path: root/net/dsa
2013-03-25dsa: fix freeing of sparse port allocationFlorian Fainelli
If we have defined a sparse port allocation which is non-contiguous and contains gaps, the code freeing port_names will just stop when it encouters a first NULL port_names, which is not right, we should iterate over all possible number of ports (DSA_MAX_PORTS) until we are done. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-25dsa: factor freeing of dsa_platform_dataFlorian Fainelli
This patch factors the freeing of the struct dsa_platform_data manipulated by the driver identically in two places to a single function. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-24dsa: add device tree bindings to register DSA switchesFlorian Fainelli
This patch adds support for registering DSA switches using Device Tree bindings. Note that we support programming the switch routing table even though no in-tree user seems to require it. I tested this on Armada 370 with a Marvell 88E6172 (not supported by mainline yet). Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-21dsa: make dsa_switch_setup check for valid port namesFlorian Fainelli
This patch changes dsa_switch_setup() to ensure that at least one valid valid port name is specified and will bail out with an error in case we walked the maximum number of port with a valid port name found. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-21dsa: use an unique and non conflicting bus name for the slave MII busFlorian Fainelli
The slave MII bus registered by the DSA code is using the parent MII bus as part of its name (ds->master_mii_bus_id), in case the parent MII bus name is already 16 characters long (such as d0072004.mdio-mi) we will get the following WARN_ON in dsa_switch_setup() when calling mdiobus_register(): [ 79.088782] ------------[ cut here ]------------ [ 79.093448] WARNING: at fs/sysfs/dir.c:536 sysfs_add_one+0x80/0xa0() [ 79.099831] sysfs: cannot create duplicate filename '/class/mdio_bus/d0072004.mdio-mi' This is a genuine warning, because the DSA slave MII bus will also be named d0072004.mdio-mi, and since MII_BUS_ID_SIZE is 17 characters long (with null-terminator) the following will truncate the slave MII bus id: snprintf(ds->slave_mii_bus->id, MII_BUS_ID_SIZE, "%s-%d:%.2x", ds->master_mii_bus->id, ds->pd->sw_addr); Fix this by using dsa-<switch index->:<sw_add> which is guaranteed to be unique. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-14net: phy: remove flags argument from phy_{attach, connect, connect_direct}Florian Fainelli
The flags argument of the phy_{attach,connect,connect_direct} functions is then used to assign a struct phy_device dev_flags with its value. All callers but the tg3 driver pass the flag 0, which results in the underlying PHY drivers in drivers/net/phy/ not being able to actually use any of the flags they would set in dev_flags. This patch gets rid of the flags argument, and passes phydev->dev_flags to the internal PHY library call phy_attach_direct() such that drivers which actually modify a phy device dev_flags get the value preserved for use by the underlying phy driver. Acked-by: Kosta Zertsekel <konszert@marvell.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-26dsa: Hide core config options; make drivers select what they needBen Hutchings
Commit 82167cb8c6b2f8166d5c7532e5ef4b5e0cc46a72 ('net: dsa/slave: Fix compilation warnings') fixed one possible invalid configuration (NET_DSA enabled with no trailer formats) but added others: drivers can select NET_DSA without its dependencies being met. It's not very useful to make either the DSA core or the tagging formats manually selectable without a driver to use them, so: 1. Define a hidden HAVE_NET_DSA option and move the dependencies of NET_DSA to that. While we're at it, drop the deprecated EXPERIMENTAL dependency. 2. Make NET_DSA and the drivers dependent on HAVE_NET_DSA. 3. Hide the tagging format options again. 4. Make drivers select both NET_DSA and the appropriate tagging format option. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-25net: dsa/slave: Fix compilation warningsviresh kumar
Currently when none of CONFIG_NET_DSA_TAG_DSA, CONFIG_NET_DSA_TAG_EDSA and CONFIG_NET_DSA_TAG_TRAILER is defined, we get following compilation warnings: net/dsa/slave.c:51:12: warning: 'dsa_slave_init' defined but not used [-Wunused-function] net/dsa/slave.c:60:12: warning: 'dsa_slave_open' defined but not used [-Wunused-function] net/dsa/slave.c:98:12: warning: 'dsa_slave_close' defined but not used [-Wunused-function] net/dsa/slave.c:116:13: warning: 'dsa_slave_change_rx_flags' defined but not used [-Wunused-function] net/dsa/slave.c:127:13: warning: 'dsa_slave_set_rx_mode' defined but not used [-Wunused-function] net/dsa/slave.c:136:12: warning: 'dsa_slave_set_mac_address' defined but not used [-Wunused-function] net/dsa/slave.c:164:12: warning: 'dsa_slave_ioctl' defined but not used [-Wunused-function] Earlier approach to fix this was discussed here: lkml.org/lkml/2012/10/29/549 This is another approach to fix it. This is done by some changes in config options, which make more sense than the earlier approach. As, atleast one tagging option must always be selected for using net/dsa/ infrastructure, this patch selects NET_DSA from tagging configs instead of having it as an selectable config. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-05-09dsa: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-29dsa: Move switch drivers to new directory drivers/net/dsaBen Hutchings
Support for specific hardware belongs under drivers/net/ not net/. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-29dsa: Move all definitions needed by drivers into <net/dsa.h>Ben Hutchings
Any headers included by drivers should be under include/, and any definitions they use are not really private to the core as the name "dsa_priv.h" suggests. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-29dsa: Remove unnecessary exportsBen Hutchings
I mistakenly exported functions from slave.c that are only called from dsa.c, part of the same module. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-26dsa: Allow core and drivers to be built as modulesBen Hutchings
Change the kconfig types to tristate and adjust the condition for declaring net_device::dsa_ptr to allow for this. Adjust the makefile so that if NET_DSA_MV88E6123_61_65=y and NET_DSA_MV88E6131=m or vice versa then both drivers are built-in. We could leave these options as bool and make NET_DSA_MV88E6XXX a user-selected option, but that would break existing configurations. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-26dsa: Define module author, description, license and aliases for driversBen Hutchings
2011-11-26mv88e6xxx: Combine mv88e6131 and mv88e612_61_65 driversBen Hutchings
These drivers share a lot of code, so if we make them modular they should be built into the same module. Therefore, link them together and merge their respective module init and exit functions. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-26dsa: Combine core and tagging codeBen Hutchings
These files have circular dependencies, so if we make DSA modular then they must be built into the same module. Therefore, link them together and merge their respective module init and exit functions. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-26dsa: Export functions from core to modulesBen Hutchings
2011-11-26dsa: Change dsa_uses_{dsa, trailer}_tags() into inline functionsBen Hutchings
eth_type_trans() will use these functions if DSA is enabled, which blocks building DSA as a module. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Fix files explicitly needing to include module.hPaul Gortmaker
With calls to modular infrastructure, these files really needs the full module.h header. Call it out so some of the cleanups of implicit and unrequired includes elsewhere can be cleaned up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29DSA: Enable cascading in multi-chip 6131 configurationBarry Grussling
This patch enables the 6131 family of chips to forward DSA packets to other switch chips. This is needed if multiple DSA chips are used in a device. Without this patch the chip will drop any DSA packets not destined for it. This patch only enables the forwarding of DSA packets if multiple chips are used in the switch configuration. Signed-off-by: Barry Grussling <barry@grussling.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c
2011-04-28dsa/mv88e6131: fix unknown multicast/broadcast forwarding on mv88e6085Peter Korsgaard
The 88e6085 has a few differences from the other devices in the port control registers, causing unknown multicast/broadcast packets to get dropped when using the standard port setup. At the same time update kconfig to clarify that the mv88e6085 is now supported. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20net: dsa: remove ethtool_ops->set_sgMichał Mirosław
Remove set_sg from DSA slave ethtool_ops. Features inheritance looks broken/not fully implemented anyway. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) net: Add support for SMSC LAN9530, LAN9730 and LAN89530 mlx4_en: Restoring RX buffer pointer in case of failure mlx4: Sensing link type at device initialization ipv4: Fix "Set rt->rt_iif more sanely on output routes." MAINTAINERS: add entry for Xen network backend be2net: Fix suspend/resume operation be2net: Rename some struct members for clarity pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev dsa/mv88e6131: add support for mv88e6085 switch ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2) be2net: Fix a potential crash during shutdown. bna: Fix for handling firmware heartbeat failure can: mcp251x: Allow pass IRQ flags through platform data. smsc911x: fix mac_lock acquision before calling smsc911x_mac_read iwlwifi: accept EEPROM version 0x423 for iwl6000 rt2x00: fix cancelling uninitialized work rtlwifi: Fix some warnings/bugs p54usb: IDs for two new devices wl12xx: fix potential buffer overflow in testmode nvs push zd1211rw: reset rx idle timer from tasklet ...
2011-04-06dsa/mv88e6131: add support for mv88e6085 switchPeter Korsgaard
The mv88e6085 is identical to the mv88e6095, except that all ports are 10/100 Mb/s, so use the existing setup code except for the cpu/dsa speed selection in _setup_port(). Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-08dsa/mv88e6060: support nonzero mii base addressPeter Korsgaard
The mv88e6060 uses either the lower 16 or upper 16 mii addresses, depending on the value of the EE_CLK/ADDR4 pin. Support both configurations by using the sw_addr setting as base address. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24module: fix missing semicolons in MODULE macro usageRusty Russell
You always needed them when you were a module, but the builtin versions of the macros used to be more lenient. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-12-24net/dsa: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. Directly flush dst->link_poll_work on remove instead. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
2010-08-11phylib: available for any speed ethernetRandy Dunlap
Several gigabit network drivers (SB1250_MAC, TIGON3, FSL, GIANFAR, UCC_GETH, MV643XX_ETH, XILINX_LL_TEMAC, S6GMAC, STMMAC_ETH, PASEMI_MAC, and OCTEON_ETHERNET) select PHYLIB. These drivers are not under NET_ETHERNET (10/100 mbit), so this warning is generated (long, irrelevant parts are omitted): warning: (NET_DSA && NET && EXPERIMENTAL && NET_ETHERNET && !S390 || ... || SB1250_MAC && NETDEVICES && NETDEV_1000 && SIBYTE_SB1xxx_SOC || TIGON3 && NETDEVICES && NETDEV_1000 && PCI || FSL_PQ_MDIO && NETDEVICES && NETDEV_1000 && FSL_SOC || GIANFAR && NETDEVICES && NETDEV_1000 && FSL_SOC || UCC_GETH && NETDEVICES && NETDEV_1000 && QUICC_ENGINE || MV643XX_ETH && NETDEVICES && NETDEV_1000 && (MV64X60 || PPC32 || PLAT_ORION) || XILINX_LL_TEMAC && NETDEVICES && NETDEV_1000 && (PPC || MICROBLAZE) || S6GMAC && NETDEVICES && NETDEV_1000 && XTENSA_VARIANT_S6000 || STMMAC_ETH && NETDEV_1000 && NETDEVICES && CPU_SUBTYPE_ST40 || PASEMI_MAC && NETDEVICES && NETDEV_10000 && PPC_PASEMI && PCI || OCTEON_ETHERNET && STAGING && !STAGING_EXCLUDE_BUILD && CPU_CAVIUM_OCTEON) selects PHYLIB which has unmet direct dependencies (!S390 && NET_ETHERNET) PHYLIB is used by non-10/100 mbit ethernet drivers, so change the dependencies to be NETDEVICES instead of NET_ETHERNET. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/vhost/net.c net/bridge/br_device.c Fix merge conflict in drivers/vhost/net.c with guidance from Stephen Rothwell. Revert the effects of net-2.6 commit 573201f36fd9c7c6d5218cdcd9948cee700b277d since net-next-2.6 has fixes that make bridge netpoll work properly thus we don't need it disabled. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12dsa: Fix Kconfig dependencies.David S. Miller
Based upon a report by Randy Dunlap. DSA needs PHYLIB, but PHYLIB needs NET_ETHERNET. So, in order to select PHYLIB we have to make DSA depend upon NET_ETHERNET. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: move address list functions to a separate fileJiri Pirko
+little renaming of unicast functions to be smooth with multicast ones Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-01netdev: convert pseudo-devices to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05dsa: fix 88e6xxx statistics counter snapshottingStephane Contri
The bit that tells us whether a statistics counter snapshot operation has completed is located in the GLOBAL register block, not in the GLOBAL2 register block, so fix up mv88e6xxx_stats_wait() to poll the right register address. Signed-off-by: Stephane Contri <Stephane.Contri@grassvalley.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21dsa: add switch chip cascading supportLennert Buytenhek
The initial version of the DSA driver only supported a single switch chip per network interface, while DSA-capable switch chips can be interconnected to form a tree of switch chips. This patch adds support for multiple switch chips on a network interface. An example topology for a 16-port device with an embedded CPU is as follows: +-----+ +--------+ +--------+ | |eth0 10| switch |9 10| switch | | CPU +----------+ +-------+ | | | | chip 0 | | chip 1 | +-----+ +---++---+ +---++---+ || || || || ||1000baseT ||1000baseT ||ports 1-8 ||ports 9-16 This requires a couple of interdependent changes in the DSA layer: - The dsa platform driver data needs to be extended: there is still only one netdevice per DSA driver instance (eth0 in the example above), but each of the switch chips in the tree needs its own mii_bus device pointer, MII management bus address, and port name array. (include/net/dsa.h) The existing in-tree dsa users need some small changes to deal with this. (arch/arm) - The DSA and Ethertype DSA tagging modules need to be extended to use the DSA device ID field on receive and demultiplex the packet accordingly, and fill in the DSA device ID field on transmit according to which switch chip the packet is heading to. (net/dsa/tag_{dsa,edsa}.c) - The concept of "CPU port", which is the switch chip port that the CPU is connected to (port 10 on switch chip 0 in the example), needs to be extended with the concept of "upstream port", which is the port on the switch chip that will bring us one hop closer to the CPU (port 10 for both switch chips in the example above). - The dsa platform data needs to specify which ports on which switch chips are links to other switch chips, so that we can enable DSA tagging mode on them. (For inter-switch links, we always use non-EtherType DSA tagging, since it has lower overhead. The CPU link uses dsa or edsa tagging depending on what the 'root' switch chip supports.) This is done by specifying "dsa" for the given port in the port array. - The dsa platform data needs to be extended with information on via which port to reach any given switch chip from any given switch chip. This info is specified via the per-switch chip data struct ->rtable[] array, which gives the nexthop ports for each of the other switches in the tree. For the example topology above, the dsa platform data would look something like this: static struct dsa_chip_data sw[2] = { { .mii_bus = &foo, .sw_addr = 1, .port_names[0] = "p1", .port_names[1] = "p2", .port_names[2] = "p3", .port_names[3] = "p4", .port_names[4] = "p5", .port_names[5] = "p6", .port_names[6] = "p7", .port_names[7] = "p8", .port_names[9] = "dsa", .port_names[10] = "cpu", .rtable = (s8 []){ -1, 9, }, }, { .mii_bus = &foo, .sw_addr = 2, .port_names[0] = "p9", .port_names[1] = "p10", .port_names[2] = "p11", .port_names[3] = "p12", .port_names[4] = "p13", .port_names[5] = "p14", .port_names[6] = "p15", .port_names[7] = "p16", .port_names[10] = "dsa", .rtable = (s8 []){ 10, -1, }, }, }, static struct dsa_platform_data pd = { .netdev = &foo, .nr_switches = 2, .sw = sw, }; Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Gary Thomas <gary@mlbassoc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21dsa: add support for the Marvell 88E6095/6095F switch chipsLennert Buytenhek
Add support for the Marvell 88E6095/6095F switch chips. These chips are similar to the 88e6131, so we can add the support to mv88e6131.c easily. Thanks to Gary Thomas <gary@mlbassoc.com> and Jesper Dangaard Brouer <hawk@diku.dk> for testing various patches. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Gary Thomas <gary@mlbassoc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21dsa: set ->iflink on slave interfaces to the ifindex of the parentLennert Buytenhek
..so that we can parse the DSA topology from 'ip link' output: 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast qlen 1000 3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast qlen 1000 4: lan1@eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue 5: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue 6: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue 7: lan4@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06dsa: convert to net_device_ops (v2)Stephen Hemminger
Convert this driver to use net_device_ops Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-10net: Make staticRoel Kluin
Sparse asked whether these could be static. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25dsa: fix warning in net/dsa/mv88e6060.cIngo Molnar
this warning: net/dsa/mv88e6060.c: In function ‘mv88e6060_poll_link’: net/dsa/mv88e6060.c:225: warning: ‘port_status’ may be used uninitialized in this function triggers because GCC does not recognize the (correct) error flow between 'link' and 'port_status'. Annotate it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
