path: root/net/dns_resolver
2018-07-22KEYS: DNS: fix parsing multiple optionsEric Biggers
commit c604cb767049b78b3075497b80ebb8fd530ea2cc upstream. My recent fix for dns_resolver_preparse() printing very long strings was incomplete, as shown by syzbot which still managed to hit the WARN_ONCE() in set_precision() by adding a crafted "dns_resolver" key: precision 50001 too large WARNING: CPU: 7 PID: 864 at lib/vsprintf.c:2164 vsnprintf+0x48a/0x5a0 The bug this time isn't just a printing bug, but also a logical error when multiple options ("#"-separated strings) are given in the key payload. Specifically, when separating an option string into name and value, if there is no value then the name is incorrectly considered to end at the end of the key payload, rather than the end of the current option. This bypasses validation of the option length, and also means that specifying multiple options is broken -- which presumably has gone unnoticed as there is currently only one valid option anyway. A similar problem also applied to option values, as the kstrtoul() when parsing the "dnserror" option will read past the end of the current option and into the next option. Fix these bugs by correctly computing the length of the option name and by copying the option value, null-terminated, into a temporary buffer. Reproducer for the WARN_ONCE() that syzbot hit: perl -e 'print "#A#", "\0" x 50000' | keyctl padd dns_resolver desc @s Reproducer for "dnserror" option being parsed incorrectly (expected behavior is to fail when seeing the unknown option "foo", actual behavior was to read the dnserror value as "1#foo" and fail there): perl -e 'print "#dnserror=1#foo\0"' | keyctl padd dns_resolver desc @s Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: 4a2d789267e0 ("DNS: If the DNS server returns an error, allow that to be cached [ver #2]") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-29KEYS: DNS: limit the length of option stringsEric Biggers
[ Upstream commit 9c438d7a3a52dcc2b9ed095cb87d3a5e83cf7e60 ] Adding a dns_resolver key whose payload contains a very long option name resulted in that string being printed in full. This hit the WARN_ONCE() in set_precision() during the printk(), because printk() only supports a precision of up to 32767 bytes: precision 1000000 too large WARNING: CPU: 0 PID: 752 at lib/vsprintf.c:2189 vsnprintf+0x4bc/0x5b0 Fix it by limiting option strings (combined name + value) to a much more reasonable 128 bytes. The exact limit is arbitrary, but currently the only recognized option is formatted as "dnserror=%lu" which fits well within this limit. Also ratelimit the printks. Reproducer: perl -e 'print "#", "A" x 1000000, "\x00"' | keyctl padd dns_resolver desc @s This bug was found using syzkaller. Reported-by: Mark Rutland <mark.rutland@arm.com> Fixes: 4a2d789267e0 ("DNS: If the DNS server returns an error, allow that to be cached [ver #2]") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: Fix race between updating and finding a negative keyDavid Howells
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream. Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection error into one field such that: (1) The instantiation state can be modified/read atomically. (2) The error can be accessed atomically with the state. (3) The error isn't stored unioned with the payload pointers. This deals with the problem that the state is spread over three different objects (two bits and a separate variable) and reading or updating them atomically isn't practical, given that not only can uninstantiated keys change into instantiated or rejected keys, but rejected keys can also turn into instantiated keys - and someone accessing the key might not be using any locking. The main side effect of this problem is that what was held in the payload may change, depending on the state. For instance, you might observe the key to be in the rejected state. You then read the cached error, but if the key semaphore wasn't locked, the key might've become instantiated between the two reads - and you might now have something in hand that isn't actually an error code. The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error code if the key is negatively instantiated. The key_is_instantiated() function is replaced with key_is_positive() to avoid confusion as negative keys are also 'instantiated'. Additionally, barriering is included: (1) Order payload-set before state-set during instantiation. (2) Order state-read before payload-read when using the key. Further separate barriering is necessary if RCU is being used to access the payload content after reading the payload pointers. Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data") Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-18net: dns_resolver: convert time_t to time64_tAya Mahfouz
Changes the definition of the pointer _expiry from time_t to time64_t. This is to handle the Y2038 problem where time_t will overflow in the year 2038. The change is safe because the kernel subsystems that call dns_query pass NULL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-21KEYS: Merge the type-specific data with the payload dataDavid Howells
Merge the type-specific data with the payload data into one four-word chunk as it seems pointless to keep them separate. Use user_key_payload() for accessing the payloads of overloaded user-defined keys. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-cifs@vger.kernel.org cc: ecryptfs@vger.kernel.org cc: linux-ext4@vger.kernel.org cc: linux-f2fs-devel@lists.sourceforge.net cc: linux-nfs@vger.kernel.org cc: ceph-devel@vger.kernel.org cc: linux-ima-devel@lists.sourceforge.net
2014-10-01Merge commit 'v3.16' into nextJames Morris
2014-09-16KEYS: Make the key matching functions return boolDavid Howells
Make the key matching functions pointed to by key_match_data::cmp return bool rather than int. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-16KEYS: Remove key_type::match in favour of overriding default by match_preparseDavid Howells
A previous patch added a ->match_preparse() method to the key type. This is allowed to override the function called by the iteration algorithm. Therefore, we can just set a default that simply checks for an exact match of the key description with the original criterion data and allow match_preparse to override it as needed. The key_type::match op is then redundant and can be removed, as can the user_match() function. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-16KEYS: Preparse match dataDavid Howells
Preparse the match data. This provides several advantages: (1) The preparser can reject invalid criteria up front. (2) The preparser can convert the criteria to binary data if necessary (the asymmetric key type really wants to do binary comparison of the key IDs). (3) The preparser can set the type of search to be performed. This means that it's not then a one-off setting in the key type. (4) The preparser can set an appropriate comparator function. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-07-22Merge branch 'keys-fixes' into keys-nextDavid Howells
2014-07-22KEYS: DNS: Use key preparsingDavid Howells
Make use of key preparsing in the DNS resolver so that quota size determination can take place prior to keyring locking when a key is being added. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Jeff Layton <jlayton@primarydata.com>
2014-07-20dns_resolver: Null-terminate the right stringBen Hutchings
*_result[len] is parsed as *(_result[len]) which is not at all what we want to touch here. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Fixes: 84a7c0b1db1c ("dns_resolver: assure that dns_query() result is null-terminated") Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-17KEYS: Allow special keys (eg. DNS results) to be invalidated by CAP_SYS_ADMINDavid Howells
Special kernel keys, such as those used to hold DNS results for AFS, CIFS and NFS and those used to hold idmapper results for NFS, used to be 'invalidateable' with key_revoke(). However, since the default permissions for keys were reduced: Commit: 96b5c8fea6c0861621051290d705ec2e971963f1 KEYS: Reduce initial permissions on keys it has become impossible to do this. Add a key flag (KEY_FLAG_ROOT_CAN_INVAL) that will permit a key to be invalidated by root. This should not be used for system keyrings as the garbage collector will try and remove any invalidate key. For system keyrings, KEY_FLAG_ROOT_CAN_CLEAR can be used instead. After this, from userspace, keyctl_invalidate() and "keyctl invalidate" can be used by any possessor of CAP_SYS_ADMIN (typically root) to invalidate DNS and idmapper keys. Invalidated keys are immediately garbage collected and will be immediately rerequested if needed again. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Steve Dickson <steved@redhat.com>
2014-06-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/core/rtnetlink.c net/core/skbuff.c Both conflicts were very simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-11dns_resolver: assure that dns_query() result is null-terminatedManuel Schölling
dns_query() credulously assumes that keys are null-terminated and returns a copy of a memory block that is off by one. Signed-off-by: Manuel Schölling <manuel.schoelling@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-06-05dns_resolver: Do not accept domain names longer than 255 charsManuel Schölling
According to RFC1035 "[...] the total length of a domain name (i.e., label octets and label length octets) is restricted to 255 octets or less." Signed-off-by: Manuel Schölling <manuel.schoelling@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net/*: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: John Fastabend <john.r.fastabend@intel.com> CC: Alex Duyck <alexander.h.duyck@intel.com> CC: Marcel Holtmann <marcel@holtmann.org> CC: Gustavo Padovan <gustavo@padovan.org> CC: Johan Hedberg <johan.hedberg@gmail.com> CC: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-12net: strict_strtoul is obsolete, use kstrtoul instead“Cosmin
patch found using checkpatch.pl Signed-off-by: Cosmin Stanescu <cosmin90stanescu@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-02Merge branch 'modsign-keys-devel' into security-next-keysDavid Howells
2012-10-02KEYS: Use keyring_alloc() to create special keyringsDavid Howells
Use keyring_alloc() to create special keyrings now that it has a permissions parameter rather than using key_alloc() + key_instantiate_and_link(). Also document and export keyring_alloc() so that modules can use it too. Signed-off-by: David Howells <dhowells@redhat.com>
2012-09-13userns: net: Call key_alloc with GLOBAL_ROOT_UID, GLOBAL_ROOT_GID instead of ↵Eric W. Biederman
0, 0 In net/dns_resolver/dns_key.c and net/rxrpc/ar-key.c make them work with user namespaces enabled where key_alloc takes kuids and kgids. Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID instead of bare 0's. Cc: Sage Weil <sage@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: linux-afs@lists.infradead.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-13KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
2012-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "New notable features: - The seccomp work from Will Drewry - PR_{GET,SET}_NO_NEW_PRIVS from Andy Lutomirski - Longer security labels for Smack from Casey Schaufler - Additional ptrace restriction modes for Yama by Kees Cook" Fix up trivial context conflicts in arch/x86/Kconfig and include/linux/filter.h * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) apparmor: fix long path failure due to disconnected path apparmor: fix profile lookup for unconfined ima: fix filename hint to reflect script interpreter name KEYS: Don't check for NULL key pointer in key_validate() Smack: allow for significantly longer Smack labels v4 gfp flags for security_inode_alloc()? Smack: recursive tramsmute Yama: replace capable() with ns_capable() TOMOYO: Accept manager programs which do not start with / . KEYS: Add invalidation support KEYS: Do LRU discard in full keyrings KEYS: Permit in-place link replacement in keyring list KEYS: Perform RCU synchronisation on keys prior to key destruction KEYS: Announce key type (un)registration KEYS: Reorganise keys Makefile KEYS: Move the key config into security/keys/Kconfig KEYS: Use the compat keyctl() syscall wrapper on Sparc64 for Sparc32 compat Yama: remove an unused variable samples/seccomp: fix dependencies on arch macros Yama: add additional ptrace scopes ...
2012-05-11KEYS: Announce key type (un)registrationDavid Howells
Announce the (un)registration of a key type in the core key code rather than in the callers. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-19KEYS: Allow special keyrings to be clearedDavid Howells
The kernel contains some special internal keyrings, for instance the DNS resolver keyring : 2a93faf1 I----- 1 perm 1f030000 0 0 keyring .dns_resolver: empty It would occasionally be useful to allow the contents of such keyrings to be flushed by root (cache invalidation). Allow a flag to be set on a keyring to mark that someone possessing the sysadmin capability can clear the keyring, even without normal write access to the keyring. Set this flag on the special keyrings created by the DNS resolver, the NFS identity mapper and the CIFS identity mapper. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-17KEYS: Improve /proc/keysDavid Howells
Improve /proc/keys by: (1) Don't attempt to summarise the payload of a negated key. It won't have one. To this end, a helper function - key_is_instantiated() has been added that allows the caller to find out whether the key is positively instantiated (as opposed to being uninstantiated or negatively instantiated). (2) Do show keys that are negative, expired or revoked rather than hiding them. This requires an override flag (no_state_check) to be passed to search_my_process_keyrings() and keyring_search_aux() to suppress this check. Without this, keys that are possessed by the caller, but only grant permissions to the caller if possessed are skipped as the possession check fails. Keys that are visible due to user, group or other checks are visible with or without this patch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-04DNS: Fix a NULL pointer deref when trying to read an error key [CVE-2011-1076]David Howells
When a DNS resolver key is instantiated with an error indication, attempts to read that key will result in an oops because user_read() is expecting there to be a payload - and there isn't one [CVE-2011-1076]. Give the DNS resolver key its own read handler that returns the error cached in key->type_data.x[0] as an error rather than crashing. Also make the kenter() at the beginning of dns_resolver_instantiate() limit the amount of data it prints, since the data is not necessarily NUL-terminated. The buggy code was added in: commit 4a2d789267e00b5a1175ecd2ddefcc78b83fbf09 Author: Wang Lei <wang840925@gmail.com> Date: Wed Aug 11 09:37:58 2010 +0100 Subject: DNS: If the DNS server returns an error, allow that to be cached [ver #2] This can trivially be reproduced by any user with the following program compiled with -lkeyutils: #include <stdlib.h> #include <keyutils.h> #include <err.h> static char payload[] = "#dnserror=6"; int main() { key_serial_t key; key = add_key("dns_resolver", "a", payload, sizeof(payload), KEY_SPEC_SESSION_KEYRING); if (key == -1) err(1, "add_key"); if (keyctl_read(key, NULL, 0) == -1) err(1, "read_key"); return 0; } What should happen is that keyctl_read() reports error 6 (ENXIO) to the user: dns-break: read_key: No such device or address but instead the kernel oopses. This cannot be reproduced with the 'keyutils add' or 'keyutils padd' commands as both of those cut the data down below the NUL termination that must be included in the data. Without this dns_resolver_instantiate() will return -EINVAL and the key will not be instantiated such that it can be read. The oops looks like: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: [<ffffffff811b99f7>] user_read+0x4f/0x8f PGD 3bdf8067 PUD 385b9067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/pci0000:00/0000:00:19.0/irq CPU 0 Modules linked in: Pid: 2150, comm: dns-break Not tainted 2.6.38-rc7-cachefs+ #468 /DG965RY RIP: 0010:[<ffffffff811b99f7>] [<ffffffff811b99f7>] user_read+0x4f/0x8f RSP: 0018:ffff88003bf47f08 EFLAGS: 00010246 RAX: 0000000000000001 RBX: ffff88003b5ea378 RCX: ffffffff81972368 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88003b5ea378 RBP: ffff88003bf47f28 R08: ffff88003be56620 R09: 0000000000000000 R10: 0000000000000395 R11: 0000000000000002 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: ffffffffffffffa1 FS: 00007feab5751700(0000) GS:ffff88003e000000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000010 CR3: 000000003de40000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process dns-break (pid: 2150, threadinfo ffff88003bf46000, task ffff88003be56090) Stack: ffff88003b5ea378 ffff88003b5ea3a0 0000000000000000 0000000000000000 ffff88003bf47f68 ffffffff811b708e ffff88003c442bc8 0000000000000000 00000000004005a0 00007fffba368060 0000000000000000 0000000000000000 Call Trace: [<ffffffff811b708e>] keyctl_read_key+0xac/0xcf [<ffffffff811b7c07>] sys_keyctl+0x75/0xb6 [<ffffffff81001f7b>] system_call_fastpath+0x16/0x1b Code: 75 1f 48 83 7b 28 00 75 18 c6 05 58 2b fb 00 01 be bb 00 00 00 48 c7 c7 76 1c 75 81 e8 13 c2 e9 ff 4c 8b b3 e0 00 00 00 4d 85 ed <41> 0f b7 5e 10 74 2d 4d 85 e4 74 28 e8 98 79 ee ff 49 39 dd 48 RIP [<ffffffff811b99f7>] user_read+0x4f/0x8f RSP <ffff88003bf47f08> CR2: 0000000000000010 Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> cc: Wang Lei <wang840925@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-22Net: dns_resolver: Makefile: Remove deprecated kbuild goal definitionsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-11DNS: If the DNS server returns an error, allow that to be cached [ver #2]Wang Lei
If the DNS server returns an error, allow that to be cached in the DNS resolver key in lieu of a value. Userspace passes the desired error number as an option in the payload: "#dnserror=<number>" Userspace must map h_errno from the name resolution routines to an appropriate Linux error before passing it up. Something like the following mapping is recommended: [HOST_NOT_FOUND] = ENODATA, [TRY_AGAIN] = EAGAIN, [NO_RECOVERY] = ECONNREFUSED, [NO_DATA] = ENODATA, in lieu of Linux errors specifically for representing name service errors. The filesystem must map these errors appropropriately before passing them to userspace. AFS is made to map ENODATA and EAGAIN to EDESTADDRREQ for the return to userspace; ECONNREFUSED is allowed to stand as is. The error can be seen in /proc/keys as a negative number after the description of the key. Compare, for example, the following key entries: 2f97238c I--Q-- 1 53s 3f010000 0 0 dns_resol afsdb:grand.centrall.org: -61 338bfbbe I--Q-- 1 59m 3f010000 0 0 dns_resol afsdb:grand.central.org: 37 If the error option is supplied in the payload, the main part of the payload is discarded. The key should have an expiry time set by userspace. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-06[DNS RESOLVER] Minor typo correctionSteve French
CC: Dave Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-06DNS: Fixes for the DNS query moduleDavid Howells
Fixes for the DNS query module, including: (1) Use 'negative' instead of '-ve' in the documentation. (2) Mark the kdoc comment with '/**' on dns_query(). Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-06cifs: Include linux/err.h for IS_ERR and PTR_ERRStephen Rothwell
Fixes build errors: net/dns_resolver/dns_key.c: In function 'init_dns_resolver': net/dns_resolver/dns_key.c:170: error: implicit declaration of function 'IS_ERR' net/dns_resolver/dns_key.c:171: error: implicit declaration of function 'PTR_ERR' net/dns_resolver/dns_query.c: In function 'dns_query': net/dns_resolver/dns_query.c:126: error: implicit declaration of function 'IS_ERR' net/dns_resolver/dns_query.c:127: error: implicit declaration of function 'PTR_ERR' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-05DNS: Separate out CIFS DNS Resolver codeWang Lei
Separate out the DNS resolver key type from the CIFS filesystem into its own module so that it can be made available for general use, including the AFS filesystem module. This facility makes it possible for the kernel to upcall to userspace to have it issue DNS requests, package up the replies and present them to the kernel in a useful form. The kernel is then able to cache the DNS replies as keys can be retained in keyrings. Resolver keys are of type "dns_resolver" and have a case-insensitive description that is of the form "[<type>:]<domain_name>". The optional <type> indicates the particular DNS lookup and packaging that's required. The <domain_name> is the query to be made. If <type> isn't given, a basic hostname to IP address lookup is made, and the result is stored in the key in the form of a printable string consisting of a comma-separated list of IPv4 and IPv6 addresses. This key type is supported by userspace helpers driven from /sbin/request-key and configured through /etc/request-key.conf. The cifs.upcall utility is invoked for UNC path server name to IP address resolution. The CIFS functionality is encapsulated by the dns_resolve_unc_to_ip() function, which is used to resolve a UNC path to an IP address for CIFS filesystem. This part remains in the CIFS module for now. See the added Documentation/networking/dns_resolver.txt for more information. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
