dev->pkt_overhead;
is decreased by the same value.
The above changed slightly the behavior of existing pktgen users,
and made the procfs interface somewhat inconsistent.
Fix it by restoring the previous pkt_overhead value and using
LL_RESERVED_SPACE as extralen in skb allocation.
Also, change pktgen_alloc_skb() to only partially reserve
the headroom to allow the caller to prefetch from ll header
start.
v1 -> v2:
- fixed some typos in the comments
Fixes: 879c7220e828 ("net: pktgen: Observe needed_headroom of the device")
Suggested-by: Ben Greear <greearb@candelatech.com>
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
commit fac8e0f579695a3ecbc4d3cac369139d7f819971 upstream.
When drivers express support for TSO of encapsulated packets, they
only mean that they can do it for one layer of encapsulation.
Supporting additional levels would mean updating, at a minimum,
more IP length fields and they are unaware of this.
No encapsulation device expresses support for handling offloaded
encapsulated packets, so we won't generate these types of frames
in the transmit path. However, GRO doesn't have a check for
multiple levels of encapsulation and will attempt to build them.
UDP tunnel GRO actually does prevent this situation but it only
handles multiple UDP tunnels stacked on top of each other. This
generalizes that solution to prevent any kind of tunnel stacking
that would cause problems.
Fixes: bf5a755f ("net-gre-gro: Add GRE support to the GRO stack")
Signed-off-by: Jesse Gross <jesse@kernel.org>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
[ Upstream commit 24b27fc4cdf9e10c5e79e5923b6b7c2c5c95096c ]
Following few steps will crash kernel -
(a) Create bonding master
> modprobe bonding miimon=50
(b) Create macvlan bridge on eth2
> ip link add link eth2 dev mvl0 address aa:0:0:0:0:01 \
type macvlan
(c) Now try adding eth2 into the bond
> echo +eth2 > /sys/class/net/bond0/bonding/slaves
<crash>
Bonding does lots of things before checking if the device enslaved is
busy or not.
In this case when the notifier call-chain sends notifications, the
bond_netdev_event() assumes that the rx_handler /rx_handler_data is
registered while the bond_enslave() hasn't progressed far enough to
register rx_handler for the new slave.
This patch adds a rx_handler check that can be performed right at the
beginning of the enslave code to avoid getting into this situation.
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
[ Upstream commit 82a31b9231f02d9c1b7b290a46999d517b0d312a ]
Similar to commit 9b368814b336 ("net: fix bridge multicast packet checksum validation")
we need to fixup the checksum for CHECKSUM_COMPLETE when
pushing skb on RX path. Otherwise we get similar splats.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Tom Herbert <tom@herbertland.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
[ Upstream commit eb70db8756717b90c01ccc765fdefc4dd969fc74 ]
People who use PACKET_FANOUT_HASH want a symmetric hash, meaning that
they want packets going in both directions on a flow to hash to the
same bucket.
The core kernel SKB hash became non-symmetric when the ipv6 flow label
and other entities were incorporated into the standard flow hash order
to increase entropy.
But there are no users of PACKET_FANOUT_HASH who want an assymetric
hash, they all want a symmetric one.
Therefore, use the flow dissector to compute a flat symmetric hash
over only the protocol, addresses and ports. This hash does not get
installed into and override the normal skb hash, so this change has
no effect whatsoever on the rest of the stack.
Reported-by: Eric Leblond <eric@regit.org>
Tested-by: Eric Leblond <eric@regit.org>
[ Upstream commit 3697649ff29e0f647565eed04b27a7779c646a22 ]
When we're dealing with clones and the area is not writeable, try
harder and get a copy via pskb_expand_head(). Replace also other
occurences in tc actions with the new skb_try_make_writable().
Reported-by: Ashhad Sheikh <ashhadsheikh394@gmail.com>
[ Upstream commit b560f03ddfb072bca65e9440ff0dc4f9b1d1f056 ]
neigh_xmit() expects to be called inside an RCU-bh read side critical
section, and while one of its two current callers gets this right, the
other one doesn't.
More specifically, neigh_xmit() has two callers, mpls_forward() and
mpls_output(), and while both callers call neigh_xmit() under
rcu_read_lock(), this provides sufficient protection for neigh_xmit()
only in the case of mpls_forward(), as that is always called from
softirq context and therefore doesn't need explicit BH protection,
while mpls_output() can be called from process context with softirqs
enabled.
When mpls_output() is called from process context, with softirqs
enabled, we can be preempted by a softirq at any time, and RCU-bh
considers the completion of a softirq as signaling the end of any
pending read-side critical sections, so if we do get a softirq
while we are in the part of neigh_xmit() that expects to be run inside
an RCU-bh read side critical section, we can end up with an unexpected
RCU grace period running right in the middle of that critical section,
making things go boom.
This patch fixes this impedance mismatch in the callee, by making
neigh_xmit() always take rcu_read_{,un}lock_bh() around the code that
expects to be treated as an RCU-bh read side critical section, as this
seems a safer option than fixing it in the callers.
Fixes: 4fd3d7d9e868f ("neigh: Add helper function neigh_xmit")
Signed-off-by: David Barroso <dbarroso@fastly.com>
Signed-off-by: Lennert Buytenhek <lbuytenhek@fastly.com>
Acked-by: David Ahern <dsa@cumulusnetworks.com>
Acked-by: Robert Shearman <rshearma@brocade.com>
[ Upstream commit 5f8e44741f9f216e33736ea4ec65ca9ac03036e6 ]
The stack object “map” has a total size of 32 bytes. Its last 4
bytes are padding generated by compiler. These padding bytes are
not initialized and sent out via “nla_put”.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
[ Upstream commit 9241e2df4fbc648a92ea0752918e05c26255649e ]
When __vlan_insert_tag() fails from skb_vlan_push() path due to the
skb_cow_head(), we need to undo the __skb_push() in the error path
as well that was done earlier to move skb->data pointer to mac header.
Moreover, I noticed that when in the non-error path the __skb_pull()
is done and the original offset to mac header was non-zero, we fixup
from a wrong skb->data offset in the checksum complete processing.
So the skb_postpush_rcsum() really needs to be done before __skb_pull()
where skb->data still points to the mac header start and thus operates
under the same conditions as in __vlan_insert_tag().
Fixes: 93515d53b133 ("net: move vlan pop/push functions into common code")
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 6b83d28a55a891a9d70fc61ccb1c138e47dcbe74 ]
Replace individual implementations with the recently introduced
skb_postpush_rcsum() helper.
[ Upstream commit 5a5abb1fa3b05dd6aa821525832644c1e7d2905f ]
Sasha Levin reported a suspicious rcu_dereference_protected() warning
found while fuzzing with trinity that is similar to this one:
[ 52.765684] net/core/filter.c:2262 suspicious rcu_dereference_protected() usage!
[ 52.765688] other info that might help us debug this:
[ 52.765695] rcu_scheduler_active = 1, debug_locks = 1
[ 52.765701] 1 lock held by a.out/1525:
[ 52.765704] #0: (rtnl_mutex){+.+.+.}, at: [<ffffffff816a64b7>] rtnl_lock+0x17/0x20
[ 52.765721] stack backtrace:
[ 52.765728] CPU: 1 PID: 1525 Comm: a.out Not tainted 4.5.0+ #264
[ 52.765768] Call Trace:
[ 52.765775] [<ffffffff813e488d>] dump_stack+0x85/0xc8
[ 52.765784] [<ffffffff810f2fa5>] lockdep_rcu_suspicious+0xd5/0x110
[ 52.765792] [<ffffffff816afdc2>] sk_detach_filter+0x82/0x90
[ 52.765801] [<ffffffffa0883425>] tun_detach_filter+0x35/0x90 [tun]
[ 52.765810] [<ffffffffa0884ed4>] __tun_chr_ioctl+0x354/0x1130 [tun]
[ 52.765818] [<ffffffff8136fed0>] ? selinux_file_ioctl+0x130/0x210
[ 52.765827] [<ffffffffa0885ce3>] tun_chr_ioctl+0x13/0x20 [tun]
[ 52.765834] [<ffffffff81260ea6>] do_vfs_ioctl+0x96/0x690
[ 52.765843] [<ffffffff81364af3>] ? security_file_ioctl+0x43/0x60
[ 52.765850] [<ffffffff81261519>] SyS_ioctl+0x79/0x90
[ 52.765858] [<ffffffff81003ba2>] do_syscall_64+0x62/0x140
[ 52.765866] [<ffffffff817d563f>] entry_SYSCALL64_slow_path+0x25/0x25
Same can be triggered with PROVE_RCU (+ PROVE_RCU_REPEATEDLY) enabled
from tun_attach_filter() when user space calls ioctl(tun_fd, TUN{ATTACH,
DETACH}FILTER, ...) for adding/removing a BPF filter on tap devices.
Since the fix in f91ff5b9ff52 ("net: sk_{detach|attach}_filter() rcu
fixes") sk_attach_filter()/sk_detach_filter() now dereferences the
filter with rcu_dereference_protected(), checking whether socket lock
is held in control path.
Since its introduction in 994051625981 ("tun: socket filter support"),
tap filters are managed under RTNL lock from __tun_chr_ioctl(). Thus the
sock_owned_by_user(sk) doesn't apply in this specific case and therefore
triggers the false positive.
Extend the BPF API with __sk_attach_filter()/__sk_detach_filter() pair
that is used by tap filters and pass in lockdep_rtnl_is_held() for the
rcu_dereference_protected() checks instead.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
[ Upstream commit c57c7a95da842807b475b823ed2e5435c42cb3b0 ]
Size of the attribute IFLA_PHYS_PORT_NAME was missing.
Fixes: db24a9044ee1 ("net: add support for phys_port_name")
CC: David Ahern <dsahern@gmail.com>
Acked-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 9b368814b336b0a1a479135eb2815edbc00efd3c ]
We need to update the skb->csum after pulling the skb, otherwise
an unnecessary checksum (re)computation can ocure for IGMP/MLD packets
in the bridge code. Additionally this fixes the following splats for
network devices / bridge ports with support for and enabled RX checksum
offloading:
[ 43.986968] eth0: hw csum failure
[ 43.990344] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.0 #2
[ 43.996193] Hardware name: BCM2709
[ 43.999647] [<800204e0>] (unwind_backtrace) from [<8001cf14>] (show_stack+0x10/0x14)
[ 44.007432] [<8001cf14>] (show_stack) from [<801ab614>] (dump_stack+0x80/0x90)
[ 44.014695] [<801ab614>] (dump_stack) from [<802e4548>] (__skb_checksum_complete+0x6c/0xac)
[ 44.023090] [<802e4548>] (__skb_checksum_complete) from [<803a055c>] (ipv6_mc_validate_checksum+0x104/0x178)
[ 44.032959] [<803a055c>] (ipv6_mc_validate_checksum) from [<802e111c>] (skb_checksum_trimmed+0x130/0x188)
[ 44.042565] [<802e111c>] (skb_checksum_trimmed) from [<803a06e8>] (ipv6_mc_check_mld+0x118/0x338)
[ 44.051501] [<803a06e8>] (ipv6_mc_check_mld) from [<803b2c98>] (br_multicast_rcv+0x5dc/0xd00)
[ 44.060077] [<803b2c98>] (br_multicast_rcv) from [<803aa510>] (br_handle_frame_finish+0xac/0x51c)
Fixes: 9afd85c9e455 ("net: Export IGMP/MLD message validation code")
Reported-by: Álvaro Fernández Rojas <noltari@gmail.com>
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
[ Upstream commit a813104d923339144078939175faf4e66aca19b4 ]
My implementation around IFF_NO_QUEUE driver flag assumed that leaving
tx_queue_len untouched (specifically: not setting it to zero) by drivers
would make it possible to assign a regular qdisc to them without having
to worry about setting tx_queue_len to a useful value. This was only
partially true: I overlooked that some drivers don't call ether_setup()
and therefore not initialize tx_queue_len to the default value of 1000.
Consequently, removing the workarounds in place for that case in qdisc
implementations which cared about it (namely, pfifo, bfifo, gred, htb,
plug and sfb) leads to problems with these specific interface types and
qdiscs.
Luckily, there's already a sanitization point for drivers setting
tx_queue_len to zero, which can be reused to assign the fallback value
most qdisc implementations used, which is 1.
Fixes: 348e3435cbefa ("net: sched: drop all special handling of tx_queue_len == 0")
Tested-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Signed-off-by: Phil Sutter <phil@nwl.cc>
eth_get_headlen
[ Upstream commit 461547f3158978c180d74484d58e82be9b8e7357 ]
This patch fixes an issue with unaligned accesses when using
eth_get_headlen on a page that was DMA aligned instead of being IP aligned.
The fact is when trying to check the length we don't need to be looking at
the flow label so we can reorder the checks to first check if we are
supposed to gather the flow label and then make the call to actually get
it.
v2: Updated path so that either STOP_AT_FLOW_LABEL or KEY_FLOW_LABEL can
cause us to check for the flow label.
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
