path: root/net/dccp
2015-06-15sock_diag: specify info_size per inet protocolCraig Gallek
Previously, there was no clear distinction between the inet protocols that used struct tcp_info to report information and those that didn't. This change adds a specific size attribute to the inet_diag_handler struct which defines these interfaces. This will make dispatching sock_diag get_info requests identical for all inet protocols in a following patch. Tested: ss -au Tested: ss -at Signed-off-by: Craig Gallek <kraig@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-24inet: fix possible panic in reqsk_queue_unlink()Eric Dumazet
[ 3897.923145] BUG: unable to handle kernel NULL pointer dereference at 0000000000000080 [ 3897.931025] IP: [<ffffffffa9f27686>] reqsk_timer_handler+0x1a6/0x243 There is a race when reqsk_timer_handler() and tcp_check_req() call inet_csk_reqsk_queue_unlink() on the same req at the same time. Before commit fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer"), listener spinlock was held and race could not happen. To solve this bug, we change reqsk_queue_unlink() to not assume req must be found, and we return a status, to conditionally release a refcount on the request sock. This also means tcp_check_req() in non fastopen case might or not consume req refcount, so tcp_v6_hnd_req() & tcp_v4_hnd_req() have to properly handle this. (Same remark for dccp_check_req() and its callers) inet_csk_reqsk_queue_drop() is now too big to be inlined, as it is called 4 times in tcp and 3 times in dccp. Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-13tcp/dccp: get rid of central timewait timerEric Dumazet
Using a timer wheel for timewait sockets was nice ~15 years ago when memory was expensive and machines had a single processor. This does not scale, code is ugly and source of huge latencies (Typically 30 ms have been seen, cpus spinning on death_lock spinlock.) We can afford to use an extra 64 bytes per timewait sock and spread timewait load to all cpus to have better behavior. Tested: On following test, /proc/sys/net/ipv4/tcp_tw_recycle is set to 1 on the target (lpaa24) Before patch : lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 419594 lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 437171 While test is running, we can observe 25 or even 33 ms latencies. lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23 ... 1000 packets transmitted, 1000 received, 0% packet loss, time 20601ms rtt min/avg/max/mdev = 0.020/0.217/25.771/1.535 ms, pipe 2 lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23 ... 1000 packets transmitted, 1000 received, 0% packet loss, time 20702ms rtt min/avg/max/mdev = 0.019/0.183/33.761/1.441 ms, pipe 2 After patch : About 90% increase of throughput : lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 810442 lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0 800992 And latencies are kept to minimal values during this load, even if network utilization is 90% higher : lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23 ... 1000 packets transmitted, 1000 received, 0% packet loss, time 19991ms rtt min/avg/max/mdev = 0.023/0.064/0.360/0.042 ms Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23inet: fix double request socket freeingFan Du
Eric Hugne reported following error : I'm hitting this warning on latest net-next when i try to SSH into a machine with eth0 added to a bridge (but i think the problem is older than that) Steps to reproduce: node2 ~ # brctl addif br0 eth0 [ 223.758785] device eth0 entered promiscuous mode node2 ~ # ip link set br0 up [ 244.503614] br0: port 1(eth0) entered forwarding state [ 244.505108] br0: port 1(eth0) entered forwarding state node2 ~ # [ 251.160159] ------------[ cut here ]------------ [ 251.160831] WARNING: CPU: 0 PID: 3 at include/net/request_sock.h:102 tcp_v4_err+0x6b1/0x720() [ 251.162077] Modules linked in: [ 251.162496] CPU: 0 PID: 3 Comm: ksoftirqd/0 Not tainted 4.0.0-rc3+ #18 [ 251.163334] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 251.164078] ffffffff81a8365c ffff880038a6ba18 ffffffff8162ace4 0000000000009898 [ 251.165084] 0000000000000000 ffff880038a6ba58 ffffffff8104da85 ffff88003fa437c0 [ 251.166195] ffff88003fa437c0 ffff88003fa74e00 ffff88003fa43bb8 ffff88003fad99a0 [ 251.167203] Call Trace: [ 251.167533] [<ffffffff8162ace4>] dump_stack+0x45/0x57 [ 251.168206] [<ffffffff8104da85>] warn_slowpath_common+0x85/0xc0 [ 251.169239] [<ffffffff8104db65>] warn_slowpath_null+0x15/0x20 [ 251.170271] [<ffffffff81559d51>] tcp_v4_err+0x6b1/0x720 [ 251.171408] [<ffffffff81630d03>] ? _raw_read_lock_irq+0x3/0x10 [ 251.172589] [<ffffffff81534e20>] ? inet_del_offload+0x40/0x40 [ 251.173366] [<ffffffff81569295>] icmp_socket_deliver+0x65/0xb0 [ 251.174134] [<ffffffff815693a2>] icmp_unreach+0xc2/0x280 [ 251.174820] [<ffffffff8156a82d>] icmp_rcv+0x2bd/0x3a0 [ 251.175473] [<ffffffff81534ea2>] ip_local_deliver_finish+0x82/0x1e0 [ 251.176282] [<ffffffff815354d8>] ip_local_deliver+0x88/0x90 [ 251.177004] [<ffffffff815350f0>] ip_rcv_finish+0xf0/0x310 [ 251.177693] [<ffffffff815357bc>] ip_rcv+0x2dc/0x390 [ 251.178336] [<ffffffff814f5da3>] __netif_receive_skb_core+0x713/0xa20 [ 251.179170] [<ffffffff814f7fca>] __netif_receive_skb+0x1a/0x80 [ 251.179922] [<ffffffff814f97d4>] process_backlog+0x94/0x120 [ 251.180639] [<ffffffff814f9612>] net_rx_action+0x1e2/0x310 [ 251.181356] [<ffffffff81051267>] __do_softirq+0xa7/0x290 [ 251.182046] [<ffffffff81051469>] run_ksoftirqd+0x19/0x30 [ 251.182726] [<ffffffff8106cc23>] smpboot_thread_fn+0x153/0x1d0 [ 251.183485] [<ffffffff8106cad0>] ? SyS_setgroups+0x130/0x130 [ 251.184228] [<ffffffff8106935e>] kthread+0xee/0x110 [ 251.184871] [<ffffffff81069270>] ? kthread_create_on_node+0x1b0/0x1b0 [ 251.185690] [<ffffffff81631108>] ret_from_fork+0x58/0x90 [ 251.186385] [<ffffffff81069270>] ? kthread_create_on_node+0x1b0/0x1b0 [ 251.187216] ---[ end trace c947fc7b24e42ea1 ]--- [ 259.542268] br0: port 1(eth0) entered forwarding state Remove the double calls to reqsk_put() [edumazet] : I got confused because reqsk_timer_handler() _has_ to call reqsk_put(req) after calling inet_csk_reqsk_queue_drop(), as the timer handler holds a reference on req. Signed-off-by: Fan Du <fan.du@intel.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Erik Hugne <erik.hugne@ericsson.com> Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer") Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23ipv6: dccp: handle ICMP messages on DCCP_NEW_SYN_RECV request socketsEric Dumazet
dccp_v6_err() can restrict lookups to ehash table, and not to listeners. Note this patch creates the infrastructure, but this means that ICMP messages for request sockets are ignored until complete conversion. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23ipv4: dccp: handle ICMP messages on DCCP_NEW_SYN_RECV request socketsEric Dumazet
dccp_v4_err() can restrict lookups to ehash table, and not to listeners. Note this patch creates the infrastructure, but this means that ICMP messages for request sockets are ignored until complete conversion. New dccp_req_err() helper is exported so that we can use it in IPv6 in following patch. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23inet: remove sk_listener parameter from syn_ack_timeout()Eric Dumazet
It is not needed, and req->sk_listener points to the listener anyway. request_sock argument can be const. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20inet: get rid of central tcp/dccp listener timerEric Dumazet
One of the major issue for TCP is the SYNACK rtx handling, done by inet_csk_reqsk_queue_prune(), fired by the keepalive timer of a TCP_LISTEN socket. This function runs for awful long times, with socket lock held, meaning that other cpus needing this lock have to spin for hundred of ms. SYNACK are sent in huge bursts, likely to cause severe drops anyway. This model was OK 15 years ago when memory was very tight. We now can afford to have a timer per request sock. Timer invocations no longer need to lock the listener, and can be run from all cpus in parallel. With following patch increasing somaxconn width to 32 bits, I tested a listener with more than 4 million active request sockets, and a steady SYNFLOOD of ~200,000 SYN per second. Host was sending ~830,000 SYNACK per second. This is ~100 times more what we could achieve before this patch. Later, we will get rid of the listener hash and use ehash instead. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20inet: drop prev pointer handling in request sockEric Dumazet
When request sock are put in ehash table, the whole notion of having a previous request to update dl_next is pointless. Also, following patch will get rid of big purge timer, so we want to delete a request sock without holding listener lock. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18inet: request sock should init IPv6/IPv4 addressesEric Dumazet
In order to be able to use sk_ehashfn() for request socks, we need to initialize their IPv6/IPv4 addresses. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18ipv6: get rid of __inet6_hash()Eric Dumazet
We can now use inet_hash() and __inet_hash() instead of private functions. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18inet: add IPv6 support to sk_ehashfn()Eric Dumazet
Intent is to converge IPv4 & IPv6 inet_hash functions to factorize code. IPv4 sockets initialize sk_rcv_saddr and sk_v6_daddr in this patch, thanks to new sk_daddr_set() and sk_rcv_saddr_set() helpers. __inet6_hash can now use sk_ehashfn() instead of a private inet6_sk_ehashfn() and will simply use __inet_hash() in a following patch. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-17inet: add sk_listener argument to inet_reqsk_alloc()Eric Dumazet
listener socket can be used to set net pointer, and will be later used to hold a reference on listener. Add a const qualifier to first argument (struct request_sock_ops *), and factorize all write_pnet(&ireq->ireq_net, sock_net(sk)); Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-14inet: fill request sock ir_iif for IPv4Eric Dumazet
Once request socks will be in ehash table, they will need to have a valid ir_iff field. This is currently true only for IPv6. This patch extends support for IPv4 as well. This means inet_diag_fill_req() can now properly use ir_iif, which is better for IPv6 link locals anyway, as request sockets and established sockets will propagate consistent netlink idiag_if. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-12inet: introduce ireq_familyEric Dumazet
Before inserting request socks into general hash table, fill their socket family. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-12ipv6: add missing ireq_net & ir_cookie initializationsEric Dumazet
I forgot to update dccp_v6_conn_request() & cookie_v6_check(). They both need to set ireq->ireq_net and ireq->ir_cookie Lets clear ireq->ir_cookie in inet_reqsk_alloc() Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 33cf7c90fe2f ("net: add real socket cookies") Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-11net: fix CONFIG_NET_NS=n compilationEric Dumazet
I forgot to use write_pnet() in three locations. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 33cf7c90fe2f9 ("net: add real socket cookies") Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-11net: add real socket cookiesEric Dumazet
A long standing problem in netlink socket dumps is the use of kernel socket addresses as cookies. 1) It is a security concern. 2) Sockets can be reused quite quickly, so there is no guarantee a cookie is used once and identify a flow. 3) request sock, establish sock, and timewait socks for a given flow have different cookies. Part of our effort to bring better TCP statistics requires to switch to a different allocator. In this patch, I chose to use a per network namespace 64bit generator, and to use it only in the case a socket needs to be dumped to netlink. (This might be refined later if needed) Note that I tried to carry cookies from request sock, to establish sock, then timewait sockets. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Eric Salo <salo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-10inet_diag: add const to inet_diag_req_v2Eric Dumazet
diag dumpers should not modify the request. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10net: introduce helper macro for_each_cmsghdrGu Zheng
Introduce helper macro for_each_cmsghdr as a wrapper of the enumerating cmsghdr from msghdr, just cleanup. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-24new helper: memcpy_from_msg()Al Viro
2014-11-18dccp: spelling s/reseting/resettingFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18dccp: replace min/casting by min_tFabian Frederick
2014-11-18dccp: remove blank lines between function/EXPORT_SYMBOLFabian Frederick
See Documentation/CodingStyle chapter 6. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18dccp: kerneldoc warning fixesFabian Frederick
2014-11-08dccp: Convert DCCP_WARN to net_warn_ratelimitedJoe Perches
Remove the dependency on the "warning" sysctl (net_msg_warn) which is only used by the LIMIT_NETDEBUG macro. Convert the LIMIT_NETDEBUG use in DCCP_WARN to the more common net_warn_ratelimited mechanism. This still ratelimits based on the net_ratelimit() function, but removes the check for the sysctl. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-05net: Add and use skb_copy_datagram_msg() helper.David S. Miller
This encapsulates all of the skb_copy_datagram_iovec() callers with call argument signature "skb, offset, msghdr->msg_iov, length". When we move to iov_iters in the networking, the iov_iter object will sit in the msghdr. Having a helper like this means there will be less places to touch during that transformation. Based upon descriptions and patch from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Include fixes for netrom and dsa (Fabian Frederick and Florian Fainelli) 2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO. 3) Several SKB use after free fixes (vxlan, openvswitch, vxlan, ip_tunnel, fou), from Li ROngQing. 4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy. 5) Use after free in virtio_net, from Michael S Tsirkin. 6) Fix flow mask handling for megaflows in openvswitch, from Pravin B Shelar. 7) ISDN gigaset and capi bug fixes from Tilman Schmidt. 8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin. 9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov. 10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong Wang and Eric Dumazet. 11) Don't overwrite end of SKB when parsing malformed sctp ASCONF chunks, from Daniel Borkmann. 12) Don't call sock_kfree_s() with NULL pointers, this function also has the side effect of adjusting the socket memory usage. From Cong Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits) bna: fix skb->truesize underestimation net: dsa: add includes for ethtool and phy_fixed definitions openvswitch: Set flow-key members. netrom: use linux/uaccess.h dsa: Fix conversion from host device to mii bus tipc: fix bug in bundled buffer reception ipv6: introduce tcp_v6_iif() sfc: add support for skb->xmit_more r8152: return -EBUSY for runtime suspend ipv4: fix a potential use after free in fou.c ipv4: fix a potential use after free in ip_tunnel_core.c hyperv: Add handling of IP header with option field in netvsc_set_hash() openvswitch: Create right mask with disabled megaflows vxlan: fix a free after use openvswitch: fix a use after free ipv4: dst_entry leak in ip_send_unicast_reply() ipv4: clean up cookie_v4_check() ipv4: share tcp_v4_save_options() with cookie_v4_check() ipv4: call __ip_options_echo() in cookie_v4_check() atm: simplify lanai.c by using module_pci_driver ...
2014-10-17ipv6: introduce tcp_v6_iif()Eric Dumazet
Commit 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses") added a regression for SO_BINDTODEVICE on IPv6. This is because we still use inet6_iif() which expects that IP6 control block is still at the beginning of skb->cb[] This patch adds tcp_v6_iif() helper and uses it where necessary. Because __inet6_lookup_skb() is used by TCP and DCCP, we add an iif parameter to it. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses") Acked-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-10Merge branch 'for-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: "A lot of activities on percpu front. Notable changes are... - percpu allocator now can take @gfp. If @gfp doesn't contain GFP_KERNEL, it tries to allocate from what's already available to the allocator and a work item tries to keep the reserve around certain level so that these atomic allocations usually succeed. This will replace the ad-hoc percpu memory pool used by blk-throttle and also be used by the planned blkcg support for writeback IOs. Please note that I noticed a bug in how @gfp is interpreted while preparing this pull request and applied the fix 6ae833c7fe0c ("percpu: fix how @gfp is interpreted by the percpu allocator") just now. - percpu_ref now uses longs for percpu and global counters instead of ints. It leads to more sparse packing of the percpu counters on 64bit machines but the overhead should be negligible and this allows using percpu_ref for refcnting pages and in-memory objects directly. - The switching between percpu and single counter modes of a percpu_ref is made independent of putting the base ref and a percpu_ref can now optionally be initialized in single or killed mode. This allows avoiding percpu shutdown latency for cases where the refcounted objects may be synchronously created and destroyed in rapid succession with only a fraction of them reaching fully operational status (SCSI probing does this when combined with blk-mq support). It's also planned to be used to implement forced single mode to detect underflow more timely for debugging. There's a separate branch percpu/for-3.18-consistent-ops which cleans up the duplicate percpu accessors. That branch causes a number of conflicts with s390 and other trees. I'll send a separate pull request w/ resolutions once other branches are merged" * 'for-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (33 commits) percpu: fix how @gfp is interpreted by the percpu allocator blk-mq, percpu_ref: start q->mq_usage_counter in atomic mode percpu_ref: make INIT_ATOMIC and switch_to_atomic() sticky percpu_ref: add PERCPU_REF_INIT_* flags percpu_ref: decouple switching to percpu mode and reinit percpu_ref: decouple switching to atomic mode and killing percpu_ref: add PCPU_REF_DEAD percpu_ref: rename things to prepare for decoupling percpu/atomic mode switch percpu_ref: replace pcpu_ prefix with percpu_ percpu_ref: minor code and comment updates percpu_ref: relocate percpu_ref_reinit() Revert "blk-mq, percpu_ref: implement a kludge for SCSI blk-mq stall during probe" Revert "percpu: free percpu allocation info for uniprocessor system" percpu-refcount: make percpu_ref based on longs instead of ints percpu-refcount: improve WARN messages percpu: fix locking regression in the failure path of pcpu_alloc() percpu-refcount: add @gfp to percpu_ref_init() proportions: add @gfp to init functions percpu_counter: add @gfp to percpu_counter_init() percpu_counter: make percpu_counters_lock irq-safe ...
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Most notable changes in here: 1) By far the biggest accomplishment, thanks to a large range of contributors, is the addition of multi-send for transmit. This is the result of discussions back in Chicago, and the hard work of several individuals. Now, when the ->ndo_start_xmit() method of a driver sees skb->xmit_more as true, it can choose to defer the doorbell telling the driver to start processing the new TX queue entires. skb->xmit_more means that the generic networking is guaranteed to call the driver immediately with another SKB to send. There is logic added to the qdisc layer to dequeue multiple packets at a time, and the handling mis-predicted offloads in software is now done with no locks held. Finally, pktgen is extended to have a "burst" parameter that can be used to test a multi-send implementation. Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4, virtio_net Adding support is almost trivial, so export more drivers to support this optimization soon. I want to thank, in no particular or implied order, Jesper Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann, David Tat, Hannes Frederic Sowa, and Rusty Russell. 2) PTP and timestamping support in bnx2x, from Michal Kalderon. 3) Allow adjusting the rx_copybreak threshold for a driver via ethtool, and add rx_copybreak support to enic driver. From Govindarajulu Varadarajan. 4) Significant enhancements to the generic PHY layer and the bcm7xxx driver in particular (EEE support, auto power down, etc.) from Florian Fainelli. 5) Allow raw buffers to be used for flow dissection, allowing drivers to determine the optimal "linear pull" size for devices that DMA into pools of pages. The objective is to get exactly the necessary amount of headers into the linear SKB area pre-pulled, but no more. The new interface drivers use is eth_get_headlen(). From WANG Cong, with driver conversions (several had their own by-hand duplicated implementations) by Alexander Duyck and Eric Dumazet. 6) Support checksumming more smoothly and efficiently for encapsulations, and add "foo over UDP" facility. From Tom Herbert. 7) Add Broadcom SF2 switch driver to DSA layer, from Florian Fainelli. 8) eBPF now can load programs via a system call and has an extensive testsuite. Alexei Starovoitov and Daniel Borkmann. 9) Major overhaul of the packet scheduler to use RCU in several major areas such as the classifiers and rate estimators. From John Fastabend. 10) Add driver for Intel FM10000 Ethernet Switch, from Alexander Duyck. 11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric Dumazet. 12) Add Datacenter TCP congestion control algorithm support, From Florian Westphal. 13) Reorganize sk_buff so that __copy_skb_header() is significantly faster. From Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits) netlabel: directly return netlbl_unlabel_genl_init() net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers net: description of dma_cookie cause make xmldocs warning cxgb4: clean up a type issue cxgb4: potential shift wrapping bug i40e: skb->xmit_more support net: fs_enet: Add NAPI TX net: fs_enet: Remove non NAPI RX r8169:add support for RTL8168EP net_sched: copy exts->type in tcf_exts_change() wimax: convert printk to pr_foo() af_unix: remove 0 assignment on static ipv6: Do not warn for informational ICMP messages, regardless of type. Update Intel Ethernet Driver maintainers list bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING tipc: fix bug in multicast congestion handling net: better IFF_XMIT_DST_RELEASE support net/mlx4_en: remove NETDEV_TX_BUSY 3c59x: fix bad split of cpu_to_le32(pci_map_single()) net: bcmgenet: fix Tx ring priority programming ...
2014-10-07Merge tag 'dmaengine-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine updates from Dan Williams: "Even though this has fixes marked for -stable, given the size and the needed conflict resolutions this is 3.18-rc1/merge-window material. These patches have been languishing in my tree for a long while. The fact that I do not have the time to do proper/prompt maintenance of this tree is a primary factor in the decision to step down as dmaengine maintainer. That and the fact that the bulk of drivers/dma/ activity is going through Vinod these days. The net_dma removal has not been in -next. It has developed simple conflicts against mainline and net-next (for-3.18). Continuing thanks to Vinod for staying on top of drivers/dma/. Summary: 1/ Step down as dmaengine maintainer see commit 08223d80df38 "dmaengine maintainer update" 2/ Removal of net_dma, as it has been marked 'broken' since 3.13 (commit 77873803363c "net_dma: mark broken"), without reports of performance regression. 3/ Miscellaneous fixes" * tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine: net: make tcp_cleanup_rbuf private net_dma: revert 'copied_early' net_dma: simple removal dmaengine maintainer update dmatest: prevent memory leakage on error path in thread ioat: Use time_before_jiffies() dmaengine: fix xor sources continuation dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup() dma: mv_xor: Remove all callers of mv_xor_slot_cleanup() dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call ioat: Use pci_enable_msix_exact() instead of pci_enable_msix() drivers: dma: Include appropriate header file in dca.c drivers: dma: Mark functions as static in dma_v3.c dma: mv_xor: Add DMA API error checks ioat/dca: Use dev_is_pci() to check whether it is pci device
2014-10-01net/dccp/ccid.c: add __init to ccid_activateFabian Frederick
ccid_activate is only called by __init ccid_initialize_builtins in same module. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-01net/dccp/proto.c: add __init to dccp_mib_initFabian Frederick
dccp_mib_init is only called by __init dccp_init in same module. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-28ipv6: add a struct inet6_skb_parm param to ipv6_opt_accepted()Eric Dumazet
ipv6_opt_accepted() assumes IP6CB(skb) holds the struct inet6_skb_parm that it needs. Lets not assume this, as TCP stack might use a different place. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-28net_dma: simple removalDan Williams
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used and there is no plan to fix it. This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards. Reverting the remainder of the net_dma induced changes is deferred to subsequent patches. Marked for stable due to Roman's report of a memory leak in dma_pin_iovec_pages(): https://lkml.org/lkml/2014/9/3/177 Cc: Dave Jiang <dave.jiang@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: David Whipple <whipple@securedatainnovations.ch> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Cc: <stable@vger.kernel.org> Reported-by: Roman Gushchin <klamm@yandex-team.ru> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2014-09-08percpu_counter: add @gfp to percpu_counter_init()Tejun Heo
Percpu allocator now supports allocation mask. Add @gfp to percpu_counter_init() so that !GFP_KERNEL allocation masks can be used with percpu_counters too. We could have left percpu_counter_init() alone and added percpu_counter_init_gfp(); however, the number of users isn't that high and introducing _gfp variants to all percpu data structures would be quite ugly, so let's just do the conversion. This is the one with the most users. Other percpu data structures are a lot easier to convert. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: x86@kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2014-07-01inet: move ipv6only in sock_commonEric Dumazet
When an UDP application switches from AF_INET to AF_INET6 sockets, we have a small performance degradation for IPv4 communications because of extra cache line misses to access ipv6only information. This can also be noticed for TCP listeners, as ipv6_only_sock() is also used from __inet_lookup_listener()->compute_score() This is magnified when SO_REUSEPORT is used. Move ipv6only into struct sock_common so that it is available at no extra cost in lookups. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-27net: remove inet6_reqsk_allocOctavian Purdila
Since pktops is only used for IPv6 only and opts is used for IPv4 only, we can move these fields into a union and this allows us to drop the inet6_reqsk_alloc function as after this change it becomes equivalent with inet_reqsk_alloc. This patch also fixes a kmemcheck issue in the IPv6 stack: the flags field was not annotated after a request_sock was allocated. Signed-off-by: Octavian Purdila <octavian.purdila@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-23net: Eliminate no_check from protoswTom Herbert
It doesn't seem like an protocols are setting anything other than the default, and allowing to arbitrarily disable checksums for a whole protocol seems dangerous. This can be done on a per socket basis. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-22net/dccp/timer.c: use 'u64' instead of 's64' to avoid compiler's warningChen Gang
'dccp_timestamp_seed' is initialized once by ktime_get_real() in dccp_timestamping_init(). It is always less than ktime_get_real() in dccp_timestamp(). Then, ktime_us_delta() in dccp_timestamp() will always return positive number. So can use manual type cast to let compiler and do_div() know about it to avoid warning. The related warning (with allmodconfig under unicore32): CC [M] net/dccp/timer.o net/dccp/timer.c: In function ‘dccp_timestamp’: net/dccp/timer.c:285: warning: comparison of distinct pointer types lacks a cast Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-14dccp: make the request_retries minimum is 1wangweidong
In Documentation/networking/dccp.txt points that request_retries should be greater than 0. So make the extra1 to be &one instead of &zero. Signed-off-by: Wang Weidong <wangweidong1@huawei.com> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-07net: clean up snmp stats codeWANG Cong
commit 8f0ea0fe3a036a47767f9c80e (snmp: reduce percpu needs by 50%) reduced snmp array size to 1, so technically it doesn't have to be an array any more. What's more, after the following commit: commit 933393f58fef9963eac61db8093689544e29a600 Date: Thu Dec 22 11:58:51 2011 -0600 percpu: Remove irqsafe_cpu_xxx variants We simply say that regular this_cpu use must be safe regardless of preemption and interrupt state. That has no material change for x86 and s390 implementations of this_cpu operations. However, arches that do not provide their own implementation for this_cpu operations will now get code generated that disables interrupts instead of preemption. probably no arch wants to have SNMP_ARRAY_SZ == 2. At least after almost 3 years, no one complains. So, just convert the array to a single pointer and remove snmp_mib_init() and snmp_mib_free() as well. Cc: Christoph Lameter <cl@linux.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-15ipv4: add a sock pointer to ip_queue_xmit()Eric Dumazet
ip_queue_xmit() assumes the skb it has to transmit is attached to an inet socket. Commit 31c70d5956fc ("l2tp: keep original skb ownership") changed l2tp to not change skb ownership and thus broke this assumption. One fix is to add a new 'struct sock *sk' parameter to ip_queue_xmit(), so that we do not assume skb->sk points to the socket used by l2tp tunnel. Fixes: 31c70d5956fc ("l2tp: keep original skb ownership") Reported-by: Zhan Jianyu <nasa4836@gmail.com> Tested-by: Zhan Jianyu <nasa4836@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-11net: Fix use after free by removing length arg from sk_data_ready callbacks.David S. Miller
Several spots in the kernel perform a sequence like: skb_queue_tail(&sk->s_receive_queue, skb); sk->sk_data_ready(sk, skb->len); But at the moment we place the SKB onto the socket receive queue it can be consumed and freed up. So this skb->len access is potentially to freed up memory. Furthermore, the skb->len can be modified by the consumer so it is possible that the value isn't accurate. And finally, no actual implementation of this callback actually uses the length argument. And since nobody actually cared about it's value, lots of call sites pass arbitrary values in such as '0' and even '1'. So just remove the length argument from the callback, that way there is no confusion whatsoever and all of these use-after-free cases get fixed as a side effect. Based upon a patch by Eric Dumazet and his suggestion to audit this issue tree-wide. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-16dccp: re-enable debug macroGerrit Renker
dccp tfrc: revert This reverts 6aee49c558de ("dccp: make local variable static") since the variable tfrc_debug is referenced by the tfrc_pr_debug(fmt, ...) macro when TFRC debugging is enabled. If it is enabled, use of the macro produces a compilation error. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13ipv4: introduce hardened ip_no_pmtu_disc modeHannes Frederic Sowa
This new ip_no_pmtu_disc mode only allowes fragmentation-needed errors to be honored by protocols which do more stringent validation on the ICMP's packet payload. This knob is useful for people who e.g. want to run an unmodified DNS server in a namespace where they need to use pmtu for TCP connections (as they are used for zone transfers or fallback for requests) but don't want to use possibly spoofed UDP pmtu information. Currently the whitelisted protocols are TCP, SCTP and DCCP as they check if the returned packet is in the window or if the association is valid. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: John Heffner <johnwheffner@gmail.com> Suggested-by: Florian Weimer <fweimer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04dccp: make local variable staticstephen hemminger
Make DCCP module config variable static, only used in one file. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
