[ Upstream commit e0aa67709f89d08c8d8e5bdd9e0b649df61d0090 ]
When a dual stack dccp listener accepts an ipv4 flow,
it should not attempt to use an ipv6 header or
inet6_iif() helper.
Fixes: 3df80d9320bc ("[DCCP]: Introduce DCCPv6")
Similarly to commit 276bdb82dedb ("dccp: check ccid before dereferencing")
it is wise to test for a NULL ccid.
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 16 Comm: ksoftirqd/1 Not tainted 5.0.0-rc3+ #37
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:ccid_hc_tx_parse_options net/dccp/ccid.h:205 [inline]
RIP: 0010:dccp_parse_options+0x8d9/0x12b0 net/dccp/options.c:233
Code: c5 0f b6 75 b3 80 38 00 0f 85 d6 08 00 00 48 b9 00 00 00 00 00 fc ff df 48 8b 45 b8 4c 8b b8 f8 07 00 00 4c 89 f8 48 c1 e8 03 <80> 3c 08 00 0f 85 95 08 00 00 48 b8 00 00 00 00 00 fc ff df 4d 8b
kobject: 'loop5' (0000000080f78fc1): kobject_uevent_env
RSP: 0018:ffff8880a94df0b8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8880858ac723 RCX: dffffc0000000000
RDX: 0000000000000100 RSI: 0000000000000007 RDI: 0000000000000001
RBP: ffff8880a94df140 R08: 0000000000000001 R09: ffff888061b83a80
R10: ffffed100c370752 R11: ffff888061b83a97 R12: 0000000000000026
R13: 0000000000000001 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff8880ae700000(0000) knlGS:0000000000000000
CR2: 00007f0defa33518 CR3: 000000008db5e000 CR4: 00000000001406e0
kobject: 'loop5' (0000000080f78fc1): fill_kobj_path: path = '/devices/virtual/block/loop5'
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
dccp_rcv_state_process+0x2b6/0x1af6 net/dccp/input.c:654
dccp_v4_do_rcv+0x100/0x190 net/dccp/ipv4.c:688
sk_backlog_rcv include/net/sock.h:936 [inline]
__sk_receive_skb+0x3a9/0xea0 net/core/sock.c:473
dccp_v4_rcv+0x10cb/0x1f80 net/dccp/ipv4.c:880
ip_protocol_deliver_rcu+0xb6/0xa20 net/ipv4/ip_input.c:208
ip_local_deliver_finish+0x23b/0x390 net/ipv4/ip_input.c:234
NF_HOOK include/linux/netfilter.h:289 [inline]
NF_HOOK include/linux/netfilter.h:283 [inline]
ip_local_deliver+0x1f0/0x740 net/ipv4/ip_input.c:255
dst_input include/net/dst.h:450 [inline]
ip_rcv_finish+0x1f4/0x2f0 net/ipv4/ip_input.c:414
ip_rcv+0xed/0x620 net/ipv4/ip_input.c:524
__netif_receive_skb_one_core+0x160/0x210 net/core/dev.c:4973
__netif_receive_skb+0x2c/0x1c0 net/core/dev.c:5083
process_backlog+0x206/0x750 net/core/dev.c:5923
napi_poll net/core/dev.c:6346 [inline]
net_rx_action+0x76d/0x1930 net/core/dev.c:6412
__do_softirq+0x30b/0xb11 kernel/softirq.c:292
run_ksoftirqd kernel/softirq.c:654 [inline]
run_ksoftirqd+0x8e/0x110 kernel/softirq.c:646
smpboot_thread_fn+0x6ab/0xa10 kernel/smpboot.c:164
kthread+0x357/0x430 kernel/kthread.c:246
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:352
Modules linked in:
---[ end trace 58a0ba03bea2c376 ]---
CR2: 00007f0defa33518 CR3: 0000000009871000 CR4: 00000000001406e0
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk>
totalram_pages and totalhigh_pages are made static inline function.
Main motivation was that managed_page_count_lock handling was complicating
things. It was discussed in length here,
https://lore.kernel.org/patchwork/patch/995739/#1181785 So it seemes
better to remove the lock and convert variables to atomic, with preventing
poteintial store-to-read tearing as a bonus.
[akpm@linux-foundation.org: coding style fixes]
Link: http://lkml.kernel.org/r/1542090790-21750-4-git-send-email-arunks@codeaurora.org
Signed-off-by: Arun KS <arunks@codeaurora.org>
Suggested-by: Michal Hocko <mhocko@suse.com>
Suggested-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Reviewed-by: Pavel Tatashin <pasha.tatashin@soleen.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: David Hildenbrand <david@redhat.com>
Patch series "mm: convert totalram_pages, totalhigh_pages and managed
pages to atomic", v5.
This series converts totalram_pages, totalhigh_pages and
zone->managed_pages to atomic variables.
totalram_pages, zone->managed_pages and totalhigh_pages updates are
protected by managed_page_count_lock, but readers never care about it.
Convert these variables to atomic to avoid readers potentially seeing a
store tear.
https://lore.kernel.org/patchwork/patch/995739/#1181785 It seemes better
to remove the lock and convert variables to atomic. With the change,
preventing poteintial store-to-read tearing comes as a bonus.
This patch (of 4):
This is in preparation to a later patch which converts totalram_pages and
zone->managed_pages to atomic variables. Please note that re-reading the
value might lead to a different value and as such it could lead to
unexpected behavior. There are no known bugs as a result of the current
code but it is better to prevent from them in principle.
Link: http://lkml.kernel.org/r/1542090790-21750-2-git-send-email-arunks@codeaurora.org
Reviewed-by: David Hildenbrand <david@redhat.com>
Patch eedbbb0d98b2 "net: dccp: initialize (addr,port) ..."
added calling to inet_hashinfo2_init() from dccp_init().
However, inet_hashinfo2_init() is marked as __init(), and
thus the kernel panics when dccp is loaded as module. Removing
__init() tag from inet_hashinfo2_init() is not feasible because
it calls into __init functions in mm.
This patch adds inet_hashinfo2_init_mod() function that can
be called after the init phase is done; changes dccp_init() to
call the new function; un-marks inet_hashinfo2_init() as
exported.
Fixes: eedbbb0d98b2 ("net: dccp: initialize (addr,port) ...")
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Peter Oskolkov <posk@google.com>
Commit d9fbc7f6431f "net: tcp: prefer listeners bound to an address"
removes port-only listener lookups. This caused segfaults in DCCP
lookups because DCCP did not initialize the (addr,port) hashtable.
This patch adds said initialization.
The only non-trivial issue here is the size of the new hashtable.
It seemed reasonable to make it match the size of the port-only
hashtable (= INET_LHTABLE_SIZE) that was used previously. Other
parameters to inet_hashinfo2_init() match those used in TCP.
V2 changes: marked inet_hashinfo2_init as an exported symbol
so that DCCP compiles when configured as a module.
Tested: syzcaller issues fixed; the second patch in the patchset
tests that DCCP lookups work correctly.
Fixes: d9fbc7f6431f "net: tcp: prefer listeners bound to an address"
Reported-by: syzcaller <syzkaller@googlegroups.com>
This reverts commit ec49d83f245453515a9b6e88324e27bbcb69fbae.
Cause build failures when DCCP is modular.
ERROR: "inet_hashinfo2_init" [net/dccp/dccp.ko] undefined!
We'll need this to handle ICMP errors for tunnels without a sending socket
(i.e. FoU and GUE). There, we might have to look up different types of IP
tunnels, registered as network protocols, before we get a match, so we
want this for the error handlers of IPPROTO_IPIP and IPPROTO_IPV6 in both
inet_protos and inet6_protos. These error codes will be used in the next
patch.
For consistency, return sensible error codes in protocol error handlers
whenever handlers can't handle errors because, even if valid, they don't
match a protocol or any of its states.
This has no effect on existing error handling paths.
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
Reviewed-by: Sabrina Dubroca <sd@queasysnail.net>
Set the backlog earlier in inet_dccp_listen() and inet_listen(),
then we can avoid the redundant setting.
Signed-off-by: Yafang Shao <laoar.shao@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
This reverts commit dd979b4df817e9976f18fb6f9d134d6bc4a3c317.
This broke tcp_poll for SMC fallback: An AF_SMC socket establishes an
internal TCP socket for the initial handshake with the remote peer.
Whenever the SMC connection can not be established this TCP socket is
used as a fallback. All socket operations on the SMC socket are then
forwarded to the TCP socket. In case of poll, the file->private_data
pointer references the SMC socket because the TCP socket has no file
assigned. This causes tcp_poll to wait on the wrong socket.
Signed-off-by: Karsten Graul <kgraul@linux.ibm.com>
Timer handlers do not imply rcu_read_lock(), so my recent fix
triggered a LOCKDEP warning when SYNACK is retransmit.
Lets add rcu_read_lock()/rcu_read_unlock() pairs around ireq->ireq_opt
usages instead of guessing what is done by callers, since it is
not worth the pain.
Get rid of ireq_opt_deref() helper since it hides the logic
without real benefit, since it is now a standard rcu_dereference().
Fixes: 1ad98e9d1bdf ("tcp/dccp: fix lockdep issue when SYN is backlogged")
Reported-by: Willem de Bruijn <willemb@google.com>
In normal SYN processing, packets are handled without listener
lock and in RCU protected ingress path.
But syzkaller is known to be able to trick us and SYN
packets might be processed in process context, after being
queued into socket backlog.
In commit 06f877d613be ("tcp/dccp: fix other lockdep splats
accessing ireq_opt") I made a very stupid fix, that happened
to work mostly because of the regular path being RCU protected.
Really the thing protecting ireq->ireq_opt is RCU read lock,
and the pseudo request refcnt is not relevant.
This patch extends what I did in commit 449809a66c1d ("tcp/dccp:
block BH for SYN processing") by adding an extra rcu_read_{lock|unlock}
pair in the paths that might be taken when processing SYN from
socket backlog (thus possibly in process context)
Fixes: 06f877d613be ("tcp/dccp: fix other lockdep splats accessing ireq_opt")
Overlapping changes in RXRPC, changing to ktime_get_seconds() whilst
adding some tracepoints.
The shift of 'cwnd' with '(now - hc->tx_lsndtime) / hc->tx_rto' value
can lead to undefined behavior [1].
In order to fix this use a gradual shift of the window with a 'while'
loop, similar to what tcp_cwnd_restart() is doing.
When comparing delta and RTO there is a minor difference between TCP
and DCCP, the last one also invokes dccp_cwnd_restart() and reduces
'cwnd' if delta equals RTO. That case is preserved in this change.
[1]:
[40850.963623] UBSAN: Undefined behaviour in net/dccp/ccids/ccid2.c:237:7
[40851.043858] shift exponent 67 is too large for 32-bit type 'unsigned int'
[40851.127163] CPU: 3 PID: 15940 Comm: netstress Tainted: G W E 4.18.0-rc7.x86_64 #1
[40851.377176] Call Trace:
[40851.408503] dump_stack+0xf1/0x17b
[40851.451331] ? show_regs_print_info+0x5/0x5
[40851.503555] ubsan_epilogue+0x9/0x7c
[40851.548363] __ubsan_handle_shift_out_of_bounds+0x25b/0x2b4
[40851.617109] ? __ubsan_handle_load_invalid_value+0x18f/0x18f
[40851.686796] ? xfrm4_output_finish+0x80/0x80
[40851.739827] ? lock_downgrade+0x6d0/0x6d0
[40851.789744] ? xfrm4_prepare_output+0x160/0x160
[40851.845912] ? ip_queue_xmit+0x810/0x1db0
[40851.895845] ? ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40851.963530] ccid2_hc_tx_packet_sent+0xd36/0x10a0 [dccp]
[40852.029063] dccp_xmit_packet+0x1d3/0x720 [dccp]
[40852.086254] dccp_write_xmit+0x116/0x1d0 [dccp]
[40852.142412] dccp_sendmsg+0x428/0xb20 [dccp]
[40852.195454] ? inet_dccp_listen+0x200/0x200 [dccp]
[40852.254833] ? sched_clock+0x5/0x10
[40852.298508] ? sched_clock+0x5/0x10
[40852.342194] ? inet_create+0xdf0/0xdf0
[40852.388988] sock_sendmsg+0xd9/0x160
Fixes: 113ced1f52e5 ("dccp ccid-2: Perform congestion-window validation")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
The wait_address argument is always directly derived from the filp
argument, so remove it.
The poll() changes were not well thought out, and completely
unexplained. They also caused a huge performance regression, because
"->poll()" was no longer a trivial file operation that just called down
to the underlying file operations, but instead did at least two indirect
calls.
Indirect calls are sadly slow now with the Spectre mitigation, but the
performance problem could at least be largely mitigated by changing the
"->get_poll_head()" operation to just have a per-file-descriptor pointer
to the poll head instead. That gets rid of one of the new indirections.
But that doesn't fix the new complexity that is completely unwarranted
for the regular case. The (undocumented) reason for the poll() changes
was some alleged AIO poll race fixing, but we don't make the common case
slower and more complex for some uncommon special case, so this all
really needs way more explanations and most likely a fundamental
redesign.
[ This revert is a revert of about 30 different commits, not reverted
individually because that would just be unnecessarily messy - Linus ]
To compute delays, better not use time of the day which can
be changed by admins or malicious programs.
Also change ccid3_first_li() to use s64 type for delta variable
to avoid potential overflows.
Cc: dccp@vger.kernel.org
On fast hosts or malicious bots, we trigger a DCCP_BUG() which
seems excessive.
syzbot reported :
BUG: delta (-6195) <= 0 at net/dccp/ccids/ccid3.c:628/ccid3_hc_rx_send_feedback()
CPU: 1 PID: 18 Comm: ksoftirqd/1 Not tainted 4.18.0-rc1+ #112
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c9/0x2b4 lib/dump_stack.c:113
ccid3_hc_rx_send_feedback net/dccp/ccids/ccid3.c:628 [inline]
ccid3_hc_rx_packet_recv.cold.16+0x38/0x71 net/dccp/ccids/ccid3.c:793
ccid_hc_rx_packet_recv net/dccp/ccid.h:185 [inline]
dccp_deliver_input_to_ccids+0xf0/0x280 net/dccp/input.c:180
dccp_rcv_established+0x87/0xb0 net/dccp/input.c:378
dccp_v4_do_rcv+0x153/0x180 net/dccp/ipv4.c:654
sk_backlog_rcv include/net/sock.h:914 [inline]
__sk_receive_skb+0x3ba/0xd80 net/core/sock.c:517
dccp_v4_rcv+0x10f9/0x1f58 net/dccp/ipv4.c:875
ip_local_deliver_finish+0x2eb/0xda0 net/ipv4/ip_input.c:215
NF_HOOK include/linux/netfilter.h:287 [inline]
ip_local_deliver+0x1e9/0x750 net/ipv4/ip_input.c:256
ip_rcv_finish+0x823/0x2220 net/ipv4/ip_input.c:396
ip_rcv+0xa18/0x1284 net/ipv4/ip_input.c:492
__netif_receive_skb_core+0x2488/0x3680 net/core/dev.c:4628
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:4693
process_backlog+0x219/0x760 net/core/dev.c:5373
napi_poll net/core/dev.c:5771 [inline]
net_rx_action+0x7da/0x1980 net/core/dev.c:5837
__do_softirq+0x2e8/0xb17 kernel/softirq.c:284
run_ksoftirqd+0x86/0x100 kernel/softirq.c:645
smpboot_thread_fn+0x417/0x870 kernel/smpboot.c:164
kthread+0x345/0x410 kernel/kthread.c:240
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
patch replaces cases of:
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
as well as handling cases of:
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kmalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kmalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kmalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kmalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(u8) * COUNT
+ COUNT
kmalloc(
- sizeof(__u8) * COUNT
+ COUNT
kmalloc(
- sizeof(char) * COUNT
+ COUNT
kmalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_CONST
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kmalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kmalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kmalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kmalloc(
- sizeof(TYPE) * COUNT * STRIDE
kmalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kmalloc(
- sizeof(THING) * (COUNT) * STRIDE
kmalloc(
- sizeof(THING) * COUNT * (STRIDE)
kmalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kmalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kmalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kmalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kmalloc(
- COUNT * (STRIDE) * SIZE
kmalloc(
- COUNT * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * SIZE
kmalloc(
- COUNT * (STRIDE) * (SIZE)
kmalloc(
- (COUNT) * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * (SIZE)
kmalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kmalloc(
- (E1) * (E2) * E3
kmalloc(
- (E1) * (E2) * (E3)
kmalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
Pull networking updates from David Miller:
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
Tested: 'git grep tw_timeout' comes up empty and it builds :-)
Signed-off-by: Maciej Żenczykowski <maze@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Pull aio updates from Al Viro:
"Majority of AIO stuff this cycle. aio-fsync and aio-poll, mostly.
The only thing I'm holding back for a day or so is Adam's aio ioprio -
his last-minute fixup is trivial (missing stub in !CONFIG_BLOCK case),
but let it sit in -next for decency sake..."
* 'work.aio-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
aio: sanitize the limit checking in io_submit(2)
aio: fold do_io_submit() into callers
aio: shift copyin of iocb into io_submit_one()
aio_read_events_ring(): make a bit more readable
aio: all callers of aio_{read,write,fsync,poll} treat 0 and -EIOCBQUEUED the same way
aio: take list removal to (some) callers of aio_complete()
aio: add missing break for the IOCB_CMD_FDSYNC case
random: convert to ->poll_mask
timerfd: convert to ->poll_mask
eventfd: switch to ->poll_mask
pipe: convert to ->poll_mask
crypto: af_alg: convert to ->poll_mask
net/rxrpc: convert to ->poll_mask
net/iucv: convert to ->poll_mask
net/phonet: convert to ->poll_mask
net/nfc: convert to ->poll_mask
net/caif: convert to ->poll_mask
net/bluetooth: convert to ->poll_mask
net/sctp: convert to ->poll_mask
net/tipc: convert to ->poll_mask
Syzbot reported the use-after-free in timer_is_static_object() [1].
This can happen because the structure for the rto timer (ccid2_hc_tx_sock)
is removed in dccp_disconnect(), and ccid2_hc_tx_rto_expire() can be
called after that.
The report [1] is similar to the one in commit 120e9dabaf55 ("dccp:
defer ccid_hc_tx_delete() at dismantle time"). And the fix is the same,
delay freeing ccid2_hc_tx_sock structure, so that it is freed in
dccp_sk_destruct().
[1]
BUG: KASAN: use-after-free in timer_is_static_object+0x80/0x90
kernel/time/timer.c:607
Read of size 8 at addr ffff8801bebb5118 by task syz-executor2/25299
CPU: 1 PID: 25299 Comm: syz-executor2 Not tainted 4.17.0-rc5+ #54
Google 01/01/2011
Call Trace:
<IRQ>
dump_stack+0x1b9/0x294 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
timer_is_static_object+0x80/0x90 kernel/time/timer.c:607
debug_object_activate+0x2d9/0x670 lib/debugobjects.c:508
debug_timer_activate kernel/time/timer.c:709 [inline]
debug_activate kernel/time/timer.c:764 [inline]
__mod_timer kernel/time/timer.c:1041 [inline]
mod_timer+0x4d3/0x13b0 kernel/time/timer.c:1102
sk_reset_timer+0x22/0x60 net/core/sock.c:2742
ccid2_hc_tx_rto_expire+0x587/0x680 net/dccp/ccids/ccid2.c:147
call_timer_fn+0x230/0x940 kernel/time/timer.c:1326
expire_timers kernel/time/timer.c:1363 [inline]
__run_timers+0x79e/0xc50 kernel/time/timer.c:1666
run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692
__do_softirq+0x2e0/0xaf5 kernel/softirq.c:285
invoke_softirq kernel/softirq.c:365 [inline]
irq_exit+0x1d1/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:525 [inline]
smp_apic_timer_interrupt+0x17e/0x710 arch/x86/kernel/apic/apic.c:1052
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:863
</IRQ>
Allocated by task 25374:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490
kmem_cache_alloc+0x12e/0x760 mm/slab.c:3554
ccid_new+0x25b/0x3e0 net/dccp/ccid.c:151
dccp_hdlr_ccid+0x27/0x150 net/dccp/feat.c:44
__dccp_feat_activate+0x184/0x270 net/dccp/feat.c:344
dccp_feat_activate_values+0x3a7/0x819 net/dccp/feat.c:1538
dccp_create_openreq_child+0x472/0x610 net/dccp/minisocks.c:128
dccp_v4_request_recv_sock+0x12c/0xca0 net/dccp/ipv4.c:408
dccp_v6_request_recv_sock+0x125d/0x1f10 net/dccp/ipv6.c:415
dccp_check_req+0x455/0x6a0 net/dccp/minisocks.c:197
dccp_v4_rcv+0x7b8/0x1f3f net/dccp/ipv4.c:841
ip_local_deliver_finish+0x2e3/0xd80 net/ipv4/ip_input.c:215
NF_HOOK include/linux/netfilter.h:288 [inline]
ip_local_deliver+0x1e1/0x720 net/ipv4/ip_input.c:256
ip_rcv_finish+0x81b/0x2200 net/ipv4/ip_input.c:396
ip_rcv+0xb70/0x143d net/ipv4/ip_input.c:492
__netif_receive_skb_core+0x26f5/0x3630 net/core/dev.c:4592
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:4657
process_backlog+0x219/0x760 net/core/dev.c:5337
napi_poll net/core/dev.c:5735 [inline]
net_rx_action+0x7b7/0x1930 net/core/dev.c:5801
Freed by task 25374:
__kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kmem_cache_free+0x86/0x2d0 mm/slab.c:3756
ccid_hc_tx_delete+0xc3/0x100 net/dccp/ccid.c:190
dccp_disconnect+0x130/0xc66 net/dccp/proto.c:286
dccp_close+0x3bc/0xe60 net/dccp/proto.c:1045
inet_release+0x104/0x1f0 net/ipv4/af_inet.c:427
inet6_release+0x50/0x70 net/ipv6/af_inet6.c:460
sock_release+0x96/0x1b0 net/socket.c:594
sock_close+0x16/0x20 net/socket.c:1149
__fput+0x34d/0x890 fs/file_table.c:209
____fput+0x15/0x20 fs/file_table.c:243
task_work_run+0x1e4/0x290 kernel/task_work.c:113
tracehook_notify_resume include/linux/tracehook.h:191 [inline]
exit_to_usermode_loop+0x2bd/0x310 arch/x86/entry/common.c:166
prepare_exit_to_usermode arch/x86/entry/common.c:196 [inline]
syscall_return_slowpath arch/x86/entry/common.c:265 [inline]
do_syscall_64+0x6ac/0x800 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
The buggy address belongs to the object at ffff8801bebb4cc0
which belongs to the cache ccid2_hc_tx_sock of size 1240
The buggy address is located 1112 bytes inside of
1240-byte region [ffff8801bebb4cc0, ffff8801bebb5198)
The buggy address belongs to the page:
page:ffffea0006faed00 count:1 mapcount:0 mapping:ffff8801bebb41c0
index:0xffff8801bebb5240 compound_mapcount: 0
flags: 0x2fffc0000008100(slab|head)
raw: 02fffc0000008100 ffff8801bebb41c0 ffff8801bebb5240 0000000100000003
raw: ffff8801cdba3138 ffffea0007634120 ffff8801cdbaab40 0000000000000000
page dumped because: kasan: bad access detected
Reported-by: syzbot+5d47e9ec91a6f15dbd6f@syzkaller.appspotmail.com
syzbot reported a crash in tasklet_action_common() caused by dccp.
dccp needs to make sure socket wont disappear before tasklet handler
has completed.
This patch takes a reference on the socket when arming the tasklet,
and moves the sock_put() from dccp_write_xmit_timer() to dccp_write_xmitlet()
kernel BUG at kernel/softirq.c:514!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 17 Comm: ksoftirqd/1 Not tainted 4.17.0-rc3+ #30
RIP: 0010:tasklet_action_common.isra.19+0x6db/0x700 kernel/softirq.c:515
RSP: 0018:ffff8801d9b3faf8 EFLAGS: 00010246
dccp_close: ABORT with 65423 bytes unread
RAX: 1ffff1003b367f6b RBX: ffff8801daf1f3f0 RCX: 0000000000000000
RDX: ffff8801cf895498 RSI: 0000000000000004 RDI: 0000000000000000
RBP: ffff8801d9b3fc40 R08: ffffed0039f12a95 R09: ffffed0039f12a94
R10: ffffed0039f12a94 R11: ffff8801cf8954a3 R12: 0000000000000000
R13: ffff8801d9b3fc18 R14: dffffc0000000000 R15: ffff8801cf895490
FS: 0000000000000000(0000) GS:ffff8801daf00000(0000) knlGS:0000000000000000
CR2: 0000001b2bc28000 CR3: 00000001a08a9000 CR4: 00000000001406e0
Call Trace:
tasklet_action+0x1d/0x20 kernel/softirq.c:533
run_ksoftirqd+0x86/0x100 kernel/softirq.c:646
kthread+0x345/0x410 kernel/kthread.c:238
Code: 48 8b 85 e8 fe ff ff 48 8b 95 f0 fe ff ff e9 94 fb ff ff 48 89 95 f0 fe ff ff e8 81 53 6e 00 48 8b 95 f0 fe ff ff e9 62 fb ff ff <0f> 0b 48 89 cf 48 89 8d e8 fe ff ff e8 64 53 6e 00 48 8b 8d e8
RIP: tasklet_action_common.isra.19+0x6db/0x700 kernel/softirq.c:515 RSP: ffff8801d9b3faf8
Fixes: dc841e30eaea ("dccp: Extend CCID packet dequeueing interface")
syzbot reported an uninit-value read of skb->mark in iptable_mangle_hook()
Thanks to the nice report, I tracked the problem to dccp not caring
of ireq->ir_mark for passive sessions.
BUG: KMSAN: uninit-value in ipt_mangle_out net/ipv4/netfilter/iptable_mangle.c:66 [inline]
BUG: KMSAN: uninit-value in iptable_mangle_hook+0x5e5/0x720 net/ipv4/netfilter/iptable_mangle.c:84
CPU: 0 PID: 5300 Comm: syz-executor3 Not tainted 4.16.0+ #81
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:53
kmsan_report+0x142/0x240 mm/kmsan/kmsan.c:1067
__msan_warning_32+0x6c/0xb0 mm/kmsan/kmsan_instr.c:676
nf_hook_entry_hookfn include/linux/netfilter.h:120 [inline]
nf_hook_slow+0x158/0x3d0 net/netfilter/core.c:483
nf_hook include/linux/netfilter.h:243 [inline]
__ip_local_out net/ipv4/ip_output.c:113 [inline]
ip_local_out net/ipv4/ip_output.c:122 [inline]
ip_queue_xmit+0x1d21/0x21c0 net/ipv4/ip_output.c:504
dccp_transmit_skb+0x15eb/0x1900 net/dccp/output.c:142
dccp_xmit_packet+0x814/0x9e0 net/dccp/output.c:281
dccp_write_xmit+0x20f/0x480 net/dccp/output.c:363
dccp_sendmsg+0x12ca/0x12d0 net/dccp/proto.c:818
inet_sendmsg+0x48d/0x740 net/ipv4/af_inet.c:764
sock_sendmsg_nosec net/socket.c:630 [inline]
sock_sendmsg net/socket.c:640 [inline]
___sys_sendmsg+0xec0/0x1310 net/socket.c:2046
__sys_sendmsg net/socket.c:2080 [inline]
SYSC_sendmsg+0x2a3/0x3d0 net/socket.c:2091
SyS_sendmsg+0x54/0x80 net/socket.c:2087
do_syscall_64+0x309/0x430 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
RIP: 0033:0x455259
RSP: 002b:00007f1a4473dc68 EFLAGS: 00000246 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00007f1a4473e6d4 RCX: 0000000000455259
RDX: 0000000000000000 RSI: 0000000020b76fc8 RDI: 0000000000000015
RBP: 000000000072bea0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000ffffffff
R13: 00000000000004f0 R14: 00000000006fa720 R15: 0000000000000000
Uninit was stored to memory at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:278 [inline]
kmsan_save_stack mm/kmsan/kmsan.c:293 [inline]
kmsan_internal_chain_origin+0x12b/0x210 mm/kmsan/kmsan.c:684
__msan_chain_origin+0x69/0xc0 mm/kmsan/kmsan_instr.c:521
ip_queue_xmit+0x1e35/0x21c0 net/ipv4/ip_output.c:502
inet_csk_clone_lock+0x503/0x580 net/ipv4/inet_connection_sock.c:797
dccp_create_openreq_child+0x7f/0x890 net/dccp/minisocks.c:92
dccp_v4_request_recv_sock+0x22c/0xe90 net/dccp/ipv4.c:408
dccp_v6_request_recv_sock+0x290/0x2000 net/dccp/ipv6.c:414
dccp_check_req+0x7b9/0x8f0 net/dccp/minisocks.c:197
dccp_v4_rcv+0x12e4/0x2630 net/dccp/ipv4.c:840
ip_local_deliver_finish+0x6ed/0xd40 net/ipv4/ip_input.c:216
ip_local_deliver+0x43c/0x4e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:449 [inline]
ip_rcv_finish+0x1253/0x16d0 net/ipv4/ip_input.c:397
ip_rcv+0x119d/0x16f0 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x47cf/0x4a80 net/core/dev.c:4562
__netif_receive_skb net/core/dev.c:4627 [inline]
process_backlog+0x62d/0xe20 net/core/dev.c:5307
napi_poll net/core/dev.c:5705 [inline]
net_rx_action+0x7c1/0x1a70 net/core/dev.c:5771
__do_softirq+0x56d/0x93d kernel/softirq.c:285
Uninit was created at:
kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:188
kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:314
kmem_cache_alloc+0xaab/0xb90 mm/slub.c:2756
reqsk_alloc include/net/request_sock.h:88 [inline]
inet_reqsk_alloc+0xc4/0x7f0 net/ipv4/tcp_input.c:6145
dccp_v4_conn_request+0x5cc/0x1770 net/dccp/ipv4.c:600
dccp_v6_conn_request+0x299/0x1880 net/dccp/ipv6.c:317
dccp_rcv_state_process+0x2ea/0x2410 net/dccp/input.c:612
dccp_v4_do_rcv+0x229/0x340 net/dccp/ipv4.c:682
dccp_v6_do_rcv+0x16d/0x1220 net/dccp/ipv6.c:578
sk_backlog_rcv include/net/sock.h:908 [inline]
__sk_receive_skb+0x60e/0xf20 net/core/sock.c:513
dccp_v4_rcv+0x24d4/0x2630 net/dccp/ipv4.c:874
dccp_disconnect() sets 'dp->dccps_hc_tx_ccid' tx handler to NULL,
therefore if DCCP socket is disconnected and dccp_sendmsg() is
called after it, it will cause a NULL pointer dereference in
dccp_write_xmit().
This crash and the reproducer was reported by syzbot. Looks like
it is reproduced if commit 69c64866ce07 ("dccp: CVE-2017-8824:
use-after-free in DCCP code") is applied.
Reported-by: syzbot+f99ab3887ab65d70f816@syzkaller.appspotmail.com
This is the mindless scripted replacement of kernel use of POLL*
variables as described by Al, done by this script:
for V in IN OUT PRI ERR RDNORM RDBAND WRNORM WRBAND HUP RDHUP NVAL MSG; do
L=`git grep -l -w POLL$V | grep -v '^t' | grep -v /um/ | grep -v '^sa' | grep -v '/poll.h$'|grep -v '^D'`
for f in $L; do sed -i "-es/^\([^\"]*\)\(\<POLL$V\>\)/\\1E\\2/" $f; done
done
with de-mangling cleanups yet to come.
NOTE! On almost all architectures, the EPOLL* constants have the same
values as the POLL* constants do. But they keyword here is "almost".
For various bad reasons they aren't the same, and epoll() doesn't
actually work quite correctly in some cases due to this on Sparc et al.
The next patch from Al will sort out the final differences, and we
should be all done.
Scripted-by: Al Viro <viro@zeniv.linux.org.uk>
1) Significantly shrink the core networking routing structures. Result
of http://vger.kernel.org/~davem/seoul2017_netdev_keynote.pdf
2) Add netdevsim driver for testing various offloads, from Jakub
Kicinski.
3) Support cross-chip FDB operations in DSA, from Vivien Didelot.
4) Add a 2nd listener hash table for TCP, similar to what was done for
UDP. From Martin KaFai Lau.
5) Add eBPF based queue selection to tun, from Jason Wang.
6) Lockless qdisc support, from John Fastabend.
7) SCTP stream interleave support, from Xin Long.
8) Smoother TCP receive autotuning, from Eric Dumazet.
9) Lots of erspan tunneling enhancements, from William Tu.
10) Add true function call support to BPF, from Alexei Starovoitov.
11) Add explicit support for GRO HW offloading, from Michael Chan.
12) Support extack generation in more netlink subsystems. From Alexander
Aring, Quentin Monnet, and Jakub Kicinski.
13) Add 1000BaseX, flow control, and EEE support to mvneta driver. From
Russell King.
14) Add flow table abstraction to netfilter, from Pablo Neira Ayuso.
15) Many improvements and simplifications to the NFP driver bpf JIT,
from Jakub Kicinski.
16) Support for ipv6 non-equal cost multipath routing, from Ido
Schimmel.
17) Add resource abstration to devlink, from Arkadi Sharshevsky.
18) Packet scheduler classifier shared filter block support, from Jiri
Pirko.
19) Avoid locking in act_csum, from Davide Caratti.
20) devinet_ioctl() simplifications from Al viro.
21) More TCP bpf improvements from Lawrence Brakmo.
22) Add support for onlink ipv6 route flag, similar to ipv4, from David
Ahern.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1925 commits)
tls: Add support for encryption using async offload accelerator
ip6mr: fix stale iterator
net/sched: kconfig: Remove blank help texts
openvswitch: meter: Use 64-bit arithmetic instead of 32-bit
tcp_nv: fix potential integer overflow in tcpnv_acked
r8169: fix RTL8168EP take too long to complete driver initialization.
qmi_wwan: Add support for Quectel EP06
rtnetlink: enable IFLA_IF_NETNSID for RTM_NEWLINK
ipmr: Fix ptrdiff_t print formatting
ibmvnic: Wait for device response when changing MAC
qlcnic: fix deadlock bug
tcp: release sk_frag.page in tcp_disconnect
ipv4: Get the address of interface correctly.
net_sched: gen_estimator: fix lockdep splat
net: macb: Handle HRESP error
net/mlx5e: IPoIB, Fix copy-paste bug in flow steering refactoring
ipv6: addrconf: break critical section in addrconf_verify_rtnl()
ipv6: change route cache aging logic
i40e/i40evf: Update DESC_NEEDED value to reflect larger value
bnxt_en: cleanup DIM work on device shutdown
Pull poll annotations from Al Viro:
"This introduces a __bitwise type for POLL### bitmap, and propagates
the annotations through the tree. Most of that stuff is as simple as
'make ->poll() instances return __poll_t and do the same to local
variables used to hold the future return value'.
Some of the obvious brainos found in process are fixed (e.g. POLLIN
misspelled as POLL_IN). At that point the amount of sparse warnings is
low and most of them are for genuine bugs - e.g. ->poll() instance
deciding to return -EINVAL instead of a bitmap. I hadn't touched those
in this series - it's large enough as it is.
Another problem it has caught was eventpoll() ABI mess; select.c and
eventpoll.c assumed that corresponding POLL### and EPOLL### were
equal. That's true for some, but not all of them - EPOLL### are
arch-independent, but POLL### are not.
The last commit in this series separates userland POLL### values from
the (now arch-independent) kernel-side ones, converting between them
in the few places where they are copied to/from userland. AFAICS, this
is the least disruptive fix preserving poll(2) ABI and making epoll()
work on all architectures.
As it is, it's simply broken on sparc - try to give it EPOLLWRNORM and
it will trigger only on what would've triggered EPOLLWRBAND on other
architectures. EPOLLWRBAND and EPOLLRDHUP, OTOH, are never triggered
at all on sparc. With this patch they should work consistently on all
architectures"
* 'misc.poll' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits)
make kernel-side POLL... arch-independent
eventpoll: no need to mask the result of epi_item_poll() again
eventpoll: constify struct epoll_event pointers
debugging printk in sg_poll() uses %x to print POLL... bitmap
annotate poll(2) guts
9p: untangle ->poll() mess
->si_band gets POLL... bitmap stored into a user-visible long field
ring_buffer_poll_wait() return value used as return value of ->poll()
the rest of drivers/*: annotate ->poll() instances
media: annotate ->poll() instances
fs: annotate ->poll() instances
ipc, kernel, mm: annotate ->poll() instances
net: annotate ->poll() instances
apparmor: annotate ->poll() instances
tomoyo: annotate ->poll() instances
sound: annotate ->poll() instances
acpi: annotate ->poll() instances
crypto: annotate ->poll() instances
block: annotate ->poll() instances
x86: annotate ->poll() instances
ccid2_hc_tx_rto_expire() timer callback always restarts the timer
again and can run indefinitely (unless it is stopped outside), and after
commit 120e9dabaf55 ("dccp: defer ccid_hc_tx_delete() at dismantle time"),
which moved ccid_hc_tx_delete() (also includes sk_stop_timer()) from
dccp_destroy_sock() to sk_destruct(), this started to happen quite often.
The timer prevents releasing the socket, as a result, sk_destruct() won't
be called.
Found with LTP/dccp_ipsec tests running on the bonding device,
which later couldn't be unloaded after the tests were completed:
unregister_netdevice: waiting for bond0 to become free. Usage count = 148
Fixes: 2a91aa396739 ("[DCCP] CCID2: Initial CCID2 (TCP-Like) implementation")
Remove DCCP probe module since jprobe has been deprecated.
That function is now replaced by dccp/dccp_probe trace-event.
You can use it via ftrace or perftools.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Add DCCP sendmsg trace event (dccp/dccp_probe) for
replacing dccpprobe. User can trace this event via
DCCP_CRIT prints some other text and then a newline after the message
string, so the message string does not need to include a newline
explicitly. Done using Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
With changes in inet_ files, DCCP state transitions are traced with
inet_sock_set_state tracepoint.
First, rename __inet_twsk_hashdance() to inet_twsk_hashdance()
Then, remove one inet_twsk_put() by setting tw_refcnt to 3 instead
of 4, but adding a fat warning that we do not have the right to access
tw anymore after inet_twsk_hashdance()
Whenever the sock object is in DCCP_CLOSED state,
dccp_disconnect() must free dccps_hc_tx_ccid and
dccps_hc_rx_ccid and set to NULL.
Signed-off-by: Mohamed Ghannam <simo.ghannam@gmail.com>
Maciej Żenczykowski reported some panics in tcp_twsk_destructor()
that might be caused by the following bug.
timewait timer is pinned to the cpu, because we want to transition
timwewait refcount from 0 to 4 in one go, once everything has been
initialized.
At the time commit ed2e92394589 ("tcp/dccp: fix timewait races in timer
handling") was merged, TCP was always running from BH habdler.
After commit 5413d1babe8f ("net: do not block BH while processing
socket backlog") we definitely can run tcp_time_wait() from process
context.
We need to block BH in the critical section so that the pinned timer
has still its purpose.
This bug is more likely to happen under stress and when very small RTO
are used in datacenter flows.
Fixes: 5413d1babe8f ("net: do not block BH while processing socket backlog")
Reported-by: Maciej Żenczykowski <maze@google.com>
Acked-by: Maciej Żenczykowski <maze@google.com>
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
Make use of the swap macro and remove unnecessary variable tmp.
This makes the code easier to read and maintain.
This code was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Several conflicts here.
NFP driver bug fix adding nfp_netdev_is_nfp_repr() check to
nfp_fl_output() needed some adjustments because the code block is in
an else block now.
Parallel additions to net/pkt_cls.h and net/sch_generic.h
A bug fix in __tcp_retransmit_skb() conflicted with some of
the rbtree changes in net-next.
The tc action RCU callback fixes in 'net' had some overlap with some
of the recent tcf_block reworking.
In my first attempt to fix the lockdep splat, I forgot we could
enter inet_csk_route_req() with a freshly allocated request socket,
for which refcount has not yet been elevated, due to complex
SLAB_TYPESAFE_BY_RCU rules.
We either are in rcu_read_lock() section _or_ we own a refcount on the
request.
Correct RCU verb to use here is rcu_dereference_check(), although it is
not possible to prove we actually own a reference on a shared
refcount :/
In v2, I added ireq_opt_deref() helper and use in three places, to fix other
possible splats.
[ 49.844590] lockdep_rcu_suspicious+0xea/0xf3
[ 49.846487] inet_csk_route_req+0x53/0x14d
[ 49.848334] tcp_v4_route_req+0xe/0x10
[ 49.850174] tcp_conn_request+0x31c/0x6a0
[ 49.851992] ? __lock_acquire+0x614/0x822
[ 49.854015] tcp_v4_conn_request+0x5a/0x79
[ 49.855957] ? tcp_v4_conn_request+0x5a/0x79
[ 49.858052] tcp_rcv_state_process+0x98/0xdcc
[ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307
[ 49.862085] tcp_v4_do_rcv+0xfc/0x145
[ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145
[ 49.866173] tcp_v4_rcv+0x5ab/0xaf9
[ 49.868029] ip_local_deliver_finish+0x1af/0x2e7
[ 49.870064] ip_local_deliver+0x1b2/0x1c5
[ 49.871775] ? inet_del_offload+0x45/0x45
[ 49.873916] ip_rcv_finish+0x3f7/0x471
[ 49.875476] ip_rcv+0x3f1/0x42f
[ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7
[ 49.878791] __netif_receive_skb_core+0x6d3/0x950
[ 49.880701] ? process_backlog+0x7e/0x216
[ 49.882589] __netif_receive_skb+0x1d/0x5e
[ 49.884122] process_backlog+0x10c/0x216
[ 49.885812] net_rx_action+0x147/0x3df
Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()")
Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races")
Reported-by: kernel test robot <fengguang.wu@intel.com>
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly. Adds a pointer back to the sock.
Cc: Soheil Hassas Yeganeh <soheil@google.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: netdev@vger.kernel.org
There were quite a few overlapping sets of changes here.
Daniel's bug fix for off-by-ones in the new BPF branch instructions,
along with the added allowances for "data_end > ptr + x" forms
collided with the metadata additions.
Along with those three changes came veritifer test cases, which in
their final form I tried to group together properly. If I had just
trimmed GIT's conflict tags as-is, this would have split up the
meta tests unnecessarily.
In the socketmap code, a set of preemption disabling changes
overlapped with the rename of bpf_compute_data_end() to
bpf_compute_data_pointers().
Changes were made to the mv88e6060.c driver set addr method
which got removed in net-next.
The hyperv transport socket layer had a locking change in 'net'
which overlapped with a change of socket state macro usage
in 'net-next'.
syzkaller found another bug in DCCP/TCP stacks [1]
For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix
ireq->pktopts race"), we need to make sure we do not access
ireq->opt unless we own the request sock.
Note the opt field is renamed to ireq_opt to ease grep games.
[1]
BUG: KASAN: use-after-free in ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474
Read of size 1 at addr ffff8801c951039c by task syz-executor5/3295
CPU: 1 PID: 3295 Comm: syz-executor5 Not tainted 4.14.0-rc4+ #80
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
tcp_transmit_skb+0x1ab7/0x3840 net/ipv4/tcp_output.c:1135
tcp_send_ack.part.37+0x3bb/0x650 net/ipv4/tcp_output.c:3587
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3557
__tcp_ack_snd_check+0x2c6/0x4b0 net/ipv4/tcp_input.c:5072
tcp_ack_snd_check net/ipv4/tcp_input.c:5085 [inline]
tcp_rcv_state_process+0x2eff/0x4850 net/ipv4/tcp_input.c:6071
tcp_child_process+0x342/0x990 net/ipv4/tcp_minisocks.c:816
tcp_v4_rcv+0x1827/0x2f80 net/ipv4/tcp_ipv4.c:1682
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:249 [inline]
ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:464 [inline]
ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514
netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587
netif_receive_skb+0xae/0x390 net/core/dev.c:4611
tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372
tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766
tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792
call_write_iter include/linux/fs.h:1770 [inline]
new_sync_write fs/read_write.c:468 [inline]
__vfs_write+0x68a/0x970 fs/read_write.c:481
vfs_write+0x18f/0x510 fs/read_write.c:543
SYSC_write fs/read_write.c:588 [inline]
SyS_write+0xef/0x220 fs/read_write.c:580
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x40c341
RSP: 002b:00007f469523ec10 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 000000000040c341
RDX: 0000000000000037 RSI: 0000000020004000 RDI: 0000000000000015
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000000f4240 R11: 0000000000000293 R12: 00000000004b7fd1
R13: 00000000ffffffff R14: 0000000020000000 R15: 0000000000025000
Allocated by task 3295:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
__do_kmalloc mm/slab.c:3725 [inline]
__kmalloc+0x162/0x760 mm/slab.c:3734
kmalloc include/linux/slab.h:498 [inline]
tcp_v4_save_options include/net/tcp.h:1962 [inline]
tcp_v4_init_req+0x2d3/0x3e0 net/ipv4/tcp_ipv4.c:1271
tcp_conn_request+0xf6d/0x3410 net/ipv4/tcp_input.c:6283
tcp_v4_conn_request+0x157/0x210 net/ipv4/tcp_ipv4.c:1313
tcp_rcv_state_process+0x8ea/0x4850 net/ipv4/tcp_input.c:5857
tcp_v4_do_rcv+0x55c/0x7d0 net/ipv4/tcp_ipv4.c:1482
tcp_v4_rcv+0x2d10/0x2f80 net/ipv4/tcp_ipv4.c:1711
Freed by task 3306:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kfree+0xca/0x250 mm/slab.c:3820
inet_sock_destruct+0x59d/0x950 net/ipv4/af_inet.c:157
__sk_destruct+0xfd/0x910 net/core/sock.c:1560
sk_destruct+0x47/0x80 net/core/sock.c:1595
__sk_free+0x57/0x230 net/core/sock.c:1603
sk_free+0x2a/0x40 net/core/sock.c:1614
sock_put include/net/sock.h:1652 [inline]
inet_csk_complete_hashdance+0xd5/0xf0 net/ipv4/inet_connection_sock.c:959
tcp_check_req+0xf4d/0x1620 net/ipv4/tcp_minisocks.c:765
tcp_v4_rcv+0x17f6/0x2f80 net/ipv4/tcp_ipv4.c:1675
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
