[ Upstream commit a94c689e6c9e72e722f28339e12dff191ee5a265 ]
If a DSA slave network device was previously disabled, there is no need
to suspend or resume it.
Fixes: 2446254915a7 ("net: dsa: allow switch drivers to implement suspend/resume hooks")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
We cannot be registering the network device first, then setting its
carrier off and finally connecting it to a PHY, doing that leaves a
window during which the carrier is at best inconsistent, and at worse
the device is not usable without a down/up sequence since the network
device is visible to user space with possibly no PHY device attached.
Re-order steps so that they make logical sense. This fixes some devices
where the port was not usable after e.g: an unbind then bind of the
driver.
Fixes: 0071f56e46da ("dsa: Register netdev before phy")
Fixes: 91da11f870f0 ("net: Distributed Switch Architecture protocol support")
Let switch drivers indicate how many TX queues they support. Some
switches, such as Broadcom Starfighter 2 are designed with 8 egress
queues. Future changes will allow us to leverage the queue mapping and
direct the transmission towards a particular queue.
Instead of checking handle, which does not have the inner class
information and drivers wrongly assume clsact->egress as ingress, use
the newly introduced classid identification helpers.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
>From all switchdev devices only DSA requires special FDB dump. This is due
to lack of ability for syncing the hardware learned FDBs with the bridge.
Due to this it is removed from switchdev and moved inside DSA.
Signed-off-by: Arkadi Sharshevsky <arkadis@mellanox.com>
Currently the MDB HW database is synced with the bridge's one, thus,
There is no need to support special dump functionality.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
The bridge port attributes/vlan for DSA devices should be set only
from bridge code. Furthermore, The vlans are synced totally with the
bridge so there is no need for special dump support.
The DSA drivers do not support bridge flags offload. Yet, this attribute
should be added in order for the bridge to fail when one tries set a
flag on the port, as explained in commit dc0ecabd6231 ("net: switchdev:
Add support for querying supported bridge flags by hardware").
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Currently DSA uses switchdev's implementation of FDB add/del ndos. This
patch moves the implementation inside DSA in order to support the legacy
way for static FDB configuration.
Add support for learning FDB through notification. The driver defers
the hardware update via ordered work queue. In case of a successful
FDB add a notification is sent back to bridge.
In case of hw FDB del failure the static FDB will be deleted from
the bridge, thus, the interface is moved to down state in order to
indicate inconsistent situation.
Currently, the switchdev objects are embedded inside the DSA notifier
info. This patch removes this dependency. This is done as a preparation
stage before adding support for learning FDB through the switchdev
notification chain.
The prepare phase for FDB add is unneeded because most of DSA devices
can have failures during bus transactions (SPI, I2C, etc.), thus, the
prepare phase cannot guarantee success of the commit stage.
The support for learning FDB through notification chain, which will be
introduced in the following patches, will provide the ability to notify
back the bridge about successful offload.
dsa_slave_create currently takes 4 arguments while it only needs the
related dsa_port and its name. Remove all other arguments.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Get rid of struct tc_to_netdev which is now just unnecessary container
and rather pass per-type structures down to drivers directly.
Along with that, consolidate the naming of per-type structure variables
in cls_*.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
As ndo_setup_tc is generic offload op for whole tc subsystem, does not
really make sense to have cls-specific args. So move them under
cls_common structurure which is embedded in all cls structs.
Let dsa_slave_setup_tc be a splitter for specific setup_tc types and
push out cls_matchall specific code into a separate function.
In order to be aligned with the rest of the types, rename
TC_SETUP_MATCHALL to TC_SETUP_CLSMATCHALL.
Since the type is always present, push it to be a separate argument to
ndo_setup_tc. On the way, name the type enum and use it for arg type.
During testing with a background iperf pushing 1Gbit/sec worth of
traffic and having both ifconfig and ethtool collect statistics, we
could see quite frequent deadlocks. Convert the often accessed DSA slave
network devices statistics to per-cpu 64-bit statistics to remove these
deadlocks and provide fast efficient statistics updates.
Fixes: f613ed665bb3 ("net: dsa: Add support for 64-bit statistics")
The rest of the helpers are named tcf_exts_*, so change the name of
the action number helpers to be aligned. While at it, change to inline
functions.
DSA slave network devices maintain a pair of bytes and packets counters
for each directions, but these are not 64-bit capable. Re-use
pcpu_sw_netstats which contains exactly what we need for that purpose
and update the code path to report 64-bit capable statistics.
To avoid confusion with the PHY EEE settings, rename the .set_eee and
.get_eee ops to respectively .set_mac_eee and .get_mac_eee.
The DSA switch operations for EEE are only meant to configure a port's
MAC EEE settings. The port's PHY EEE settings are accessed by the DSA
layer and must be made available via a proper PHY driver.
In order to reduce this confusion, remove the phy_device argument from
the .set_eee operation.
All DSA drivers are calling phy_init_eee if eee_enabled is true.
Move up this statement in the DSA layer to simplify the DSA drivers.
qca8k does not require to cache the ethtool_eee structures from now on.
The port's PHY and MAC are both implied in EEE. The current code does
not call the PHY operations if the related device is NULL. Change that
by returning -ENODEV if there's no PHY device attached to the interface.
Introduce a helper function which will return a reference to the CPU
port used in a dsa_switch_tree. Right now this is a singleton, but this
will change once we introduce multi-CPU port support, so ease the
transition by converting the affected code paths.
In preparation for supporting multiple CPU ports with DSA, have the
dsa_port structure know which CPU it is associated with. This will be
important in order to make sure the correct CPU is used for transmission
of the frames. If not for functional reasons, for performance (e.g: load
balancing) and forwarding decisions.
Relocate master_ethtool_ops and master_orig_ethtool_ops into struct
dsa_port in order to be both consistent, and make things self contained
within the dsa_port structure.
This is a preliminary change to supporting multiple CPU port interfaces.
In preparation for supporting multiple CPU ports, remove
dst->master_netdev and ds->master_netdev and replace them with only one
instance of the common object we have for a port: struct
dsa_port::netdev. ds->master_netdev is currently write only and would be
helpful in the case where we have two switches, both with CPU ports, and
also connected within each other, which the multi-CPU port patch series
would address.
While at it, introduce a helper function used in net/dsa/slave.c to
immediately get a reference on the master network device called
dsa_master_netdev().
Make return value void since function never return meaningfull value
Signed-off-by: Yuval Shaia <yuval.shaia@oracle.com>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
We need to push the chain index down to the drivers, so they have the
information to which chain the rule belongs. For now, no driver supports
multichain offload, so only chain 0 is supported. This is needed to
prevent chain squashes during offload for now. Later this will be used
to implement multichain offload.
As of a86d8becc3f0 ("net: dsa: Factor bottom tag receive functions"),
the rcv caller frees the original SKB in case or error.
Be symmetric with that and make the xmit caller do the same.
At the same time, fix the checkpatch NULL comparison check:
CHECK: Comparison to NULL could be written "!nskb"
#208: FILE: net/dsa/tag_trailer.c:35:
+ if (nskb == NULL)
The helper is only used once and makes the code more complicated that it
should. Remove it and reorganize the variables so that it fits on 80
columns.
Move the DSA port code which handles VLAN objects in port.c, where it
belongs.
Move the DSA port code which handles MDB objects in port.c, where it
belongs.
Move the DSA port code which handles FDB objects in port.c, where it
belongs.
Move the DSA port code which sets a port ageing time in port.c, where it
belongs.
Move the DSA port code which sets VLAN filtering on a port in port.c,
where it belongs.
Move the DSA port code which bridges a port in port.c, where it belongs.
Add a new port.c file to hold all DSA port-wide logic. This patch moves
in the code which sets a port state.
Change the scope of the switchdev bridge ageing time attribute setter
from the DSA slave device to the generic DSA port, so that the future
port-wide API can also be used for other port types, such as CPU and DSA
links.
Also ds->ports is now a contiguous array of dsa_port structures, thus
their addresses cannot be NULL. Remove the useless check in
dsa_fastest_ageing_time.
Change the scope of the switchdev VLAN filtering attribute setter from
links.
Change the scope of the switchdev VLAN object handlers from the DSA
slave device to the generic DSA port, so that the future port-wide API
can also be used for other port types, such as CPU and DSA links.
Change the scope of the switchdev MDB object handlers from the DSA slave
device to the generic DSA port, so that the future port-wide API can
Change the scope of the switchdev FDB object handlers from the DSA slave
Now that the bridge join and leave functions only deal with a DSA port,
change their scope from the DSA slave net_device to the DSA generic
dsa_port.
Change the scope of the fabric notification helper from the DSA slave to
the DSA port, since this is a DSA layer specific notion, that can be
used by non-slave ports (CPU and DSA).
Instead of having multiple STP state helpers scoping a slave device
supporting both the DSA logic and the switchdev binding, provide a
single dsa_port_set_state helper scoping a DSA port, as well as its
dsa_port_set_state_now wrapper which skips the prepare phase.
This allows us to better separate the DSA logic from the slave device
handling.
DSA drivers and core use switchdev. Include switchdev.h only once, in
the dsa.h public header, so that inclusion in DSA drivers or forward
declarations of switchdev structures in not necessary anymore.
The public include/net/dsa.h file is meant for DSA drivers, while all
DSA core files share a common private header net/dsa/dsa_priv.h file.
Ensure that dsa_priv.h is the only DSA core file to include net/dsa.h,
and add a new line to separate absolute and relative headers at the same
time.
