path: root/net/dccp
2017-12-16tcp/dccp: block bh before arming time_wait timerEric Dumazet
[ Upstream commit cfac7f836a715b91f08c851df915d401a4d52783 ] Maciej Żenczykowski reported some panics in tcp_twsk_destructor() that might be caused by the following bug. timewait timer is pinned to the cpu, because we want to transition timwewait refcount from 0 to 4 in one go, once everything has been initialized. At the time commit ed2e92394589 ("tcp/dccp: fix timewait races in timer handling") was merged, TCP was always running from BH habdler. After commit 5413d1babe8f ("net: do not block BH while processing socket backlog") we definitely can run tcp_time_wait() from process context. We need to block BH in the critical section so that the pinned timer has still its purpose. This bug is more likely to happen under stress and when very small RTO are used in datacenter flows. Fixes: 5413d1babe8f ("net: do not block BH while processing socket backlog") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Maciej Żenczykowski <maze@google.com> Acked-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18tcp/dccp: fix other lockdep splats accessing ireq_optEric Dumazet
[ Upstream commit 06f877d613be3621604c2520ec0351d9fbdca15f ] In my first attempt to fix the lockdep splat, I forgot we could enter inet_csk_route_req() with a freshly allocated request socket, for which refcount has not yet been elevated, due to complex SLAB_TYPESAFE_BY_RCU rules. We either are in rcu_read_lock() section _or_ we own a refcount on the request. Correct RCU verb to use here is rcu_dereference_check(), although it is not possible to prove we actually own a reference on a shared refcount :/ In v2, I added ireq_opt_deref() helper and use in three places, to fix other possible splats. [ 49.844590] lockdep_rcu_suspicious+0xea/0xf3 [ 49.846487] inet_csk_route_req+0x53/0x14d [ 49.848334] tcp_v4_route_req+0xe/0x10 [ 49.850174] tcp_conn_request+0x31c/0x6a0 [ 49.851992] ? __lock_acquire+0x614/0x822 [ 49.854015] tcp_v4_conn_request+0x5a/0x79 [ 49.855957] ? tcp_v4_conn_request+0x5a/0x79 [ 49.858052] tcp_rcv_state_process+0x98/0xdcc [ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307 [ 49.862085] tcp_v4_do_rcv+0xfc/0x145 [ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145 [ 49.866173] tcp_v4_rcv+0x5ab/0xaf9 [ 49.868029] ip_local_deliver_finish+0x1af/0x2e7 [ 49.870064] ip_local_deliver+0x1b2/0x1c5 [ 49.871775] ? inet_del_offload+0x45/0x45 [ 49.873916] ip_rcv_finish+0x3f7/0x471 [ 49.875476] ip_rcv+0x3f1/0x42f [ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7 [ 49.878791] __netif_receive_skb_core+0x6d3/0x950 [ 49.880701] ? process_backlog+0x7e/0x216 [ 49.882589] __netif_receive_skb+0x1d/0x5e [ 49.884122] process_backlog+0x10c/0x216 [ 49.885812] net_rx_action+0x147/0x3df Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()") Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: kernel test robot <fengguang.wu@intel.com> Reported-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-18tcp/dccp: fix ireq->opt racesEric Dumazet
[ Upstream commit c92e8c02fe664155ac4234516e32544bec0f113d ] syzkaller found another bug in DCCP/TCP stacks [1] For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix ireq->pktopts race"), we need to make sure we do not access ireq->opt unless we own the request sock. Note the opt field is renamed to ireq_opt to ease grep games. [1] BUG: KASAN: use-after-free in ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474 Read of size 1 at addr ffff8801c951039c by task syz-executor5/3295 CPU: 1 PID: 3295 Comm: syz-executor5 Not tainted 4.14.0-rc4+ #80 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:52 print_address_description+0x73/0x250 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x25b/0x340 mm/kasan/report.c:409 __asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427 ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474 tcp_transmit_skb+0x1ab7/0x3840 net/ipv4/tcp_output.c:1135 tcp_send_ack.part.37+0x3bb/0x650 net/ipv4/tcp_output.c:3587 tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3557 __tcp_ack_snd_check+0x2c6/0x4b0 net/ipv4/tcp_input.c:5072 tcp_ack_snd_check net/ipv4/tcp_input.c:5085 [inline] tcp_rcv_state_process+0x2eff/0x4850 net/ipv4/tcp_input.c:6071 tcp_child_process+0x342/0x990 net/ipv4/tcp_minisocks.c:816 tcp_v4_rcv+0x1827/0x2f80 net/ipv4/tcp_ipv4.c:1682 ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216 NF_HOOK include/linux/netfilter.h:249 [inline] ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257 dst_input include/net/dst.h:464 [inline] ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397 NF_HOOK include/linux/netfilter.h:249 [inline] ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493 __netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476 __netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514 netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587 netif_receive_skb+0xae/0x390 net/core/dev.c:4611 tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372 tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766 tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792 call_write_iter include/linux/fs.h:1770 [inline] new_sync_write fs/read_write.c:468 [inline] __vfs_write+0x68a/0x970 fs/read_write.c:481 vfs_write+0x18f/0x510 fs/read_write.c:543 SYSC_write fs/read_write.c:588 [inline] SyS_write+0xef/0x220 fs/read_write.c:580 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x40c341 RSP: 002b:00007f469523ec10 EFLAGS: 00000293 ORIG_RAX: 0000000000000001 RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 000000000040c341 RDX: 0000000000000037 RSI: 0000000020004000 RDI: 0000000000000015 RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000 R10: 00000000000f4240 R11: 0000000000000293 R12: 00000000004b7fd1 R13: 00000000ffffffff R14: 0000000020000000 R15: 0000000000025000 Allocated by task 3295: save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59 save_stack+0x43/0xd0 mm/kasan/kasan.c:447 set_track mm/kasan/kasan.c:459 [inline] kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551 __do_kmalloc mm/slab.c:3725 [inline] __kmalloc+0x162/0x760 mm/slab.c:3734 kmalloc include/linux/slab.h:498 [inline] tcp_v4_save_options include/net/tcp.h:1962 [inline] tcp_v4_init_req+0x2d3/0x3e0 net/ipv4/tcp_ipv4.c:1271 tcp_conn_request+0xf6d/0x3410 net/ipv4/tcp_input.c:6283 tcp_v4_conn_request+0x157/0x210 net/ipv4/tcp_ipv4.c:1313 tcp_rcv_state_process+0x8ea/0x4850 net/ipv4/tcp_input.c:5857 tcp_v4_do_rcv+0x55c/0x7d0 net/ipv4/tcp_ipv4.c:1482 tcp_v4_rcv+0x2d10/0x2f80 net/ipv4/tcp_ipv4.c:1711 ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216 NF_HOOK include/linux/netfilter.h:249 [inline] ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257 dst_input include/net/dst.h:464 [inline] ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397 NF_HOOK include/linux/netfilter.h:249 [inline] ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493 __netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476 __netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514 netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587 netif_receive_skb+0xae/0x390 net/core/dev.c:4611 tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372 tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766 tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792 call_write_iter include/linux/fs.h:1770 [inline] new_sync_write fs/read_write.c:468 [inline] __vfs_write+0x68a/0x970 fs/read_write.c:481 vfs_write+0x18f/0x510 fs/read_write.c:543 SYSC_write fs/read_write.c:588 [inline] SyS_write+0xef/0x220 fs/read_write.c:580 entry_SYSCALL_64_fastpath+0x1f/0xbe Freed by task 3306: save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59 save_stack+0x43/0xd0 mm/kasan/kasan.c:447 set_track mm/kasan/kasan.c:459 [inline] kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524 __cache_free mm/slab.c:3503 [inline] kfree+0xca/0x250 mm/slab.c:3820 inet_sock_destruct+0x59d/0x950 net/ipv4/af_inet.c:157 __sk_destruct+0xfd/0x910 net/core/sock.c:1560 sk_destruct+0x47/0x80 net/core/sock.c:1595 __sk_free+0x57/0x230 net/core/sock.c:1603 sk_free+0x2a/0x40 net/core/sock.c:1614 sock_put include/net/sock.h:1652 [inline] inet_csk_complete_hashdance+0xd5/0xf0 net/ipv4/inet_connection_sock.c:959 tcp_check_req+0xf4d/0x1620 net/ipv4/tcp_minisocks.c:765 tcp_v4_rcv+0x17f6/0x2f80 net/ipv4/tcp_ipv4.c:1675 ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216 NF_HOOK include/linux/netfilter.h:249 [inline] ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257 dst_input include/net/dst.h:464 [inline] ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397 NF_HOOK include/linux/netfilter.h:249 [inline] ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493 __netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476 __netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514 netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587 netif_receive_skb+0xae/0x390 net/core/dev.c:4611 tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372 tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766 tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792 call_write_iter include/linux/fs.h:1770 [inline] new_sync_write fs/read_write.c:468 [inline] __vfs_write+0x68a/0x970 fs/read_write.c:481 vfs_write+0x18f/0x510 fs/read_write.c:543 SYSC_write fs/read_write.c:588 [inline] SyS_write+0xef/0x220 fs/read_write.c:580 entry_SYSCALL_64_fastpath+0x1f/0xbe Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets") Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30dccp: defer ccid_hc_tx_delete() at dismantle timeEric Dumazet
[ Upstream commit 120e9dabaf551c6dc03d3a10a1f026376cb1811c ] syszkaller team reported another problem in DCCP [1] Problem here is that the structure holding RTO timer (ccid2_hc_tx_rto_expire() handler) is freed too soon. We can not use del_timer_sync() to cancel the timer since this timer wants to grab socket lock (that would risk a dead lock) Solution is to defer the freeing of memory when all references to the socket were released. Socket timers do own a reference, so this should fix the issue. [1] ================================================================== BUG: KASAN: use-after-free in ccid2_hc_tx_rto_expire+0x51c/0x5c0 net/dccp/ccids/ccid2.c:144 Read of size 4 at addr ffff8801d2660540 by task kworker/u4:7/3365 CPU: 1 PID: 3365 Comm: kworker/u4:7 Not tainted 4.13.0-rc4+ #3 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Workqueue: events_unbound call_usermodehelper_exec_work Call Trace: <IRQ> __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:52 print_address_description+0x73/0x250 mm/kasan/report.c:252 kasan_report_error mm/kasan/report.c:351 [inline] kasan_report+0x24e/0x340 mm/kasan/report.c:409 __asan_report_load4_noabort+0x14/0x20 mm/kasan/report.c:429 ccid2_hc_tx_rto_expire+0x51c/0x5c0 net/dccp/ccids/ccid2.c:144 call_timer_fn+0x233/0x830 kernel/time/timer.c:1268 expire_timers kernel/time/timer.c:1307 [inline] __run_timers+0x7fd/0xb90 kernel/time/timer.c:1601 run_timer_softirq+0x21/0x80 kernel/time/timer.c:1614 __do_softirq+0x2f5/0xba3 kernel/softirq.c:284 invoke_softirq kernel/softirq.c:364 [inline] irq_exit+0x1cc/0x200 kernel/softirq.c:405 exiting_irq arch/x86/include/asm/apic.h:638 [inline] smp_apic_timer_interrupt+0x76/0xa0 arch/x86/kernel/apic/apic.c:1044 apic_timer_interrupt+0x93/0xa0 arch/x86/entry/entry_64.S:702 RIP: 0010:arch_local_irq_enable arch/x86/include/asm/paravirt.h:824 [inline] RIP: 0010:__raw_write_unlock_irq include/linux/rwlock_api_smp.h:267 [inline] RIP: 0010:_raw_write_unlock_irq+0x56/0x70 kernel/locking/spinlock.c:343 RSP: 0018:ffff8801cd50eaa8 EFLAGS: 00000286 ORIG_RAX: ffffffffffffff10 RAX: dffffc0000000000 RBX: ffffffff85a090c0 RCX: 0000000000000006 RDX: 1ffffffff0b595f3 RSI: 1ffff1003962f989 RDI: ffffffff85acaf98 RBP: ffff8801cd50eab0 R08: 0000000000000001 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801cc96ea60 R13: dffffc0000000000 R14: ffff8801cc96e4c0 R15: ffff8801cc96e4c0 </IRQ> release_task+0xe9e/0x1a40 kernel/exit.c:220 wait_task_zombie kernel/exit.c:1162 [inline] wait_consider_task+0x29b8/0x33c0 kernel/exit.c:1389 do_wait_thread kernel/exit.c:1452 [inline] do_wait+0x441/0xa90 kernel/exit.c:1523 kernel_wait4+0x1f5/0x370 kernel/exit.c:1665 SYSC_wait4+0x134/0x140 kernel/exit.c:1677 SyS_wait4+0x2c/0x40 kernel/exit.c:1673 call_usermodehelper_exec_sync kernel/kmod.c:286 [inline] call_usermodehelper_exec_work+0x1a0/0x2c0 kernel/kmod.c:323 process_one_work+0xbf3/0x1bc0 kernel/workqueue.c:2097 worker_thread+0x223/0x1860 kernel/workqueue.c:2231 kthread+0x35e/0x430 kernel/kthread.c:231 ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:425 Allocated by task 21267: save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59 save_stack+0x43/0xd0 mm/kasan/kasan.c:447 set_track mm/kasan/kasan.c:459 [inline] kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551 kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:489 kmem_cache_alloc+0x127/0x750 mm/slab.c:3561 ccid_new+0x20e/0x390 net/dccp/ccid.c:151 dccp_hdlr_ccid+0x27/0x140 net/dccp/feat.c:44 __dccp_feat_activate+0x142/0x2a0 net/dccp/feat.c:344 dccp_feat_activate_values+0x34e/0xa90 net/dccp/feat.c:1538 dccp_rcv_request_sent_state_process net/dccp/input.c:472 [inline] dccp_rcv_state_process+0xed1/0x1620 net/dccp/input.c:677 dccp_v4_do_rcv+0xeb/0x160 net/dccp/ipv4.c:679 sk_backlog_rcv include/net/sock.h:911 [inline] __release_sock+0x124/0x360 net/core/sock.c:2269 release_sock+0xa4/0x2a0 net/core/sock.c:2784 inet_wait_for_connect net/ipv4/af_inet.c:557 [inline] __inet_stream_connect+0x671/0xf00 net/ipv4/af_inet.c:643 inet_stream_connect+0x58/0xa0 net/ipv4/af_inet.c:682 SYSC_connect+0x204/0x470 net/socket.c:1642 SyS_connect+0x24/0x30 net/socket.c:1623 entry_SYSCALL_64_fastpath+0x1f/0xbe Freed by task 3049: save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59 save_stack+0x43/0xd0 mm/kasan/kasan.c:447 set_track mm/kasan/kasan.c:459 [inline] kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524 __cache_free mm/slab.c:3503 [inline] kmem_cache_free+0x77/0x280 mm/slab.c:3763 ccid_hc_tx_delete+0xc5/0x100 net/dccp/ccid.c:190 dccp_destroy_sock+0x1d1/0x2b0 net/dccp/proto.c:225 inet_csk_destroy_sock+0x166/0x3f0 net/ipv4/inet_connection_sock.c:833 dccp_done+0xb7/0xd0 net/dccp/proto.c:145 dccp_time_wait+0x13d/0x300 net/dccp/minisocks.c:72 dccp_rcv_reset+0x1d1/0x5b0 net/dccp/input.c:160 dccp_rcv_state_process+0x8fc/0x1620 net/dccp/input.c:663 dccp_v4_do_rcv+0xeb/0x160 net/dccp/ipv4.c:679 sk_backlog_rcv include/net/sock.h:911 [inline] __sk_receive_skb+0x33e/0xc00 net/core/sock.c:521 dccp_v4_rcv+0xef1/0x1c00 net/dccp/ipv4.c:871 ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216 NF_HOOK include/linux/netfilter.h:248 [inline] ip_local_deliver+0x1ce/0x6d0 net/ipv4/ip_input.c:257 dst_input include/net/dst.h:477 [inline] ip_rcv_finish+0x8db/0x19c0 net/ipv4/ip_input.c:397 NF_HOOK include/linux/netfilter.h:248 [inline] ip_rcv+0xc3f/0x17d0 net/ipv4/ip_input.c:488 __netif_receive_skb_core+0x19af/0x33d0 net/core/dev.c:4417 __netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4455 process_backlog+0x203/0x740 net/core/dev.c:5130 napi_poll net/core/dev.c:5527 [inline] net_rx_action+0x792/0x1910 net/core/dev.c:5593 __do_softirq+0x2f5/0xba3 kernel/softirq.c:284 The buggy address belongs to the object at ffff8801d2660100 which belongs to the cache ccid2_hc_tx_sock of size 1240 The buggy address is located 1088 bytes inside of 1240-byte region [ffff8801d2660100, ffff8801d26605d8) The buggy address belongs to the page: page:ffffea0007499800 count:1 mapcount:0 mapping:ffff8801d2660100 index:0x0 compound_mapcount: 0 flags: 0x200000000008100(slab|head) raw: 0200000000008100 ffff8801d2660100 0000000000000000 0000000100000005 raw: ffffea00075271a0 ffffea0007538820 ffff8801d3aef9c0 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff8801d2660400: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ffff8801d2660480: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb >ffff8801d2660500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ^ ffff8801d2660580: fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc fc ffff8801d2660600: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ================================================================== Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30dccp: purge write queue in dccp_destroy_sock()Eric Dumazet
[ Upstream commit 7749d4ff88d31b0be17c8683143135adaaadc6a7 ] syzkaller reported that DCCP could have a non empty write queue at dismantle time. WARNING: CPU: 1 PID: 2953 at net/core/stream.c:199 sk_stream_kill_queues+0x3ce/0x520 net/core/stream.c:199 Kernel panic - not syncing: panic_on_warn set ... CPU: 1 PID: 2953 Comm: syz-executor0 Not tainted 4.13.0-rc4+ #2 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:16 [inline] dump_stack+0x194/0x257 lib/dump_stack.c:52 panic+0x1e4/0x417 kernel/panic.c:180 __warn+0x1c4/0x1d9 kernel/panic.c:541 report_bug+0x211/0x2d0 lib/bug.c:183 fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:190 do_trap_no_signal arch/x86/kernel/traps.c:224 [inline] do_trap+0x260/0x390 arch/x86/kernel/traps.c:273 do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:310 do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:323 invalid_op+0x1e/0x30 arch/x86/entry/entry_64.S:846 RIP: 0010:sk_stream_kill_queues+0x3ce/0x520 net/core/stream.c:199 RSP: 0018:ffff8801d182f108 EFLAGS: 00010297 RAX: ffff8801d1144140 RBX: ffff8801d13cb280 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffffffff85137b00 RDI: ffff8801d13cb280 RBP: ffff8801d182f148 R08: 0000000000000001 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801d13cb4d0 R13: ffff8801d13cb3b8 R14: ffff8801d13cb300 R15: ffff8801d13cb3b8 inet_csk_destroy_sock+0x175/0x3f0 net/ipv4/inet_connection_sock.c:835 dccp_close+0x84d/0xc10 net/dccp/proto.c:1067 inet_release+0xed/0x1c0 net/ipv4/af_inet.c:425 sock_release+0x8d/0x1e0 net/socket.c:597 sock_close+0x16/0x20 net/socket.c:1126 __fput+0x327/0x7e0 fs/file_table.c:210 ____fput+0x15/0x20 fs/file_table.c:246 task_work_run+0x18a/0x260 kernel/task_work.c:116 exit_task_work include/linux/task_work.h:21 [inline] do_exit+0xa32/0x1b10 kernel/exit.c:865 do_group_exit+0x149/0x400 kernel/exit.c:969 get_signal+0x7e8/0x17e0 kernel/signal.c:2330 do_signal+0x94/0x1ee0 arch/x86/kernel/signal.c:808 exit_to_usermode_loop+0x21c/0x2d0 arch/x86/entry/common.c:157 prepare_exit_to_usermode arch/x86/entry/common.c:194 [inline] syscall_return_slowpath+0x3a7/0x450 arch/x86/entry/common.c:263 Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11dccp: fix a memleak for dccp_feat_init err processXin Long
[ Upstream commit e90ce2fc27cad7e7b1e72b9e66201a7a4c124c2b ] In dccp_feat_init, when ccid_get_builtin_ccids failsto alloc memory for rx.val, it should free tx.val before returning an error. Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11dccp: fix a memleak that dccp_ipv4 doesn't put reqsk properlyXin Long
[ Upstream commit b7953d3c0e30a5fc944f6b7bd0bcceb0794bcd85 ] The patch "dccp: fix a memleak that dccp_ipv6 doesn't put reqsk properly" fixed reqsk refcnt leak for dccp_ipv6. The same issue exists on dccp_ipv4. This patch is to fix it for dccp_ipv4. Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11dccp: fix a memleak that dccp_ipv6 doesn't put reqsk properlyXin Long
[ Upstream commit 0c2232b0a71db0ac1d22f751aa1ac0cadb950fd2 ] In dccp_v6_conn_request, after reqsk gets alloced and hashed into ehash table, reqsk's refcnt is set 3. one is for req->rsk_timer, one is for hlist, and the other one is for current using. The problem is when dccp_v6_conn_request returns and finishes using reqsk, it doesn't put reqsk. This will cause reqsk refcnt leaks and reqsk obj never gets freed. Jianlin found this issue when running dccp_memleak.c in a loop, the system memory would run out. dccp_memleak.c: int s1 = socket(PF_INET6, 6, IPPROTO_IP); bind(s1, &sa1, 0x20); listen(s1, 0x9); int s2 = socket(PF_INET6, 6, IPPROTO_IP); connect(s2, &sa1, 0x20); close(s1); close(s2); This patch is to put the reqsk before dccp_v6_conn_request returns, just as what tcp_conn_request does. Reported-by: Jianlin Shi <jishi@redhat.com> Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-07ipv6/dccp: do not inherit ipv6_mc_list from parentWANG Cong
[ Upstream commit 83eaddab4378db256d00d295bda6ca997cd13a52 ] Like commit 657831ffc38e ("dccp/tcp: do not inherit mc_list from parent") we should clear ipv6_mc_list etc. for IPv6 sockets too. Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-22dccp: fix memory leak during tear-down of unsuccessful connection requestHannes Frederic Sowa
[ Upstream commit 72ef9c4125c7b257e3a714d62d778ab46583d6a3 ] This patch fixes a memory leak, which happens if the connection request is not fulfilled between parsing the DCCP options and handling the SYN (because e.g. the backlog is full), because we forgot to free the list of ack vectors. Reported-by: Jianwen Ji <jiji@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-22dccp/tcp: fix routing redirect raceJon Maxwell
[ Upstream commit 45caeaa5ac0b4b11784ac6f932c0ad4c6b67cda0 ] As Eric Dumazet pointed out this also needs to be fixed in IPv6. v2: Contains the IPv6 tcp/Ipv6 dccp patches as well. We have seen a few incidents lately where a dst_enty has been freed with a dangling TCP socket reference (sk->sk_dst_cache) pointing to that dst_entry. If the conditions/timings are right a crash then ensues when the freed dst_entry is referenced later on. A Common crashing back trace is: #8 [] page_fault at ffffffff8163e648 [exception RIP: __tcp_ack_snd_check+74] . . #9 [] tcp_rcv_established at ffffffff81580b64 #10 [] tcp_v4_do_rcv at ffffffff8158b54a #11 [] tcp_v4_rcv at ffffffff8158cd02 #12 [] ip_local_deliver_finish at ffffffff815668f4 #13 [] ip_local_deliver at ffffffff81566bd9 #14 [] ip_rcv_finish at ffffffff8156656d #15 [] ip_rcv at ffffffff81566f06 #16 [] __netif_receive_skb_core at ffffffff8152b3a2 #17 [] __netif_receive_skb at ffffffff8152b608 #18 [] netif_receive_skb at ffffffff8152b690 #19 [] vmxnet3_rq_rx_complete at ffffffffa015eeaf [vmxnet3] #20 [] vmxnet3_poll_rx_only at ffffffffa015f32a [vmxnet3] #21 [] net_rx_action at ffffffff8152bac2 #22 [] __do_softirq at ffffffff81084b4f #23 [] call_softirq at ffffffff8164845c #24 [] do_softirq at ffffffff81016fc5 #25 [] irq_exit at ffffffff81084ee5 #26 [] do_IRQ at ffffffff81648ff8 Of course it may happen with other NIC drivers as well. It's found the freed dst_entry here: 224 static bool tcp_in_quickack_mode(struct sock *sk)↩ 225 {↩ 226 ▹ const struct inet_connection_sock *icsk = inet_csk(sk);↩ 227 ▹ const struct dst_entry *dst = __sk_dst_get(sk);↩ 228 ↩ 229 ▹ return (dst && dst_metric(dst, RTAX_QUICKACK)) ||↩ 230 ▹ ▹ (icsk->icsk_ack.quick && !icsk->icsk_ack.pingpong);↩ 231 }↩ But there are other backtraces attributed to the same freed dst_entry in netfilter code as well. All the vmcores showed 2 significant clues: - Remote hosts behind the default gateway had always been redirected to a different gateway. A rtable/dst_entry will be added for that host. Making more dst_entrys with lower reference counts. Making this more probable. - All vmcores showed a postitive LockDroppedIcmps value, e.g: LockDroppedIcmps 267 A closer look at the tcp_v4_err() handler revealed that do_redirect() will run regardless of whether user space has the socket locked. This can result in a race condition where the same dst_entry cached in sk->sk_dst_entry can be decremented twice for the same socket via: do_redirect()->__sk_dst_check()-> dst_release(). Which leads to the dst_entry being prematurely freed with another socket pointing to it via sk->sk_dst_cache and a subsequent crash. To fix this skip do_redirect() if usespace has the socket locked. Instead let the redirect take place later when user space does not have the socket locked. The dccp/IPv6 code is very similar in this respect, so fixing it there too. As Eric Garver pointed out the following commit now invalidates routes. Which can set the dst->obsolete flag so that ipv4_dst_check() returns null and triggers the dst_release(). Fixes: ceb3320610d6 ("ipv4: Kill routes during PMTU/redirect updates.") Cc: Eric Garver <egarver@redhat.com> Cc: Hannes Sowa <hsowa@redhat.com> Signed-off-by: Jon Maxwell <jmaxwell37@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-22dccp: fix use-after-free in dccp_feat_activate_valuesEric Dumazet
[ Upstream commit 62f8f4d9066c1c6f2474845d1ca7e2891f2ae3fd ] Dmitry reported crashes in DCCP stack [1] Problem here is that when I got rid of listener spinlock, I missed the fact that DCCP stores a complex state in struct dccp_request_sock, while TCP does not. Since multiple cpus could access it at the same time, we need to add protection. [1] BUG: KASAN: use-after-free in dccp_feat_activate_values+0x967/0xab0 net/dccp/feat.c:1541 at addr ffff88003713be68 Read of size 8 by task syz-executor2/8457 CPU: 2 PID: 8457 Comm: syz-executor2 Not tainted 4.10.0-rc7+ #127 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: <IRQ> __dump_stack lib/dump_stack.c:15 [inline] dump_stack+0x292/0x398 lib/dump_stack.c:51 kasan_object_err+0x1c/0x70 mm/kasan/report.c:162 print_address_description mm/kasan/report.c:200 [inline] kasan_report_error mm/kasan/report.c:289 [inline] kasan_report.part.1+0x20e/0x4e0 mm/kasan/report.c:311 kasan_report mm/kasan/report.c:332 [inline] __asan_report_load8_noabort+0x29/0x30 mm/kasan/report.c:332 dccp_feat_activate_values+0x967/0xab0 net/dccp/feat.c:1541 dccp_create_openreq_child+0x464/0x610 net/dccp/minisocks.c:121 dccp_v6_request_recv_sock+0x1f6/0x1960 net/dccp/ipv6.c:457 dccp_check_req+0x335/0x5a0 net/dccp/minisocks.c:186 dccp_v6_rcv+0x69e/0x1d00 net/dccp/ipv6.c:711 ip6_input_finish+0x46d/0x17a0 net/ipv6/ip6_input.c:279 NF_HOOK include/linux/netfilter.h:257 [inline] ip6_input+0xdb/0x590 net/ipv6/ip6_input.c:322 dst_input include/net/dst.h:507 [inline] ip6_rcv_finish+0x289/0x890 net/ipv6/ip6_input.c:69 NF_HOOK include/linux/netfilter.h:257 [inline] ipv6_rcv+0x12ec/0x23d0 net/ipv6/ip6_input.c:203 __netif_receive_skb_core+0x1ae5/0x3400 net/core/dev.c:4190 __netif_receive_skb+0x2a/0x170 net/core/dev.c:4228 process_backlog+0xe5/0x6c0 net/core/dev.c:4839 napi_poll net/core/dev.c:5202 [inline] net_rx_action+0xe70/0x1900 net/core/dev.c:5267 __do_softirq+0x2fb/0xb7d kernel/softirq.c:284 do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902 </IRQ> do_softirq.part.17+0x1e8/0x230 kernel/softirq.c:328 do_softirq kernel/softirq.c:176 [inline] __local_bh_enable_ip+0x1f2/0x200 kernel/softirq.c:181 local_bh_enable include/linux/bottom_half.h:31 [inline] rcu_read_unlock_bh include/linux/rcupdate.h:971 [inline] ip6_finish_output2+0xbb0/0x23d0 net/ipv6/ip6_output.c:123 ip6_finish_output+0x302/0x960 net/ipv6/ip6_output.c:148 NF_HOOK_COND include/linux/netfilter.h:246 [inline] ip6_output+0x1cb/0x8d0 net/ipv6/ip6_output.c:162 ip6_xmit+0xcdf/0x20d0 include/net/dst.h:501 inet6_csk_xmit+0x320/0x5f0 net/ipv6/inet6_connection_sock.c:179 dccp_transmit_skb+0xb09/0x1120 net/dccp/output.c:141 dccp_xmit_packet+0x215/0x760 net/dccp/output.c:280 dccp_write_xmit+0x168/0x1d0 net/dccp/output.c:362 dccp_sendmsg+0x79c/0xb10 net/dccp/proto.c:796 inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744 sock_sendmsg_nosec net/socket.c:635 [inline] sock_sendmsg+0xca/0x110 net/socket.c:645 SYSC_sendto+0x660/0x810 net/socket.c:1687 SyS_sendto+0x40/0x50 net/socket.c:1655 entry_SYSCALL_64_fastpath+0x1f/0xc2 RIP: 0033:0x4458b9 RSP: 002b:00007f8ceb77bb58 EFLAGS: 00000282 ORIG_RAX: 000000000000002c RAX: ffffffffffffffda RBX: 0000000000000017 RCX: 00000000004458b9 RDX: 0000000000000023 RSI: 0000000020e60000 RDI: 0000000000000017 RBP: 00000000006e1b90 R08: 00000000200f9fe1 R09: 0000000000000020 R10: 0000000000008010 R11: 0000000000000282 R12: 00000000007080a8 R13: 0000000000000000 R14: 00007f8ceb77c9c0 R15: 00007f8ceb77c700 Object at ffff88003713be50, in cache kmalloc-64 size: 64 Allocated: PID = 8446 save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:57 save_stack+0x43/0xd0 mm/kasan/kasan.c:502 set_track mm/kasan/kasan.c:514 [inline] kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:605 kmem_cache_alloc_trace+0x82/0x270 mm/slub.c:2738 kmalloc include/linux/slab.h:490 [inline] dccp_feat_entry_new+0x214/0x410 net/dccp/feat.c:467 dccp_feat_push_change+0x38/0x220 net/dccp/feat.c:487 __feat_register_sp+0x223/0x2f0 net/dccp/feat.c:741 dccp_feat_propagate_ccid+0x22b/0x2b0 net/dccp/feat.c:949 dccp_feat_server_ccid_dependencies+0x1b3/0x250 net/dccp/feat.c:1012 dccp_make_response+0x1f1/0xc90 net/dccp/output.c:423 dccp_v6_send_response+0x4ec/0xc20 net/dccp/ipv6.c:217 dccp_v6_conn_request+0xaba/0x11b0 net/dccp/ipv6.c:377 dccp_rcv_state_process+0x51e/0x1650 net/dccp/input.c:606 dccp_v6_do_rcv+0x213/0x350 net/dccp/ipv6.c:632 sk_backlog_rcv include/net/sock.h:893 [inline] __sk_receive_skb+0x36f/0xcc0 net/core/sock.c:479 dccp_v6_rcv+0xba5/0x1d00 net/dccp/ipv6.c:742 ip6_input_finish+0x46d/0x17a0 net/ipv6/ip6_input.c:279 NF_HOOK include/linux/netfilter.h:257 [inline] ip6_input+0xdb/0x590 net/ipv6/ip6_input.c:322 dst_input include/net/dst.h:507 [inline] ip6_rcv_finish+0x289/0x890 net/ipv6/ip6_input.c:69 NF_HOOK include/linux/netfilter.h:257 [inline] ipv6_rcv+0x12ec/0x23d0 net/ipv6/ip6_input.c:203 __netif_receive_skb_core+0x1ae5/0x3400 net/core/dev.c:4190 __netif_receive_skb+0x2a/0x170 net/core/dev.c:4228 process_backlog+0xe5/0x6c0 net/core/dev.c:4839 napi_poll net/core/dev.c:5202 [inline] net_rx_action+0xe70/0x1900 net/core/dev.c:5267 __do_softirq+0x2fb/0xb7d kernel/softirq.c:284 Freed: PID = 15 save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:57 save_stack+0x43/0xd0 mm/kasan/kasan.c:502 set_track mm/kasan/kasan.c:514 [inline] kasan_slab_free+0x73/0xc0 mm/kasan/kasan.c:578 slab_free_hook mm/slub.c:1355 [inline] slab_free_freelist_hook mm/slub.c:1377 [inline] slab_free mm/slub.c:2954 [inline] kfree+0xe8/0x2b0 mm/slub.c:3874 dccp_feat_entry_destructor.part.4+0x48/0x60 net/dccp/feat.c:418 dccp_feat_entry_destructor net/dccp/feat.c:416 [inline] dccp_feat_list_pop net/dccp/feat.c:541 [inline] dccp_feat_activate_values+0x57f/0xab0 net/dccp/feat.c:1543 dccp_create_openreq_child+0x464/0x610 net/dccp/minisocks.c:121 dccp_v6_request_recv_sock+0x1f6/0x1960 net/dccp/ipv6.c:457 dccp_check_req+0x335/0x5a0 net/dccp/minisocks.c:186 dccp_v6_rcv+0x69e/0x1d00 net/dccp/ipv6.c:711 ip6_input_finish+0x46d/0x17a0 net/ipv6/ip6_input.c:279 NF_HOOK include/linux/netfilter.h:257 [inline] ip6_input+0xdb/0x590 net/ipv6/ip6_input.c:322 dst_input include/net/dst.h:507 [inline] ip6_rcv_finish+0x289/0x890 net/ipv6/ip6_input.c:69 NF_HOOK include/linux/netfilter.h:257 [inline] ipv6_rcv+0x12ec/0x23d0 net/ipv6/ip6_input.c:203 __netif_receive_skb_core+0x1ae5/0x3400 net/core/dev.c:4190 __netif_receive_skb+0x2a/0x170 net/core/dev.c:4228 process_backlog+0xe5/0x6c0 net/core/dev.c:4839 napi_poll net/core/dev.c:5202 [inline] net_rx_action+0xe70/0x1900 net/core/dev.c:5267 __do_softirq+0x2fb/0xb7d kernel/softirq.c:284 Memory state around the buggy address: ffff88003713bd00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffff88003713bd80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc >ffff88003713be00: fc fc fc fc fc fc fc fc fc fc fb fb fb fb fb fb ^ Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-22dccp: Unlock sock before calling sk_free()Arnaldo Carvalho de Melo
[ Upstream commit d5afb6f9b6bb2c57bd0c05e76e12489dc0d037d9 ] The code where sk_clone() came from created a new socket and locked it, but then, on the error path didn't unlock it. This problem stayed there for a long while, till b0691c8ee7c2 ("net: Unlock sock before calling sk_free()") fixed it, but unfortunately the callers of sk_clone() (now sk_clone_locked()) were not audited and the one in dccp_create_openreq_child() remained. Now in the age of the syskaller fuzzer, this was finally uncovered, as reported by Dmitry: ---- 8< ---- I've got the following report while running syzkaller fuzzer on 86292b33d4b7 ("Merge branch 'akpm' (patches from Andrew)") [ BUG: held lock freed! ] 4.10.0+ #234 Not tainted ------------------------- syz-executor6/6898 is freeing memory ffff88006286cac0-ffff88006286d3b7, with a lock still held there! (slock-AF_INET6){+.-...}, at: [<ffffffff8362c2c9>] spin_lock include/linux/spinlock.h:299 [inline] (slock-AF_INET6){+.-...}, at: [<ffffffff8362c2c9>] sk_clone_lock+0x3d9/0x12c0 net/core/sock.c:1504 5 locks held by syz-executor6/6898: #0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff839a34b4>] lock_sock include/net/sock.h:1460 [inline] #0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff839a34b4>] inet_stream_connect+0x44/0xa0 net/ipv4/af_inet.c:681 #1: (rcu_read_lock){......}, at: [<ffffffff83bc1c2a>] inet6_csk_xmit+0x12a/0x5d0 net/ipv6/inet6_connection_sock.c:126 #2: (rcu_read_lock){......}, at: [<ffffffff8369b424>] __skb_unlink include/linux/skbuff.h:1767 [inline] #2: (rcu_read_lock){......}, at: [<ffffffff8369b424>] __skb_dequeue include/linux/skbuff.h:1783 [inline] #2: (rcu_read_lock){......}, at: [<ffffffff8369b424>] process_backlog+0x264/0x730 net/core/dev.c:4835 #3: (rcu_read_lock){......}, at: [<ffffffff83aeb5c0>] ip6_input_finish+0x0/0x1700 net/ipv6/ip6_input.c:59 #4: (slock-AF_INET6){+.-...}, at: [<ffffffff8362c2c9>] spin_lock include/linux/spinlock.h:299 [inline] #4: (slock-AF_INET6){+.-...}, at: [<ffffffff8362c2c9>] sk_clone_lock+0x3d9/0x12c0 net/core/sock.c:1504 Fix it just like was done by b0691c8ee7c2 ("net: Unlock sock before calling sk_free()"). Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Cong Wang <xiyou.wangcong@gmail.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170301153510.GE15145@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-22tcp/dccp: block BH for SYN processingEric Dumazet
[ Upstream commit 449809a66c1d0b1563dee84493e14bf3104d2d7e ] SYN processing really was meant to be handled from BH. When I got rid of BH blocking while processing socket backlog in commit 5413d1babe8f ("net: do not block BH while processing socket backlog"), I forgot that a malicious user could transition to TCP_LISTEN from a state that allowed (SYN) packets to be parked in the socket backlog while socket is owned by the thread doing the listen() call. Sure enough syzkaller found this and reported the bug ;) ================================= [ INFO: inconsistent lock state ] 4.10.0+ #60 Not tainted --------------------------------- inconsistent {IN-SOFTIRQ-W} -> {SOFTIRQ-ON-W} usage. syz-executor0/5090 [HC0[0]:SC0[0]:HE1:SE1] takes: (&(&hashinfo->ehash_locks[i])->rlock){+.?...}, at: [<ffffffff83a6a370>] spin_lock include/linux/spinlock.h:299 [inline] (&(&hashinfo->ehash_locks[i])->rlock){+.?...}, at: [<ffffffff83a6a370>] inet_ehash_insert+0x240/0xad0 net/ipv4/inet_hashtables.c:407 {IN-SOFTIRQ-W} state was registered at: mark_irqflags kernel/locking/lockdep.c:2923 [inline] __lock_acquire+0xbcf/0x3270 kernel/locking/lockdep.c:3295 lock_acquire+0x241/0x580 kernel/locking/lockdep.c:3753 __raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline] _raw_spin_lock+0x33/0x50 kernel/locking/spinlock.c:151 spin_lock include/linux/spinlock.h:299 [inline] inet_ehash_insert+0x240/0xad0 net/ipv4/inet_hashtables.c:407 reqsk_queue_hash_req net/ipv4/inet_connection_sock.c:753 [inline] inet_csk_reqsk_queue_hash_add+0x1b7/0x2a0 net/ipv4/inet_connection_sock.c:764 tcp_conn_request+0x25cc/0x3310 net/ipv4/tcp_input.c:6399 tcp_v4_conn_request+0x157/0x220 net/ipv4/tcp_ipv4.c:1262 tcp_rcv_state_process+0x802/0x4130 net/ipv4/tcp_input.c:5889 tcp_v4_do_rcv+0x56b/0x940 net/ipv4/tcp_ipv4.c:1433 tcp_v4_rcv+0x2e12/0x3210 net/ipv4/tcp_ipv4.c:1711 ip_local_deliver_finish+0x4ce/0xc40 net/ipv4/ip_input.c:216 NF_HOOK include/linux/netfilter.h:257 [inline] ip_local_deliver+0x1ce/0x710 net/ipv4/ip_input.c:257 dst_input include/net/dst.h:492 [inline] ip_rcv_finish+0xb1d/0x2110 net/ipv4/ip_input.c:396 NF_HOOK include/linux/netfilter.h:257 [inline] ip_rcv+0xd90/0x19c0 net/ipv4/ip_input.c:487 __netif_receive_skb_core+0x1ad1/0x3400 net/core/dev.c:4179 __netif_receive_skb+0x2a/0x170 net/core/dev.c:4217 netif_receive_skb_internal+0x1d6/0x430 net/core/dev.c:4245 napi_skb_finish net/core/dev.c:4602 [inline] napi_gro_receive+0x4e6/0x680 net/core/dev.c:4636 e1000_receive_skb drivers/net/ethernet/intel/e1000/e1000_main.c:4033 [inline] e1000_clean_rx_irq+0x5e0/0x1490 drivers/net/ethernet/intel/e1000/e1000_main.c:4489 e1000_clean+0xb9a/0x2910 drivers/net/ethernet/intel/e1000/e1000_main.c:3834 napi_poll net/core/dev.c:5171 [inline] net_rx_action+0xe70/0x1900 net/core/dev.c:5236 __do_softirq+0x2fb/0xb7d kernel/softirq.c:284 invoke_softirq kernel/softirq.c:364 [inline] irq_exit+0x19e/0x1d0 kernel/softirq.c:405 exiting_irq arch/x86/include/asm/apic.h:658 [inline] do_IRQ+0x81/0x1a0 arch/x86/kernel/irq.c:250 ret_from_intr+0x0/0x20 native_safe_halt+0x6/0x10 arch/x86/include/asm/irqflags.h:53 arch_safe_halt arch/x86/include/asm/paravirt.h:98 [inline] default_idle+0x8f/0x410 arch/x86/kernel/process.c:271 arch_cpu_idle+0xa/0x10 arch/x86/kernel/process.c:262 default_idle_call+0x36/0x60 kernel/sched/idle.c:96 cpuidle_idle_call kernel/sched/idle.c:154 [inline] do_idle+0x348/0x440 kernel/sched/idle.c:243 cpu_startup_entry+0x18/0x20 kernel/sched/idle.c:345 start_secondary+0x344/0x440 arch/x86/kernel/smpboot.c:272 verify_cpu+0x0/0xfc irq event stamp: 1741 hardirqs last enabled at (1741): [<ffffffff84d49d77>] __raw_spin_unlock_irqrestore include/linux/spinlock_api_smp.h:160 [inline] hardirqs last enabled at (1741): [<ffffffff84d49d77>] _raw_spin_unlock_irqrestore+0xf7/0x1a0 kernel/locking/spinlock.c:191 hardirqs last disabled at (1740): [<ffffffff84d4a732>] __raw_spin_lock_irqsave include/linux/spinlock_api_smp.h:108 [inline] hardirqs last disabled at (1740): [<ffffffff84d4a732>] _raw_spin_lock_irqsave+0xa2/0x110 kernel/locking/spinlock.c:159 softirqs last enabled at (1738): [<ffffffff84d4deff>] __do_softirq+0x7cf/0xb7d kernel/softirq.c:310 softirqs last disabled at (1571): [<ffffffff84d4b92c>] do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902 other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&(&hashinfo->ehash_locks[i])->rlock); <Interrupt> lock(&(&hashinfo->ehash_locks[i])->rlock); *** DEADLOCK *** 1 lock held by syz-executor0/5090: #0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff83406b43>] lock_sock include/net/sock.h:1460 [inline] #0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffff83406b43>] sock_setsockopt+0x233/0x1e40 net/core/sock.c:683 stack backtrace: CPU: 1 PID: 5090 Comm: syz-executor0 Not tainted 4.10.0+ #60 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: __dump_stack lib/dump_stack.c:15 [inline] dump_stack+0x292/0x398 lib/dump_stack.c:51 print_usage_bug+0x3ef/0x450 kernel/locking/lockdep.c:2387 valid_state kernel/locking/lockdep.c:2400 [inline] mark_lock_irq kernel/locking/lockdep.c:2602 [inline] mark_lock+0xf30/0x1410 kernel/locking/lockdep.c:3065 mark_irqflags kernel/locking/lockdep.c:2941 [inline] __lock_acquire+0x6dc/0x3270 kernel/locking/lockdep.c:3295 lock_acquire+0x241/0x580 kernel/locking/lockdep.c:3753 __raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline] _raw_spin_lock+0x33/0x50 kernel/locking/spinlock.c:151 spin_lock include/linux/spinlock.h:299 [inline] inet_ehash_insert+0x240/0xad0 net/ipv4/inet_hashtables.c:407 reqsk_queue_hash_req net/ipv4/inet_connection_sock.c:753 [inline] inet_csk_reqsk_queue_hash_add+0x1b7/0x2a0 net/ipv4/inet_connection_sock.c:764 dccp_v6_conn_request+0xada/0x11b0 net/dccp/ipv6.c:380 dccp_rcv_state_process+0x51e/0x1660 net/dccp/input.c:606 dccp_v6_do_rcv+0x213/0x350 net/dccp/ipv6.c:632 sk_backlog_rcv include/net/sock.h:896 [inline] __release_sock+0x127/0x3a0 net/core/sock.c:2052 release_sock+0xa5/0x2b0 net/core/sock.c:2539 sock_setsockopt+0x60f/0x1e40 net/core/sock.c:1016 SYSC_setsockopt net/socket.c:1782 [inline] SyS_setsockopt+0x2fb/0x3a0 net/socket.c:1765 entry_SYSCALL_64_fastpath+0x1f/0xc2 RIP: 0033:0x4458b9 RSP: 002b:00007fe8b26c2b58 EFLAGS: 00000292 ORIG_RAX: 0000000000000036 RAX: ffffffffffffffda RBX: 0000000000000006 RCX: 00000000004458b9 RDX: 000000000000001a RSI: 0000000000000001 RDI: 0000000000000006 RBP: 00000000006e2110 R08: 0000000000000010 R09: 0000000000000000 R10: 00000000208c3000 R11: 0000000000000292 R12: 0000000000708000 R13: 0000000020000000 R14: 0000000000001000 R15: 0000000000000000 Fixes: 5413d1babe8f ("net: do not block BH while processing socket backlog") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Acked-by: Soheil Hassas Yeganeh <soheil@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-26dccp: fix freeing skb too early for IPV6_RECVPKTINFOAndrey Konovalov
[ Upstream commit 5edabca9d4cff7f1f2b68f0bac55ef99d9798ba4 ] In the current DCCP implementation an skb for a DCCP_PKT_REQUEST packet is forcibly freed via __kfree_skb in dccp_rcv_state_process if dccp_v6_conn_request successfully returns. However, if IPV6_RECVPKTINFO is set on a socket, the address of the skb is saved to ireq->pktopts and the ref count for skb is incremented in dccp_v6_conn_request, so skb is still in use. Nevertheless, it gets freed in dccp_rcv_state_process. Fix by calling consume_skb instead of doing goto discard and therefore calling __kfree_skb. Similar fixes for TCP: fb7e2399ec17f1004c0e0ccfd17439f8759ede01 [TCP]: skb is unexpectedly freed. 0aea76d35c9651d55bbaf746e7914e5f9ae5a25d tcp: SYN packets are now simply consumed Signed-off-by: Andrey Konovalov <andreyknvl@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-18tcp: don't annotate mark on control socket from tcp_v6_send_response()Pablo Neira
commit 92e55f412cffd016cc245a74278cb4d7b89bb3bc upstream. Unlike ipv4, this control socket is shared by all cpus so we cannot use it as scratchpad area to annotate the mark that we pass to ip6_xmit(). Add a new parameter to ip6_xmit() to indicate the mark. The SCTP socket family caches the flowi6 structure in the sctp_transport structure, so we cannot use to carry the mark unless we later on reset it back, which I discarded since it looks ugly to me. Fixes: bf99b4ded5f8 ("tcp: fix mark propagation with fwmark_reflect enabled") Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-29net/dccp: fix use-after-free in dccp_invalid_packetEric Dumazet
pskb_may_pull() can reallocate skb->head, we need to reload dh pointer in dccp_invalid_packet() or risk use after free. Bug found by Andrey Konovalov using syzkaller. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-03ipv6: dccp: add missing bind_conflict to dccp_ipv6_mappedEric Dumazet
While fuzzing kernel with syzkaller, Andrey reported a nasty crash in inet6_bind() caused by DCCP lacking a required method. Fixes: ab1e0a13d7029 ("[SOCK] proto: Add hashinfo member to struct proto") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-03ipv6: dccp: fix out of bound access in dccp_v6_err()Eric Dumazet
dccp_v6_err() does not use pskb_may_pull() and might access garbage. We only need 4 bytes at the beginning of the DCCP header, like TCP, so the 8 bytes pulled in icmpv6_notify() are more than enough. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-03dccp: fix out of bound access in dccp_v4_err()Eric Dumazet
dccp_v4_err() does not use pskb_may_pull() and might access garbage. We only need 4 bytes at the beginning of the DCCP header, like TCP, so the 8 bytes pulled in icmp_socket_deliver() are more than enough. This patch might allow to process more ICMP messages, as some routers are still limiting the size of reflected bytes to 28 (RFC 792), instead of extended lengths (RFC 1812 4.3.2.3) Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-03dccp: do not send reset to already closed socketsEric Dumazet
Andrey reported following warning while fuzzing with syzkaller WARNING: CPU: 1 PID: 21072 at net/dccp/proto.c:83 dccp_set_state+0x229/0x290 Kernel panic - not syncing: panic_on_warn set ... CPU: 1 PID: 21072 Comm: syz-executor Not tainted 4.9.0-rc1+ #293 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 ffff88003d4c7738 ffffffff81b474f4 0000000000000003 dffffc0000000000 ffffffff844f8b00 ffff88003d4c7804 ffff88003d4c7800 ffffffff8140c06a 0000000041b58ab3 ffffffff8479ab7d ffffffff8140beae ffffffff8140cd00 Call Trace: [< inline >] __dump_stack lib/dump_stack.c:15 [<ffffffff81b474f4>] dump_stack+0xb3/0x10f lib/dump_stack.c:51 [<ffffffff8140c06a>] panic+0x1bc/0x39d kernel/panic.c:179 [<ffffffff8111125c>] __warn+0x1cc/0x1f0 kernel/panic.c:542 [<ffffffff8111144c>] warn_slowpath_null+0x2c/0x40 kernel/panic.c:585 [<ffffffff8389e5d9>] dccp_set_state+0x229/0x290 net/dccp/proto.c:83 [<ffffffff838a0aa2>] dccp_close+0x612/0xc10 net/dccp/proto.c:1016 [<ffffffff8316bf1f>] inet_release+0xef/0x1c0 net/ipv4/af_inet.c:415 [<ffffffff82b6e89e>] sock_release+0x8e/0x1d0 net/socket.c:570 [<ffffffff82b6e9f6>] sock_close+0x16/0x20 net/socket.c:1017 [<ffffffff815256ad>] __fput+0x29d/0x720 fs/file_table.c:208 [<ffffffff81525bb5>] ____fput+0x15/0x20 fs/file_table.c:244 [<ffffffff811727d8>] task_work_run+0xf8/0x170 kernel/task_work.c:116 [< inline >] exit_task_work include/linux/task_work.h:21 [<ffffffff8111bc53>] do_exit+0x883/0x2ac0 kernel/exit.c:828 [<ffffffff811221fe>] do_group_exit+0x10e/0x340 kernel/exit.c:931 [<ffffffff81143c94>] get_signal+0x634/0x15a0 kernel/signal.c:2307 [<ffffffff81054aad>] do_signal+0x8d/0x1a30 arch/x86/kernel/signal.c:807 [<ffffffff81003a05>] exit_to_usermode_loop+0xe5/0x130 arch/x86/entry/common.c:156 [< inline >] prepare_exit_to_usermode arch/x86/entry/common.c:190 [<ffffffff81006298>] syscall_return_slowpath+0x1a8/0x1e0 arch/x86/entry/common.c:259 [<ffffffff83fc1a62>] entry_SYSCALL_64_fastpath+0xc0/0xc2 Dumping ftrace buffer: (ftrace buffer empty) Kernel Offset: disabled Fix this the same way we did for TCP in commit 565b7b2d2e63 ("tcp: do not send reset to already closed sockets") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-03dccp: do not release listeners too soonEric Dumazet
Andrey Konovalov reported following error while fuzzing with syzkaller : IPv4: Attempt to release alive inet socket ffff880068e98940 kasan: CONFIG_KASAN_INLINE enabled kasan: GPF could be caused by NULL-ptr deref or user memory access general protection fault: 0000 [#1] SMP KASAN Modules linked in: CPU: 1 PID: 3905 Comm: a.out Not tainted 4.9.0-rc3+ #333 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff88006b9e0000 task.stack: ffff880068770000 RIP: 0010:[<ffffffff819ead5f>] [<ffffffff819ead5f>] selinux_socket_sock_rcv_skb+0xff/0x6a0 security/selinux/hooks.c:4639 RSP: 0018:ffff8800687771c8 EFLAGS: 00010202 RAX: ffff88006b9e0000 RBX: 1ffff1000d0eee3f RCX: 1ffff1000d1d312a RDX: 1ffff1000d1d31a6 RSI: dffffc0000000000 RDI: 0000000000000010 RBP: ffff880068777360 R08: 0000000000000000 R09: 0000000000000002 R10: dffffc0000000000 R11: 0000000000000006 R12: ffff880068e98940 R13: 0000000000000002 R14: ffff880068777338 R15: 0000000000000000 FS: 00007f00ff760700(0000) GS:ffff88006cd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000020008000 CR3: 000000006a308000 CR4: 00000000000006e0 Stack: ffff8800687771e0 ffffffff812508a5 ffff8800686f3168 0000000000000007 ffff88006ac8cdfc ffff8800665ea500 0000000041b58ab3 ffffffff847b5480 ffffffff819eac60 ffff88006b9e0860 ffff88006b9e0868 ffff88006b9e07f0 Call Trace: [<ffffffff819c8dd5>] security_sock_rcv_skb+0x75/0xb0 security/security.c:1317 [<ffffffff82c2a9e7>] sk_filter_trim_cap+0x67/0x10e0 net/core/filter.c:81 [<ffffffff82b81e60>] __sk_receive_skb+0x30/0xa00 net/core/sock.c:460 [<ffffffff838bbf12>] dccp_v4_rcv+0xdb2/0x1910 net/dccp/ipv4.c:873 [<ffffffff83069d22>] ip_local_deliver_finish+0x332/0xad0 net/ipv4/ip_input.c:216 [< inline >] NF_HOOK_THRESH ./include/linux/netfilter.h:232 [< inline >] NF_HOOK ./include/linux/netfilter.h:255 [<ffffffff8306abd2>] ip_local_deliver+0x1c2/0x4b0 net/ipv4/ip_input.c:257 [< inline >] dst_input ./include/net/dst.h:507 [<ffffffff83068500>] ip_rcv_finish+0x750/0x1c40 net/ipv4/ip_input.c:396 [< inline >] NF_HOOK_THRESH ./include/linux/netfilter.h:232 [< inline >] NF_HOOK ./include/linux/netfilter.h:255 [<ffffffff8306b82f>] ip_rcv+0x96f/0x12f0 net/ipv4/ip_input.c:487 [<ffffffff82bd9fb7>] __netif_receive_skb_core+0x1897/0x2a50 net/core/dev.c:4213 [<ffffffff82bdb19a>] __netif_receive_skb+0x2a/0x170 net/core/dev.c:4251 [<ffffffff82bdb493>] netif_receive_skb_internal+0x1b3/0x390 net/core/dev.c:4279 [<ffffffff82bdb6b8>] netif_receive_skb+0x48/0x250 net/core/dev.c:4303 [<ffffffff8241fc75>] tun_get_user+0xbd5/0x28a0 drivers/net/tun.c:1308 [<ffffffff82421b5a>] tun_chr_write_iter+0xda/0x190 drivers/net/tun.c:1332 [< inline >] new_sync_write fs/read_write.c:499 [<ffffffff8151bd44>] __vfs_write+0x334/0x570 fs/read_write.c:512 [<ffffffff8151f85b>] vfs_write+0x17b/0x500 fs/read_write.c:560 [< inline >] SYSC_write fs/read_write.c:607 [<ffffffff81523184>] SyS_write+0xd4/0x1a0 fs/read_write.c:599 [<ffffffff83fc02c1>] entry_SYSCALL_64_fastpath+0x1f/0xc2 It turns out DCCP calls __sk_receive_skb(), and this broke when lookups no longer took a reference on listeners. Fix this issue by adding a @refcounted parameter to __sk_receive_skb(), so that sock_put() is used only when needed. Fixes: 3b24d854cb35 ("tcp/dccp: do not touch listener sk_refcnt under synflood") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Andrey Konovalov <andreyknvl@google.com> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-29Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - TPM core and driver updates/fixes - IPv6 security labeling (CALIPSO) - Lots of Apparmor fixes - Seccomp: remove 2-phase API, close hole where ptrace can change syscall #" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (156 commits) apparmor: fix SECURITY_APPARMOR_HASH_DEFAULT parameter handling tpm: Add TPM 2.0 support to the Nuvoton i2c driver (NPCT6xx family) tpm: Factor out common startup code tpm: use devm_add_action_or_reset tpm2_i2c_nuvoton: add irq validity check tpm: read burstcount from TPM_STS in one 32-bit transaction tpm: fix byte-order for the value read by tpm2_get_tpm_pt tpm_tis_core: convert max timeouts from msec to jiffies apparmor: fix arg_size computation for when setprocattr is null terminated apparmor: fix oops, validate buffer size in apparmor_setprocattr() apparmor: do not expose kernel stack apparmor: fix module parameters can be changed after policy is locked apparmor: fix oops in profile_unpack() when policy_db is not present apparmor: don't check for vmalloc_addr if kvzalloc() failed apparmor: add missing id bounds check on dfa verification apparmor: allow SYS_CAP_RESOURCE to be sufficient to prlimit another task apparmor: use list_next_entry instead of list_entry_next apparmor: fix refcount race when finding a child profile apparmor: fix ref count leak when profile sha1 hash is read apparmor: check that xindex is in trans_table bounds ...
2016-07-13dccp: limit sk_filter trim to payloadWillem de Bruijn
Dccp verifies packet integrity, including length, at initial rcv in dccp_invalid_packet, later pulls headers in dccp_enqueue_skb. A call to sk_filter in-between can cause __skb_pull to wrap skb->len. skb_copy_datagram_msg interprets this as a negative value, so (correctly) fails with EFAULT. The negative length is reported in ioctl SIOCINQ or possibly in a DCCP_WARN in dccp_close. Introduce an sk_receive_skb variant that caps how small a filter program can trim packets, and call this in dccp with the header length. Excessively trimmed packets are now processed normally and queued for reception as 0B payloads. Fixes: 7c657876b63c ("[DCCP]: Initial implementation") Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-09dccp: avoid deadlock in dccp_v4_ctl_send_resetEric Dumazet
In the prep work I did before enabling BH while handling socket backlog, I missed two points in DCCP : 1) dccp_v4_ctl_send_reset() uses bh_lock_sock(), assuming BH were blocked. It is not anymore always true. 2) dccp_v4_route_skb() was using __IP_INC_STATS() instead of IP_INC_STATS() A similar fix was done for TCP, in commit 47dcc20a39d0 ("ipv4: tcp: ip_send_unicast_reply() is not BH safe") Fixes: 7309f8821fd6 ("dccp: do not assume DCCP code is non preemptible") Fixes: 5413d1babe8f ("net: do not block BH while processing socket backlog") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-07Merge branch 'stable-4.8' of git://git.infradead.org/users/pcmoore/selinux ↵James Morris
into next
2016-06-27ipv6: Allow request socks to contain IPv6 options.Huw Davies
If set, these will take precedence over the parent's options during both sending and child creation. If they're not set, the parent's options (if any) will be used. This is to allow the security_inet_conn_request() hook to modify the IPv6 options in just the same way that it already may do for IPv4. Signed-off-by: Huw Davies <huw@codeweavers.com> Signed-off-by: Paul Moore <paul@paul-moore.com>
2016-05-02dccp: do not assume DCCP code is non preemptibleEric Dumazet
DCCP uses the generic backlog code, and this will soon be changed to not disable BH when protocol is called back. Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Soheil Hassas Yeganeh <soheil@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-27net: snmp: kill STATS_BH macrosEric Dumazet
There is nothing related to BH in SNMP counters anymore, since linux-3.0. Rename helpers to use __ prefix instead of _BH prefix, for contexts where preemption is disabled. This more closely matches convention used to update percpu variables. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-27net: rename NET_{ADD|INC}_STATS_BH()Eric Dumazet
Rename NET_INC_STATS_BH() to __NET_INC_STATS() and NET_ADD_STATS_BH() to __NET_ADD_STATS() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-27net: rename ICMP6_INC_STATS_BH()Eric Dumazet
Rename ICMP6_INC_STATS_BH() to __ICMP6_INC_STATS() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-27net: rename IP_INC_STATS_BH()Eric Dumazet
Rename IP_INC_STATS_BH() to __IP_INC_STATS(), to better express this is used in non preemptible context. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-27net: rename ICMP_INC_STATS_BH()Eric Dumazet
Rename ICMP_INC_STATS_BH() to __ICMP_INC_STATS() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-27dccp: rename DCCP_INC_STATS_BH()Eric Dumazet
Rename DCCP_INC_STATS_BH() to __DCCP_INC_STATS() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-07net: introduce lockdep_is_held and update various places to use itHannes Frederic Sowa
The socket is either locked if we hold the slock spin_lock for lock_sock_fast and unlock_sock_fast or we own the lock (sk_lock.owned != 0). Check for this and at the same time improve that the current thread/cpu is really holding the lock. Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-04tcp/dccp: do not touch listener sk_refcnt under synfloodEric Dumazet
When a SYNFLOOD targets a non SO_REUSEPORT listener, multiple cpus contend on sk->sk_refcnt and sk->sk_wmem_alloc changes. By letting listeners use SOCK_RCU_FREE infrastructure, we can relax TCP_LISTEN lookup rules and avoid touching sk_refcnt Note that we still use SLAB_DESTROY_BY_RCU rules for other sockets, only listeners are impacted by this change. Peak performance under SYNFLOOD is increased by ~33% : On my test machine, I could process 3.2 Mpps instead of 2.4 Mpps Most consuming functions are now skb_set_owner_w() and sock_wfree() contending on sk->sk_wmem_alloc when cooking SYNACK and freeing them. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-17tcp/dccp: remove obsolete WARN_ON() in icmp handlersEric Dumazet
Now SYN_RECV request sockets are installed in ehash table, an ICMP handler can find a request socket while another cpu handles an incoming packet transforming this SYN_RECV request socket into an ESTABLISHED socket. We need to remove the now obsolete WARN_ON(req->sk), since req->sk is set when a new child is created and added into listener accept queue. If this race happens, the ICMP will do nothing special. Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Ben Lazarus <blazarus@google.com> Reported-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/phy/bcm7xxx.c drivers/net/phy/marvell.c drivers/net/vxlan.c All three conflicts were cases of simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-18tcp/dccp: fix another race at listener dismantleEric Dumazet
Ilya reported following lockdep splat: kernel: ========================= kernel: [ BUG: held lock freed! ] kernel: 4.5.0-rc1-ceph-00026-g5e0a311 #1 Not tainted kernel: ------------------------- kernel: swapper/5/0 is freeing memory ffff880035c9d200-ffff880035c9dbff, with a lock still held there! kernel: (&(&queue->rskq_lock)->rlock){+.-...}, at: [<ffffffff816f6a88>] inet_csk_reqsk_queue_add+0x28/0xa0 kernel: 4 locks held by swapper/5/0: kernel: #0: (rcu_read_lock){......}, at: [<ffffffff8169ef6b>] netif_receive_skb_internal+0x4b/0x1f0 kernel: #1: (rcu_read_lock){......}, at: [<ffffffff816e977f>] ip_local_deliver_finish+0x3f/0x380 kernel: #2: (slock-AF_INET){+.-...}, at: [<ffffffff81685ffb>] sk_clone_lock+0x19b/0x440 kernel: #3: (&(&queue->rskq_lock)->rlock){+.-...}, at: [<ffffffff816f6a88>] inet_csk_reqsk_queue_add+0x28/0xa0 To properly fix this issue, inet_csk_reqsk_queue_add() needs to return to its callers if the child as been queued into accept queue. We also need to make sure listener is still there before calling sk->sk_data_ready(), by holding a reference on it, since the reference carried by the child can disappear as soon as the child is put on accept queue. Reported-by: Ilya Dryomov <idryomov@gmail.com> Fixes: ebb516af60e1 ("tcp/dccp: fix race at listener dismantle phase") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-11inet: refactor inet[6]_lookup functions to take skbCraig Gallek
This is a preliminary step to allow fast socket lookup of SO_REUSEPORT groups. Doing so with a BPF filter will require access to the skb in question. This change plumbs the skb (and offset to payload data) through the call stack to the listening socket lookup implementations where it will be used in a following patch. Signed-off-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-11inet: create IPv6-equivalent inet_hash functionCraig Gallek
In order to support fast lookups for TCP sockets with SO_REUSEPORT, the function that adds sockets to the listening hash set needs to be able to check receive address equality. Since this equality check is different for IPv4 and IPv6, we will need two different socket hashing functions. This patch adds inet6_hash identical to the existing inet_hash function and updates the appropriate references. A following patch will differentiate the two by passing different comparison functions to __inet_hash. Additionally, in order to use the IPv6 address equality function from inet6_hashtables (which is compiled as a built-in object when IPv6 is enabled) it also needs to be in a built-in object file as well. This moves ipv6_rcv_saddr_equal into inet_hashtables to accomplish this. Signed-off-by: Craig Gallek <kraig@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/renesas/ravb_main.c kernel/bpf/syscall.c net/ipv4/ipmr.c All three conflicts were cases of overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-03ipv6: kill sk_dst_lockEric Dumazet
While testing the np->opt RCU conversion, I found that UDP/IPv6 was using a mixture of xchg() and sk_dst_lock to protect concurrent changes to sk->sk_dst_cache, leading to possible corruptions and crashes. ip6_sk_dst_lookup_flow() uses sk_dst_check() anyway, so the simplest way to fix the mess is to remove sk_dst_lock completely, as we did for IPv4. __ip6_dst_store() and ip6_dst_store() share same implementation. sk_setup_caps() being called with socket lock being held or not, we have to use sk_dst_set() instead of __sk_dst_set() Note that I had to move the "np->dst_cookie = rt6_get_cookie(rt);" in ip6_dst_store() before the sk_setup_caps(sk, dst) call. This is because ip6_dst_store() can be called from process context, without any lock held. As soon as the dst is installed in sk->sk_dst_cache, dst can be freed from another cpu doing a concurrent ip6_dst_store() Doing the dst dereference before doing the install is needed to make sure no use after free would trigger. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-02ipv6: add complete rcu protection around np->optEric Dumazet
This patch addresses multiple problems : UDP/RAW sendmsg() need to get a stable struct ipv6_txoptions while socket is not locked : Other threads can change np->opt concurrently. Dmitry posted a syzkaller (http://github.com/google/syzkaller) program desmonstrating use-after-free. Starting with TCP/DCCP lockless listeners, tcp_v6_syn_recv_sock() and dccp_v6_request_recv_sock() also need to use RCU protection to dereference np->opt once (before calling ipv6_dup_options()) This patch adds full RCU protection to np->opt Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-01net: rename SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATAEric Dumazet
This patch is a cleanup to make following patch easier to review. Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA from (struct socket)->flags to a (struct socket_wq)->flags to benefit from RCU protection in sock_wake_async() To ease backports, we rename both constants. Two new helpers, sk_set_bit(int nr, struct sock *sk) and sk_clear_bit(int net, struct sock *sk) are added so that following patch can change their implementation. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-30net: Generalise wq_has_sleeper helperHerbert Xu
The memory barrier in the helper wq_has_sleeper is needed by just about every user of waitqueue_active. This patch generalises it by making it take a wait_queue_head_t directly. The existing helper is renamed to skwq_has_sleeper. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-02tcp/dccp: fix ireq->pktopts raceEric Dumazet
IPv6 request sockets store a pointer to skb containing the SYN packet to be able to transfer it to full blown socket when 3WHS is done (ireq->pktopts -> np->pktoptions) As explained in commit 5e0724d027f0 ("tcp/dccp: fix hashdance race for passive sessions"), we must transfer the skb only if we won the hashdance race, if multiple cpus receive the 'ack' packet completing 3WHS at the same time. Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets") Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-01Use 64-bit timekeepingTina Ruchandani
This patch changes the use of struct timespec in dccp_probe to use struct timespec64 instead. timespec uses a 32-bit seconds field which will overflow in the year 2038 and beyond. timespec64 uses a 64-bit seconds field. Note that the correctness of the code isn't changed, since the original code only uses the timestamps to compute a small elapsed interval. This patch is part of a larger attempt to remove instances of 32-bit timekeeping structures (timespec, timeval, time_t) from the kernel so it is easier to identify where the real 2038 issues are. Signed-off-by: Tina Ruchandani <ruchandani.tina@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-23tcp/dccp: fix hashdance race for passive sessionsEric Dumazet
Multiple cpus can process duplicates of incoming ACK messages matching a SYN_RECV request socket. This is a rare event under normal operations, but definitely can happen. Only one must win the race, otherwise corruption would occur. To fix this without adding new atomic ops, we use logic in inet_ehash_nolisten() to detect the request was present in the same ehash bucket where we try to insert the new child. If request socket was not found, we have to undo the child creation. This actually removes a spin_lock()/spin_unlock() pair in reqsk_queue_unlink() for the fast path. Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets") Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-16tcp/dccp: add inet_csk_reqsk_queue_drop_and_put() helperEric Dumazet
Let's reduce the confusion about inet_csk_reqsk_queue_drop() : In many cases we also need to release reference on request socket, so add a helper to do this, reducing code size and complexity. Fixes: 4bdc3d66147b ("tcp/dccp: fix behavior of stale SYN_RECV request sockets") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
