path: root/net/ethernet
2006-01-06[NET]: Use newer is_multicast_ether_addr() in some filesKris Katterjohn
This uses is_multicast_ether_addr() because it has recently been changed to do the same thing these seperate tests are doing. Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NET]: Change 1500 to ETH_DATA_LEN in some filesKris Katterjohn
These patches add the header linux/if_ether.h and change 1500 to ETH_DATA_LEN in some files. Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-29[ETH]: ether address compareStephen Hemminger
Expose faster ether compare for use by protocols and other driver. And change name to be more consistent with other ether address manipulation routines in same file Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-28[NET]: Fix reversed logic in eth_type_trans().David S. Miller
I got the second compare_eth_addr() test reversed, oops. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-27[NET]: Slightly optimize ethernet address comparison.David S. Miller
We know the thing is at least 2-byte aligned, so take advantage of that instead of invoking memcmp() which results in truly horrifically inefficient code because it can't assume anything about alignment. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Remove explicit initializations of skb->input_devDavid S. Miller
Instead, set it in one place, namely the beginning of netif_receive_skb(). Based upon suggestions from Jamal Hadi Salim. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[NET]: Micro optimization in eth_header()Denis Vlasenko
Signed-off-by: Denis Vlasenko <vda@ilport.com.ua> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05[PATCH] update Ross Biro bouncing email addressJesper Juhl
Ross moved. Remove the bad email address so people will find the correct one in ./CREDITS. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
