[ Upstream commit 50c7d2ba9de20f60a2d527ad6928209ef67e4cdd ]
If there are multiple switch trees on the device, only the last one
will be listed, because the arguments of list_add_tail are swapped.
Fixes: 83c0afaec7b7 ("net: dsa: Add new binding implementation")
Signed-off-by: Vivien Didelot <vivien.didelot@gmail.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 68be930249d051fd54d3d99156b3dcadcb2a1f9b ]
BUG: unable to handle kernel paging request at ffffffffa01c5430
PGD 3270067 P4D 3270067 PUD 3271063 PMD 230bc5067 PTE 0
Oops: 0000 [#1
CPU: 0 PID: 6159 Comm: modprobe Not tainted 5.1.0+ #33
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014
RIP: 0010:raw_notifier_chain_register+0x16/0x40
Code: 63 f8 66 90 e9 5d ff ff ff 90 90 90 90 90 90 90 90 90 90 90 55 48 8b 07 48 89 e5 48 85 c0 74 1c 8b 56 10 3b 50 10 7e 07 eb 12 <39> 50 10 7c 0d 48 8d 78 08 48 8b 40 08 48 85 c0 75 ee 48 89 46 08
RSP: 0018:ffffc90001c33c08 EFLAGS: 00010282
RAX: ffffffffa01c5420 RBX: ffffffffa01db420 RCX: 4fcef45928070a8b
RDX: 0000000000000000 RSI: ffffffffa01db420 RDI: ffffffffa01b0068
RBP: ffffc90001c33c08 R08: 000000003e0a33d0 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000094443661 R12: ffff88822c320700
R13: ffff88823109be80 R14: 0000000000000000 R15: ffffc90001c33e78
FS: 00007fab8bd08540(0000) GS:ffff888237a00000(0000) knlGS:0000000000000000
CR2: ffffffffa01c5430 CR3: 00000002297ea000 CR4: 00000000000006f0
Call Trace:
register_netdevice_notifier+0x43/0x250
? 0xffffffffa01e0000
dsa_slave_register_notifier+0x13/0x70 [dsa_core
dsa_init_module+0x2e/0x1000 [dsa_core
do_one_initcall+0x6c/0x3cc
? do_init_module+0x22/0x1f1
? rcu_read_lock_sched_held+0x97/0xb0
? kmem_cache_alloc_trace+0x325/0x3b0
do_init_module+0x5b/0x1f1
load_module+0x1db1/0x2690
? m_show+0x1d0/0x1d0
__do_sys_finit_module+0xc5/0xd0
__x64_sys_finit_module+0x15/0x20
do_syscall_64+0x6b/0x1d0
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Cleanup allocated resourses if there are errors,
otherwise it will trgger memleak.
Fixes: c9eb3e0f8701 ("net: dsa: Add support for learning FDB through notification")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Reviewed-by: Vivien Didelot <vivien.didelot@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit 17ab4f61b8cd6f9c38e9d0b935d86d73b5d0d2b5 ]
The unbalance of master's promiscuity or allmulti will happen after ifdown
and ifup a slave interface which is in a bridge.
When we ifdown a slave interface , both the 'dsa_slave_close' and
'dsa_slave_change_rx_flags' will clear the master's flags. The flags
of master will be decrease twice.
In the other hand, if we ifup the slave interface again, since the
slave's flags were cleared the 'dsa_slave_open' won't set the master's
flag, only 'dsa_slave_change_rx_flags' that triggered by 'br_add_if'
will set the master's flags. The flags of master is increase once.
Only propagating flag changes when a slave interface is up makes
sure this does not happen. The 'vlan_dev_change_rx_flags' had the
same problem and was fixed, and changes here follows that fix.
Fixes: 91da11f870f0 ("net: Distributed Switch Architecture protocol support")
Signed-off-by: Rundong Ge <rdong.ge@gmail.com>
[ Upstream commit a94c689e6c9e72e722f28339e12dff191ee5a265 ]
If a DSA slave network device was previously disabled, there is no need
to suspend or resume it.
Fixes: 2446254915a7 ("net: dsa: allow switch drivers to implement suspend/resume hooks")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 349b71d6f427ff8211adf50839dbbff3f27c1805 ]
When pskb_trim_rcsum fails, the lack of error-handling code may
cause unexpected results.
This patch adds error-handling code after calling pskb_trim_rcsum.
Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com>
commit fc5f33768cca7144f8d793205b229d46740d183b upstream.
The Marvell switches under some conditions will pass a frame to the
host with the port being the CPU port. Such frames are invalid, and
should be dropped. Not dropping them can result in a crash when
incrementing the receive statistics for an invalid port.
This has been reworked for 4.14, which does not have the central
dsa_master_find_slave() function, so each tag driver needs to check.
Reported-by: Chris Healy <cphealy@gmail.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
The current code does not return after successfully preparing the VLAN
addition on every ports member of a it. Fix this.
Fixes: 1ca4aa9cd4cc ("net: dsa: check VLAN capability of every switch")
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
The current code does not return after successfully preparing the MDB
addition on every ports member of a multicast group. Fix this.
Fixes: a1a6b7ea7f2d ("net: dsa: add cross-chip multicast support")
Reported-by: Egil Hjelmeland <privat@egil-hjelmeland.no>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull initial SPDX identifiers from Greg KH:
"License cleanup: add SPDX license identifiers to some files
Update the files which contain no license information with the
'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally
binding shorthand, which can be used instead of the full boiler plate
text.
This patch is based on work done by Thomas Gleixner and Kate Stewart
and Philippe Ombredanne.
How this work was done:
Patches were generated and checked against linux-4.14-rc6 for a subset
of the use cases:
where non-standard license headers were used, and references to
license had to be inferred by heuristics based on keywords.
The analysis to determine which SPDX License Identifier to be applied
to a file was done in a spreadsheet of side by side results from of
the output of two independent scanners (ScanCode & Windriver)
producing SPDX tag:value files created by Philippe Ombredanne.
Philippe prepared the base worksheet, and did an initial spot review
of a few 1000 files.
The 4.13 kernel was the starting point of the analysis with 60,537
files assessed. Kate Stewart did a file by file comparison of the
scanner results in the spreadsheet to determine which SPDX license
identifier(s) to be applied to the file. She confirmed any
determination that was not immediately clear with lawyers working with
the Linux Foundation.
- Make and config files were included as candidates if they contained
>5 lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
Linux-syscall-note" otherwise it was "GPL-2.0". Results of that
was:
- when the two scanners agreed on the detected license(s), that
became the concluded license(s).
- when there was disagreement between the two scanners (one detected
a license but the other didn't, or they both detected different
resulted in a clear resolution of the license that should apply
(and which scanner probably needed to revisit its heuristics).
in time.
source files by Kate, Philippe, Thomas and, in some cases,
confirmation by lawyers working with the Linux Foundation.
disagreed against that SPDX file, to see if there was new insights.
The Windriver scanner is based on an older version of FOSSology in
part, so they are related.
files he inspected. For the non-uapi files Thomas did random spot
checks in about 15000 files.
copy/paste license identifier errors, and have been fixed to reflect
the correct identifier.
inspection and review of the 12,461 patched files from the initial
patch version early this week with:
license ids and scores
- reviewing anything where there was no detection but the patch
license was not GPL-2.0 WITH Linux-syscall-note to ensure that the
generate the patches.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'spdx_identifiers-4.14-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
License cleanup: add SPDX license identifier to uapi header files with a license
License cleanup: add SPDX license identifier to uapi header files with no license
License cleanup: add SPDX GPL-2.0 license identifier to files with no license
the use cases:
lines of source
lines).
GPL-2.0 11139
in time.
they are related.
correct identifier.
In the case of pdata, the dsa_cpu_parse function calls dev_put() before
making sure it isn't NULL. Fix this.
Fixes: 71e0bbde0d88 ("net: dsa: Add support for platform data")
We cannot be registering the network device first, then setting its
carrier off and finally connecting it to a PHY, doing that leaves a
window during which the carrier is at best inconsistent, and at worse
the device is not usable without a down/up sequence since the network
device is visible to user space with possibly no PHY device attached.
Re-order steps so that they make logical sense. This fixes some devices
where the port was not usable after e.g: an unbind then bind of the
driver.
Fixes: 0071f56e46da ("dsa: Register netdev before phy")
We originally used skb->priority but that was not quite correct as this
bitfield needs to contain the egress switch queue we intend to send this
SKB to.
Let switch drivers indicate how many TX queues they support. Some
switches, such as Broadcom Starfighter 2 are designed with 8 egress
queues. Future changes will allow us to leverage the queue mapping and
direct the transmission towards a particular queue.
Three cases of simple overlapping changes.
If we do not have a master network device attached dst->cpu_dp will be
NULL and accessing cpu_dp->netdev will create a trace similar to the one
below. The correct check is on dst->cpu_dp period.
[ 1.004650] DSA: switch 0 0 parsed
[ 1.008078] Unable to handle kernel NULL pointer dereference at
virtual address 00000010
[ 1.016195] pgd = c0003000
[ 1.018918] [00000010] *pgd=80000000004003, *pmd=00000000
[ 1.024349] Internal error: Oops: 206 [#1] SMP ARM
[ 1.029157] Modules linked in:
[ 1.032228] CPU: 0 PID: 1 Comm: swapper/0 Not tainted
4.13.0-rc6-00071-g45b45afab9bd-dirty #7
[ 1.040772] Hardware name: Broadcom STB (Flattened Device Tree)
[ 1.046704] task: ee08f840 task.stack: ee090000
[ 1.051258] PC is at dsa_register_switch+0x5e0/0x9dc
[ 1.056234] LR is at dsa_register_switch+0x5d0/0x9dc
[ 1.061211] pc : [<c08fb28c>] lr : [<c08fb27c>] psr: 60000213
[ 1.067491] sp : ee091d88 ip : 00000000 fp : 0000000c
[ 1.072728] r10: 00000000 r9 : 00000001 r8 : ee208010
[ 1.077965] r7 : ee2b57b0 r6 : ee2b5780 r5 : 00000000 r4 :
ee208e0c
[ 1.084506] r3 : 00000000 r2 : 00040d00 r1 : 2d1b2000 r0 :
00000016
[ 1.091050] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM
Segment user
[ 1.098199] Control: 32c5387d Table: 00003000 DAC: fffffffd
[ 1.103957] Process swapper/0 (pid: 1, stack limit = 0xee090210)
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 6d3c8c0dd88a ("net: dsa: Remove master_netdev and use dst->cpu_dp->netdev")
Two kfree_skb() should be consume_skb(), to be friend with drop monitor
(perf record ... -e skb:kfree_skb)
The first call of skb_put_padto() will free up the SKB on error, but we
return NULL which tells dsa_slave_xmit() that the original SKB should be
freed so this would lead to a double free here.
The second skb_put_padto() already frees the passed sk_buff reference
upon error, so calling kfree_skb() on it again is not necessary.
Detected by CoverityScan, CID#1416687 ("USE_AFTER_FREE")
Fixes: e71cb9e00922 ("net: dsa: ksz: fix skb freeing")
Reviewed-by: Woojung Huh <Woojung.Huh@microchip.com>
compile tested only, but saw no warnings/errors with
allmodconfig build.
The DSA layer frees the original skb when an xmit function returns NULL,
meaning an error occurred. But if the tagging code copied the original
skb, it is responsible of freeing the copy if an error occurs.
The ksz tagging code currently has two issues: if skb_put_padto fails,
the skb copy is not freed, and the original skb will be freed twice.
To fix that, move skb_put_padto inside both branches of the skb_tailroom
condition, before freeing the original skb, and free the copy on error.
Reviewed-by: Woojung Huh <woojung.huh@microchip.com>
Instead of checking handle, which does not have the inner class
information and drivers wrongly assume clsact->egress as ingress, use
the newly introduced classid identification helpers.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
The MT7530 inserts the 4 magic header in between the 802.3 address and
protocol field. The patch implements the callback that can be called by
the flow dissector to figure out the real protocol and offset of the
network header. With this patch applied we can properly parse the packet
and thus make hashing function properly.
Signed-off-by: Muciri Gatimu <muciri@openmesh.com>
Signed-off-by: Shashidhar Lakkavalli <shashidhar.lakkavalli@openmesh.com>
Signed-off-by: John Crispin <john@phrozen.org>
We need to access this struct from within the flow_dissector to fix
dissection for packets coming in on DSA devices.
Save 2628 bytes on arm eabi by allocate only the required 3 ports.
Now that ds->num_ports is correct: In net/dsa/tag_lan9303.c
eliminate duplicate LAN9303_MAX_PORTS, use ds->num_ports.
(Matching the pattern of other net/dsa/tag_xxx.c files.)
Signed-off-by: Egil Hjelmeland <privat@egil-hjelmeland.no>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
>From all switchdev devices only DSA requires special FDB dump. This is due
to lack of ability for syncing the hardware learned FDBs with the bridge.
Due to this it is removed from switchdev and moved inside DSA.
Signed-off-by: Arkadi Sharshevsky <arkadis@mellanox.com>
Currently the MDB HW database is synced with the bridge's one, thus,
There is no need to support special dump functionality.
The bridge port attributes/vlan for DSA devices should be set only
from bridge code. Furthermore, The vlans are synced totally with the
bridge so there is no need for special dump support.
The DSA drivers do not support bridge flags offload. Yet, this attribute
should be added in order for the bridge to fail when one tries set a
flag on the port, as explained in commit dc0ecabd6231 ("net: switchdev:
Add support for querying supported bridge flags by hardware").
Currently DSA uses switchdev's implementation of FDB add/del ndos. This
patch moves the implementation inside DSA in order to support the legacy
way for static FDB configuration.
Add support for learning FDB through notification. The driver defers
the hardware update via ordered work queue. In case of a successful
FDB add a notification is sent back to bridge.
In case of hw FDB del failure the static FDB will be deleted from
the bridge, thus, the interface is moved to down state in order to
indicate inconsistent situation.
Currently, the switchdev objects are embedded inside the DSA notifier
info. This patch removes this dependency. This is done as a preparation
stage before adding support for learning FDB through the switchdev
notification chain.
The prepare phase for FDB add is unneeded because most of DSA devices
can have failures during bus transactions (SPI, I2C, etc.), thus, the
prepare phase cannot guarantee success of the commit stage.
The support for learning FDB through notification chain, which will be
introduced in the following patches, will provide the ability to notify
back the bridge about successful offload.
In order to support FDB add/del to be on a notifier chain the slave
API need to be changed to be switchdev independent.
dsa_slave_create currently takes 4 arguments while it only needs the
related dsa_port and its name. Remove all other arguments.
dsa_cpu_dsa_setup currently takes 4 arguments but they are all available
from the dsa_port argument. Remove all others.
dsa_switch_alloc() already assigns ds-dev, which can be used in
dsa_switch_setup_one and dsa_cpu_dsa_setups instead of requiring an
additional struct device argument.
Get rid of struct tc_to_netdev which is now just unnecessary container
and rather pass per-type structures down to drivers directly.
Along with that, consolidate the naming of per-type structure variables
in cls_*.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
As ndo_setup_tc is generic offload op for whole tc subsystem, does not
really make sense to have cls-specific args. So move them under
cls_common structurure which is embedded in all cls structs.
Let dsa_slave_setup_tc be a splitter for specific setup_tc types and
push out cls_matchall specific code into a separate function.
In order to be aligned with the rest of the types, rename
TC_SETUP_MATCHALL to TC_SETUP_CLSMATCHALL.
Since the type is always present, push it to be a separate argument to
ndo_setup_tc. On the way, name the type enum and use it for arg type.
During testing with a background iperf pushing 1Gbit/sec worth of
traffic and having both ifconfig and ethtool collect statistics, we
could see quite frequent deadlocks. Convert the often accessed DSA slave
network devices statistics to per-cpu 64-bit statistics to remove these
deadlocks and provide fast efficient statistics updates.
Fixes: f613ed665bb3 ("net: dsa: Add support for 64-bit statistics")
The rest of the helpers are named tcf_exts_*, so change the name of
the action number helpers to be aligned. While at it, change to inline
functions.
DSA slave network devices maintain a pair of bytes and packets counters
for each directions, but these are not 64-bit capable. Re-use
pcpu_sw_netstats which contains exactly what we need for that purpose
and update the code path to report 64-bit capable statistics.
To avoid confusion with the PHY EEE settings, rename the .set_eee and
.get_eee ops to respectively .set_mac_eee and .get_mac_eee.
The DSA switch operations for EEE are only meant to configure a port's
MAC EEE settings. The port's PHY EEE settings are accessed by the DSA
layer and must be made available via a proper PHY driver.
In order to reduce this confusion, remove the phy_device argument from
the .set_eee operation.
All DSA drivers are calling phy_init_eee if eee_enabled is true.
Move up this statement in the DSA layer to simplify the DSA drivers.
qca8k does not require to cache the ethtool_eee structures from now on.
The port's PHY and MAC are both implied in EEE. The current code does
not call the PHY operations if the related device is NULL. Change that
by returning -ENODEV if there's no PHY device attached to the interface.
Two minor conflicts in virtio_net driver (bug fix overlapping addition
of a helper) and MAINTAINERS (new driver edit overlapping revamp of
PHY entry).
