[ Upstream commit 4078b76cac68e50ccf1f76a74e7d3d5788aec3fe ]
We need to check the return value of phy_connect_direct() in
dsa_slave_phy_connect() otherwise we may be continuing the
initialization of a slave network device with a PHY that already
attached somewhere else and which will soon be in error because the PHY
device is in error.
The conditions for such an error to occur are that we have a port of our
switch that is not disabled, and has the same port number as a PHY
address (say both 5) that can be probed using the DSA slave MII bus. We
end-up having this slave network device find a PHY at the same address
as our port number, and we try to attach to it.
A slave network (e.g: port 0) has already attached to our PHY device,
and we try to re-attach it with a different network device, but since we
ignore the error we would end-up initializating incorrect device
references by the time the slave network interface is opened.
The code has been (re)organized several times, making it hard to provide
an exact Fixes tag, this is a bugfix nonetheless.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 382e1eea2d983cd2343482c6a638f497bb44a636 ]
dsa_slave_create() can fail, and dsa_user_port_unapply() will properly check
for the network device not being NULL before attempting to destroy it. We were
not setting the slave network device as NULL if dsa_slave_create() failed, so
we would later on be calling dsa_slave_destroy() on a now free'd and
unitialized network device, causing crashes in dsa_slave_destroy().
Fixes: 83c0afaec7b7 ("net: dsa: Add new binding implementation")
[ Upstream commit f154be241d22298d2b63c9b613f619fa1086ea75 ]
Commit 448b4482c671 ("net: dsa: Add lockdep class to tx queues to avoid
lockdep splat") removed the netif_device_detach() call done in
dsa_slave_suspend() which is necessary, and paired with a corresponding
netif_device_attach(), bring it back.
Fixes: 448b4482c671 ("net: dsa: Add lockdep class to tx queues to avoid lockdep splat")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit faf3a932fbeb77860226a8323eacb835edc98648 ]
It is perfectly possible to have non zero indexed switches being present
in a DSA switch tree, in such a case, we will be deferencing a NULL
pointer while dsa_cpu_port_ethtool_{setup,restore}. Be more defensive
and ensure that dst->ds[0] is valid before doing anything with it.
Fixes: 0c73c523cf73 ("net: dsa: Initialize CPU port ethtool ops per tree")
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Make sure to deregister and free any fixed-link PHY registered using
of_phy_register_fixed_link() on slave-setup errors and on slave destroy.
Fixes: 0d8bcdd383b8 ("net: dsa: allow for more complex PHY setups")
Signed-off-by: Johan Hovold <johan@kernel.org>
Add helper to deregister fixed-link PHYs registered using
of_phy_register_fixed_link().
Convert the two drivers that care to deregister their fixed-link PHYs to
use the new helper, but note that most drivers currently fail to do so.
Make sure to drop the reference taken by of_parse_phandle() before
returning from dsa_slave_phy_setup().
Note that this also modifies the PHY priority so that any fixed-link
node is only parsed when no phy-handle is given, which is in accordance
with the common scheme for this.
_dsa_register_switch() gets a dsa_switch_tree object either via
dsa_get_dst() or via dsa_add_dst(). Former path does not increase kref
in returned object (resulting into caller not owning a reference),
while later path does create a new object (resulting into caller owning
a reference).
The rest of _dsa_register_switch() assumes that it owns a reference, and
calls dsa_put_dst().
This causes a memory breakage if first switch in the tree initialized
successfully, but second failed to initialize. In particular, freed
dsa_swith_tree object is left referenced by switch that was initialized,
and later access to sysfs attributes of that switch cause OOPS.
To fix, need to add kref_get() call to dsa_get_dst().
Signed-off-by: Nikita Yushchenko <nikita.yoush@cogentembedded.com>
Make sure to drop the reference taken by of_phy_find_device() when
registering and deregistering the fixed-link PHY-device.
Fixes: 39b0c705195e ("net: dsa: Allow configuration of CPU & DSA port
speeds/duplex")
Today the DSA drivers are in charge of flushing the MAC addresses
associated to a port when its STP state changes from Learning or
Forwarding, to Disabled or Blocking or Listening.
This makes the drivers more complex and hides the generic switch logic.
Introduce a new optional port_fast_age operation to dsa_switch_ops, to
move this logic to the DSA layer and keep drivers simple.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Add a void helper to set the STP state of a port, checking first if the
required routine is provided by the driver.
Only 1 of the 3 drivers currently has a set_addr() operation. Make the
set_addr() callback optional to reduce the amount of empty stubs inside
the drivers.
Signed-off-by: John Crispin <john@phrozen.org>
commit 83c0afaec7b730b ("net: dsa: Add new binding implementation")
has a duplicate invocation of the set_addr() operation callback. Remove one
of them.
Add support for the 2-bytes Qualcomm tag that gigabit switches such as
the QCA8337/N might insert when receiving packets, or that we need
to insert while targeting specific switch ports. The tag is inserted
directly behind the ethernet header.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Add SWITCHDEV_OBJ_ID_PORT_MDB support to the DSA layer.
Now that the dsa_switch_driver structure contains only function pointers
as it is supposed to, rename it to the more appropriate dsa_switch_ops,
uniformly to any other operations structure in the kernel.
No functional changes here, basically just the result of something like:
s/dsa_switch_driver *drv/dsa_switch_ops *ops/g
However keep the {un,}register_switch_driver functions and their
dsa_switch_drivers list as is, since they represent the -- likely to be
deprecated soon -- legacy DSA registration framework.
In the meantime, also fix the following checks from checkpatch.pl to
make it happy with this patch:
CHECK: Comparison to NULL could be written "!ops"
#403: FILE: net/dsa/dsa.c:470:
+ if (ops == NULL) {
CHECK: Comparison to NULL could be written "ds->ops->get_strings"
#773: FILE: net/dsa/slave.c:697:
+ if (ds->ops->get_strings != NULL)
CHECK: Comparison to NULL could be written "ds->ops->get_ethtool_stats"
#824: FILE: net/dsa/slave.c:785:
+ if (ds->ops->get_ethtool_stats != NULL)
CHECK: Comparison to NULL could be written "ds->ops->get_sset_count"
#835: FILE: net/dsa/slave.c:798:
+ if (ds->ops->get_sset_count != NULL)
total: 0 errors, 0 warnings, 4 checks, 784 lines checked
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
DSA drivers may drive different families of switches which need
different tag protocol. Rather than hard code the tag protocol in the
driver structure, have a callback for the DSA core to call.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
The Broadcom Starfighter 2 switch driver should be a proper platform
driver, now that the DSA code has been updated to allow that, register a
switch device, feed it with the proper configuration data coming from
Device Tree and register our switch device with DSA.
The bulk of the changes consist in moving what bcm_sf2_sw_setup() did
into the platform driver probe function.
In preparation for allowing switch drivers to implement system-wide
suspend/resume functions, export dsa_switch_suspend and
dsa_switch_resume() such that these are callable from the appropriate
driver specific suspend/resume functions.
Tested-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Add a new function for DSA drivers to handle the switchdev
SWITCHDEV_ATTR_ID_BRIDGE_AGEING_TIME attribute.
The ageing time is passed as milliseconds.
Also because we can have multiple logical bridges on top of a physical
switch and ageing time are switch-wide, call the driver function with
the fastest ageing time in use on the chip instead of the requested one.
Fixes the following sparse warning:
net/dsa/dsa2.c:680:6: warning:
symbol '_dsa_unregister_switch' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The routing table of every switch in a tree is currently initialized to
all zeros. This is an issue since 0 is a valid port number.
Add a DSA_RTABLE_NONE=-1 constant to initialize the signed values of the
routing table pointing to other switches.
This fixes the device mapping of the mv88e6xxx driver where the port
pointing to the switch itself and to non-existent switches was wrongly
configured to be 0. It is now set to the expected 0xf value.
Now that we can properly support multiple distinct trees in the system,
using a global variable: dsa_cpu_port_ethtool_ops is getting clobbered
as soon as the second switch tree gets probed, and we don't want that.
We need to move this to be dynamically allocated, and since we can't
really be comparing addresses anymore to determine first time
initialization versus any other times, just move this to dsa.c and
dsa2.c where the remainder of the dst/ds initialization happens.
The operations teardown restores the master netdev's ethtool_ops to its
original ethtool_ops pointer (typically within the Ethernet driver)
Add a helper function: dsa_cpu_port_ethtool_init() which initializes a
custom ethtool_ops structure with custom DSA ethtool operations for CPU
ports. This is a preliminary change to move the initialization outside
of net/dsa/slave.c.
Mimic what net/dsa/dsa.c does and provide a slave MII bus by default
which will be created if the driver implements a phy_read method.
Some drivers rely on these two bitmasks to contain the correct values
for them to successfully probe and initialize at drv->setup() time,
calculate correct values to put in both masks as early as possible in
dsa_get_ports_dn().
In case we have multiples trees and switches with the same index, we
need to add another discriminating id: the switch tree.
The existing DSA binding has a number of limitations and problems. The
main problem is that it cannot represent a switch as a linux device,
hanging off some bus. It is limited to one CPU port. The DSA platform
device is artificial, and does not really represent hardware.
Implement a new binding which can be embedded into any type of node on
a bus to represent one switch device, and its links to other switches.
The switch may want to instantiate its own MDIO bus. Only do it
centrally if the switch has not already created one, and the read op
is implemented.
Replace the two switch statements with an array lookup, and store the
result in the dsa tree structure. The drivers no longer need to know
the selected tag protocol, so remove it from the dsa switch structure.
Refactor the code to setup a single DSA/CPU port into a function of
its own, and export it, so it can be used by the new binding.
Similarly, refactor the destroy code into a function. When destroying
the ports, don't put the of node. They should be released at the end
along with the normal ports.
The new binding will not have a chip data structure, it will place the
routing directly into the switch structure. To enable backwards
compatibility, copy the routing from the chip data into the switch
structure.
With a maximum of four switches, the size of the routing table is the
same as the pointer to it. Removing it makes the code simpler.
Move the port device node structure into the port structure, from the
chip data. This information is needed in the next step of implementing
the new binding.
The chip data structure is used while parsing the whole old binding,
before the individual switch structures exist. With the new bindings,
this is reversed, the switches exist first, and the interconnections
between the switches is derived from the individual switch
bindings. Thus this chip data structure becomes unneeded.
There are going to be more per-port members added to the switch
structure. So add a port structure and move the netdev into it.
The platform data nr_chips is used when validating a received packet,
to ensure it comes from a know switch chip. The number of possible
switches is limited to DSA_MAX_SWITCHES, so use this as the first
validation step. The new binding allows holes in the dst->ds[] array,
so also ensure ensure there is a valid dsa_switch for this packet.
The DSA layer should no longer assume the switch is connected to an
MDIO bus. As a result, we cannot use the address on the MDIO bus when
forming the name of the switches internal MDIO bus for its builtin and
possibly external PHYs. The switch index is sufficient to make the
name unique, so drop the MDIO address.
The new binding does not make use of dsa_chip_data, a.k.a cd. When
retrieving the size of the EEPROM attached to a switch, don't assume
there is a cd attached to the switch structure.
The dsa_switch structure contains a dsa_chip_data member called pd.
However in the rest of the code, pd is used for dsa_platform_data.
This is confusing. Rename it cd, which is already often used in dsa.c
and slave.c for this data type.
The switch drivers only use the master_dev member for dev_info()
messages. Now that the device is passed to the old style probe, and
new style drivers are probed as true linux drivers, this is no longer
needed.
Resetting the switch is something the driver does, not the framework.
So move the parsing of this property into the driver.
There are no in kernel users of this property, so moving it does not
break anything. There is however a board which will make use of this
property making its way into the kernel.
This patch overloads the DSA master netdev, aka CPU Ethernet MAC to also
include switch-side statistics, which is useful for debugging purposes,
when the switch is not properly connected to the Ethernet MAC (duplex
mismatch, (RG)MII electrical issues etc.).
We accomplish this by retaining the original copy of the master netdev's
ethtool_ops, and just overload the 3 operations we care about:
get_sset_count, get_strings and get_ethtool_stats so as to intercept
these calls and call into the original master_netdev ethtool_ops, plus
our own.
We take this approach as opposed to providing a set of DSA helper
functions that would retrive the CPU port's statistics, because the
entire purpose of DSA is to allow unmodified Ethernet MAC drivers to be
used as CPU conduit interfaces, therefore, statistics overlay in such
drivers would simply not scale.
The new ethtool -S <iface> output would therefore look like this now:
<iface> statistics
p<2 digits cpu port number>_<switch MIB counter names>
Having the tag protocol in dsa_switch_driver for setup time and in
dsa_switch_tree for runtime is enough. Remove dsa_switch's one.
The dsa_slave_priv structure does not need a pointer to its net_device.
Kill it.
Change the dsa_switch_driver.probe function to return a const char *.
The phys in phys_port_mask suggests this mask is about PHYs. In fact,
it means physical ports. Rename to enabled_port_mask, indicating
external enabled ports of the switch, which is hopefully less
confusing.
The drivers now allocate their own memory for private usage. Remove
the allocation from the core code.
Now the switch devices have a dev pointer, make use of it for allocating
the drivers private data structures using a devm_kzalloc().
By passing a device structure to the switch devices, it allows them
to use devm_* methods for resource management.
The switchdev design implies that a software error should not happen in
the commit phase since it must have been previously reported in the
prepare phase. If an hardware error occurs during the commit phase,
there is nothing switchdev can do about it.
The DSA layer separates port_vlan_prepare and port_vlan_add for
simplicity and convenience. If an hardware error occurs during the
commit phase, there is no need to report it outside the driver itself.
Make the DSA port_vlan_add routine return void for explicitness.
