path: root/net/dccp/ackvec.c
2006-10-24[DCCP]: Update documentation references.Gerrit Renker
Updates the references to spec documents throughout the code, taking into account that * the DCCP, CCID 2, and CCID 3 drafts all became RFCs in March this year * RFC 1063 was obsoleted by RFC 1191 * draft-ietf-tcpimpl-pmtud-0x.txt was published as an Informational RFC, RFC 2923 on 2000-09-22. All references verified. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[DCCP] ackvec: Remove unused variablesAndrea Bittau
Get rid of unused variables in ackvector state. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[DCCP] ackvec: Fix how DCCP_ACKVEC_STATE_NOT_RECEIVED is usedAndrea Bittau
Fix the way state is masked out. DCCP_ACKVEC_STATE_NOT_RECEIVED is defined as appears in the packet, therefore bit shifting is not required. This fix allows CCID2 to correctly detect losses. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[DCCP] ACKVEC: fix ackvector length calculationAndrea Bittau
Fix ackvector length calculation upon receiving an "ack-of-ack". This patch avoids the ackvector from growing too large which causes it to not be inserted into packets. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-11[DCCP] Ackvec: fix soft lockup in ackvec handling codeAndrea Bittau
A soft lockup existed in the handling of ack vector records. Specifically, when a tail of the list of ack vector records was removed, it was possible to end up iterating infinitely on an element of the tail. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] options: Make dccp_insert_options & friends yell on errorArnaldo Carvalho de Melo
And not the silly LIMIT_NETDEBUG and silently return without inserting the option requested. Also drop some old debugging messages associated to option insertion. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] ackvec: Delete all the ack vector records in dccp_ackvec_freeArnaldo Carvalho de Melo
2006-03-20[DCCP] ackvec: Introduce ack vector recordsAndrea Bittau
Based on a patch by Andrea Bittau. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] ackvec: Introduce dccp_ackvec_slabArnaldo Carvalho de Melo
2006-03-20[DCCP] ackvec: Ditch dccpav_buf_lenArnaldo Carvalho de Melo
Simplifying the code a bit as we're always using DCCP_MAX_ACKVEC_LEN. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[NET]: "signed long" -> "long"Kris Katterjohn
Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-04[DCCP] ackvec: use u8 for the buf offsetsArnaldo Carvalho de Melo
2006-01-04[DCCP] ackvec: Fix spelling of "throw"Andrea Bittau
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-18[DCCP]: Move the ack vector code to net/dccp/ackvec.[ch]Arnaldo Carvalho de Melo
Isolating it, that will be used when we introduce a CCID2 (TCP-Like) implementation. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
