[ Upstream commit 3a89eaa65db68bf53bf92dedc60084f810e1779a ]
The support for DSA Ethernet switch chips depends on TCP/IP networking,
thus explicit that HAVE_NET_DSA depends on INET.
DSA uses SWITCHDEV, thus select it instead of depending on it.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
[ Upstream commit 4078b76cac68e50ccf1f76a74e7d3d5788aec3fe ]
We need to check the return value of phy_connect_direct() in
dsa_slave_phy_connect() otherwise we may be continuing the
initialization of a slave network device with a PHY that already
attached somewhere else and which will soon be in error because the PHY
device is in error.
The conditions for such an error to occur are that we have a port of our
switch that is not disabled, and has the same port number as a PHY
address (say both 5) that can be probed using the DSA slave MII bus. We
end-up having this slave network device find a PHY at the same address
as our port number, and we try to attach to it.
A slave network (e.g: port 0) has already attached to our PHY device,
and we try to re-attach it with a different network device, but since we
ignore the error we would end-up initializating incorrect device
references by the time the slave network interface is opened.
The code has been (re)organized several times, making it hard to provide
an exact Fixes tag, this is a bugfix nonetheless.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit f154be241d22298d2b63c9b613f619fa1086ea75 ]
Commit 448b4482c671 ("net: dsa: Add lockdep class to tx queues to avoid
lockdep splat") removed the netif_device_detach() call done in
dsa_slave_suspend() which is necessary, and paired with a corresponding
netif_device_attach(), bring it back.
Fixes: 448b4482c671 ("net: dsa: Add lockdep class to tx queues to avoid lockdep splat")
Simplify DSA by pushing the switchdev objects for VLAN add and delete
operations down to its drivers. Currently only mv88e6xxx is affected.
No driver implements port_fdb_getnext anymore, and port_fdb_dump is
preferred anyway, so remove this function from DSA.
Not all switch chips support a Get Next operation to iterate on its FDB.
So add a more simple port_fdb_dump function for them.
drivers/net/usb/asix_common.c
net/ipv4/inet_connection_sock.c
net/switchdev/switchdev.c
In the inet_connection_sock.c case the request socket hashing scheme
is completely different in net-next.
The other two conflicts were overlapping changes.
When object is used in deferred work, we cannot use pointers in
switchdev object structures because the memory they point at may be already
used by someone else. So rather do local copy of the value.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: Scott Feldman <sfeldma@gmail.com>
Reviewed-by: John Fastabend <john.r.fastabend@intel.com>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
A DSA driver may not provide the port_join_bridge and port_leave_bridge
functions, so don't warn in such case.
For consistency with the FDB add operation, propagate the
switchdev_obj_port_fdb structure in the DSA drivers.
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Now that the prepare phase is pushed down to the DSA drivers, propagate
it to the port_fdb_add function.
Push the prepare phase for FDB operations down to the DSA drivers, with
a new port_fdb_prepare function. Currently only mv88e6xxx is affected.
If no switch were found in dsa_setup_dst, return -ENODEV and
exit the dsa_probe cleanly.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Now the kfree calls exists in the the remove functions, remove them in all
places except the of_probe functions and replace allocation calls
with their devm_ counterparts.
When unbinding dsa, complete the dsa_switch_destroy to unregister the
fixed link phy then cleanly unregister and destroy the net devices.
To prevent memory leakage on unbinding, add missing mdiobus unregister
and unallocation calls.
To prevent memory leakage on unbinding, add missing kfree calls.
Includes minor cosmetic change to make patch clean.
Add additional error reporting to the generic DSA code, so it's easier
to debug when things go wrong. This was useful when initially bringing
up 88e6176 on a new board.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Suggested-by: Scott Feldman <sfeldma@gmail.com>
Replace "void *obj" with a generic structure. Introduce couple of
helpers along that.
Make the struct name in sync with object id name.
Suggested-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
To be aligned with obj.
Because of the default 0 value of ret in dsa_slave_port_attr_set, a
driver may return -EOPNOTSUPP from the commit phase of a STP state,
which triggers a WARN() from switchdev.
This happened on a 6185 switch which does not support hardware bridging.
Fixes: 3563606258cf ("switchdev: convert STP update to switchdev attr set")
Reported-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Similar to the notifier_call callback of a notifier_block, change the
function signature of switchdev add and del operations to:
int switchdev_port_obj_add/del(struct net_device *dev,
enum switchdev_obj_id id, void *obj);
This allows the caller to pass a specific switchdev_obj_* structure
instead of the generic switchdev_obj one.
Drivers implementation of these operations and switchdev have been
changed accordingly.
function signature of switchdev dump operation to:
int switchdev_port_obj_dump(struct net_device *dev,
enum switchdev_obj_id id, void *obj,
int (*cb)(void *obj));
This allows the caller to pass and expect back a specific
switchdev_obj_* structure instead of the generic switchdev_obj one.
Drivers implementation of dump operation can now expect this specific
structure and call the callback with it. Drivers have been changed
accordingly.
The net_device associated to a dump operation does not have to be passed
to the callback. switchdev stores it in a superset struct, if needed.
Also some drivers (such as DSA drivers) may not have easy access to it.
This will simplify pushing the callback function down to the drivers.
net/ipv4/arp.c
The net/ipv4/arp.c conflict was one commit adding a new
local variable while another commit was deleting one.
Provide a device_type information for slave network devices created by
DSA, this is useful for user-space application to easily locate/search
for devices of a specific kind.
of_find_net_device_by_node() uses class_find_device() internally to
lookup the corresponding network device. class_find_device() returns
a reference to the embedded struct device, with its refcount
incremented.
Add a comment to the definition in net/core/net-sysfs.c indicating the
need to drop this refcount, and fix the DSA code to drop this refcount
when the OF-generated platform data is cleaned up and freed. Also
arrange for the ref to be dropped when handling errors.
Current users of of_mdio_find_bus() leak a struct device refcount, as
they fail to clean up the reference obtained inside class_find_device().
Fix the DSA code to properly refcount the returned MDIO bus by:
1. taking a reference on the struct device whenever we assign it to
pd->chip[x].host_dev.
2. dropping the reference when we overwrite the existing reference.
3. dropping the reference when we free the data structure.
4. dropping the initial reference we obtained after setting up the
platform data structure, or on failure.
In step 2 above, where we obtain a new MDIO bus, there is no need to
take a reference on it as we would only have to drop it immediately
after assignment again, iow:
put_device(cd->host_dev); /* drop original assignment ref */
cd->host_dev = get_device(&mdio_bus_switch->dev); /* get our ref */
put_device(&mdio_bus_switch->dev); /* drop of_mdio_find_bus ref */
The enum is going to disappear, use the helpers instead.
Before it disappears completely, move transaction phase enum under
transaction structure and make attr/obj structures a bit cleaner.
Now, the memory allocation in prepare/commit state is done separatelly
in each driver (rocker). Introduce the similar mechanism in generic
switchdev code, in form of queue. That can be used not only for memory
allocations, but also for different items. Abort item destruction
is handled as well.
This is temporary, name "trans" will be used for something else and
"trans_ph" will eventually disappear.
The Marvell Egress rx trailer check must be fixed to
correctly detect bad bits in the third byte of the
Eggress trailer as described in the Table 28 of the
88E6060 datasheet.
The current code incorrectly omits to check the third
byte and checks the fourth byte twice.
Acked-by: Guenter Roeck <linux@roeck-us.net>
It can be useful for DSA and CPU ports to have a phy-mode property, in
particular to specify RGMII delays. Parse the property and set it in
the fixed-link phydev.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
By default, DSA and CPU ports are configured to the maximum speed the
switch supports. However there can be use cases where the peer devices
port is slower. Allow a fixed-link property to be used with the DSA
and CPU port in the device tree, and use this information to configure
the port.
With more than two switches in a hierarchy, it becomes necessary to
describe multi-hop routes between switches. The current binding does
not allow this, although the older platform_data did. Extend the link
property to be a list rather than a single phandle to a remote switch.
It is then possible to express that a port should be used to reach
more than one switch and the switch maybe more than one hop away.
Signed-off-by: Phil Sutter <phil@nwl.cc>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Add new functions in DSA drivers to access hardware VLAN entries through
SWITCHDEV_OBJ_PORT_VLAN objects:
- port_pvid_get() and vlan_getnext() to dump a VLAN
- port_vlan_del() to exclude a port from a VLAN
- port_pvid_set() and port_vlan_add() to join a port to a VLAN
The DSA infrastructure will ensure that each VLAN of the given range
does not already belong to another bridge. If it does, it will fallback
to software VLAN and won't program the hardware.
drivers/net/ethernet/cavium/Kconfig
The cavium conflict was overlapping dependency
changes.
In case we need to divert reads/writes using the slave MII bus, we may have
already fetched a valid PHY interface property from Device Tree, and that
mode is used by the PHY driver to make configuration decisions.
If we could not fetch the "phy-mode" property, we will assign p->phy_interface
to PHY_INTERFACE_MODE_NA, such that we can actually check for that condition as
to whether or not we should override the interface value.
Fixes: 19334920eaf7 ("net: dsa: Set valid phy interface type")
Implement the switchdev_port_obj_{add,del,dump} functions in DSA to
support the SWITCHDEV_OBJ_PORT_FDB objects.
Change the prototype of port_getnext to include a vid parameter.
This is necessary to introduce the support for VLAN.
Also rename the fdb_{add,del,getnext} function pointers to
port_fdb_{add,del,getnext} since they are specific to a given port.
This reverts commit f1d5ca434413b20cd3f8c18ff2b634b7782149a5, reversing
changes made to 4933d85c5173832ebd261756522095837583c458.
I applied v2 instead of v3.
When using a cluster of switches, some topologies will have an MDIO
bus per switch, not one for the whole cluster. Allow this to be
represented in the device tree, by adding an optional mii-bus property
at the switch level. The old platform_device method of instantiation
supports this already, so only the device tree binding needs extending
with an additional optional phandle.
