[ Upstream commit c305c6ae79e2ce20c22660ceda94f0d86d639a82 ]
KCSAN reported a data-race [1]
While we can use READ_ONCE() on the read sides,
we need to make sure hh->hh_len is written last.
[1]
BUG: KCSAN: data-race in eth_header_cache / neigh_resolve_output
write to 0xffff8880b9dedcb8 of 4 bytes by task 29760 on cpu 0:
eth_header_cache+0xa9/0xd0 net/ethernet/eth.c:247
neigh_hh_init net/core/neighbour.c:1463 [inline]
neigh_resolve_output net/core/neighbour.c:1480 [inline]
neigh_resolve_output+0x415/0x470 net/core/neighbour.c:1470
neigh_output include/net/neighbour.h:511 [inline]
ip6_finish_output2+0x7a2/0xec0 net/ipv6/ip6_output.c:116
__ip6_finish_output net/ipv6/ip6_output.c:142 [inline]
__ip6_finish_output+0x2d7/0x330 net/ipv6/ip6_output.c:127
ip6_finish_output+0x41/0x160 net/ipv6/ip6_output.c:152
NF_HOOK_COND include/linux/netfilter.h:294 [inline]
ip6_output+0xf2/0x280 net/ipv6/ip6_output.c:175
dst_output include/net/dst.h:436 [inline]
NF_HOOK include/linux/netfilter.h:305 [inline]
ndisc_send_skb+0x459/0x5f0 net/ipv6/ndisc.c:505
ndisc_send_ns+0x207/0x430 net/ipv6/ndisc.c:647
rt6_probe_deferred+0x98/0xf0 net/ipv6/route.c:615
process_one_work+0x3d4/0x890 kernel/workqueue.c:2269
worker_thread+0xa0/0x800 kernel/workqueue.c:2415
kthread+0x1d4/0x200 drivers/block/aoe/aoecmd.c:1253
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:352
read to 0xffff8880b9dedcb8 of 4 bytes by task 29572 on cpu 1:
neigh_resolve_output net/core/neighbour.c:1479 [inline]
neigh_resolve_output+0x113/0x470 net/core/neighbour.c:1470
Reported by Kernel Concurrency Sanitizer on:
CPU: 1 PID: 29572 Comm: kworker/1:4 Not tainted 5.4.0-rc6+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Workqueue: events rt6_probe_deferred
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 217e6fa24ce28ec87fca8da93c9016cb78028612 ]
The stack must not pass packets to device drivers that are shorter
than the minimum link layer header length.
Previously, packet sockets would drop packets smaller than or equal
to dev->hard_header_len, but this has false positives. Zero length
payload is used over Ethernet. Other link layer protocols support
variable length headers. Support for validation of these protocols
removed the min length check for all protocols.
Introduce an explicit dev->min_header_len parameter and drop all
packets below this value. Initially, set it to non-zero only for
Ethernet and loopback. Other protocols can follow in a patch to
net-next.
Fixes: 9ed988cd5915 ("packet: validate variable length ll headers")
Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
[ Upstream commit fcd91dd449867c6bfe56a81cabba76b829fd05cd ]
Currently, GRO can do unlimited recursion through the gro_receive
handlers. This was fixed for tunneling protocols by limiting tunnel GRO
to one level with encap_mark, but both VLAN and TEB still have this
problem. Thus, the kernel is vulnerable to a stack overflow, if we
receive a packet composed entirely of VLAN headers.
This patch adds a recursion counter to the GRO layer to prevent stack
overflow. When a gro_receive function hits the recursion limit, GRO is
aborted for this skb and it is processed normally. This recursion
counter is put in the GRO CB, but could be turned into a percpu counter
if we run out of space in the CB.
Thanks to Vladimír Beneš <vbenes@redhat.com> for the initial bug report.
Fixes: CVE-2016-7039
Fixes: 9b174d88c257 ("net: Add Transparent Ethernet Bridging GRO support.")
Fixes: 66e5133f19e9 ("vlan: Add GRO support for non hardware accelerated vlan")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Tom Herbert <tom@herbertland.com>
Noticed that the compiler (gcc version 4.8.5 20150623 (Red Hat 4.8.5-4) (GCC))
generated suboptimal assembler code in eth_get_headlen().
This early return coding style is usually not an issue, on super scalar CPUs,
but the compiler choose to put the return statement after this very unlikely
branch, thus creating larger jump down to the likely code path.
Performance wise, I could measure slightly less L1-icache-load-misses
and less branch-misses, and an improvement of 1 nanosec with an IP-forwarding
use-case with 257 bytes packets with ixgbe (CPU i7-4790K @ 4.00GHz).
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
The flags argument will allow control of the dissection process (for
instance whether to parse beyond L3).
Signed-off-by: Tom Herbert <tom@herbertland.com>
This patch fix double word "the the" in
Documentation/DocBook/networking/API-eth-get-headlen.html
Documentation/DocBook/networking/netdev.html
Documentation/DocBook/networking.xml
These files are generated from comment in source,
so I have to fix comment in net/ethernet/eth.c.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
This patch adds full IPv6 addresses into flow_keys and uses them as
input to the flow hash function. The implementation supports either
IPv4 or IPv6 addresses in a union, and selector is used to determine
how may words to input to jhash2.
We also add flow_get_u32_dst and flow_get_u32_src functions which are
used to get a u32 representation of the source and destination
addresses. For IPv6, ipv6_addr_hash is called. These functions retain
getting the legacy values of src and dst in flow_keys.
With this patch, Ethertype and IP protocol are now included in the
flow hash input.
When we scan a packet for GRO processing, we want to see the most
common packet types in the front of the offload_base list.
So add a priority field so we can handle this properly.
IPv4/IPv6 get the highest priority with the implicit zero priority
field.
Next comes ethernet with a priority of 10, and then we have the MPLS
types with a priority of 15.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Suggested-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Since these functions are defined in flow_dissector.c, move header
declarations from skbuff.h into flow_dissector.h
This change does two things. First it fixes a sparse error for the fact
that the __be16 degrades to an integer. Since that is actually what I am
kind of doing I am simply working around that by forcing both sides of the
comparison to u16.
Also I realized on some compilers I was generating another instruction for
big endian systems such as PowerPC since it was masking the value before
doing the comparison. So to resolve that I have simply pulled the mask out
and wrapped it in an #ifndef __BIG_ENDIAN.
Lastly I pulled this all out into its own function. I notices there are
similar checks in a number of other places so this function can be reused
there to help reduce overhead in these paths as well.
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Avoid recomputing the Ethernet header location and instead just use the
pointer provided by skb->data. The problem with using eth_hdr is that the
compiler wasn't smart enough to realize that skb->head + skb->mac_header
was the same thing as skb->data before it added ETH_HLEN. By just caching
it off before calling skb_pull_inline we can avoid a few unnecessary
instructions.
This change makes it so that we process the address in
is_multicast_ether_addr at the same size as the other calls. This allows
us to avoid duplicate reads when used with other calls such as
is_zero_ether_addr or eth_addr_copy. In addition I have added a 64 bit
version of the function so in eth_type_trans we can process the destination
address as a 64 bit value throughout.
This change takes advantage of the fact that ETH_P_802_3_MIN is aligned to
512 so as a result we can actually ignore the lower 8b when comparing the
Ethertype to ETH_P_802_3_MIN. This allows us to avoid a byte swap by simply
masking the value and comparing it to the byte swapped value for
ETH_P_802_3_MIN.
Use the built-in function instead of memset.
Now that there are no more users kill dev_rebuild_header and all of it's
implementations.
This is long overdue.
Currently the only tunnel protocol that supports GRO with encapsulated
Ethernet is VXLAN. This pulls out the Ethernet code into a proper layer
so that it can be used by other tunnel protocols such as GRE and Geneve.
Signed-off-by: Jesse Gross <jesse@nicira.com>
This patch updates some of the flow_dissector api so that it can be used to
parse the length of ethernet buffers stored in fragments. Most of the
changes needed were to __skb_get_poff as it needed to be updated to support
sending a linear buffer instead of a skb.
I have split __skb_get_poff into two functions, the first is skb_get_poff
and it retains the functionality of the original __skb_get_poff. The other
function is __skb_get_poff which now works much like __skb_flow_dissect in
relation to skb_flow_dissect in that it provides the same functionality but
works with just a data buffer and hlen instead of needing an skb.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
DSA is currently registering one packet_type function per EtherType it
needs to intercept in the receive path of a DSA-enabled Ethernet device.
Right now we have three of them: trailer, DSA and eDSA, and there might
be more in the future, this will not scale to the addition of new
protocols.
This patch proceeds with adding a new layer of abstraction and two new
functions:
dsa_switch_rcv() which will dispatch into the tag-protocol specific
receive function implemented by net/dsa/tag_*.c
dsa_slave_xmit() which will dispatch into the tag-protocol specific
transmit function implemented by net/dsa/tag_*.c
When we do create the per-port slave network devices, we iterate over
the switch protocol to assign the DSA-specific receive and transmit
operations.
A new fake ethertype value is used: ETH_P_XDSA to illustrate the fact
that this is no longer going to look like ETH_P_DSA or ETH_P_TRAILER
like it used to be.
This allows us to greatly simplify the check in eth_type_trans() and
always override the skb->protocol with ETH_P_XDSA for Ethernet switches
tagged protocol, while also reducing the number repetitive slave
netdevice_ops assignments.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
eth_type_trans() can read uninitialized memory as drivers
do not necessarily pull more than 14 bytes in skb->head before
calling it.
As David suggested, we can use skb_header_pointer() to
fix this without breaking some drivers that might not expect
eth_type_trans() pulling 2 additional bytes.
Cc: Ben Hutchings <bhutchings@solarflare.com>
Mark code path's likely/unlikely based on most common usage.
* Very few devices use dsa tags.
* Most traffic is Ethernet (not 802.2)
* No sane person uses trailer type or Novell encapsulation
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Remove old legacy comment and weird if condition.
The comment has outlived it's stay and is throwback to some
early net code (before my time). Maybe Dave remembers what it meant.
removed these checkpatch.pl warnings:
net/ethernet/eth.c:61: WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
net/ethernet/eth.c:136: WARNING: Prefer netdev_dbg(netdev, ... then dev_dbg(dev, ... then pr_debug(... to printk(KERN_DEBUG ...
net/ethernet/eth.c:181: ERROR: space prohibited before that close parenthesis ')'
Signed-off-by: Avinash Kumar <avi.kp.137@gmail.com>
It's just a duplicate implementation of "%*phC". Thanks to Joe
Perches for showing that we had exactly this support in the
lib/vsprintf.c code already.
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for
an 802.3 frame. Frames with a lower value in the ethernet type field
are Ethernet II.
Also update all the users of this value that David Miller and
I could find to use the new constant.
Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN
should be >= not >.
As suggested by Jesse Gross.
Compile tested only.
Cc: Jesse Gross <jesse@nicira.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Bart De Schuymer <bart.de.schuymer@pandora.be>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netfilter-devel@vger.kernel.org
Cc: bridge@lists.linux-foundation.org
Cc: linux-wireless@vger.kernel.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-media@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: dev@openvswitch.org
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Signed-off-by: Simon Horman <horms@verge.net.au>
When we set mac address, software mac address in system and hardware mac
address all need to be updated. Current eth_mac_addr() doesn't allow
callers to implement error handling nicely.
This patch split eth_mac_addr() to prepare part and real commit part,
then we can prepare first, and try to change hardware address, then do
the real commit if hardware address is set successfully.
Signed-off-by: Stefan Hajnoczi <stefanha@gmail.com>
Signed-off-by: Amos Kong <akong@redhat.com>
NET_ADDR_SET is set in dev_set_mac_address() no need to alter
dev->addr_assign_type value in drivers.
The Ethernet II wrapper is only used by IPX protocol, may have once
been used by Appletalk but not currently. Therefore it makes sense to
move it to the IPX dust bin and drop the exports.
Build tested only.
Fix incorrect start markers, wrapped summary lines, missing section
breaks, incorrect separators, and some name mismatches.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Introduce IFF_LIVE_ADDR_CHANGE priv_flag and use it to disable
netif_running() check in eth_mac_addr()
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Use the new bool function ether_addr_equal_64bits to add
some clarity and reduce the likelihood for misuse of
compare_ether_addr_64bits for sorting.
Done via cocci script:
$ cat compare_ether_addr_64bits.cocci
expression a,b;
- !compare_ether_addr_64bits(a, b)
+ ether_addr_equal_64bits(a, b)
expression a,b;
- compare_ether_addr_64bits(a, b)
+ !ether_addr_equal_64bits(a, b)
expression a,b;
- !ether_addr_equal_64bits(a, b) == 0
expression a,b;
- !ether_addr_equal_64bits(a, b) != 0
expression a,b;
- ether_addr_equal_64bits(a, b) == 0
expression a,b;
- ether_addr_equal_64bits(a, b) != 0
expression a,b;
- !!ether_addr_equal_64bits(a, b)
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
If eth_mac_addr() get called, usually if SIOCSIFHWADDR was
used to change the MAC of a ethernet device, reset the
addr_assign_type to NET_ADDR_PERM if the state was
NET_ADDR_RANDOM before. Reset the state since the MAC is
no longer random at least not from the kernel side.
v2: changed to bitops, removed if()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
d88733150 introduced the IFF_SKB_TX_SHARING flag, which I unilaterally set in
ether_setup. In doing this I didn't realize that other flags (such as
IFF_XMIT_DST_RELEASE) might be set prior to calling the ether_setup routine.
This patch changes ether_setup to or in SKB_TX_SHARING so as not to
inadvertently clear other existing flags. Thanks to Pekka Riikonen for pointing
out my error
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Pekka Riikonen <priikone@iki.fi>
CC: "David S. Miller" <davem@davemloft.net>
Pktgen attempts to transmit shared skbs to net devices, which can't be used by
some drivers as they keep state information in skbs. This patch adds a flag
marking drivers as being able to handle shared skbs in their tx path. Drivers
are defaulted to being unable to do so, but calling ether_setup enables this
flag, as 90% of the drivers calling ether_setup touch real hardware and can
handle shared skbs. A subsequent patch will audit drivers to ensure that the
flag is set properly
Reported-by: Jiri Pirko <jpirko@redhat.com>
CC: Robert Olsson <robert.olsson@its.uu.se>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Alexey Dobriyan <adobriyan@gmail.com>
CC: David S. Miller <davem@davemloft.net>
Fix new kernel-doc warning in eth.c:
Warning(net/ethernet/eth.c:237): No description found for parameter 'type'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Fix new kernel-doc warning (copy-paste typo):
Warning(net/ethernet/eth.c:366): No description found for parameter 'rxqs'
Added alloc_netdev_mqs function which allows the number of transmit and
receive queues to be specified independenty. alloc_netdev_mq was
changed to a macro to call the new function. Also added
alloc_etherdev_mqs with same purpose.
Signed-off-by: Tom Herbert <therbert@google.com>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
strlcpy() returns the total length of the string they tried to create, so
we should not use its return value without any check. scnprintf() returns
the number of characters written into @buf not including the trailing '\0',
so use it instead here.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
This patch fix a code style issue, if a function is exported, the
EXPORT_SYMBOL macro for it should follow immediately after the closing
function brace line.
Signed-off-by: Chihau Chau <chihau@gmail.com>
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
In commit 6be8ac2f ("[NET]: uninline skb_pull, de-bloats a lot")
we uninlined skb_pull.
But in some critical paths it makes sense to inline this thing
and it helps performance significantly.
Create an skb_pull_inline() so that we can do this in a way that
serves also as annotation.
Based upon a patch by Eric Dumazet.
Eric's recent patch added __force, but this
place would seem to require actually doing
a byte order conversion so the printk is
consistent across architectures.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Sparse can help us find endianness bugs, but we need to make some
cleanups to be able to more easily spot real bugs.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Using dev_hard_header allows us to use LLC with VLANs and potentially
other Ethernet/TokernRing specific encapsulations. It also removes code
duplication between LLC and Ethernet/TokenRing core code.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
