path: root/net/dccp/ipv4.c
2008-09-09This reverts "Merge branch 'dccp' of git://eden-feed.erg.abdn.ac.uk/dccp_exp"Gerrit Renker
as it accentally contained the wrong set of patches. These will be submitted separately. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-09-04dccp: Cleanup routines for feature negotiationGerrit Renker
This inserts the required de-allocation routines for memory allocated by feature negotiation in the socket destructors, replacing dccp_feat_clean() in one instance. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz>
2008-09-04dccp: Per-socket initialisation of feature negotiationGerrit Renker
This provides feature-negotiation initialisation for both DCCP sockets and DCCP request_sockets, to support feature negotiation during connection setup. It also resolves a FIXME regarding the congestion control initialisation. Thanks to Wei Yongjun for help with the IPv6 side of this patch. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz>
2008-07-26dccp: Fix incorrect length check for ICMPv4 packetsWei Yongjun
Unlike TCP, which only needs 8 octets of original packet data, DCCP requires minimally 12 or 16 bytes for ICMP-payload sequence number checks. This patch replaces the insufficient length constant of 8 with a two-stage test, making sure that 12 bytes are available, before computing the basic header length required for sequence number checks. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-07-26dccp: Fix sequence number check for ICMPv4 packetsWei Yongjun
The payload of ICMP message is a part of the packet sent by ourself, so the sequence number check must use AWL and AWH, not SWL and SWH. For example: Endpoint A Endpoint B DATA-ACK --------> (SEQ=X) <-------- ICMP (Fragmentation Needed) (SEQ=X) Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to NET_INC_STATS_BHPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to IP_INC_STATS_BHPavel Emelyanov
2008-07-14mib: add struct net to ICMP_INC_STATS_BHPavel Emelyanov
2008-07-14inet: toss struct net initialization aroundPavel Emelyanov
Some places, that deal with ICMP statistics already have where to get a struct net from, but use it directly, without declaring a separate variable on the stack. Since I will need this net soon, I declare a struct net on the stack and use it in the existing places in a separate patch not to spoil the future ones. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10inet{6}_request_sock: Init ->opt and ->pktopts in the constructorArnaldo Carvalho de Melo
Wei Yongjun noticed that we may call reqsk_free on request sock objects where the opt fields may not be initialized, fix it by introducing inet_reqsk_alloc where we initialize ->opt to NULL and set ->pktopts to NULL in inet6_reqsk_alloc. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-27dccp: Fix to handle short sequence numbers packet correctlyWei Yongjun
RFC4340 said: 8.5. Pseudocode ... If P.type is not Data, Ack, or DataAck and P.X == 0 (the packet has short sequence numbers), drop packet and return But DCCP has some mistake to handle short sequence numbers packet, now it drop packet only if P.type is Data, Ack, or DataAck and P.X == 0. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[DCCP]: Fix comment about control sockets.Pavel Emelyanov
These sockets now have a bit other names and are no longer global. Shame on me, I haven't provided a good comment for this when sending DCCP netnsization patches. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-13[NETNS][DCCPV4]: Enable DCCPv4 in net namespaces.Pavel Emelyanov
This enables sockets creation with IPPROTO_DCCP and enables the ip level to pass DCCP packets to the DCCP level. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NETNS][DCCPV4]: Make per-net socket lookup.Pavel Emelyanov
The inet_lookup family of functions requires a net to lookup a socket in, so give a proper one to them. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NETNS][DCCPV4]: Use proper net to route the reset packet.Pavel Emelyanov
The dccp_v4_route_skb used in dccp_v4_ctl_send_reset, currently works with init_net's routing tables - fix it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NETNS][DCCPV4]: Actually create ctl socket on each net and use it.Pavel Emelyanov
Move the call to inet_ctl_sock_create to init callback (and inet_ctl_sock_destroy to exit one) and use proper ctl sock in dccp_v4_ctl_send_reset. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NETNS][DCCPV4]: Move the dccp_v4_ctl_sk on the struct net.Pavel Emelyanov
And replace all its usage with init_net's socket. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NETNS][DCCPV4]: Add dummy per-net operations.Pavel Emelyanov
They will be responsible for ctl socket initialization, but currently they are void. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[DCCP]: Fix skb->cb conflicts with IPPatrick McHardy
dev_queue_xmit() and the other IP output functions expect to get a skb with clear or properly initialized skb->cb. Unlike TCP and UDP, the dccp_skb_cb doesn't contain a struct inet_skb_parm at the beginning, so the DCCP-specific data is interpreted by the IP output functions. This can cause false negatives for the conditional POST_ROUTING hook invocation, making the packet bypass the hook. Add a inet_skb_parm/inet6_skb_parm union to the beginning of dccp_skb_cb to avoid clashes. Also add a BUILD_BUG_ON to make sure it fits in the cb. [ Combined with patch from Gerrit Renker to remove two now unnecessary memsets of IPCB(skb)->opt ] Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[NETNS]: Inet control socket should not hold a namespace.Denis V. Lunev
This is a generic requirement, so make inet_ctl_sock_create namespace aware and create a inet_ctl_sock_destroy wrapper around sk_release_kernel. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[INET]: Let inet_ctl_sock_create return sock rather than socket.Denis V. Lunev
All upper protocol layers are already use sock internally. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[INET]: Rename inet_csk_ctl_sock_create to inet_ctl_sock_create.Denis V. Lunev
This call is nothing common with INET connection sockets code. It simply creates an unhashes kernel sockets for protocol messages. Move the new call into af_inet.c after the rename. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[DCCP]: dccp_v(4|6)_ctl_socket is leaked.Denis V. Lunev
This seems a purism as module can't be unloaded, but though if cleanup method is present it should be correct and clean all staff created. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[DCCP]: Replace socket with sock for reset sending.Denis V. Lunev
Replace dccp_v(4|6)_ctl_socket with sock to unify a code with TCP/ICMP. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-28[SOCK]: Drop inuse pcounter from struct proto (v2).Pavel Emelyanov
An uppercut - do not use the pcounter on struct proto. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-22[SOCK]: Add udp_hash member to struct proto.Pavel Emelyanov
Inspired by the commit ab1e0a13 ([SOCK] proto: Add hashinfo member to struct proto) from Arnaldo, I made similar thing for UDP/-Lite IPv4 and -v6 protocols. The result is not that exciting, but it removes some levels of indirection in udpxxx_get_port and saves some space in code and text. The first step is to union existing hashinfo and new udp_hash on the struct proto and give a name to this union, since future initialization of tcpxxx_prot, dccp_vx_protinfo and udpxxx_protinfo will cause gcc warning about inability to initialize anonymous member this way. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05[IPV4]: Add 'rtable' field in struct sk_buff to alias 'dst' and avoid castsEric Dumazet
(Anonymous) unions can help us to avoid ugly casts. A common cast it the (struct rtable *)skb->dst one. Defining an union like : union { struct dst_entry *dst; struct rtable *rtable; }; permits to use skb->rtable in place. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[INET]: Remove struct dst_entry *dst from request_sock_ops.rtx_syn_ack.Denis V. Lunev
It looks like dst parameter is used in this API due to historical reasons. Actually, it is really used in the direct call to tcp_v4_send_synack only. So, create a wrapper for tcp_v4_send_synack and remove dst from rtx_syn_ack. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03[SOCK] proto: Add hashinfo member to struct protoArnaldo Carvalho de Melo
This way we can remove TCP and DCCP specific versions of sk->sk_prot->get_port: both v4 and v6 use inet_csk_get_port sk->sk_prot->hash: inet_hash is directly used, only v6 need a specific version to deal with mapped sockets sk->sk_prot->unhash: both v4 and v6 use inet_hash directly struct inet_connection_sock_af_ops also gets a new member, bind_conflict, so that inet_csk_get_port can find the per family routine. Now only the lookup routines receive as a parameter a struct inet_hashtable. With this we further reuse code, reducing the difference among INET transport protocols. Eventually work has to be done on UDP and SCTP to make them share this infrastructure and get as a bonus inet_diag interfaces so that iproute can be used with these protocols. net-2.6/net/ipv4/inet_hashtables.c: struct proto | +8 struct inet_connection_sock_af_ops | +8 2 structs changed __inet_hash_nolisten | +18 __inet_hash | -210 inet_put_port | +8 inet_bind_bucket_create | +1 __inet_hash_connect | -8 5 functions changed, 27 bytes added, 218 bytes removed, diff: -191 net-2.6/net/core/sock.c: proto_seq_show | +3 1 function changed, 3 bytes added, diff: +3 net-2.6/net/ipv4/inet_connection_sock.c: inet_csk_get_port | +15 1 function changed, 15 bytes added, diff: +15 net-2.6/net/ipv4/tcp.c: tcp_set_state | -7 1 function changed, 7 bytes removed, diff: -7 net-2.6/net/ipv4/tcp_ipv4.c: tcp_v4_get_port | -31 tcp_v4_hash | -48 tcp_v4_destroy_sock | -7 tcp_v4_syn_recv_sock | -2 tcp_unhash | -179 5 functions changed, 267 bytes removed, diff: -267 net-2.6/net/ipv6/inet6_hashtables.c: __inet6_hash | +8 1 function changed, 8 bytes added, diff: +8 net-2.6/net/ipv4/inet_hashtables.c: inet_unhash | +190 inet_hash | +242 2 functions changed, 432 bytes added, diff: +432 vmlinux: 16 functions changed, 485 bytes added, 492 bytes removed, diff: -7 /home/acme/git/net-2.6/net/ipv6/tcp_ipv6.c: tcp_v6_get_port | -31 tcp_v6_hash | -7 tcp_v6_syn_recv_sock | -9 3 functions changed, 47 bytes removed, diff: -47 /home/acme/git/net-2.6/net/dccp/proto.c: dccp_destroy_sock | -7 dccp_unhash | -179 dccp_hash | -49 dccp_set_state | -7 dccp_done | +1 5 functions changed, 1 bytes added, 242 bytes removed, diff: -241 /home/acme/git/net-2.6/net/dccp/ipv4.c: dccp_v4_get_port | -31 dccp_v4_request_recv_sock | -2 2 functions changed, 33 bytes removed, diff: -33 /home/acme/git/net-2.6/net/dccp/ipv6.c: dccp_v6_get_port | -31 dccp_v6_hash | -7 dccp_v6_request_recv_sock | +5 3 functions changed, 5 bytes added, 38 bytes removed, diff: -33 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETNS]: Tcp-v4 sockets per-net lookup.Pavel Emelyanov
Add a net argument to inet_lookup and propagate it further into lookup calls. Plus tune the __inet_check_established. The dccp and inet_diag, which use that lookup functions pass the init_net into them. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_flow.Denis V. Lunev
Needed to propagate it down to the __ip_route_output_key. Signed_off_by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[INET]: Uninline the __inet_hash function.Pavel Emelyanov
This one is used in quite many places in the networking code and seems to big to be inline. After the patch net/ipv4/build-in.o loses ~650 bytes: add/remove: 2/0 grow/shrink: 0/5 up/down: 461/-1114 (-653) function old new delta __inet_hash_nolisten - 282 +282 __inet_hash - 179 +179 tcp_sacktag_write_queue 2255 2254 -1 __inet_lookup_listener 284 274 -10 tcp_v4_syn_recv_sock 755 493 -262 tcp_v4_hash 389 35 -354 inet_hash_connect 1086 599 -487 This version addresses the issue pointed by Eric, that while being inline this function was optimized by gcc in respect to the 'listen_possible' argument. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Allow to parse options on Request SocketsGerrit Renker
The option parsing code currently only parses on full sk's. This causes a problem for options sent during the initial handshake (in particular timestamps and feature-negotiation options). Therefore, this patch extends the option parsing code with an additional argument for request_socks: if it is non-NULL, options are parsed on the request socket, otherwise the normal path (parsing on the sk) is used. Subsequent patches, which implement feature negotiation during connection setup, make use of this facility. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07[DCCP]: Use DEFINE_PROTO_INUSE infrastructure.David S. Miller
2007-10-24[DCCP]: One more exemption from full sequence number checksGerrit Renker
This fixes the following problem: client connects to peer which has no DCCP enabled or loaded; ICMP error messages ("Protocol Unavailable") can be seen on the wire, but the application hangs. Reason: ICMP packets don't get through to dccp_v4_err. When reporting errors, a sequence number check is made for the DCCP packet that had caused an ICMP error to arrive. Such checks can not be made if the socket is in state LISTEN, RESPOND (which in the implementation is the same as LISTEN), or REQUEST, since update_gsr() has not been called in these states, hence the sequence window is 0..0. This patch fixes the problem by adding the REQUEST state as another exemption to the window check. The error reporting now works as expected on connecting. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-10-24[DCCP]: Retrieve packet sequence number for error reportingGerrit Renker
This fixes a problem when analysing erroneous packets in dccp_v{4,6}_err: * dccp_hdr_seq currently takes an skb * however, the transport headers in the skb are shifted, due to the preceding IPv4/v6 header. Fixed for v4 and v6 by changing dccp_hdr_seq to take a struct dccp_hdr as argument. Verified that the correct sequence number is now reported in the error handler. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-10-22[INET]: Use MODULE_ALIAS_NET_PF_PROTO_TYPE where possible.Jean Delvare
Now that we have this new macro, use it where possible. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[DCCP]: Twice the wrong reset code in receiving connection-RequestsGerrit Renker
This fixes two bugs in processing of connection-Requests in v{4,6}_conn_request: 1. Due to using the variable `reset_code', the Reset code generated internally by dccp_parse_options() is overwritten with the initialised value ("Too Busy") of reset_code, which is not what is intended. 2. When receiving a connection-Request on a multicast or broadcast address, no Reset should be generated, to avoid storms of such packets. Instead of jumping to the `drop' label, the v{4,6}_conn_request functions now return 0. Below is why in my understanding this is correct: When the conn_request function returns < 0, then the caller, dccp_rcv_state_process(), returns 1. In all instances where dccp_rcv_state_process is called (dccp_v4_do_rcv, dccp_v6_do_rcv, and dccp_child_process), a return value of != 0 from dccp_rcv_state_process() means that a Reset is generated. If on the other hand the conn_request function returns 0, the packet is discarded and no Reset is generated. Note: There may be a related problem when sending the Response, due to the following. if (dccp_v6_send_response(sk, req, NULL)) goto drop_and_free; /* ... */ drop_and_free: return -1; In this case, if send_response fails due to transmission errors, the next thing that is generated is a Reset with a code "Too Busy". I haven't been able to conjure up such a condition, but it might be good to change the behaviour here also (not done by this patch). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[DCCP]: Factor out common code for generating ResetsGerrit Renker
This factors code common to dccp_v{4,6}_ctl_send_reset into a separate function, and adds support for filling in the Data 1 ... Data 3 fields from RFC 4340, 5.6. It is useful to have this separate, since the following Reset codes will always be generated from the control socket rather than via dccp_send_reset: * Code 3, "No Connection", cf. 8.3.1; * Code 4, "Packet Error" (identification for Data 1 added); * Code 5, "Option Error" (identification for Data 1..3 added, will be used later); * Code 6, "Mandatory Error" (same as Option Error); * Code 7, "Connection Refused" (what on Earth is the difference to "No Connection"?); * Code 8, "Bad Service Code"; * Code 9, "Too Busy"; * Code 10, "Bad Init Cookie" (not used). Code 0 is not recommended by the RFC, the following codes would be used in dccp_send_reset() instead, since they all relate to an established DCCP connection: * Code 1, "Closed"; * Code 2, "Aborted"; * Code 11, "Aggression Penalty" (12.3). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-10-10[DCCP]: Sequence number wrap-around when sending resetGerrit Renker
This replaces normal addition with mod-48 addition so that sequence number wraparound is respected. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-10-10[DCCP]: Remove unneeded pointer newdp from dccp_v4_request_recv_sock()Micah Gruber
This trivial patch removes the unneeded pointer newdp, which is never used. Signed-off-by: Micah Gruber <micah.gruber@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce icmp_hdr(), remove skb->h.icmphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-02-10[NET] DCCP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[IPV4/IPV6]: Always wait for IPSEC SA resolution in socket contexts.David S. Miller
Do this even for non-blocking sockets. This avoids the silly -EAGAIN that applications can see now, even for non-blocking sockets in some cases (f.e. connect()). With help from Venkat Tekkirala. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[DCCP]: Whitespace cleanupsArnaldo Carvalho de Melo
That accumulated over the last months hackaton, shame on me for not using git-apply whitespace helping hand, will do that from now on. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Simplified conditions due to use of enum:8 statesGerrit Renker
This reaps the benefit of the earlier patch, which changed the type of CCID 3 states to use enums, in that many conditions are now simplified and the number of possible (unexpected) values is greatly reduced. In a few instances, this also allowed to simplify pre-conditions; where care has been taken to retain logical equivalence. [DCCP]: Introduce a consistent BUG/WARN message scheme This refines the existing set of DCCP messages so that * BUG(), BUG_ON(), WARN_ON() have meaningful DCCP-specific counterparts * DCCP_CRIT (for severe warnings) is not rate-limited * DCCP_WARN() is introduced as rate-limited wrapper Using these allows a faster and cleaner transition to their original counterparts once the code has matured into a full DCCP implementation. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[NET]: Conditionally use bh_lock_sock_nested in sk_receive_skbArnaldo Carvalho de Melo
Spotted by Ian McDonald, tentatively fixed by Gerrit Renker: http://www.mail-archive.com/dccp%40vger.kernel.org/msg00599.html Rewritten not to unroll sk_receive_skb, in the common case, i.e. no lock debugging, its optimized away. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
