path: root/net/hsr
2020-04-24hsr: check protocol version in hsr_newlink()Taehee Yoo
[ Upstream commit 4faab8c446def7667adf1f722456c2f4c304069c ] In the current hsr code, only 0 and 1 protocol versions are valid. But current hsr code doesn't check the version, which is received by userspace. Test commands: ip link add dummy0 type dummy ip link add dummy1 type dummy ip link add hsr0 type hsr slave1 dummy0 slave2 dummy1 version 4 In the test commands, version 4 is invalid. So, the command should be failed. After this patch, following error will occur. "Error: hsr: Only versions 0..1 are supported." Fixes: ee1c27977284 ("net/hsr: Added support for HSR v1") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02hsr: set .netnsok flagTaehee Yoo
[ Upstream commit 09e91dbea0aa32be02d8877bd50490813de56b9a ] The hsr module has been supporting the list and status command. (HSR_C_GET_NODE_LIST and HSR_C_GET_NODE_STATUS) These commands send node information to the user-space via generic netlink. But, in the non-init_net namespace, these commands are not allowed because .netnsok flag is false. So, there is no way to get node information in the non-init_net namespace. Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02hsr: add restart routine into hsr_get_node_list()Taehee Yoo
[ Upstream commit ca19c70f5225771c05bcdcb832b4eb84d7271c5e ] The hsr_get_node_list() is to send node addresses to the userspace. If there are so many nodes, it could fail because of buffer size. In order to avoid this failure, the restart routine is added. Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02hsr: use rcu_read_lock() in hsr_get_node_{list/status}()Taehee Yoo
[ Upstream commit 173756b86803655d70af7732079b3aa935e6ab68 ] hsr_get_node_{list/status}() are not under rtnl_lock() because they are callback functions of generic netlink. But they use __dev_get_by_index() without rtnl_lock(). So, it would use unsafe data. In order to fix it, rcu_read_lock() and dev_get_by_index_rcu() are used instead of __dev_get_by_index(). Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-04-02hsr: fix general protection fault in hsr_addr_is_self()Taehee Yoo
[ Upstream commit 3a303cfdd28d5f930a307c82e8a9d996394d5ebd ] The port->hsr is used in the hsr_handle_frame(), which is a callback of rx_handler. hsr master and slaves are initialized in hsr_add_port(). This function initializes several pointers, which includes port->hsr after registering rx_handler. So, in the rx_handler routine, un-initialized pointer would be used. In order to fix this, pointers should be initialized before registering rx_handler. Test commands: ip netns del left ip netns del right modprobe -rv veth modprobe -rv hsr killall ping modprobe hsr ip netns add left ip netns add right ip link add veth0 type veth peer name veth1 ip link add veth2 type veth peer name veth3 ip link add veth4 type veth peer name veth5 ip link set veth1 netns left ip link set veth3 netns right ip link set veth4 netns left ip link set veth5 netns right ip link set veth0 up ip link set veth2 up ip link set veth0 address fc:00:00:00:00:01 ip link set veth2 address fc:00:00:00:00:02 ip netns exec left ip link set veth1 up ip netns exec left ip link set veth4 up ip netns exec right ip link set veth3 up ip netns exec right ip link set veth5 up ip link add hsr0 type hsr slave1 veth0 slave2 veth2 ip a a 192.168.100.1/24 dev hsr0 ip link set hsr0 up ip netns exec left ip link add hsr1 type hsr slave1 veth1 slave2 veth4 ip netns exec left ip a a 192.168.100.2/24 dev hsr1 ip netns exec left ip link set hsr1 up ip netns exec left ip n a 192.168.100.1 dev hsr1 lladdr \ fc:00:00:00:00:01 nud permanent ip netns exec left ip n r 192.168.100.1 dev hsr1 lladdr \ fc:00:00:00:00:01 nud permanent for i in {1..100} do ip netns exec left ping 192.168.100.1 & done ip netns exec left hping3 192.168.100.1 -2 --flood & ip netns exec right ip link add hsr2 type hsr slave1 veth3 slave2 veth5 ip netns exec right ip a a 192.168.100.3/24 dev hsr2 ip netns exec right ip link set hsr2 up ip netns exec right ip n a 192.168.100.1 dev hsr2 lladdr \ fc:00:00:00:00:02 nud permanent ip netns exec right ip n r 192.168.100.1 dev hsr2 lladdr \ fc:00:00:00:00:02 nud permanent for i in {1..100} do ip netns exec right ping 192.168.100.1 & done ip netns exec right hping3 192.168.100.1 -2 --flood & while : do ip link add hsr0 type hsr slave1 veth0 slave2 veth2 ip a a 192.168.100.1/24 dev hsr0 ip link set hsr0 up ip link del hsr0 done Splat looks like: [ 120.954938][ C0] general protection fault, probably for non-canonical address 0xdffffc0000000006: 0000 [#1]I [ 120.957761][ C0] KASAN: null-ptr-deref in range [0x0000000000000030-0x0000000000000037] [ 120.959064][ C0] CPU: 0 PID: 1511 Comm: hping3 Not tainted 5.6.0-rc5+ #460 [ 120.960054][ C0] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006 [ 120.962261][ C0] RIP: 0010:hsr_addr_is_self+0x65/0x2a0 [hsr] [ 120.963149][ C0] Code: 44 24 18 70 73 2f c0 48 c1 eb 03 48 8d 04 13 c7 00 f1 f1 f1 f1 c7 40 04 00 f2 f2 f2 4 [ 120.966277][ C0] RSP: 0018:ffff8880d9c09af0 EFLAGS: 00010206 [ 120.967293][ C0] RAX: 0000000000000006 RBX: 1ffff1101b38135f RCX: 0000000000000000 [ 120.968516][ C0] RDX: dffffc0000000000 RSI: ffff8880d17cb208 RDI: 0000000000000000 [ 120.969718][ C0] RBP: 0000000000000030 R08: ffffed101b3c0e3c R09: 0000000000000001 [ 120.972203][ C0] R10: 0000000000000001 R11: ffffed101b3c0e3b R12: 0000000000000000 [ 120.973379][ C0] R13: ffff8880aaf80100 R14: ffff8880aaf800f2 R15: ffff8880aaf80040 [ 120.974410][ C0] FS: 00007f58e693f740(0000) GS:ffff8880d9c00000(0000) knlGS:0000000000000000 [ 120.979794][ C0] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 120.980773][ C0] CR2: 00007ffcb8b38f29 CR3: 00000000afe8e001 CR4: 00000000000606f0 [ 120.981945][ C0] Call Trace: [ 120.982411][ C0] <IRQ> [ 120.982848][ C0] ? hsr_add_node+0x8c0/0x8c0 [hsr] [ 120.983522][ C0] ? rcu_read_lock_held+0x90/0xa0 [ 120.984159][ C0] ? rcu_read_lock_sched_held+0xc0/0xc0 [ 120.984944][ C0] hsr_handle_frame+0x1db/0x4e0 [hsr] [ 120.985597][ C0] ? hsr_nl_nodedown+0x2b0/0x2b0 [hsr] [ 120.986289][ C0] __netif_receive_skb_core+0x6bf/0x3170 [ 120.992513][ C0] ? check_chain_key+0x236/0x5d0 [ 120.993223][ C0] ? do_xdp_generic+0x1460/0x1460 [ 120.993875][ C0] ? register_lock_class+0x14d0/0x14d0 [ 120.994609][ C0] ? __netif_receive_skb_one_core+0x8d/0x160 [ 120.995377][ C0] __netif_receive_skb_one_core+0x8d/0x160 [ 120.996204][ C0] ? __netif_receive_skb_core+0x3170/0x3170 [ ... ] Reported-by: syzbot+fcf5dd39282ceb27108d@syzkaller.appspotmail.com Fixes: c5a759117210 ("net/hsr: Use list_head (and rcu) instead of array for slave devices.") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-02-14net: hsr: fix possible NULL deref in hsr_handle_frame()Eric Dumazet
[ Upstream commit 2b5b8251bc9fe2f9118411f037862ee17cf81e97 ] hsr_port_get_rcu() can return NULL, so we need to be careful. general protection fault, probably for non-canonical address 0xdffffc0000000006: 0000 [#1] PREEMPT SMP KASAN KASAN: null-ptr-deref in range [0x0000000000000030-0x0000000000000037] CPU: 1 PID: 10249 Comm: syz-executor.5 Not tainted 5.5.0-syzkaller #0 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 RIP: 0010:__read_once_size include/linux/compiler.h:199 [inline] RIP: 0010:hsr_addr_is_self+0x86/0x330 net/hsr/hsr_framereg.c:44 Code: 04 00 f3 f3 f3 65 48 8b 04 25 28 00 00 00 48 89 45 d0 31 c0 e8 6b ff 94 f9 4c 89 f2 48 b8 00 00 00 00 00 fc ff df 48 c1 ea 03 <80> 3c 02 00 0f 85 75 02 00 00 48 8b 43 30 49 39 c6 49 89 47 c0 0f RSP: 0018:ffffc90000da8a90 EFLAGS: 00010206 RAX: dffffc0000000000 RBX: 0000000000000000 RCX: ffffffff87e0cc33 RDX: 0000000000000006 RSI: ffffffff87e035d5 RDI: 0000000000000000 RBP: ffffc90000da8b20 R08: ffff88808e7de040 R09: ffffed1015d2707c R10: ffffed1015d2707b R11: ffff8880ae9383db R12: ffff8880a689bc5e R13: 1ffff920001b5153 R14: 0000000000000030 R15: ffffc90000da8af8 FS: 00007fd7a42be700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000001b32338000 CR3: 00000000a928c000 CR4: 00000000001406e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Call Trace: <IRQ> hsr_handle_frame+0x1c5/0x630 net/hsr/hsr_slave.c:31 __netif_receive_skb_core+0xfbc/0x30b0 net/core/dev.c:5099 __netif_receive_skb_one_core+0xa8/0x1a0 net/core/dev.c:5196 __netif_receive_skb+0x2c/0x1d0 net/core/dev.c:5312 process_backlog+0x206/0x750 net/core/dev.c:6144 napi_poll net/core/dev.c:6582 [inline] net_rx_action+0x508/0x1120 net/core/dev.c:6650 __do_softirq+0x262/0x98c kernel/softirq.c:292 do_softirq_own_stack+0x2a/0x40 arch/x86/entry/entry_64.S:1082 </IRQ> Fixes: c5a759117210 ("net/hsr: Use list_head (and rcu) instead of array for slave devices.") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-23hsr: reset network header when supervision frame is createdTaehee Yoo
commit 3ed0a1d563903bdb4b4c36c58c4d9c1bcb23a6e6 upstream. The supervision frame is L2 frame. When supervision frame is created, hsr module doesn't set network header. If tap routine is enabled, dev_queue_xmit_nit() is called and it checks network_header. If network_header pointer wasn't set(or invalid), it resets network_header and warns. In order to avoid unnecessary warning message, resetting network_header is needed. Test commands: ip netns add nst ip link add veth0 type veth peer name veth1 ip link add veth2 type veth peer name veth3 ip link set veth1 netns nst ip link set veth3 netns nst ip link set veth0 up ip link set veth2 up ip link add hsr0 type hsr slave1 veth0 slave2 veth2 ip a a 192.168.100.1/24 dev hsr0 ip link set hsr0 up ip netns exec nst ip link set veth1 up ip netns exec nst ip link set veth3 up ip netns exec nst ip link add hsr1 type hsr slave1 veth1 slave2 veth3 ip netns exec nst ip a a 192.168.100.2/24 dev hsr1 ip netns exec nst ip link set hsr1 up tcpdump -nei veth0 Splat looks like: [ 175.852292][ C3] protocol 88fb is buggy, dev veth0 Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Taehee Yoo <ap420073@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-19net/hsr: fix possible crash in add_timer()Eric Dumazet
[ Upstream commit 1e027960edfaa6a43f9ca31081729b716598112b ] syzbot found another add_timer() issue, this time in net/hsr [1] Let's use mod_timer() which is safe. [1] kernel BUG at kernel/time/timer.c:1136! invalid opcode: 0000 [#1] PREEMPT SMP KASAN CPU: 0 PID: 15909 Comm: syz-executor.3 Not tainted 5.0.0+ #97 Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011 kobject: 'loop2' (00000000f5629718): kobject_uevent_env RIP: 0010:add_timer kernel/time/timer.c:1136 [inline] RIP: 0010:add_timer+0x654/0xbe0 kernel/time/timer.c:1134 Code: 0f 94 c5 31 ff 44 89 ee e8 09 61 0f 00 45 84 ed 0f 84 77 fd ff ff e8 bb 5f 0f 00 e8 07 10 a0 ff e9 68 fd ff ff e8 ac 5f 0f 00 <0f> 0b e8 a5 5f 0f 00 0f 0b e8 9e 5f 0f 00 4c 89 b5 58 ff ff ff e9 RSP: 0018:ffff8880656eeca0 EFLAGS: 00010246 kobject: 'loop2' (00000000f5629718): fill_kobj_path: path = '/devices/virtual/block/loop2' RAX: 0000000000040000 RBX: 1ffff1100caddd9a RCX: ffffc9000c436000 RDX: 0000000000040000 RSI: ffffffff816056c4 RDI: ffff88806a2f6cc8 RBP: ffff8880656eed58 R08: ffff888067f4a300 R09: ffff888067f4abc8 R10: 0000000000000000 R11: 0000000000000000 R12: ffff88806a2f6cc0 R13: dffffc0000000000 R14: 0000000000000001 R15: ffff8880656eed30 FS: 00007fc2019bf700(0000) GS:ffff8880ae800000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000738000 CR3: 0000000067e8e000 CR4: 00000000001406f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 Call Trace: hsr_check_announce net/hsr/hsr_device.c:99 [inline] hsr_check_carrier_and_operstate+0x567/0x6f0 net/hsr/hsr_device.c:120 hsr_netdev_notify+0x297/0xa00 net/hsr/hsr_main.c:51 notifier_call_chain+0xc7/0x240 kernel/notifier.c:93 __raw_notifier_call_chain kernel/notifier.c:394 [inline] raw_notifier_call_chain+0x2e/0x40 kernel/notifier.c:401 call_netdevice_notifiers_info+0x3f/0x90 net/core/dev.c:1739 call_netdevice_notifiers_extack net/core/dev.c:1751 [inline] call_netdevice_notifiers net/core/dev.c:1765 [inline] dev_open net/core/dev.c:1436 [inline] dev_open+0x143/0x160 net/core/dev.c:1424 team_port_add drivers/net/team/team.c:1203 [inline] team_add_slave+0xa07/0x15d0 drivers/net/team/team.c:1933 do_set_master net/core/rtnetlink.c:2358 [inline] do_set_master+0x1d4/0x230 net/core/rtnetlink.c:2332 do_setlink+0x966/0x3510 net/core/rtnetlink.c:2493 rtnl_setlink+0x271/0x3b0 net/core/rtnetlink.c:2747 rtnetlink_rcv_msg+0x465/0xb00 net/core/rtnetlink.c:5192 netlink_rcv_skb+0x17a/0x460 net/netlink/af_netlink.c:2485 rtnetlink_rcv+0x1d/0x30 net/core/rtnetlink.c:5210 netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline] netlink_unicast+0x536/0x720 net/netlink/af_netlink.c:1336 netlink_sendmsg+0x8ae/0xd70 net/netlink/af_netlink.c:1925 sock_sendmsg_nosec net/socket.c:622 [inline] sock_sendmsg+0xdd/0x130 net/socket.c:632 sock_write_iter+0x27c/0x3e0 net/socket.c:923 call_write_iter include/linux/fs.h:1869 [inline] do_iter_readv_writev+0x5e0/0x8e0 fs/read_write.c:680 do_iter_write fs/read_write.c:956 [inline] do_iter_write+0x184/0x610 fs/read_write.c:937 vfs_writev+0x1b3/0x2f0 fs/read_write.c:1001 do_writev+0xf6/0x290 fs/read_write.c:1036 __do_sys_writev fs/read_write.c:1109 [inline] __se_sys_writev fs/read_write.c:1106 [inline] __x64_sys_writev+0x75/0xb0 fs/read_write.c:1106 do_syscall_64+0x103/0x610 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x457f29 Code: ad b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00 RSP: 002b:00007fc2019bec78 EFLAGS: 00000246 ORIG_RAX: 0000000000000014 RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000457f29 RDX: 0000000000000001 RSI: 00000000200000c0 RDI: 0000000000000003 RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000246 R12: 00007fc2019bf6d4 R13: 00000000004c4a60 R14: 00000000004dd218 R15: 00000000ffffffff Fixes: f421436a591d ("net/hsr: Add support for the High-availability Seamless Redundancy protocol (HSRv0)") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: syzbot <syzkaller@googlegroups.com> Cc: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-19net: hsr: fix memory leak in hsr_dev_finalize()Mao Wenan
[ Upstream commit 6caabe7f197d3466d238f70915d65301f1716626 ] If hsr_add_port(hsr, hsr_dev, HSR_PT_MASTER) failed to add port, it directly returns res and forgets to free the node that allocated in hsr_create_self_node(), and forgets to delete the node->mac_list linked in hsr->self_node_db. BUG: memory leak unreferenced object 0xffff8881cfa0c780 (size 64): comm "syz-executor.0", pid 2077, jiffies 4294717969 (age 2415.377s) hex dump (first 32 bytes): e0 c7 a0 cf 81 88 ff ff 00 02 00 00 00 00 ad de ................ 00 e6 49 cd 81 88 ff ff c0 9b 87 d0 81 88 ff ff ..I............. backtrace: [<00000000e2ff5070>] hsr_dev_finalize+0x736/0x960 [hsr] [<000000003ed2e597>] hsr_newlink+0x2b2/0x3e0 [hsr] [<000000003fa8c6b6>] __rtnl_newlink+0xf1f/0x1600 net/core/rtnetlink.c:3182 [<000000001247a7ad>] rtnl_newlink+0x66/0x90 net/core/rtnetlink.c:3240 [<00000000e7d1b61d>] rtnetlink_rcv_msg+0x54e/0xb90 net/core/rtnetlink.c:5130 [<000000005556bd3a>] netlink_rcv_skb+0x129/0x340 net/netlink/af_netlink.c:2477 [<00000000741d5ee6>] netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline] [<00000000741d5ee6>] netlink_unicast+0x49a/0x650 net/netlink/af_netlink.c:1336 [<000000009d56f9b7>] netlink_sendmsg+0x88b/0xdf0 net/netlink/af_netlink.c:1917 [<0000000046b35c59>] sock_sendmsg_nosec net/socket.c:621 [inline] [<0000000046b35c59>] sock_sendmsg+0xc3/0x100 net/socket.c:631 [<00000000d208adc9>] __sys_sendto+0x33e/0x560 net/socket.c:1786 [<00000000b582837a>] __do_sys_sendto net/socket.c:1798 [inline] [<00000000b582837a>] __se_sys_sendto net/socket.c:1794 [inline] [<00000000b582837a>] __x64_sys_sendto+0xdd/0x1b0 net/socket.c:1794 [<00000000c866801d>] do_syscall_64+0x147/0x600 arch/x86/entry/common.c:290 [<00000000fea382d9>] entry_SYSCALL_64_after_hwframe+0x49/0xbe [<00000000e01dacb3>] 0xffffffffffffffff Fixes: c5a759117210 ("net/hsr: Use list_head (and rcu) instead of array for slave devices.") Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: Mao Wenan <maowenan@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13hsr: fix incorrect warningKaricheri, Muralidharan
[ Upstream commit 675c8da049fd6556eb2d6cdd745fe812752f07a8 ] When HSR interface is setup using ip link command, an annoying warning appears with the trace as below:- [ 203.019828] hsr_get_node: Non-HSR frame [ 203.019833] Modules linked in: [ 203.019848] CPU: 0 PID: 158 Comm: sd-resolve Tainted: G W 4.12.0-rc3-00052-g9fa6bf70 #2 [ 203.019853] Hardware name: Generic DRA74X (Flattened Device Tree) [ 203.019869] [<c0110280>] (unwind_backtrace) from [<c010c2f4>] (show_stack+0x10/0x14) [ 203.019880] [<c010c2f4>] (show_stack) from [<c04b9f64>] (dump_stack+0xac/0xe0) [ 203.019894] [<c04b9f64>] (dump_stack) from [<c01374e8>] (__warn+0xd8/0x104) [ 203.019907] [<c01374e8>] (__warn) from [<c0137548>] (warn_slowpath_fmt+0x34/0x44) root@am57xx-evm:~# [ 203.019921] [<c0137548>] (warn_slowpath_fmt) from [<c081126c>] (hsr_get_node+0x148/0x170) [ 203.019932] [<c081126c>] (hsr_get_node) from [<c0814240>] (hsr_forward_skb+0x110/0x7c0) [ 203.019942] [<c0814240>] (hsr_forward_skb) from [<c0811d64>] (hsr_dev_xmit+0x2c/0x34) [ 203.019954] [<c0811d64>] (hsr_dev_xmit) from [<c06c0828>] (dev_hard_start_xmit+0xc4/0x3bc) [ 203.019963] [<c06c0828>] (dev_hard_start_xmit) from [<c06c13d8>] (__dev_queue_xmit+0x7c4/0x98c) [ 203.019974] [<c06c13d8>] (__dev_queue_xmit) from [<c0782f54>] (ip6_finish_output2+0x330/0xc1c) [ 203.019983] [<c0782f54>] (ip6_finish_output2) from [<c0788f0c>] (ip6_output+0x58/0x454) [ 203.019994] [<c0788f0c>] (ip6_output) from [<c07b16cc>] (mld_sendpack+0x420/0x744) As this is an expected path to hsr_get_node() with frame coming from the master interface, add a check to ensure packet is not from the master port and then warn. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-18net/hsr: Remove unused but set variableTobias Klauser
Remove the unused but set variable master_dev in check_local_dest to fix the following GCC warning when building with 'W=1': net/hsr/hsr_forward.c: In function ‘check_local_dest’: net/hsr/hsr_forward.c:303:21: warning: variable ‘master_dev’ set but not used [-Wunused-but-set-variable] Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-16net/hsr: Use setup_timer and mod_timer.Muhammad Falak R Wani
The function setup_timer combines the initialization of a timer with the initialization of the timer's function and data fields. The mulitiline code for timer initialization is now replaced with function setup_timer. Also, quoting the mod_timer() function comment: -> mod_timer() is a more efficient way to update the expire field of an active timer (if the timer is inactive it will be activated). Use setup_timer() and mod_timer() to setup and arm a timer, making the code compact and aid readablity. Signed-off-by: Muhammad Falak R Wani <falakreyaz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-21NLA_BINARY misuse bug in HSRPeter Heise
Removed .type field from NLA to do proper length checking. Reported by Daniel Borkmann and Julia Lawall. Signed-off-by: Peter Heise <peter.heise@airbus.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-04-15net/hsr: Added support for HSR v1Peter Heise
This patch adds support for the newer version 1 of the HSR networking standard. Version 0 is still default and the new version has to be selected via iproute2. Main changes are in the supervision frame handling and its ethertype field. Signed-off-by: Peter Heise <peter.heise@airbus.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-23net/hsr: fix a warning messageDan Carpenter
WARN_ON_ONCE() takes a condition, it doesn't take an error message. I have converted this to WARN() instead. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-18net: hsr: convert to using IFF_NO_QUEUEPhil Sutter
Signed-off-by: Phil Sutter <phil@nwl.cc> Cc: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01net/hsr: Fix NULL pointer dereference and refcnt bugs when deleting a HSR ↵Arvid Brodin
interface. To repeat: $ sudo ip link del hsr0 BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: [<ffffffff8187f495>] hsr_del_port+0x15/0xa0 etc... Bug description: As part of the hsr master device destruction, hsr_del_port() is called for each of the hsr ports. At each such call, the master device is updated regarding features and mtu. When the master device is freed before the slave interfaces, master will be NULL in hsr_del_port(), which led to a NULL pointer dereference. Additionally, dev_put() was called on the master device itself in hsr_del_port(), causing a refcnt error. A third bug in the same code path was that the rtnl lock was not taken before hsr_del_port() was called as part of hsr_dev_destroy(). The reporter (Nicolas Dichtel) also said: "hsr_netdev_notify() supposes that the port will always be available when the notification is for an hsr interface. It's wrong. For example, netdev_wait_allrefs() may resend NETDEV_UNREGISTER.". As a precaution against this, a check for port == NULL was added in hsr_dev_notify(). Reported-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Fixes: 51f3c605318b056a ("net/hsr: Move slave init to hsr_slave.c.") Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-11net/hsr: Remove left-over never-true conditional code.Arvid Brodin
MacAddressB is an array (unsigned char MacAddressB[ETH_ALEN]) and is allocated as a part of *node_dst (which is a struct hsr_node). So the condition is always false. Detected by Dan Carpenter. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Fix NULL pointer dereference on incomplete hsr_newlink() params.Arvid Brodin
If none of the slave interfaces are specified, struct nlattr *data[] may be NULL. Make sure to check for that. While I'm at it, fix the horrible error messages displayed when only one of the slave interfaces isn't specified. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Better frame dispatchArvid Brodin
This patch removes the separate paths for frames coming from the outside, and frames sent from the HSR device, and instead makes all frames go through hsr_forward_skb() in hsr_forward.c. This greatly improves code readability and also opens up the possibility for future support of the HSR Interlink device that is the basis for HSR RedBoxes and HSR QuadBoxes, as well as VLAN compatibility. Other improvements: * A reduction in the number of times an skb is copied on machines without HAVE_EFFICIENT_UNALIGNED_ACCESS, which improves throughput somewhat. * Headers are now created using the standard eth_header(), and using the standard hard_header_len. * Each HSR slave now gets its own private skb, so slave-specific fields can be correctly set. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Added SET_NETDEV_DEVTYPE and features |= NETIF_F_NETNS_LOCAL to ↵Arvid Brodin
dev_setup. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Implemented .ndo_fix_features (better device features handling).Arvid Brodin
2014-07-08net/hsr: Use list_head (and rcu) instead of array for slave devices.Arvid Brodin
2014-07-08net/hsr: Move slave init to hsr_slave.c.Arvid Brodin
Also try to prevent some possible slave dereference race conditions. This is finalized in the next patch, which abandons the slave array in favour of a list_head list and list RCU. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Operstate handling cleanup.Arvid Brodin
2014-07-08net/hsr: Move to per-hsr device prune timer.Arvid Brodin
2014-07-08net/hsr: Switch from dev_add_pack() to netdev_rx_handler_register()Arvid Brodin
Also move the frame receive handler to hsr_slave.c. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net/hsr: Better variable names and update of contact info.Arvid Brodin
2014-03-27hsr: replace del_timer by del_timer_syncJulia Lawall
Use del_timer_sync to ensure that the timer is stopped on all CPUs before the driver exists. This change was suggested by Thomas Gleixner. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ declarer name module_exit; identifier ex; @@ module_exit(ex); @@ identifier r.ex; @@ ex(...) { <... - del_timer + del_timer_sync (...) ...> } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c net/ipv6/sit.c The SIT driver conflict consists of a bug fix being done by hand in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper was created (netdev_alloc_pcpu_stats()) which takes care of this. The two wireless conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-03hsr: off by one sanity check in hsr_register_frame_in()Dan Carpenter
This is a sanity check and we never pass invalid values so this patch doesn't change anything. However the node->time_in[] array has HSR_MAX_SLAVE (2) elements and not HSR_MAX_DEV (3). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-18hsr: Use ether_addr_copyJoe Perches
It's slightly smaller/faster for some architectures. Make sure def_multicast_addr is __aligned(2) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17net/hsr: using kfree_rcu() to simplify the codeWei Yongjun
The callback function of call_rcu() just calls a kfree(), so we can use kfree_rcu() instead of call_rcu() + callback function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-30net/hsr: Support iproute print_opt ('ip -details ...')Arvid Brodin
This implements the rtnl_link_ops fill_info routine for HSR. Signed-off-by: Arvid Brodin <arvid.brodin@alten.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-30net/hsr: Very small fix of comment style.Arvid Brodin
2013-11-19genetlink: make multicast groups const, prevent abuseJohannes Berg
Register generic netlink multicast groups as an array with the family and give them contiguous group IDs. Then instead of passing the global group ID to the various functions that send messages, pass the ID relative to the family - for most families that's just 0 because the only have one group. This avoids the list_head and ID in each group, adding a new field for the mcast group ID offset to the family. At the same time, this allows us to prevent abusing groups again like the quota and dropmon code did, since we can now check that a family only uses a group it owns. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: pass family to functions using groupsJohannes Berg
This doesn't really change anything, but prepares for the next patch that will change the APIs to pass the group ID within the family, rather than the global group ID. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19hsr: don't call genl_unregister_mc_group()Johannes Berg
There's no need to unregister the multicast group if the generic netlink family is registered immediately after. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: only pass array to genl_register_family_with_ops()Johannes Berg
As suggested by David Miller, make genl_register_family_with_ops() a macro and pass only the array, evaluating ARRAY_SIZE() in the macro, this is a little safer. The openvswitch has some indirection, assing ops/n_ops directly in that code. This might ultimately just assign the pointers in the family initializations, saving the struct genl_family_and_ops and code (once mcast groups are handled differently.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14net/hsr: Fix possible leak in 'hsr_get_node_status()'Geyslan G. Bem
If 'hsr_get_node_data()' returns error, going directly to 'fail' label doesn't free the memory pointed by 'skb_out'. Signed-off-by: Geyslan G. Bem <geyslan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: make all genl_ops users constJohannes Berg
Now that genl_ops are no longer modified in place when registering, they can be made const. This patch was done mostly with spatch: @@ identifier ops; @@ +const struct genl_ops ops[] = { ... }; (except the struct thing in net/openvswitch/datapath.c) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14hsr: use genl_register_family_with_ops()Johannes Berg
This simplifies the code since there's no longer a need to have error handling in the registration. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-03net/hsr: Add support for the High-availability Seamless Redundancy protocol ↵Arvid Brodin
(HSRv0) High-availability Seamless Redundancy ("HSR") provides instant failover redundancy for Ethernet networks. It requires a special network topology where all nodes are connected in a ring (each node having two physical network interfaces). It is suited for applications that demand high availability and very short reaction time. HSR acts on the Ethernet layer, using a registered Ethernet protocol type to send special HSR frames in both directions over the ring. The driver creates virtual network interfaces that can be used just like any ordinary Linux network interface, for IP/TCP/UDP traffic etc. All nodes in the network ring must be HSR capable. This code is a "best effort" to comply with the HSR standard as described in IEC 62439-3:2010 (HSRv0). Signed-off-by: Arvid Brodin <arvid.brodin@xdin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
