[ Upstream commit 2ab2ddd301a22ca3c5f0b743593e4ad2953dfa53 ]
Timer handlers do not imply rcu_read_lock(), so my recent fix
triggered a LOCKDEP warning when SYNACK is retransmit.
Lets add rcu_read_lock()/rcu_read_unlock() pairs around ireq->ireq_opt
usages instead of guessing what is done by callers, since it is
not worth the pain.
Get rid of ireq_opt_deref() helper since it hides the logic
without real benefit, since it is now a standard rcu_dereference().
Fixes: 1ad98e9d1bdf ("tcp/dccp: fix lockdep issue when SYN is backlogged")
Reported-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 1ad98e9d1bdf4724c0a8532fabd84bf3c457c2bc ]
In normal SYN processing, packets are handled without listener
lock and in RCU protected ingress path.
But syzkaller is known to be able to trick us and SYN
packets might be processed in process context, after being
queued into socket backlog.
In commit 06f877d613be ("tcp/dccp: fix other lockdep splats
accessing ireq_opt") I made a very stupid fix, that happened
to work mostly because of the regular path being RCU protected.
Really the thing protecting ireq->ireq_opt is RCU read lock,
and the pseudo request refcnt is not relevant.
This patch extends what I did in commit 449809a66c1d ("tcp/dccp:
block BH for SYN processing") by adding an extra rcu_read_{lock|unlock}
pair in the paths that might be taken when processing SYN from
socket backlog (thus possibly in process context)
Fixes: 06f877d613be ("tcp/dccp: fix other lockdep splats accessing ireq_opt")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 61ef4b07fcdc30535889990cf4229766502561cf ]
The shift of 'cwnd' with '(now - hc->tx_lsndtime) / hc->tx_rto' value
can lead to undefined behavior [1].
In order to fix this use a gradual shift of the window with a 'while'
loop, similar to what tcp_cwnd_restart() is doing.
When comparing delta and RTO there is a minor difference between TCP
and DCCP, the last one also invokes dccp_cwnd_restart() and reduces
'cwnd' if delta equals RTO. That case is preserved in this change.
[1]:
[40850.963623] UBSAN: Undefined behaviour in net/dccp/ccids/ccid2.c:237:7
[40851.043858] shift exponent 67 is too large for 32-bit type 'unsigned int'
[40851.127163] CPU: 3 PID: 15940 Comm: netstress Tainted: G W E 4.18.0-rc7.x86_64 #1
[40851.377176] Call Trace:
[40851.408503] dump_stack+0xf1/0x17b
[40851.451331] ? show_regs_print_info+0x5/0x5
[40851.503555] ubsan_epilogue+0x9/0x7c
[40851.548363] __ubsan_handle_shift_out_of_bounds+0x25b/0x2b4
[40851.617109] ? __ubsan_handle_load_invalid_value+0x18f/0x18f
[40851.686796] ? xfrm4_output_finish+0x80/0x80
[40851.739827] ? lock_downgrade+0x6d0/0x6d0
[40851.789744] ? xfrm4_prepare_output+0x160/0x160
[40851.845912] ? ip_queue_xmit+0x810/0x1db0
[40851.895845] ? ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40851.963530] ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40852.029063] dccp_xmit_packet+0x1d3/0x720 [dccp]
[40852.086254] dccp_write_xmit+0x116/0x1d0 [dccp]
[40852.142412] dccp_sendmsg+0x428/0xb20 [dccp]
[40852.195454] ? inet_dccp_listen+0x200/0x200 [dccp]
[40852.254833] ? sched_clock+0x5/0x10
[40852.298508] ? sched_clock+0x5/0x10
[40852.342194] ? inet_create+0xdf0/0xdf0
[40852.388988] sock_sendmsg+0xd9/0x160
Fixes: 113ced1f52e5 ("dccp ccid-2: Perform congestion-window validation")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit 0ce4e70ff00662ad7490e545ba0cd8c1fa179fca ]
To compute delays, better not use time of the day which can
be changed by admins or malicious programs.
Also change ccid3_first_li() to use s64 type for delta variable
to avoid potential overflows.
Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Cc: dccp@vger.kernel.org
[ Upstream commit 74174fe5634ffbf645a7ca5a261571f700b2f332 ]
On fast hosts or malicious bots, we trigger a DCCP_BUG() which
seems excessive.
syzbot reported :
BUG: delta (-6195) <= 0 at net/dccp/ccids/ccid3.c:628/ccid3_hc_rx_send_feedback()
CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.18.0-rc1+ #112
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c9/0x2b4 lib/dump_stack.c:113
ccid3_hc_rx_send_feedback net/dccp/ccids/ccid3.c:628 [inline]
ccid3_hc_rx_packet_recv.cold.16+0x38/0x71 net/dccp/ccids/ccid3.c:793
ccid_hc_rx_packet_recv net/dccp/ccid.h:185 [inline]
dccp_deliver_input_to_ccids+0xf0/0x280 net/dccp/input.c:180
dccp_rcv_established+0x87/0xb0 net/dccp/input.c:378
dccp_v4_do_rcv+0x153/0x180 net/dccp/ipv4.c:654
sk_backlog_rcv include/net/sock.h:914 [inline]
__sk_receive_skb+0x3ba/0xd80 net/core/sock.c:517
dccp_v4_rcv+0x10f9/0x1f58 net/dccp/ipv4.c:875
ip_local_deliver_finish+0x2eb/0xda0 net/ipv4/ip_input.c:215
NF_HOOK include/linux/netfilter.h:287 [inline]
ip_local_deliver+0x1e9/0x750 net/ipv4/ip_input.c:256
dst_input include/net/dst.h:450 [inline]
ip_rcv_finish+0x823/0x2220 net/ipv4/ip_input.c:396
ip_rcv+0xa18/0x1284 net/ipv4/ip_input.c:492
__netif_receive_skb_core+0x2488/0x3680 net/core/dev.c:4628
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:4693
process_backlog+0x219/0x760 net/core/dev.c:5373
napi_poll net/core/dev.c:5771 [inline]
net_rx_action+0x7da/0x1980 net/core/dev.c:5837
__do_softirq+0x2e8/0xb17 kernel/softirq.c:284
run_ksoftirqd+0x86/0x100 kernel/softirq.c:645
smpboot_thread_fn+0x417/0x870 kernel/smpboot.c:164
kthread+0x345/0x410 kernel/kthread.c:240
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412
[ Upstream commit 2677d20677314101293e6da0094ede7b5526d2b1 ]
Syzbot reported the use-after-free in timer_is_static_object() [1].
This can happen because the structure for the rto timer (ccid2_hc_tx_sock)
is removed in dccp_disconnect(), and ccid2_hc_tx_rto_expire() can be
called after that.
The report [1] is similar to the one in commit 120e9dabaf55 ("dccp:
defer ccid_hc_tx_delete() at dismantle time"). And the fix is the same,
delay freeing ccid2_hc_tx_sock structure, so that it is freed in
dccp_sk_destruct().
[1]
BUG: KASAN: use-after-free in timer_is_static_object+0x80/0x90
kernel/time/timer.c:607
Read of size 8 at addr ffff8801bebb5118 by task syz-executor2/25299
CPU: 1 PID: 25299 Comm: syz-executor2 Not tainted 4.17.0-rc5+ #54
Google 01/01/2011
Call Trace:
<IRQ>
dump_stack+0x1b9/0x294 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
timer_is_static_object+0x80/0x90 kernel/time/timer.c:607
debug_object_activate+0x2d9/0x670 lib/debugobjects.c:508
debug_timer_activate kernel/time/timer.c:709 [inline]
debug_activate kernel/time/timer.c:764 [inline]
__mod_timer kernel/time/timer.c:1041 [inline]
mod_timer+0x4d3/0x13b0 kernel/time/timer.c:1102
sk_reset_timer+0x22/0x60 net/core/sock.c:2742
ccid2_hc_tx_rto_expire+0x587/0x680 net/dccp/ccids/ccid2.c:147
call_timer_fn+0x230/0x940 kernel/time/timer.c:1326
expire_timers kernel/time/timer.c:1363 [inline]
__run_timers+0x79e/0xc50 kernel/time/timer.c:1666
run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692
__do_softirq+0x2e0/0xaf5 kernel/softirq.c:285
invoke_softirq kernel/softirq.c:365 [inline]
irq_exit+0x1d1/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:525 [inline]
smp_apic_timer_interrupt+0x17e/0x710 arch/x86/kernel/apic/apic.c:1052
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:863
</IRQ>
Allocated by task 25374:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490
kmem_cache_alloc+0x12e/0x760 mm/slab.c:3554
ccid_new+0x25b/0x3e0 net/dccp/ccid.c:151
dccp_hdlr_ccid+0x27/0x150 net/dccp/feat.c:44
__dccp_feat_activate+0x184/0x270 net/dccp/feat.c:344
dccp_feat_activate_values+0x3a7/0x819 net/dccp/feat.c:1538
dccp_create_openreq_child+0x472/0x610 net/dccp/minisocks.c:128
dccp_v4_request_recv_sock+0x12c/0xca0 net/dccp/ipv4.c:408
dccp_v6_request_recv_sock+0x125d/0x1f10 net/dccp/ipv6.c:415
dccp_check_req+0x455/0x6a0 net/dccp/minisocks.c:197
dccp_v4_rcv+0x7b8/0x1f3f net/dccp/ipv4.c:841
ip_local_deliver_finish+0x2e3/0xd80 net/ipv4/ip_input.c:215
NF_HOOK include/linux/netfilter.h:288 [inline]
ip_local_deliver+0x1e1/0x720 net/ipv4/ip_input.c:256
ip_rcv_finish+0x81b/0x2200 net/ipv4/ip_input.c:396
ip_rcv+0xb70/0x143d net/ipv4/ip_input.c:492
__netif_receive_skb_core+0x26f5/0x3630 net/core/dev.c:4592
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:4657
process_backlog+0x219/0x760 net/core/dev.c:5337
napi_poll net/core/dev.c:5735 [inline]
net_rx_action+0x7b7/0x1930 net/core/dev.c:5801
Freed by task 25374:
__kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kmem_cache_free+0x86/0x2d0 mm/slab.c:3756
ccid_hc_tx_delete+0xc3/0x100 net/dccp/ccid.c:190
dccp_disconnect+0x130/0xc66 net/dccp/proto.c:286
dccp_close+0x3bc/0xe60 net/dccp/proto.c:1045
inet_release+0x104/0x1f0 net/ipv4/af_inet.c:427
inet6_release+0x50/0x70 net/ipv6/af_inet6.c:460
sock_release+0x96/0x1b0 net/socket.c:594
sock_close+0x16/0x20 net/socket.c:1149
__fput+0x34d/0x890 fs/file_table.c:209
____fput+0x15/0x20 fs/file_table.c:243
task_work_run+0x1e4/0x290 kernel/task_work.c:113
tracehook_notify_resume include/linux/tracehook.h:191 [inline]
exit_to_usermode_loop+0x2bd/0x310 arch/x86/entry/common.c:166
prepare_exit_to_usermode arch/x86/entry/common.c:196 [inline]
syscall_return_slowpath arch/x86/entry/common.c:265 [inline]
do_syscall_64+0x6ac/0x800 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
The buggy address belongs to the object at ffff8801bebb4cc0
which belongs to the cache ccid2_hc_tx_sock of size 1240
The buggy address is located 1112 bytes inside of
1240-byte region [ffff8801bebb4cc0, ffff8801bebb5198)
The buggy address belongs to the page:
page:ffffea0006faed00 count:1 mapcount:0 mapping:ffff8801bebb41c0
index:0xffff8801bebb5240 compound_mapcount: 0
flags: 0x2fffc0000008100(slab|head)
raw: 02fffc0000008100 ffff8801bebb41c0 ffff8801bebb5240 0000000100000003
raw: ffff8801cdba3138 ffffea0007634120 ffff8801cdbaab40 0000000000000000
page dumped because: kasan: bad access detected
Reported-by: syzbot+5d47e9ec91a6f15dbd6f@syzkaller.appspotmail.com
[ Upstream commit a8d7aa17bbc970971ccdf71988ea19230ab368b1 ]
syzbot reported a crash in tasklet_action_common() caused by dccp.
dccp needs to make sure socket wont disappear before tasklet handler
has completed.
This patch takes a reference on the socket when arming the tasklet,
and moves the sock_put() from dccp_write_xmit_timer() to dccp_write_xmitlet()
kernel BUG at kernel/softirq.c:514!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 17 Comm: ksoftirqd/1 Not tainted 4.17.0-rc3+ #30
RIP: 0010:tasklet_action_common.isra.19+0x6db/0x700 kernel/softirq.c:515
RSP: 0018:ffff8801d9b3faf8 EFLAGS: 00010246
dccp_close: ABORT with 65423 bytes unread
RAX: 1ffff1003b367f6b RBX: ffff8801daf1f3f0 RCX: 0000000000000000
RDX: ffff8801cf895498 RSI: 0000000000000004 RDI: 0000000000000000
RBP: ffff8801d9b3fc40 R08: ffffed0039f12a95 R09: ffffed0039f12a94
R10: ffffed0039f12a94 R11: ffff8801cf8954a3 R12: 0000000000000000
R13: ffff8801d9b3fc18 R14: dffffc0000000000 R15: ffff8801cf895490
FS: 0000000000000000(0000) GS:ffff8801daf00000(0000) knlGS:0000000000000000
CR2: 0000001b2bc28000 CR3: 00000001a08a9000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
tasklet_action+0x1d/0x20 kernel/softirq.c:533
run_ksoftirqd+0x86/0x100 kernel/softirq.c:646
kthread+0x345/0x410 kernel/kthread.c:238
Code: 48 8b 85 e8 fe ff ff 48 8b 95 f0 fe ff ff e9 94 fb ff ff 48 89 95 f0 fe ff ff e8 81 53 6e 00 48 8b 95 f0 fe ff ff e9 62 fb ff ff <0f> 0b 48 89 cf 48 89 8d e8 fe ff ff e8 64 53 6e 00 48 8b 8d e8
RIP: tasklet_action_common.isra.19+0x6db/0x700 kernel/softirq.c:515 RSP: ffff8801d9b3faf8
Fixes: dc841e30eaea ("dccp: Extend CCID packet dequeueing interface")
commit b855ff827476adbdc2259e9895681d82b7b26065 upstream.
syzbot reported an uninit-value read of skb->mark in iptable_mangle_hook()
Thanks to the nice report, I tracked the problem to dccp not caring
of ireq->ir_mark for passive sessions.
BUG: KMSAN: uninit-value in ipt_mangle_out net/ipv4/netfilter/iptable_mangle.c:66 [inline]
BUG: KMSAN: uninit-value in iptable_mangle_hook+0x5e5/0x720 net/ipv4/netfilter/iptable_mangle.c:84
CPU: 0 PID: 5300 Comm: syz-executor3 Not tainted 4.16.0+ #81
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:53
kmsan_report+0x142/0x240 mm/kmsan/kmsan.c:1067
__msan_warning_32+0x6c/0xb0 mm/kmsan/kmsan_instr.c:676
nf_hook_entry_hookfn include/linux/netfilter.h:120 [inline]
nf_hook_slow+0x158/0x3d0 net/netfilter/core.c:483
nf_hook include/linux/netfilter.h:243 [inline]
__ip_local_out net/ipv4/ip_output.c:113 [inline]
ip_local_out net/ipv4/ip_output.c:122 [inline]
ip_queue_xmit+0x1d21/0x21c0 net/ipv4/ip_output.c:504
dccp_transmit_skb+0x15eb/0x1900 net/dccp/output.c:142
dccp_xmit_packet+0x814/0x9e0 net/dccp/output.c:281
dccp_write_xmit+0x20f/0x480 net/dccp/output.c:363
dccp_sendmsg+0x12ca/0x12d0 net/dccp/proto.c:818
inet_sendmsg+0x48d/0x740 net/ipv4/af_inet.c:764
sock_sendmsg_nosec net/socket.c:630 [inline]
sock_sendmsg net/socket.c:640 [inline]
___sys_sendmsg+0xec0/0x1310 net/socket.c:2046
__sys_sendmsg net/socket.c:2080 [inline]
SYSC_sendmsg+0x2a3/0x3d0 net/socket.c:2091
SyS_sendmsg+0x54/0x80 net/socket.c:2087
do_syscall_64+0x309/0x430 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
RIP: 0033:0x455259
RSP: 002b:00007f1a4473dc68 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00007f1a4473e6d4 RCX: 0000000000455259
RDX: 0000000000000000 RSI: 0000000020b76fc8 RDI: 0000000000000015
RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 00000000000004f0 R14: 00000000006fa720 R15: 0000000000000000
Uninit was stored to memory at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:278 [inline]
kmsan_save_stack mm/kmsan/kmsan.c:293 [inline]
kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:684
__msan_chain_origin+0x69/0xc0 mm/kmsan/kmsan_instr.c:521
ip_queue_xmit+0x1e35/0x21c0 net/ipv4/ip_output.c:502
inet_csk_clone_lock+0x503/0x580 net/ipv4/inet_connection_sock.c:797
dccp_create_openreq_child+0x7f/0x890 net/dccp/minisocks.c:92
dccp_v4_request_recv_sock+0x22c/0xe90 net/dccp/ipv4.c:408
dccp_v6_request_recv_sock+0x290/0x2000 net/dccp/ipv6.c:414
dccp_check_req+0x7b9/0x8f0 net/dccp/minisocks.c:197
dccp_v4_rcv+0x12e4/0x2630 net/dccp/ipv4.c:840
ip_local_deliver_finish+0x6ed/0xd40 net/ipv4/ip_input.c:216
ip_local_deliver+0x43c/0x4e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:449 [inline]
ip_rcv_finish+0x1253/0x16d0 net/ipv4/ip_input.c:397
ip_rcv+0x119d/0x16f0 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x47cf/0x4a80 net/core/dev.c:4562
__netif_receive_skb net/core/dev.c:4627 [inline]
process_backlog+0x62d/0xe20 net/core/dev.c:5307
napi_poll net/core/dev.c:5705 [inline]
net_rx_action+0x7c1/0x1a70 net/core/dev.c:5771
__do_softirq+0x56d/0x93d kernel/softirq.c:285
Uninit was created at:
kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:188
kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:314
kmem_cache_alloc+0xaab/0xb90 mm/slub.c:2756
reqsk_alloc include/net/request_sock.h:88 [inline]
inet_reqsk_alloc+0xc4/0x7f0 net/ipv4/tcp_input.c:6145
dccp_v4_conn_request+0x5cc/0x1770 net/dccp/ipv4.c:600
dccp_v6_conn_request+0x299/0x1880 net/dccp/ipv6.c:317
dccp_rcv_state_process+0x2ea/0x2410 net/dccp/input.c:612
dccp_v4_do_rcv+0x229/0x340 net/dccp/ipv4.c:682
dccp_v6_do_rcv+0x16d/0x1220 net/dccp/ipv6.c:578
sk_backlog_rcv include/net/sock.h:908 [inline]
__sk_receive_skb+0x60e/0xf20 net/core/sock.c:513
dccp_v4_rcv+0x24d4/0x2630 net/dccp/ipv4.c:874
[ Upstream commit 67f93df79aeefc3add4e4b31a752600f834236e2 ]
dccp_disconnect() sets 'dp->dccps_hc_tx_ccid' tx handler to NULL,
therefore if DCCP socket is disconnected and dccp_sendmsg() is
called after it, it will cause a NULL pointer dereference in
dccp_write_xmit().
This crash and the reproducer was reported by syzbot. Looks like
it is reproduced if commit 69c64866ce07 ("dccp: CVE-2017-8824:
use-after-free in DCCP code") is applied.
Reported-by: syzbot+f99ab3887ab65d70f816@syzkaller.appspotmail.com
commit 69c64866ce072dea1d1e59a0d61e0f66c0dffb76 upstream.
Whenever the sock object is in DCCP_CLOSED state,
dccp_disconnect() must free dccps_hc_tx_ccid and
dccps_hc_rx_ccid and set to NULL.
Signed-off-by: Mohamed Ghannam <simo.ghannam@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit dd5684ecae3bd8e44b644f50e2c12c7e57fdfef5 ]
ccid2_hc_tx_rto_expire() timer callback always restarts the timer
again and can run indefinitely (unless it is stopped outside), and after
commit 120e9dabaf55 ("dccp: defer ccid_hc_tx_delete() at dismantle time"),
which moved ccid_hc_tx_delete() (also includes sk_stop_timer()) from
dccp_destroy_sock() to sk_destruct(), this started to happen quite often.
The timer prevents releasing the socket, as a result, sk_destruct() won't
be called.
Found with LTP/dccp_ipsec tests running on the bonding device,
which later couldn't be unloaded after the tests were completed:
unregister_netdevice: waiting for bond0 to become free. Usage count = 148
Fixes: 2a91aa396739 ("[DCCP] CCID2: Initial CCID2 (TCP-Like) implementation")
[ Upstream commit cfac7f836a715b91f08c851df915d401a4d52783 ]
Maciej Żenczykowski reported some panics in tcp_twsk_destructor()
that might be caused by the following bug.
timewait timer is pinned to the cpu, because we want to transition
timwewait refcount from 0 to 4 in one go, once everything has been
initialized.
At the time commit ed2e92394589 ("tcp/dccp: fix timewait races in timer
handling") was merged, TCP was always running from BH habdler.
After commit 5413d1babe8f ("net: do not block BH while processing
socket backlog") we definitely can run tcp_time_wait() from process
context.
We need to block BH in the critical section so that the pinned timer
has still its purpose.
This bug is more likely to happen under stress and when very small RTO
are used in datacenter flows.
Fixes: 5413d1babe8f ("net: do not block BH while processing socket backlog")
Reported-by: Maciej Żenczykowski <maze@google.com>
Acked-by: Maciej Żenczykowski <maze@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
In my first attempt to fix the lockdep splat, I forgot we could
enter inet_csk_route_req() with a freshly allocated request socket,
for which refcount has not yet been elevated, due to complex
SLAB_TYPESAFE_BY_RCU rules.
We either are in rcu_read_lock() section _or_ we own a refcount on the
request.
Correct RCU verb to use here is rcu_dereference_check(), although it is
not possible to prove we actually own a reference on a shared
refcount :/
In v2, I added ireq_opt_deref() helper and use in three places, to fix other
possible splats.
[ 49.844590] lockdep_rcu_suspicious+0xea/0xf3
[ 49.846487] inet_csk_route_req+0x53/0x14d
[ 49.848334] tcp_v4_route_req+0xe/0x10
[ 49.850174] tcp_conn_request+0x31c/0x6a0
[ 49.851992] ? __lock_acquire+0x614/0x822
[ 49.854015] tcp_v4_conn_request+0x5a/0x79
[ 49.855957] ? tcp_v4_conn_request+0x5a/0x79
[ 49.858052] tcp_rcv_state_process+0x98/0xdcc
[ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307
[ 49.862085] tcp_v4_do_rcv+0xfc/0x145
[ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145
[ 49.866173] tcp_v4_rcv+0x5ab/0xaf9
[ 49.868029] ip_local_deliver_finish+0x1af/0x2e7
[ 49.870064] ip_local_deliver+0x1b2/0x1c5
[ 49.871775] ? inet_del_offload+0x45/0x45
[ 49.873916] ip_rcv_finish+0x3f7/0x471
[ 49.875476] ip_rcv+0x3f1/0x42f
[ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7
[ 49.878791] __netif_receive_skb_core+0x6d3/0x950
[ 49.880701] ? process_backlog+0x7e/0x216
[ 49.882589] __netif_receive_skb+0x1d/0x5e
[ 49.884122] process_backlog+0x10c/0x216
[ 49.885812] net_rx_action+0x147/0x3df
Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()")
Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races")
Reported-by: kernel test robot <fengguang.wu@intel.com>
syzkaller found another bug in DCCP/TCP stacks [1]
For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix
ireq->pktopts race"), we need to make sure we do not access
ireq->opt unless we own the request sock.
Note the opt field is renamed to ireq_opt to ease grep games.
[1]
BUG: KASAN: use-after-free in ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474
Read of size 1 at addr ffff8801c951039c by task syz-executor5/3295
CPU: 1 PID: 3295 Comm: syz-executor5 Not tainted 4.14.0-rc4+ #80
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
tcp_transmit_skb+0x1ab7/0x3840 net/ipv4/tcp_output.c:1135
tcp_send_ack.part.37+0x3bb/0x650 net/ipv4/tcp_output.c:3587
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3557
__tcp_ack_snd_check+0x2c6/0x4b0 net/ipv4/tcp_input.c:5072
tcp_ack_snd_check net/ipv4/tcp_input.c:5085 [inline]
tcp_rcv_state_process+0x2eff/0x4850 net/ipv4/tcp_input.c:6071
tcp_child_process+0x342/0x990 net/ipv4/tcp_minisocks.c:816
tcp_v4_rcv+0x1827/0x2f80 net/ipv4/tcp_ipv4.c:1682
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:249 [inline]
ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:464 [inline]
ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514
netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587
netif_receive_skb+0xae/0x390 net/core/dev.c:4611
tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372
tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766
tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792
call_write_iter include/linux/fs.h:1770 [inline]
new_sync_write fs/read_write.c:468 [inline]
__vfs_write+0x68a/0x970 fs/read_write.c:481
vfs_write+0x18f/0x510 fs/read_write.c:543
SYSC_write fs/read_write.c:588 [inline]
SyS_write+0xef/0x220 fs/read_write.c:580
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x40c341
RSP: 002b:00007f469523ec10 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 000000000040c341
RDX: 0000000000000037 RSI: 0000000020004000 RDI: 0000000000000015
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000000f4240 R11: 0000000000000293 R12: 00000000004b7fd1
R13: 00000000ffffffff R14: 0000000020000000 R15: 0000000000025000
Allocated by task 3295:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
__do_kmalloc mm/slab.c:3725 [inline]
__kmalloc+0x162/0x760 mm/slab.c:3734
kmalloc include/linux/slab.h:498 [inline]
tcp_v4_save_options include/net/tcp.h:1962 [inline]
tcp_v4_init_req+0x2d3/0x3e0 net/ipv4/tcp_ipv4.c:1271
tcp_conn_request+0xf6d/0x3410 net/ipv4/tcp_input.c:6283
tcp_v4_conn_request+0x157/0x210 net/ipv4/tcp_ipv4.c:1313
tcp_rcv_state_process+0x8ea/0x4850 net/ipv4/tcp_input.c:5857
tcp_v4_do_rcv+0x55c/0x7d0 net/ipv4/tcp_ipv4.c:1482
tcp_v4_rcv+0x2d10/0x2f80 net/ipv4/tcp_ipv4.c:1711
Freed by task 3306:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kfree+0xca/0x250 mm/slab.c:3820
inet_sock_destruct+0x59d/0x950 net/ipv4/af_inet.c:157
__sk_destruct+0xfd/0x910 net/core/sock.c:1560
sk_destruct+0x47/0x80 net/core/sock.c:1595
__sk_free+0x57/0x230 net/core/sock.c:1603
sk_free+0x2a/0x40 net/core/sock.c:1614
sock_put include/net/sock.h:1652 [inline]
inet_csk_complete_hashdance+0xd5/0xf0 net/ipv4/inet_connection_sock.c:959
tcp_check_req+0xf4d/0x1620 net/ipv4/tcp_minisocks.c:765
tcp_v4_rcv+0x17f6/0x2f80 net/ipv4/tcp_ipv4.c:1675
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
Add handling of IPV6_PKTOPTIONS to dccp_v6_do_rcv() in net/dccp/ipv6.c,
similar
to the handling in net/ipv6/tcp_ipv6.c
Signed-off-by: Andrii Vladyka <tulup@mail.ru>
syszkaller team reported another problem in DCCP [1]
Problem here is that the structure holding RTO timer
(ccid2_hc_tx_rto_expire() handler) is freed too soon.
We can not use del_timer_sync() to cancel the timer
since this timer wants to grab socket lock (that would risk a dead lock)
Solution is to defer the freeing of memory when all references to
the socket were released. Socket timers do own a reference, so this
should fix the issue.
[1]
BUG: KASAN: use-after-free in ccid2_hc_tx_rto_expire+0x51c/0x5c0 net/dccp/ccids/ccid2.c:144
Read of size 4 at addr ffff8801d2660540 by task kworker/u4:7/3365
CPU: 1 PID: 3365 Comm: kworker/u4:7 Not tainted 4.13.0-rc4+ #3
Workqueue: events_unbound call_usermodehelper_exec_work
Call Trace:
<IRQ>
kasan_report+0x24e/0x340 mm/kasan/report.c:409
__asan_report_load4_noabort+0x14/0x20 mm/kasan/report.c:429
call_timer_fn+0x233/0x830 kernel/time/timer.c:1268
expire_timers kernel/time/timer.c:1307 [inline]
__run_timers+0x7fd/0xb90 kernel/time/timer.c:1601
run_timer_softirq+0x21/0x80 kernel/time/timer.c:1614
__do_softirq+0x2f5/0xba3 kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364 [inline]
irq_exit+0x1cc/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:638 [inline]
smp_apic_timer_interrupt+0x76/0xa0 arch/x86/kernel/apic/apic.c:1044
apic_timer_interrupt+0x93/0xa0 arch/x86/entry/entry_64.S:702
RIP: 0010:arch_local_irq_enable arch/x86/include/asm/paravirt.h:824 [inline]
RIP: 0010:__raw_write_unlock_irq include/linux/rwlock_api_smp.h:267 [inline]
RIP: 0010:_raw_write_unlock_irq+0x56/0x70 kernel/locking/spinlock.c:343
RSP: 0018:ffff8801cd50eaa8 EFLAGS: 00000286 ORIG_RAX: ffffffffffffff10
RAX: dffffc0000000000 RBX: ffffffff85a090c0 RCX: 0000000000000006
RDX: 1ffffffff0b595f3 RSI: 1ffff1003962f989 RDI: ffffffff85acaf98
RBP: ffff8801cd50eab0 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801cc96ea60
R13: dffffc0000000000 R14: ffff8801cc96e4c0 R15: ffff8801cc96e4c0
</IRQ>
release_task+0xe9e/0x1a40 kernel/exit.c:220
wait_task_zombie kernel/exit.c:1162 [inline]
wait_consider_task+0x29b8/0x33c0 kernel/exit.c:1389
do_wait_thread kernel/exit.c:1452 [inline]
do_wait+0x441/0xa90 kernel/exit.c:1523
kernel_wait4+0x1f5/0x370 kernel/exit.c:1665
SYSC_wait4+0x134/0x140 kernel/exit.c:1677
SyS_wait4+0x2c/0x40 kernel/exit.c:1673
call_usermodehelper_exec_sync kernel/kmod.c:286 [inline]
call_usermodehelper_exec_work+0x1a0/0x2c0 kernel/kmod.c:323
process_one_work+0xbf3/0x1bc0 kernel/workqueue.c:2097
worker_thread+0x223/0x1860 kernel/workqueue.c:2231
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:425
Allocated by task 21267:
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:489
kmem_cache_alloc+0x127/0x750 mm/slab.c:3561
ccid_new+0x20e/0x390 net/dccp/ccid.c:151
dccp_hdlr_ccid+0x27/0x140 net/dccp/feat.c:44
__dccp_feat_activate+0x142/0x2a0 net/dccp/feat.c:344
dccp_feat_activate_values+0x34e/0xa90 net/dccp/feat.c:1538
dccp_rcv_request_sent_state_process net/dccp/input.c:472 [inline]
dccp_rcv_state_process+0xed1/0x1620 net/dccp/input.c:677
dccp_v4_do_rcv+0xeb/0x160 net/dccp/ipv4.c:679
sk_backlog_rcv include/net/sock.h:911 [inline]
__release_sock+0x124/0x360 net/core/sock.c:2269
release_sock+0xa4/0x2a0 net/core/sock.c:2784
inet_wait_for_connect net/ipv4/af_inet.c:557 [inline]
__inet_stream_connect+0x671/0xf00 net/ipv4/af_inet.c:643
inet_stream_connect+0x58/0xa0 net/ipv4/af_inet.c:682
SYSC_connect+0x204/0x470 net/socket.c:1642
SyS_connect+0x24/0x30 net/socket.c:1623
Freed by task 3049:
kmem_cache_free+0x77/0x280 mm/slab.c:3763
ccid_hc_tx_delete+0xc5/0x100 net/dccp/ccid.c:190
dccp_destroy_sock+0x1d1/0x2b0 net/dccp/proto.c:225
inet_csk_destroy_sock+0x166/0x3f0 net/ipv4/inet_connection_sock.c:833
dccp_done+0xb7/0xd0 net/dccp/proto.c:145
dccp_time_wait+0x13d/0x300 net/dccp/minisocks.c:72
dccp_rcv_reset+0x1d1/0x5b0 net/dccp/input.c:160
dccp_rcv_state_process+0x8fc/0x1620 net/dccp/input.c:663
__sk_receive_skb+0x33e/0xc00 net/core/sock.c:521
dccp_v4_rcv+0xef1/0x1c00 net/dccp/ipv4.c:871
NF_HOOK include/linux/netfilter.h:248 [inline]
ip_local_deliver+0x1ce/0x6d0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:477 [inline]
ip_rcv_finish+0x8db/0x19c0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x17d0 net/ipv4/ip_input.c:488
__netif_receive_skb_core+0x19af/0x33d0 net/core/dev.c:4417
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4455
process_backlog+0x203/0x740 net/core/dev.c:5130
napi_poll net/core/dev.c:5527 [inline]
net_rx_action+0x792/0x1910 net/core/dev.c:5593
The buggy address belongs to the object at ffff8801d2660100
The buggy address is located 1088 bytes inside of
1240-byte region [ffff8801d2660100, ffff8801d26605d8)
page:ffffea0007499800 count:1 mapcount:0 mapping:ffff8801d2660100 index:0x0 compound_mapcount: 0
flags: 0x200000000008100(slab|head)
raw: 0200000000008100 ffff8801d2660100 0000000000000000 0000000100000005
raw: ffffea00075271a0 ffffea0007538820 ffff8801d3aef9c0 0000000000000000
Memory state around the buggy address:
ffff8801d2660400: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801d2660480: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8801d2660500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801d2660580: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc
ffff8801d2660600: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
syzkaller reported that DCCP could have a non empty
write queue at dismantle time.
WARNING: CPU: 1 PID: 2953 at net/core/stream.c:199 sk_stream_kill_queues+0x3ce/0x520 net/core/stream.c:199
Kernel panic - not syncing: panic_on_warn set ...
CPU: 1 PID: 2953 Comm: syz-executor0 Not tainted 4.13.0-rc4+ #2
Call Trace:
panic+0x1e4/0x417 kernel/panic.c:180
__warn+0x1c4/0x1d9 kernel/panic.c:541
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:190
do_trap_no_signal arch/x86/kernel/traps.c:224 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:273
do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:310
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:323
invalid_op+0x1e/0x30 arch/x86/entry/entry_64.S:846
RIP: 0010:sk_stream_kill_queues+0x3ce/0x520 net/core/stream.c:199
RSP: 0018:ffff8801d182f108 EFLAGS: 00010297
RAX: ffff8801d1144140 RBX: ffff8801d13cb280 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffffffff85137b00 RDI: ffff8801d13cb280
RBP: ffff8801d182f148 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801d13cb4d0
R13: ffff8801d13cb3b8 R14: ffff8801d13cb300 R15: ffff8801d13cb3b8
inet_csk_destroy_sock+0x175/0x3f0 net/ipv4/inet_connection_sock.c:835
dccp_close+0x84d/0xc10 net/dccp/proto.c:1067
inet_release+0xed/0x1c0 net/ipv4/af_inet.c:425
sock_release+0x8d/0x1e0 net/socket.c:597
sock_close+0x16/0x20 net/socket.c:1126
__fput+0x327/0x7e0 fs/file_table.c:210
____fput+0x15/0x20 fs/file_table.c:246
task_work_run+0x18a/0x260 kernel/task_work.c:116
exit_task_work include/linux/task_work.h:21 [inline]
do_exit+0xa32/0x1b10 kernel/exit.c:865
do_group_exit+0x149/0x400 kernel/exit.c:969
get_signal+0x7e8/0x17e0 kernel/signal.c:2330
do_signal+0x94/0x1ee0 arch/x86/kernel/signal.c:808
exit_to_usermode_loop+0x21c/0x2d0 arch/x86/entry/common.c:157
prepare_exit_to_usermode arch/x86/entry/common.c:194 [inline]
syscall_return_slowpath+0x3a7/0x450 arch/x86/entry/common.c:263
Add a second device index, sdif, to inet6 socket lookups. sdif is the
index for ingress devices enslaved to an l3mdev. It allows the lookups
to consider the enslaved device as well as the L3 domain when searching
for a socket.
TCP moves the data in the cb. Prior to tcp_v4_rcv (e.g., early demux) the
ingress index is obtained from IPCB using inet_sdif and after tcp_v4_rcv
tcp_v4_sdif is used.
Signed-off-by: David Ahern <dsahern@gmail.com>
Add a second device index, sdif, to inet socket lookups. sdif is the
for a socket.
ingress index is obtained from IPCB using inet_sdif and after the cb move
in tcp_v4_rcv the tcp_v4_sdif helper is used.
In dccp_feat_init, when ccid_get_builtin_ccids failsto alloc
memory for rx.val, it should free tx.val before returning an
error.
Signed-off-by: Xin Long <lucien.xin@gmail.com>
The patch "dccp: fix a memleak that dccp_ipv6 doesn't put reqsk
properly" fixed reqsk refcnt leak for dccp_ipv6. The same issue
exists on dccp_ipv4.
This patch is to fix it for dccp_ipv4.
In dccp_v6_conn_request, after reqsk gets alloced and hashed into
ehash table, reqsk's refcnt is set 3. one is for req->rsk_timer,
one is for hlist, and the other one is for current using.
The problem is when dccp_v6_conn_request returns and finishes using
reqsk, it doesn't put reqsk. This will cause reqsk refcnt leaks and
reqsk obj never gets freed.
Jianlin found this issue when running dccp_memleak.c in a loop, the
system memory would run out.
dccp_memleak.c:
int s1 = socket(PF_INET6, 6, IPPROTO_IP);
bind(s1, &sa1, 0x20);
listen(s1, 0x9);
int s2 = socket(PF_INET6, 6, IPPROTO_IP);
connect(s2, &sa1, 0x20);
close(s1);
close(s2);
This patch is to put the reqsk before dccp_v6_conn_request returns,
just as what tcp_conn_request does.
Reported-by: Jianlin Shi <jishi@redhat.com>
Don't populate array error_code on the stack but make it static. Makes
the object code smaller by almost 250 bytes:
Before:
10366 983 0 11349 2c55 net/dccp/input.o
After:
10161 1039 0 11200 2bc0 net/dccp/input.o
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
Patch "call inet_add_protocol after register_pernet_subsys in dccp_v4_init"
fixed a null pointer dereference issue for dccp_ipv4 module.
The same fix is needed for dccp_ipv6 module.
Now dccp_ipv4 works as a kernel module. During loading this module, if
one dccp packet is being recieved after inet_add_protocol but before
register_pernet_subsys in which v4_ctl_sk is initialized, a null pointer
dereference may be triggered because of init_net.dccp.v4_ctl_sk is 0x0.
Jianlin found this issue when the following call trace occurred:
[ 171.950177] BUG: unable to handle kernel NULL pointer dereference at 0000000000000110
[ 171.951007] IP: [<ffffffffc0558364>] dccp_v4_ctl_send_reset+0xc4/0x220 [dccp_ipv4]
[ 171.984629] Call Trace:
[ 171.984859] <IRQ>
[ 171.985061]
[ 171.985213] [<ffffffffc0559a53>] dccp_v4_rcv+0x383/0x3f9 [dccp_ipv4]
[ 171.985711] [<ffffffff815ca054>] ip_local_deliver_finish+0xb4/0x1f0
[ 171.986309] [<ffffffff815ca339>] ip_local_deliver+0x59/0xd0
[ 171.986852] [<ffffffff810cd7a4>] ? update_curr+0x104/0x190
[ 171.986956] [<ffffffff815c9cda>] ip_rcv_finish+0x8a/0x350
[ 171.986956] [<ffffffff815ca666>] ip_rcv+0x2b6/0x410
[ 171.986956] [<ffffffff810c83b4>] ? task_cputime+0x44/0x80
[ 171.986956] [<ffffffff81586f22>] __netif_receive_skb_core+0x572/0x7c0
[ 171.986956] [<ffffffff810d2c51>] ? trigger_load_balance+0x61/0x1e0
[ 171.986956] [<ffffffff81587188>] __netif_receive_skb+0x18/0x60
[ 171.986956] [<ffffffff8158841e>] process_backlog+0xae/0x180
[ 171.986956] [<ffffffff8158799d>] net_rx_action+0x16d/0x380
[ 171.986956] [<ffffffff81090b7f>] __do_softirq+0xef/0x280
[ 171.986956] [<ffffffff816b6a1c>] call_softirq+0x1c/0x30
This patch is to move inet_add_protocol after register_pernet_subsys in
dccp_v4_init, so that v4_ctl_sk is initialized before any incoming dccp
packets are processed.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Use our own macro instead of abusing tcp_time_stamp
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Pull networking fixes from David Miller:
1) Track alignment in BPF verifier so that legitimate programs won't be
rejected on !CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS architectures.
2) Make tail calls work properly in arm64 BPF JIT, from Deniel
Borkmann.
3) Make the configuration and semantics Generic XDP make more sense and
don't allow both generic XDP and a driver specific instance to be
active at the same time. Also from Daniel.
4) Don't crash on resume in xen-netfront, from Vitaly Kuznetsov.
5) Fix use-after-free in VRF driver, from Gao Feng.
6) Use netdev_alloc_skb_ip_align() to avoid unaligned IP headers in
qca_spi driver, from Stefan Wahren.
7) Always run cleanup routines in BPF samples when we get SIGTERM, from
Andy Gospodarek.
8) The mdio phy code should bring PHYs out of reset using the shared
GPIO lines before invoking bus->reset(). From Florian Fainelli.
9) Some USB descriptor access endian fixes in various drivers from
Johan Hovold.
10) Handle PAUSE advertisements properly in mlx5 driver, from Gal
Pressman.
11) Fix reversed test in mlx5e_setup_tc(), from Saeed Mahameed.
12) Cure netdev leak in AF_PACKET when using timestamping via control
messages. From Douglas Caetano dos Santos.
13) netcp doesn't support HWTSTAMP_FILTER_ALl, reject it. From Miroslav
Lichvar.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits)
ldmvsw: stop the clean timer at beginning of remove
ldmvsw: unregistering netdev before disable hardware
net: netcp: fix check of requested timestamping filter
ipv6: avoid dad-failures for addresses with NODAD
qed: Fix uninitialized data in aRFS infrastructure
mdio: mux: fix device_node_continue.cocci warnings
net/packet: fix missing net_device reference release
net/mlx4_core: Use min3 to select number of MSI-X vectors
macvlan: Fix performance issues with vlan tagged packets
net: stmmac: use correct pointer when printing normal descriptor ring
net/mlx5: Use underlay QPN from the root name space
net/mlx5e: IPoIB, Only support regular RQ for now
net/mlx5e: Fix setup TC ndo
net/mlx5e: Fix ethtool pause support and advertise reporting
net/mlx5e: Use the correct pause values for ethtool advertising
vmxnet3: ensure that adapter is in proper state during force_close
sfc: revert changes to NIC revision numbers
net: ch9200: add missing USB-descriptor endianness conversions
net: irda: irda-usb: fix firmware name on big-endian hosts
net: dsa: mv88e6xxx: add default case to switch
Like commit 657831ffc38e ("dccp/tcp: do not inherit mc_list from parent")
we should clear ipv6_mc_list etc. for IPv6 sockets too.
Cc: Eric Dumazet <edumazet@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- Documentation updates.
- Miscellaneous fixes.
- Parallelize SRCU callback handling (plus overlapping patches).
A group of Linux kernel hackers reported chasing a bug that resulted
from their assumption that SLAB_DESTROY_BY_RCU provided an existence
guarantee, that is, that no block from such a slab would be reallocated
during an RCU read-side critical section. Of course, that is not the
case. Instead, SLAB_DESTROY_BY_RCU only prevents freeing of an entire
slab of blocks.
However, there is a phrase for this, namely "type safety". This commit
therefore renames SLAB_DESTROY_BY_RCU to SLAB_TYPESAFE_BY_RCU in order
to avoid future instances of this sort of confusion.
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <linux-mm@kvack.org>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
[ paulmck: Add comments mentioning the old name, as requested by Eric
Dumazet, in order to help people familiar with the old name find
the new one. ]
Acked-by: David Rientjes <rientjes@google.com>
This patch fixes a memory leak, which happens if the connection request
is not fulfilled between parsing the DCCP options and handling the SYN
(because e.g. the backlog is full), because we forgot to free the
list of ack vectors.
Reported-by: Jianwen Ji <jiji@redhat.com>
As Eric Dumazet pointed out this also needs to be fixed in IPv6.
v2: Contains the IPv6 tcp/Ipv6 dccp patches as well.
We have seen a few incidents lately where a dst_enty has been freed
with a dangling TCP socket reference (sk->sk_dst_cache) pointing to that
dst_entry. If the conditions/timings are right a crash then ensues when the
freed dst_entry is referenced later on. A Common crashing back trace is:
#8 [] page_fault at ffffffff8163e648
[exception RIP: __tcp_ack_snd_check+74]
#9 [] tcp_rcv_established at ffffffff81580b64
#10 [] tcp_v4_do_rcv at ffffffff8158b54a
#11 [] tcp_v4_rcv at ffffffff8158cd02
#12 [] ip_local_deliver_finish at ffffffff815668f4
#13 [] ip_local_deliver at ffffffff81566bd9
#14 [] ip_rcv_finish at ffffffff8156656d
#15 [] ip_rcv at ffffffff81566f06
#16 [] __netif_receive_skb_core at ffffffff8152b3a2
#17 [] __netif_receive_skb at ffffffff8152b608
#18 [] netif_receive_skb at ffffffff8152b690
#19 [] vmxnet3_rq_rx_complete at ffffffffa015eeaf [vmxnet3]
#20 [] vmxnet3_poll_rx_only at ffffffffa015f32a [vmxnet3]
#21 [] net_rx_action at ffffffff8152bac2
#22 [] __do_softirq at ffffffff81084b4f
#23 [] call_softirq at ffffffff8164845c
#24 [] do_softirq at ffffffff81016fc5
#25 [] irq_exit at ffffffff81084ee5
#26 [] do_IRQ at ffffffff81648ff8
Of course it may happen with other NIC drivers as well.
It's found the freed dst_entry here:
224 static bool tcp_in_quickack_mode(struct sock *sk)↩
225 {↩
226 ▹ const struct inet_connection_sock *icsk = inet_csk(sk);↩
227 ▹ const struct dst_entry *dst = __sk_dst_get(sk);↩
228 ↩
229 ▹ return (dst && dst_metric(dst, RTAX_QUICKACK)) ||↩
230 ▹ ▹ (icsk->icsk_ack.quick && !icsk->icsk_ack.pingpong);↩
231 }↩
But there are other backtraces attributed to the same freed dst_entry in
netfilter code as well.
All the vmcores showed 2 significant clues:
- Remote hosts behind the default gateway had always been redirected to a
different gateway. A rtable/dst_entry will be added for that host. Making
more dst_entrys with lower reference counts. Making this more probable.
- All vmcores showed a postitive LockDroppedIcmps value, e.g:
LockDroppedIcmps 267
A closer look at the tcp_v4_err() handler revealed that do_redirect() will run
regardless of whether user space has the socket locked. This can result in a
race condition where the same dst_entry cached in sk->sk_dst_entry can be
decremented twice for the same socket via:
do_redirect()->__sk_dst_check()-> dst_release().
Which leads to the dst_entry being prematurely freed with another socket
pointing to it via sk->sk_dst_cache and a subsequent crash.
To fix this skip do_redirect() if usespace has the socket locked. Instead let
the redirect take place later when user space does not have the socket
locked.
The dccp/IPv6 code is very similar in this respect, so fixing it there too.
As Eric Garver pointed out the following commit now invalidates routes. Which
can set the dst->obsolete flag so that ipv4_dst_check() returns null and
triggers the dst_release().
Fixes: ceb3320610d6 ("ipv4: Kill routes during PMTU/redirect updates.")
Cc: Eric Garver <egarver@redhat.com>
Cc: Hannes Sowa <hsowa@redhat.com>
Signed-off-by: Jon Maxwell <jmaxwell37@gmail.com>
Dmitry reported crashes in DCCP stack [1]
Problem here is that when I got rid of listener spinlock, I missed the
fact that DCCP stores a complex state in struct dccp_request_sock,
while TCP does not.
Since multiple cpus could access it at the same time, we need to add
protection.
[1]
BUG: KASAN: use-after-free in dccp_feat_activate_values+0x967/0xab0
net/dccp/feat.c:1541 at addr ffff88003713be68
Read of size 8 by task syz-executor2/8457
CPU: 2 PID: 8457 Comm: syz-executor2 Not tainted 4.10.0-rc7+ #127
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:15 [inline]
dump_stack+0x292/0x398 lib/dump_stack.c:51
kasan_object_err+0x1c/0x70 mm/kasan/report.c:162
print_address_description mm/kasan/report.c:200 [inline]
kasan_report_error mm/kasan/report.c:289 [inline]
kasan_report.part.1+0x20e/0x4e0 mm/kasan/report.c:311
kasan_report mm/kasan/report.c:332 [inline]
__asan_report_load8_noabort+0x29/0x30 mm/kasan/report.c:332
dccp_feat_activate_values+0x967/0xab0 net/dccp/feat.c:1541
dccp_create_openreq_child+0x464/0x610 net/dccp/minisocks.c:121
dccp_v6_request_recv_sock+0x1f6/0x1960 net/dccp/ipv6.c:457
dccp_check_req+0x335/0x5a0 net/dccp/minisocks.c:186
dccp_v6_rcv+0x69e/0x1d00 net/dccp/ipv6.c:711
ip6_input_finish+0x46d/0x17a0 net/ipv6/ip6_input.c:279
NF_HOOK include/linux/netfilter.h:257 [inline]
ip6_input+0xdb/0x590 net/ipv6/ip6_input.c:322
dst_input include/net/dst.h:507 [inline]
ip6_rcv_finish+0x289/0x890 net/ipv6/ip6_input.c:69
ipv6_rcv+0x12ec/0x23d0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x1ae5/0x3400 net/core/dev.c:4190
__netif_receive_skb+0x2a/0x170 net/core/dev.c:4228
process_backlog+0xe5/0x6c0 net/core/dev.c:4839
napi_poll net/core/dev.c:5202 [inline]
net_rx_action+0xe70/0x1900 net/core/dev.c:5267
__do_softirq+0x2fb/0xb7d kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902
</IRQ>
do_softirq.part.17+0x1e8/0x230 kernel/softirq.c:328
do_softirq kernel/softirq.c:176 [inline]
__local_bh_enable_ip+0x1f2/0x200 kernel/softirq.c:181
local_bh_enable include/linux/bottom_half.h:31 [inline]
rcu_read_unlock_bh include/linux/rcupdate.h:971 [inline]
ip6_finish_output2+0xbb0/0x23d0 net/ipv6/ip6_output.c:123
ip6_finish_output+0x302/0x960 net/ipv6/ip6_output.c:148
NF_HOOK_COND include/linux/netfilter.h:246 [inline]
ip6_output+0x1cb/0x8d0 net/ipv6/ip6_output.c:162
ip6_xmit+0xcdf/0x20d0 include/net/dst.h:501
inet6_csk_xmit+0x320/0x5f0 net/ipv6/inet6_connection_sock.c:179
dccp_transmit_skb+0xb09/0x1120 net/dccp/output.c:141
dccp_xmit_packet+0x215/0x760 net/dccp/output.c:280
dccp_write_xmit+0x168/0x1d0 net/dccp/output.c:362
dccp_sendmsg+0x79c/0xb10 net/dccp/proto.c:796
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744
sock_sendmsg_nosec net/socket.c:635 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:645
SYSC_sendto+0x660/0x810 net/socket.c:1687
SyS_sendto+0x40/0x50 net/socket.c:1655
entry_SYSCALL_64_fastpath+0x1f/0xc2
RIP: 0033:0x4458b9
RSP: 002b:00007f8ceb77bb58 EFLAGS: 00000282 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000000017 RCX: 00000000004458b9
RDX: 0000000000000023 RSI: 0000000020e60000 RDI: 0000000000000017
RBP: 00000000006e1b90 R08: 00000000200f9fe1 R09: 0000000000000020
R10: 0000000000008010 R11: 0000000000000282 R12: 00000000007080a8
R13: 0000000000000000 R14: 00007f8ceb77c9c0 R15: 00007f8ceb77c700
Object at ffff88003713be50, in cache kmalloc-64 size: 64
Allocated:
PID = 8446
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:57
save_stack+0x43/0xd0 mm/kasan/kasan.c:502
set_track mm/kasan/kasan.c:514 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:605
kmem_cache_alloc_trace+0x82/0x270 mm/slub.c:2738
kmalloc include/linux/slab.h:490 [inline]
dccp_feat_entry_new+0x214/0x410 net/dccp/feat.c:467
dccp_feat_push_change+0x38/0x220 net/dccp/feat.c:487
__feat_register_sp+0x223/0x2f0 net/dccp/feat.c:741
dccp_feat_propagate_ccid+0x22b/0x2b0 net/dccp/feat.c:949
dccp_feat_server_ccid_dependencies+0x1b3/0x250 net/dccp/feat.c:1012
dccp_make_response+0x1f1/0xc90 net/dccp/output.c:423
dccp_v6_send_response+0x4ec/0xc20 net/dccp/ipv6.c:217
dccp_v6_conn_request+0xaba/0x11b0 net/dccp/ipv6.c:377
dccp_rcv_state_process+0x51e/0x1650 net/dccp/input.c:606
dccp_v6_do_rcv+0x213/0x350 net/dccp/ipv6.c:632
sk_backlog_rcv include/net/sock.h:893 [inline]
__sk_receive_skb+0x36f/0xcc0 net/core/sock.c:479
dccp_v6_rcv+0xba5/0x1d00 net/dccp/ipv6.c:742
Freed:
PID = 15
kasan_slab_free+0x73/0xc0 mm/kasan/kasan.c:578
slab_free_hook mm/slub.c:1355 [inline]
slab_free_freelist_hook mm/slub.c:1377 [inline]
slab_free mm/slub.c:2954 [inline]
kfree+0xe8/0x2b0 mm/slub.c:3874
dccp_feat_entry_destructor.part.4+0x48/0x60 net/dccp/feat.c:418
dccp_feat_entry_destructor net/dccp/feat.c:416 [inline]
dccp_feat_list_pop net/dccp/feat.c:541 [inline]
dccp_feat_activate_values+0x57f/0xab0 net/dccp/feat.c:1543
ffff88003713bd00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88003713bd80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff88003713be00: fc fc fc fc fc fc fc fc fc fc fb fb fb fb fb fb
Tested-by: Dmitry Vyukov <dvyukov@google.com>
1) Fix double-free in batman-adv, from Sven Eckelmann.
2) Fix packet stats for fast-RX path, from Joannes Berg.
3) Netfilter's ip_route_me_harder() doesn't handle request sockets
properly, fix from Florian Westphal.
4) Fix sendmsg deadlock in rxrpc, from David Howells.
5) Add missing RCU locking to transport hashtable scan, from Xin Long.
6) Fix potential packet loss in mlxsw driver, from Ido Schimmel.
7) Fix race in NAPI handling between poll handlers and busy polling,
from Eric Dumazet.
8) TX path in vxlan and geneve need proper RCU locking, from Jakub
Kicinski.
9) SYN processing in DCCP and TCP need to disable BH, from Eric
Dumazet.
10) Properly handle net_enable_timestamp() being invoked from IRQ
context, also from Eric Dumazet.
11) Fix crash on device-tree systems in xgene driver, from Alban Bedel.
12) Do not call sk_free() on a locked socket, from Arnaldo Carvalho de
Melo.
13) Fix use-after-free in netvsc driver, from Dexuan Cui.
14) Fix max MTU setting in bonding driver, from WANG Cong.
15) xen-netback hash table can be allocated from softirq context, so use
GFP_ATOMIC. From Anoob Soman.
16) Fix MAC address change bug in bgmac driver, from Hari Vyas.
17) strparser needs to destroy strp_wq on module exit, from WANG Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (69 commits)
strparser: destroy workqueue on module exit
sfc: fix IPID endianness in TSOv2
sfc: avoid max() in array size
rds: remove unnecessary returned value check
rxrpc: Fix potential NULL-pointer exception
nfp: correct DMA direction in XDP DMA sync
nfp: don't tell FW about the reserved buffer space
net: ethernet: bgmac: mac address change bug
net: ethernet: bgmac: init sequence bug
xen-netback: don't vfree() queues under spinlock
xen-netback: keep a local pointer for vif in backend_disconnect()
netfilter: nf_tables: don't call nfnetlink_set_err() if nfnetlink_send() fails
netfilter: nft_set_rbtree: incorrect assumption on lower interval lookups
netfilter: nf_conntrack_sip: fix wrong memory initialisation
can: flexcan: fix typo in comment
can: usb_8dev: Fix memory leak of priv->cmd_msg_buffer
can: gs_usb: fix coding style
can: gs_usb: Don't use stack memory for USB transfers
ixgbe: Limit use of 2K buffers on architectures with 256B or larger cache lines
ixgbe: update the rss key on h/w, when ethtool ask for it
When handling problems in cloning a socket with the sk_clone_locked()
function we need to perform several steps that were open coded in it and
its callers, so introduce a routine to avoid this duplication:
sk_free_unlock_clone().
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Link: http://lkml.kernel.org/n/net-ui6laqkotycunhtmqryl9bfx@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The code where sk_clone() came from created a new socket and locked it,
but then, on the error path didn't unlock it.
This problem stayed there for a long while, till b0691c8ee7c2 ("net:
Unlock sock before calling sk_free()") fixed it, but unfortunately the
callers of sk_clone() (now sk_clone_locked()) were not audited and the
one in dccp_create_openreq_child() remained.
Now in the age of the syskaller fuzzer, this was finally uncovered, as
reported by Dmitry:
---- 8< ----
I've got the following report while running syzkaller fuzzer on
86292b33d4b7 ("Merge branch 'akpm' (patches from Andrew)")
[ BUG: held lock freed! ]
4.10.0+ #234 Not tainted
syz-executor6/6898 is freeing memory
ffff88006286cac0-ffff88006286d3b7, with a lock still held there!
(slock-AF_INET6){+.-...}, at: [<ffffffff8362c2c9>] spin_lock
include/linux/spinlock.h:299 [inline]
sk_clone_lock+0x3d9/0x12c0 net/core/sock.c:1504
5 locks held by syz-executor6/6898:
#0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff839a34b4>] lock_sock
include/net/sock.h:1460 [inline]
inet_stream_connect+0x44/0xa0 net/ipv4/af_inet.c:681
#1: (rcu_read_lock){......}, at: [<ffffffff83bc1c2a>]
inet6_csk_xmit+0x12a/0x5d0 net/ipv6/inet6_connection_sock.c:126
#2: (rcu_read_lock){......}, at: [<ffffffff8369b424>] __skb_unlink
include/linux/skbuff.h:1767 [inline]
#2: (rcu_read_lock){......}, at: [<ffffffff8369b424>] __skb_dequeue
include/linux/skbuff.h:1783 [inline]
process_backlog+0x264/0x730 net/core/dev.c:4835
#3: (rcu_read_lock){......}, at: [<ffffffff83aeb5c0>]
ip6_input_finish+0x0/0x1700 net/ipv6/ip6_input.c:59
#4: (slock-AF_INET6){+.-...}, at: [<ffffffff8362c2c9>] spin_lock
Fix it just like was done by b0691c8ee7c2 ("net: Unlock sock before calling
sk_free()").
Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Link: http://lkml.kernel.org/r/20170301153510.GE15145@kernel.org
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
SYN processing really was meant to be handled from BH.
When I got rid of BH blocking while processing socket backlog
in commit 5413d1babe8f ("net: do not block BH while processing socket
backlog"), I forgot that a malicious user could transition to TCP_LISTEN
from a state that allowed (SYN) packets to be parked in the socket
backlog while socket is owned by the thread doing the listen() call.
Sure enough syzkaller found this and reported the bug ;)
[ INFO: inconsistent lock state ]
4.10.0+ #60 Not tainted
inconsistent {IN-SOFTIRQ-W} -> {SOFTIRQ-ON-W} usage.
syz-executor0/5090 [HC0[0]:SC0[0]:HE1:SE1] takes:
(&(&hashinfo->ehash_locks[i])->rlock){+.?...}, at:
[<ffffffff83a6a370>] spin_lock include/linux/spinlock.h:299 [inline]
[<ffffffff83a6a370>] inet_ehash_insert+0x240/0xad0
net/ipv4/inet_hashtables.c:407
{IN-SOFTIRQ-W} state was registered at:
mark_irqflags kernel/locking/lockdep.c:2923 [inline]
__lock_acquire+0xbcf/0x3270 kernel/locking/lockdep.c:3295
lock_acquire+0x241/0x580 kernel/locking/lockdep.c:3753
__raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline]
_raw_spin_lock+0x33/0x50 kernel/locking/spinlock.c:151
inet_ehash_insert+0x240/0xad0 net/ipv4/inet_hashtables.c:407
reqsk_queue_hash_req net/ipv4/inet_connection_sock.c:753 [inline]
inet_csk_reqsk_queue_hash_add+0x1b7/0x2a0 net/ipv4/inet_connection_sock.c:764
tcp_conn_request+0x25cc/0x3310 net/ipv4/tcp_input.c:6399
tcp_v4_conn_request+0x157/0x220 net/ipv4/tcp_ipv4.c:1262
tcp_rcv_state_process+0x802/0x4130 net/ipv4/tcp_input.c:5889
tcp_v4_do_rcv+0x56b/0x940 net/ipv4/tcp_ipv4.c:1433
tcp_v4_rcv+0x2e12/0x3210 net/ipv4/tcp_ipv4.c:1711
ip_local_deliver_finish+0x4ce/0xc40 net/ipv4/ip_input.c:216
ip_local_deliver+0x1ce/0x710 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:492 [inline]
ip_rcv_finish+0xb1d/0x2110 net/ipv4/ip_input.c:396
ip_rcv+0xd90/0x19c0 net/ipv4/ip_input.c:487
__netif_receive_skb_core+0x1ad1/0x3400 net/core/dev.c:4179
__netif_receive_skb+0x2a/0x170 net/core/dev.c:4217
netif_receive_skb_internal+0x1d6/0x430 net/core/dev.c:4245
napi_skb_finish net/core/dev.c:4602 [inline]
napi_gro_receive+0x4e6/0x680 net/core/dev.c:4636
e1000_receive_skb drivers/net/ethernet/intel/e1000/e1000_main.c:4033 [inline]
e1000_clean_rx_irq+0x5e0/0x1490
drivers/net/ethernet/intel/e1000/e1000_main.c:4489
e1000_clean+0xb9a/0x2910 drivers/net/ethernet/intel/e1000/e1000_main.c:3834
napi_poll net/core/dev.c:5171 [inline]
net_rx_action+0xe70/0x1900 net/core/dev.c:5236
irq_exit+0x19e/0x1d0 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:658 [inline]
do_IRQ+0x81/0x1a0 arch/x86/kernel/irq.c:250
ret_from_intr+0x0/0x20
native_safe_halt+0x6/0x10 arch/x86/include/asm/irqflags.h:53
arch_safe_halt arch/x86/include/asm/paravirt.h:98 [inline]
default_idle+0x8f/0x410 arch/x86/kernel/process.c:271
arch_cpu_idle+0xa/0x10 arch/x86/kernel/process.c:262
default_idle_call+0x36/0x60 kernel/sched/idle.c:96
cpuidle_idle_call kernel/sched/idle.c:154 [inline]
do_idle+0x348/0x440 kernel/sched/idle.c:243
cpu_startup_entry+0x18/0x20 kernel/sched/idle.c:345
start_secondary+0x344/0x440 arch/x86/kernel/smpboot.c:272
verify_cpu+0x0/0xfc
irq event stamp: 1741
hardirqs last enabled at (1741): [<ffffffff84d49d77>]
__raw_spin_unlock_irqrestore include/linux/spinlock_api_smp.h:160
[inline]
_raw_spin_unlock_irqrestore+0xf7/0x1a0 kernel/locking/spinlock.c:191
hardirqs last disabled at (1740): [<ffffffff84d4a732>]
__raw_spin_lock_irqsave include/linux/spinlock_api_smp.h:108 [inline]
_raw_spin_lock_irqsave+0xa2/0x110 kernel/locking/spinlock.c:159
softirqs last enabled at (1738): [<ffffffff84d4deff>]
__do_softirq+0x7cf/0xb7d kernel/softirq.c:310
softirqs last disabled at (1571): [<ffffffff84d4b92c>]
Possible unsafe locking scenario:
CPU0
lock(&(&hashinfo->ehash_locks[i])->rlock);
<Interrupt>
*** DEADLOCK ***
1 lock held by syz-executor0/5090:
#0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff83406b43>] lock_sock
sock_setsockopt+0x233/0x1e40 net/core/sock.c:683
stack backtrace:
CPU: 1 PID: 5090 Comm: syz-executor0 Not tainted 4.10.0+ #60
Call Trace:
print_usage_bug+0x3ef/0x450 kernel/locking/lockdep.c:2387
valid_state kernel/locking/lockdep.c:2400 [inline]
mark_lock_irq kernel/locking/lockdep.c:2602 [inline]
mark_lock+0xf30/0x1410 kernel/locking/lockdep.c:3065
mark_irqflags kernel/locking/lockdep.c:2941 [inline]
__lock_acquire+0x6dc/0x3270 kernel/locking/lockdep.c:3295
dccp_v6_conn_request+0xada/0x11b0 net/dccp/ipv6.c:380
dccp_rcv_state_process+0x51e/0x1660 net/dccp/input.c:606
sk_backlog_rcv include/net/sock.h:896 [inline]
__release_sock+0x127/0x3a0 net/core/sock.c:2052
release_sock+0xa5/0x2b0 net/core/sock.c:2539
sock_setsockopt+0x60f/0x1e40 net/core/sock.c:1016
SYSC_setsockopt net/socket.c:1782 [inline]
SyS_setsockopt+0x2fb/0x3a0 net/socket.c:1765
RIP: 0033:0x4458b9
RSP: 002b:00007fe8b26c2b58 EFLAGS: 00000292 ORIG_RAX: 0000000000000036
RAX: ffffffffffffffda RBX: 0000000000000006 RCX: 00000000004458b9
RDX: 000000000000001a RSI: 0000000000000001 RDI: 0000000000000006
RBP: 00000000006e2110 R08: 0000000000000010 R09: 0000000000000000
R10: 00000000208c3000 R11: 0000000000000292 R12: 0000000000708000
R13: 0000000020000000 R14: 0000000000001000 R15: 0000000000000000
Reported-by: Andrey Konovalov <andreyknvl@google.com>
DCCP doesn't purge timewait sockets on network namespace shutdown.
So, after net namespace destroyed we could still have an active timer
which will trigger use after free in tw_timer_handler():
BUG: KASAN: use-after-free in tw_timer_handler+0x4a/0xa0 at addr ffff88010e0d1e10
Read of size 8 by task swapper/1/0
Call Trace:
__asan_load8+0x54/0x90
call_timer_fn+0x127/0x480
expire_timers+0x1db/0x2e0
run_timer_softirq+0x12f/0x2a0
__do_softirq+0x105/0x5b4
irq_exit+0xdd/0xf0
smp_apic_timer_interrupt+0x57/0x70
apic_timer_interrupt+0x90/0xa0
Object at ffff88010e0d1bc0, in cache net_namespace size: 6848
Allocated:
save_stack_trace+0x1b/0x20
kasan_kmalloc+0xee/0x180
kmem_cache_alloc+0x134/0x310
copy_net_ns+0x8d/0x280
create_new_namespaces+0x23f/0x340
unshare_nsproxy_namespaces+0x75/0xf0
SyS_unshare+0x299/0x4f0
entry_SYSCALL_64_fastpath+0x18/0xad
Freed:
kasan_slab_free+0xae/0x180
kmem_cache_free+0xb4/0x350
net_drop_ns+0x3f/0x50
cleanup_net+0x3df/0x450
process_one_work+0x419/0xbb0
worker_thread+0x92/0x850
kthread+0x192/0x1e0
ret_from_fork+0x2e/0x40
Add .exit_batch hook to dccp_v4_ops()/dccp_v6_ops() which will purge
timewait sockets on net namespace destruction and prevent above issue.
Fixes: f2bf415cfed7 ("mib: add net to NET_ADD_STATS_BH")
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
In the current DCCP implementation an skb for a DCCP_PKT_REQUEST packet
is forcibly freed via __kfree_skb in dccp_rcv_state_process if
dccp_v6_conn_request successfully returns.
However, if IPV6_RECVPKTINFO is set on a socket, the address of the skb
is saved to ireq->pktopts and the ref count for skb is incremented in
dccp_v6_conn_request, so skb is still in use. Nevertheless, it gets freed
in dccp_rcv_state_process.
Fix by calling consume_skb instead of doing goto discard and therefore
calling __kfree_skb.
Similar fixes for TCP:
fb7e2399ec17f1004c0e0ccfd17439f8759ede01 [TCP]: skb is unexpectedly freed.
0aea76d35c9651d55bbaf746e7914e5f9ae5a25d tcp: SYN packets are now
simply consumed
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Two trivial overlapping changes conflicts in MPLS and mlx5.
Unlike ipv4, this control socket is shared by all cpus so we cannot use
it as scratchpad area to annotate the mark that we pass to ip6_xmit().
Add a new parameter to ip6_xmit() to indicate the mark. The SCTP socket
family caches the flowi6 structure in the sctp_transport structure, so
we cannot use to carry the mark unless we later on reset it back, which
I discarded since it looks ugly to me.
Fixes: bf99b4ded5f8 ("tcp: fix mark propagation with fwmark_reflect enabled")
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
The only difference between inet6_csk_bind_conflict and inet_csk_bind_conflict
is how they check the rcv_saddr, so delete this call back and simply
change inet_csk_bind_conflict to call inet_rcv_saddr_equal.
Signed-off-by: Josef Bacik <jbacik@fb.com>
