commit fc5f33768cca7144f8d793205b229d46740d183b upstream.
The Marvell switches under some conditions will pass a frame to the
host with the port being the CPU port. Such frames are invalid, and
should be dropped. Not dropping them can result in a crash when
incrementing the receive statistics for an invalid port.
This has been reworked for 4.14, which does not have the central
dsa_master_find_slave() function, so each tag driver needs to check.
Reported-by: Chris Healy <cphealy@gmail.com>
Fixes: 91da11f870f0 ("net: Distributed Switch Architecture protocol support")
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
compile tested only, but saw no warnings/errors with
allmodconfig build.
Introduce a helper function which will return a reference to the CPU
port used in a dsa_switch_tree. Right now this is a singleton, but this
will change once we introduce multi-CPU port support, so ease the
transition by converting the affected code paths.
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
As of a86d8becc3f0 ("net: dsa: Factor bottom tag receive functions"),
the rcv caller frees the original SKB in case or error.
Be symmetric with that and make the xmit caller do the same.
At the same time, fix the checkpatch NULL comparison check:
CHECK: Comparison to NULL could be written "!nskb"
#208: FILE: net/dsa/tag_trailer.c:35:
+ if (nskb == NULL)
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Many rcv functions from net/dsa/tag_*.c have a useless out_drop goto
label which simply returns NULL. Kill it in favor of the obvious.
The public include/net/dsa.h file is meant for DSA drivers, while all
DSA core files share a common private header net/dsa/dsa_priv.h file.
Ensure that dsa_priv.h is the only DSA core file to include net/dsa.h,
and add a new line to separate absolute and relative headers at the same
time.
A dsa_switch_tree instance holds a dsa_switch pointer and a port index
to identify the switch port to which the CPU is attached.
Now that the DSA layer has a dsa_port structure to hold this data, use
it to point the switch CPU port.
This patch simply substitutes s/dst->cpu_switch/dst->cpu_dp->ds/ and
s/dst->cpu_port/dst->cpu_dp->index/.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
All DSA tag receive functions do strictly the same thing after they have located
the originating source port from their tag specific protocol:
- push ETH_HLEN bytes
- set pkt_type to PACKET_HOST
- call eth_type_trans()
- bump up counters
- call netif_receive_skb()
Factor all of that into dsa_switch_rcv(). This also makes us return a pointer to
a sk_buff, which makes us symetric with the xmit function.
All DSA tag receive functions need to unshare the skb before mangling it, move
this to the generic dsa_switch_rcv() function which will allow us to make the
tag receive function return their mangled skb without caring about freeing a
NULL skb.
dsa_switch_rcv() already tests for dst == NULL, so there is no need to duplicate
the same check within the tag receive functions.
There is an include loop between netdevice.h, dsa.h, devlink.h because
of NETDEV_ALIGN, making it impossible to use devlink structures in
dsa.h.
Break this loop by taking dsa.h out of netdevice.h, add a forward
declaration of dsa_switch_tree and netdev_set_default_ethtool_ops()
function, which is what netdevice.h requires.
No longer having dsa.h in netdevice.h means the includes in dsa.h no
longer get included. This breaks a few other files which depend on
these includes. Add these directly in the affected file.
Store a pointer to the dsa_port structure in the dsa_slave_priv
structure, instead of the switch/port index.
This will allow to store more information such as the bridge device,
needed in DSA drivers for multi-chip configuration.
Now that the DSA Ethernet switches are true Linux devices, the CPU
switch is not necessarily the first one. If its address is higher than
the second switch on the same MDIO bus, its index will be 1, not 0.
Avoid any confusion by using dst->cpu_switch instead of dst->ds[0].
Add support for the 2-bytes Qualcomm tag that gigabit switches such as
the QCA8337/N might insert when receiving packets, or that we need
to insert while targeting specific switch ports. The tag is inserted
directly behind the ethernet header.
Signed-off-by: John Crispin <john@phrozen.org>
