commit fc5f33768cca7144f8d793205b229d46740d183b upstream.
The Marvell switches under some conditions will pass a frame to the
host with the port being the CPU port. Such frames are invalid, and
should be dropped. Not dropping them can result in a crash when
incrementing the receive statistics for an invalid port.
This has been reworked for 4.14, which does not have the central
dsa_master_find_slave() function, so each tag driver needs to check.
Reported-by: Chris Healy <cphealy@gmail.com>
Fixes: 91da11f870f0 ("net: Distributed Switch Architecture protocol support")
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Three cases of simple overlapping changes.
Two kfree_skb() should be consume_skb(), to be friend with drop monitor
(perf record ... -e skb:kfree_skb)
The first call of skb_put_padto() will free up the SKB on error, but we
return NULL which tells dsa_slave_xmit() that the original SKB should be
freed so this would lead to a double free here.
The second skb_put_padto() already frees the passed sk_buff reference
upon error, so calling kfree_skb() on it again is not necessary.
Detected by CoverityScan, CID#1416687 ("USE_AFTER_FREE")
Fixes: e71cb9e00922 ("net: dsa: ksz: fix skb freeing")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Woojung Huh <Woojung.Huh@microchip.com>
compile tested only, but saw no warnings/errors with
allmodconfig build.
The DSA layer frees the original skb when an xmit function returns NULL,
meaning an error occurred. But if the tagging code copied the original
skb, it is responsible of freeing the copy if an error occurs.
The ksz tagging code currently has two issues: if skb_put_padto fails,
the skb copy is not freed, and the original skb will be freed twice.
To fix that, move skb_put_padto inside both branches of the skb_tailroom
condition, before freeing the original skb, and free the copy on error.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Reviewed-by: Woojung Huh <woojung.huh@microchip.com>
Introduce a helper function which will return a reference to the CPU
port used in a dsa_switch_tree. Right now this is a singleton, but this
will change once we introduce multi-CPU port support, so ease the
transition by converting the affected code paths.
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
As of a86d8becc3f0 ("net: dsa: Factor bottom tag receive functions"),
the rcv caller frees the original SKB in case or error.
Be symmetric with that and make the xmit caller do the same.
At the same time, fix the checkpatch NULL comparison check:
CHECK: Comparison to NULL could be written "!nskb"
#208: FILE: net/dsa/tag_trailer.c:35:
+ if (nskb == NULL)
function ksz_rcv can be made static as it does not need to be
in global scope. Reformat arguments to make it checkpatch warning
free too.
Cleans up sparse warning: "symbol 'ksz_rcv' was not declared. Should
it be static?"
Adding support for the Microchip KSZ switch family tail tagging.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Woojung Huh <Woojung.Huh@microchip.com>
