path: root/net/dccp/output.c
2014-04-15ipv4: add a sock pointer to ip_queue_xmit()Eric Dumazet
ip_queue_xmit() assumes the skb it has to transmit is attached to an inet socket. Commit 31c70d5956fc ("l2tp: keep original skb ownership") changed l2tp to not change skb ownership and thus broke this assumption. One fix is to add a new 'struct sock *sk' parameter to ip_queue_xmit(), so that we do not assume skb->sk points to the socket used by l2tp tunnel. Fixes: 31c70d5956fc ("l2tp: keep original skb ownership") Reported-by: Zhan Jianyu <nasa4836@gmail.com> Tested-by: Zhan Jianyu <nasa4836@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-10inet: rename ir_loc_port to ir_numEric Dumazet
In commit 634fb979e8f ("inet: includes a sock_common in request_sock") I forgot that the two ports in sock_common do not have same byte order : skc_dport is __be16 (network order), but skc_num is __u16 (host order) So sparse complains because ir_loc_port (mapped into skc_num) is considered as __u16 while it should be __be16 Let rename ir_loc_port to ireq->ir_num (analogy with inet->inet_num), and perform appropriate htons/ntohs conversions. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-10inet: includes a sock_common in request_sockEric Dumazet
TCP listener refactoring, part 5 : We want to be able to insert request sockets (SYN_RECV) into main ehash table instead of the per listener hash table to allow RCU lookups and remove listener lock contention. This patch includes the needed struct sock_common in front of struct request_sock This means there is no more inet6_request_sock IPv6 specific structure. Following inet_request_sock fields were renamed as they became macros to reference fields from struct sock_common. Prefix ir_ was chosen to avoid name collisions. loc_port -> ir_loc_port loc_addr -> ir_loc_addr rmt_addr -> ir_rmt_addr rmt_port -> ir_rmt_port iif -> ir_iif Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10net: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-03dccp: fix bug in sequence number validation during connection setupSamuel Jero
This fixes a bug in the sequence number validation during the initial handshake. The code did not treat the initial sequence numbers ISS and ISR as read-only and did not keep state for GSR and GSS as required by the specification. This causes problems with retransmissions during the initial handshake, causing the budding connection to be reset. This patch now treats ISS/ISR as read-only and tracks GSS/GSR as required. Signed-off-by: Samuel Jero <sj323707@ohio.edu> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-07-04dccp: combine the functionality of enqeueing and cloningGerrit Renker
Realising the following call pattern, * first dccp_entail() is called to enqueue a new skb and * then skb_clone() is called to transmit a clone of that skb, this patch integrates both into the same function. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-05-08inet: Pass flowi to ->queue_xmit().David S. Miller
This allows us to acquire the exact route keying information from the protocol, however that might be managed. It handles all of the possibilities, from the simplest case of storing the key in inet->cork.fl to the more complex setup SCTP has where individual transports determine the flow. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-07dccp: Policy-based packet dequeueing infrastructureTomasz Grobelny
This patch adds a generic infrastructure for policy-based dequeueing of TX packets and provides two policies: * a simple FIFO policy (which is the default) and * a priority based policy (set via socket options). Both policies honour the tx_qlen sysctl for the maximum size of the write queue (can be overridden via socket options). The priority policy uses skb->priority internally to assign an u32 priority identifier, using the same ranking as SO_PRIORITY. The skb->priority field is set to 0 when the packet leaves DCCP. The priority is supplied as ancillary data using cmsg(3), the patch also provides the requisite parsing routines. Signed-off-by: Tomasz Grobelny <tomasz@grobelny.oswiecenia.net> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2010-11-15dccp ccid-2: Schedule Sync as out-of-band mechanismGerrit Renker
The problem with Ack Vectors is that i) their length is variable and can in principle grow quite large, ii) it is hard to predict exactly how large they will be. Due to the second point it seems not a good idea to reduce the MPS; in particular when on average there is enough room for the Ack Vector and an increase in length is momentarily due to some burst loss, after which the Ack Vector returns to its normal/average length. The solution taken by this patch is to subtract a minimum-expected Ack Vector length from the MPS, and to defer any larger Ack Vectors onto a separate Sync - but only if indeed there is no space left on the skb. This patch provides the infrastructure to schedule Sync-packets for transporting (urgent) out-of-band data. Its signalling is quicker than scheduling an Ack, since it does not need to wait for new application data. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2010-10-28dccp: Refine the wait-for-ccid mechanismGerrit Renker
This extends the existing wait-for-ccid routine so that it may be used with different types of CCID, addressing the following problems: 1) The queue-drain mechanism only works with rate-based CCIDs. If CCID-2 for example has a full TX queue and becomes network-limited just as the application wants to close, then waiting for CCID-2 to become unblocked could lead to an indefinite delay (i.e., application "hangs"). 2) Since each TX CCID in turn uses a feedback mechanism, there may be changes in its sending policy while the queue is being drained. This can lead to further delays during which the application will not be able to terminate. 3) The minimum wait time for CCID-3/4 can be expected to be the queue length times the current inter-packet delay. For example if tx_qlen=100 and a delay of 15 ms is used for each packet, then the application would have to wait for a minimum of 1.5 seconds before being allowed to exit. 4) There is no way for the user/application to control this behaviour. It would be good to use the timeout argument of dccp_close() as an upper bound. Then the maximum time that an application is willing to wait for its CCIDs to can be set via the SO_LINGER option. These problems are addressed by giving the CCID a grace period of up to the `timeout' value. The wait-for-ccid function is, as before, used when the application (a) has read all the data in its receive buffer and (b) if SO_LINGER was set with a non-zero linger time, or (c) the socket is either in the OPEN (active close) or in the PASSIVE_CLOSEREQ state (client application closes after receiving CloseReq). In addition, there is a catch-all case of __skb_queue_purge() after waiting for the CCID. This is necessary since the write queue may still have data when (a) the host has been passively-closed, (b) abnormal termination (unread data, zero linger time), (c) wait-for-ccid could not finish within the given time limit. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-28dccp: Extend CCID packet dequeueing interfaceGerrit Renker
This extends the packet dequeuing interface of dccp_write_xmit() to allow 1. CCIDs to take care of timing when the next packet may be sent; 2. delayed sending (as before, with an inter-packet gap up to 65.535 seconds). The main purpose is to take CCID-2 out of its polling mode (when it is network- limited, it tries every millisecond to send, without interruption). The mode of operation for (2) is as follows: * new packet is enqueued via dccp_sendmsg() => dccp_write_xmit(), * ccid_hc_tx_send_packet() detects that it may not send (e.g. window full), * it signals this condition via `CCID_PACKET_WILL_DEQUEUE_LATER', * dccp_write_xmit() returns without further action; * after some time the wait-condition for CCID becomes true, * that CCID schedules the tasklet, * tasklet function calls ccid_hc_tx_send_packet() via dccp_write_xmit(), * since the wait-condition is now true, ccid_hc_tx_packet() returns "send now", * packet is sent, and possibly more (since dccp_write_xmit() loops). Code reuse: the taskled function calls dccp_write_xmit(), the timer function reduces to a wrapper around the same code. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-12dccp: remove unused argument in CCID tx functionGerrit Renker
This removes the argument `more' from ccid_hc_tx_packet_sent, since it was nowhere used in the entire code. (Btw, this argument was not even used in the original KAME code where the function initially came from; compare the variable moreToSend in the freebsd61-dccp-kame-28.08.2006.patch kept by Emmanuel Lochin.) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2010-10-12dccp: merge now-reduced connect_init() functionGerrit Renker
After moving the assignment of GAR/ISS from dccp_connect_init() to dccp_transmit_skb(), the former function becomes very small, so that a merger with dccp_connect() suggests itself. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2010-05-01net: sock_def_readable() and friends RCU conversionEric Dumazet
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we need two atomic operations (and associated dirtying) per incoming packet. RCU conversion is pretty much needed : 1) Add a new structure, called "struct socket_wq" to hold all fields that will need rcu_read_lock() protection (currently: a wait_queue_head_t and a struct fasync_struct pointer). [Future patch will add a list anchor for wakeup coalescing] 2) Attach one of such structure to each "struct socket" created in sock_alloc_inode(). 3) Respect RCU grace period when freeing a "struct socket_wq" 4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct socket_wq" 5) Change sk_sleep() function to use new sk->sk_wq instead of sk->sk_sleep 6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside a rcu_read_lock() section. 7) Change all sk_has_sleeper() callers to : - Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock) - Use wq_has_sleeper() to eventually wakeup tasks. - Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock) 8) sock_wake_async() is modified to use rcu protection as well. 9) Exceptions : macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq" instead of dynamically allocated ones. They dont need rcu freeing. Some cleanups or followups are probably needed, (possible sk_callback_lock conversion to a spinlock for example...). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15net: replace ipfragok with skb->local_dfShan Wei
As Herbert Xu said: we should be able to simply replace ipfragok with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function) has droped ipfragok and set local_df value properly. The patch kills the ipfragok parameter of .queue_xmit(). Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11inet: Remove unused send_check length argumentHerbert Xu
inet: Remove unused send_check length argument This patch removes the unused length argument from the send_check function in struct inet_connection_sock_af_ops. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Yinghai <yinghai.lu@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09net: adding memory barrier to the poll and receive callbacksJiri Olsa
Adding memory barrier after the poll_wait function, paired with receive callbacks. Adding fuctions sock_poll_wait and sk_has_sleeper to wrap the memory barrier. Without the memory barrier, following race can happen. The race fires, when following code paths meet, and the tp->rcv_nxt and __add_wait_queue updates stay in CPU caches. CPU1 CPU2 sys_select receive packet ... ... __add_wait_queue update tp->rcv_nxt ... ... tp->rcv_nxt check sock_def_readable ... { schedule ... if (sk->sk_sleep && waitqueue_active(sk->sk_sleep)) wake_up_interruptible(sk->sk_sleep) ... } If there was no cache the code would work ok, since the wait_queue and rcv_nxt are opposit to each other. Meaning that once tp->rcv_nxt is updated by CPU2, the CPU1 either already passed the tp->rcv_nxt check and sleeps, or will get the new value for tp->rcv_nxt and will return with new data mask. In both cases the process (CPU1) is being added to the wait queue, so the waitqueue_active (CPU2) call cannot miss and will wake up CPU1. The bad case is when the __add_wait_queue changes done by CPU1 stay in its cache, and so does the tp->rcv_nxt update on CPU2 side. The CPU1 will then endup calling schedule and sleep forever if there are no more data on the socket. Calls to poll_wait in following modules were ommited: net/bluetooth/af_bluetooth.c net/irda/af_irda.c net/irda/irnet/irnet_ppp.c net/mac80211/rc80211_pid_debugfs.c net/phonet/socket.c net/rds/af_rds.c net/rfkill/core.c net/sunrpc/cache.c net/sunrpc/rpc_pipe.c net/tipc/socket.c Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02dccp: Do not let initial option overhead shrink the MPSGerrit Renker
This fixes a problem caused by the overlap of the connection-setup and established-state phases of DCCP connections. During connection setup, the client retransmits Confirm Feature-Negotiation options until a response from the server signals that it can move from the half-established PARTOPEN into the OPEN state, whereupon the connection is fully established on both ends (RFC 4340, 8.1.5). However, since the client may already send data while it is in the PARTOPEN state, consequences arise for the Maximum Packet Size: the problem is that the initial option overhead is much higher than for the subsequent established phase, as it involves potentially many variable-length list-type options (server-priority options, RFC 4340, 6.4). Applying the standard MPS is insufficient here: especially with larger payloads this can lead to annoying, counter-intuitive EMSGSIZE errors. On the other hand, reducing the MPS available for the established phase by the added initial overhead is highly wasteful and inefficient. The solution chosen therefore is a two-phase strategy: If the payload length of the DataAck in PARTOPEN is too large, an Ack is sent to carry the options, and the feature-negotiation list is then flushed. This means that the server gets two Acks for one Response. If both Acks get lost, it is probably better to restart the connection anyway and devising yet another special-case does not seem worth the extra complexity. The result is a higher utilisation of the available packet space for the data transmission phase (established state) of a connection. The patch (over-)estimates the initial overhead to be 32*4 bytes -- commonly seen values were around 90 bytes for initial feature-negotiation options. It uses sizeof(u32) to mean "aligned units of 4 bytes". For consistency, another use of 4-byte alignment is adapted. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02dccp: Minimise header option overhead in setting the MPSGerrit Renker
This patch resolves a long-standing FIXME to dynamically update the Maximum Packet Size depending on actual options usage. It uses the flags set by the feature-negotiation infrastructure to compute the required header option size. Most options are fixed-size, a notable exception are Ack Vectors (required currently only by CCID-2). These can have any length between 3 and 1020 bytes. As a result of testing, 16 bytes (2 bytes for type/length plus 14 Ack Vector cells) have been found to be sufficient for loss-free situations. There are currently no CCID-specific header options which may appear on data packets, thus it is not necessary to define a corresponding CCID field as suggested in the old comment. Further changes: ---------------- Adjusted the type of 'cur_mps' to match the unsigned return type of the function. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-05dccp: use roundup instead of opencodingIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16dccp: Mechanism to resolve CCID dependenciesGerrit Renker
This adds a hook to resolve features whose value depends on the choice of CCID. It is done at the server since it can only be done after the CCID values have been negotiated; i.e. the client will add its CCID preference list on the Change options sent in the Request, which will be reconciled with the local preference list of the server. The concept is documented on http://www.erg.abdn.ac.uk/users/gerrit/dccp/notes/feature_negotiation/\ implementation_notes.html#ccid_dependencies Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12dccp: Resolve dependencies of features on choice of CCIDGerrit Renker
This provides a missing link in the code chain, as several features implicitly depend and/or rely on the choice of CCID. Most notably, this is the Send Ack Vector feature, but also Ack Ratio and Send Loss Event Rate (also taken care of). For Send Ack Vector, the situation is as follows: * since CCID2 mandates the use of Ack Vectors, there is no point in allowing endpoints which use CCID2 to disable Ack Vector features such a connection; * a peer with a TX CCID of CCID2 will always expect Ack Vectors, and a peer with a RX CCID of CCID2 must always send Ack Vectors (RFC 4341, sec. 4); * for all other CCIDs, the use of (Send) Ack Vector is optional and thus negotiable. However, this implies that the code negotiating the use of Ack Vectors also supports it (i.e. is able to supply and to either parse or ignore received Ack Vectors). Since this is not the case (CCID-3 has no Ack Vector support), the use of Ack Vectors is here disabled, with a comment in the source code. An analogous consideration arises for the Send Loss Event Rate feature, since the CCID-3 implementation does not support the loss interval options of RFC 4342. To make such use explicit, corresponding feature-negotiation options are inserted which signal the use of the loss event rate option, as it is used by the CCID3 code. Lastly, the values of the Ack Ratio feature are matched to the choice of CCID. The patch implements this as a function which is called after the user has made all other registrations for changing default values of features. The table is variable-length, the reserved (and hence for feature-negotiation invalid, confirmed by considering section 19.4 of RFC 4340) feature number `0' is used to mark the end of the table. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-19dccp: Port redirection support for DCCPGerrit Renker
Commit a3116ac5c216fc3c145906a46df9ce542ff7dcf2 from 1st October ("tcp: Port redirection support for TCP") broke DCCP skb lookup by changing inet_csk_clone, which is used by DCCP to generate the child socket after the handshake. This patch updates DCCP to use 'loc_port' instead of 'sport', which fixes the problem, and thus inheriting port redirection support via the new interface. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26dccp: Bug-Fix - AWL was never updatedGerrit Renker
The AWL lower Ack validity window advances in proportion to GSS, the greatest sequence number sent. Updating AWL other than at connection setup (in the DCCP-Request sent by dccp_v{4,6}_connect()) was missing in the DCCP code. This bug lead to syslog messages such as "kernel: dccp_check_seqno: DCCP: Step 6 failed for DATAACK packet, [...] P.ackno exists or LAWL(82947089) <= P.ackno(82948208) <= S.AWH(82948728), sending SYNC..." The difference between AWL/AWH here is 1639 packets, while the expected value (the Sequence Window) would have been 100 (the default). A closer look showed that LAWL = AWL = 82947089 equalled the ISS on the Response. The patch now updates AWL with each increase of GSS. Further changes: ---------------- The patch also enforces more stringent checks on the ISS sequence number: * AWL is initialised to ISS at connection setup and remains at this value; * AWH is then always set to GSS (via dccp_update_gss()); * so on the first Request: AWL = AWH = ISS, and on the n-th Request: AWL = ISS, AWH = ISS + n. As a consequence, only Response packets that refer to Requests sent by this host will pass, all others are discarded. This is the intention and in effect implements the initial adjustments for AWL as specified in RFC 4340, 7.5.1. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz>
2008-07-26dccp: Allow to distinguish original and retransmitted packetsGerrit Renker
This patch allows the sender to distinguish original and retransmitted packets, which is in particular needed for the retransmission of DCCP-Requests: * the first Request uses ISS (generated in net/dccp/ip*.c), and sets GSS = ISS; * all retransmitted Requests use GSS' = GSS + 1, so that the n-th retransmitted Request has sequence number ISS + n (mod 48). To add generic support, the patch reorganises existing code so that: * icsk_retransmits == 0 for the original packet and * icsk_retransmits = n > 0 for the n-th retransmitted packet at the time dccp_transmit_skb() is called, via dccp_retransmit_skb(). Thanks to Wei Yongjun for pointing this problem out. Further changes: ---------------- * removed the `skb' argument from dccp_retransmit_skb(), since sk_send_head is used for all retransmissions (the exception is client-Acks in PARTOPEN state, but these do not use sk_send_head); * since sk_send_head always contains the original skb (via dccp_entail()), skb_cloned() never evaluated to true and thus pskb_copy() was never used. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-06-11dccp: Fix sparse warningsGerrit Renker
This patch fixes the following sparse warnings: * nested min(max()) expression: net/dccp/ccids/ccid3.c:91:21: warning: symbol '__x' shadows an earlier one net/dccp/ccids/ccid3.c:91:21: warning: symbol '__y' shadows an earlier one * Declaration of function prototypes in .c instead of .h file, resulting in "should it be static?" warnings. * Declared "struct dccpw" static (local to dccp_probe). * Disabled dccp_delayed_ack() - not fully removed due to RFC 4340, 11.3 ("Receivers SHOULD implement delayed acknowledgement timers ..."). * Used a different local variable name to avoid net/dccp/ackvec.c:293:13: warning: symbol 'state' shadows an earlier one net/dccp/ackvec.c:238:33: originally declared here * Removed unused functions `dccp_ackvector_print' and `dccp_ackvec_print'. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-12[DCCP]: Fix skb->cb conflicts with IPPatrick McHardy
dev_queue_xmit() and the other IP output functions expect to get a skb with clear or properly initialized skb->cb. Unlike TCP and UDP, the dccp_skb_cb doesn't contain a struct inet_skb_parm at the beginning, so the DCCP-specific data is interpreted by the IP output functions. This can cause false negatives for the conditional POST_ROUTING hook invocation, making the packet bypass the hook. Add a inet_skb_parm/inet6_skb_parm union to the beginning of dccp_skb_cb to avoid clashes. Also add a BUILD_BUG_ON to make sure it fits in the cb. [ Combined with patch from Gerrit Renker to remove two now unnecessary memsets of IPCB(skb)->opt ] Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[DCCP]: Replace socket with sock for reset sending.Denis V. Lunev
Replace dccp_v(4|6)_ctl_socket with sock to unify a code with TCP/ICMP. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Introducing CCMPSGerrit Renker
This introduces a CCMPS field for setting a CCID-specific upper bound on the application payload size, as is defined in RFC 4340, section 14. Only the TX CCID is considered in setting this limit, since the RX CCID generates comparatively small (DCCP-Ack) feedback packets. The CCMPS field includes network and transport layer header lengths. The only current CCMPS customer is CCID4 (via RFC 4828). A wrapper is used to allow querying the CCMPS even at times where the CCID modules may not have been fully negotiated yet. In dccp_sync_mss() the variable `mss_now' has been renamed into `cur_mps', to reflect that we are dealing with an MPS, but not an MSS. Since the DCCP code closely follows the TCP code, the identifiers `dccp_sync_mss' and `dccps_mss_cache' have been kept, as they have direct TCP counterparts. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Support inserting options during the 3-way handshakeGerrit Renker
This provides a separate routine to insert options during the initial handshake. The main purpose is to conduct feature negotiation, for the moment the only user is the timestamp echo needed for the (CCID3) handshake RTT sample. Padding of options has been put into a small separate routine, to be shared among the two functions. This could also be used as a generic routine to finish inserting options. Also removed an `XXX' comment since its content was obvious. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Support for server holding timewait stateGerrit Renker
This adds a socket option and signalling support for the case where the server holds timewait state on closing the connection, as described in RFC 4340, 8.3. Since holding timewait state at the server is the non-usual case, it is enabled via a socket option. Documentation for this socket option has been added. The setsockopt statement has been made resilient against different possible cases of expressing boolean `true' values using a suggestion by Ian McDonald. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Shift the retransmit timer for active-close into output.cGerrit Renker
When performing active close, RFC 4340, 8.3. requires to retransmit the Close/CloseReq with a backoff-retransmit timer starting at intially 2 RTTs. This patch shifts the existing code for active-close retransmit timer into output.c, so that the retransmit timer is started when the first Close/CloseReq is sent. Previously, the timer was started when, after releasing the socket in dccp_close(), the actively-closing side had not yet reached the CLOSED/TIMEWAIT state. The patch further reduces the initial timeout from 3 seconds to the required 2 RTTs, where - in absence of a known RTT - the fallback value specified in RFC 4340, 3.4 is used. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Use AF-independent rebuild_header routineGerrit Renker
This fixes a nasty bug: dccp_send_reset() is called by both DCCPv4 and DCCPv6, but uses inet_sk_rebuild_header() in each case. This leads to unpredictable and weird behaviour: under some conditions, DCCPv6 Resets were sent, in other not. The fix is to use the AF-independent rebuild_header routine. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Name magic constants in sock_wake_async()Pavel Emelyanov
The sock_wake_async() performs a bit different actions depending on "how" argument. Unfortunately this argument ony has numerical magic values. I propose to give names to their constants to help people reading this function callers understand what's going on without looking into this function all the time. I suppose this is 2.6.25 material, but if it's not (or the naming seems poor/bad/awful), I can rework it against the current net-2.6 tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[DCCP]: Wait for CCIDGerrit Renker
This performs a minor optimisation: when ccid_hc_tx_send_packet returns a value greater zero, then the same call previously was done again at the begin of the while loop in dccp_wait_for_ccid. This patch exploits the available information and schedule-timeouts directly instead. Documentation also added. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[DCCP]: Factor out common code for generating ResetsGerrit Renker
This factors code common to dccp_v{4,6}_ctl_send_reset into a separate function, and adds support for filling in the Data 1 ... Data 3 fields from RFC 4340, 5.6. It is useful to have this separate, since the following Reset codes will always be generated from the control socket rather than via dccp_send_reset: * Code 3, "No Connection", cf. 8.3.1; * Code 4, "Packet Error" (identification for Data 1 added); * Code 5, "Option Error" (identification for Data 1..3 added, will be used later); * Code 6, "Mandatory Error" (same as Option Error); * Code 7, "Connection Refused" (what on Earth is the difference to "No Connection"?); * Code 8, "Bad Service Code"; * Code 9, "Too Busy"; * Code 10, "Bad Init Cookie" (not used). Code 0 is not recommended by the RFC, the following codes would be used in dccp_send_reset() instead, since they all relate to an established DCCP connection: * Code 1, "Closed"; * Code 2, "Aborted"; * Code 11, "Aggression Penalty" (12.3). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-10-10[DCCP]: Remove duplicate code for Reset from connected socketGerrit Renker
In this patch, duplicated code is removed for the case when a Reset packet is sent from a connected socket. This code duplication is between dccp_make_reset and dccp_transmit_skb, which already contained an (up to now entirely unused) switch statement to fill in the reset code from the DCCP_SKB_CB. The only thing that has been removed is the call to dst_clone(dst), since the queue_xmit functions use sk_dst_cache anyway. I wasn't sure which purpose inet_sk_rebuild_header served, so I left it in. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-10-10[DCCP]: Add FIXME for send_delayed_ackGerrit Renker
This adds a FIXME to signal that the function dccp_send_delayed_ack is nowhere used in the entire DCCP/CCID code. Using a delayed Ack timer is suggested in 11.3 of RFC 4340, but it has also rather subtle implications for the Ack-Ratio-accounting. CCID2 does not use this (maybe it should). I think leaving the function in is good, in case someone wants to implement this. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-10-10[DCCP]: Parameter renamingGerrit Renker
The parameter `seq' of dccp_send_sync() is in fact an acknowledgement number and not a sequence number - thus renamed by this patch into `ackno'. Secondly, a `critical' warning is added when a Sync/SyncAck could not be sent. Sanity: I have checked all other functions that are called in dccp_transmit_skb, there are no clashes with the use of dccpd_ack_seq; no other function is using this slot at the same time. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[DCCP]: More debug information for dccp_wait_for_ccidGerrit Renker
This adds more detail in the wait_for_ccid packet scheduling loop. In particular, it informs about (i) when delay is used and (ii) why a packet is discarded. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-09[DCCP]: Initialise write_xmit_timer also on passive socketsGerrit Renker
The TX CCID needs the write_xmit_timer for delaying packet sends. Previously this timer was only activated on active (connecting) sockets. This patch initialises the write_xmit_timer in sync with the other timers, i.e. the timer will be ready on any socket. This is used by applications with a listening socket which start to stream after receiving an initiation by the client. The write_xmit_timer is stopped when the application closes, as before. Was tested to work and to remove the timer bug reported on dccp@vger. Also moved timer initialisation into timer.c (static). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-28[NET]: Fix kfree(skb)Patrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] DCCP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-26[TCP]: Restore SKB socket owner setting in tcp_transmit_skb().David S. Miller
Revert 931731123a103cfb3f70ac4b7abfc71d94ba1f03 We can't elide the skb_set_owner_w() here because things like certain netfilter targets (such as owner MATCH) need a socket to be set on the SKB for correct operation. Thanks to Jan Engelhardt and other netfilter list members for pointing this out. Signed-off-by: David S. Miller <davem@davemloft.net>
